Q12AB6FF30Q
Q12AB6FF30Q
    BANNER(邦纳)
    PHOTO SEN 30MM LO BIPOLAR
Q12AB6FF30Q 数据手册
WORLD-BEAM® Q12 Series Sensor Datasheet Miniature self-contained photoelectric sensors in universal housing • • • • • • • • • • Standard Model Bright, visible red (640 nm) light source Standard models available with 4-wire 2 m (6.5 ft) or 9 m (30 ft) cable or 3 or 4wire 150 mm (6 in) pigtail with Pico-style M8 threaded connector Solid-state, bipolar outputs: one current sourcing (PNP) and one current sinking (NPN) standard on 4-wire models Single output solid-state PNP or NPN standard on Q3 models Light Operate (LO) or Dark Operate (DO), depending on model Models available with PFA chemical-resistant jacket (1200 psi washdown rated) for use in harsh environments Compact 8 mm (0.31 in) housing mounts almost anywhere Crosstalk avoidance circuitry for applications with multiple sensors LED status indicators for Power ON, Output Overload, Signal Received, and Marginal Signal Advanced ASIC technology makes sensor resistant to optical and electrical noise source Chemical-Resistant Model WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Chemical-Resistant Models Model1 Sensing Mode 640 nm Visible Red Range Q126ECR Output N/A Q12AB6RCR Bipolar LO 1.5 m (4.9 ft) OPPOSED Q12RB6RCR Bipolar DO Effective Beam: 5.7 mm (0.22 in) Performance based on use of 90% reflectance white test card. Q12AB6FF15CR Q12RB6FF15CR Q12AB6FF30CR FIXED-FIELD VISIBLE RED 640 nm Visible Red Q12RB6FF30CR Q12AB6FF50CR Q12RB6FF50CR Bipolar LO 13 mm (0.5 in) cutoff; 8 mm (0.3 in) focus Bipolar DO 28 mm (1.1 in) cutoff; 14 mm (0.6 in) focus Bipolar DO 48 mm (1.9 in) cutoff; 14 mm (0.6 in) focus Bipolar DO Bipolar LO Bipolar LO 1 Only standard 2 m (6.5 ft) cables are available for chemical-resistant models. Original Document 119223 Rev. M 7 April 2020 119223 WORLD-BEAM® Q12 Series Sensor Standard Models Model2 Sensing Mode Q126E (emitter) 640 nm Visible Red Q126EQ3 (emitter) Range 2m (6.5 ft) Connection Output 2 m (6.5 ft) cable N/A 150 mm (6 in) cable with a 3-pin M8/ Pico-style QD N/A Q12AB6R 2 m (6.5 ft) cable Q12RB6R Q12AP6RQ3 OPPOSED Effective Beam: 5.7 mm (0.22 in) 2m (6.5 ft) Q12RP6RQ3 Q12AN6RQ3 1 PNP LO 150 mm (6 in) cable with a 3-pin M8/ Pico-style QD Q12RN6RQ3 Q12AB6LP 2 m (6.5 ft) cable Q12AP6LPQ3 POLAR RETRO 640 nm Visible Red Q12RP6LPQ3 150 mm (6 in) cable with a 3-pin M8/ Pico-style QD Q12AN6LPQ3 Bipolar LO Bipolar DO 1 PNP DO 1 NPN LO 1 NPN DO Q12AB6LV 2 m (6.5 ft) cable Q12RB6LV Q12AP6LVQ3 640 nm Visible Red 1 NPN LO 1 PNP LO 1 m (40 in) 3 Q12RN6LPQ3 RETRO 1 PNP DO 1 NPN DO Q12RB6LP P Bipolar LO Bipolar DO 1.5 m (59 in) 3 Q12RP6LVQ3 Q12AN6LVQ3 Bipolar LO Bipolar DO 1 PNP LO 150 mm (6 in) cable with a 3-pin M8/ Pico-style