S-8239AAI-M6T1U
S-8239AAI-M6T1U
    ABLIC(艾普凌科)
    SOT23-6
    IC BATT MONITOR LI-ION SOT23-6
S-8239AAI-M6T1U 数据手册
S-8239A Series www.ablic.com OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK © ABLIC Inc., 2013-2020 Rev.1.6_00 The S-8239A Series is an overcurrent monitoring IC for multi-serial-cell pack including high-accuracy voltage detection circuits and delay circuits. The S-8239A Series is suitable for protection of lithium-ion / lithium polymer rechargeable battery packs from overcurrent.  Features • Built-in high-accuracy voltage detection circuit Overcurrent 1 detection voltage*1 0.04 V to 0.30 V (10 mV step) Accuracy ±15 mV Overcurrent 2 detection voltage 0.1 V to 0.7 V (100 mV step) Accuracy ±100 mV Overcurrent 3 detection voltage 1.2 V (Fixed) Accuracy ±300 mV • Built-in three-step overcurrent detection circuit: Overcurrent 1, overcurrent 2, overcurrent 3 • Overcurrent 3 detection function: Available, unavailable • UVLO (under voltage lock out) function UVLO detection voltage 2.0 V (Fixed) Accuracy ±100 mV • High-withstand voltage: VM pin, DO pin: Absolute maximum rating 28 V • Delay times are generated only by an internal circuit (External capacitors are unnecessary). • Low current consumption During normal operation: 7.0 μA max. During UVLO operation: 6.0 μA max. • Output logic: Active "L", Active "H" • Wide operation temperature range: Ta = −40°C to +85°C • Lead-free (Sn 100%), halogen-free *1. Overcurrent 1 detection voltage ≤ 0.06 V should be satisfied in the case of overcurrent 2 detection voltage = 0.1 V. Overcurrent 1 detection voltage ≤ 0.85 × overcurrent 2 detection voltage − 0.05 V should be satisfied in the case of overcurrent 2 detection voltage ≥ 0.2 V.  Applications • Lithium-ion rechargeable battery pack • Lithium polymer rechargeable battery pack  Package • SOT-23-6 1 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00  Block Diagram DP DO + VDD − Delay circuit output control circuit UVLO detection comparator + − VM RVMS Overcurrent latch comparator + − VINI Overcurrent 1 detection comparator + − Overcurrent 2 detection comparator + − VSS Remark All the diodes shown in the figure are parasitic diodes. Figure 1 2 Overcurrent 3 detection comparator OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00  Product Name Structure 1. Product name S-8239A xx - M6T1 U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 M6T1: SOT-23-6, Tape Serial code*2 Sequentially set from AA to ZZ *1. Refer to the tape drawing. *2. Refer to "3. Product name list". 2. Package Table 1 Package Drawing Codes Package Name SOT-23-6 Dimension Tape Reel MP006-A-P-SD MP006-A-C-SD MP006-A-R-SD 3. Product name list Table 2 Product Name Overcurrent 1 Detection Voltage [VDIOV1] Overcurrent 2 Detection Voltage [VDIOV2] Overcurrent 1 Detection Delay Time [tDIOV1] Overcurrent 2 Detection Delay Time [tDIOV2] S-8239AAA-M6T1U 0.08 V 0.4 V 1150 ms S-8239AAB-M6T1U 0.10 V 0.5 V 1150 ms S-8239AAC-M6T1U 0.10 V 0.3 V 18.0 ms S-8239AAD-M6T1U 0.10 V 0.2 V 290 ms S-8239AAE-M6T1U 0.10 V 0.7 V 18.0 ms S-8239AAF-M6T1U 0.04 V 0.3 V 4600 ms S-8239AAG-M6T1U 0.10 V 0.2 V 1150 ms S-8239AAH-M6T1U 0.06 V 0.1 V 290 ms S-8239AAI-M6T1U 0.10 V 0.3 V 290 ms S-8239AAJ-M6T1U 0.11 V 0.3 V 4600 ms S-8239AAK-M6T1U 0.10 V 0.3 V 290 ms S-8239AAL-M6T1U 0.06 V 0.2 V 290 ms S-8239AAM-M6T1U 0.06 V 0.1 V 1150 ms S-8239AAN-M6T1U 0.07 V 0.2 V 290 ms S-8239AAO-M6T1U 0.30 V 0.6 V 4600 ms S-8239AAP-M6T1U 0.10 V 0.2 V 36 ms Remark Contact our sales representatives for products other than the above. 