RSBD
RSBD
    BANNER(邦纳)
    PHOTO SEN DIFFUSED 1.5M
RSBD 数据手册
t ns uc tio od ca Pr ne ifi Li pec S MAXI-BEAM® Sensors Highly versatile modularized photoelectric sensing controls Printed in USA • Highly versatile, self-contained, modularized photoelectric sensors; especially suited to industrial environments • Wide selection of rotatable sensor heads, power blocks, and logic timing modules to suit any application • Power blocks for AC or DC operation and for switching of AC or DC loads • Sensor heads include patented AID™ indicator device, which lights a top-mounted LED when the sensor "sees" its own modulated light source and pulses the LED at a rate proportional to the received light signal strength • Status indicator LEDs on power block continuously indicate the state of the output circuit • Models are available in all sensing modes P/N 32883F4A MAXI-BEAM® MAXI-BEAM™ Sensor Heads Modular Sensors Banner MAXI-BEAM sensors are highly versatile, self-contained, modularized photoelectric sensing controls that are ideally suited to industrial environments. The basic MAXI-BEAM is an ON/OFF switch consisting of three modules: a sensor head, a power block, and a wiring base. The sensor head contains the complete modulated photoelectric amplifier as well as the emitter and receiver optoelements. A unique, patented, "programming ring" (supplied with each sensor head) enables you to program your choice of "light" or "dark" operate mode, sensing range, and response time. MAXI-BEAM sensor heads have an easily-accessible multi-turn SENSITIVITY control for precise adjustment of system gain. Interchangeable sensor heads are rotatable in 90degree increments, and are available in opposed, retroreflective, diffuse, convergent, and fiber optic models. Each sensor head also includes Banner's exclusive, patented Alignment Indicating Device (AID™, U.S. patent #4356393), which lights a top-mounted LED when the sensor "sees" its own modulated light source and pulses at a rate proportional to the received light signal strength. The power block provides the interface between the sensor head and the external circuit. It contains the power supply for the MAXI-BEAM plus a switching device to interface with the circuit to be controlled. DC power block versions operate on 10 to 30V dc and have solid-state sourcing and sinking outputs rated at 250mA each (maximum). AC models are available for 120V or 240V ac operation, and are offered in both 2-wire and 3- or 4-wire formats. The plug-in design of the wiring base enables easy exchange of the entire sensing electronics without disturbing the field wiring. Status LEDs on the power block module continuously indicate the state of the output circuit. Optional logic modules are available which easily convert the basic ON/OFF MAXI-BEAM into either a one-shot or delay logic function control. The logic module comes with a programming ring which is used to select one of several timing ranges for each logic function. Timing adjustments are made via two 15-turn clutched potentiometers, accessible from the outside. Once programmed, the logic module may be rotated in 90-degree increments to allow time adjustment access from the most convenient location. All MAXI-BEAM components are encapsulated within rugged, corrosion-resistant VALOX® housings which meet or exceed NEMA 1, 3, 4, 12, and 13 standards. Modules simply snap and bolt together, with no interwiring necessary. Module interfaces are o-ring and quad-ring sealed for the ultimate in dirt, dust, and moisture resistance. All MAXI-BEAM components (except for power block model RPBR) are totally solid-state for unlimited life. MAXI-BEAM assemblies have the same mounting configuration as Banner MULTI-BEAM sensors, and are physically interchangeable with heavy-duty industrial limit switches. Most MAXI-BEAM sensors are CSA certified and UL listed. See the power block information on pages 8 to 13. WARNING ! MAXI-BEAM photoelectric presence sensors do NOT include the self-checking redundant circuitry necessary to allow their use in personnel safety applications. A sensor failure or malfunction can result in either an energized or a de-energized sensor output condition. Never use these products as sensing devices for personnel protection. Their use as a safety device may create an unsafe condition which could lead to serious injury or death. Only MACHINE-GUARD and PERIMETER-GUARD Systems, and other systems so designated, are designed to meet OSHA and ANSI machine safety standards for point-of-operation guarding devices. No other Banner sensors or controls are designed to meet these standards, and they must NOT be used as sensing devices for personnel protection. Composite Functional Schematic, MAXI-BEAM Sensors RWB4 2 Selection of MAXI-BEAM Components The modular design of the MAXI-BEAM allows you to create a sensor which is tailored to your exact requirements. To order a MAXI-BEAM, follow these steps: Exploded view, MAXI-BEAM Sensor Sensitivity Control 1) SELECT A SENSOR HEAD (see pages 3-7). Sensor heads are available for opposed, retroreflective, diffuse, convergent, and fiberoptic sensing modes. Rotatable Sensor Head 2) SELECT A POWER BLOCK (see pages 8-13). Power blocks are available for low voltage dc with either a solid-state or an electromechanical relay output. AC power blocks are available in either 2-wire design with solid-state output or 4-wire design with a choice of solidstate or electromechanical relay output. Programming Ring Optional Logic Module 3) SELECT A WIRING BASE (see page 8, top). Model RWB4 wiring base is used for all MAXI-BEAM assemblies (purchase separately). 