QD Q12RN6LVQ3 1 PNP DO 1 NPN LO 1 NPN DO Performance based on use of 90% reflectance white test card. Q12AB6FF15 Q12RB6FF15 Q12AP6FF15Q3 Q12RP6FF15Q3 Q12AN6FF15Q3 2 m (6.5 ft) cable 15 mm (0.6 in) cutoff; 10 mm (0.4 in) focus 1 PNP LO 150 mm (6 in) cable with a 3-pin M8/ Pico-style QD Q12RN6FF15Q3 Q12AB6FF30 Q12AP6FF30Q3 640 nm Visible Red Q12RP6FF30Q3 2 m (6.5 ft) cable 30 mm (1.2 in) cutoff; 16 mm (0.63 in) focus Q12AN6FF30Q3 150 mm (6 in) cable with a 3-pin M8/ Pico-style QD 2 m (6.5 ft) cable Q12RB6FF50 Q12AN6FF50Q3 50 mm (2 in) cutoff; 16 mm (0.63 in) focus 1 PNP DO 1 NPN LO Bipolar LO Bipolar DO 1 PNP LO 150 mm (6 in) cable with a 3-pin M8/ Pico-style QD Q12RN6FF50Q3 2 Bipolar LO Bipolar DO 1 NPN DO Q12AB6FF50 Q12RP6FF50Q3 1 NPN LO 1 PNP LO Q12RN6FF30Q3 Q12AP6FF50Q3 1 PNP DO 1 NPN DO Q12RB6FF30 FIXED-FIELD VISIBLE RED Bipolar LO Bipolar DO 1 PNP DO 1 NPN LO 1 NPN DO To order the 9 m (30 ft) cable model, add the suffix W/30 to the model number. For example, Q126E W/30. To order the 150 mm (6 in) cable with a 4-pin M8/Pico-style (M8 threaded) QD model, add the suffix Q to the model number. For example, Q126EQ. • To order the 150 mm (6 in) cable with a 4-pin M12/Euro-style QD model, add the suffix Q5 to the model number. For example Q126EQ5. 3 Retroreflective range is specified using one model BRT-60X40C retroreflector. Actual sensing range may be more or less than specified, depending upon efficiency and reflective area of the retroreflector(s) used. 2 • • www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 119223 Rev. M WORLD-BEAM® Q12 Series Sensor Indicator Features 1 - Amber and green LEDs • Green on: power to sensor is on • Amber on: received signal • Amber flashing: marginal signal 1 Chemical-Resistant models: LEDs are visible through translucent PFA jacket. Rated to 1200 psi washdown. Wiring Emitters have no connection to black and white. CAUTION: Observe proper ESD precautions (grounding) when connecting QD models. Bipolar Models, Light Operate Emitters bn (1) brown wh (2) 10–30 V DC blue + 10–30 V dc – bu (3) + bk (4) – – 10–30 V dc + bn (1) bk (4) Load PNP Models, Dark Operate + 10–30 V dc – bn (1) Load bk (4) NPN Models, Dark Operate bu (3) + 10–30 V dc – bu (3) Load – 10–30 V dc + bn (1) bk (4) Load Load Load 3-pin M8/Pico-style Male QD 1 = Brown 2 = White 3 = Blue 4 = Black bu (3) Load bu (3) Key NPN Models, Light Operate + 10–30 V dc – bu (3) bk (4) bn (1) bk (4) bn (1) Load Bipolar Models, Dark Operate wh (2) PNP Models, Light Operate 4 3 1 4-pin M8/Pico-style Male QD 2 4 1 3 4-pin M12/Euro-style Male QD 2 3 1 4 Specifications Supply Voltage and Current 10 to 30 V dc (10% maximum ripple) at 20 mA maximum current Sensing Beam 640 nm visible red Supply