SM750
LynxExp Embedded Graphics Processor
The SM750 is a PCI Express 2D multimedia mobile display controller device, packaged in a 265-pin BGA.
Designed to complement needs for the embedded industry, it provides video and 2D capability. To help reduce
system costs, it supports a wide variety of I/O, including analog RGB and digital LCD Panel interfaces, two Zoom
Video interfaces, and Pulse Width Modulation (PWM). There are additional GPIO bits that can be used to
interface to external devices as well.
The 2D engine includes a front-end color space conversion with 4:1 and 1:8 scaling support. The video engine
supports two different video outputs (Dual Monitor), at 8-bit, 16-bit, or 32-bit per pixel and a 3-color hardware
cursor per video output. The LCD panel video pipe supports a back-end YUV color space conversion with 4:1 and
1:212 scaling. A Zoom Video (ZV) port is also included to interface to external circuitry for MPEG decode or TV
input.
APPLICATIONS
Thin Client
Handheld / Portable Device
Server
Gaming Machine
IPC / POS / MFP / DVR
Test Instrument
Factory Automation (HMI)
Digital Signage
Medical Device
All Other Embedded Graphics Applications
FEATURES
PCI-Express x 1 Architecture
- X86 processors
- ARM, MIPS, PPC, and ARC processors
16MB Integrated Video DDR Memory
- Embedded 16MB DDR only
- Embedded 16MB DDR (32Bit I/F) + external 16MB
DDR (32Bit I/F)
- External up to 64MB DDR (64bit I/F)
Low Power Consumption < 1.5W
Serial EEPROM Interface
DMA Controller
GPIO/I2C/SSP Interface
SPECIFICATION
Graphics Engine
2D
Cost-Effective Multi-Display/Panel Supports
Host Interface
PCIe x 1
- Dual 300 MHz DAC supports up to 1920x1200
resolution
- Dual 18-bit DVO interface for TMDS or LVDS
transmitter supports up to 1920x1200 resolution
- Independent resolution and refresh rates for dual
display types
Int. Memory
16MB DDR (option)
Ext. Memory
64MB DDR (max)
Resolution
1920 x 1200 (max)
Software Support
WinCE, WinXP, Win7, Win8, Win8.1,
Quick-Rotation Features
- Allow for 90º, 180º, and 270º rotation of on-screen
images
2D Graphic Accelerator
Win2008(32-bit/64-bit),Win2012(32-bit/64-bit),
Linux Enterprise(32-bit/64-bit)
CPU Platform
Intel, AMD, ZFMicro, Freescale PPC, AMCC,
STMicro, Marvell, Loongson and other PCIe
Operation
C-Temp & I-Temp
Temperature
Package
265-pin BGA MCM (17mm x 17mm)
- 128-bit 2D graphic engine
- ROP3’s, BitBLT, transparent BLT, pattern BLT, color
expansion, and line drawing
- YUV-16/32-bit RGB conversion
Video Display Layers
- Support 7 layers of display frames (2 hardware
cursors, primary graphic, video, video alpha, alpha,
and secondary graphic)
Zoom Video Port
- Two 8-bit ports or one 16-bit video capture port
supports ITU601 and ITU 656 specifications
www.siliconmotion.com
© Copyright 2019 Silicon Motion, Inc.
SM750-PB-201910
很抱歉,暂时无法提供与“SM750KE160000-AC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+441.561401+57.10590
- 国内价格
- 1+664.56720
- 200+265.17240
- 500+256.30560
- 1000+251.93160
