QS18VP6CV45Q5
QS18VP6CV45Q5
    BANNER(邦纳)
    PHOTO SEN 43MM PNP
QS18VP6CV45Q5 数据手册
WORLD-BEAM® QS18 Series Sensor Quick Start Guide Miniature Self-Contained Photoelectric Sensors In Universal-Mount Housing This guide is designed to help you set up and install the WORLD-BEAM® QS18. For complete information on programming, performance, troubleshooting, dimensions, and accessories, please refer to the Instruction Manual at www.bannerengineering.com. Search for p/n 197052 to view the Instruction Manual. Use of this document assumes familiarity with pertinent industry standards and practices. WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Original Document 197051 Rev. D 28 September 2020 197051 WORLD-BEAM® QS18 Series Sensor Models Model1 Sensing Mode Output Type QS186E Emitter QS186EV QS18VN6R NPN QS18VN6DB QS18VP6DB 20 m (66 ft) Opposed Sensing Mode Output Type NPN 450 mm (18 in) Diffuse PNP QS18VN6DL QS18VP6DL OPPOSED NPN 600 mm (23.6 in) Diffuse DIFFUSE QS18VN6DVS QS18VP6R PNP NPN PNP QS18VP6DVS OPPOSED 250 mm (10 in) Diffuse Visible red PNP DIFFUSE QS186EB Emitter QS18VN6RB QS18VP6RB Model1 NPN 3 m (10 ft) Opposed PNP OPPOSED QS18VN6W QS18VP6W DIVERGENT 100 mm (4 in) Divergent Diffuse NPN PNP DIFFUSE QS18VN6LP QS18VP6LP NPN 3.5 m (12 ft) Polarized Retro QS18VN6FF50 QS18VP6FF50 P PNP QS18VN6FF100 QS18VP6FF100 POLAR RETRO QS18VP6FF125 NPN QS18VN6LV QS18VN6FF150 QS18VP6LV QS18VP6FF150 6.5 m (21 ft) Non-Polarized Retro PNP QS18VN6FP NPN QS18VP6FP RETRO QS18VN6CV15 QS18VP6CV15 16 mm (0.63 in) Convergent PNP QS18VN6F NPN QS18VP6F CONVERGENT VISIBLE RED QS18VN6CV45 QS18VP6CV45 43 mm (1.7 in) Convergent 50 mm (2 in) Fixed-Field NPN 100 mm (4 in) Fixed-Field NPN 125 mm (5 in) Fixed-Field PNP PNP FIXED-FIELD NPN 150 mm (6 in) Fixed-Field PNP NPN 220 mm (8.7 in) Individual (Opposed) 60 mm (2.4 in) Bifurcated (Diffuse) Range specified using 1.5 mm plastic fiber optics PNP PLASTIC FIBER NPN 500 mm (20 in) Individual (Opposed) 38 mm (1.5 in) Bifurcated ( Diffuse) Range specified using 3.2 mm plastic fiber optics PNP PNP GLASS FIBER PNP CONVERGENT VISIBLE RED QS18VN6D QS18VP6D NPN 450 mm (18 in) Diffuse PNP DIFFUSE 1 Integral 2 m (6.5 ft) unterminated cable models are listed. • To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. For example, QS186E W/30. • To order the 4-pin M12/Euro-style integral quick disconnect model, add the suffix "Q8" to the model number. For example, QS186EQ8. • To order the 150 mm (6 in) PVC cable model with a 4-pin M12/Euro-style quick disconnect, add the suffix "Q5" to the model number. For example, QS186EQ5. • To order the 4-pin M8/Pico-style integral quick disconnect model, add the suffix "Q7" to the model number. For example, QS186EQ7. • To order the 150 mm (6 in) PVC cable model with a 4-pin M8/Pico-style quick disconnect, add the suffix "Q" to the model number. For example, QS186EQ. 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 197051 Rev. D WORLD-BEAM® QS18 Series Sensor Wiring Diagrams QS18 with NPN Outputs bu (3) wh (2) bn (1) – 10–30 V dc + bn (1) bk (4) QS18 with PNP Outputs bk (4) wh (2) Load 4-pin M12/Euro-style Models (Male) 2 3 + 10–30 V dc – bu (3) Load QS18 Emitters brown + 10–30 V DC Load blue Load 4-pin M8/Pico-style Models (Male) 1 2 4 4 1 3 – Key 1 = Brown 2 = White 3 = Blue 4 = Black Specifications Supply Voltage 10 V dc to 30 V dc (10% maximum ripple) at less than 25 mA, exclusive of load Protected against reverse polarity and transient voltages Repeatability Opposed Mode: 100 microseconds DVS, DL and FF Modes: 90 microseconds All Other Modes: 150 microseconds Light Source Glass Fiber Optic, Opposed and Diffuse mode models: Infrared, 940 nm Plastic