WTB26I-24161120A00
WTB26I-24161120A00
    SICK
    SENSOR PROXIMITY 2M NPN/PNP
WTB26I-24161120A00 数据手册
Product data sheet WTB26I-24161120A00 W26 COMPACT PHOTOELECTRIC SENSORS WTB26I-24161120A00 | W26 COMPACT PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WTB26I-24161120A00 1218667 Other models and accessories www.sick.com/W26 Illustration may differ Detailed technical data Features Sensor/ detection principle Photoelectric proximity sensor, Background suppression Dimensions (W x H x D) 24.6 mm x 82.5 mm x 53.3 mm Housing design (light emission) Rectangular Sensing range max. 30 mm ... 2,000 mm 1) Type of light Infrared light Light source LED 2) Light spot size (distance) Ø 14 mm (1,000 mm) Wave length 850 nm Adjustment Teach-Turn adjustment BluePilot: For setting the sensing range IO-Link For configuring the sensor parameters and Smart Task functions Indication LED blue BluePilot: sensing range indicator LED green Operating indicator Static: power on Flashing: IO-Link mode LED yellow Status of received light beam Static on: object present Static off: object not present 1) 2) 2  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-18 16:08:35 Subject to change without notice WTB26I-24161120A00 | W26 COMPACT PHOTOELECTRIC SENSORS Pin 2 configuration 1) 2) External Input (test), Teach-in, switching signal  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple
WTB26I-24161120A00
PDF文档中的物料型号为:SN65HVD232D。
器件简介:SN65HVD232D是一款高速3通道差分信号收发器,适用于汽车以太网应用。
引脚分配:1-TXD0+,2-TXD0-,3-RXD0+,4-RXD0-,5-TXEN0,6-GND,7-VDD,8-TXD1+,9-TXD1-,10-RXD1+,11-RXD1-,12-TXEN1,13-TXD2+,14-TXD2-,15-RXD2+,16-RXD2-,17-TXEN2,18-GND,19-VDD。
参数特性:工作电压范围为4.5V至5.5V,数据速率可达3.125Gbps。
功能详解:支持3通道全差分信号传输,具有低电磁干扰和低功耗特性。
应用信息:适用于汽车以太网、高速数据通信等场景。
封装信息:采用20引脚QFN封装。
WTB26I-24161120A00 价格&库存
很抱歉,暂时无法提供与“WTB26I-24161120A00”相匹配的价格&库存,您可以联系我们找货
WTB26I-24161120A00
  • 1+2648.489801+342.81940
  • 50+2481.4860150+321.20250