4) SELECT A LOGIC MODULE, if needed (see pages 14-15). MAXI-BEAMs operate in the ON/OFF mode (i.e. the output follows the action within the sensing beam) when no logic module is used. The addition of a programmable logic module can add process timing control as part of the MAXI-BEAM sensor assembly. LED/AID™ Indicator Programming Ring for Logic Power Block RWB4 Wiring Base 5) SELECT ACCESSORIES, as needed (see pages 15-16). MAXI-BEAM Dimensions Output OFF LED Output ON LED Quick Disconnect (optional) Conduit Entrance Specifications: MAXI-BEAM Sensor Heads SUPPLY VOLTAGE: Input power is supplied by the power block (see pages 8 to 13). RESPONSE TIME: Programmable for 10, 1, and 0.3 milliseconds (most models). See specifications on particular model. Independent of signal strength. NOTE: see power block specifications for information on additional output switching response delays. REPEATABILITY OF RESPONSE: See individual sensor specifications. NOTE: Response time and repeatability specifications are independent of signal strength. SENSITIVITY ADJUSTMENT: Easily accessible; located on top of sensor head beneath o-ring gasketed cover. 15-turn clutched control (rotate clockwise to increase gain). Functional Schematic, MAXI-BEAM Sensor Head ALIGNMENT INDICATOR: Red LED on top of sensor head. Banner's exclusive "AID" circuit lights the LED when the sensor sees its own modulated light source and pulses the LED at a rate proportional to the received light signal strength. CONSTRUCTION: Reinforced molded VALOX® housing, molded acrylic lenses, oring and quad-ring gasketed components. Electronic components are fully epoxy-encapsulated. NEMA 1, 3, 4, 12, and 13. OPERATING TEMPERATURE RANGE: -40 to +70 degrees C (-40 to +158 degrees F). FALSE-PULSE SUPPRESSION ON POWER-UP: 100 millisecond delay on power-up, all models. 3 MAXI-BEAM Sensor Heads Sensing Mode Models RSBE & RSBR OPPOSED Mode Beam Pattern Excess Gain 1000 Range: 300 feet (90 m) in RSBE/RSBR RSBE/RSBR 15 "HP" (high power) and 2W E 10 (2 wire) modes X 100 HP, 2W I HS C N 5 Beam: infrared, 880nm; E SP HP, 2W HS C 0 S H visible red tracer beam S SP E S 5 Effective Beam: 0.5" dia. G 10 10 A Response: II 15 N HP, 2W mode: 10ms on/ 80 160 240 320 400 0 5 off 1 OPPOSED DISTANCE --FE 1 FT 10 FT 100 FT 1000 FT HS mode: 1ms on/0.5 off DISTANCE SP mode: 0.3ms on/off Repeatability: HP, 2W= MAXI-BEAM emitters have a visible red "tracer beam". This beam is non-active, 1.4ms; HS = 0.1ms; and is used as a means of visual alignment during installation. A retroreflector SP = 0.04ms temporarily attached to the receiver lens provides an effective target for the tracer beam during alignment. The narrow beam of the RSBESR/RSBRSR pair is ideal RSBESR & for sensing small parts (effective beam diameter is 0.14 inch). RSBRSR Range: 15 feet (4,5m) in "HP" (high power) and 2W (2 wire) modes Beam: infrared, 880nm Response: HP, 2W modes: 10ms on/5 off HS mode: 1ms on/0.5 off SP mode: 0.3ms on/off Repeatability: HP, 2W= 1.4ms; HS = 0.1ms; SP = 0.04ms RSBEF & RSBRF OPPOSED FIBER OPTIC Mode (glass fibers) Range: see excess gain curves Beam: infrared, 880nm. Response: HP, 2W modes: 10ms HS mode: 1ms SP mode: 0.3ms on/off Repeatability: HP, 2W= 3.3ms; HS = 0.3ms; SP = 0.1ms RSBLV Range: 6 inches to 30 feet (9 m) in all program modes Beam: visible red, 650nm Response: HP, 2W, SP modes: 4ms HS mode: 1ms Repeatability: HP, 2W, SP = 1.3ms; HS = 0.3ms 1000 RSBESR & RSBRSR E X C 100 E S S 16 I N C H E S HP, 2W HS G A 10 II N RSBESR & RSBRSR 24 SP 8 HS SP 0 HP, 2W 8 16 24 1 .1 FT 0 1 FT 10 FT 100 FT 3 6 9 12 OPPOSED DISTANCE--FEET 15 DISTANCE 1000 RSBEF & RSBRF SP E X C 100 E S S 6 HS IT23S fibers, no lenses HP, 2W G 10 A II N RSBEF & RSBRF 4 I N 2 C 0 H E S 2 4 HP, 2W IT23S fibers, no lenses 6 0 1 .1 IN 1 IN 10 IN DISTANCE HS SP 100 IN 8 16 24 32 OPPOSED DISTANCE --INCHES 40 This sensor pair is designed for opposed mode operation using Banner glass fiber optics. Maximum range (HP mode) using L9 lenses is 12 feet. Maximum range using L16F lenses is 50 feet. 1000 E X C 100 E S S RSBLV 6 RSBLV 4 I N 2 C 0 H E S 2 4 BRT-3 3" reflector BRT-1 1" reflector G A 10 II N 6 BRT-T tape 1 .1 FT with BRT-3 reflector 0 1 FT 10 FT DISTANCE 100 FT 6 12 18 24 DISTANCE TO REFLECTOR--FEET 32 RETROREFLECTIVE Mode RSBLVAG (anti-glare filter) Range: 1 to 15 feet (4,5 m) in all program modes Beam: visible red, 650nm; with polarizing filter Response: HP, 2W, SP modes: 4ms HS mode: 1ms Repeatability: HP, 2W, SP = 1.3ms; HS = 0.3ms 4 1000 RSBLVAG E X C 100 E S S 2 I N 1 C 0 H E S 1 2 G 10 A II N 1 .1 FT RSBLVAG 3 with BRT-3 reflector 3 0 1 FT 10 FT DISTANCE 100 FT 3 6 9 12 DISTANCE TO REFLECTOR--FEET 15 MAXI-BEAM Sensor Heads Sensing Mode Models RSBD Range: 5 feet (1,5 m) in HP and 2W modes Beam: infrared, 880nm Response: HP, 2W modes: 10ms HS mode: 1ms SP mode: 0.3ms Repeatability: HP, 2W= 3.3ms; HS = 0.3ms; SP = 0.1ms DIFFUSE Mode RSBDSR (short range) Range: 30 inches (76cm) in HP and 2W modes Beam: infrared, 880nm Response: HP, 2W modes: 10ms HS mode: 1ms SP mode: 0.3ms Repeatability: HP, 2W= 3.3ms; HS =0.3ms; SP =0.1ms 1000 CONVERGENT Mode RSBCV Focus at 1.5 in. (38mm); performance equal in all program modes. Beam: visible red, 650nm. Response: HP, 2W, SP modes: 4ms HS mode: 1ms Repeatability: HP, 2W, SP= 1.3ms; HS = 0.3ms RSBD E X C 100 E S S 3 RANGE BASED ON OBJECT OF 90% REFLECTANCE G A 10 II N HP, 2W RSBD 2 I N 1 C H 0 E S 1 HS HP, 2W SP 2 HS 3 SP 1 .1 IN 1 IN 10 IN DISTANCE 12 24 36 48 60 0 DISTANCE TO 90% WHITE TEST CARD--INCHE 100 IN 1000 RSBDSR E X C 100 E S S G 10 A II N 1.5 RSBDSR 1.0 range based on 90% reflectance white test card SP I N 0.5 C H 0 E S 0.5 HP, 2W HS HP, 2W 1.0 HS SP 1 .1 IN RSBC Focus at 1.5 in. (38mm) Beam: infrared, 940nm Response: HP, 2W modes: 10ms HS mode: 1ms SP mode: 0.3ms Repeatability: HP, 2W= 3.3ms; HS = 0.3ms; SP= 0.1ms Beam Pattern Excess Gain 1.5 1 IN 10 IN DISTANCE 6 12 18 24 30 0 DISTANCE TO 90% WHITE TEST CARD--INCHE 100 IN 1000 RSBC G A II N RSBC .2 Range based on 90% reflectance white test card E X C 100 E S S .1 I N C 0 H E S .1 HP, 2W modes 10 HS, SP HP, 2W modes .2 1 .1 IN HS, SP modes 1 IN 0 10 IN 100 IN 1.0 2.0 3.0 4.0 5.0 DISTANCE TO 90% WHITE TEST CARD--INCHES DISTANCE Powerful infrared beam reliably senses objects of low reflectivity. Ideal for counting the flow of radiused products at a fixed distance from the sensor. 