Fiber Optic, Retroreflective, Convergent models: Visible red, 660 nm Fixed-Field and DVS models: Visible red, 630 nm Output Configuration Solid-state complementary (SPDT): NPN or PNP (current sinking or sourcing), depending on model; Rating: 100 mA maximum each output at 25 °C DVS, DL and FF Modes ON-state Saturation Voltage: less than 1.5 V at 10 mA; less than 3 V at 100 mA All Other Modes: ON-state Saturation Voltage: less than 1 V at 10 mA; less than 1.5 V at 100 mA Protected against false pulse on power-up and continuous overload or short circuit of outputs Adjustments Glass Fiber Optic, Plastic Fiber Optic, Convergent, Diffuse, and Retroreflective mode models (only): Single-turn sensitivity (Gain) adjustment potentiometer Indicators 2 LED indicators on sensor top Green: Power on Amber: Light sensed Amber flashing: Marginal excess gain (1 to 1.5 times excess gain) Certifications Output Response Opposed Mode: 750 microseconds ON; 375 microseconds OFF DVS, FF and DL Modes: 850 microseconds ON/OFF All Other Modes: 600 microseconds ON/OFF 100 millisecond delay on power-up; outputs do not conduct during this time Construction ABS housing 3 mm mounting hardware included Connections 2 m (6.5 ft) 4-wire PVC cable; 9 m (30 ft) 4-wire PVC cable; 4-pin M8/Picostyle or M12/Euro-style QD; or 150 mm (6 in) cable with a 4-pin M8/Picostyle or M12/Euro-style QD, depending on model Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 P/N 197051 Rev. D Environmental IEC IP67; NEMA 6 Operating Conditions –20 °C to +70 °C (–4 °F to +158 °F) 95% at +50 °C maximum relative humidity (non-condensing) Vibration and Mechanical Shock All models meet MIL-STD-202F, Method 201A (Vibration: 10 Hz to 60 Hz maximum, 0.06 inch (1.52 mm) double amplitude, 10G maximum acceleration) requirements. Also meets IEC 60947-5-2 (Shock: 30G 11 ms duration, half sine wave) requirements. Note: For performance specifications of the FF50 and FF100 models built prior to date code 17090, refer to document p/n 63908. www.bannerengineering.com - Tel: + 1 888 373 6767 3 WORLD-BEAM® QS18 Series Sensor Dimensions All measurements are listed in millimeters [inches], unless noted otherwise. Model Suffix E, EV, R, FF Model Suffix EB, RB 31.0 mm (1.22") 17.1 mm (0.67") 15.0 mm (0.59") Yellow LED Green LED 3.0 mm (0.12") Model Suffix DB, W 21.1 mm (0.82") 21.1 mm (0.82") 3.0 mm (0.12") 3.0 mm (0.12") Model Suffix FP 27.5 mm (1.09") 15.0 mm (0.59") 17.1 mm (0.67") 7.5 mm (0.30") 13.4 mm (0.53") 24.1 mm (0.95") 35.0 mm (1.38") 5.2 mm (0.21") 7.6 mm (0.30") Ø3.3 mm (0.13") Max. torque 0.9 Nm (8 lbf. in) Model Suffix F Model Suffix CV15, CV45, D, DL, LV, LP QS18...FP Fiber Installation A C † Single-turn Sensitivity Adjustment † 31.0 mm (1.22") 3.0 mm (0.12") CV Models: 33.2 mm (1.31") 17.1 mm (0.67") 36.9 mm (1.45") M18x1 Thread Max. torque 2.3 Nm (20 lbf. in) A. Slide the fiber clip to open. B. Insert fiber ends into each port, as far as they will go. C. Slide the fiber clip closed, locking fibers into position. 19.8 mm (0.78") *Model Suffix Q *Model Suffix Q5 *Model Suffix Q7 *Model Suffix Q8 (e.g. QS186EQ) (e.g. QS186EQ5) (e.g. QS186EQ7) (e.g. QS186EQ8) Slot for Fiber Clip 41.5 mm (1.63") M18 x 1 Jam Nut Packing List Sensor M18 x 1 jam nut M3 hardware packet Installation sheet P/N 63687 24.2 mm(0.95") 8.0 mm(0.32") B M3 2– 2– 2– Hardware Packet Contents: M3 x 0.5 x 20 mm SS screw M3 x 0.5 SS hex nut M3 SS washer 150 mm (6") Pico-Style Pigtail 150 mm (6") Euro-Style Pigtail Integral 4-pin Pico-Style QD 49 mm (1.93") Integral 4-pin Euro-Style QD Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
QS18VP6CV45Q5 价格&库存
很抱歉,暂时无法提供与“QS18VP6CV45Q5”相匹配的价格&库存,您可以联系我们找货