1.12 ms 0.28 ms 0.28 ms 0.56 ms 0.56 ms 0.28 ms 1.12 ms 0.56 ms 0.28 ms 2.24 ms 1.12 ms 1.12 ms 9.00 ms 0.56 ms 143 ms 0.56 ms Overcurrent 3 Detection Output Logic Function Unavailable Unavailable Unavailable Unavailable Unavailable Unavailable Available Unavailable Unavailable Available Available Unavailable Available Available Available Unavailable Active "L" Active "L" Active "L" Active "L" Active "L" Active "L" Active "L" Active "L" Active "L" Active "L" Active "H" Active "L" Active "L" Active "L" Active "L" Active "L" 3 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00  Pin Configuration 1. SOT-23-6 Table 3 Top view 6 5 4 1 2 3 Figure 2 *1. The DP pin should be open. 4 Pin No. Symbol 1 VINI 2 3 4 5 6 VM DO DP*1 VDD VSS Description Voltage detection pin between VINI pin and VSS pin (Overcurrent detection pin) Overcurrent latch pin Connection pin of discharge control FET gate Test pin for delay time measurement Input pin for positive power supply Input pin for negative power supply Rev.1.6_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series  Absolute Maximum Ratings Table 4 (Ta = +25°C unless otherwise specified) Item Input voltage between VDD pin and VSS pin VM pin input voltage VINI pin input voltage DO pin output voltage Power dissipation Operation ambient temperature Symbol VDS VVM VVINI VDO PD Topr Storage temperature Tstg Applied pin VDD VM VINI DO − − Absolute Maximum Rating VSS − 0.3 to VSS +12 VDD − 28 to VDD + 0.3 VSS − 0.3 to VSS + 12 VSS − 0.3 to VSS + 28 650*1 −40 to +85 Unit V V V V mW °C − −55 to +125 °C *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm × 76.2 mm × t1.6 mm (2) Board name: JEDEC STANDARD51-7 1. The DP pin should be open. 2. The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 700 Power dissipation (PD) [mW] Caution 600 500 400 300 200 100 0 0 100 150 50 Ambient temperature (Ta) [°C] Figure 3 Power Dissipation of Package (When Mounted on Board) 5 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00  Electrical Characteristics 1. Ta = +25°C Table 5 Item Symbol Condition VDIOV1 − Overcurrent 2 detection voltage*1 VDIOV2 − Min. (Ta = +25°C unless otherwise specified) Test Test Typ. Max. Unit Condition Circuit Detection Voltage Overcurrent 1 detection voltage Overcurrent 3 detection voltage VDIOV3 UVLO detection voltage VUVLO Release Voltage Overcurrent release voltage VRIOV Input Voltage, Operation Voltage Operation voltage between VDSOP VDD pin and VSS pin Current Consumption Current consumption during IOPE normal operation Current consumption during IUVLO UVLO operation Internal Resistance Internal resistance between RVMS VM pin and VSS pin Output Resistance (Active "L") DO pin resistance "L" RDOL Output Resistance (Active "H") DO pin resistance "L" RDOL With overcurrent 3 detection function − VDIOV1 VDIOV1 − 0.015 VDIOV2 VDIOV2 − 0.100 VDIOV1 + 0.015 VDIOV2 + 0.100 V 1 1 V 1 1 0.90 1.20 1.50 V 1 1 1.90 2.00 2.10 V 1 1 VDD criteria, VDD = 3.5 V 0.7 1.2 1.5 V 1 1 Output logic is determined*2 1.5 − 8 V − − VDD = 3.5 V, VVM = 0 V 1.0 3.5 7.0 μA 2 2 VDD = VVM = 1.5 V 0.7 3.0 6.0 μA 2 2 VDD = VVM = 3.5 V 210 300 390 kΩ 3 3 VDD = VVINI = 3.5 V, VDO = 0.5 V 2.5 5 10 kΩ 4 4 VDD = 3.5 V, VVINI = 0 V VDO = 0.5 V 2.5 5 10 kΩ 4 4 tDIOV1 tDIOV1 × 1.4 ms 5 5 tDIOV2 tDIOV2 × 1.4 ms 5 5 280 392 μs 5 5 Delay Time tDIOV1 Overcurrent 1 detection delay − tDlOV1 × 0.6 time t Overcurrent 2 detection delay DIOV2 − tDlOV2 × 0.6 time With overcurrent 3 detection Overcurrent 3 detection delay 168 tDlOV3 function time − UVLO detection delay time tUVLO 2.94 *1. Even if overcurrent 1 detection voltage and overcurrent 2 detection voltage are VDIOV2. *2. It indicates that DO pin output logic is determined. 