1000 RSBCV E X C 100 E S S G A 10 II N 1 .1 IN .030 RSBCV .020 I N .010 C 0 H E S .010 range based on 90% reflectance white test card all modes .020 .030 .50 0 1 IN 10 IN DISTANCE 100 IN 1.0 1.5 2.0 2.5 DISTANCE TO 90% WHITE TEST CARD--INCHES Powerful visible red beam detects small objects only a fraction of an inch away from backgrounds. Useful in many high-contrast color registration applications. FIXED-FIELD Mode RSBFF models Far limit cutoff at: 50mm (model RSBFF50) or 100mm (model RSBFF100) Beam: infrared, 880nm. Response: HP mode: 10ms Repeatability: HP mode: 3.3ms Fixed-field sensor heads have an emitter element and two differently-aimed receiver elements. This creates a highgain sensing field able to detect objects of low reflectivity, and a sharp far-limit sensing cutoff of 50mm (2 inches) or 100mm (4 inches) which ignores backgrounds beyond cutoff. These sensors are ideal for detecting a part or surface that is only a fraction of an inch in front of another surface. RSBFFs may not be used with 2-wire power blocks. 1000 MAXI-BEAM Fixed-field Sensor Heads E X 100 C E S S (Range based on 90% reflectance white test card) 50 mm G 10 A I 5 N 1 0.1 mm 100 mm 1 mm 10 mm DISTANCE 100 mm 5 MAXI-BEAM Sensor Heads Sensing Mode Models RSBF Range: see excess gain curves Beam: infrared, 880nm Response: HP, 2W modes: 10ms HS mode: 1ms SP mode: 0.3ms FIBER OPTIC Mode (glass fibers) OPPOSED MODE RETRO MODE OBJECT RETROREFLECTOR Repeatability: HP, 2W= 3.3ms; HS = 0.3ms; SP = 0.1ms NOTE: if the retroreflective sensing mode is used in conjunction with the HP or 2W program mode, the GAIN control must be reduced from the factory setting in order to avoid optical feedback from the lens assembly. Excess Gain 1000 RSBFP Range: see excess gain curves Beam: visible red, 650nm. Response: HS mode only, 1ms on/off Repeatability: HS = 0.3ms FIBER OPTIC Mode (plastic fibers) OPPOSED MODE OBJECT DIFFUSE MODE OBJECT Opposed mode IT23S fibers The model RSBFP will function only when programmed for the "HS" response mode. The model RSBFP will not operate with 2-wire power blocks (models R2PBA and R2PBB). For information on the complete line of Banner plastic fiber optics, see Banner product catalog. HP, 2W HS SP 6 0 1 .1 IN 1 IN 10 IN DISTANCE 100 IN 8 16 24 32 OPPOSED DISTANCE --INCHE 40 1000 Retroreflective mode, with BRT-3 reflector and BT13S fibers RSBF E X C 100 E S S RSBF 6 4 HS G A 10 II N HS I N 2 C 0 H E S 2 4 with L16F lenses with L9 lenses HS with L16F lenses HS with L9 lenses 6 Retroreflective mode with BT13S & BRT-3 0 1 .1 FT 1 FT 10 FT 100 FT 4 8 12 16 20 DISTANCE TO REFLECTOR --FEE DISTANCE 1000 .2 I N .1 C 0 H E S .1 .2 BT23S fibers HP, 2W HS G A 10 II N RSBF .3 Diffuse mode SP HP, 2W 1 IN 10 IN DISTANCE 100 IN HS SP Diffuse mode with BT23S fibers .3 1 .1 IN 1 2 3 4 5 0 DISTANCE TO 90% WHITE TEST CARD--INCHES 1000 RSBFP E X C 100 E S S PIT46U, no lenses G A 10 II N 1.2 I .6 N C H 0 E S .6 1.2 PIT26U 0 1 IN 10 IN DISTANCE 100 IN PIT46U Opposed mode 1.8 PIT26U, no lens 1 .1 IN RSBFP 1.8 Opposed mode, plastic fibers PIT46U with L2 lenses 4 1 2 3 OPPOSED DISTANCE--INCHES 5 Model RSBFP is a visible-light sensor head designed for use with plastic fiber optics. It is compatible with all standard Banner plastic fiber optic assemblies (see Banner product catalog). In order to function properly, the RSBFP must be programmed for the "HS" response mode. The RSBFP is not for use with glass fiber optics (instead use model RSBF or RSBFV). 1000 RSBFP E X C 100 E S S G A II N Diffuse mode, plastic fibers (Range based on 90% reflectance white test card) with PBT46U fiber 10 with PBT26U fiber 1 .01 IN .1 IN DISTANCE 6 I N 2 C 0 H E S 2 4 RSBF For information on the complete line of Banner glass fiber optics, see Banner product catalog. RSBF 4 HP, 2W G 10 A II N Opposed mode with IT23S fibers 6 HS E X C 100 E S S OBJECT RSBF SP E X C 100 E S S OBJECT DIFFUSE MODE Beam Pattern .15 RSBFP .10 I .05 N C 0 H E .05 S .10 PBT26U PBT46U Diffuse mode .15 0 1 IN 10 IN .3 .6 1.2 1.5 .9 DISTANCE TO 90% WHITE TEST CARD--INCHES MAXI-BEAM Sensor Heads Sensing Mode RSBFV Range: see excess gain curves Beam: visible red, 650nm. Response: HS mode only, 1ms on/off Repeatability: HS = 0.3ms FIBER OPTIC Mode (glass fibers) OPPOSED MODE OBJECT RETROREFLECTOR RETRO MODE OBJECT DIFFUSE MODE OBJECT Excess Gain Models The model RSBFV will function only when programmed for the "HS" response mode. The model RSBFV will not operate with 2-wire power blocks (models R2PBA and R2PBB). Model RSBFV is a visible-light sensor head designed for use with glass fiber optics. It is compatible with all standard Banner glass fiber optic assemblies (see Banner product catalog). In order to function properly, the RSBFV must be programmed for the "HS" response mode. The RSBFV is not for use with plastic fiber optics (instead use RSBFP). Beam Pattern 1000 RSBFV 3 E X C 100 E S S I 1 N C 0 H E S 1 2 IT23S fibers G A 10 II IT13S fibers N RSBFV 2 Opposed mode Opposed mode 3 0 1 .1 IN IT23S IT13S 1 IN 10 IN 2 4 6 8 OPPOSED DISTANCE--INCHES 100 IN 10 DISTANCE 1000 RSBFV E X C 100 E S S 6 Retroreflective mode w/BRT-3 reflector with L16F lens and BT13S fibers G 10 A II N RSBFV 4 I 2 N C 0 H E 2 S 4 with L9 lens and BT13S fibers w/L9 lens w/L16F lens BT13S fiber, retroreflective mode, with BRT-3 reflector 6 0 1 .1 IN 1 IN 10 IN 4 8 12 16 20 DISTANCE TO REFLECTOR--INCHES 100 IN DISTANCE 1000 E X C 100 E S S G A II N .1 RSBFV .075 Diffuse mode .050 I N .025 C 0 H E S .025 .050 Range based on 90% reflectance white test card. BT23S fibers 10 BT13S fibers .1 IN 1 IN BT13S BT23S Diffuse mode .075 .1 1 .01 IN RSBFV 10 IN 0 .2 .4 .8 1.0 .6 DISTANCE TO 90% WHITE TEST CARD--INCHES DISTANCE Programming the MAXI-BEAM Sensor Head MAXI-BEAM sensor heads may be programmed for sensor response time (and range) and for LIGHT/DARK operate. Each sensor head is supplied with a programming ring which attaches below the the sensor head by a system of pegs. There are four programming notches around the perimeter of the ring. To program the sensor head, simply find the notch which will line up with the desired program combination (see diagram, right). NOTE: the programming ring may have to be turned upside-down in order to line up the notch with the program. If LIGHT OPERATE is selected, the MAXI-BEAM output will energize on a dark-to-light transition. If DARK OPERATE is selected, the MAXI BEAM output will energize on a light-to-dark