PMT20RIM
PMT20RIM
    CARLOGAVAZZI
    SENSOR THROUGH-BEAM 20M MUTE
PMT20RIM 数据手册
Photoelectrics Through-beam, Industrial Door Market Type PMT20.M, Mute Input • Range: 20 m • Modulated, infrared light • LED-indication for power supply ON (emitter) and target detected (receiver) • Multi supply voltage: 24 VDC and 24 VAC, 50/60 Hz • 25 x 65 x 81 mm reinforced PC housing, IP 67 • CE, UL325 and UL508 approved Product Description Ordering Key housing. PG 13.5 or 1/2" NPT cable gland. With Mute Input on the transmitter the sensor fullfill EN12978 Type Receiver Cable gland Mute Input Housing WxHxD Ordering no. Receiver without timer Ordering no. Emitter 25 x 65 x 81 PG 13.5 cable gland 1/2" NPT cable gland PMT 20R GM PMT 20R IM PMT 20 GM PMT 20 IM Through-beam photoelectric switch. Range up to 20 m. Immune to ambient light. Precise detection through narrow beam. LED-indication. Protection degree IP 67. Screw terminal connection. 25 x 65 x 81 mm plastic PMT20 R G M Type Selection Specifications Emitter Specifications Receiver Rated operational volt. (UB) AC: 45 to 65 Hz Rated operational power Light source Light type Optical angle Indication Power supply ON Output function Rated operational volt. (UB) AC: 45 to 65 Hz Rated operational power (Relay ON) Output Contact ratings (AgCdO) Resistive loads AC 1 DC 1 Small inductive loads AC 15 DC 13 Mechanical life Electrical life 24 VDC ± 20% 24 VAC ± 20% ≤ 1 W (1.2 VA) GaAIAs LED, 880 nm Infrared, modulated ± 2° LED, green Switch selectable, make or break switching Dielectric voltage Sensitivity Optical angle Rated operating dist. (Sn) (0 to 5,000 lux) Operating frequency (f) Response time OFF-ON (tON) ON-OFF (tOFF) Power ON delay ( tv ) Output function Specifications are subject to change without notice (12.02.2010) 24 VDC ± 20% 24 VAC ± 20% ≤ 2 W (2.5 VA) µ (micro gap) 3 A/250 VAC 3 A/30 VDC 2 A/250 VAC 3 A/30 VDC ≥ 40 x 106 operations ≥ 5 x 105 operations at 220 VAC - 3 A resistive load: 360 impulses/h 2 kVAC (rms) (cont./supply) Adjustable, single turn pot. ± 2° 20 m 20 Hz ≤ 20 ms ≤ 20 ms ≤ 300 ms (typ. 100 ms) Mute function 1 PMT20.M General Specifications Environment Overvoltage category Pollution degree Degree of protection Temperature Operating Storage Vibration Shock Housing material Body Front Cover Cable gland Mounting bracket Connection Screw terminal Cable gland Weight Emitter Receiver UL-Approval Sensitivity adjustment -25° to +55°C (-13° to +131°F) -30° to +80°C (-22° to +176°F) 10 to 150 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 2 x 1 m & 100 x 0.5 m (IEC 60068-2-32) LED DIP switches 24 VDC 24 VAC 50/60 Hz PC, grey, reinforced PC, black PC, black PA, black, reinforced Steel, black 30 VDC 250 VAC Max. 3 A 5 x 2 x 1 mm2 PG 13.5 or 1/2" NPT for cable 6 to 10 mm Selection of Function Switch 1 2 3 PMT 20R.M Time adjustment (optional) III (IEC 60664/60664A, 60947-1) 3 (IEC 60664/60664A, 60947-1) IP 67 (IEC 60529, 60947-1) 110 g 115 g cus UL325, CSA-C22.2 No.247 cus UL508 Yes CE-marking Connection Diagram 1 Break switching 2 Make switching Don't care PMT20 Emitter LED Break Make Mute input MAKE/BREAKE L Power supply: 24 VDC or 24 AC, 50/60 Hz N Mute input voltage: 24 VDC M or 24 AC, 50/60 Hz Upper postion ON (Mode 1) Lower position OFF (Mode 0) 2 Specifications are subject to change without notice (12.02.2010) PMT20.M Operation Diagram t = Time delay tv = Power ON delay Power supply Target present Object present Func 1. Output ON Func 2. Output ON Func 3. Output ON Func 4. Output ON Func 5. Output ON Func 6. Output ON Func 7. Output ON Func 8. Output ON Func 9. Output ON Func 10. Output ON Dimensions PMT 20 with angle bracket or 1/2" NPT PMT 20 Specifications are subject to change without notice (12.02.2010) 3 PMT20.M Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled Delivery Contents Accessories • • • • • • MB02 (longer mounting bracket), please refer to "Accessories" 4 Photoelectric switch: PMT 20 Cable gland Installation instruction Mounting bracket Packaging: Corrugated cardboard (environmentally friendly recycling material) Specifications are subject to change without notice (12.02.2010)
PMT20RIM 价格&库存
很抱歉,暂时无法提供与“PMT20RIM”相匹配的价格&库存,您可以联系我们找货
PMT20RIM
  • 1+1754.16261
库存:1