Protection Circuitry Protected against reverse polarity and transient voltages P/N 119223 Rev. M Output Configuration Bipolar (1 NPN and 1 PNP) solid-state output or Single output (PNP or NPN), LO or DO, depending on model Repeatability 125 microseconds Switching Frequency Opposed Mode: 385 Hz LP/LV Mode: 715 Hz FF Mode: 590 Hz www.bannerengineering.com - Tel: + 1 888 373 6767 3 WORLD-BEAM® Q12 Series Sensor Output Protection Circuitry Protected against false pulse on power-up, short-circuit protected Output Response Time Opposed Mode: 1.3 ms ON; 900 µs OFF LP/LV Mode: 700 µs ON/OFF FF Mode: 850 µs ON/OFF NOTE: 120 ms delay on power-up; outputs do not conduct during this time. Indicators One Yellow and one Green LED (see Figure 1) Construction Polarized Retro Models: Thermoplastic elastomer housing with glass lens All Other Standard Models: Thermoplastic elastomer housing with polycarbonate lens Chemical-Resistant Models: Housing encased in PFA jacket; cable encased in 3/16 in O.D. PFA tubing Connections Standard Models: 2 m (6.5 ft) or 9 m (30 ft) attached PVC cable, or 150 mm (6 in) pigtail with M8 or M12 threaded connection, depending on the model ordered Chemical-Resistant Models: 2 m (6.5 ft) cable encased in 3/16 in O.D. PFA tubing Environmental Rating Standard Models: IEC IP67 Chemical-Resistant Models: IEC IP67 (NEMA6) and PW12 1200 psi washdown per NEMA ICS5, Annex F-2002 Output Ratings OFF-state leakage current: NPN: 10 µA PNP: 10 µA ON-state saturation voltage: NPN: 2 V at 50 mA PNP: 2 V at 50 mA Vibration and Mechanical Shock All models meet MIL-STD-202F, Method 201A (Vibration: 10 Hz to 60 Hz maximum, 0.06 inch (1.52 mm) double amplitude, 10G maximum acceleration) requirements. Also meets IEC 60947-5-2 (Shock: 30G 11 ms duration, half sine wave) requirements. Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Conditions Operating Temperature: –20 °C to +55 °C (–4 °F to +131°F) Storage Temperature: –30 °C to +75 °C (–22 °F to +167 °F) 95% at +50 °C maximum relative humidity (non-condensing) Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Certifications (Chemical-resistant models are not UR/UL approved.) Dimensions 12.4 mm (0.49") M3 mounting screws included 8.0 mm (0.31") 15.0 mm (0.59") 5.1 mm (0.20") 23.1 mm (0.91") 22 mm (0.86") 3.5 mm (0.14") 3.4 mm (0.13") Polarized Retro Models 4.7 mm (0.19") Emitter (opposed mode models) Emitter (all other models) Ø 3 mm (0.12") max. torque 0.9 Nm (8 in-lbf) Figure 1. Standard Models 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 119223 Rev. M WORLD-BEAM® Q12 Series Sensor 22.6 mm (0.89") 8.1 mm (0.32") 12.5 mm (0.49") Mounting hardware not included 5.9 mm (0.23") 3.2 mm (0.13") Ø 3.4 mm (0.13") max. torque* 0.9 Nm (8 in-lbf) * When mounting by running a screw through both flanges without support between the flanges, the max. torque applied should be 0.1 Nm (1 in-lbf). 