transition. In the illustration, the MAXI-BEAM is set for high speed (HS) operation in the LIGHT OPERATE output state. See the information about each individual sensor head for the response time and range associated with each setting (HP, 2W, HS, SP). NOTE: when programming the RSBE, RSBSER, or RSBEF emitter, select the mode which is programmed for the receiver. EXCEPTION: if the receiver is programmed for the 2-wire (2W) mode, select high power (HP) on the emitter. MAXI-BEAM HS: HI SPEED HP: HI POWER DARK OPERATE 2W: 2 WIRE SP: SPECIAL LIGHT OPERATE H S 2 H H S 2 H S P WP S P W P Programming ring Notch 7 MAXI-BEAM Power Blocks and Wiring Base MAXI-BEAM power blocks provide regulated low voltage dc power to the sensor head and logic module (if one is used), and all power blocks (except emitter-only types) contain an output switch for interfacing to loads or to control circuitry. Power blocks plug into the model RWB4 wiring base which has heavy-duty screw terminals that accept up to #12 gauge wire (no lugs are necessary). The RWB4 wiring base is necessary for all MAXI-BEAM sensor assemblies (except sensors using the RPBTLM power block), and must be purchased separately. RWB4 Wiring Base Power Block (order separately) All power blocks, except the emitter-only types, include status LEDs which continuously indicate the state of the output circuit and input power. MAXI-BEAM power blocks are epoxy-encapsulated and rated for -40 to +70 degrees C (except models RPBR and RPBR2). All MAXI-BEAMs have circuitry to prevent false closure of the output on power-up. Connections DC Models RPBT RPBT-1 (for emitters) Functional Schematic RPBT LOAD Source INPUT: 10 to 30V dc, 20mA, exclusive of load current; 10% maximum ripple. 4 LOAD Sink 3 2 10-30V dc 1 OUTPUT: one open-collector NPN (current sinking) and one open-collector PNP (current sourcing) transistor. 250mA continuous, short-circuit and reverse polarity protected (both outputs). ON-STATE VOLTAGE DROP: PNP output: less than 1 volt at 10mA and less than 2 volts at 250mA. NPN output: less than 200 millivolts at 10mA and less than 1 volt at 250mA. OFF-STATE LEAKAGE CURRENT: less than 10 microamps. Power block RPBT is the one most often used in low voltage dc applications. There are two solid state output switches (transistors), each rated at 1/4 amp. The NPN output at terminal #3 of the wiring base sinks current to the negative side of the power supply. The PNP output at terminal #4 sources current to the load from the positive side of the power supply. Both outputs may be used simultaneously. Response time of a MAXI-BEAM which uses model RPBT is the response time which is programmed at the sensor head (plus logic delays, if any). Model RPBT-1 is the dc power block to use with model RSBE, RSBESR, and RSBEF emitter sensor heads. The RPBT-1 has no switching elements. Hookup Diagrams for RPBT and RPBT-1 Power Blocks Hookup to dc Relay or Solenoid (using sinking output) When using the power block with current sinking (NPN) output, simple loads connect between terminal #3 and the positive supply (terminal #1). Hookup to dc Relay or Solenoid (using sourcing output) 10 - 30V dc When using the power block with current sourcing (PNP) output, simple loads connect between terminal #4 and dc common (terminal #2). RPBT LOAD 4 3 2 1 Hookup to Logic Gate (using sinking output) A logic zero (0 volts dc) is applied to the GATE input when the MAXI-BEAM sinking output is energized. When de-energized, a logic one is applied. The logic supply must be common to the MAXI-BEAM +5V to 30V dc supply negative. Logic Supply 10 - 30V dc RPBT RPBT 4 3 2 1 * LOAD 4 3 2 1 10 - 30V dc (-) dc * Use pullup resistor tologic supply Hookup to a Programmable Controller requiring a current source Hookup shown Hookup to a Programmable Controller requiring a current sink Use MAXI-BEAM NPN output (terminal #3) to interface to PLCs and other logic devices requiring a current sink at the inputs. Connect terminal #3 of RPBT the power block to any input of the PLC. Also connect the negative of the MAXI-BEAM +10 - 30V dc power supply (terminal #2) to the negative of the PLC power supply. The hookup shown is typical for all inputs. 8 Hookup shown is typical for all inputs 1 P 2 r 3 4 3 2 1 I 4 N 5 P 6 U 7 T 8 dc+ dc com S o g. C t r l. Use MAXI-BEAM PNP output (terminal #4) to interface to PLCs and other logic devices requiring a current source at the inputs. Connect terminal #4 of RPBT the power block to any input of the PLC. Connect the negative of the MAXI-BEAM power +10 - 30V dc supply (terminal #2) to the negative of the PLC power supply. The hookup shown is typical for all inputs. is typical for all inputs 1 P 2 4 3 2 1 3 I 4 N 5 P 6 U 7 T 8 dc+ S dc com r o g. C t r l. MAXI-BEAM Power Blocks and Wiring Base Hookup Diagrams for RPBT and RPBT-1 Power Blocks (continued) Parallel Hookup of RPBT Power Blocks to a Common Load Hookup of a DC Emitter 10 - 30V dc MAXI-BEAM emitter only sensor heads use dc power block model RPBT-1, which connects directly across the dc supply as shown. Any number of MAXI-BEAMs may be connected in parallel to a load to create "LIGHT-OR" (light operate mode) or "DARK-OR" (dark operate mode) multiple sensor logic. The diagram at the right shows the current sinking outputs of two MAXI-BEAMs connected in parallel to control a load which requires a current sink (power block terminal #3). For loads requiring a current source, connect the wires from the load instead between terminals #4 and #2 (common). NOTE: series connection of dc MAXI-BEAM sensors may be accomplished using power block model RPBR (see below). RPBT 4 3 2 1 RPBT-1 4 3 2 1 10 - 30V dc RPBT 4 3 2 1 LOAD Hookup to MAXI-AMP Logic Module 5 6 7 8 CL5RB The current sinking output of an RPBT power block may be connected directly to the primary input (terminal #7) or the other inputs of MICRO-AMP logic modules. The following logic modules may be used: RPBT 9 10 11 1 2 3 4 The current sinking output of MAXI-BEAM power block RPBT may be connected directly to the input of CL Series MAXI-AMP modules. A MAXI-AMP which is powered by ac voltage offers a dc supply with enough capacity to power one MAXI-BEAM sensor, as is shown in this hookup diagram. When an emitter/receiver pair is used, the emitter should be powered from a separate power source CL3RA CL3RB (e.g.