SM312LVQD-50939
SM312LVQD-50939
    BANNER(邦纳)
    PHOTO SEN SHORT RANGE BIPOLAR
SM312LVQD-50939 数据手册
MINI-BEAM® DC Voltage Series Sensor Datasheet Self-contained photoelectric sensors • • • • 10 to 30 V DC with bipolar NPN/PNP outputs Signal strength or output indicator 2 m or 9 m integral cable, or Euro-style quick-disconnect fitting 18 mm threaded lens mount on some models WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Models Integral 2 m (6.5 ft) unterminated cable models are listed. • To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. For example, SM31EW/30. • To order the 4-pin M12/Euro-style QD models, add the suffix “QD” to the model number. For example, SM31EQD. • To order the 150 mm (6 in) cable with QD, add the suffix “QDP” to the model number. For example, SM31EQDP. • To order a 0.3 ms response time model, add the suffix “MHS” to the model number. For example, SM31EMHS. Range Sensing Mode Opposed Emitter Opposed Receiver OPPOSED Opposed Emitter - Long Range Opposed Receiver - Long Range Opposed Emitter - Clear Plastic Detection OPPOSED Opposed Receiver - Clear Plastic Detection LED Model SM31E 3 m (10 ft) Infrared, 880 nm 30 m (100 ft) SM31R SM31EL SM31RL SM31EPD 0 to 300 mm (0 to 12 in) Actual range varies, depending on the light transmission properties of the plastic material being sensed. SM31RPD Non-Polarized Retroreflective 5 m (15 ft) Polarized Retroreflective 55 mm to 2 m (2 in to 7 ft) SM312LVAG Extended-Range Polarized Retroreflective 10 mm to 3 m (0.4 in to 10 ft) SM312LP 380 mm (15 in) SM312D 300 mm (12 in) SM312DBZ Visible red, 650 nm SM312LV RETRO P POLAR RETRO Diffuse DIFFUSE Divergent Diffuse 130 mm (5 in) 16 mm (0.65 in) Focus Convergent CONVERGENT Original Document 69943 Rev. G 43 mm (1.7 in) Focus SM312W Infrared, 880 nm SM312C SM312C2 8 September 2020 69943 MINI-BEAM® DC Voltage Series Sensor Sensing Mode Range LED Model 16 mm (0.65 in) Focus SM312CV Visible red, 650 nm 43 mm (1.7 in) Focus CONVERGENT 16 mm (0.65 in) Focus SM312CVB Visible blue, 475 nm 49 mm (1.9 in) Focus CONVERGENT 16 mm (0.65 in) Focus SM312CV2B SM312CVG Visible green, 525 nm 49 mm (1.9 in) Focus CONVERGENT SM312CV2 Glass Fiber Optic GLASS FIBER Range varies, depending on sensing mode and fiber optics used. Plastic Fiber Optic PLASTIC FIBER Special High-Power Option Plastic Fiber Optic SM312CV2G Infrared, 880 nm SM312F Visible red, 650 nm SM312FV Visible blue, 475 nm SM312FVB Visible green, 525 nm SM312FVG Visible red, 650 nm SM312FP Visible blue, 475 nm SM312FPB Visible green, 525 nm SM312FPG Visible red, 650 nm SM312FPH Overview 1. Adjustment Indicator Device (AID) 2. Gain (sensitivity) adjustment screw 3. Light/dark operate select switch 1 Adjust clockwise for light operate (outputs conduct when sensing light is received) and counterclockwise for dark operate (outputs conduct when sensing light is not received). 2 3 Wiring Diagrams Emitters with Attached Cable All Other Models with Attached Cable bn bn bu 2 + 10-30V dc – bu + 10-30V dc – wh bk www.bannerengineering.com - Tel: + 1 888 373 6767 Load Load P/N 69943 Rev. G MINI-BEAM® DC Voltage Series Sensor Emitters with Quick Disconnect (4-pin Euro-Style) bn All Other Models with Quick Disconnect (4-pin Euro-Style) bn + 10-30V dc – bu + 10-30V dc – bu wh wh bk bk Load Load The output type for all models is Bipolar NPN/PNP; load 150 mA max., each output. Sensor Mounting and Alignment MINI-BEAM sensors perform most reliably if they are properly aligned and securely mounted. For maximum mechanical stability, mount MINI-BEAM sensors through 18 mm diameter holes by their threaded barrel (where available), or use a mounting bracket. A complete selection of mounting brackets is available. Visit http:// www.bannerengineering.com or contact Banner Engineering for information on mounting options. Begin with line-of-sight positioning of the MINI-BEAM sensor to its emitter (opposed-mode sensing) or to its target (all other sensing modes). When using a retroreflective sensor, the target is the retroreflector (“retro target”). For diffuse or convergent sensing modes, the target is the object to be detected. Apply power to the sensor (and to the emitter, if using the opposed