6 4.90 6.86 s 5 5 in the same range, VDIOV1 is lower than Rev.1.6_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series 2. Ta = −40°C to +85°C*1 Table 6 Item Symbol Condition (Ta = −40°C to +85°C*1 unless otherwise specified) Test Test Min. Typ. Max. Unit Condition Circuit Detection Voltage VDIOV1 − Overcurrent 2 detection voltage*2 VDIOV2 − Overcurrent 1 detection voltage Overcurrent 3 detection voltage VDIOV3 UVLO detection voltage VUVLO Release Voltage Overcurrent release voltage VRIOV Input Voltage, Operation Voltage Operation voltage between VDSOP VDD pin and VSS pin Current Consumption Current consumption during IOPE normal operation Current consumption during IUVLO UVLO operation Internal Resistance Internal resistance between RVMS VM pin and VSS pin Output Resistance (Active "L") DO pin resistance "L" RDOL Output Resistance (Active "H") DO pin resistance "L" RDOL With overcurrent 3 detection function − VDIOV1 VDIOV1 − 0.021 VDIOV2 VDIOV2 − 0.130 VDIOV1 + 0.021 VDIOV2 + 0.130 V 1 1 V 1 1 0.70 1.20 1.70 V 1 1 1.85 2.00 2.15 V 1 1 VDD criteria, VDD = 3.5 V 0.5 1.2 1.7 V 1 1 Output logic is determined*3 1.5 − 8 V − − VDD = 3.5 V, VVM = 0 V 0.7 3.5 8.0 μA 2 2 VDD = VVM = 1.5 V 0.5 3.0 7.0 μA 2 2 VDD = VVM = 3.5 V 150 300 450 kΩ 3 3 VDD = VVINI = 3.5 V, VDO = 0.5 V 1.2 5 15 kΩ 4 4 VDD = 3.5 V, VVINI = 0 V VDO = 0.5 V 1.2 5 15 kΩ 4 4 Delay Time tDIOV1 tDIOV1 Overcurrent 1 detection delay − tDlOV1 tDIOV1 ms 5 5 × 0.2 × 1.8 time tDIOV2 tDIOV2 Overcurrent 2 detection delay − tDlOV2 tDIOV2 ms 5 5 × 0.2 × 1.8 time With overcurrent 3 detection Overcurrent 3 detection delay μs 56 280 504 tDlOV3 5 5 function time − UVLO detection delay time tUVLO 0.98 4.90 8.82 s 5 5 *1. Since products are not screened at high and low temperatures, the specification for this temperature range is guaranteed by design, not tested in production. *2. Even if overcurrent 1 detection voltage and overcurrent 2 detection voltage are in the same range, VDIOV1 is lower than VDIOV2. *3. It indicates that DO pin output logic is determined. 7 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00  Test Circuits Caution Unless otherwise specified, the output voltage levels "H" and "L" at the DO pin (VDO) are judged by the threshold voltage (1.0 V) of the N-channel FET. Judge the DO pin level with respect to VSS. 1. Overcurrent 1 detection voltage, overcurrent 2 detection voltage, overcurrent release voltage, UVLO detection voltage (Test condition 1, test circuit 1) 1. 1 Active "L" The overcurrent 1 detection voltage (VDIOV1) is defined as the voltage V2 whose delay time for changing VDO from "H" to "L" lies between the minimum and the maximum value of the overcurrent 1 detection delay time after the voltage V2 is increased instantaneously (within 10 μs) from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. The overcurrent 2 detection voltage (VDIOV2) is defined as the voltage V2 whose delay time for changing VDO from "H" to "L" lies between the minimum and the maximum value of the overcurrent 2 detection delay time after the voltage V2 is increased instantaneously (within 10 μs) from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. The overcurrent release voltage (VRIOV) is defined as the voltage V3 at which VDO goes from "L" to "H" after decreasing V2 to 0 V and the voltage V3 is increased gradually from the set conditions of V1 = V2 = 3.5 V, V3 = 0 V. The UVLO detection voltage (VUVLO) is defined as the voltage V1 at which VDO goes from "H" to "L" after the voltages V1 and V3 are decreased gradually from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. 