WTB26I-1H161120A00
WTB26I-1H161120A00
    SICK
    SENSOR PROXIMITY 2M NPN/PNP
WTB26I-1H161120A00 数据手册
Product data sheet WTB26I-1H161120A00 W26 COMPACT PHOTOELECTRIC SENSORS WTB26I-1H161120A00 | W26 COMPACT PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WTB26I-1H161120A00 1218825 Other models and accessories www.sick.com/W26 Illustration may differ Detailed technical data Features Sensor/ detection principle Photoelectric proximity sensor, Background suppression Dimensions (W x H x D) 24.6 mm x 82.5 mm x 53.3 mm Housing design (light emission) Rectangular Sensing range max. 30 mm ... 2,000 mm 1) Type of light Infrared light Light source LED 2) Light spot size (distance) Ø 14 mm (1,000 mm) Wave length 850 nm Adjustment Teach-Turn adjustment BluePilot: For setting the sensing range IO-Link For configuring the sensor parameters and Smart Task functions Indication LED blue BluePilot: sensing range indicator LED green Operating indicator Static: power on Flashing: IO-Link mode LED yellow Status of received light beam Static on: object present Static off: object not present 1) 2) 2  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-18 16:08:35 Subject to change without notice WTB26I-1H161120A00 | W26 COMPACT PHOTOELECTRIC SENSORS Pin 2 configuration 1) 2) External Input (test), Teach-in, switching signal  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple
WTB26I-1H161120A00 价格&库存
很抱歉,暂时无法提供与“WTB26I-1H161120A00”相匹配的价格&库存,您可以联系我们找货
WTB26I-1H161120A00
  • 1+3190.903451+411.91890
  • 5+2945.456075+380.23370
