S-8239BAA-M6T1U
S-8239BAA-M6T1U
    ABLIC(艾普凌科)
    SOT23-6
    IC BATT MONITOR LI-ION SOT23-6
S-8239BAA-M6T1U 数据手册
S-8239B Series www.ablic.com OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK © ABLIC Inc., 2014-2019 Rev.1.2_00 The S-8239B Series is an overcurrent monitoring IC for multi-serial-cell pack including high-accuracy voltage detection circuits and delay circuits. The S-8239B Series is suitable for protection of lithium-ion / lithium polymer rechargeable battery packs from overcurrent.  Features • Built-in high-accuracy voltage detection circuit Overcurrent 1 detection voltage*1 0.04 V to 0.30 V (10 mV step) Accuracy ±15 mV Overcurrent 2 detection voltage 0.1 V to 0.7 V (100 mV step) Accuracy ±100 mV Overcurrent 3 detection voltage 1.2 V (Fixed) Accuracy ±300 mV • Built-in three-step overcurrent detection circuit: Overcurrent 1, overcurrent 2, overcurrent 3 • Overcurrent 3 detection function: Available, unavailable • UVLO (under voltage lock out) function UVLO detection voltage 2.0 V (Fixed) Accuracy ±100 mV • High-withstand voltage: VM pin, DO pin: Absolute maximum rating 28 V • Delay times are generated only by an internal circuit (External capacitors are unnecessary). • Low current consumption During normal operation: 7.0 μA max. During power-down: 0.1 μA max. • Output logic: Active "L" • Wide operation temperature range: Ta = −40°C to +85°C • Lead-free (Sn 100%), halogen-free *1. Overcurrent 1 detection voltage ≤ 0.06 V should be satisfied in the case of overcurrent 2 detection voltage = 0.1 V. Overcurrent 1 detection voltage ≤ 0.85 × overcurrent 2 detection voltage − 0.05 V should be satisfied in the case of overcurrent 2 detection voltage ≥ 0.2 V.  Applications • Lithium-ion rechargeable battery pack • Lithium polymer rechargeable battery pack  Package • SOT-23-6 1 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00  Block Diagram DP − RVMD VM DO + VDD Delay circuit output control circuit UVLO detection comparator + − Overcurrent latch comparator + − VINI Overcurrent 1 detection comparator + − Overcurrent 2 detection comparator + − VSS Remark All the diodes shown in the figure are parasitic diodes. Figure 1 2 Overcurrent 3 detection comparator OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00  Product Name Structure 1. Product name S-8239B xx - M6T1 U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications M6T1: SOT-23-6, Tape *1 *2 Serial code Sequentially set from AA to ZZ *1. Refer to the tape drawing. *2. Refer to "3. Product name list". 2. Package Table 1 Package Drawing Codes Package Name SOT-23-6 Dimension Tape Reel MP006-A-P-SD MP006-A-C-SD MP006-A-R-SD 3. Product name list Table 2 Product Name Overcurrent 1 Detection Voltage [VDIOV1] Overcurrent 2 Detection Voltage [VDIOV2] Overcurrent 1 Detection Delay Time [tDIOV1] S-8239BAA-M6T1U 0.20 V 0.4 V 1150 ms Remark Contact our sales representatives for products other than the above. Overcurrent 2 Detection Delay Time [tDIOV2] 0.56 ms Overcurrent 3 Detection Function Unavailable 3 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00  Pin Configuration 1. SOT-23-6 Table 3 Top view 6 5 4 1 2 3 Figure 2 *1. The DP pin should be open. 4 Pin No. Symbol Description Voltage detection pin between VINI pin and VSS pin 1 VINI (Overcurrent detection pin) 2 VM Overcurrent latch pin 3 DO Connection pin of discharge control FET gate 4 DP*1 Test pin for delay time measurement 5 VDD Input pin for positive power supply 6 VSS Input pin for negative power supply *1. The DP pin should be open. Rev.1.2_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series  Absolute Maximum Ratings Table 4 (Ta = +25°C unless otherwise specified) Item Input voltage between