mode). Advance the 15-turn Gain control to maximum (clockwise end of rotation) using a small flat-blade screwdriver. The Gain control is clutched at both ends to avoid damage and will “free-wheel” when either endpoint is reached. If the MINI-BEAM sensor is receiving its light signal, the red LED Alignment indicator will be ON and flashing at a rate proportional to the signal strength (faster = more signal). Move the sensor (or retro target, if applicable) up-down-right-left (including angular rotation) to find the center of the movement zone within which the LED indicator remains ON. Reducing the Gain setting reduces the size of the movement zone for more precise alignment. Repeat the alignment motions after each Gain reduction. When optimum alignment is achieved, mount sensor(s) (and the retro target, if applicable) solidly in that position. Increase the Gain to maximum. Test the sensor by placing the object to be detected in the sensing position, then removing it. The Alignment indicator LED should come ON when the sensing beam is established (Light condition) or be ON when the beam is broken (Dark condition). If the Alignment indicator LED stays ON for both sensing conditions, consider the following tips for each sensing mode. Opposed Mode Alignment Emitter jec Ob Flooding occurs when a portion of the sensing beam passes around the object to be sensed. Burn-through occurs when a portion of the emitter’s light energy passes through a thin or translucent object, and is sensed by the receiver. To correct either problem, do one or more of the following to reduce the light energy: • Reduce the Gain adjustment on the receiver • Add an aperture to one or both lenses (MINI-BEAM apertures, available from Banner, fit neatly inside the lens assembly) • Intentionally misalign the emitter and receiver t Receiver Note: • • P/N 69943 Rev. G www.bannerengineering.com - Tel: + 1 888 373 6767 Light condition: sensor output is ON when there is no object in the beam Dark condition: sensor output is ON when there is an object in the beam 3 MINI-BEAM® DC Voltage Series Sensor Diffuse Mode Alignment If the Alignment LED does not go OFF when the object is removed from the beam, the sensor is probably detecting light reflected from some background object. To remedy this problem: • Reduce the reflectivity of the background by painting the surface(s) flat-black, scuffing any shiny surface, or drilling a large hole, directly opposite the diffuse sensor • Move the sensor closer to the object to be detected and reduce the Gain adjustment. Rule of thumb for diffuse sensing: The distance to the nearest background object should be at least three times the sensing distance t jec Ob Note: • • Light condition: sensor output is ON when there is no object in the beam Dark condition: sensor output is ON when there is an object in the beam Retroreflective Mode Alignment A highly reflective object may reflect enough light back to a retroreflective sensor to allow that object to slip through the beam, without being detected. This problem is called proxing, and the following methods may be used to correct it: • Position the sensor and retro target so the beam will not strike a shiny surface perpendicular to the sensor lens • Reduce the Gain adjustment • Add a polarizing filter (for model SM312LV) tro Re t ge r a T Note: • • Light condition: sensor output is ON when there is no object in the beam Dark condition: sensor output is ON when there is an object in the beam Convergent Mode Alignment w Lo vity ti flec nd Re grou k c Ba t jec Ob The sensing energy of a convergent mode sensor is concentrated at the specified focus point. Convergent mode sensors are less sensitive to background reflections, compared with diffuse mode sensors. However, if background reflections are a problem: • Skew the sensor position at a 10° to 25° angle to eliminate direct reflections from shiny background surfaces • Reduce the reflectivity of the background by painting the surface(s) flat-black, scuffing any shiny surface, or drilling a large hole, directly opposite the sensor • Reduce the Gain adjustment Note: • • 4 www.bannerengineering.com - Tel: + 1 888 373 6767 Light condition: sensor output