1. 2 Active "H" The overcurrent 1 detection voltage (VDIOV1) is defined as the voltage V2 whose delay time for changing VDO from "L" to "H" lies between the minimum and the maximum value of the overcurrent 1 detection delay time after the voltage V2 is increased instantaneously (within 10 μs) from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. The overcurrent 2 detection voltage (VDIOV2) is defined as the voltage V2 whose delay time for changing VDO from "L" to "H" lies between the minimum and the maximum value of the overcurrent 2 detection delay time after the voltage V2 is increased instantaneously (within 10 μs) from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. The overcurrent release voltage (VRIOV) is defined as the voltage V3 at which VDO goes from "H" to "L" after decreasing V2 to 0 V and the voltage V3 is increased gradually from the set conditions of V1 = V2 = 3.5 V, V3 = 0 V. The UVLO detection voltage (VUVLO) is defined as the voltage V1 at which VDO goes from "L" to "H" after the voltages V1 and V3 are decreased gradually from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. 2. Overcurrent 3 detection voltage (With overcurrent 3 detection function) (Test condition 1, test circuit 1) 2. 1 Active "L" The overcurrent 3 detection voltage (VDIOV3) is defined as the voltage V2 whose delay time for changing VDO from "H" to "L" lies between the minimum and the maximum value of the overcurrent 3 detection delay time after the voltage V2 is increased instantaneously (within 10 μs) from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. 2. 2 Active "H" The overcurrent 3 detection voltage (VDIOV3) is defined as the voltage V2 whose delay time for changing VDO from "L" to "H" lies between the minimum and the maximum value of the overcurrent 3 detection delay time after the voltage V2 is increased instantaneously (within 10 μs) from the set conditions of V1 = V3 = 3.5 V, V2 = 0 V. 3. Current consumption during normal operation, current consumption during UVLO operation (Test condition 2, test circuit 2) The current consumption during normal operation (IOPE) is the current that flows through the VDD pin (IDD) under the set conditions of V1 = 3.5 V, V2 = 0 V. The current consumption during UVLO operation (IUVLO) is IDD under the set conditions of V1 = V2 = 1.5 V. 4. Internal resistance between VM pin and VSS pin (Test condition 3, test circuit 3) The internal resistance between the VM pin and the VSS pin (RVMS) is the resistance between the VM pin and the VSS pin under the set condition of V1 = V2 = V3 = 3.5 V. 8 Rev.1.6_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series 5. DO pin resistance "L" (Test condition 4, test circuit 4) 5. 1 Active "L" The DO pin resistance "L" (RDOL) is the DO pin resistance under the set conditions of V1 = V2 = 3.5 V, V3 = 0.5 V. 5. 2 Active "H" The DO pin resistance "L" (RDOL) is the DO pin resistance under the set conditions of V1 = 3.5 V, V2 = 0 V, V3 = 0.5 V. 6. Overcurrent 1 detection delay time (Test condition 5, test circuit 5) 6. 1 Active "L" 6. 1. 