Q10 Series Sensors
Datasheet
Miniature Self-Contained DC Photoelectric Sensors
Self-contained dc sensors in miniature right-angle housings; only
11 mm (0.43 in) thick
Epoxy-encapsulated circuitry; IP54 (NEMA5) construction;
hermetically-sealed optics
1.8 m (70 in) opposed range or 0.5 m (20 in) diffuse range
Diffuse models have sensitivity adjustment
Choose models for light operate or dark operate; choose either
NPN (sinking) or PNP (sourcing) output models
WARNING: Not To Be Used for Personnel Protection
Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death.
This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety
applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output
condition.
Models
Note: Models with a quick disconnect require a mating cordset.
Table 1: Q10 Opposed Mode Emitter (E) and Receiver (R)
Models
Range
Cable
Supply Voltage
Q106E
2 m (6.5 in)
Q106EQ
3-Pin Pico-style 150 mm (6 in) QD
Q10AN6R
2 m (6.5 in)
Q10AN6RQ
Q10RN6R
Q10RN6RQ
1.8 m (70 in)
2 m (6.5 in)
Q10AP6R
2 m (6.5 in)
Q10AP6RQ
Q10RP6R
2 m (6.5 in)
Q10RP6RQ
NPN/ PNP
L.O./ D.O.
L.O.
NPN
10 V dc to 30 V dc
D.O.
L.O.
PNP
D.O.
Table 2: Q10 Diffuse Mode
Models
Range
Cable
Supply Voltage
Q10AN6D
2 m (6.5 in)
Q10AN6DQ
Q10RN6D
2 m (6.5 in)
Q10RN6DQ
Q10AP6D
0.5 m (20 in)
2 m (6.5 in)
Q10AP6DQ
Q10RP6D
2 m (6.5 in)
Q10RP6DQ
Original Document
45725 Rev. C
NPN/ PNP
L.O./ D.O.
L.O.
NPN
D.O.
10 V dc to 30 V dc
L.O.
PNP
D.O.
23 October 2017
45725
Q10 Series Sensors
Wiring Diagrams
Emitters
NPN Receivers
3
1
PNP Receivers
3
10-30V dc
4
1
10-30 V dc
1
Key
10-30 V dc
3
4
Load
1 = Brown
3 = Blue
4 = Black
Load
Quick disconnect (QD) wiring diagrams are functionally identical.
Mounting Specifications
Flat Mounting
Stand-Off Mounting
M2.5 x 0.45 Machine Screw
25 mm (1.0 in) long
Nylon Spacer
M2.5 x 0.45
Machine Screw
12mm Long
Split Lockwasher
Hex Nut
Specifications
Sensing Beam
Infrared, 880 nm
Adjustments
Diffuse models (only); single-turn, top-mounted sensitivity control for
adjustment of system gain (turn clockwise to increase)
Supply Voltage and Current
10 V dc to 30 V dc (10% maximum ripple)
Emitter or receiver: 15 mA
Diffuse models: 20 mA (exclusive of load)
Supply Protection Circuitry
Protected against reverse polarity
Output Configuration
SPST solid-state dc switch
Choose NPN (current sinking) or PNP (current sourcing) models
Choose light operate (N.O.) or dark operate (N.C.) models
Output Rating
150 mA maximum
Off-state leakage current: < 10 microamps at 30 V dc
On-state saturation voltage: < 0.5 V at 10 mA dc; < 1.5 V at 150 mA dc
Output Protection Circuitry
Protected against output short-circuit, continuous overload, and false pulse on
power-up
Overload trip point ≥ 220 mA, typical, at 20 °C
Output Response Time
Opposed mode: 8 ms On, 4 ms Off
Diffuse mode: 3 ms On and Off
Repeatability
Opposed mode: 1.0 ms
Diffuse mode: 0.75 ms
2
Indicators
Opposed mode receivers and diffuse mode sensors have two LEDs: Green and
Amber
Green on = power to the sensor is On
Green flashing = output is overloaded
Amber on = light is sensed
Amber flashing = marginal excess gain (1 to 1.5×) in light condition
Emitters have one Green LED; Green on = power to the sensor is On
Construction
Housings are black ABS; Rated UL 94V0
