VS4AP5R
VS4AP5R
    BANNER(邦纳)
    VS4 SERIES: OPPOSED MODERANG
VS4AP5R 数据手册
VS4 Series Opposed-Mode Sensors Datasheet Miniature Self-Contained Sensors • • • • • • • 10 to 30V dc operation Visible red, 660 nm sensing beam Up to 1.0 m (39 in) sensing range Choose dark or light operate models Choose models with NPN (sinking) or PNP (sourcing) output 2-wire and 3-wire hookup; output load capacity to 50 mA Choice of integral cable or quick-disconnect pigtail WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models OPPOSED Model Number Sensing Range Cable VS4EV 2 m (6.5 ft) 2 wire VS4EVQ 3-pin pico Pigtail QD VS4AN5R 2 m (6.5 ft) 3 wire VS4AN5RQ 3-pin pico Pigtail QD VS4RN5R VS4RN5RQ 1.0 m (39 in) 2 m (6.5 ft) 3 wire 3-pin pico Pigtail QD VS4AP5R 2 m (6.5 ft) 3 wire VS4AP5RQ 3-pin pico Pigtail QD VS4RP5R 2 m (6.5 ft) 3 wire VS4RP5RQ 3-pin pico Pigtail QD Original Document 69421 Rev. D Supply Voltage Output Type – NPN/LO 10 to 30V dc NPN/DO PNP/LO PNP/DO 13 September 2016 69421 VS4 Series Opposed-Mode Sensors Wiring Diagrams Emitters with Cable NPN Models with Cable bn bu – 10-30V dc + bn Emitters with Quick-Disconnect bu bn PNP Models with Cable bu bk bn bk bk bk Load PNP Models with Quick-Disconnect + 10-30V dc – bu + 10-30V dc – bu Load NPN Models with Quick-Disconnect – 10-30V dc + bn + 10-30V dc – Load bn + 10-30V dc – bu bk Load Specifications Supply Voltage and Current 10 to 30V dc (10% maximum ripple) Emitter: 25 mA Receiver: 25 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration SPST solid-state switch Choose NPN (current sinking) or PNP (current sourcing), depending on model Choose light operate (N.O.) or dark operate (N.C.), depending on model Output Rating 50 mA maximum Off-state leakage current: < 1 microamp at 24V dc On-state saturation voltage: < 0.25V at 10 mA dc; < 0.5V at 50 mA dc Output Protection Circuitry Protected against false pulse on power-up ‑and continuous overload or short circuit of outputs Overload trip point ≥ 100 mA Output Response Time 1 millisecond ON and 0.5 milliseconds OFF NOTE: 100 millisecond delay on power-up: output is non-conducting during this time Repeatability 100 microseconds Indicators Two LEDs: Green and Yellow Green ON steady: power to sensor is ON Green flashing: output overload Yellow ON steady: light is sensed Yellow flashing: marginal excess gain (1 to 1.5x) in light condition Construction Polycarbonate mounting holes and lens Low pressure molded thermoplastic housing (UL 94-V0) Connections 2 m (6.5 ft) attached cable: three #28 ga stranded conductors with PE insulation; PVC outer cable jacket; or 3-pin Pico-style pigtail quickdisconnect fitting. QD cables are ordered separately. Operating Conditions Temperature: −20 °C to +55 °C (−4 °F to +131°F) Humidity: 80% at +50 °C maximum relative humidity (noncondensing) Vibration and Mechanical Shock Vibration: All models meet IEC 60068-2-6, IEC 60947-5-2, UL491 Section 40, MIL-STD-202F Method 201A; 10 to 60 Hz, 0.5 mm peak to peak Shock: All models meet IEC 60068-2-27, IEC 60947-5-2; 30g peak acceleration, 11 millisecond pulse duration, half-sine wave pulse shape Application Notes M2 stainless steel mounting hardware included. Optional mounting bracket available. Certifications Environmental Rating IEC IP67; NEMA 6 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 69421 Rev. D VS4 Series Opposed-Mode Sensors Dimensions Emitter Receiver 2.75 mm (0.11") 2.75 mm (0.11") 12.5 mm (0.49") 9.8 mm (0.37") 4.75 mm (0.19") 3.1 mm (0.12") 8.25 mm (0.32") 25.4 mm (1.00") 16.0 mm (0.63") 2x ø2.4 mm (ø0.09") Performance Curves Excess Gain Beam Pattern 1000 100 PATTERN 10 WIDTH G A I N Effective Beam =3 mm BEAM E X C E S S 1 0.01 m 0.4 in 60 mm 2.36 in 40 mm 1.57 in 20 mm 0.78 in 0 0 -20 mm -0.78 in -40 mm -1.57 in -60 mm -2.36 in 0 0.10 m 4 in 1.0 m 40 in 10.0 m 400 in 200 mm 8 in 400 mm 16 in 600 mm 24 in 800 mm 32 in 1000 mm 40 in DISTANCE DISTANCE Accessories Quick-Disconnect Cables 3-Pin Threaded M8/Pico-Style Cordsets Model Length PKG3M-2 2 m (6.56 ft) PKG3M-5 5 m (16.40 ft) PKG3M-7 7 m (22.97 ft) PKG3M-9 9 m (29.53 ft) PKG3M-10 P/N 69421 Rev. D Style Dimensions Pinout (Female) 4 35 Typ. Straight ø 9.5 M8 x 1 10 m (32.81 ft) www.bannerengineering.com - Tel: +1-763-544-3164 1 3 1 = Brown 3 = Blue 4 = Black 3 VS4 Series Opposed-Mode Sensors Apertures Model Description Dimensions 5.0 mm (0.20 in) 2 x 5.1 mm (0.20 in) 12.40 mm (0.49 in) APVS4-0206 • • 2-holed aperture 0.020 in and 0.060 in diameter holes 2 x 2.85 mm (0.11 in) 2 x ø 0.5 mm (0.02 in) 2 x 20.0 mm (0.80 in) 2.0 mm (0.08 in) 2 x ø 1.5 mm (0.06 in) 2 x 5.55 mm (0.22 in) 12.0 mm (0.47 in) 2 x 5.55 mm (0.22 in) 4 x ø 2.1 mm (0.08 in) 2.0 mm (0.08 in) 16.0 mm (0.63 in) 4 x 1.9 mm (0.08 in) 2.9 mm (0.11 in) 2.9 mm (0.11 in) 5.0mm (0.20 in) APVS4-0408 • • 2-holed aperture 0.040 in and 0.080 in diameter holes 12.40 mm (0.49 in) 2 x ø 1.0 mm (0.04 in) 2 x 20.0 mm (0.80 in) 2 x 2.85 mm (0.11 in) 2.0 mm (0.08 in) 2 x ø 2.0 mm (0.08 in) 12.0 mm (0.47 in) 4 x 1.9 mm (0.08 in) 2 x 5.55 mm (0.22 in) 2 x 5.55 mm (0.22 in) 2 x 5.1 mm (0.20 in) 4 x ø 2.1 mm (0.08 in) 2.0 mm (0.08 in) 16.0 mm (0.63 in) 2.9 mm (0.11 in) 2.9 mm (0.11 in) Brackets SMBVS4SRA • Right-angle bracket • 300 series stainless steel A = 3 x R1.6, B = ø 3.2, C = R1.2 17 C 33 B 11 A Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
VS4AP5R 价格&库存
很抱歉,暂时无法提供与“VS4AP5R”相匹配的价格&库存,您可以联系我们找货
