PD30CND10NPDU
PD30CND10NPDU
    CARLOGAVAZZI
    SENSOR REFLECTIVE 1M NPN NO/NC
PD30CND10NPDU 数据手册
Photoelectrics Diffuse-reflective Type PD30CND10....DU • Miniature sensor range • Range: 1 m • Sensitivity adjustment by Teach-In programming • Modulated, red light 660 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP preset • Make or break switching function programmable • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable and plug versions • Excellent EMC performance • Dust alarm output Product Description Ordering Key The PD30CND10 sensor family comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABS housing. The sensors are useful in applications where high accuracy detection as well as small size is required. Compact housing and high power LED for excellent performance-size ratio. Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Dust Output The Teach-In function for adjustment of the sensitivity makes the sensors highly flexible. The output type is preset (NPN or PNP), and the output switching function is one NO or NC output and one dust output NO or NC. PD30CND10PPM5DU Type Selection Housing Range Connection WxHxD Sn Ordering no. NPN Make and break switching Ordering no. PNP Make and break switching 10 x 30 x 20 mm 10 x 30 x 20 mm PD 30 CND 10 NPDU PD 30 CND 10 NPM5DU PD 30 CND 10 PPDU PD 30 CND 10 PPM5DU Specifications 1 m 1 m Cable Plug EN 60947-5-2 Rated operating distance (Sn) Up to 1 m, Protection Short-circuit, reverse polarity reference target Kodak test and transients card R27, white, 90% Light source GaAlAs, LED, 660 nm reflective, 200 x 200 mm Light type Red, modulated Blind zone ≤ 20 mm Sensing angle ± 2º Sensitivity Adjustable by Teach-In Ambient light 10,000 lux Temperature drift ≤ 0.1%/ºC Light spot 110 mm @ 1.5 m Hysteresis (H) Operating frequency (f) ≤ 1000 Hz (differential travel) ≤ 10% Response time Rated operational volt. (UB ) 10 to 30 VDC OFF-ON (tON) ≤ 0.5 ms (ripple included) ON-OFF (tOFF ) ≤ 0.5 ms Ripple (Urpp ) ≤ 10% Power ON delay (t ) ≤ 300 ms v Output current Output function Continuous (Ie) ≤ 100 mA NPN and PNP Preset Short-time (I) ≤ 100 mA Output configuration NO or NC (max. load capacity 100 nF) Programming options No load supply current (Io) ≤ 30 mA @ 24 VDC Output pin 4 black NO or NC Minimum operational current (Im) ≤ 0.5 mA Output pin 2 white NO or NC (dust) OFF-state current (Ir ) ≤ 100 µA Dust alarm output Voltage drop (Ud ) ≤ 2.4 VDC @ 100 mA Delay on operate 20 ms Specifications are subject to change without notice (05.07.2016) 1 PD30CND10....DU Specifications (cont.) Indication Output ON Signal stability ON and Power ON Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock EN 60947-5-2 LED, yellow LED, green III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) -25° to +60°C (-13° to +140°F) -40° to +70°C (-40° to +158°F) 10 to 55 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) Rated insulation voltage ≤ 500 VAC (rms) Housing material Body ABS Frontglas PMMA Red Connection Cable PVC, black, 2 m 4 x 0.14 mm2, Ø = 3.3 mm Plug M8, 4-pin (CON. 54-series) Weight Cable version ≤ 40 g Plug version ≤ 10 g CE-marking Yes Approvals cULus (UL508 + CSA) Operation Diagram Tv = Power ON delay Power supply ON OFF Break Output (N.C.) Present Not Present Tv ON OFF Make Output (N.O.) ON OFF Object Tv Wiring Diagrams NPN 1 BN PNP V 1 BN V 4 BK 2 WH* 2 WH* 4 BK 3 BU 3 BU *Dust Output GND *Dust Output Detection Diagram GND Excess Gain 1,000 40 30 Exess gain 20 (mm) 10 0 -10 100 10 -20 -30 -40 0 200 400 600 800 Distance (mm) 1000 1200 1400 1 10 100 1,000 10,000 Distance (mm) 2 Specifications are subject to change without notice (05.07.2016) PD30CND10....DU Signal Stability Indication Accessories 21.2 14 9° 32.4 1.2 25.4 Excess Gain 9° 26,3 29.3 39 1.0 0.75 3.2 Operation level x 1.25 Operation level Operation level x 0.75 1.2 10 1.25 25.4 3.2 13.5 16.2 6.0 5.2 3 Yellow LED ON 4.4 Dust ON 14 4.4 6.0 16 10 7.3 Green LED ON 8.2 5.7 Time 4.4 Mounting bracket: APD30-1 Mounting bracket: APD30-2 Dimensions Plug version Cable version Incorrect 10.8 1.1 17 Receiver Optical axis xxxxxxS Correct Emitter Two M3 Two, 9.5 dia. Lenses 15 15 30 5.5 5.5 25.4 R 22 Optical axis Two, 9.5 dia. Lenses Power / Stability LED Green 10.6 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET 25.4 Receiver 22 1.1 10.8 17 xxxxxxS 30 PD30CNP 06NPM5T 10.6 R Output LED Yellow Power / Stability LED Green 5.5 5.5 Output LED Yellow PD30CNP 06NPM5T 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET 6 20 10.6 6 Teach Button 20 10.6 Teach Button Two M3 > 100 mm Emitter 10.25 Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Delivery Contents Accessories • Photoelectric switch: PD 30 CND 10 ... • Installation instruction • Mounting bracket APD30-MB1 • Packaging: Cardboard box • Mounting bracket APD30-MB1 or APD30-MB2 to be purchased separately. Specifications are subject to change without notice (05.07.2016) 3 PD30CND10....DU Teach functions Normal operation, optimized switching point. 1. Line up the sensor at the background. Yellow LED is OFF and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Place the object in the detection zone. 4. Press the button once and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 3 sec. 4 For dynamic set-up (running process) 1. Line up the sensor at the object. Green LED is ON, status on the yellow LED is not important. 2. Press the button for 3 second until both LEDs flashes simultaneously. 3. Press the button a second time for at least one second, both LED’s flashes fast simultaneously and keep the button pressed for at least one process cycle, release the button and the sensor is ready to operate (The second switch point is stored) 1 2 3 Push once 3 sec. For maximum sensing distance (default setting) 1. Line up the sensor at the background. Yellow LED is OFF and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) One cycle For make or break set-up (N.O. or N.C.) 1. Press the button for 10 seconds, until the green LEDs flashes. 2. While the green LED flashes, the output is inverted each time the button is pressed. Yellow LED indicates N.O. function selected. If the button is not pressed within the next 10 seconds, the current output is stored. 1 2 1 2 3 10 sec. 3 sec. Push once For minimum detection overhead. 1. Line up the sensor at the object. Yellow LED is ON and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate(Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 For dust output (N.O. or N.C.) 1. Press the button for 15 seconds, until the yellow LEDs flashes. 2. While the yellow LED flashes, the dust output is inverted each time the button is pressed. Green LED indicates N.O. function selected. If the button is not pressed within the next 10 seconds, the current output is stored. 1 4 2 3 15 sec. 3 sec. Push once Push once Push once Specifications are subject to change without notice (05.07.2016)
PD30CND10NPDU 价格&库存
很抱歉,暂时无法提供与“PD30CND10NPDU”相匹配的价格&库存,您可以联系我们找货