1 VDIOV2 = 0.1 V The overcurrent 1 detection delay time (tDIOV1) is the time period from when the voltage V2 exceeds VDIOV1 to when VDO goes to "L", after V2 is increased to 0.08V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 6. 1. 2 VDIOV2 ≥ 0.2 V The overcurrent 1 detection delay time (tDIOV1) is the time period from when the voltage V2 exceeds VDIOV1 to when VDO goes to "L", after V2 is increased to VDIOV1 max. + 0.01 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 6. 2 Active "H" 6. 2. 1 VDIOV2 = 0.1 V The overcurrent 1 detection delay time (tDIOV1) is the time period from when the voltage V2 exceeds VDIOV1 to when VDO goes to "H", after V2 is increased to 0.08V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 6. 2. 2 VDIOV2 ≥ 0.2 V The overcurrent 1 detection delay time (tDIOV1) is the time period from when the voltage V2 exceeds VDIOV1 to when VDO goes to "H", after V2 is increased to VDIOV1 max. + 0.01 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 7. Overcurrent 2 detection delay time, UVLO detection delay time (Test condition 5, test circuit 5) 7. 1 Active "L" The overcurrent 2 detection delay time (tDIOV2) is the time period from when the voltage V2 exceeds VDIOV2 to when VDO goes to "L", after V2 is increased to 0.9 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. The UVLO detection delay time (tUVLO) is the time period from when the voltage V1 falls below VUVLO to when VDO goes to "L", after V1 is decreased to 1.8 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 7. 2 Active "H" The overcurrent 2 detection delay time (tDIOV2) is the time period from when the voltage V2 exceeds VDIOV2 to when VDO goes to "H", after V2 is increased to 0.9 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. The UVLO detection delay time (tUVLO) is the time period from when the voltage V1 falls below VUVLO to when VDO goes to "H", after V1 is decreased to 1.8 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 9 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00 8. Overcurrent 3 detection delay time (With overcurrent 3 detection function) (Test condition 5, test circuit 5) 8. 1 Active "L" The overcurrent 3 detection delay time (tDIOV3) is the time period from when the voltage V2 exceeds VDIOV3 to when VDO goes to "L", after V2 is increased to 1.6 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 8. 2 Active "H" The overcurrent 3 detection delay time (tDIOV3) is the time period from when the voltage V2 exceeds VDIOV3 to when VDO goes to "H", after V2 is increased to 1.6 V instantaneously (within 10 μs) under the set conditions of V1 = 3.5 V, V2 = 0 V. 10 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00 IDD A DP VDD V1 V1 S-8239A Series VSS S-8239A Series V3 VM VSS VM DO VINI DO VINI DP VDD 100 kΩ V2 V2 V VDO COM COM Figure 5 Test Circuit 2 Figure 4 Test Circuit 1 V1 S-8239A Series V1 S-8239A Series VINI DO VINI VM VSS VM VSS DP VDD DP VDD A IVM A IDO V2 V3 V2 DO V3 COM COM Figure 6 Test Circuit 3 DP VDD V1 Figure 7 Test Circuit 4 S-8239A Series VSS VM DO VINI 100 kΩ V2 COM Oscilloscope Figure 8 Test Circuit 5 11 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00  Operation 1. Normal status The S-8239A Series monitors the voltage between the VINI pin and the VSS pin to control discharging. When the VINI pin voltage is equal to or lower than the overcurrent 1 detection voltage (VDIOV1), the DO pin becomes "High-Z" (Active "L") or VSS potential (Active "H"). This status is called the normal status. Caution When a battery is connected for the first time, the S-8239A Series may not be in the normal status. In this case, short the VM pin and VSS pin or connect the charger. The S-8239A Series then becomes the normal status. 