VDD pin and VSS pin VM pin input voltage VINI pin input voltage DO pin output voltage Power dissipation Operation ambient temperature Storage temperature Symbol VDS VVM VVINI VDO PD Topr Applied pin VDD VM VINI DO − − Absolute Maximum Rating VSS − 0.3 to VSS +12 VDD − 28 to VDD + 0.3 VSS − 0.3 to VSS + 12 VSS − 0.3 to VSS + 28 650*1 −40 to +85 Unit V V V V mW °C Tstg − −55 to +125 °C *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm × 76.2 mm × t1.6 mm (2) Board name: JEDEC STANDARD51-7 1. The DP pin should be open. 2. The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 700 Power dissipation (PD) [mW] Caution 600 500 400 300 200 100 0 0 100 150 50 Ambient temperature (Ta) [°C] Figure 3 Power Dissipation of Package (When Mounted on Board) 5 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00  Electrical Characteristics 1. Ta = +25°C Table 5 Item Symbol Condition VDIOV1 − Overcurrent 2 detection voltage*1 VDIOV2 − Min. (Ta = +25°C unless otherwise specified) Test Test Typ. Max. Unit Condition Circuit Detection Voltage Overcurrent 1 detection voltage Overcurrent 3 detection voltage VDIOV3 UVLO detection voltage VUVLO Release Voltage Overcurrent release voltage VRIOV Input Voltage, Operation Voltage Operation voltage between VDSOP VDD pin and VSS pin Current Consumption Current consumption during IOPE normal operation Current consumption during IPDN power-down Internal Resistance Internal resistance between RVMD VM pin and VDD pin Output Resistance DO pin resistance "L" RDOL Delay Time With overcurrent 3 detection function − VDIOV1 VDIOV1 − 0.015 VDIOV2 VDIOV2 − 0.100 V 1 1 V 1 1 0.90 1.20 1.50 V 1 1 1.90 2.00 2.10 V 1 1 VDD criteria, VDD = 3.5 V 0.7 1.2 1.5 V 1 1 Output logic is determined*2 1.5 − 8 V − − VDD = 3.5 V, VVM = 0 V 1.0 3.5 7.0 μA 2 2 − − 0.1 μA 2 2 VDD = 1.8 V, VVM = 0 V 100 300 900 kΩ 3 3 VDD = VVINI = 3.5 V, VDO = 0.5 V 2.5 5 10 kΩ 4 4 tDIOV1 tDIOV1 × 1.4 ms 5 5 tDIOV2 tDIOV2 × 1.4 ms 5 5 280 392 μs 5 5 VDD = VVM = 1.5 V tDIOV1 Overcurrent 1 detection delay − tDlOV1 × 0.6 time tDIOV2 Overcurrent 2 detection delay − tDlOV2 × 0.6 time Overcurrent 3 detection delay With overcurrent 3 detection 168 tDlOV3 function time − 2.94 UVLO detection delay time tUVLO *1. Even if overcurrent 1 detection voltage and overcurrent 2 detection voltage are VDIOV2. *2. It indicates that DO pin output logic is determined. 6 VDIOV1 + 0.015 VDIOV2 + 0.100 4.90 6.86 s 5 5 in the same range, VDIOV1 is lower than Rev.1.2_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series 2. Ta = −40°C to +85°C*1 Table 6 Item Symbol Condition (Ta = −40°C to +85°C*1 unless otherwise specified) Test Test Min. Typ. Max. Unit Condition Circuit Detection Voltage VDIOV1 − Overcurrent 2 detection voltage*2 VDIOV2 − Overcurrent 1 detection voltage Overcurrent 3 detection voltage VDIOV3 UVLO detection voltage VUVLO Release Voltage Overcurrent release voltage VRIOV Input Voltage, Operation Voltage Operation voltage between VDSOP VDD pin and VSS pin Current Consumption Current consumption during IOPE normal operation Current consumption during IPDN power-down Internal Resistance Internal resistance between RVMD VM pin and VDD pin Output Resistance DO pin resistance "L" RDOL Delay Time With overcurrent 3 detection function − VDIOV1 VDIOV1 − 0.021 VDIOV2 VDIOV2 − 0.130 VDIOV1 + 0.021 VDIOV2 + 0.130 V 1 1 V 1 1 0.70 1.20 1.70 V 1 1 1.85 2.00 2.15 V 1 1 VDD criteria, VDD = 3.5 V 0.5 1.2 1.7 V 1 1 Output logic is determined*3 1.5 − 8 V − − VDD = 3.5 V, VVM = 0 V 0.7 3.5 8.0 μA 2 2 VDD = VVM = 1.5 V − − 0.15 μA 2 2 VDD =1.8 V, VVM = 0 V 78 300 1310 kΩ 3 3 VDD = VVINI = 3.5 V, VDO = 0.5 V 1.2 5 15 kΩ 4 4 tDIOV1 tDIOV1 Overcurrent 1 detection delay − tDIOV1 ms 5 5 