PD30CNT15PPRT
PD30CNT15PPRT
    CARLOGAVAZZI
    SENSOR THROUGH-BEAM 15M PNP
PD30CNT15PPRT 数据手册
Photoelectrics Through-beam Type PD30CNT15....MU/RT • Miniature sensor range • Range: 15 m • Sensitivity adjustment by Teach-In programming • Modulated, Infraredred light 880 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP preset • Make and break switching function programmable • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable and plug versions • Excellent EMC performance • Mute function (Sensor blanking) Emitter • Remote teach - Receiver Product Description The PD30CNT15 sensor family comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABS housing. The sensors are useful in applications where high-accuracy detection as well as small size is required. Compact housing and high power LED for excellent performance-size ratio. Ordering Key The Teach-In function for adjustment of the sensitivity makes the sensors highly flexible. The output type is preset (NPN or PNP), and the output switching function is programmable (NO or NC). The mute function can be used for testing the sensor for: Malfunctioning, disconnection, optical axis adjustment, dusty and dirty lenses. PD30CNT15NPM5RT Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Remote teach Type Selection Housing Range Connection Ordering no. WxHxD Sn NPN Emitter Ordering no. Ordering no. NPN PNP Make or break switching Emitter 10 x 30 x 20 mm 15 m Cable PD 30 CNT 15 NMU PD 30 CNT 15 NPRT 10 x 30 x 20 mm 15 m Plug PD 30 CNT 15 NM5MU PD 30 CNT 15 NPM5RT Note: Emitter, Receiver and Connector to be ordered separately. Specifications Emitter Rated operational volt. (UB ) Ripple (Urpp ) Supply current Light Source Optical angle Light type Light spot Ordering no. PNP Make or break switching PD 30 CNT 15 PMU PD 30 CNT 15 PPRT PD 30 CNT 15 PM5MU PD 30 CNT 15 PPM5RT EN 60947-5-2 10 to 30 VDC ≤ 10% ≤ 25 mA GaAIAs, LED, 880 nm ± 2º at ½ range Infrared, modulated 110 mm @ 1.5 m Specifications Receiver Protection Reverse polarity, transients Indication function Power supply ON LED, green Mute function Emitter off 0 to 3 sec 0 to 2.5 VDC (NPN) 5 to 30 VDC (PNP) Emitter half power > 3 sec 0 to 2.5 VDC (NPN) 5 to 30 VDC (PNP) EN 60947-5-2 Rated operating distance (Sn) 15 m, with PD30CNT15 Emitter Blind zone None Sensitivity Adjustable by Teach-In (push button or wire) Temperature drift ≤ 0.3%/ºC Hysteresis (H) (differential travel) ≤ 10% 10 to 30 VDC Rated operational volt. (UB ) ≤ 10% Ripple (Urpp ) Specifications are subject to change without notice (10.02.2017) Adjustable range resolution Output current Continuous (Ie) Short-time (I) No load supply current (Io) Minimum operational current (Im) OFF-state current (Ir ) Voltage drop (Ud ) 1.5 m to 15 m 3% on distance ≤ 100 mA ≤ 100 mA (max. load capacity 100 nF) ≤ 30 mA 0.5 mA ≤ 100 µA ≤ 2.5 VDC @ 100 mA 1 PD30CNT15....MU/RT Excess Gain Detection Diagram Emitter Y X (feet) Receiver 16.5 400 33 49.5 66 16 300 12 200 8 100 4 0 0 -4 -100 -200 -8 -300 -12 -400 -16 20 0 5 10 15 1000 100 10 1 1.0 10.0 100.0 Distance (m) Sensing range (m) Accessories Signal Stability Indication 21.2 14 9° 32.4 1.2 25.4 Excess Gain 3.2 9° Operation level Operation level x 0.75 29.3 1.0 0.75 26,3 Operation level x 1.25 1.2 39 1.25 3.2 Environment Installation category III (IEC 60664/60664A; 60947-1) Pollution degree 3 (IEC 60664/60664A; 60947-1) Degree of protection IP 67 (IEC 60529; 60947-1) Ambient temperature Operating -25° to +55°C (-13° to +131°F) Storage -40° to +70°C (-40° to +158°F) Vibration 10 to 55 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) Shock 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) Rated insulation voltage 500 VAC (rms) Housing material Body ABS Front material PMMA, red Connection Cable Emitter/receiver PVC, black, 2 m, Ø = 3.3 mm 4 x 0.14 mm2 Plug M8, 4-pin (CON, 54-series) Weight (each sensor) With cable: 40 g With plug:  10 g CE-marking Yes Approvals cULus (UL508) 25.4 EN 60947-5-2 (inch) Protection Short-circuit, reverse polarity and transients Sensing angle ± 4º Ambient light 10,000 lux Operating frequency 1000 Hz Response time ≤ 0.5 ms OFF-ON (tON) ON-OFF (tOFF ) ≤ 0.5 ms ≤ 300 ms Power ON delay (tv) Output function NPN and PNP Preset NO/NC switching