2. Overcurrent status (Overcurrent 1, overcurrent 2, overcurrent 3) When a battery is in the normal status, if the VINI pin voltage is equal to or higher than the overcurrent detection voltage because the discharge current is equal to or higher than the specified value and the status continues for the overcurrent detection delay time or longer, the DO pin becomes VSS potential (Active "L") or "High-Z" (Active "H"). This status is called the overcurrent status. The overcurrent status is retained when the voltage between the VDD pin and the VM pin is equal to or lower than the overcurrent release voltage (VRIOV). In the overcurrent status, the VM pin and VSS pin are shorted by the internal resistor between the VM pin and the VSS pin (RVMS) in the S-8239A Series. However, the VM pin is at VDD potential due to the external load as long as the external load is connected. When the external load is disconnected completely, the VM pin returns to VSS potential. The overcurrent status is released when the voltage between the VDD pin and the VM pin is equal to or higher than VRIOV. 3. UVLO status The S-8239A Series includes a UVLO (under voltage lock out) function to prevent the IC malfunction due to the decrease of the battery voltage when detecting the overcurrent. When the battery voltage in the normal status is equal to or lower than the UVLO detection voltage (VUVLO) and the status continues for the UVLO detection delay time (tUVLO) or longer, the DO pin becomes VSS potential (Active "L") or "High-Z" (Active "H"). This status is called the UVLO status. In the UVLO status, the VM pin and VSS pin are shorted by RVMS between the VM pin and the VSS pin in the S-8239A Series. After that, the UVLO status is released if the battery voltage becomes equal to or higher than VUVLO. 12 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00 4. Delay circuit The detection delay times are determined by dividing a clock of approximately 3.5 kHz with the counter. Remark The overcurrent 2 detection delay time (tDIOV2) starts when the overcurrent 1 detection voltage (VDIOV1) is detected. When the overcurrent 2 detection voltage (VDIOV2) is detected over tDIOV2 after the detection of VDIOV1, the S-8239A Series becomes the overcurrent status within tDIOV2 from the time of detecting VDIOV2. DO pin High-Z 0 ≤ tD ≤ tDIOV2 VSS tDIOV2 tD Time VDIOV2 VINI pin VDIOV1 VSS Time Figure 9 5. DP pin The DP pin is a test pin for delay time measurement and it should be open in the actual application. If a capacitor whose capacitance is 1000 pF or more or a resistor whose resistance is 1 MΩ or less is connected to this pin, error may occur in the delay times or in the detection voltages. 13 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00  Timing Charts 1. Overcurrent detection 1. 1 Active "L" 1. 1. 1 With overcurrent 3 detection function VINI pin VDIOV3 VDIOV2 VDIOV1 VSS VDD VRIOV VM pin VSS High-Z DO pin High-Z High-Z High-Z VSS External load connection Overcurrent 1 detection delay time (tDIOV1) Overcurrent 2 detection delay time (tDIOV2) Status*1 (1) (2) (1) (2) *1. (1): Normal status (2): Overcurrent status Figure 10 14 Overcurrent 3 detection delay time (tDIOV3) (1) (2) (1) OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00 1. 1. 