QS303E
QS303E
    BANNER(邦纳)
    PHOTO SEN EMITTER 60M
QS303E 数据手册
WORLD-BEAM® QS30 – Universal Voltage Quick Start Guide Self-Contained, Photoelectric Sensors in Universal-Style Housing For complete technical information about this product, including installation instructions, application requirements and guidelines, EU Declaration of Conformity, technical specifications, and accessories, see www.bannerengineering.com and search 119166. WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the selfchecking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or deenergized sensor output condition. Models Model Sensing Mode OPPOSED P Range LED Output Infrared, 875 nm QS303E Emitter 60 m (200 ft) QS30VR3R Receiver 60 m (200 ft) - 8 m (26 ft)2 Visible red, 630 nm QS30VR3LP Effective Beam: 18 mm (0.7 in) POLAR RETRO - SPDT FIXED-FIELD QS30VR3FF200 200 mm (7.9 in) QS30VR3FF400 400 mm (15.7 in) QS30VR3FF600 600 mm (23.6 in) Visible red, 680 nm Wiring Diagrams Cabled Emitters Other Cabled Models Cable and QPMA hookups are functionally identical. bn bu bn 24 - 250V ac (50/60 Hz) 12 - 250V dc bu 24 - 250V ac (50/60 Hz) 12 - 250V dc wh N.C. ye bk C N.O. 1 Standard 2 m (6.5 ft) cable models are listed. • For 9 m (30 ft) integral cable: add suffix "W/30” (for example, QS303E W/30). • 5-pin Micro-style 152 mm (6 in) cable: add "QPMA" (for example, QS303EQPMA). 2 Range is measured using a model BRT-84 retroreflector. Original Document 119168 Rev. D 15 December 2016 119168 WORLD-BEAM® QS30 – Universal Voltage Specifications Supply Voltage Universal Voltage: 24 V to 250 V ac (50 Hz/60 Hz) or 12 V to 250 V dc (1.0 watt maximum) Operating Conditions −20 °C to +70 °C (−4 °F to +158 °F) 95% at +50 °C maximum relative humidity (non-condensing) Supply Protection Circuitry Protected against transient voltages Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Output Configuration SPDT (Single-Pole Double-Throw) electromechanical relay output (all models except emitters) Output Rating Max. Switching Power (resistive load): 150 W, 1250 VA Max. Switching Voltage (resistive load): 250 V ac; 125 V dc Max. Switching Current (resistive load): 5 A at 250 V ac; 5 A at 30 V dc derated to 200 mA at 125 V dc Min. Voltage and Current: 5 V dc, 10 mA Mechanical life of relay: 50 million operations Electrical life of relay at full resistive load: 100,000 operations Output Response 15 milliseconds ON and OFF NOTE: 100 millisecond delay on power-up; output does not conduct during this time. Cutoff Point Tolerance Fixed-Field Only: ± 5% of nominal cutoff distance Indicators Two LEDs (Green and Amber) on top of sensor Green ON: power to sensors is ON Amber ON: light sensed Amber flashing: excess gain marginal (1 to 1.5 times) in light condition Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Certifications Large, oval LED indicator on sensor back (except emitters) Amber ON: normally open output is conducting Construction ABS housing, rated IEC IP67, NEMA 6; acrylic lens cover Connections 2 m (6.5 in) or 9 m (30 in) 5-wire PVC cable 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 119168 Rev. D WORLD-BEAM® QS30 – Universal Voltage Dimensions Hardware included: (2) M3 x 0.5 x 28 stainless steel machine screws, nuts and washers 22.0 mm (0.87") 54.3 mm (2.14") 1.4 mm (0.05") 44.0 mm (1.73") 8.9 mm (0.35") M30 x 1.5 Thread max. torque 6 Nm (53 in lbs) with included 30 mm mounting nut 51.1 mm (2.01") Amber and Green LEDs Amber LED Output Indicator 33.0 mm (1.30") 5.5 mm (0.22") 2 x ø3.3 mm (0.13") max. torque 0.7 Nm (6 in lbs) 12.5 mm (0.47") 16 mm (0.63") Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
QS303E 价格&库存
很抱歉,暂时无法提供与“QS303E”相匹配的价格&库存,您可以联系我们找货