function Set up by button Remote teach “Push button active” 0 to 2.5 VDC (NPN) 5 to 30 VDC (PNP) Tamper proof When activated more than 20 sec. the sensor goes into a Tamper proof mode. Indication Output ON LED, yellow Signal stability ON and power ON LED, green General Specifications 10 EN 60947-5-2 (mm) Specifications Receiver (cont.) Excess Gain PD30CNT15....MU/RT 13.5 Operation Diagram 16.2 6.0 5.7 6.0 Yellow LED ON 3 4.4 Power supply Object Present Not Present T > 3 sec. Plug version Cable version Tv Wiring Diagrams Teach 2 WH Mute 2 WH 10.6 Two M3 3 BU V Teach input active when connected to GND 2 Teach input active when connected to V+ V V V Mute input active when connected to GND 1.1 Two M3 3 BU 3 BU 3 BU 15 Mute Two, 9.5 dia. Lenses 5.5 5.5 4 BK 2 WH 15 2 WH 4 BK Receiver or emitter Optical axis 22 V 30 1 BN 10.8 17 25.4 V Two, 9.5 dia. Lenses 5.5 5.5 PNP 1 BN V 22 NPN 1 BN Optical axis 25.4 PNP V Receiver or emitter Power / Stability LED Green 10.6 10.8 17 1.1 Emitter NPN Output LED Yellow* Power / Stability LED Green 10.6 Receiver Teach Teach Button* 20 Tv 6 Teach Button* Output LED Yellow* 1 BN Mounting bracket: APD30-MB2 Dimensions 30 Break Output (N.C.) ON OFF T < 3 sec. 6 ON OFF Mounting bracket: APD30-MB1 10.6 Make Output (N.O.) Emitted power 4.4 20 Optics ON OFF 100% 50% 0% Dirty Clean Mute (Emitter) 14 4.4 8.2 16 10 7.3 Green LED ON tv = Power ON delay ON OFF 5.2 Time Mute input active when connected to V+ Specifications are subject to change without notice (10.02.2017) 10.25 * Not avaible on emitter version Specifications are subject to change without notice (10.02.2017) 3 xxxxxxS Incorrect Correct xxxxxxS PD30CNT15....MU/RT > 100 mm Teach functions Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect PD30CNT15....MU/RT Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Delivery Contents Accessories • Photoelectric switch: PD 30 CNT 15 ... • Installation instruction • Mountingbracket APD30-1 • Packaging: Cardboard box • Mounting bracket APD30-2 to be purchased separately • Connector type CONG 5A../CON. 54NF.. series. Normal operation, optimized switching point 1. Line up the emitter and receiver. Yellow LED and Green LED are ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Place the object between the emitter and receiver in the detection zone. 4. Press the button once and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 For dynamic set-up (running process) 1. Line up the emitter and receiver. Green LED is ON, status on the yellow LED is not important. 2. Press the button for 3 second until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and keep the button pressed for at least one process cycle, release the button and the sensor is ready to operate (The second switch point is stored) 1 4 2 3 sec. 3 sec. 1 Push once Push once For maximum sensing distance (default setting) 1. Line up the emitter and receiver, place the object between the emitter and receiver in the detection zone. Yellow LED is OFF and Green LED is ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 3 2 For make or break set-up 1. Press the button for 10 seconds, until the green LEDs flashes. 2. While the green LED flashes, the output is inverted each time the button is pressed. Yellow LED indicates N.O. function selected. If the button is not pressed within the next 10 seconds, the current output is stored. 1 2 3 10 sec. 3 sec. Push once Push once For minimum sensing distance (Transparent or semi-transparent objects) 1. Line up the emitter and receiver. Yellow LED and Green LED are ON. 2. Press the button for 3 seconds until both LEDs flashes simultaneously. (The first switch point is stored) 3. Press the button a second time and the sensor is ready to operate (Green LED ON, Yellow LED ON) (The second switch point is stored) 1 2 3 sec. 4 Specifications are subject to change without notice (10.02.2017) 3 Push once Specifications are subject to change without notice (10.02.2017) 5
PD30CNT15PPRT 价格&库存
很抱歉,暂时无法提供与“PD30CNT15PPRT”相匹配的价格&库存,您可以联系我们找货
PD30CNT15PPRT
  • 1+785.770181+101.60202
  • 5+746.488585+96.52281
库存:8
PD30CNT15PPRT
    • 1+634.19725
    库存:4
    PD30CNT15PPRT
    • 1+750.347721+97.02180
    • 5+700.359495+90.55820
    • 10+650.2838810+84.08330
    库存:1