6.2 mm (0.25") Emitter (opposed mode models) 28.8 mm (1.13") 15.0 mm (0.59") 10.7 mm (0.42") 4.7 mm (0.18") 8.6 mm (0.34") 5.5 mm (0.22") Emitter (all other models) 4.8 mm (0.19") O.D. PFA Tube 2 m (6.5') Ø12.5 mm (0.49") Figure 2. Chemical-Resistant Models Performance Curves - Opposed Mode Excess Gain Beam Pattern 1000 Q12.. EXCESS GAIN Opposed Mode Q12.. 30 mm 1.2" Opposed Mode 20 mm 100 0.8" 10 mm 0.4" 0 Standard 0 Chemical-Resistant 10 mm 10 0.4" 20 mm 0.8" 30 mm Standard 1.2" Chemical-Resistant 1 0.01 m 0.033' 0 0.1 m 0.33' 1m 3.3' 0.5 m 20" 10 m 33' 1m 40" 1.5 m 60" 2m 80" 2.5 m 100" DISTANCE DISTANCE Performance Curves - Retroreflective Mode Performance is based on the use of a model BRT-60X40C retroreflector. Polarized Retroreflective Excess Gain Retroreflective Beam Pattern Excess Gain EXCESS GAIN 100 Q12.. Q12.. 9 mm Polarized Retro 6 mm 0.2" 3 mm 0.1" 0 0 3 mm 10 0.1" 6 mm 0.2" 9 mm 0.3" 0 0.1 m 0.33' 1m 3.3' DISTANCE P/N 119223 Rev. M 10 m 33' 0.3" 0.3 m 12" 0.6 m 24" 0.9 m 35" DISTANCE 1.2 m 47" 1.5 m 59" Retroreflective EXCESS GAIN Q12.. Polarized Retro 1 0.01 m 0.03' Beam Pattern 1000 1000 Q12.. 30 mm 100 Retroreflective 0.8" 10 mm 0.4" 0 0 10 10 mm 0.4" 20 mm 0.8" 30 mm 1 0.01 m 0.03' 1.2" 0 0.1 m 0.33' 1m 3.3' 10 m 33' 1.2" 20 mm 0.3 m 12" 0.6 m 24" 0.9 m 35" 1.2 m 47" 1.5 m 59" DISTANCE DISTANCE www.bannerengineering.com - Tel: + 1 888 373 6767 5 WORLD-BEAM® Q12 Series Sensor Performance Curves - Fixed-Field Focus and spot sizes are typical. Performance based on use of 90% reflectance white test card.* Fixed Field -- 15 mm Fixed Field -- 30 mm Fixed Field -- 50 mm 1000 1000 1000 Standard 10 100 Standard 10 100 Standard 10 Chemical-Resistant Chemical-Resistant Chemical-Resistant 100 mm 4.0" EXCESS GAIN EXCESS GAIN EXCESS GAIN 100 10 mm 0.4" Fixed-Field Mode Fixed-Field Fixed-Field 1 1 mm 0.04" Q12..FF50 Q12..FF30 Q12..FF15 1 1 mm 0.04" 1000 mm 40.0" 10 mm 0.4" 100 mm 4.0" 1 1 mm 0.04" 1000 mm 40.0" 100 mm 4.0" 1000 mm 40.0" DISTANCE DISTANCE DISTANCE Standard Models: Standard Models: 10 mm 0.4" Standard Models: • Ø 0.4 mm spot size at 10 mm focus • Ø 0.5 mm spot size at 16 mm focus • Ø 0.5 mm spot size at 16 mm focus • Ø 1.5 mm spot size at 15 mm cutoff • Ø 3.0 mm spot size at 30 mm cutoff • Ø 6.5 mm spot size at 50 mm cutoff Chemical-Resistant Models: • Ø 0.4 mm spot size at 8 mm focus • Ø 1.5 mm spot size at 13 mm cutoff Chemical-Resistant Models: • Ø 0.5 mm spot size at 14 mm focus • Ø 3.0 mm spot size at 28 mm cutoff * Using 18% gray test card: cutoff distance will be 95% of value shown. Using 6% black test