PD30CNG02NPM5MU
PD30CNG02NPM5MU
    CARLOGAVAZZI
    SENSOR RETROREFLECTIVE 2M NPN
PD30CNG02NPM5MU 数据手册
Photoelectrics Retro-reflective for Transparent Objects Type PD30CNG02....MU • Miniature sensor range • Range: 2 m, with reflector • Sensitivity adjustment by Teach-In programming • Modulated, red light 617 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP preset • Make and break switching function programmable • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable and plug versions • Excellent EMC performance • Mute function (sensor blanking) Product Description Ordering Key The PD30CNG02 sensor family comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABS housing. The sensors are useful in applications where detection of transparent objects are needed. Compact housing and high power LED for excellent performance-size ratio. Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Mute The Teach-In function for adjustment of the sensitivity makes the sensors highly flexible. The output type is preset (NPN or PNP), and the output switching function is programmable (NO or NC). The mute function can be used for testing the sensor for: Malfunctioning, disconnection, optical axis adjustment, dusty and dirty lenses. PD30CNG02PPM5MU Type Selection Housing Range Connection WxHxD Sn Ordering no. NPN Make or break switching Ordering no. PNP Make or break switching 10 x 30 x 20 mm 2 m Cable 10 x 30 x 20 mm 2 m Plug Note: Reflectors to be ordered separately PD 30 CNG 02 NPMU PD 30 CNG 02 NPM5MU PD 30 CNG 02 PPMU PD 30 CNG 02 PPM5MU Specifications EN 60947-5-2 Rated operating distance (Sn) Up to 2 m, with reflector Ø 80 mm (ER4) Detection reliability 20% attenuation Blind zone 10 mm Sensitivity Adjustable by Teach-In Temperature drift ≤ 0.1%/ºC Teach settings are valid for teach temperature ± 20°C Hysteresis (H) (differential travel) ≤ 10% Rated operational volt. (UB ) 10 to 30 VDC (ripple included) Ripple (Urpp ) ≤ 10% Output current Continuous (Ie) ≤ 100 mA Short-time (I) ≤ 100 mA (max. load capacity 100 nF) No load supply current (Io) ≤ 30 mA @ 24 VDC Minimum operational current (Im) 0.5 mA OFF-state current (Ir ) ≤ 100 µA Voltage drop (Ud ) ≤ 2.4 VDC @ 100 mA Specifications are subject to change without notice (07.07.2016) Protection Short-circuit, reverse polarity and transients Light source inGaAlP, LED, 617 nm Light type, not polarized Red, modulated Sensing angle ± 2º Ambient light 10,000 lux Light spot 110 mm @ 1.5 m Operating frequency 1000 Hz Response time OFF-ON (tON) ≤ 0.5 ms ON-OFF (tOFF ) ≤ 0.5 ms Power ON delay (tv) ≤ 300 ms Output function NPN and PNP Preset NO/NC switching function Set up by button Mute function Emitter off 0 to 3 sec 0 to 2.5 VDC (NPN) 5 to 30 VDC (PNP) Operating mode Not connected Indication Output ON LED, yellow Signal stability ON and power ON LED, green 1 PD30CNG02....MU Specifications (cont.) Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock EN 60947-5-2 III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) -25° to +55°C (-13° to +131°F) -40° to +70°C (-40° to +158°F) 10 to 55 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) Rated insulation voltage 500 VAC (rms) Housing material Body ABS Front material PMMA, red Connection Cable PVC, black, 2 m 4 x 0.14 mm2, Ø = 3.3 mm Plug M8, 4-pin (CON, 54-series) Weight With cable: 40 g With plug:  10 g CE-marking Yes Approvals cULus (UL508) Operation Diagram tv = Power ON delay Power supply ON OFF Object Present Not Present Mute ON OFF Emitted power ON OFF Make Output (N.O.) ON OFF Break Output (N.C.) ON OFF T < 3 sec. T > 3 sec. Tv Tv Wiring Diagrams NPN 1 BN Mute PNP V 2 WH 4 BK 1 BN Mute 3 BU V 4 BK 2 WH 3 BU V (GND) V (GND) Mute input active when connected to GND Mute input active when connected to V+ Excess Gain Detection Diagram 150 100 Bredde [mm] 50 0 0 500 1000 1500 2000 2500 3000 Excess Gain 100 10 -50 -100 1 10 -150 100 1000 10000 Distance (mm) Afstand [mm] 2 Specifications are subject to change without notice (07.07.2016) PD30CNG02....MU Accessories Signal Stability Indication 21.2 14 9° 32.4 1.2 25.4 Excess Gain 9° 26,3 29.3 39 3.2 Operation level x 1.05 Operation level Operation level x 0.95 1.2 10 1.05 1.0 0.95 25.4 3.2 13.5 16.2 6.0 5.2 3 Yellow LED ON 4.4 14 4.4 6.0 16 10 7.3 Green LED ON 8.2 5.7 Time 4.4 Mounting bracket: APD30-MB1 Mounting bracket: APD30-MB2 Dimensions Plug version Cable version 10.6 PD30CNP 06NPM5T 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET 10.8 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET Incorrect xxxxxxS Correct Emitter Two M3 Two, 9.5 dia. Lenses 15 30 15 22 Receiver Optical axis 5.5 5.5 Two, 9.5 dia. Lenses 10.8 17 22 Receiver Optical axis R 25.4 17 R Power / Stability LED Green 10.6 1.1 PD30CNP 06NPM5T 25.4 30 Output LED Yellow Power / Stability LED Green 5.5 5.5 1.1 Output LED Yellow xxxxxxS 6 20 10.6 6 Teach Button 20 10.6 Teach Button Two M3 > 100 mm Emitter 10.25 Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Delivery Contents Accessories • Photoelectric switch: PD 30 CNG 02 ...MU • Installation instruction • Mountingbracket APD30-MB1 • Packaging: Cardboard box • Mounting bracket APD30-MB2 to be purchased separately Specifications are subject to change without notice (07.07.2016) 3 PD30CNG02....MU Teach functions Normal operation, optimized switching point 1. Line up the sensor with the reflector. Yellow LED and Green LED are ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Place the object between the sensor and reflector in the detection zone. 4. Press the button once and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 For make or break set-up (N.O. or N.C.) 1. Press the button for 10 seconds, until the green LEDs flashes. 2. While the green LED flashes, the output is inverted each time the button is pressed. Yellow LED indicates N.O. function selected. If the button is not pressed within the next 10 seconds, the current output is stored. 1 2 4 10 sec. 3 sec. Push once Push once For maximum sensing distance (default setting) 1. Line up the sensor with the reflector, place a new transparant object between the sensor and reflector in the detection zone. Yellow LED is OFF and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 sec. 3 Push once For the most transparent objects 1. Line up the sensor with the reflector. Yellow LED and Green LED are ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 sec. 4 3 Push once Specifications are subject to change without notice (07.07.2016)
PD30CNG02NPM5MU 价格&库存
很抱歉,暂时无法提供与“PD30CNG02NPM5MU”相匹配的价格&库存,您可以联系我们找货
PD30CNG02NPM5MU
  • 1+1110.423771+143.93207
PD30CNG02NPM5MU
  • 1+897.37001
库存:1
PD30CNG02NPM5MU
  • 1+970.122921+125.74640
  • 5+905.436435+117.36180
  • 10+840.7499510+108.97720
