PD30CNT15PPDU
PD30CNT15PPDU
    CARLOGAVAZZI
    SENSOR THROUGH-BEAM 15M PNP
PD30CNT15PPDU 数据手册
Photoelectrics Through-beam Type PD30CNT15....MU/DU • Miniature sensor range • Range: 15 m • Sensitivity adjustment by Teach-In programming • Modulated, Infraredred light 880 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP preset • Make and break switching function programmable • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable and plug versions • Excellent EMC performance • Mute function (Sensor blanking) Emitter • Dust alarm output - Receiver Product Description Ordering Key The PD30CNT15 sensor family comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABS housing. The sensors are useful in applications where high-accuracy detection as well as small size is required. Compact housing and high power LED for excellent performance-size ratio. The Teach-In function for adjustment of the sensitivi- Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Dust ty makes the sensors highly flexible. The output type is preset (NPN or PNP), and the output switching function is programmable (NO or NC), and one dust output NO or NC. The mute function can be used for testing the sensor for: Malfunctioning, disconnection, optical axis adjustment, dusty and dirty lenses. PD30CNT15NPM5DU Type Selection Housing Range Connection Ordering no. WxHxD Sn NPN Emitter 10 x 30 x 20 mm 15 m Cable 10 x 30 x 20 mm 15 m Plug Ordering no. Ordering no. NPN PNP Make or break switching Emitter PD 30 CNT 15 NMU PD 30 CNT 15 NPDU PD 30 CNT 15 NM5MU PD 30 CNT 15 NPM5DU Ordering no. PNP Make or break switching PD 30 CNT 15 PMU PD 30 CNT 15 PPDU PD 30 CNT 15 PM5MU PD 30 CNT 15 PPM5DU Note: Emitter, Receiver and Connector to be ordered separately. Specifications Emitter Rated operational volt. (UB ) Ripple (Urpp ) Supply current Light Source Optical angle Light type Light spot EN 60947-5-2 10 to 30 VDC ≤ 10% ≤ 25 mA GaAIAs, LED, 880 nm ± 2º at ½ range Infrared, modulated 110 mm @ 1.5 m Specifications Receiver Protection Reverse polarity, transients Indication function Power supply ON LED, green Mute function Emitter off 0 to 3 sec 0 to 2.5 VDC (NPN) 5 to 30 VDC (PNP) Emitter half power > 3 sec 0 to 2.5 VDC (NPN) 5 to 30 VDC (PNP) EN 60947-5-2 Rated operating distance (Sn) 15 m, with PD30CNT15 Emitter Blind zone None Sensitivity Adjustable by Teach-In Temperature drift ≤ 0.3%/ºC Hysteresis (H) (differential travel) ≤ 10% Rated operational volt. (UB ) 10 to 30 VDC Ripple (Urpp ) ≤ 10% Adjustable range 1.5 m to 15 m resolution 3% on distance Specifications are subject to change without notice (24.08.2016) Output current Continuous (Ie) Short-time (I) Dust output current Continuous (Ie) Short-time (I) No load supply current (Io) Minimum operational current (Im) OFF-state current (Ir ) ≤ 100 mA ≤ 100 mA (max. load capacity 100 nF) ≤ 20 mA ≤ 20 mA (max. load capacity 100 nF) ≤ 30 mA 0.5 mA ≤ 100 µA 1 PD30CNT15....MU/DU Specifications Receiver (cont.) EN 60947-5-2 Voltage drop (Ud ) ≤ 2.5 VDC @ 100 mA Protection Short-circuit, reverse polarity and transients Sensing angle ± 4º Ambient light 10,000 lux Operating frequency 1000 Hz Response time OFF-ON (tON) ≤ 0.5 ms ON-OFF (tOFF ) ≤ 0.5 ms Power ON delay (tv) ≤ 300 ms Output function NPN and PNP Preset NO/NC switching function Set up by button Programming options Output pin 4 black NO or NC Output pin 2 white NO or NC (dust) Dust alarm output Delay on operate 20 ms Indication Output ON LED, yellow Signal stability ON and power ON LED, green General Specifications EN 60947-5-2 Environment Installation category III (IEC 60664/60664A; 60947-1) Pollution degree 3 (IEC 60664/60664A; 60947-1) Degree of protection IP 67 (IEC 60529; 60947-1) Ambient temperature Operating -25° to +55°C (-13° to +131°F) Storage -40° to +70°C (-40° to +158°F) Vibration 10 to 55 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) Shock 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) Rated insulation voltage 500 VAC (rms) Housing material Body ABS Front material PMMA, red Connection Cable Emitter/receiver PVC, black, 2 m, Ø = 3.3 mm 4 x 0.14 mm2 Plug M8, 4-pin (CON, 54-series) Weight (each sensor) With cable: 40 g With plug:  10 g CE-marking Yes Approvals cULus (UL508) Operation Diagram tv = Power ON delay Power supply ON OFF Object Present Not Present Optics ON OFF 100% 50% 0% Dirty Clean Make