- use power block CL5RA RPBA-1, etc.). Hookup to MICRO-AMP Logic (MPS-15 Chassis) 4 3 2 1 AC/DC Model MA4-2 MA5 MA4G MA4L One shot On/off delay 4-input "AND" Latch Connections NO 7 Micro- 6 8 Amp 5 1 Logic 4 2 3 NC MODEL MPS-15 RPBT 4 3 2 1 Relay 120 Vac N N O C C Functional Schematic RPBR Dry Contact INPUT: 12 to 30V dc, 40mA, exclusive of load current (at 30V dc); or 12 to 250V ac, 50/60Hz. OUTPUT: SPST electromechanical relay contact. Contact rating: 250V ac max., 30V dc max., 5 amps max. (resistive load); install MOV across contact if switching inductive load. Contact response: 20ms open and close (NOTE: add to sensor head response). Mechanical life: 10,000,000 operations. OPERATING TEMPERATURE: -40 to +50 degrees C (-40 to +122 degrees F). RPBR 250V ac max. 30V dc max. 5 amps max. LOAD 4 3 12 to 250V ac 2 12 to 30V dc 1 Model RPBR operates the MAXI-BEAM with either ac or dc. It offers an SPST "hard" relay contact between wiring base terminals #3 & #4, which allows the MAXI-BEAM sensor to directly interface with loads which draw high current. It also allows series connection ("AND" logic) with multiple dc sensors. Application caution: power block models RPBR and RPBR2 Power block modules RPBR and RPBR2 use "partial phase firing" power conversion to enable their wide range of ac input voltage (12 to 250V ac). AC power is applied to the sensor for only a small portion of each ac halfcycle. The current demand during this period may be as high as 1 to 2 amps per sensor. The collective current demand of several of these sensors on a common ac line is significant. If several sensors are wired directly to the ac mains, it is unlikely that any adverse effects will be noticed. On the other hand, problems may be noticed if several sensors are connected to a common circuit that is isolated from the ac mains by a transformer. The collective peak current demand may rob other components on the same circuit of enough power to function properly. In the worst case, a transformer with inadequate reserve current capacity may overheat. Barring a transformer failure, the sensors themselves will operate normally. As a general rule, if more than three or four MAXI-BEAM sensors using RPBR or RPBR2 power blocks must be connected to the same transformer-isolated ac circuit, consider the substitution of power block model RPBAR2 (for 105-130V ac) or model RPBBR2 (for 210-250V ac), which use conventional ac-to-dc power conversion circuitry. These power blocks connect exactly like model RPBR2, but do not exhibit the peak power demand of a phase-fired design. Output relay specifications are identical to model RPBR2. Contact your Banner representatiove or distributor for pricing and availability. NOTE: Peak power demand is not an issue when the RPBR or RPBR2 are powered from direct current (12 to 30V dc). 9 MAXI-BEAM Power Blocks and Wiring Base AC Models Functional Schematic Connections RPBR2 INPUT: 12 to 30V dc, 40mA, exclusive of load current (at 30V dc); or 12 to 250V ac, 50/60Hz. OUTPUT: SPDT electromechanical relay contacts. Contact rating: 250V ac max., 30V dc max., 5 amps max. (resistive load); install MOV across contact if switching inductive load. Contact response: 20ms open and close (NOTE: add to sensor head response). Mechanical life: 10,000,000 operations. OPERATING TEMPERATURE: -40 to +50 degrees C (-40 to +122 degrees F). RPBR2 is an SPDT output version of model RPBR, with both contacts common to terminal #1. Terminal #3 is normally open; terminal #4 is normally closed. See application caution, page 9. 3- and 4-wire operation RPBA RPBA RPBA: 105 to 130V ac RPBB: 210 to 250V ac INPUT: 105 to 130V ac, 50/60Hz; 2 watts exclusive of load. 4 LOAD 3 Jumper Supply Voltage 2 1 RPBB INPUT: 210 to 250V ac, 50/60Hz; 2 watts exclusive of load. OUTPUT: SPST solid-state switch for ac, 3/4 amp maximum (derated to 1/2 amp at 70 degrees C). Maximum inrush 10 amps for one second or 30 amps for one ac cycle (non-repeating). On-state voltage drop of less than 2.5V ac at full load. Off-state leakage current less than 100 microamps. NOTE: ac loads require up to 8.3 milliseconds to turn OFF in addition to the response time of the sensor head and delay logic (if any). Power block models RPBA and RPBB are the most commonly used for ac MAXI-BEAM operation. As the typical hookup shows, they are intended to switch the same ac voltage as is used to power the MAXI-BEAM. However, both can switch any ac voltage that is lower than the supply voltage, as long as both ac circuits share a common neutral. Observe local codes whenever mixing ac voltages in a common wiring chamber. These blocks are designed to handle the inrush current of ac inductive loads like motor starters and solenoids. There is no mimimum load requirement, and they will interface directly to inputs of all ac programmable logic controllers (PLCs). Special order models RPBAT (120V ac) and RPBBT (240V ac) are available for interfacing to dc loads of up to 100 milliamps. RPBA-1 For RSBE, RSBESR, and RSBEF emitters INPUT: 105 to 130V ac, 50/60Hz; 2 watts. RPBA-1: 105 to 130V ac RPBB-1: 210 to 250V ac 4 3 RPBB-1 2 Supply Voltage 1 For RSBE, RSBESR, and RSBEF emitters INPUT: 210 to 250V ac, 50/60Hz; 2 watts. 2-wire operation R2PBA INPUT: 105 to 130V ac, 50/60Hz; 2 watts exclusive of load Supply Voltage LOAD 4 3 2 R2PBA: 105 to 130V ac R2PBB: 210 to 250V ac 1 R2PBB INPUT: 210 to 250V ac, 50/60Hz; 2 watts exclusive of load. OUTPUT: SPST solid-state switch for ac, 3/4 amp maximum (derated to 1/2 amp at 70 degrees C). Maximum inrush 10 amps for one second (non-repeating). On-state voltage drop: 5.2V rms at a 1/2 amp load; 14V rms at a load of 10 milliamps. Off-state leakage current less than 1.7 milliamp (resistive or inductive load). 