PE12CNT15
PE12CNT15
    CARLOGAVAZZI
    SENSOR THROUGH-BEAM 15M
PE12CNT15 数据手册
Photoelectrics Through-beam, Transistor Output Type PE12CNT15.. • Elevators, Escalators and Entrance control • Range 15 m • ESPE-Type 2, PL C. • Modulated, infrared light • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP type • Make or break switching • LED for output indication or power supply • Protection: reverse polarity, short circuit, transients • Cable versions with or without connector • Emitter mute and power adjustment • CE, UL325 and UL508 approved Product Description The PE12CNT. is a family of general purpose Photoelectric sensors. They are specially designed for Elevators, Escalators, Entrance control to meet the requirements in the door market. The “snap-on” housing can be mounted with a wall thickness from 0.6 mm to 2.25 mm. The emitter has a mute input to turn it off for evaluation of the sensor function. Available in 10-30 VDC version. Ordering Key PE12CNT15NO-C2 Type Housing style Housing size Housing material Sensor code Detection principle Sensing distance Output type Output configuration Connection type Cable connector Type Selection Housing Range Con- Ordering no. Ordering no. Ordering no. Ordering no. Ordering no. diameter Sn nec- Receiver Receiver Receiver Receiver Emitter tor NPN, NO NPN, NC PNP, NO PNP, NC Ø 12 mm 15 m Ø 12 mm 15 m NO YES PE12CNT15NO PE12CNT15NC PE12CNT15PO PE12CNT15PC PE12CNT15 PE12CNT15NO-C2 PE12CNT15NC-C2 PE12CNT15PO-C2 PE12CNT15PC-C2 PE12CNT15-C2 Note: Please order emitter and receiver separately Specifications Emitter Rated operational volt. (UB) 10 to 30 VDC Ripple (Urrp) ≤ 10% Supply current ≤ 20 mA Protection Reverse polarity, transients Power ON delay (tv) ≤ 100 ms Control input Normal oper. > 1.5 VDC Mute < 1.2 VDC Light source LED, 890 nm Light type Light spot Emitter angle Indication function Power supply ON Mute input ON Power adjustment Rx ~ 3 kΩ -10 kΩ Specifications are subject to change without notice. Rev. *1* (28.04.2017) Infrared, modulated 940 mm @ 9 m ± 3° @ 9 m LED, green LED, green flashing 3.5 Hz 3 ... 18 m in 19 step 1 PE12 Specifications Receiver Rated operating dist. (Sn) Blind zone Temperature drift Hysteresis (H) Rated operational volt. (UB) Ripple (Urrp) No load supply current (Io) Output current Continuous (Ie) Short-time (I) Minimum operational current (Im) OFF-state current (Ir ) Voltage drop (Ud ) Protection 15 m None ≤ 0.4 %/°C 3 - 20 % 10 to 30 VDC (ripple included) ≤ 10 % ≤ 16 mA ≤ 100 mA ≤ 100 mA, (max. load capacity 100 nF) 0.5 mA ≤100 µA ≤ 1.6 VDC @ 100 mA Short-circuit, reverse pola- rity, transients Utility category DC12 Control of resistive loads and solid state loads with optical isolation DC13 Control of electromagnets Ambient light 3,000 ... 