Output (N.O.) ON OFF Break Output (N.C.) ON OFF Mute (Emitter) Emitted power T < 3 sec. T > 5 sec. Tv Tv Wiring Diagrams Receiver Emitter PNP NPN NPN PNP 1 BN NPN V 1 BN V PNP * Teach 4 BK 3 BU 3 BU Output PNP V 1 BN BK 44BK 2 WH 2 WH* 3 BU PNP 1 BN V 4 BK Mute V V V V Mute 3 BU GND Mute input active when *Dust Outputto GND connected 2 WH 3 BU 3 BU Teach input active whenGND *Dust Output connected to V+ 1 BN 2 WH 2 WH* 3 BU V GND Teach input active whenGND Output connected*Dust to GND 2 1 BN V 2 WH Teach BK 24 WH* NPN 1 BN V V Mute input active when connected to V+ Specifications are subject to change without notice (24.08.2016) PD30CNT15....MU/DU Excess Gain Detection Diagram Emitter Y (feet) Receiver 16.5 33 49.5 66 16 300 12 200 8 100 4 0 0 -4 -100 -200 -8 -300 -12 -400 -16 20 0 5 10 15 1000 (inch) (mm) 400 Excess Gain X 100 10 1 1.0 10.0 100.0 Distance (m) Sensing range (m) Accessories Signal Stability Indication 21.2 14 9° 32.4 1.2 25.4 Excess Gain 9° 29.3 26,3 Operation level Operation level x 0.75 39 1.0 0.75 3.2 Operation level x 1.25 1.2 10 1.25 25.4 3.2 13.5 16.2 6.0 5.7 6.0 5.2 Yellow LED ON t Dust alarm 3 4.4 t 14 4.4 16 10 7.3 Green LED ON 8.2 Time 4.4 Mounting bracket: APD30-MB1 Mounting bracket: APD30-MB2 Dimensions Plug version Cable version 6 20 10.6 6 Teach Button* 20 10.6 Teach Button* Output LED Yellow* Output LED Yellow* Power / Stability LED Green 10.6 1.1 Receiver or emitter 15 22 Two, 9.5 dia. Lenses 5.5 5.5 Optical axis 15 Two M3 10.8 17 25.4 5.5 5.5 22 30 Optical axis Two, 9.5 dia. Lenses 30 1.1 Receiver or emitter 25.4 10.6 10.8 17 Power / Stability LED Green Two M3 10.25 * Not avaible on emitter version Specifications are subject to change without notice (24.08.2016) 3 xxxxxxS Incorrect Correct xxxxxxS PD30CNT15....MU/DU > 100 mm Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Delivery Contents Accessories • Photoelectric switch: PD 30 CNT 15 ... • Installation instruction • Mountingbracket APD30-1 • Packaging: Cardboard box • Mounting bracket APD30-2 to be purchased separately • Connector type CONG 5A../CON. 54NF.. series. 4 Specifications are subject to change without notice (24.08.2016) PD30CNT15....MU/DU Teach functions Normal operation, optimized switching point 1. Line up the emitter and receiver. Yellow LED and Green LED are ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Place the object between the emitter and receiver in the detection zone. 4. Press the button once and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 For dynamic set-up (running process) 1. Line up the emitter and receiver. Green LED is ON, status on the yellow LED is not important. 2. Press the button for 3 second until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and keep the button pressed for at least one process cycle, release the button and the sensor is ready to operate (The second switch point is stored) 1 4 2 3 sec. 3 sec. 1 Push once Push once For maximum sensing distance (default setting) 1. Line up the emitter and receiver, place the object between the emitter and receiver in the detection zone. Yellow LED is OFF and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 3 2 For make or break set-up 1. Press the button for 10 seconds, until the green LEDs flashes. 2. While the green LED flashes, the output is inverted each time the button is pressed. Yellow LED indicates N.O. function selected. If the button is not pressed within the next 10 seconds, the current output is stored. 1 3 10 sec. 3 sec. Push once For minimum sensing distance (Transparent or semi-transparent objects) 1. Line up the emitter and receiver. Yellow LED and Green LED are ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 Push once For dust output (N.O. or N.C.) 1. Press the button for 15 seconds, until the yellow LEDs flashes. 2. While the yellow LED flashes, the dust output is inverted each time the button is pressed. Green LED indicates N.O. function selected. If the button is not pressed within the next 10 seconds, the current output is stored. 1 2 3 15 sec. 3 sec. 2 Push once Push once Specifications are subject to change without notice (24.08.2016) 5
PD30CNT15PPDU 价格&库存
很抱歉,暂时无法提供与“PD30CNT15PPDU”相匹配的价格&库存,您可以联系我们找货
PD30CNT15PPDU
  • 1+750.347721+97.02180
  • 5+700.359495+90.55820
  • 10+650.2838810+84.08330
PD30CNT15PPDU
  • 1+634.19725
  • 5+602.50674
  • 10+583.43923
库存:10
