PD30CND10NASA
PD30CND10NASA
    CARLOGAVAZZI
    SENSOR REFLECTIVE 1M NPN NO/NC
PD30CND10NASA 数据手册
Photoelectrics Diffuse-reflective Type PD30CND10....SA • Miniature sensor range • Range: 1 m • Sensitivity adjustment by Potentiometer • Modulated, red light 625 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP preset • Make and break switching function • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable and plug versions • Excellent EMC performance Product Description Ordering Key The PD30CND10 sensor family comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABS housing. The sensors are useful in applications where high-accuracy detection as well as small size is required. Compact housing and high power LED for excellent performance-size ratio. Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Sensitivity adjustment The Potentiometer function for adjustment of the sensitivity makes the sensors highly flexible. The output type is preset (NPN or PNP), and the output switching function is NO and NC output. PD30CND10NAM5SA Type Selection Housing Range Connection WxHxD Sn Ordering no. NPN Make and break switching Ordering no. PNP Make and break switching 10 x 30 x 20 mm 10 x 30 x 20 mm PD 30 CND 10 NASA PD 30 CND 10 NAM5SA PD 30 CND 10 PASA PD 30 CND 10 PAM5SA Specifications 1000 mm 1000 mm Cable Plug EN 60947-5-2 Rated operating distance (Sn) Up to 1 m, reference target Kodak test card R27, white, 90% reflective, 200 x 200 mm Blind zone ≤ 20 mm @ maximum distance Sensitivity Electrical adjustment 210˚ Mechanical adjustment 240˚ Temperature drift ≤ 0.2%/ºC Hysteresis (H) 5% to 20% Rated operational volt. (UB ) 10 to 30 VDC (ripple included) Ripple (Urpp ) ≤ 10% Output current Continuous (Ie) ≤ 100 mA Short-time (I) ≤ 100 mA (max. load capacity 100 nF) No load supply current (Io) ≤ 25 mA @ UB max Minimum operational current (Im) ≤ 0.5 mA Specifications are subject to change without notice (14.06.2016) OFF-state current (Ir ) ≤ 100 µA Voltage drop (Ud ) ≤ 2 VDC @ Ie max Protection Short-circuit, reverse polarity and transients Light source InGaAlP, LED, 625 nm Light type Red, modulated Emitter angle ± 2º @ half sensing distance Light spot 1.5 times the sensing distance 110 mm Ambient light ≤ 10,000 lux Operating frequency (f) ≤ 1000 Hz Response time OFF-ON (tON) ≤ 0.5 ms ON-OFF (tOFF ) ≤ 0.5 ms Power ON delay (tv) ≤ 30 ms Output function Open collector NPN or PNP by sensor type Output switching function N.O. and N.C. 1 PD30CND10....SA Specifications (cont.) Indication Output ON Power ON Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock LED, yellow Signal stability ON and LED, green. See curve for condition of stability III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) -25° to +60°C (-13° to +140°F) -40° to +70°C (-40° to +158°F) 10 to 150 Hz, 1.0 mm/15 G (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) Rated insulation voltage ≤ 500 VAC (rms) Housing material Body ABS Light Grey Frontglas PMMA Red Trimmer shaft POM Dark Grey Connection Cable PVC, black, 2 m 4 x 0.14 mm2, Ø = 3.3 mm Plug M8, 4-pin (CON. 54-series) Weight Cable version ≤ 50 g Plug version ≤ 20 g CE-marking Yes Approvals cULus (UL508 + CSA) Operation Diagram Tv = Power ON delay Power supply ON OFF Break Output (N.C.) Present Not Present Tv ON OFF Make Output (N.O.) ON OFF Object Tv Signal Stability Indication Wiring Diagrams NPN 1BN Excess Gain 1.10 Operation level x 1.10 1.0 0.90 Operation level Operation level x 0.90 Time Green LED ON Yellow LED ON 2WH 4BK 3BU PNP 1BN 4BK 2WH 3BU 2 Specifications are subject to change without notice (14.06.2016) PD30CND10....SA Excess Gain Detection Diagram Sender Sensor Y R27 Kodac test card Distance (Inches) 7,9 200 15,7 23,6 400 600 31,5 800 Distance (Inches) 39,4 47,2 55,1 2,0 1,6 1,2 0,8 0,4 0,0 -0,4 -0,8 -1,2 -1,6 -2,0 1.000 1.200 1.400 0,0 1.000 Excess Gain 0,0 50 40 30 20 10 0 -10 -20 -30 -40 -50 0 (Inches) (mm) X 0,4 3,9 39,4 393,7 1.000 100 100 10 10 1 1 10 1 10.000 100 1.000 Distance (mm) Distance (mm) Dimensions Plug version 10.6 20 20 10.6 Cable version Receiver Receiver Optical axis Emitter Two M3 Potentiometer Two, 9.5 dia. Lenses 15 30 Correct 15 25.4 xxxxxxS 22 Incorrect 22 10.8 17 7 Optical axis R 7 17 Power / Stability LED Green 10.6 10-30 V Potentiometer 100 mA BN: V+ UL Two, 9.5 dia. BU: VBK: OUT Lenses WH: ET 5.5 5.5 1.1 25.4 30 10.8 R xxxxxxS PD30CNP 06NPM5T 10.6 1.1 PD30CNP 06NPM5T 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET Output LED Yellow Power / Stability LED Green 5.5 5.5 Output LED Yellow Two M3 > 100 mm Emitter 10.25 Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Delivery Contents Accessories • Photoelectric switch: PD30CND10 ... • Screwdriver • Packaging: Plastic bag • Mounting bracket APD30-MB1 or APD30-MB2 to be purchased separately. Specifications are subject to change without notice (14.06.2016) 3
PD30CND10NASA 价格&库存
很抱歉,暂时无法提供与“PD30CND10NASA”相匹配的价格&库存,您可以联系我们找货
PD30CND10NASA
  • 1+491.687031+63.73200
  • 5+458.907905+59.48320
  • 10+426.1287610+55.23440
PD30CND10NASA
    • 1+587.01816
    • 5+557.58866
    库存:8