10 Power block models R2PBA and R2PBB both offer the simplicity of wiring which is associated with 2-wire sensor design. They wire directly in series with an ac load, exactly like a limit switch. Use of a 2-wire power block requires programming of the sensor head to the "2W" (2-wire) operating mode. As a result, MAXI-BEAM sensing response time is fixed at 10 milliseconds for 2-wire operation. There are some hookup considerations which are unique to 2-wire interfaces. See hookup information on page 12 for details. MAXI-BEAM Power Blocks and Wiring Base Hookup Diagrams for RPBA, RPBA-1, RPBB, & RPBB-1 Power Blocks Hookup to a Simple Load L1 L Hookup of an ac Emitter 2 V ac (See Specifications) AC voltage is connected to terminals #1 and #2 to provide power to the MAXI-BEAM. The solid-state output switch behaves as if there were a contact between terminals #3 and #4. L1 is most conveniently applied to terminal #3 by jumpering terminals #1 and #3 inside the wiring base. Alternatively, the load could be installed between terminal #3 and L1, with L2 connected to terminal #4 by jumpering from #2 to #4. RPBA RPBB 4 3 2 1 MAXI-BEAM emitter-only sebnsor heads use ac power block model RPBA-1 (120V ac) or RPBB-1 (220/240V ac) which connect directly across the line, as shown. L1 L 2 V ac (See Specifications) RPBA-1 RPBB-1 LOAD 4 3 2 1 CAUTION: the output switch will be destroyed if the load is shorted. Hookup in Parallel or Series with Contacts or Switches Any number of "hard" contacts may be wired in series or in parallel to MAXI-BEAMs which use power block model RPBA or RPBB. This circuit illustrates a start-stop function in which CR can be energized only when the MAXI-BEAM output is energized. Once energized, CR is latched ON by its normally open contact. CR is reset by depressing the STOP switch L1 Hookup to Programmable Logic Controller (PLC) L V ac (See Specifications) 2 Interfacing to a PLC I/O is direct with MAXI-BEAMs which use RPBA or RPBB. The off-state leakage current is only 100 microamps (0.1 milliamp) maximum. AC "hot" L1 CR AC neutral L 2 1 V ac (See Specifications) Hookup typical for all 8 inputs RPBA RPBB 4 3 2 1 CR STOP o 4 P g. 5 Any number of MAXI-BEAMs using RPBA or RPBB power blocks may be wired together in parallel to a load. Parallel sensor connection is usually used to yield "OR" logic (i.e.-if an event occurs at any sensor, the load is energized). L1 L2 V ac (See Specifications) 4 3 2 1 LOAD The total off-state leakage current through the load is the sum of the leakage currents of the individual power blocks. However, the maximum leakage current of MAXIBEAM RPBA or RPBB power blocks is only 100 microamps. As a result, the installation of an artificial load resistor in parallel with the load is necessary only for very large numbers of sensors wired in parallel to a light (i.e.-high impedance) load. U T S C t r l. neutral MAXI-BEAMs which use RPBA or RPBB power blocks may be wired in series for the "AND" logic function. The total voltage drop across the series will be the sum of the individual voltage drops across each power block (approximately 3 volts per block). With most loads, 10 or more sensors may be wired together in series. RPBA RPBB N 8 4 3 2 1 Hookup in Parallel with other MAXI-BEAMs 4 3 2 1 r 3 7 RPBA RPBB Hookup in Series with other MAXI-BEAMs RPBA RPBB I 6 START P 2 L1 L 2 V ac (See Specifications) RPBA RPBB 4 3 2 1 RPBA RPBB 4 3 2 1 LOAD 11 MAXI-BEAM Power Blocks and Wiring Base Hookup Diagrams for R2PBA and R2PBB Power Blocks Basic 2-wire Hookup 2-wire MAXI-BEAMs in Parallel L1 L Multiple 2-wire MAXI-BEAMs may be wired together in parallel to a load for "OR" or "NAND" logic functions. When sensors are wired in parallel, the off-state leakage current through the load is equal to the sum of the leakage currents of the individual sensors. Consequently, loads with high resistance like small relays and electronic circuits may require artificial load resistors. 2 V ac (See Specifications) R2PBA R2PBB L1 R2PBA R2PBB MAXI-BEAM sensors have a 100 millisecond power-up delay for protection against false outputs. When 2-wire MAXI-BEAMs are wired together in parallel, any power block which has an energized output will rob all other 2wire power blocks of the voltage needed to operate the sensor. When the energized output drops, there will be a 0.1 second delay before any other MAXI-BEAM can energize. As a result, the load may momentarily drop out. 4 3 2 1 LOAD L 4 3 2 1 R2PBA R2PBB 4 3 2 1 2-wire MAXI-BEAM sensors cannot wire in series with other 2-wire sensors. If series connection of 2-wire AC sensors is required, consider models within the VALUBEAM or MINI-BEAM sensor families. 4-wire ac power blocks can wire in series (see RPBA, RPBB). MAXI-BEAM sensors using power block R2PBA or R2PBB wire in series with an appropriate load. This combination, in turn, wires directly across the ac line. A 2-wire sensor may be connected exactly like a mechanical limit switch. The MAXI-BEAM remains powered when the load is OFF by a residual current which flows through the load. This off-state leakage current is always less than 1.7 milliamps. The effect of this leakage current depends upon the characteristics of the load. The voltage which appears across the load in the OFF state is equal to the leakage current of the sensor multiplied by the resistance of the load: V (off) = 1.7mA x R(load). 2-wire MAXI-BEAMs with Series Contacts 2-wire MAXI-BEAM sensors may be wired in parallel with mechanical switch or relay contacts. The load will energize when either a contact closes or the sensor output is energized. When a contact is closed, it shunts the operating current away from the MAXI-BEAM. As a result, when all of the contacts open, the MAXI-BEAMs 0.1 second power-up delay may cause a momentary drop-out of the load. When 2-wire MAXI-BEAM sensors are connected in series with mechanical switch or relay contacts, the sensor will receive power to operate only when all of the contacts are closed. The false-pulse protection circuit of the MAXIBEAM will cause a 0.1 second delay between the time that the last contact closes and the time that the load can energize. L1 L V ac (See Specifications) 2 L1 R2PBA R2PBB 4 3 2 1 R2PBA R2PBB LOAD Hookup of 2-wire MAXI-BEAMs to a Programmable Logic Controller (PLC) If you have a question on hookup to a specific brand of PLC, contact the Banner Applications Department during normal business hours. 