3,200 K > 80,000 LUX (EN60947-5-2) Detection angle ± 2.5° @ 9 m Operating frequency (f) 100 Hz Response time OFF-ON (tON) ≈ 6.5 ms ON-OFF (tOFF) ≈ 3.5 ms Power ON delay (tv ) ≤ 100 ms Output function NPN or PNP Make or break (NO or NC) Indication function Output ON LED, yellow General Specifications Environment Overvoltage category Pollution degree Degree of protection Temperature Operating Storage Rated insulation voltage Dielectric test voltage Rated impulse withstand test ESPE PFHd Diagnostic coverage Performance level MTTFd (worst case full sensor) Electrostatic discharge (EN61000-4-2) Contact discharge Air discharge Radiated RF electromagnetic fields (EN 61000-4-3) Electrical fast transients/burst (EN 61000-4-4) 2 IIl (IEC 60664/60664A, 60947-1) 3 (IEC 60664/60664A, 60947-1) IP67 (IEC 60529; EN60947-1) 1, 2, 12 (NEMA types) -20° to +50°C (-4° to +122°F) -25° to +80°C (-13° to +176°F) 75 VDC 500 Vac rms (EN60947-1) 800 V (1.2 / 50 µs) (EN60947-1) Type 2 6 x 10-8 failure per hour (worst case SRP for CS) 99 % (EN13849-1: 2008) C (EN13849-1: 2008) 298 Years (worst case full receiver) EN ISO 13849-1, SN 29500 368 Years (worst case full emitter) EN ISO 13849-1, SN 29500 > 12 kV > 8 kV > 10 V/m Surge (EN 61000-4-5) Power-supply > 1 kV (with 500 Ω) Sensor output > 1 kV (with 500 Ω) Wire conducted disturbances (EN 61000-4-6) > 10 Vrms Power-frequency magnetic fields (EN 61000-4-8) Continous > 30 A/m, 38 μ tesla Short-time > 300 A/m, 380 μ tesla Vibration (IEC 60068-2-6) 10 to 150 Hz, 1 mm / 15 g Shock (IEC 60068-2-27) 30 g / 11 ms, 6 pos, 6 neg per axis Free fall (IEC 60068-2-31) 2 times from 1 m, 100 times from 0.5 m Pig-tail connector (-C2) 3-pol micro MATE-N-LOK Series, AMP/TE Housing material Body PE12 PC black Front glass PC black Connection Cable PVC, Emitter: grey / Receiver: black, 5 m, 3 x 0.14 mm2, Ø 2.9 mm Weight Emitter 80 g Receiver 80 g CE-marking EN12445, EN12453, EN12978, EN 60947-5-2 UL-Approval UL325 UL508, CSA-C22.2 No.247 ± 4 kV Specifications are subject to change without notice. Rev. *1* (28.04.2017) PE12 Operation Diagram tv = Power ON delay Power supply Target emitter present Object present Break (NC) Output ON Make (NO) Output ON Mute active ≤ 1.2 VDC Detection Diagram Emitter PE12........ Sensing range [feet] Y X Ø2.9 Ø15 Detection width [m] 0,0 6,6 0,5 Receiver Ø11.8 19,7 26,2 32,8 39,4 45,9 52,5 59,1 65,6 19,7 0,4 15,8 0,3 11,8 0,2 7,9 0,1 3,9 0,0 0,0 -0,1 -3,9 -0,2 -7,9 -0,3 -11,8 -0,4 -15,8 -0,5 26.2 13,1 0 2 4 6 2.6 8 10 12 Sensing range [m] 14 16 18 20 Detection width [inches] Dimensions (mm) -19,7 Excess Gain Excess Gain 100000 Gain 10000 1000 100 10 0.6 - 2.25 mm Ø12 or ½” (12,7 mm) 1 0.1 1 10 100 Sensing range [m] Power adjustment curve PE12.....-C2 with connector Typical mute function characteristic Sensing range [feet] 0 10 24,6 6,6 13,1 19,7 2 4 6 26,2 32,8 39,4 45,9 52,2 59,0 14 16 18 10 160 5000 Resistor value [kOhm] 9 8 7 6 5 4 3 2 1 0 To be mounted in material with a thickness of 0.6 - 2.25 mm Specifications are subject to change without notice. Rev. *1* (28.04.2017) 0 8 10 12 Sensing range [m] 3 Wiring Diagram Delivery Contents • PE12... • Packaging: plastic bag Receiver Emitter 1BN 1BN 1BN 4BK 3BU 3BU 4BK 4BK Rext 3BU PE 12 CNT 15 PE 12 CNT 15 NO PE 12 CNT 15 NC 1BN 1BN 4BK 4BK 3BU 3BU PE 12 CNT 15 PO PE 12 CNT 15 PC Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 4 Specifications are subject to change without notice. Rev. *1* (28.04.2017)
PE12CNT15 价格&库存
很抱歉,暂时无法提供与“PE12CNT15”相匹配的价格&库存,您可以联系我们找货
PE12CNT15
  • 1+426.651831+55.30220
  • 5+398.144455+51.60710
  • 10+369.8114210+47.93460
库存:1
PE12CNT15
    • 1+503.32158
    库存:17