is ON when there is no object in the beam Dark condition: sensor output is ON when there is an object in the beam P/N 69943 Rev. G MINI-BEAM® DC Voltage Series Sensor Installing Plastic Fibers on a MINI-BEAM Follow these instructions to install plastic fibers into your sensor. MINI-BEAMS may have either a fiber gripper or a clamp screw. MINI-BEAM and ECONO-BEAM sensors for use with plastic fiber optic assemblies include sensors with the letters FP in their model number. MINI-BEAM "FP1" Sensor Gripper Unlock Lock Adapters for 0.25- and 0.5-mm fibers Slide Fibers & Bushings into Ports Trimmed fiber control ends Sensor Face Fiber Bushings (supplied with fiber) Tighten Clamp Screw to Secure Fiber Sensor Face Plastic fiber Receiver port Plastic fiber Emitter port 0.25" Unterminated Plastic Fibers Figure 1. MINI-BEAM with fiber grippers Figure 2. MINI-BEAM with clamp screws 1. Prepare the sensor ends of the fibers (see Cut the Plastic Fiber on p. 5). 2. Prepare the sensor for the fibers. • For models with a fiber gripper: Unlock the fiber gripper as shown in the figure and apply the appropriate fiber adaptors to the fiber, if needed. • For models with a clamp screw: Loosen the clamp screw on the sensor face. 3. Insert the plastic fibers. • For models with a fiber gripper: Gently insert the prepared fiber ends into the ports as far as they will go. • For models with a clamp screw: Align the fiber ends flush with the ends of the bushings as shown. Hold the bushings to the fibers and slide both into the sensor ports. Push the fiber an additional 1 inch through the bushing. 4. Lock in the fibers. • For models with a fiber gripper: Slide the fiber gripper back to lock, as shown in the figure. • For models with a clamp screw: Tighten the clamp screw to secure the fibers. Cut the Plastic Fiber An unterminated plastic fiber is designed to be cut by the customer to the length required for the application. To facilitate cutting, a Banner model PFC-4 cutting device is supplied with this fiber. 1. Locate the non-terminated end, and determine the length of fiber required for the application. 2. Lift the top of the cutter to open the cutting ports. 3. Insert the non-terminated end through one of the four large cutting ports on the PFC-4 cutter so that the excess fiber protrudes from the back of the cutter. 4. Double-check the fiber length, and close the cutter until the fiber is cut. 5. Gently wipe the cut ends of the fiber with a clean, dry cloth to remove any contamination. Note: Do not use solvents or abrasives on any exposed optical fiber. Do not use a cutting port more than once. The blade may tend to dull after one cut. Installing the Glass Fibers in MINI-BEAMs Retaining Clip O-ring P/N 69943 Rev. G www.bannerengineering.com - Tel: + 1 888 373 6767 5 MINI-BEAM® DC Voltage Series Sensor 1. Install the O-ring (supplied with the fiber) on each fiber end, as shown in the drawing. 2. While pressing the fiber ends firmly into the ports on the sensor front, slide the U-shaped retaining clip (supplied with the sensor) into the slot in the sensor's barrel, until it snaps into place. Specifications Supply Voltage and Current 10 to 30 V DC (10% maximum ripple) at less than 25 mA (exclusive of load) Environmental Rating Meets NEMA standards 1, 2, 3, 3S, 4, 4X, 6, 12, and 13; IEC IP67. Supply Protection Circuitry Protected against reverse polarity and transient voltages Connections PVC-jacketed 4-conductor 2 m (6.5 ft) or 9 m (30 ft) cables, or 4-pin M12/ Euro-style male QD fitting; QD cables available separately Output Configuration Bipolar: One current sourcing (PNP) and one current sinking (NPN) open collector transistor Output Rating 150 mA maximum each output at 25 °C, derated to 100 mA at 70 °C (derate ≈ 1 mA per °C) OFF State Leakage Current: less than 1 microamp Output Saturation Voltage (PNP Output): less than 1 V at 10 mA, less than 2 V at 150 mA Output Saturation Voltage (NPN Output): less than 200 millivolts at 10 mA, less than 1 V at 150 mA Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short-circuit of outputs Operating Conditionsperating Conditions –20 °C to +70 °C (–4 °F to +158 °F) 90% at +50 °C maximum relative humidity (non-condensing) Application Note The NPN (current sinking) output of dc MINI-BEAM sensors is directly compatible as an input to Banner logic modules, including all non-amplified MAXI-AMP and MICRO-AMP modules. MINI-BEAMs are TTL compatible. Required Overcurrent Protection Output Response Time Sensors will respond to either a “light” or “dark” signal of 1 millisecond or longer duration, 500 Hz maximum. Modification for 0.3 millisecond response is available (MHS-suffix models; these models also feature reduced sensitivity range and reduced repeatability.) Note: Outputs are non-conducting during 100 millisecond delay on power-up. Repeatability Opposed: 0.14 milliseconds Non-Polarized and Polarized Retro, Diffuse, Convergent, Glass Fiber Optic, and Plastic Fiber Optic: 0.3 milliseconds WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Response time and repeatability specifications are independent of signal strength. Adjustments Light/Dark Operate Select switch 15-turn slotted brass screw Gain (sensitivity) adjustment potentiometer (clutched at both ends of travel) Located on the rear panel, protected by a gasketed, clear acrylic cover. Indicators Patented Alignment Indicator Device system (AID™, US patent #4356393) lights a rear-panel-mounted LED indicator when the sensor sees light. Its pulse rate is proportional to the light signal strength (the stronger the signal, the faster the pulse rate). Certifications Construction Reinforced thermoplastic polyester housing, totally encapsulated, o-ring sealing, acrylic lenses, stainless steel screws Performance Curves for SM31Ex Emitter and SM31Rx Receiver Models 1000 SM31E & SM31R SMA31E & SM2A31R 12.0 in 200 mm Opposed Mode 8.0 in 100 mm 4.0 in 0 0 100 mm 4.0 in 200 mm 8.0 in 300 mm 12.0 in 0.6 m 2 ft 1.2 m 4 ft 1.8 m 6 ft 2.4 m 8 ft 3.0 m 10 ft Distance Effective Beam: 3.5 mm 6 SM31E & SM31R SMA31E & SM2A31R Excess Gain 300 mm 0 Beam Pattern for SM31EL/RL Opposed Mode 100 1000 750 mm SM31EL & SM31RL SMA31EL & SM2A31RL 30.0 in 500 mm Opposed Mode 20.0 in 250 mm 10.0 in 0 10 1 .01 m .033 ft .10 m .33 ft Distance 1.0 m 3.3 ft 10 m 33 ft 0 250 mm 10.0 in 500 mm 20.0 in 750 mm 30.0 in 0 6m 20 ft 12 m 40 ft Excess Gain Curve for SM31EL/RL 18 m 60 ft 24 m 80 ft 30 m 100ft Distance SM31EL & SM31RL SMA31EL & SM2A31RL Opposed Mode Excess Gain Excess Gain Curve for SM31E/R Beam Pattern for SM31E/R 100 10 1 0.1 m 0.33 ft 1.0 m 3.3 ft 10 m 33 ft 100 m 330 ft Distance Effective Beam: 13 mm www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 69943 Rev. G MINI-BEAM® DC Voltage Series Sensor Performance Curves for the SM312Lx Retroreflective Models Excess Gain Curve for SM312LVxx Beam Pattern for SM312LVxx 1.0 in 0 0 25 mm 1.0 in With BRT-3 Reflector 50 mm 2.0 in 75 mm 60 mm Retroreflective Mode 100 1m 3 ft 2m 6 ft 3m 9 ft 4m 12 ft 20 mm 0.8 in 40 mm 1.6 in With BRT-3 Reflector 0 10 m 33 ft .6 m 2 ft 1.2 m 4 ft 1.8 m 6 ft 2.4 m 8 ft 100 With BRT-3 Reflector 10 2.4 in 1 .01 m 0.03 ft 3.0 m 20 ft Distance Distance 0.1 m 0.3 ft 1m 3 ft 10 m 30 ft Distance SM312LVAG SM2A312LVAG 3.0 in Retroreflective Mode 2.0 in 25 mm 1.0 in 0 0 25 mm 1.0 in 50 mm 2.0 in With BRT-3 Reflector 75 mm 1.2 m 4 ft 1.8 m 6 ft 2.4 m 8 ft Excess Gain 50 mm .6 m 2 ft 1.0 m 3.3 ft 1.6 in 1000 SM312LVAG SM2A312LVAG 0 .10 m .33 ft SM312LP SM2A312LP Retroreflective Mode 0 60 mm 1 .01 m .033 ft 5m 15 ft 2.4 in 0.8 in 0 10 Distance 75 mm 40 mm 20 mm With BRT-3 Reflector 3.0 in 0 SM312LP SM2A312LP Retroreflective Mode Excess Gain 2.0 in Retroreflective Mode 25 mm SM312LV SM2A312LV 3.0 in Excess Gain 50 mm 1000 1000 SM312LV SM2A312LV 75 mm Excess Gain Curve for SM312LP Beam Pattern for SM312LP Retroreflective Mode 100 With BRT-3 Reflector 10 3.0 in 1 .01 m .033 ft 3.0 m 10 ft Distance .10 m .33 ft 1.0 m 3.3 ft 10 m 33 ft Distance Performance Curves for the SM312Dx and SM312W Diffuse Models 1000 SM312D, SM2A312D SM312D, SM2A312D Diffuse Mode 0.6 in 10 mm 0.4 in 5 mm 0.2 in 0 0 5 mm 0.2 in 10 mm 0.4 in 15 mm 0.6 in 0 75 mm 3.0 in 150 mm 6.0 in 225 mm 9.0 in Diffuse Mode 100 Excess Gain 15 mm 1 1 mm .04 in 300 mm 375 mm 12.0 in 15.0 in Distance 0.4 in 5 mm 0.2 in 0 5 mm 0.2 in 10 mm 0.4 in 15 mm 0.6 in 0 75 mm 3.0 in 150 mm 6.0 in 225 mm 9.0 