WSE16I-1H162100A00
WSE16I-1H162100A00
    SICK
    SENSOR THRU-BEAM 45M NPN/PNP
WSE16I-1H162100A00 数据手册
Product data sheet WSE16I-1H162100A00 W16 SMALL PHOTOELECTRIC SENSORS WSE16I-1H162100A00 | W16 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WSE16I-1H162100A00 1088328 Other models and accessories www.sick.com/W16 Illustration may differ Detailed technical data Features Device type Photoelectric sensors Sensor/ detection principle Through-beam photoelectric sensor Dimensions (W x H x D) 20 mm x 55.7 mm x 42 mm Housing design (light emission) Rectangular Sensing range max. 0 m ... 45 m Type of light Infrared light Light source LED 1) Light spot size (distance) Ø 110 mm (8 m) Wave length 850 nm Adjustment IO-Link For configuring the sensor parameters and Smart Task functions Wire/pin For activating the test input Indication LED blue BluePilot: Alignment aid LED green Operating indicator Static: power on Flashing: IO-Link mode LED yellow Status of received light beam Static: object not present Static off: object present Flashing: Below the 1.5 function reserve 1) 2  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-11-19 20:08:52 Subject to change without notice WSE16I-1H162100A00 | W16 SMALL PHOTOELECTRIC SENSORS Pin 2 configuration 1) External input, Teach-in, switching signal  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple
WSE16I-1H162100A00 价格&库存
很抱歉,暂时无法提供与“WSE16I-1H162100A00”相匹配的价格&库存,您可以联系我们找货
WSE16I-1H162100A00
  • 1+3190.531901+412.98110
  • 5+2924.617865+378.56130
