SME312LPCQD
SME312LPCQD
    BANNER(邦纳)
    PHOTO SEN 1M 1 NPN 1 PNP
SME312LPCQD 数据手册
MINI-BEAM Expert Series Quick Start Guide Microprocessor-Based TEACH Mode Photoelectric Sensors This guide is designed to help you set up and install the MINI-BEAM® Expert™. For complete information on programming, performance, troubleshooting, dimensions, and accessories, please refer to the Instruction Manual at www.bannerengineering.com. Search for p/n 55214 to view the Instruction Manual. Use of this document assumes familiarity with pertinent industry standards and practices. WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. U.S. patent(s) issued or pending Models Retroreflective Models Model1 Sensing Mode Range or Focus2 SME312LV Retroreflective, Visible red, 650 nm 5 m (15 ft) SME312LP Polarized retroreflective, Visible red, 650 nm 10 mm to 3 m (0.4 in to 10 ft) SME312LPC Polarized retroreflective, Visible red, 650 nm (clear object) 1 m (3.3 ft) with supplied reflector Model1 Sensing Mode Range or Focus SME312D Diffuse, Infrared, 880 nm 380 mm (15 in) SME312DV Diffuse, Visible red, 650 nm 1100 mm (43 in) SME312W Divergent Diffuse, Infrared, 880 nm 130 mm (5 in) Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP Diffuse Models Convergent Models Model1 Sensing Mode Range or Focus Spot Size at Focus SME312CV Convergent, Visible red, 650 nm 16 mm (0.65 in) 1.3 mm (0.05 in) SME312CV2 Convergent, Visible red, 650 nm 43 mm (1.7 in) 3.0 mm (0.12 in) SME312CVG Convergent, Visible green, 525 nm 16 mm (0.65 in) 1.0 mm (0.04 in) SME312CVB Convergent, Visible blue, 475 nm 16 mm (0.65 in) 1.8 mm (0.07 in) SME312CVW Convergent, Visible white, 450–650 nm 1 Standard 2 m (6.5 ft) cable models are listed. To order the 9 m (30 ft) cable model, add suffix “W/30” to the model number (for example, SME312LV W/30.) To order the 5-pin Euro-style QD models, add suffix “QD” (for example, SME312LVQD). Models with a QD connector require a mating cable. 2 Sensing ranges vary according to the efficiency and reflective area of the retroreflector(s) used. (Retroreflective tape is not recommended for use with Clear Object Detection models.) See Accessories and the Banner Engineering catalog for more information. Original Document 68812 Rev. C 13 July 2016 68812 MINI-BEAM Expert Series Glass Fiber Optic Models Model1 Sensing Mode SME312F Glass Fiber Optic, 880 nm infrared SME312FV Glass Fiber Optic, Visible red, 650 nm SME312FVG Glass Fiber Optic, Visible green, 525 nm SME312FVB Glass Fiber Optic, Visible blue, 475 nm SME312FVW Glass Fiber Optic, Visible white, 450–650 nm Range or Focus Range varies by sensing mode and fiber optics used Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP Supply Voltage Output Type 10 V dc to 30 V dc Bipolar NPN/PNP Plastic Fiber Optic Models Model1 Sensing Mode SME312FP Plastic Fiber Optic, Visible red, 650 nm SME312FPG Plastic Fiber Optic, Visible green, 525 nm SME312FPB Plastic Fiber Optic, Visible blue, 475 nm SME312FPW Plastic Fiber Optic, Visible white, 450–650 nm Range or Focus Range varies by sensing mode and fiber optics used Overview Amber output indicator LED Bi-color green/red indicator LED MINI-BEAM® Expert™ is a complete family of sensors, all housed in the popular, robust and compact rectangular housing. Their large push button and easy-to-see indicators provide easy configuration, alignment, and monitoring during use. Status Indicators Normal sensor operation is called RUN mode. Sensor configuration (setting the sensitivity threshold and selecting output ON and OFF conditions) is performed in TEACH mode. The two LED indicators (bi-color green/red and amber) have distinct roles in the two operation modes. If contrast is marginal, the bi-color indicator will flash green to indicate instability. If this occurs, reconfigure or realign the sensor, or clean the sensor or fiber lenses. The Signal Strength indicator is Banner’s exclusive AID™ (Alignment Indicating Device). Its pulse rate increases as the received light signal strength increases (during programming). This feature simplifies accurate alignment during TEACH mode, and gives a relative indication of sensing contrast between the light and dark conditions. LED RUN Mode Solid green Power is on Flashing green Sensed light level is approaching sensing threshold3 Solid red TEACH Mode Sensor “sees” its own modulated light source; pulse rate is proportional to the received light signal strength4 Amber on Outputs conducting Ready to TEACH output ON condition Amber off Outputs not conducting Ready to TEACH output OFF condition 3 This is the Stability indicator, which signals when maintenance, realignment, or reconfiguration is needed during RUN mode. 4 The faster the pulse rate, the stronger the light signal. 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 68812 Rev. C MINI-BEAM Expert Series Remote Configuration The remote function can be used to configure the sensor remotely or to disable the push button for security. Connect the gray wire of the sensor to ground (0 V dc), with a remote programming switch connected between them. Pulse the remote line according to the diagrams in the configuration procedures. The length of the individual programming pulses is equal to the value T where: 0.04 seconds ≤ “T” ≤ 0.8 seconds Installation Wiring Diagrams QD Models Cabled Models bn bu wh bk gy bn bu wh bk gy + 10-30V dc – Load Load Remote Teach + 10-30V dc – Load Load Remote Teach Glass Fiber Installation Retaining Clip O-ring 1. Install the O-ring (supplied with the fiber) on each fiber end, as shown in the drawing. 2. While pressing the fiber ends firmly into the ports on the sensor front, slide the U-shaped retaining clip (supplied with the sensor) into the slot in the sensor's barrel, until it snaps into place. Plastic Fiber Installation Gripper Unlock Lock Sensor Face Adapters for 0.25- and 0.5-mm fibers Trimmed fiber control ends 1. With supplied fiber cutter, make a clean cut at the control ends of fibers. 