tDlOV1 × 0.2 × 1.8 time tDIOV2 tDIOV2 Overcurrent 2 detection delay − tDIOV2 ms 5 5 tDlOV2 × 0.2 × 1.8 time Overcurrent 3 detection delay With overcurrent 3 detection μs 5 5 56 280 504 tDlOV3 function time − 0.98 4.90 8.82 s 5 5 UVLO detection delay time tUVLO *1. Since products are not screened at high and low temperatures, the specification for this temperature range is guaranteed by design, not tested in production. *2. Even if overcurrent 1 detection voltage and overcurrent 2 detection voltage are in the same range, VDIOV1 is lower than VDIOV2. *3. It indicates that DO pin output logic is determined. 7 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00  Test Circuits Caution Unless otherwise specified, the output voltage levels "H" and "L" at the DO pin (VDO) are judged by the threshold voltage (1.0 V) of the N-channel FET. Judge the DO pin level with respect to VSS. 1. Overcurrent 1 detection voltage, overcurrent 2 detection voltage, overcurrent release voltage, UVLO detection voltage (Test condition 1, test circuit 1) The overcurrent 1 detection voltage (VDIOV1) is defined as the voltage V2 whose delay time for changing VDO from "H" to "L" lies between the minimum and the maximum value of the overcurrent 1 detection delay time after the voltage V2 is increased instantaneously (within 10 μs) from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. The overcurrent 2 detection voltage (VDIOV2) is defined as the voltage V2 whose delay time for changing VDO from "H" to "L" lies between the minimum and the maximum value of the overcurrent 2 detection delay time after the voltage V2 is increased instantaneously (within 10 μs) from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. The overcurrent release voltage (VRIOV) is defined as the voltage V3 at which VDO goes from "L" to "H" after decreasing V2 to 0 V and the voltage V3 is increased gradually from the set conditions of V1 = V2 = 3.5 V, V3 = 0 V. The UVLO detection voltage (VUVLO) is defined as the voltage V1 at which VDO goes from "H" to "L" after the voltages V1 and V3 are decreased gradually from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. 2. Overcurrent 3 detection voltage (With overcurrent 3 detection function) (Test condition 1, test circuit 1) The overcurrent 3 detection voltage (VDIOV3) is defined as the voltage V2 whose delay time for changing VDO from "H" to "L" lies between the minimum and the maximum value of the overcurrent 3 detection delay time after the voltage V2 is increased instantaneously (within 10 μs) from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. 3. Current consumption during normal operation, current consumption during power-down (Test condition 2, test circuit 2) The current consumption during normal operation (IOPE) is the current that flows through the VDD pin (IDD) under the set conditions of V1 = 3.5 V, V2 = 0 V. The current consumption during power-down (IPDN) is IDD under the set conditions of V1 = V2 = 1.5 V. 4. Internal resistance between VM pin and VDD pin (Test condition 3, test circuit 3) The internal resistance between the VM pin and the VDD pin (RVMD) is the resistance between the VM pin and the VDD pin under the set conditions of V1 = 1.8 V, V2 = V3 = 0 V. 5. DO pin resistance "L" (Test condition 4, test circuit 4) The DO pin resistance "L" (RDOL) is the DO pin resistance under the set conditions of V1 = V2 = 3.5 V, V3 = 0.5 V. 8 Rev.1.2_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series 6. Overcurrent 1 detection delay time (Test condition 5, test circuit 5) 6. 1 VDIOV2 = 0.1 V The overcurrent 1 detection delay time (tDIOV1) is the time period from when the voltage V2 exceeds VDIOV1 to when VDO goes to "L", after V2 is increased to 0.08 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 6. 