WSE12-3P2431
WSE12-3P2431
    SICK
    SENSOR THROUGH-BEAM 15M PNP
WSE12-3P2431 数据手册
Product data sheet WSE12-3P2431 W12-3 SMALL PHOTOELECTRIC SENSORS WSE12-3P2431 | W12-3 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WSE12-3P2431 1041459 Included in delivery: BEF-KH-W12 (2) Other models and accessories www.sick.com/W12-3 Illustration may differ Detailed technical data Features Device type Photoelectric sensors Sensor/ detection principle Through-beam photoelectric sensor Dimensions (W x H x D) 15.6 mm x 48.5 mm x 42 mm Housing design (light emission) Rectangular Sensing range max. 0 m ... 20 m Sensing range 0 m ... 15 m Focus Approx. 1.5° Type of light Visible red light Light source LED 1) Light spot size (distance) Ø 220 mm (15 m) Angle of dispersion Approx. 1.5° Wave length 640 nm Adjustment Potentiometer, 5 turns 1) 2  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-11-16 18:52:29 Subject to change without notice WSE12-3P2431 | W12-3 SMALL PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple Uv - 2,5 V / ca. 0 V Output current Imax. ≤ 100 mA Response time ≤ 330 µs 4) Switching frequency 1,500 Hz 5) Connection type Male connector M12, 4-pin Circuit protection A 6) C 7) D 8) Protection class III Weight 120 g Housing material Metal Optics material Plastic, PMMA Enclosure rating IP66 IP67 IP69K Items supplied 2 x clamps BEF-KH-W12, incl. screws Test input sender off TE to 0 V Ambient operating temperature –40 °C ... +60 °C Ambient temperature, storage –40 °C ... +75 °C UL File No. NRKH.E181493 & NRKH7.E181493 Part number of individual components 2041879 WS12-3D2430 2041881 WE12-3P2431 1) 2) 3) 4) 5) 6) 7) 8)  Limit values when operated in short-circuit protected network: max. 8 A.  May not exceed or fall below Uv tolerances.  Without load.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  C = interference suppression.  D = outputs overcurrent and short-circuit protected. Safety-related parameters MTTFD 826 years DCavg 0 % Classifications ECl@ss 5.0 27270901 ECl@ss 5.1.4 27270901 2021-11-16 18:52:29 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 3 WSE12-3P2431 | W12-3 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T ECl@ss 6.0 27270901 ECl@ss 6.2 27270901 ECl@ss 7.0 27270901 ECl@ss 8.0 27270901 ECl@ss 8.1 27270901 ECl@ss 9.0 27270901 ECl@ss 10.0 27270901 ECl@ss 11.0 27270901 ETIM 5.0 EC002716 ETIM 6.0 EC002716 ETIM 7.0 EC002716 ETIM 8.0 EC002716 UNSPSC 16.0901 39121528 Connection diagram Cd-072 2 1 BN 1 + (L+) WH 2 not connected BU 3 - (M) BK 4 Test BN 1 WH 2 BU 3 BK 4 + (L+) Q - (M) Q ①  Sender ②  Receiver 4 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-11-16 18:52:29 Subject to change without notice WSE12-3P2431 | W12-3 SMALL PHOTOELECTRIC SENSORS Characteristic curve WSE12-3 1000 100 10 Sensing range Sensing range, typ. max. 1 m 4 8 12 16 20 (feet) (13.12) (26.25) (39.37) (52.49) (65.62) Distance in m (feet) Sensing range diagram WSE12-3 0 15 0 20 4 8 12 16 20 (13.12) (26.25) (39.37) (52.49) (65.62) Distance in m (feet) Sensing range Sensing range typ. max. Adjustments WL12-3, WSE12-3 2 3 6 ②  LED indicator yellow: Status of received light beam ③  LED indicator green: Supply voltage active ⑥  Sensitivity control: potentiometer 2021-11-16 18:52:29 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 WSE12-3P2431 | W12-3 SMALL PHOTOELECTRIC SENSORS Dimensional drawing (Dimensions in mm (inch)) WL12-3, WSE12-3 24 (0.94) 10 (0.39) 3.5 12.9 (0.51) 1 7.3 (0.29) 6.1 5 7 23.1 (0.91) H I J K L M N O P Q R S T 5.1 (0.24) 39.9 (1.57) 48.5 (1.91) ø 4.2 (0.91) 5 (0.2) 42 (1.65) 29.9 (1.18) 15.6 (0.61) (0.14) 4 32 (1.26) A B C D E F 6 3 2 19.4 (0.76) ①  Optical axis ②  LED indicator yellow: Status of received light beam ③  LED indicator green: Supply voltage active ④  M4 threaded mounting hole, 4 mm deep ⑤  Mounting hole, Ø 4.2 mm ⑥  Sensitivity control: potentiometer ⑦  Connection Recommended accessories Other models and accessories www.sick.com/W12-3 Brief description Type Part no. YF2A14050VB3XLEAX 2096235 STE-1204-G 6009932 Plug connectors and cables Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M12, 4-pin, straight Head B: Cable: unshielded 6 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-11-16 18:52:29 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
WSE12-3P2431
物料型号:WSE12-3P2431
器件简介:这是SICK公司生产的小型光电传感器,型号为WSE12-3P2431,属于W12-3系列。
引脚分配:文档中提供了连接图,显示了4个引脚的分配,包括正极(L+)、负极(M)、未连接和测试点(BK)。
参数特性: - 供电电压:10 V DC至30 V DC - 功耗:发射器不超过30 mA,接收器不超过15 mA - 输出类型:PNP - 输出功能:互补 - 响应时间:不超过330微秒 - 开关频率:1500 Hz
功能详解: - 这是一种透射式光电传感器,使用可见的红光,波长为640纳米。 - 具有可调节的灵敏度控制,通过电位器进行调节。 - 具有两个LED指示灯,分别表示接收到的光束状态和电源激活状态。
应用信息:SICK是工业应用中智能传感器和传感器解决方案的领先制造商,提供广泛的产品和服务,以安全高效地控制流程,保护个人免受事故,并防止环境损害。
封装信息:传感器的尺寸为15.6 mm x 48.5 mm x 42 mm,外壳设计为矩形,材料为金属,光学元件材料为PMMA塑料。防护等级为IP66、IP67和IP69K。
推荐配件:文档还提供了推荐的配件信息,包括插头连接器和电缆。
WSE12-3P2431 价格&库存
很抱歉,暂时无法提供与“WSE12-3P2431”相匹配的价格&库存,您可以联系我们找货