card: cutoff distance will be 90% of value shown. * Using 18% gray test card: cutoff distance will be 80% of value shown. Using 6% black test card: cutoff distance will be 60% of value shown. * Using 18% gray test card: cutoff distance will be 90% of value shown. Using 6% black test card: cutoff distance will be 80% of value shown. Chemical-Resistant Models: • Ø 0.5 mm spot size at 14 mm focus • Ø 6.5 mm spot size at 48 mm cutoff * Using 18% gray test card: cutoff distance will be 70% of value shown. Using 6% black test card: cutoff distance will be 50% of value shown. Accessories Cordsets 3-Pin Threaded M8/Pico-Style Cordsets Model Length PKG3M-2 2.035 m (6.68 ft) PKG3M-5 5.035 m (16.51 ft) PKG3M-7 7.035 m (23.08 ft) PKG3M-9 9.035 m (29.64 ft) PKG3M-10 10.035 m (32.92 ft) PKW3M-2 2 m (6.56 ft) PKW3M-5 5 m (16.40 ft) Style Dimensions 35 Typ. Straight ø 9.5 M8 x 1 4 1 3 28 Typ. 20 Typ. Right-Angle PKW3M-9 Pinout (Female) 1 = Brown 3 = Blue 4 = Black 9 m (29.53 ft) M8 x 1 ø 9.5 6 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 119223 Rev. M WORLD-BEAM® Q12 Series Sensor 4-Pin Threaded M8/Pico-Style Cordsets—Single Ended Model Length PKG4M-2 2 m (6.56 ft) PKG4M-5 5 m (16.4 ft) Style Dimensions Pinout (Female) 35 Typ. Straight PKG4M-9 9 m (29.5 ft) PKW4M-2 2 m (6.56 ft) PKW4M-5 5 m (16.4 ft) ø 9.5 2 1 3 28 Typ. 1 = Brown 2 = White 3 = Blue 4 = Black 20 Typ. Right Angle PKW4M-9 4 M8 x 1 9 m (29.5 ft) M8 x 1 ø 9.5 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 3 4 1 = Brown 2 = White 3 = Blue 4 = Black 30 Typ. [1.18"] 15.2 m (50 ft) 2 1 32 Typ. [1.26"] Right-Angle MQDC-450RA Pinout (Female) M12 x 1 ø 14.5 [0.57"] Brackets SMBQ12T • Right-angle bracket 20-ga. 300 series stainless • steel SMBQ12A • Adjustable right-angle bracket 20-ga. 300 series stainless • steel 4X Ø3.3 2X Ø3.2 34 11 Ø3.3 34 34 11 Hole center spacing: A to B = 7.6 Hole center spacing: A to B = 7.6 Hole size: A = 3.5 x 8.1, B=ø 3.2 Hole size: A = 3.5 x 8.1, B=ø 3.2 Ø3.2 34 Sensor Status Indicators S15L Series In-Line Sensor Status Indicator Model Input Type S15LGYPQ PNP LED Color Dimensions NPN P/N 119223 Rev. M Input Active = Yellow Male 57.8 [2.27] Power ON = Green S15LGYNQ Female 27.9 [1.1] 15.0 [0.59] 1 4 www.bannerengineering.com - Tel: + 1 888 373 6767 2 3 2 3 Wiring 1 = Brown, 10 to 30 V DC 2 = White 4 3 = Blue, dc common 4 = Black, Sensor Input 1 7 WORLD-BEAM® Q12 Series Sensor Apertures Opposed-mode sensors (standard models only) may be fitted with apertures to narrow or shape the sensor’s effective beam to more closely match the size or profile of the objects being sensed. A common example is the use of “line” (or “slot”) type apertures to sense thread. Note: The use of apertures will reduce the