2 VDIOV2 ≥ 0.2 V The overcurrent 1 detection delay time (tDIOV1) is the time period from when the voltage V2 exceeds VDIOV1 to when VDO goes to "L", after V2 is increased to VDIOV1 max. + 0.01 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 7. Overcurrent 2 detection delay time, UVLO detection delay time (Test condition 5, test circuit 5) The overcurrent 2 detection delay time (tDIOV2) is the time period from when the voltage V2 exceeds VDIOV2 to when VDO goes to "L", after V2 is increased to 0.9 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. The UVLO detection delay time (tUVLO) is the time period from when the voltage V1 falls below VUVLO to when VDO goes to "L", after V1 is decreased to 1.8 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 8. Overcurrent 3 detection delay time (With overcurrent 3 detection function) (Test condition 5, test circuit 5) The overcurrent 3 detection delay time (tDIOV3) is the time period from when the voltage V2 exceeds VDIOV3 to when VDO goes to "L", after V2 is increased to 1.6 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 9 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series IDD A DP VDD V1 VSS S-8239B Series V3 VM VSS VM DO VINI DO VINI DP VDD V1 S-8239B Series Rev.1.2_00 100 kΩ V2 V2 V VDO COM COM Figure 5 Test Circuit 2 Figure 4 Test Circuit 1 V1 S-8239B Series V1 S-8239B Series VINI DO VINI VM VSS VM VSS DP VDD DP VDD DO A IVM A IDO COM COM Figure 6 Test Circuit 3 DP VDD V1 S-8239B Series VSS VM DO VINI 100 kΩ V2 COM 10 V2 V3 V2 Oscilloscope Figure 8 Test Circuit 5 Figure 7 Test Circuit 4 V3 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00  Operation 1. Normal status The S-8239B Series monitors the voltage between the VINI pin and the VSS pin to control discharging. When the VINI pin voltage is equal to or lower than the overcurrent 1 detection voltage (VDIOV1), the DO pin becomes "High-Z". This status is called the normal status. Caution When a battery is connected for the first time, the S-8239B Series may not be in the normal status. In this case, short the VM pin and VSS pin or connect the charger. The S-8239B Series then becomes the normal status. 2. Overcurrent status (Overcurrent 1, overcurrent 2, overcurrent 3) When a battery is in the normal status, if the VINI pin voltage is equal to or higher than the overcurrent detection voltage because the discharge current is equal to or higher than the specified value and the status continues for the overcurrent detection delay time or longer, the DO pin becomes VSS potential. This status is called the overcurrent status. The overcurrent status is retained when the voltage between the VDD pin and the VM pin is equal to or lower than the overcurrent release voltage (VRIOV). In the overcurrent status, the VM pin and the VDD pin are shorted by the internal resistance between the VM pin and the VDD pin (RVMD) in the S-8239B Series. After that, the overcurrent status is released if the voltage between the VDD pin and the VM pin becomes equal to or higher than VRIOV by connecting a charger. 3. UVLO status The S-8239B Series includes a UVLO (under voltage lock out) function to prevent the IC malfunction due to the decrease of the battery voltage when detecting the overcurrent. When the battery voltage in the normal status is equal to or lower than the UVLO detection voltage (VUVLO) and the status continues for the UVLO detection delay time (tUVLO) or longer, the DO pin becomes VSS potential. This status is called the UVLO status. In the UVLO status, the VM pin and the VDD pin are shorted by RVMD between the VM pin and the VDD pin in the S-8239B Series. After that, the UVLO status is released if the battery voltage becomes equal to or higher than VUVLO. 