GTB10-P4411S01
GTB10-P4411S01
    SICK
    SENSOR PROXIMITY 950MM PNP
GTB10-P4411S01 数据手册
Product data sheet GTB10-P4411S01 G10 SMALL PHOTOELECTRIC SENSORS GTB10-P4411S01 | G10 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. GTB10-P4411S01 1066852 Other models and accessories www.sick.com/G10 Illustration may differ Detailed technical data Features Sensor/ detection principle Photoelectric proximity sensor, Background suppression Dimensions (W x H x D) 20 mm x 50 mm x 39 mm Housing design (light emission) Rectangular Sensing range max. 20 mm ... 950 mm 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 8 mm (700 mm) Wave length 625 nm Adjustment Potentiometer, 5 turns Special features High functional reliability on foil-wrapped objects 1) 2)  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 1) 2) 3) 4) 5) 6) 7) 8) 9) 2 10 V DC ... 30 V DC 1)  Limit values when operated in short-circuit protected network: max. 8 A.  May not exceed or fall below Uv tolerances.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  C = interference suppression.  D = outputs overcurrent and short-circuit protected.  Complies with the UL325 standard when used with sturdy protection hood (e.g. BEF-G10WSG, 2071960). PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-09-09 18:21:28 Subject to change without notice GTB10-P4411S01 | G10 SMALL PHOTOELECTRIC SENSORS Ripple
GTB10-P4411S01 价格&库存
很抱歉,暂时无法提供与“GTB10-P4411S01”相匹配的价格&库存,您可以联系我们找货
