T18-2VPFF50IR-Q8
T18-2VPFF50IR-Q8
    BANNER(邦纳)
    T18-2 IR 50MM PNP M12 4PIN
T18-2VPFF50IR-Q8 数据手册
T18-2 Epoxy Encapsulated Right-Angle Sensor Datasheet Next Generation of Self-Contained dc-Operated Sensors • • • • • • • • • • Complete family of sensors, all housed in the compact right angle 18 mm threaded housing designed for long service life in wet environments ECO-Lab certified chemically robust epoxy encapsulated plastic sensors for wash-down applications typically found in the food and beverage industry Epoxy encapsulation of electronics provides a redundant seal in addition to plastic ultrasonic weld joints for maximum reliability in wet thermal shock environments Permanent laser etched product marking will not wear off after repeated cleaning cycles Food grade plastic materials used for all exposed surfaces Hygienic shape for easier cleaning of the sensor Powerful and bright visible red emitter beam for easy alignment and set-up Highly visible output and dual-function power and stability indicators Advanced ASIC technology makes sensor resistant to optical and electrical noise source Wide operating temperature range: –40 °C to +70 °C (–40 °F to +158 °F) WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Integral 4-pin M12/Euro-style quick disconnect models are listed. • To order the 2 m (6 ft) cable model, replace the suffix "-Q8" with "-2M" • To order the 9 m (30 ft) cable model, replace the suffix "-Q8" with "-9M" Models with a quick disconnect require a mating cordset. Emitter Models Visible Red Models Infrared Models T18-2NAEL-Q8 T18-2NAELIR-Q8 T18-2NAEJ-Q8 T18-2NAEJIR-Q8 T18-2NAES-Q8 T18-2NAESIR-Q8 Type Range Output 25 m (82 ft) Emitter 25 m (82 ft) with beam inhibit None 25 m (82 ft) with adjustment Receiver Models Model Range T18-2VNRL-Q8 Output Complementary NPN 25 m (82 ft) T18-2VPRL-Q8 T18-2VNRS-Q8 Complementary PNP Complementary NPN 25 m (82 ft) with adjustment T18-2VPRS-Q8 Complementary PNP Polarized Retroreflective Models Model Range T18-2VNLP-Q8 Output Complementary NPN 6 m (19.7 ft) with BRT-84 reflector T18-2VPLP-Q8 T18-2VNLPC-Q8 Complementary PNP Complementary NPN 6 m (19.7 ft) with BRT-84 reflector, with adjustment T18-2VPLPC-Q8 Complementary PNP Diffuse Models Models with Red Emitters Models with Infrared Emitters T18-2VNDL-Q8 T18-2VNDLIR-Q8 T18-2VPDL-Q8 T18-2VPDLIR-Q8 T18-2VNDS-Q8 – T18-2VPDS-Q8 – Original Document 201875 Rev. D Range 750 mm (29.5 in) with adjustment 300 mm (11.8 in) with adjustment Output Complementary NPN Complementary PNP Complementary NPN Complementary PNP 24 April 2020 201875 T18-2 Epoxy Encapsulated Right-Angle Sensor Fixed Field Models Models with Red Emitters Models with Infrared Emitters T18-2VNFF30-Q8 T18-2VNFF30IR-Q8 T18-2VPFF30-Q8 T18-2VPFF30IR-Q8 T18-2VNFF50-Q8 T18-2VNFF50IR-Q8 T18-2VPFF50-Q8 T18-2VPFF50IR-Q8 T18-2VNFF75-Q8 T18-2VNFF75IR-Q8 T18-2VPFF75-Q8 T18-2VPFF75IR-Q8 T18-2VNFF100-Q8 T18-2VNFF100IR-Q8 T18-2VPFF100-Q8 T18-2VPFF100IR-Q8 T18-2VNFF150-Q8 T18-2VNFF150IR-Q8 T18-2VPFF150-Q8 T18-2VPFF150IR-Q8 T18-2VNFF200-Q8 T18-2VNFF200IR-Q8 T18-2VPFF200-Q8 