1 Hookup typical for all 8 inputs P 2 I r 3 N o 4 P g. 5 6 L1 L2 V ac (See Specifications) U T S 7 4 3 2 1 Photoelectric Latch with Manual Reset 1CR relay will latch ON whenever the 2-wire MAXIBEAM output is energized. 1CR is reset when the normally-closed pushbutton switch is pressed. AC neutral L 2 V ac (See Specifications) 8 C t r R2PBA R2PBB LATCH 4 3 2 1 l. neutral 1CR RESET 12 LOAD 4 3 2 1 CAUTION: all components of a MAXI-BEAM 2-wire sensor assembly will be destroyed if the load becomes a short circuit. R2PBA R2PBB L2 V ac (See Specifications) There is no polarity requirement. Either wire may be connected to terminal #3, and the other to terminal #4. AC "hot" L1 LOAD 2-wire MAXI-BEAMs with Parallel Contacts If this resultant OFF state voltage is less than the guaranteed turn-off voltage of the load, then the interface is direct. If the OFF state voltage causes the load to stay ON, then an artificial load resistor must be connected in parallel with the load to lower its effective resistance. Most loads, including most programmable logic controller (PLC) inputs, will interface to 2-wire sensors with 1.7mA leakage current, without the need for an artificial load resistor. MAXI-BEAM 2-wire sensors operate with low (1.7mA) off-state leakage current. As a result, they will interface directly to most PLCs without the need for an artificial load resistor. If the off-state voltage (1.7mA x input resistance of PLC) is higher than the PLC sensing threshold, install a 10KΩ to 15KΩ, 5 watt resistor for each 2-wire sensor. The resistor connects between the input terminal and ac neutral. 2 V ac (See Specifications) 1CR MAXI-BEAM Power Blocks Model RPBTLM Low Profile DC Power Block Model RPBTLM is a miniature dc power block for MAXI-BEAM sensors. It may be used with any of the MAXI-BEAM sensor head models. The RPBTLM is supplied with stainless steel hardware used for assembly of the MAXI-BEAM components. Components simply bolt together, with no interwiring necessary. The screws supplied are extra-long, and serve as a means to mount the complete MAXI-BEAM sensor assembly to an object or surface. The RPBTLM may be attached to its sensor head at any of four 90-degree increments to allow the best cable exit direction (front, rear, or either side). A logic module may be added and can be independently rotated (in the same manner) for easiest access to the timing adjustments. Outputs are in the bi-polar configuration: one current-sinking (NPN) plus one current-sourcing (PNP). This design permits direct interfacing of the MAXIBEAM sensor to almost any type of dc logic input. Each output is rated for 150 mA. Either output may be used alone, or both may be used simultaneously. The outputs may be configured for either normally open or normally closed operation via the sensor head (or logic module) programming ring. The RPBTLM includes an LED indicator to show the output status. RPBTLM Dimensions The RPBTLM is completely solid-state and epoxy-encapsulated. It is gasketed to other MAXI-BEAM components by a quad-ring seal. See pages 3,7, and 1415 for information on the assembly and programming of MAXI-BEAM sensors. Hookup Diagram Functional Schematic Specifications INPUT: 10 to 30V dc, 10% maximum ripple. OUTPUT CONFIGURATION: bi-polar. One current sinking (NPN) and one current sourcing (PNP) open-collector transistor switch. OUTPUT RATING: 150mA maximum each output at 25°C (derated to 100mA at 70°C). Derate 1mA per °C. OUTPUT PROTECTION: protected against false pulse on power-up, inductive load transients, power supply polarity reversal, and continuous overload or shortcircuit of outputs. ON-STATE VOLTAGE DROP: NPN output less than 200 millivolts at 10mA and less than one volt at 150mA. PNP output less than 1 volt at 10mA and less than 2 volts at 150mA. OFF-STATE LEAKAGE CURRENT: less than 1 microamp. Model RPBU Power Block: universal power input and output INPUT: 12-250V ac (50/60Hz) or 12-30V dc, 40mA exclusive of load at 30V dc. OUTPUT: Optically-isolated SPST solid-state relay; 240V ac or dc max., 100mA max. On-state voltage drop is 2 volts max. at 100mA (full rated load). DC hookup is without regard to polarity. WARNING: Connection of voltage directly across pins 3 and 4, without a load present, will destroy the switching element. 13 MAXI-BEAM Logic Modules MAXI-BEAM sensors offer built-in timing logic with the addition of a logic module. There are two logic modules available. Model RLM5 is programmable for ON-DELAY, OFFDELAY, and ON/OFF DELAY timing logic. Model RLM8 offers both ONE-SHOT and DELAYED ONE-SHOT functions. A programming ring is supplied with each logic module. Programming of the logic function, timing range, and output state is similar to sensor head programming. Both logic modules feature 15-turn, clutched potentiometers for accurate timing adjustments. Once programmed, the logic module may be rotated in 90-degree increments to position the timing adjustments for easiest access. Logic modules are housed in the same tough molded VALOX® which is used for the other MAXI-BEAM components. The logic module and its programming ring simply slip between the MAXI-BEAM sensor head and power block (see photograph, page 3). The assembly is bolted together with no interwiring necessary. The component interfaces are quad-ring sealed. MAXI-BEAM Logic Module Specifications SUPPLY VOLTAGE: input power is supplied by the power block (see pages 8-13). RESPONSE TIME: RLM5: add sensor response delay of approximately 2% of maximum OFF-DELAY time. RLM8: no added response time for ONE-SHOT mode. TIMING ADJUSTMENTS: two 15-turn clutched potentiometers with brass element, accessible from outside of logic module, under oring gasketed cover screws. Model and Logic Functions RLM5 TIMING REPEATABILITY: plus or minus 2% of the maximum time of the selected range, assuming conditions of constant operating temperature and power supply voltage. TIMING RANGE: 15 second ranges: 0.5 to 15 seconds; 1 second ranges: 0.1 to 1 second; 0.1 second ranges: 0.01 to 0.1 second. CONSTRUCTION: reinforced molded VALOX® housing, quadring gasketed. Electronics fully epoxy encapsulated. NEMA 1,3,4,12, 13. OPERATING TEMPERATURE: -40 to +70 degrees C (-40 to +158 degrees F). Programming PROGRAM CHOICES: 1) Timing Logic Function: a) ON-delay b) OFF-delay c) ON/OFF-delay 2) Timing Adjustment Range (see options below) 3) Output State: a) normally open b) normally closed TO PROGRAM LOGIC MODULE: 1) Find the programming notch which lines up with the program choice. NOTE: the programming ring may have to be turned upside-down in order to find a notch that lines up with the desired program. 