PA18CRD08PASA
PA18CRD08PASA
    CARLOGAVAZZI
    插件
    SENSOR REFLECTIVE 800MM PNP
PA18CRD08PASA 数据手册
Photoelectrics Diffuse-reflective Type PA18C.D..., DC • Miniature sensor range • Range: 1 m (Axial), 0.8 m (Radial) • Sensitivity adjustment by potentiometer • Modulated, red light 625 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP, N.O & N.C. • Degree of protection IP67, IP69K • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable and plug versions • Excellent EMC performance Product Description Ordering Key The PA18CAD10... is part of a family of inexpensive general purpose diffuse reflective sensors in industrial standard 18 mm cylindrical ABS housing. The sensors are useful in applications where high-accuracy detection as well as small size is required. Type Housing style Housing size Housing material Housing type axial Detection principle Sensing distance Output type Output configuration Connection type Sensitive adjustment Compact housing and high power LED for excellent performance-size ratio. The potentiometer used for adjustment of the sensitivity makes the sensors highly flexible. The output type is NPN or PNP and the output switching function is NO and NC. PA18CAD10PAM1SA Type Selection Housing style Range Connection Sn Ordering no. NPN Make & break switching Ordering no. PNP Make & break switching M18 Axial type M18 Axial type M18 Radial type M18 Radial type PA 18 CAD 10 NASA PA 18 CAD 10 NAM1SA PA 18 CRD 08 NASA PA 18 CRD 08 NAM1SA PA 18 CAD 10 PASA PA 18 CAD 10 PAM1SA PA 18 CRD 08 PASA PA 18 CRD 08 PAM1SA Specifications 1 m 1 m 0.8 m 0.8 m Cable Plug Cable Plug according to EN60947-5-2 Rated operating distance (Sn) Axial type (A) Up to 1 m, Radial type (R) Up to 0.8 m reference target Kodak test card R27, white, 90% reflective, 200 x 200 mm Blind zone 2 mm @ Sn max. Sensitivity control Adjustable by potentiometer Electrical adjustment 210˚ Mecanical adjustment 240˚ Adjustable distance Axial types 50-1000 mm Radial types 50-800 mm Temperature drift ≤ 0.2%/ºC Hysteresis (H) (differential travel) ≤ 20% Rated operational volt. (UB ) 10 to 30 VDC (ripple included) Ripple (Urpp ) ≤ 10% Output current Continuous (Ie) ≤ 100 mA Short-time (I) ≤ 100 mA (max. load capacity 100 nF) Specifications are subject to change without notice (15.06.2017) No load supply current (Io) ≤ 25 mA @ 24 VDC Minimum operational current (Im) 0.5 mA OFF-state current (Ir ) ≤ 100 µA Voltage drop (Ud ) ≤ 2.0 VDC @ 100 mA Protection Short-circuit, reverse polarity and transients Light source InGaAlP, LED, 625 nm Light type Red, modulated Sensing angle ± 2º Ambient light 30.000 lux Incandescent lamp Light spot Diameter Ø 30 mm @ 0.5 m Operating frequency 500 Hz Response time OFF-ON (tON) ≤ 1.0 ms ON-OFF (tOFF ) ≤ 1.0 ms Power ON delay (tv) ≤ 100 ms Output function Type NPN or PNP Switching function NO and NC 1 PA18C.D... Specifications (cont.) Indication Output ON Signal stability and power ON Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock Rated insulation voltage LED, yellow LED, green III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67, IP 69K* -25° to +60°C (-13° to +140°F) -40° to +70°C (-40° to +158°F) 10 to 150 Hz, 1 mm/15 g (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) 500 VAC (rms) IEC protection class III Housing material Body ABS, grey Front material PMMA, red Cable gland POM, Black Trimmer shaft POM, Dark Grey Locknuts PBTB, black Mounting bracket PPA, black Connection Cable PVC, grey, 2 m 4 x 0.25 mm2, Ø = 4.5 mm Plug M12, 4-pin (CONB14NF-series) Weight With cable: 85g With plug: 25 g CE-marking Yes