T18-2VPFF200IR-Q8 Range Output Complementary NPN 30 mm Complementary PNP Complementary NPN 50 mm Complementary PNP Complementary NPN 75 mm Complementary PNP Complementary NPN 100 mm Complementary PNP Complementary NPN 150 mm Complementary PNP Complementary NPN 200 mm Complementary PNP Installing the T18-2 Epoxy Encapsulated Right-Angle Sensor Power Output LED LED * To install the T18-2 Epoxy Encapsulated Right-Angle Sensor: 1. Align the sensor as required for the application. For the most sensitive object detection, align the sensor so that the objects move across the sensor's axis. 2. Secure the sensor to a bracket. 3. Wire sensor as shown in the wiring diagrams. 4. Adjust the gain adjuster (sensitivity pot) if necessary. Gain Adjustment * * Applicable models Wiring Diagrams Emitter brown Emitter with Active High Beam Inhibit bu (3) + 10–30 V DC blue Complementary NPN – 3 1 4 − 10-30V dc + bn (1) 10-30V dc wh (2) bk (4) – 10–30 V dc + Load Load Complementary PNP bn (1) + 10–30 V dc – bu (3) bk (4) wh (2) Load Load Specifications Supply Voltage 10 V dc to 30 V dc for ambient temperature ≤ 55 °C 10 V dc to 24 V dc for ambient temperature > 55 °C Supply Current (Exclusive of Load Current) All models except FF IR: < 16 mA FF IR models: < 25 mA Output Protection Circuitry Protected against false pulse on power-up and continuous short circuit of outputs. Short circuit protection at elevated temperature may require a power cycle to reset. Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Rating ≤ 50 mA total current for ambient temperatures > 55 °C ≤ 100 mA total current through both outputs ≤ 55 °C OFF-State Leakage Current: < 50 µA at 30 V dc ON-State Saturation Voltage: < 1.5 V at 10 mA; < 3.0 V at 100 mA Output Configuration Complementary PNP or NPN by model number Emitter LED Visible Red on most models Infrared 850 nm on select models Infrared fixed-field models provide higher excess gain on green and blue targets 2 Output Response Time Response is independent of signal strength Opposed models: 1.5 milliseconds ON, 1 millisecond OFF Polarized Retro, and Diffuse models: 1.5 milliseconds ON, 0.75 milliseconds OFF Fixed Field models: 2 milliseconds ON, 2 milliseconds OFF Delay on Power-up: 100 milliseconds; outputs do not conduct during this time Repeatability Repeatability is independent of signal strength Opposed models: 300 microseconds Retro, Polarized Retro, and Diffuse models: 100 microseconds Fixed Field models: 200 microseconds Adjustments Diffuse (DL, DS), Emitter (ES), Receiver (RS), Polarized Retroreflective (LPC) models: Single turn sensitivity (gain) adjustment potentiometer Emitter Beam Inhibit (EJ) models: Tie black wire to 10 to 30 V dc for beam inhibit Construction Housing, M12 QD, and cover: Black or Yellow PBT polyester Indicator light pipes: Translucent white PMMA (acrylic) Indicator cover and gain pot driver: PBT polyester Front window: PMMA www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 201875 Rev. D T18-2 Epoxy Encapsulated Right-Angle Sensor Indicators Two LEDs (1 green, 1 amber) Green