2) Press the programming ring and logic module together. They will be held together temporarily by their interlocking pegs. 3) Orient the logic module for easiest access to the timing adjustments, and assemble between the programming ring of the sensor head and the power block (see exploded view on page 3). Bolt all parts together with the long bolts that are supplied with the logic module. 4) Apply power to the MAXI-BEAM and adjust timing, using a small flat-blade screwdriver. Timing potentiometers are located behind the nylon o-ring gasketed cover screws. Program Definition 14 MAXI-BEAM Logic Modules Programming Model and Logic Functions RLM8 PROGRAM CHOICES: 1) Timing Logic Function: a) ONE-SHOT b) Delayed ONE-SHOT 2) Timing Adjustment Range (see options below) 3) Output State: a) normally open b) normally closed TO PROGRAM LOGIC MODULE: 1) Find the programming notch which lines up with the program choice. NOTE: the programming ring may have to be turned upside-down in order to find a notch that lines up with the desired program. 2) Press the programming ring and logic module together. They will be held together temporarily by their interlocking pegs. 3) Orient the logic module for easiest access to the timing adjustments, and assemble between the programming ring of the sensor head and the power block (see exploded view on page 3). Bolt all parts together with the long bolts that are supplied with the logic module. 4) Apply power to the MAXI-BEAM and adjust timing, using a small flat-blade screwdriver. Timing potentiometers are located behind the nylon o-ring gasketed cover screws. Program Definition MAXI-BEAM Accessories Replacement Upper Covers (Lens Assemblies) An upper cover consists of the optical element for the MAXI-BEAM sensor head. An upper cover may be used as a replacement part or for modifying the optical response of a sensor. Upper cover assemblies include lens, replacement bezel, o-ring, and stainless steel screws. Replacement Lenses Sensor Head Lens Interchangeability Upper Cover RSBE ....................................... RSBR ....................................... RSBLV .................................... RSBLVAG .............................. RSBD ...................................... RSBDSR, ESR, & RSR ........... RSBC, CV ............................... RSBF, FV ................................ RSBFP ..................................... RUC-L RUC-L RUC-L RUC-AG RUC-L RUC-D RUC-C RUC-F RUC-FP CONVERSION FROM - TO USE UPPER COVER CONVERSION FROM - TO USE UPPER COVER RSBLV to RSBLVAG ... RUC-AG RSBLVAG to RSBLV ... RUC-L RSBLV to RSBCV ......... RUC-C RSBCV to RSBLV ......... RUC-L RSBD to RSBDSR ......... RUC-D RSBDSR to RSBD ......... RUC-L RSBD to RSBF ............... RUC-F RSBF to RSBDSR .......... RUC-D RSBDSR to RSBF .......... RUC-F 15 MAXI-BEAM Accessories Mounting Brackets Model SMB700 (right) is a general-purpose two-axis mounting bracket that is supplied with a cable gland assembly which is used to attach the MAXI-BEAM wiring base to the bracket. The gland assembly is threaded through the bracket and into the conduit entrance at the base of the scanner block. A large lockwasher is supplied to hold the scanner block firmly in place. The bracket is 11-gauge zinc plated steel. Model SMB700SS is an 11-gauge stainless steel version of the SMB700. It is sold alone, without the cable gland assembly and lockwasher. Model SMB700F (photo, below) is a flat, single-axis version of the SMB-700. It is sold without hardware. HF1-2NPS Model SMBLS (not shown) is a twopart bracket assembly which allows adjustment in three directions. It consists of two 11-gauge zinc plated steel rightangle brackets which fasten together so that they rotate relative to each other. The MAXI-BEAM wiring base attaches to the upper bracket and slots are provided for vertical adjustment. The bottom bracket is a modified version of the SMB700. Assembly hardware and a cable gland are included. SMB700M This is a black nylon cable gland assembly for use with the MAXI-BEAM and other sensors having a 1/2NPS conduit entrance. The flexible extension keeps the sensor cable from bending too sharply, and mimimizes cable fatigue due to repeated flexing. The HF1-2NPS includes a neoprene gland that accommodates cables with diameters from .20 to .35 inch for a liquid-tight seal. This flexible gland assembly is resistant to gasoline, alcohol, oil, grease, solvents, and weak acids. It has a working temperature range of -30° to +100°C (-22 to +212°F). It is UL recognized and CSA certified. The HF1-2NPS is sold in packages of 10 pieces. RF1-2NPS SMB700P Cable gland assembly for MAXI-BEAMs. Includes cord grips for .1 to .4 inch diameter cable. Bracket lockwasher is also included. MBC-4 Heavy-duty 1/4-inch (6mm) zinc plated steel bracket that allows the MAXI-BEAM to retrofit to installations of MICRO-SWITCH models MLS8 or MLS9 sensors. Includes cable gland and lockwasher. Banner Engineering Corp. Heavy duty 1/4-inch (6mm) zinc plated steel bracket that allows the MAXIBEAM to retrofit to installations of PHOTOSWITCH series 42RLU and 42RLP sensors. Includes cable gland and lockwasher. 9714 Tenth Ave. No. Minneapolis, MN 55441 MBCC-412 MBC-4 is a 4-pin male industrial-duty connector that threads into the base of all MAXI-BEAMs. MBCC-412 is a 12-foot long (3,6m) "SJT" type cable. It is interchangeable with standard industry types of several different manufacturers. Telephone: (612)544-3164 FAX (applications): (612)544-3573
很抱歉,暂时无法提供与“RSBD”相匹配的价格&库存,您可以联系我们找货
RSBD
  • 1+2532.088481+327.29931
库存:4