4. Power-down status In the UVLO status, the current consumption is decreased to the current consumption during power-down (IPDN) if the voltage between the VDD pin and the VM pin becomes equal to or lower than 0.7 V typ. in the S-8239B Series. This status is called the power-down status. Moreover, if the voltage between the VDD pin and the VM pin becomes equal to or lower than 0.7 V typ. and the status continues for tUVLO or longer in the normal status, the DO pin becomes VSS potential and the S-8239B Series becomes power-down status. After that, the power-down status is released if the voltage between the VDD pin and the VM pin is equal to or higher than 0.7 V typ. by connecting a charger. 11 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00 5. Delay circuit The detection delay times are determined by dividing a clock of approximately 3.5 kHz with the counter. Remark The overcurrent 2 detection delay time (tDIOV2) starts when the overcurrent 1 detection voltage (VDIOV1) is detected. When the overcurrent 2 detection voltage (VDIOV2) is detected over tDIOV2 after the detection of VDIOV1, the S-8239B Series becomes the overcurrent status within tDIOV2 from the time of detecting VDIOV2. DO pin High-Z 0 ≤ tD ≤ tDIOV2 VSS tDIOV2 tD Time VDIOV2 VINI pin VDIOV1 VSS Time Figure 9 6. DP pin The DP pin is a test pin for delay time measurement and it should be open in the actual application. If a capacitor whose capacitance is 1000 pF or more or a resistor whose resistance is 1 MΩ or less is connected to this pin, error may occur in the delay times or in the detection voltages. 12 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00  Timing Charts 1. Overcurrent detection 1. 1 With overcurrent 3 detection function VINI pin VDIOV3 VDIOV2 VDIOV1 VSS VDD VRIOV VM pin VSS High-Z DO pin High-Z High-Z High-Z Overcurrent 2 detection delay time (tDIOV2) Overcurrent 3 detection delay time (tDIOV3) VSS Charger connection External load connection Overcurrent 1 detection delay time (tDIOV1) Status *1 (1) (2) (1) (2) (1) (2) (1) *1. (1): Normal status (2): Overcurrent status Figure 10 13 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series 1. 2 Without overcurrent 3 detection function VINI pin VDIOV2 VDIOV1 VSS VDD VRIOV VM pin VSS High-Z DO pin High-Z High-Z VSS Charger connection External load connection Overcurrent 1 detection delay time (tDIOV1) Status Overcurrent 2 detection delay time (tDIOV2) *1 (1) (2) (1) (2) *1. (1): Normal status (2): Overcurrent status Figure 11 14 (1) Rev.1.2_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00 2. UVLO detecion VUVLO Battery voltage VDD VDD − 0.7 V VM pin VSS DO pin High-Z High-Z VSS Charger connection External load connection UVLO detection delay time (tUVLO) Status *1 (1) (2) (3) (2) (1) *1. (1): Normal status (2): UVLO status (3): Power-down status Remark The charger is assumed to charge with a constant current. Figure 12 15 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00  5-serial-cell Protection Circuit Example Figure 13 shows the 5-serial-cell protection circuit example used by the S-8239B Series and the S-8225A Series. Contact our sales representatives when using the circuit other than the following protection circuit example. EB+ 100 Ω 1 MΩ FET4 CTLD VDD CTLC VC1 CO VC2 1 kΩ 1 MΩ 0.1 μF 0.1 μF 1 kΩ *2 FET2 FET3 330 kΩ RVM FET1*2 RDOP VM DP S-8239B Series DO VDD RDO VSS VINI RVINI 1 MΩ VC3 DO S-8225A Series*1 SEL1 VC4 1 kΩ 1 kΩ RVDD CVDD SEL2 VC5 CDT VC6 CCT VSS 1 kΩ 1 μF 0.1 μF 0.1 μF ZVINI 100 Ω 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ CHA− DIS− CFET DFET RSENSE Figure 13 Table 7 Constants for External Components Symbol RVDD RVINI RSENSE RVM RDO*3 RDOP CVDD Min. 300 1 0 1 − 330 0.022 Typ. 470 − − 5.1 5.1 510 0.1 Max. 1000 − − 51 − 2000 1 Unit Ω kΩ mΩ kΩ kΩ kΩ μF *1. Refer to the data sheet of the S-8225A Series for the recommended value for external components of the S-8225A Series. *2. Use the products with the same model number for FET1 and FET2. *3. Set up the optimal constant according to the FET in use. Caution 1. The constants may be changed without notice. 2. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. 3. The DP pin should be open. 16 Rev.1.2_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series  Precautions • The application conditions for the input voltage, output voltage, and load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 17 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00  Characteristics (Typical Data) 1. Current consumption 1. 2 IOPE vs. VDD 8 8 6 6 IOPE [μA] IOPE [μA] 1. 1 IOPE vs. Ta 4 2 0 −40 −25 0 +25 Ta [°C] +50 0 25 Ta [°C] 50 4 2 0 +75 +85 0 2 4 VDD [V] 6 8 1. 3 IPDN vs. Ta 0.10 IPDN [μA] 0.08 0.06 0.04 0.02 0 −40 −25 75 85 2. Overcurrent detection / release voltage, UVLO function and delay times 2. 1 VDIOV1 vs. Ta 2. 2 VDIOV2 vs. Ta VDIOV2 = 0.4 V 0.10 0.6 0.09 0.5 VDIOV2 [V] VDIOV1 [V] VDIOV1 = 0.08 V 0.08 0.07 0.06 −40 −25 0 25 Ta [°C] 50 25 Ta [°C] 50 +75 +85 0 +25 Ta [°C] +50 +75 +85 1.5 1.3 VRIOV [V] VDIOV3 [V] 0 1.8 1.4 1.2 1.1 1.0 18 −40 −25 2. 4 VRIOV vs. Ta 1.5 0.9 0.3 0.2 +75 +85 2. 3 VDIOV3 vs. Ta 0.4 −40 −25 0 25 Ta [°C] 50 +75 +85 1.2 0.9 0.6 −40 −25 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00 2. 6 VDIOV2 vs. VDD 2. 5 VDIOV1 vs. VDD VDIOV2 = 0.4 V 0.10 0.6 0.09 0.5 VDIOV2 [V] VDIOV1 [V] VDIOV1 = 0.08 V 0.08 0.07 0.06 0.4 0.3 0.2 2 3 4 5 6 7 2 8 3 4 5 VDD [V] 6 7 8 4 5 VDD [V] 6 7 8 VDD [V] 2. 7 VDIOV3 vs. VDD 2. 8 VRIOV vs. VDD 1.5 1.8 1.4 1.5 VRIOV [V] VDIOV3 [V] 1.3 1.2 1.1 1.0 0.9 1.2 0.9 0.6 2 3 4 5 6 7 2 8 3 VDD [V] 2. 9 tDIOV1 vs. Ta 2. 10 tDIOV2 vs. Ta tDIOV2 = 1.12 ms 1.6 1.4 1.4 tDIOV2 [ms] tDIOV1 [s] tDIOV1 = 1150 ms 1.6 1.2 1.0 0.8 −40 −25 +25 Ta [°C] 0 +50 +75 +85 2. 11 tDIOV3 vs. Ta 1.2 1.0 0.8 −40 −25 0 +25 Ta [°C] +50 +75 +85 2. 12 tDIOV1 vs. VDD 400 1.6 340 1.4 tDIOV1 [s] tDIOV3 [μs] tDIOV1 = 1150 ms 280 220 160 −40 −25 0 +25 Ta [°C] +50 +75 +85 1.2 1.0 0.8 2 3 4 5 VDD [V] 6 7 8 19 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series 2. 13 tDIOV2 vs. VDD Rev.1.2_00 2. 14 tDIOV3 vs. VDD 1.6 400 1.4 340 tDIOV3 [μs] tDIOV2 [ms] tDIOV2 = 1.12 ms 1.2 1.0 0.8 280 220 160 2 3 4 5 6 7 2 8 3 4 VDD [V] 2. 15 VUVLO vs. Ta tUVLO [s] VUVLO [V] 8 5.5 2.0 1.9 5.0 4.5 4.0 3.5 −40 −25 0 25 Ta [°C] 50 +75 +85 3. Output Resistance 3. 1 RDOL vs. Ta 10.0 8.0 RDOL [kΩ] 7 6.0 2.1 6.0 4.0 2.0 0.0 20 6 2. 16 tUVLO vs. VDD 2.2 1.8 5 VDD [V] −40 −25 0 +25 Ta [°C] +50 +75 +85 3.0 1.5 1.6 1.7 1.8 VDD [V] 1.9 2.0 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239B Series Rev.1.2_00  Marking Specification 1. SOT-23-6 Top view 6 5 (1) to (3): (4): 4 Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) 1 2 3 Product name vs. Product code Product Name S-8239BAA-M6T1U Product Code (1) (2) (3) 3 L A 21 2.9±0.2 1.9±0.2 6 0.95 4 5 1 2 3 +0.1 0.15 -0.05 0.95 0.35±0.15 No. MP006-A-P-SD-2.1 TITLE SOT236-A-PKG Dimensions No. MP006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 6 Feed direction No. MP006-A-C-SD-3.1 TITLE SOT236-A-Carrier Tape No. MP006-A-C-SD-3.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP006-A-R-SD-2.1 TITLE SOT236-A-Reel No. MP006-A-R-SD-2.1 ANGLE QTY UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-8239BAA-M6T1U 价格&库存
很抱歉,暂时无法提供与“S-8239BAA-M6T1U”相匹配的价格&库存,您可以联系我们找货