Solid: Indicates power applied and sensor ready Green flashing: Indicates marginal sensing signal Amber solid: Indicates Pin-4 (black wire) conducting Vibration and Mechanical Shock All models meet Mil. Std. 202G requirements. Method 201A (Vibration; frequency 10 to 60 Hz, max., double amplitude 0.06 in acceleration 10G). Method 213B conditions H&I (Shock: 75G with unit operating; 100G for nonoperation) Operating Conditions –40 °C to +70 °C (–40 °F to +158 °F) 95% at +50 °C maximum relative humidity (non-condensing) Environmental Rating IEC IP67 per IEC60529 IEC IP68 per IEC60529 IP69K per DIN 40050-9 Certifications Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Class 2 power UL Environmental Rating: Type 1 Industrial Control Equipment 3TJJ Chemical compatibility certified ECOLAB is a registered trademark of Ecolab USA Inc. All rights reserved. Performance Curves Diffuse Models (300 mm Range) Beam Pattern Excess Gain 20 15 5 0 EXCESS GAIN BEAM PATTERN (mm) 1000 10 −5 −10 100 10 −15 −20 0 50 10 0 15 0 20 0 25 0 30 0 35 0 1 40 0 DISTANCE (mm) 10 1 100 DISTANCE (mm) 1000 Diffuse Models (750 mm Range) Beam Pattern Excess Gain 50 40 30 20 10 0 10 20 30 40 50 Visible 750mm EXCESS GAIN BEAM PATTERN (mm) 100 IR 750mm 0 100 200 300 400 500 DISTANCE (mm) 600 700 800 10 1 1 10 100 1000 DISTANCE (mm) P/N 201875 Rev. D www.bannerengineering.com - Tel: + 1 888 373 6767 3 T18-2 Epoxy Encapsulated Right-Angle Sensor Emitter/Receiver Models (Effective Beam Size: 15.2 mm) Beam Pattern Excess Gain 2000 1600 1200 800 400 0 400 800 1200 1600 2000 EXCESS GAIN BEAM PATTERN (mm) 1000 0 5 10 15 20 100 10 25 DISTANCE (m) 1 0.1 1 10 100 DISTANCE (m) Polarized Retroreflective Models Beam Pattern Excess Gain 100 BRT-92x92C BRT-84 BRT-60x40C BRT-40x19A BRT-60x40IP BRT-THG-2-100 40 EXCESS GAIN BEAM PATTERN (mm) 60 20 0 - 20 10 - 40 - 60 0 1 2 3 4 5 6 DISTANCE (m) 1 0.01 0.1 1 10 DISTANCE (m) Fixed Field Models - Excess Gain (Applies to both Visible Red and IR models) Target for Excess Gain Curves use a 90% Reflective White Card 1000 100 EXCESS GAIN EXCESS GAIN 1000 10 1 1 10 100 1000 100 10 1 1 T18-2FF30 Emitter Image Size: 4.0 mm square at 15 mm and 3.5 mm square at 30 mm 18% Gray Test Card: Cutoff distance will be 98% of value shown 6% Black Test Card: Cutoff distance will be 95% of value shown 4 10 100 1000 DISTANCE (mm) DISTANCE (mm) T18-2FF50 Emitter Image Size: 4 mm square at 25 mm and 3 mm square at 50 mm 18% Gray Test Card: Cutoff distance will be 98% of value shown 6% Black Test Card: Cutoff distance will be 95% of value shown www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 201875 Rev. D T18-2 Epoxy Encapsulated Right-Angle Sensor Fixed Field Models - Excess Gain (Applies to both Visible Red and IR models) Target for Excess Gain Curves use a 90% Reflective White Card 1000 EXCESS GAIN 1000 EXCESS GAIN 100 10 10 100 10 1 1 mm (0.04") 1 1 100 1000 T18-2FF75 Emitter Image Size: 4.5 mm square at 37 mm and 4.0 mm square at 75 mm 18% Gray Test Card: Cutoff distance will be 98% of value shown 6% Black Test Card: Cutoff distance will be 