2. Unlock the fiber gripper as shown in the drawing. 3. Apply appropriate fiber adaptors to the fiber, if needed. 4. Gently insert the prepared fiber ends into the ports as far as they will go. 5. Slide the fiber gripper back to lock, as shown in the drawing. Plastic fiber receiver port Plastic fiber emitter port P/N 68812 Rev. C www.bannerengineering.com - Tel: +1-763-544-3164 3 MINI-BEAM Expert Series Static Teach 2nd Taught Condition 1st Taught Condition Sensor positions threshold between taught conditions Output OFF Output ON The two sensing conditions may be presented in either order. The condition presented first is the condition for which the output will energize (the “Output ON” target). Sensitivity is automatically set (and optimized) when teaching the sensor the ON and OFF conditions. When the push button is clicked, the sensor samples each sensing condition and registers it into memory. After the second sensing condition is registered, the MINI-BEAM Expert automatically sets the sensitivity to the optimum value for the application, and then returns to RUN mode. Push button (0.04 seconds ≤ “Click” ≤ 0.8 seconds); Remote line (0.04 seconds ≤ “T” ≤ 0.8 seconds) 1. Access TEACH mode. Method Action Result Via push button Press and hold push button until the bi-color (green/ red) indicator begins to flash red, or turns OFF. Push button method only: The amber LED is on. The red LED pulses to indicate relative received signal strength. The sensor is ready for the output ON condition. Via remote line No action required; sensor is ready for 1st sensing condition. 2. Teach the first sensing condition. Method Action Via push button Present the first sensing condition and click the push button. Via remote line Result The amber LED is off. The red LED pulses to indicate relative signal strength. The sensor registers the output ON condition and is ready for the output OFF Present the first sensing condition and single-pulse the condition. remote line. 3. Teach the second sensing condition and return to RUN mode. Method Action Result Via push button Present the second sensing condition and click the push button. Via remote line Present the second sensing condition and single-pulse the remote line. If the teach is accepted the green LED is on (or flashes if the signal is close to the switching threshold) and the amber LED is off until the sensing condition changes; the sensor registers the output OFF condition, positions the threshold, and returns to RUN mode. If the teach is not accepted, the amber LED is on and the red LED pulses to indicate the relative received signal strength. The sensor returns to its wait state and is ready for the first sensing condition. NOTE: The sensor returns to RUN mode if the first TEACH condition is not registered within 90 seconds. TEACH mode may be cancelled before either the first or second condition by holding the push button depressed for more than two seconds. Enabling or Disabling the Push Button In addition to its programming function, the remote line may be used to disable the push buttons for security. Disabling the push buttons prevents undesired tampering with the sensor configuration settings. 1. Connect the sensor’s gray wire. 2. Four-pulse the remote line to enable or disable the push button. The sensor toggles between enable and disable settings and returns to RUN mode. 4 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 68812 Rev. C MINI-BEAM Expert Series Specifications Supply Voltage and Current 10 V dc to 30 V dc (10% maximum ripple) at less than 45 mA, exclusive of load Supply Protection Circuitry Protected against reverse polarity and transient voltages Adjustments Push-button TEACH mode sensitivity setting; remote TEACH mode input is provided Indicators Two LEDs: amber and bi-color green/red Construction Reinforced thermoplastic polyester housing, totally encapsulated, oring seal, acrylic lenses, and stainless steel screws. Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to http:// www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Connections PVC-jacketed 5-conductor 2 m (6.5 ft) or 9 m (30 ft) unterminated cable, or 5-pin Euro-style quick-disconnect (QD) fitting are available. QD cables are ordered separately. Application Notes The first condition presented during TEACH mode becomes the output ON condition. Output Configuration Bipolar: One current sourcing (PNP) and one current sinking (NPN) open-collector transistor Output Rating 150 mA maximum each output at 25° C, derated to 100 mA at 70° C (derate ≈1 mA per °C) Off-state leakage current: less than 5 μA at 30 V dc ON-state saturation current: less than 1 V at 10 mA; less than 1.5 V at 150 mA Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short-circuit of outputs Output Response Time Sensors will respond to either a “light” or a “dark” signal of 500 microseconds or longer duration, 1 kHz max. NOTE: 1 second delay on power-up; outputs do not conduct during this time. Repeatability 100 microseconds (all models) Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 6, 12, and 13; IEC IP67 Operating Conditions Temperature: –20° to +70° C (–4° to +158° F) Max. Relative Humidity: 90% at 50° C (non-condensing) Troubleshooting If the MINI-BEAM Expert’s Power LED alternately flashes red/green, this indicates a microprocessor memory error. To clear the error, re-teach the sensor or cycle the power ON and OFF and re-teach the sensor. If this does not solve the problem, or if it occurs frequently, replace the sensor. Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Copyright Notice Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved. www.bannerengineering.com - Tel: +1-763-544-3164
SME312LPCQD 价格&库存
很抱歉,暂时无法提供与“SME312LPCQD”相匹配的价格&库存,您可以联系我们找货
SME312LPCQD
  • 1+1962.482981+254.81866
库存:5