in Distance P/N 69943 Rev. G Diffuse Mode 100 mm 4 in 1000 mm 40 in 1000 15.0 mm 0.6 in 7.5 mm 0.3 in 0 7.5 mm 0.3 in 15.0 mm 0.6 in 22.5 mm 0.9 in 0 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in Distance SM312W SM2A312W 0.9 in 100 mm 125 mm 4.0 in 5.0 in Diffuse Mode 100 10 1 1 mm .04 in 10 mm .4 in 100 mm 4 in 1000 mm 40 in Distance 1000 SM312DBZ SM2A312DBZ 0.6 in 10 mm 0 10 mm .4 in Distance 300 mm 375 mm 12.0 in 15.0 in Diffuse Mode 100 Excess Gain SM312DBZ, SM2A312DBZ Diffuse Mode 15 mm SM312W, SM2A312W 22.5 mm 0 10 Excess Gain Curve for SM312W Beam Pattern for SM312W Excess Gain Excess Gain Curve for SM312Dx Beam Pattern for SM312Dx 10 1 1 mm .04 in 10 mm .40 in 100 mm 4.0 in 1000 mm 40 in Distance www.bannerengineering.com - Tel: + 1 888 373 6767 7 MINI-BEAM® DC Voltage Series Sensor Performance Curves for the SM312Cx Convergent Models SM312C, SM2A312C 0.15" 2.5 mm 0.10" 1.2 mm 0.05" 0 0 1.2 mm 0.05" 2.5 mm 0.10" 3.8 mm Convergent Mode 100 Excess Gain Convergent Mode 25 mm (1") 50 mm (2") 75 mm (3") 10 1.2 mm 0.05" 0 0 1.2 mm 0.05" 2.5 mm 0.10" 3.8 mm 0.15" Excess Gain 0.10" 75 mm (3") 100 mm (4") 1000 2.5 mm 50 mm (2") 10 mm (0.4") 1.0 mm 0.04" 2.0 mm 0.08" 1000 mm (40") 7.5 mm (0.3") 15 mm (0.6") Convergent Mode 2.0 mm 100 22.5 mm (0.9") 1 1 mm (0.04") Distance 10 mm (0.4") 100 mm (4") Convergent Mode SM312CV2 SM2A312CV2 0.08" Convergent Mode 0 1.0 mm 0.04" 2.0 mm 0.08" 3.0 mm 0.12" 0 25 mm (1") 50 mm (2") 75 mm (3") 100 10 1 1 mm (0.04") 100 mm 125 mm (5") (4") Distance Distance 1000 mm (40") 0.12" 0.04" 1000 mm (40") 100 mm (4") 1000 SM312CV2, SM2A312CV2 0 100 mm 125 mm (5") (4") 10 mm (0.4") Distance 1.0 mm 10 10 1 1 mm (0.04") 30 mm 37.5 mm (1.2") (1.5") Distance 3.0 mm 100 0.12" 0 SM312C2 SM2A312C2 0.15" Convergent Mode 25 mm (1") 0 Distance SM312C2, SM2A312C2 0 0.04" 3.0 mm 1 1 mm (0.04") 100 mm 125 mm (4") (5") Convergent Mode 0.08" 0 Distance 3.8 mm 2.0 mm SM312CV SM2A312CV 0.12" Convergent Mode 1.0 mm 0.15" 0 1000 SM312CV, SM2A312CV 3.0 mm Excess Gain 1000 SM312C, SM2A312C 3.8 mm Excess Gain Curve for SM312CV Beam Pattern for SM312CV Excess Gain Excess Gain Curve for SM312C Beam Pattern for SM312C 10 mm (0.4") 100 mm (4") 1000 mm (40") Distance Performance is based on a 90% reflectance white test card. 0.80 mm 0.030" 0.40 mm 0.015" 0 0 0.40 mm 0.015" 0.80 mm 0.030" 1.20 mm 0.045" 0 7.5 mm (0.3") 15 mm (0.6") 22.5 mm (0.9") 1000 Convergent Mode 100 10 100 mm (4") 0 0 1.0 mm 0.04" 2.0 mm 0.08" 3.0 mm 0.12" 25 mm (1") 50 mm (2") 75 mm (3") Distance 8 Convergent Mode 100 mm 125 mm (4") (5") Excess Gain 0.04" 0 SM312CV2B 0.08" 1.0 mm 0.40 mm 0.015 in 0 0.40 mm 0.015 in 0.80 mm 0.030 in 7.5 mm 0.3 in 15 mm 0.6 in 22.5 mm 0.9 in 1 1 mm .04 in 10 mm .4 in Distance 100 mm 4 in 1000 mm 40 in 30 mm 1.2 in 1 1 mm .04 in 37.5 mm 1.5 in 0 1.0 mm 0.04 in 2.0 mm 0.08 in 3.0 mm 0.12 in 25 mm 1 in 50 mm 2 in 75 mm 3 in Distance www.bannerengineering.com - Tel: + 1 888 373 6767 1000 mm 40 in SM312CV2G 0.08 in 0.04 in 0 100 mm 4 in Distance 0.12 in Convergent Mode 2.0 mm 10 mm .4 in 1000 SM312CV2G 3.0 mm 0 10 10 Distance 1.0 mm 100 Convergent Mode 100 0.045 in 0 1000 mm (40") 0.12" Convergent Mode 2.0 mm 0.030 in Distance 1000 3.0 mm 0.80 mm 1.20 mm 10 mm (0.4") SM312CVG, SM2A312CVG 0.045 in Convergent Mode 0 1 1 mm (0.04") 30 mm 37.5 mm (1.2") (1.5") Distance SM312CV2B 1000 SM312CVG, SM2A312CVG 1.20 mm SM312CVB Excess Gain 0.045" Convergent Mode Excess Gain SM312CVB 1.20 mm Excess Gain Curve for SM312CVG Beam Pattern for SM312CVG 100 mm 125 mm 4 in 5 in Convergent Mode Excess Gain Excess Gain Curve for SM312CVB Beam Pattern for SM312CVB 100 10 1 1 mm .04 in 10 mm .4 in 100 mm 4 in 1000 mm 40 in Distance P/N 69943 Rev. G MINI-BEAM® DC Voltage Series Sensor Performance Curves for the SM312F Glass Fiber Optic Models Diffuse Mode Opposed Mode Excess Gain Curve for SM312F Beam Pattern for SM312F Excess Gain Curve for SM312F Beam Pattern for SM312F 1000 1000 BT13S 0 BT23S 0.65 mm 0.025 in 1.3 mm 0.050 in 1.9 mm 0.075 in 0 7.5 mm 0.3 in 15 mm 0.6 in 22.5 mm 0.9 in 30 mm 1.2 in 50 mm 1 in 0 BT13S Fiber 1 1 mm .04 in 37.5 mm 1.5 in Distance 10 mm .4 in 100 mm 4 in 2 in 25 mm BT23S Fiber 10 IT13S 1 in 50 mm 2 in 75 mm 3 in 0 100 