2 Without overcurrent 3 detection function VINI pin VDIOV2 VDIOV1 VSS VDD VRIOV VM pin VSS High-Z DO pin High-Z High-Z VSS External load connection Overcurrent 1 detection delay time (tDIOV1) Overcurrent 2 detection delay time (tDIOV2) Status *1 (1) (2) (1) (2) (1) *1. (1): Normal status (2): Overcurrent status Figure 11 15 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00 1. 2 Active "H" 1. 2. 1 With overcurrent 3 detection function VINI pin VDIOV3 VDIOV2 VDIOV1 VSS VDD VRIOV VM pin VSS High-Z DO pin High-Z High-Z VSS External load connection Overcurrent 1 detection delay time (tDIOV1) Overcurrent 2 detection delay time (tDIOV2) Overcurrent 3 detection delay time (tDIOV3) Status*1 (1) (2) (1) (2) *1. (1): Normal status (2): Overcurrent status Figure 12 16 (1) (2) (1) OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00 1. 2. 2 Without overcurrent 3 detection function VINI pin VDIOV2 VDIOV1 VSS VDD VRIOV VM pin VSS High-Z DO pin High-Z VSS External load connection Overcurrent 1 detection delay time (tDIOV1) Overcurrent 2 detection delay time (tDIOV2) Status *1 (1) (2) (1) (2) (1) *1. (1): Normal status (2): Overcurrent status Figure 13 17 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series 2. UVLO detection 2. 1 Active "L" VUVLO Battery voltage VDD VM pin VSS DO pin High-Z High-Z VSS Charger connection External load connection UVLO detection delay time (tUVLO) Status *1 (1) (2) (1) *1. (1): Normal status (2): UVLO status Remark The charger is assumed to charge with a constant current. Figure 14 18 Rev.1.6_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00 2. 2 Active "H" VUVLO Battery voltage VDD VM pin VSS DO pin High-Z VSS Charger connection External load connection UVLO detection delay time (tUVLO) Status *1 (1) (2) (1) *1. (1): Normal status (2): UVLO status Remark The charger is assumed to charge with a constant current. Figure 15 19 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00  5-serial-cell Protection Circuit Examples Figure 16 and Figure 17 show the 5-serial-cell protection circuit examples used by the S-8239A Series and the S-8225A Series. Contact our sales representatives when using the circuit other than the following protection circuit examples. 1. Active "L" EB+ 100 Ω 1 MΩ FET4 CTLD VDD CTLC VC1 CO VC2 1 kΩ 1 MΩ 0.1 μF 0.1 μF 1 kΩ *2 FET2 FET3 RVM 330 kΩ FET1*2 RDOP VM DP S-8239A Series DO VDD RDO VINI 1 kΩ 1 kΩ RVDD CVDD 1 μF VSS SEL2 VC5 CDT VC6 1 kΩ 0.1 μF 0.1 μF ZVINI RVINI 1 MΩ DO VC3 S-8225A Series*1 SEL1 VC4 CCT 100 Ω 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ VSS CHA− DIS− RSENSE DFET CFET Figure 16 2. Active "H" EB+ 100 Ω 1 MΩ FET4 CTLD VDD CTLC VC1 CO VC2 1 kΩ 1 MΩ 1 kΩ FET2 *2 FET3 RDOP 330 kΩ 1 MΩ FET1*2 RVM RDO VM DP S-8239A Series DO VDD FET5 VINI RVINI 1 MΩ VSS 1 kΩ CFET DFET CVDD RSENSE SEL2 VC5 CDT VC6 CCT VSS 1 kΩ 1 μF 0.1 μF 0.1 μF ZVINI Figure 17 20 1 kΩ RVDD CHA− DIS− DO VC3 S-8225A Series*1 SEL1 VC4 0.1 μF 0.1 μF 100 Ω 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ 0.1 μF 1 kΩ Rev.1.6_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Table 7 Constants for External Components Symbol RVDD RVINI RSENSE RVM RDO*3 RDOP CVDD Min. 300 1 0 1 − 330 0.022 Typ. 470 − − 5.1 5.1 510 0.1 Max. 1000 − − 51 − 2000 1 Unit Ω kΩ mΩ kΩ kΩ kΩ μF *1. Refer to the data sheet of the S-8225A Series for the recommended value for external components of the S-8225A Series. *2. Use the products with the same model number for FET1 and FET2. *3. Set up the optimal constant according to the FET in use. Caution 1. The constants may be changed without notice. 2. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. 3. The DP pin should be open. 21 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00  Precautions • The application conditions for the input voltage, output voltage, and load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 22 Rev.1.6_00 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series  Characteristics (Typical Data) 1. Current consumption 1. 2 IOPE vs. VDD 8 8 6 6 IOPE [μA] IOPE [μA] 1. 1 IOPE vs. Ta 4 2 0 −40 −25 0 +25 Ta [°C] +50 +75 +85 0 +25 Ta [°C] +50 +75 +85 4 2 0 0 2 4 VDD [V] 6 8 1. 3 IUVLO vs. Ta IUVLO [μA] 8 6 4 2 0 −40 −25 2. Overcurrent detection / release voltage, UVLO function and delay times 2. 2 VDIOV2 vs. Ta 2. 1 VDIOV1 vs. Ta VDIOV2 = 0.4 V 0.10 0.6 0.09 0.5 VDIOV2 [V] VDIOV1 [V] VDIOV1 = 0.08 V 0.08 0.07 0.06 −40 −25 0 25 Ta [°C] 50 0 25 Ta [°C] 50 +75 +85 0 +25 Ta [°C] +50 +75 +85 1.8 1.4 1.5 1.3 VRIOV [V] VDIOV3 [V] −40 −25 2. 4 VRIOV vs. Ta 1.5 1.2 1.1 1.0 0.9 0.3 0.2 +75 +85 2. 3 VDIOV3 vs. Ta 0.4 −40 −25 0 25 Ta [°C] 50 +75 +85 1.2 0.9 0.6 −40 −25 23 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00 2. 6 VDIOV2 vs. VDD 2. 5 VDIOV1 vs. VDD VDIOV2 = 0.4 V 0.10 0.6 0.09 0.5 VDIOV2 [V] VDIOV1 [V] VDIOV1 = 0.08 V 0.08 0.07 0.06 0.4 0.3 0.2 2 3 4 5 6 7 2 8 3 4 5 VDD [V] 6 7 8 4 5 VDD [V] 6 7 8 VDD [V] 2. 7 VDIOV3 vs. VDD 2. 8 VRIOV vs. VDD 1.5 1.8 1.4 1.5 VRIOV [V] VDIOV3 [V] 1.3 1.2 1.1 1.0 0.9 1.2 0.9 0.6 2 3 4 5 6 7 2 8 3 VDD [V] 2. 10 tDIOV2 vs. Ta 2. 9 tDIOV1 vs. Ta tDIOV2 = 1.12 ms 1.6 1.4 1.4 tDIOV2 [ms] tDIOV1 [s] tDIOV1 = 1150 ms 1.6 1.2 1.0 0.8 −40 −25 +25 Ta [°C] 0 +50 +75 +85 2. 11 tDIOV3 vs. Ta 1.2 1.0 0.8 −40 −25 0 +25 Ta [°C] +50 +75 +85 2. 12 tDIOV1 vs. VDD 400 1.6 340 1.4 280 220 160 24 tDIOV1 [s] tDIOV3 [μs] tDIOV1 = 1150 ms −40 −25 0 +25 Ta [°C] +50 +75 +85 1.2 1.0 0.8 2 3 4 5 VDD [V] 6 7 8 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00 2. 14 tDIOV3 vs. VDD 2. 13 tDIOV2 vs. VDD 1.6 400 1.4 340 tDIOV3 [μs] tDIOV2 [ms] tDIOV2 = 1.12 ms 1.2 1.0 0.8 280 220 160 2 3 4 5 6 7 2 8 3 4 VDD [V] 2. 15 VUVLO vs. Ta 7 8 6.0 5.5 tUVLO [s] 2.1 VUVLO [V] 6 2. 16 tUVLO vs. VDD 2.2 2.0 1.9 1.8 5 VDD [V] 5.0 4.5 4.0 3.5 −40 −25 0 25 Ta [°C] 50 +75 +85 3.0 1.5 1.6 1.7 1.8 VDD [V] 1.9 2.0 3. Output Resistance 3. 1 RDOL vs. Ta 10.0 RDOL [kΩ] 8.0 6.0 4.0 2.0 0.0 −40 −25 0 +25 Ta [°C] +50 +75 +85 25 OVERCURRENT MONITORING IC FOR MULTI-SERIAL-CELL PACK S-8239A Series Rev.1.6_00  Marking Specification 1. SOT-23-6 Top view 6 5 (1) to (3): (4): 4 (1) (2) (3) (4) 1 2 3 Product name vs. Product code Product Name S-8239AAA-M6T1U S-8239AAB-M6T1U S-8239AAC-M6T1U S-8239AAD-M6T1U S-8239AAE-M6T1U S-8239AAF-M6T1U S-8239AAG-M6T1U S-8239AAH-M6T1U S-8239AAI-M6T1U S-8239AAJ-M6T1U S-8239AAK-M6T1U S-8239AAL-M6T1U S-8239AAM-M6T1U S-8239AAN-M6T1U S-8239AAO-M6T1U S-8239AAP-M6T1U 26 Product Code (1) (2) (3) 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 S S S S S S S S S S S S S S S S A B C D E F G H I J K L M N O P Product code (Refer to Product name vs. Product code) Lot number 2.9±0.2 1.9±0.2 6 0.95 4 5 1 2 3 +0.1 0.15 -0.05 0.95 0.35±0.15 No. MP006-A-P-SD-2.1 TITLE SOT236-A-PKG Dimensions No. MP006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 6 Feed direction No. MP006-A-C-SD-3.1 TITLE SOT236-A-Carrier Tape No. MP006-A-C-SD-3.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP006-A-R-SD-2.1 TITLE SOT236-A-Reel No. MP006-A-R-SD-2.1 ANGLE QTY UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-8239AAI-M6T1U 价格&库存
很抱歉,暂时无法提供与“S-8239AAI-M6T1U”相匹配的价格&库存,您可以联系我们找货