sensing range (see table below). Model Description Pieces Reduced Sensor Range (Two Apertures Used) Circular APQ12-.5 0.5 mm (0.02 in) diameter 10 60 mm (2.4 in) APQ12-1 1 mm (0.04 in) diameter 10 190 mm (7.5 in) APQ12-1.5 1.5 mm (0.06 in) diameter 10 400 mm (15.7 in) APQ12-2 2 mm (0.08 in) diameter 10 725 mm (28.5 in) APQ12-.5H 0.5 mm (0.02 in) 10 350 mm (13.8 in) APQ12-1H 1 mm (0.04 in) 10 725 mm (28.5 in) APQ12-.5V 0.5 mm (0.02 in) 10 450 mm (17.7 in) APQ12-1V 1 mm (0.04 in) 10 900 mm (35.4 in) 2000 mm (78.7 in) Horizontal Slot Vertical Slot Protective Jacket APQ12-4S 4 mm (0.16 in) square 10 APKQ12 Kit containing two of each aperture above 18 — Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. FCC Part 15 and CAN ICES-3 (B)/NMB-3(B) This device complies with part 15 of the FCC Rules and CAN ICES-3 (B)/NMB-3(B). Operation is subject to the following two conditions: 1. 2. This device may not cause harmful interference, and This device must accept any interference received, including interference that may cause undesired operation. This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules and CAN ICES-3 (B)/NMB-3(B). These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: • Reorient or relocate the receiving antenna. • Increase the separation between the equipment and receiver. • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. • Consult the manufacturer. © Banner Engineering Corp. All rights reserved
Q12AB6FF30Q
物料型号: - 标准型号:Q126E、Q126EQ3、Q12AB6R、Q12RB6R、Q12AP6RQ3、Q12RP6RQ3、Q12AN6RQ3、Q12RN6RQ3 - 化学抗性型号:Q126ECR、Q12AB6FF15CR、Q12RB6FF15CR、Q12AB6FF30CR、Q12RB6FF30CR、Q12AB6FF50CR、Q12RB6FF50CR - 极化反射型号:Q12AB6LP、Q12RB6LP、Q12AP6LPQ3、Q12RP6LPQ3、Q12AN6LPQ3、Q12RN6LPQ3 - 反射型号:Q12AB6LV、Q12RB6LV、Q12AP6LVQ3、Q12RP6LVQ3、Q12AN6LVQ3、Q12RN6LVQ3 - 固定场型号:Q12AB6FF15、Q12RB6FF15、Q12AP6FF15Q3、Q12RP6FF15Q3、Q12AN6FF15Q3、Q12RN6FF15Q3、Q12AB6FF30、Q12RB6FF30、Q12AP6FF30Q3、Q12RP6FF30Q3、Q12AN6FF30Q3、Q12RN6FF30Q3、Q12AB6FF50、Q12RB6FF50、Q12AP6FF50Q3、Q12RP6FF50Q3、Q12AN6FF50Q3、Q12RN6FF50Q3
器件简介: - WORLD-BEAM® Q12系列传感器是小型自包含光电传感器,具有多种功能和配置选项。
引脚分配: - 发射器:棕色(+)、蓝色(-) - 双极性LO模型:棕色(+)、白色(2)、蓝色(1)、黑色(4) - PNP LO模型:蓝色(3)、棕色(1)、黑色(4) - NPN LO模型:同PNP LO - 双极性DO模型:棕色(+)、白色(2)、蓝色(1)、黑色(4) - PNP DO模型:同PNP LO - NPN DO模型:蓝色(3)、棕色(1)、黑色(4)
参数特性: - 供电电压:10到30伏直流电,最大纹波10% - 工作电流:最大20毫安 - 感应光束:640纳米可见红光 - 输出配置:双极性(1个NPN和1个PNP)固态输出或单输出(PNP或NPN),取决于型号 - 重复性:125微秒 - 开关频率:对射模式385赫兹,LP/LV模式715赫兹,FF模式590赫兹
功能详解: - 提供了多种工作模式,包括对射、极化反射、反射和固定场模式。 - 具有LED状态指示,包括电源、输出过载、信号接收和边缘信号。 - 高级ASIC技术使传感器对光学和电气噪声源具有抗性。
应用信息: - 适用于多种工业应用,包括物体检测、自动化控制等。
封装信息: - 标准型号:IEC IP67 - 化学抗性型号:IEC IP67 (NEMA6) 和 PW12 1200 psi洗刷,符合NEMA ICS5, Annex F-2002
Q12AB6FF30Q 价格&库存
很抱歉,暂时无法提供与“Q12AB6FF30Q”相匹配的价格&库存,您可以联系我们找货
Q12AB6FF30Q
  • 1+1190.080101+154.65395