mm 4 in 200 mm 8 in 300 mm 12 in Diffuse Mode Excess Gain Curve for SM312FV BT13S 0 BT23S 0.65 mm 0.025 in 1.30 mm 0.050 in 1.95 mm 0.075 in 0 5 mm 0.2 in 10 mm 0.4 in 15 mm 0.6 in 20 mm 0.8 in 10 0 1.0 mm 0.04" 2.0 mm 0.08" 3.0 mm 0.12" 8 mm (0.3") 16 mm (0.6") 24 mm (0.9") 32 mm (1.2") Diffuse Mode Excess Gain 0.04" BT23S BT13S 0 SM312FVB 1 in 50 mm 2 in 75 mm 3 in 0 50 mm 2 in 100 mm 4 in BT23S Fiber BT13S Fiber 40 mm (1.5") Distance 1 mm (0.04") 10 mm (0.40") IT23S Fiber 10 IT13S Fiber 1 1 mm .04 in 200 mm 250 mm 8 in 10 in 10 mm .40 in 100 mm 4.0 in Excess Gain Curve for SM312FVG 1000 SM312FVG 3.0 mm Diffuse Mode 0.08 in 0.04 in 0 BT23S 1.0 mm 0.04 in 2.0 mm 0.08 in 3.0 mm 0.12 in 0 100 mm (4") 8 mm 0.3 in SM312FVG 0.12 in BT13S 16 mm 0.6 in 24 mm 0.9 in 32 mm 1.2 in Diffuse Mode 100 BT23S Fiber 10 BT13S Fiber 1 .1 mm .004 in 40 mm 1.5 in 1 mm .04 in Distance Distance 1000 mm 40 in Distance 1.0 mm 10 100 Beam Pattern for SM312FVG 0 1 0.1 mm (0.004") 150 mm 6 in Opposed Mode Distance 2.0 mm 100 0 IT23S 25 mm 100 mm 4 in Excess Gain Curve for SM312FVB 0.08" 1.0 mm 0 10 mm .40 in 0.12" Diffuse Mode 2.0 mm 1 mm .04 in 1000 SM312FVB 3.0 mm BT23S Fiber SM312FV SM2A312FV 2 in IT13S Distance Beam Pattern for SM312FVB 10 m 33 ft Excess Gain Curve for SM312FV 1 in 0 Distance 1m 3.3 ft 3 in Opposed Mode 25 mm BT13S Fiber 25 mm 1.0 in SM312FV, SM2A312FV 50 mm 100 1 .1 mm .004 in .1 m .33 ft Distance Beam Pattern for SM312FV 75 mm Diffuse Mode Excess Gain 0.025 in 0 IT23S Fibers 1000 SM312FV SM2A312FV 0.050 in 0.65 mm IT13S Fibers Opposed Mode 0.075 in 1.30 mm IT23S Fibers w/L9 lenses 10 1 .01 m .033 ft 400 mm 500 mm 16 in 20 in 1000 SM312FV, SM2A312FV Diffuse Mode 1.95 mm Opposed Mode Glass Fibers 100 Distance Distance Beam Pattern for SM312FV 0 IT23S 25 mm 1000 mm 40 in SM312F, SM2A312F 3 in Opposed Mode Excess Gain 100 0.025 in Excess Gain 0.65 mm 0 Diffuse Mode Glass Fibers 0.050 in SM312F, SM2A312F 75 mm Excess Gain 1.3 mm SM312F, SM2A312F 0.075 in SM312F, SM2A312F Diffuse Mode Excess Gain 1.9 mm 10 mm .40 in 100 mm 4 in Distance Performance Curves for the SM312FP Plastic Fiber Models Diffuse Mode Opposed Mode 1000 SM312FP/SM2A312FP SM312FP SM2A312FP 45 mm 2.5 mm 0.10 in 30 mm 1.2 mm 0.05 in Diffuse Mode Plastic Fibers Diffuse Mode 0 0 PBT46U PBT26U 1.2 mm 0.05 in 2.5 mm 0.01 in 3.8 mm 0.015 in 0 7.5 mm 0.3 in 15 mm 0.6 in 22.5 mm 0.9 in Distance P/N 69943 Rev. G 30 mm 1.2 in 37.5 mm 1.5 in Excess Gain 0.15 in 3.8 mm 100 10 PBT26U Fiber 1 .1 mm .004 in 1 mm .04 in 10 mm .4 in Distance 1000 SM312FP/SM2A312FP 1.2 in 100 mm 4 in 0.6 in 0 PIT46U PIT26U 0 15 mm 0.6 in 30 mm 1.2 in 45 mm 1.8 in 0 25 mm 1 in SM312FP SM2A312FP 1.8 in Opposed Mode 15 mm PBT46U Fiber Excess Gain Curve for SM312FP Beam Pattern for SM312FP 50 mm 2 in 75 mm 3 in Distance www.bannerengineering.com - Tel: + 1 888 373 6767 100 mm 125 mm 4 in 5 in Opposed Mode Plastic Fibers 100 Excess Gain Excess Gain Curve for SM312FP Beam Pattern for SM312FP PIT46U Fiber 10 PIT26U Fiber 1 1 mm .04 in 10 mm .40 in 100 mm 4.0 in 1000 mm 40 in Distance 9 MINI-BEAM® DC Voltage Series Sensor 1000 SM312FPB 2.0 mm 0.08" 1.0 mm 0.04" 0 0 PBT46U 1.0 mm 0.04" 2.0 mm 0.08" 3.0 mm 3.0 mm Diffuse Mode Plastic Fiber 100 0.12" 0 4 mm (0.15") 8 mm (0.30") 12 mm (0.45") 16 mm (0.60") 2.0 mm 0.08 in 1.0 mm 0.04 in 0 PBT46U 1.0 mm 0.04 in 2.0 mm 0.08 in 3.0 mm 1 0.1 mm (0.004") 20 mm (0.75") 1 mm (0.04") Distance 10 mm (0.4") 100 mm (4") Distance SM312FPG 0.12 in Diffuse Mode 0 PBT46U Fiber 10 Excess Gain Curve for SM312FPG 1000 SM312FPG SM312FPB 0.12" Diffuse Mode Excess Gain 3.0 mm Beam Pattern for SM312FPG Diffuse Mode Plastic Fiber 100 Excess Gain Excess Gain Curve for SM312FPB Beam Pattern for SM312FPB PBT46U Fiber 10 0.12 in 0 4 mm 0.15 in 8 mm 0.30 in 12 mm 0.45 in 16 mm 0.60 in 1 .1 mm .004 in 20 mm 0.75 in Distance 1 mm .04 in 10 mm .4 in 100 mm 4 in Distance Dimensions Cabled Models (Suffix E, EL, EPD, R, RL, RPD, LV, LVAG, LP, LPC, D, C, C2, CV, CV2, CVG, CV2G, CVB, CV2B, CVW ) 3.2 mm (0.13”) Divergent Diffuse Models (Suffix DBZ and W) 3 mm dia Clearance (2) 12.2 mm (0.48”) Bezel 30.7 mm (1.21”) 24.1 mm (0.95”) 18.0 mm (0.71”) 3 mm dia Clearance (2) M18 × 1 × 15 mm Thread (Mounting