92% of value shown 100 EXCESS GAIN 100 EXCESS GAIN 1000 10 100 mm (4") 1000 mm (40") T18-2FF100 Emitter Image Size: 4.5 mm square at 50 mm and 4.5 mm square at 100 mm 18% Gray Test Card: Cutoff distance will be 95% of value shown 6% Black Test Card: Cutoff distance will be 90% of value shown 1000 10 mm (0.4") 100 mm (4") DISTANCE DISTANCE (mm) 1 1 mm (0.04") 10 mm (0.4") 1000 mm (40") 10 1 1 mm (0.04") DISTANCE 10 mm (0.4") 100 mm (4") 1000 mm (40") DISTANCE T18-2FF150 Emitter Image Size: 5 mm square at 75 mm and 8 mm square at 150 mm 18% Gray Test Card: Cutoff distance will be 90% of value shown 6% Black Test Card: Cutoff distance will be 70% of value shown T18-2FF200 Emitter Image Size: 5 mm square at 100 mm and 8 mm square at 200 mm 18% Gray Test Card: Cutoff distance will be 85% of value shown 6% Black Test Card: Cutoff distance will be 60% of value shown Dimensions All measurements are listed in millimeters [inches], unless noted otherwise. P/N 201875 Rev. D www.bannerengineering.com - Tel: + 1 888 373 6767 5 T18-2 Epoxy Encapsulated Right-Angle Sensor Accessories Cordsets All measurements are listed in millimeters, unless noted otherwise. 4-Pin Threaded M12/Euro-Style Cordsets—Washdown, Stainless Steel, Single Ended Model Length MQDC-WDSS-0406 2 m (6.56 ft) MQDC-WDSS-0415 5 m (16.4 ft) Style Dimensions Pinout (Female) 1 Straight MQDC-WDSS-0430 4 Ø15.5 mm 2 3 Ø4.8 mm 9 m (29.5 ft) 1 = Brown 2 = White 3 = Blue 4 = Black 43.5 mm 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC-406 2 m (6.56 ft) MQDC-415 5 m (16.4 ft) MQDC-430 9 m (29.5 ft) MQDC-450 15 m (49.2 ft) MQDC-406RA 2 m (6.56 ft) MQDC-415RA 5 m (16.4 ft) MQDC-430RA 9 m (29.5 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 30 Typ. [1.18"] 15 m (49.2 ft) 1 4 32 Typ. [1.26"] Right-Angle MQDC-450RA Pinout (Female) 2 3 1 = Brown 2 = White 3 = Blue 4 = Black M12 x 1 ø 14.5 [0.57"] 6 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 201875 Rev. D T18-2 Epoxy Encapsulated Right-Angle Sensor Apertures Model Units Aperture Description Product AP18SCN 3 Kit includes round apertures of 0.5 mm (0.02 in), 1.0 mm (0.04 in), and 2.5 mm (0.10 in) diameter. AP18SRN 3 Kit includes rectangular apertures of 0.5 mm (0.02 in), 1.0 mm (0.04 in), and 2.5 mm (0.10 in) wide. Each kit also includes a thread-on housing, Teflon® FEP® lens, and o-ring. APG18S 1 Kit with glass lens to protect plastic sensor lens from chemical environments and weld splatter damage. Brackets SMB18A • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware 30 C A 41 B 46 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 SMB18FA..-SS • Swivel bracket with tilt and pan movement for precision adjustment • Easy sensor mounting to extruded rail T-slots • Stainless steel • Metric and inch size bolts available • 18 mm sensor mounting hole SMB18FA.. • Swivel bracket with tilt and pan movement for precision adjustment • Easy sensor mounting to extruded rail T-slots • Metric and inch size bolts available • 18 mm sensor mounting hole 66 B 69 A Hole size: B=ø 18.1 66 B Model Bolt Thread (A) SMB18FA 3/8 - 16 × 2 in SMB18FAM10 M10 - 1.5 × 50 SMB18FAM12 n/a; no bolt included. Mounts directly to 12 mm (½ in) rods ACC-T18-2-GSK-FDA-10 Gasket Kit • FDA approved blue silicon • 18 mm ID; 27 mm OD; 0.79 mm thick • Quantity: 10 0.79 69 A Ø18 Ø27 Hole size: B=ø 18.1 Model Bolt Thread (A) SMB18FA-SS 3/8 - 16 × 2 in SMB18FAM10-SS M10 - 1.5 × 50 SMB18FAM12-SS n/a; no bolt included. Mounts directly to 12 mm (½ in) rods For additional brackets, check the current Banner catalog or visit www.bannerengineering.com. All measurements are listed in millimeters, unless noted otherwise. P/N 201875 Rev. D www.bannerengineering.com - Tel: + 1 888 373 6767 7 T18-2 Epoxy Encapsulated Right-Angle Sensor Reflectors BRT-2X2 • Square, acrylic target • Reflectivity factor: 1.0 • Max. temperature: +50 °C (+122 ºF) • Optional brackets are available • Approximate size: 51 mm × 51 mm BRT-84X84A • Square, acrylic target • Reflectivity Factor: 2.0 • Temperature: –20 °C to +60 °C (–4 °F to +140 °F) • Approximate size: 84 mm × 84 mm BRT-40X19A • Rectangular, acrylic target • Reflectivity Factor: 1.3 • Temperature: –20 °C to +60 °C (–4 °F to +140 °F) • Approximate size: 19 mm × 60 mm overall; 19 mm × 40 mm reflector BRT-60X40C • Rectangular, acrylic target • Reflectivity Factor: 1.4 • Temperature: –20 °C to +60 °C (–4 °F to +140 °F) • Optional brackets are available • Approximate size: 40 mm × 60 mm BRT-60X40IP69K • Rectangular, acrylic target (color is amber) • Reflectivity Factor: 0.7 • Temperature: –20 °C to +140 °C (–4 °F to +284 °F) • Chemically resistant • IP69K washdown rated • Optional brackets are available • Approximate size: 40 mm × 60 mm BRT-60X40AF • Rectangular, acrylic target • Reflectivity Factor: 1.4 • Temperature: –20 °C to +60 °C (–4 °F to +140 °F) • Anti-fogging coating for use around steam • Optional brackets are available • Approximate size: 40 mm × 60 mm BRT-84 • Round, acrylic target • Reflectivity Factor: 1.4 • Temperature: –20 °C to +60 °C (–4 °F to +140 °F) • Optional brackets are available • Size: 84 mm diameter • Mounting Hole: 4.5 mm diameter Retroreflective Tape Model Reflectivity Factor Maximum Temperature Size BRT-THG-2-100 0.7 +60 °C (+140 °F) 50 mm (2 in) wide, 2.5 m (100 in) long Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
T18-2VPFF50IR-Q8
物料型号:T18-2
器件简介:这是一款新一代自包含直流操作传感器,专为食品和饮料行业中常见的冲洗应用设计,具有化学稳定性强的环氧树脂封装塑料传感器,以实现在潮湿环境中的长期服务寿命。
引脚分配:文档中提到了4针M12/欧式快速断开型号,具体引脚分配为: - Brown (3): 10-30V DC - Blue (4): 10-30V DC - Bu (3): 10-30V DC - Bn (1): 10-30V DC
参数特性: - 工作温度范围:-40°C 至 +70°C - 电源电压:10V DC 至 30V DC(环境温度 ≤ 55°C),10V DC 至 24V DC(环境温度 > 55°C) - 电源电流:除FF IR型号外 < 16 mA,FF IR型号 < 25 mA - 输出响应时间:对射型1.5ms ON, 1ms OFF;极化反射型和漫反射型1.5ms ON, 0.75ms OFF;固定场型2ms ON, 2ms OFF
功能详解: - 传感器具有高亮度的可见红发射器光束,便于对齐和设置。 - 高度可见的输出和双功能电源及稳定性指示器。 - 采用先进的ASIC技术,使传感器对光学和电气噪声源具有抗干扰性。
应用信息:传感器适用于需要在潮湿环境中长期稳定工作的场合,如食品和饮料行业。
封装信息:传感器采用紧凑的直角18mm螺纹外壳设计,外壳材料为食品级塑料,所有暴露表面均使用食品级塑料材料,形状卫生,便于清洁。
T18-2VPFF50IR-Q8 价格&库存
很抱歉,暂时无法提供与“T18-2VPFF50IR-Q8”相匹配的价格&库存,您可以联系我们找货
T18-2VPFF50IR-Q8
  • 1+1167.917631+150.93245
库存:4
T18-2VPFF50IR-Q8
  • 1+1228.19753
库存:2