Lenses are hermetically-sealed glass; lens covers are clear acrylic
Circuitry is epoxy-encapsulated and completely sealed
Stainless steel M2.5 mounting hardware is included
Connections
2 m (6.5 ft) attached cable, or 3-pin pico-style quick-disconnect fitting
Cables for QD models are purchased separately
Environmental Rating
IEC IP54 (NEMA 5)
Operating Conditions
–40 °C to +70 °C (–40 °F to +158 °F)
90% at +50 °C maximum relative humidity (non-condensing)
www.bannerengineering.com - Tel: +1-763-544-3164
P/N 45725 Rev. C
Q10 Series Sensors
Dimensions
Opposed Mode Models
Diffuse Mode Models
Cabled Models
Cabled Models
11.0 mm
(0.43 in)
11.0 mm
(0.43 in)
Yellow LED
Signal Indicator
(Receiver, Only)
21.6 mm
(0.85 in)
Green LED
Power Indicator
Yellow LED
Signal Indicator
(Receiver, Only)
Gain
(Sensitivity)
Adjustment
35.0 mm
(1.38 in)
Green LED
Power Indicator
15.2 mm
(0.60 in)
QD Models
2.8 mm
(0.11 in)
2.8 mm
(0.11 in)
2X Clearance
for M2.5 Screw
10.0 mm
(0.39 in)
18.0 mm
(0.70 in)
2.8 mm
(0.11 in)
20.0 mm
(0.79 in)
14.5 mm
(0.57 in)
2X Clearance
for M2.5 Screw
2.8 mm
(0.11 in)
QD Models
28.9 mm
(1.14 in)
20.0 mm
(0.79 in)
14.5 mm
(0.57 in)
42.4 mm
(1.67 in)
Performance Curves
Opposed Mode
1000
E
X
C
E
S
S
G
A
I
N
Q10 Series
Q10 Series
300 mm
Opposed Mode
100
12 in
Opposed Mode
200 mm
8 in
100 mm
4 in
1
.01 m
.033 ft
100 mm
4 in
200 mm
8 in
300 mm
12 in
.1 m
.33 ft
1m
3.3 ft
.5 m
20 in
10 m
33 ft
1.0 m
40 in
1.5 m
60 in
2.0 m
80 in
2.5 m
100 in
DISTANCE
DISTANCE
Effective Beam: 5 mm
Diffuse Mode
Performance based on a 90% reflectance white test card.
1000
E
X
C
E
S
S
G
A
I
N
Q10 Series
Q10 Series
60 mm
Diffuse mode
2.4 in
Diffuse Mode
40 mm
1.6 in
20 mm
100
0.8 in
1
1 mm
.04 in
20 mm
0.8 in
40 mm
1.6 in
60 mm
2.4 in
10 mm
.4 in
100 mm
4 in
1000 mm
40 in
125 mm
5 in
250 mm
10 in
375 mm
15 in
500 mm 625 mm
20 in
25 in
DISTANCE
DISTANCE
P/N 45725 Rev. C
3
Q10 Series Sensors
Cordsets
3-Pin Threaded M8/Pico-Style Cordsets
Model
Length
PKG3M-2
2 m (6.56 ft)
PKG3M-5
5 m (16.40 ft)
PKG3M-7
7 m (22.97 ft)
PKG3M-9
9 m (29.53 ft)
PKG3M-10
10 m (32.81 ft)
PKW3M-2
2 m (6.56 ft)
PKW3M-5
5 m (16.40 ft)
Style
Dimensions
35 Typ.
Straight
ø 9.5
M8 x 1
4
1
3
28 Typ.
20 Typ.
Right-Angle
PKW3M-9
Pinout (Female)
9 m (29.53 ft)
1 = Brown
3 = Blue
4 = Black
M8 x 1
ø 9.5
Banner Engineering Corp. Limited Warranty
Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or
replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover
damage or liability for misuse, abuse, or the improper application or installation of the Banner product.
THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE.
This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY
OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT
DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE.
Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously
manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the
product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the
product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time.
Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to:
www.bannerengineering.com.
© Banner Engineering Corp. All rights reserved
很抱歉,暂时无法提供与“Q10RP6R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1004.025941+129.88609