nut supplied) 2 m (6.5’) Cable Mounting peg (6.3 mm dia × 2.5 mm) 19.1 mm (0.75”) 39.1 mm (1.54”) 53.3 mm (2.10”) 13.2 mm (0.52”) 27.4 mm (1.08”) Glass Fiber Models (Suffix F, FV, FVB, FVG, FVW) Plastic Fiber Models (Suffix FP, FPB, FPG, FPH, FPW) 3.2 mm (0.13”) M18 x 1 x 19 mm Thread (Mounting Nut Supplied) 30.7 mm (1.21”) 12.2 mm (0.48”) 24.1 mm (0.95”) 3 mm dia clearance (2) Fiber Optic Fitting Fiber Optic Fitting 2 m (6.5’) Cable Mounting Peg (6.3 mm dia × 2.5 mm) 57.5 mm (2.27") 22.3 mm (0.88”) 19.1 mm (0.75”) 31.2 mm (1.23") 42.1 mm (1.66”) 10 www.bannerengineering.com - Tel: + 1 888 373 6767 16.2 mm (0.64”) P/N 69943 Rev. G MINI-BEAM® DC Voltage Series Sensor QD Models 12 mm Thread Quick-disconnect 20.0 mm (0.79”) Accessories 4-Pin Euro-Style Cordsets 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length Style MQDC-406 2 m (6.56 ft) MQDC-415 5 m (16.4 ft) MQDC-430 9 m (29.5 ft) MQDC-450 15 m (49.2 ft) MQDC-406RA 2 m (6.56 ft) MQDC-415RA 5 m (16.4 ft) MQDC-430RA 9 m (29.5 ft) Dimensions 44 Typ. Straight M12 x 1 ø 14.5 3 4 1 = Brown 2 = White 3 = Blue 4 = Black 30 Typ. [1.18"] 15 m (49.2 ft) 2 1 32 Typ. [1.26"] Right-Angle MQDC-450RA Pinout (Female) M12 x 1 ø 14.5 [0.57"] Mounting Brackets SMB46L • Right-angle • L bracket • 14-ga. 316 stainless steel SMB46S • Right-angle • S bracket • 14-ga. 316 stainless steel 54 65 Hole center spacing: A = 16.0 Hole center spacing: A = 16.0 A SMB46U • Right-angle • U bracket for sensor protection • 14-ga. 316 stainless steel 70 B 54 Hole center spacing: A = 16.0 Hole size: A = 16.5 × 18.7, B = 34.0 × 13.0 A 65 SMB18A • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware 65 16 54 Hole size: A = 16.5 × 18.7, B = 34.0 × 10.0 Hole size: A = 16.5 × 18.7 27 27 A B 30 C A 41 B 46 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 P/N 69943 Rev. G www.bannerengineering.com - Tel: + 1 888 373 6767 11 MINI-BEAM® DC Voltage Series Sensor SMB18AFA.. • Protective, swivel bracket with tilt and pan movement for precision adjustment • Easy sensor mounting to extruded rail T-slots • Metric and inch size bolts available • Mounting hole for 18 mm sensors 44 51 ø18.1 3/8-16 UNC X 2 in. SMB18Q • Right-angle flanged bracket • 18 mm sensor mounting hole • 12-ga. stainless steel 46 A 41 B ø19.8 51 C 30 Hole size: B = ø 18.1 Model Bolt Thread (A) SMB18AFA 3/8 - 16 × 2 in SMB18AFAM10 M10 - 1.5 × 50 SMB18SF • 18 mm swivel bracket with M18 × 1 internal thread • Black thermoplastic polyester • Stainless steel swivel locking hardware included Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 19.0 51 B 42 25 A SMB18UR • 2-piece universal swivel bracket • 300 series stainless steel • Stainless steel swivel locking hardware included • Mounting hole for 18 mm sensor C A 137 B 64 Hole center spacing: A = 36.0 Hole size: A = ø 5.3, B = ø 18.0 SMB312PD • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware 42 Hole center spacing: A = 25.4, B = 46.7 Hole size: B = 6.9 × 32.0, C = ø 18.3 A 46 B 41 SMBAMS18RA • Right-angle SMBAMS series bracket with 18 mm hole • Articulation slots for 90+° rotation • 12-ga. (2.6 mm) cold-rolled steel C 32 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17 × 4.6, C = ø 18.5 40 C 48 A 45 B Hole center spacing: A = 26.0, A to B = 13.0 Hole size: A = 26.8 × 7.0, B = ø 6.5, C = ø 19.0 Note: Not for use with plastic fiber optic sensors SMBAMS18P • Flat SMBAMS series bracket with 18 mm hole • Articulation slots for 90+° rotation • 12-ga. (2.6 mm) cold-rolled steel C 78 A SMB30SK • Flat-mount swivel bracket with extended range of motion • Black reinforced thermoplastic polyester and 316 stainless steel • Stainless steel swivel locking hardware included A 68 B 57 78 B 45 Hole center spacing: A = 26.0, A to B = 13.0 Hole size: A = 26.8 × 7.0, B = ø 6.5, C = ø 19.0 12 Hole center spacing: A = 50.8 Hole size: A = ø 7, B = ø 18 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 69943 Rev. G MINI-BEAM® DC Voltage Series Sensor SMB3018SC • 18 mm swivel side or barrelmount bracket • Black reinforced thermoplastic polyester • Stainless steel swivel locking hardware included 67 B 59 29 67 B 58 29 A Hole center spacing: A = 50.8 Hole size: A = ø 7.0, B = ø 18.0 A Hole center spacing: A = 50.8, B = 24.1 Hole size: A = ø 7, B = ø 7.6 SMB312S • SMB30SUS • Side-mount swivel with extended range of motion • Black reinforced thermoplastic polyester • Stainless steel swivel locking hardware included SMB312B B Stainless steel 2-axis, sidemount bracket 46 • • C Stainless steel 2-axis, bottom-mount bracket Includes mounting foot 24 A A 32 20 51 23 B C A = diam. 6.9, B = 4.3 × 10.5, C = 3.1 × 15.2 A = 4.3 × 7.5, B = diam. 3, C = 3 × 15.3 Miscellaneous Accessories and Replacement Parts MINI-BEAM lens assemblies are field-replaceable. Replacement Lens Model Replacement Lens for MINI-BEAM Model Possible Sensing Mode or Range Changes UC-300AG LVAG LV to LVAG UC-300BZ W and DBZ D to DBZ and F to DBZ UC-300C..7 C, CV, and CVG CV2 to CV UC-300C2 C2 and CV2 CV to CV2 UC-300E E and R - UC-300EL EL and RL Extends the range of the E/R models UC-300EPD EPD - F and FV D to F and DBZ to F FP (old style) - UC-300F UC-300FP UC-300FP2 UC-300L UC-300LP UC-300RPD FP - LV and D F to D, LVAG to LV, and DBZ to D LP - RPD - MINI-BEAM right-angle reflectors are useful for tight sensing locations. These reflectors significantly decrease excess gain. Right-Angle Reflectors RAR300SM • Side mount right-angle reflector • Profile dimension of 14 mm (0.56 inches) in the direction of the scan • Use with MINI-BEAM models 31E, EL, R, RL; and 312D, DBZ, LV, W P/N 69943 Rev. G 30.48 mm [1.2”] 55.7 mm [2.2”] 45° 42.4 mm [1.67”] 12.7 mm [0.5”] 24.13 mm [0.95”] 3.18 mm dia [0.125”] RAR300FM • Front mount right-angle reflector that attaches directly to the threaded barrel of most MINIBEAMs • Profile dimension of 34 mm (1.35 inches) in the direction of the scan • Use with MINI-BEAM models 31E, EL, R, RL; and 312D, LV www.bannerengineering.com - Tel: + 1 888 373 6767 30.5 mm [1.2”] 24.13 mm [0.95”] 37.6 mm [1.48”] 45° 4.45 mm [0.18”] dia 3.18mm (2) [0.125’”] 17.5 mm [0.69”] 32.5 mm [1.28”] 13 MINI-BEAM® DC Voltage Series Sensor Opposed-mode MINI-BEAM sensors may be fitted with apertures that narrow or shape the effective beam of the sensor to more closely match the size or profile of the object to be sensed, for example, the use of “line” (or “slit”) apertures for sensing wire or thread. Each model contains 20 apertures. MINI-BEAM Opposed-Mode Aperture Kits Model Description Qty Circular AP31-020 0.5 mm dia. 20 AP31-040 1.0 mm dia. 20 AP31-100 2.5 mm dia. 20 AP31-020H 0.5 x 6.4 mm 20 AP31-040H 1.0 x 6.4 mm 20 AP31-100H 2.5 x 6.4 mm 20 AP31-200H 5.1 x 6.4 mm 20 Horizontal Slot Vertical Slot AP31-020V 0.5 x 12.7 mm 20 AP31-040V 1.0 x 12.7 mm 20 AP31-100V 2.5 x 12.7 mm 20 AP31-200V 5.1 x 12.7 mm 20 AP31-DVHX2 2 of each aperture Kit 2 Range (Standard Group I and II Sensor Pairs) Aperture on Both Emitter and Received Aperture on Receiver Only Aperture Range (Group I Sensor Pairs with UC-300EL Upper Covers Substituted) Group I Sensors Group II Sensors Group I Sensors Group II Sensors Aperture on Both Emitter and Received Aperture on Receiver Only AP31-020 89 mm 102 mm 457 mm 1.5 m 127 mm 914 mm AP31-040 330 mm 457 mm 940 mm 3.2 m 183 mm 2m AP31-100 1.5 m 3m 2.5 m 8.2 m 2.1 m 5.8 m AP31-020H 406 mm 1.8 m 965 mm 9.1 m 864 mm 3.4 m AP31-040H 914 mm 4m 1.8 m 12.5 m 1.8 m 5.2 m AP31-100H 2.3 m 10.4 m 2.9 m 20.7 m 5.2 m 8.5 m AP31-200H 2.8 m 21.3 m 3m 24.4 m 8.2 m 11 m AP31-020V 457 mm 1.7 m 1m 8.2 m 1m 3.4 m AP31-040V 1m 5.5 m 1.8 m 15.8 m 2.1 m 5.5 m AP31-100V 2.3 m 10.7 m 2.9 m 22.9 m 6.1 m 8.5 m AP31-200V 2.8 m 22.9 m 3m 25.9 m 8.5 m 11 m GROUP I Emitter/ Receiver Pairs (see Range): SM31E/SM31R GROUP II Emitter/ Receiver Pairs (see Range): SM31EL/SM31RL Example: A MINI-BEAM sensor pair is in Group I. With an AP31-040 circular aperture on the receiver only, range is 940 mm (37 in). With AP31-040 apertures on both emitter and receiver, range is 330 mm (13 in). Group I range with AP31-040 apertures and UC-300EL upper covers on both units is 183 mm; range with receiver aperture only is 2 m (80 in). 14 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 69943 Rev. G MINI-BEAM® DC Voltage Series Sensor Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
SM312LVQD-50939 价格&库存
很抱歉,暂时无法提供与“SM312LVQD-50939”相匹配的价格&库存,您可以联系我们找货
SM312LVQD-50939
  • 1+1625.749471+210.31552
库存:5