Approvals cULus (UL508) supply class 2 90° * The IP69K test according to DIN 40050-9 for high-pressure, high-temperature wash-down applications. The sensor must not only be dust tight (IP6X), but also able to withstand high-pressure and steam cleaning. The sensor is exposed to high pressure water from a spray nozzle that is fed with 80°C water at 8’000– 10’000 KPa (80–100bar) and a flow rate of 14–6L/min. The nozzle is held 100 –150 mm from the sensor at angles of 0°, 30°, 60° and 90° for 30s each. The test device sits on a turntable that rotates with a speed of 5 times per minute. The sensor must not suffer any damaging effects from the high pressure water in appearance and function. 60° 30° 0° Operation Diagram Operation Diagram tv = Power ON delay Power supply ON OFF Break Output (N.C.) Present Not Present Tv ON OFF Make Output (N.O.) ON OFF Object Tv Wiring Diagrams NPN 1 BN V PNP 1 BN V 4 BK 2 WH 2 WH 4 BK 3 BU 3 BU V GND 2 V GND Specifications are subject to change without notice (15.06.2017) PA18C.D... Detection Diagram Y X R27 Kodac test card 7,9 15,7 Radial (inch) (inch) 23,6 31,5 39,4 47,2 55,1 0,0 7,9 15,7 23,6 31,5 39,4 1,18 30 1,18 20 0,79 20 0,79 10 0,39 10 0,39 0 0,00 0 0,00 (mm) 30 (inch) (mm) 0,0 Axial -10 -0,39 -10 -0,39 -20 -0,79 -20 -0,79 -1,18 -30 -30 0,0 0,2 0,4 0,6 0,8 1,0 1,2 1,4 (inch) Sensor -1,18 0,0 0,2 0,4 Distance (m) 0,6 0,8 1,0 Distance (m) Excess Gain 0,0 7,9 15,7 Axial Radial (inch) (inch) 23,6 31,5 39,4 47,2 0,0 55,1 Excess Gain Excess Gain 7,9 15,7 23,6 31,5 39,4 0,4 0,6 0,8 1,0 1.000 10.000 1.000 100 10 100 10 1 1 0,0 0,2 0,4 0,6 0,8 1,0 1,2 0,0 1,4 0,2 Distance (m) Distance (m) APA18-MB1 Signal Stability Indication 1.1 Operation level x 1.1 1.0 0.9 Operation level Operation level x 0.9 Ø 27 Excess Gain 10 Time Ø 27 Green LED ON 10 Yellow LED ON Specifications are subject to change without notice (15.06.2017) 3 PA18C.D... Dimensions Radial version Cable version Sensitivity Control 270° 30 15 6.3 M18 x 1 Ø 4.5 Ø 9.9 13,3 Operation Indicator (Yellow) 0.6 8.1 30.8 Power and Stability Indicator (Green) 49.6 9.7 3.5 3.5 Receiver Optical Axis Emitter Plug version Sensitivity Control 270° 13,3 Operation Indicator (Yellow) 30 15 10.8 M18 x 1 M12x1 Plug 8.1 30.8 54.1 Power and Stability Indicator (Green) 0.6 9.7 3.5 3.5 Receiver Optical Axis Emitter 4 Specifications are subject to change without notice (15.06.2017) PA18C.D... Dimensions Axial version Plug version Cable version 6.3 8.1 39.3 Operation Indicator (Yellow) 30 Emitter Emitter Optical Axis Power and Stability Indicator (Green) 15 10.8 0.6 Receiver M12x1 Plug 3.5 3.5 M18 x 1 M18 x 1 20.5 3 3.5 3.5 30 Sensitivity Control 270° 15 Ø 9.9 3 Operation Indicator (Yellow) Ø 4.5 Sensitivity Control 270° Optical Axis 20.5 8.1 43.8 Power and Stability Indicator (Green) 0.6 Receiver Mounting Systems Axial version Radial version M18 Locknut M18 Locknut m m m 0 1. .5 m in. x. 4 M a M APA18-MB1 APA18-MB1 PA18 mounting with a combination of 1 x APA18-MB1 and 1 x M18 locknut. Maximum torque 0.9 NM PA18 mounting with a combination of 2 x M18 locknuts. Maximum torque 2.0 NM Specifications are subject to change without notice (15.06.2017) 5 Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Delivery Contents Accessories • Photoelectric switch: PA 18 C.D... • Installation instruction on plastic bag • Screwdriver • Mounting bracket APA18-MB1 • 2 M18 locknuts • Packaging: Plastic bag • Connector type CONG1A.. / CONB14NF.. series 6 Specifications are subject to change without notice (15.06.2017)
PA18CRD08PASA 价格&库存
很抱歉,暂时无法提供与“PA18CRD08PASA”相匹配的价格&库存,您可以联系我们找货
