S18SN6DL W/30
S18SN6DL W/30
    BANNER(邦纳)
    RANGE: 300 MM; INPUT: 10-30 V DC
S18SN6DL W/30 数据手册
Installation Guide S18 Sensors – dc-Voltage Series Self-contained, dc-operated sensors Sensing Mode Opposed Retroreflective† Polarized Retroreflective† P R LISTED Cabled Emitters bn + bu – Diffuse + bu – Fixed Field 10 - 30V dc No Connection NPN (Sinking) Outputs Standard Hookup bu bn bk wh – 10 - 30V dc + Load Alarm S18SN6R PNP S18SP6R NPN S18SN6L PNP S18SP6L NPN S18SN6LP PNP S18SP6LP 100 mm (4") NPN S18SN6D PNP S18SP6D 300 mm (12") NPN S18SN6DL PNP S18SP6DL NPN S18SN6FF25 PNP S18SP6FF25 50 mm (2") cutoff NPN S18SN6FF50 PNP S18SP6FF50 100 mm (4") cutoff NPN S18SN6FF100 PNP S18SP6FF100 2m (79") Visible Red 680 nm Infrared 880 nm Dimensions QD Models Yellow LED Output Indicator Yellow LED Output Indicator Jam Nuts (2 Provided) 2m (6.5') Cable 59.2 mm* (2.33") Green LED Power Indicator Jam Nuts (2 Provided) 18 x 1 mm Thread Green LED Power Indicator PNP (Sourcing) Outputs S186E NPN Infrared 950 nm Cabled Models – 10 - 30V dc + Model* * Standard 2 m (6.5') cable models are listed. • 9 m (30') cable: add suffix “W/30” (e.g., S186E W/30). • 4-pin Euro-style QD models: add suffix “Q” (e.g., S186EQ). A model with a QD connector requires a mating cable. † Use polarized models when shiny objects will be sensed. Load Load Alarm Hookup bn bu bk wh Output – 20 m (66') 25 mm (1") cutoff bk wh LED 10-30V dc QD Emitters bn Range 37.0 mm (1.46") 18 x 1 mm Thread 78.0 mm* (3.07") 37.0 mm (1.46") Standard Hookup bn bu bk wh + – *Polarized retro and fixed-field models = 65.0 mm (2.56") 10 - 30V dc Load Load Alarm Hookup bu bn bk wh + – 10 - 30V dc Load Alarm NOTE: QD hookups are functionally identical. Downloaded from Elcodis.com electronic components distributor *Polarized retro and fixed-field models = 83.8 mm (3.30") S18 Sensors – dc-Voltage Series Specifications Supply Voltage and Current (exclusive of load current): 10 to 30V dc (10% max. ripple); supply current (exclusive of load current): Emitters, Non-Polarized Retro, Diffuse: 25 mA Receivers: 20 mA Polarized Retroreflective: 30 mA Fixed-Field: 35 mA Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration SPDT solid-state dc switch; Choose NPN (current sinking) or PNP (current sourcing) models Light Operate: N.O. output conducts when sensor sees its own (or the emitter’s) modulated light Dark Operate: N.C. output conducts when the sensor sees dark; the N.C. (normally closed) output may be wired as a normally open marginal signal alarm output, depending upon hookup to power supply (U.S. patent 5087838) Output Rating 150 mA maximum (each) in standard hookup. When wired for alarm output, the total load may not exceed 150 mA. OFF-state leakage current: < 1 microamp @ 30V dc ON-state saturation voltage: < 1V at 10 mA dc; < 1.5V at 150 mA dc Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short circuit of outputs Output Response Time Opposed mode: 3 ms ON, 1.5 ms OFF Retro, Fixed-Field and Diffuse: 3 ms ON and OFF NOTE: 100 ms delay on power-up; outputs do not conduct during this time. Repeatability Opposed mode: 375 µs Retro, Fixed-Field and Diffuse: 750 µs Repeatability and response are independent of signal strength. Indicators Two LEDs (Green and Yellow) Green ON steady: power to sensor is ON Green flashing: output is overloaded Yellow ON steady: N.O. output is conducting Yellow flashing: excess gain marginal (1 to 1.5x) in light condition Construction PBT polyester housing; polycarbonate (opposed mode) or acrylic lens Environmental Rating Leakproof design rated NEMA 6P, DIN 40050 (IP69K) Connections 2 m (6.5') or 9 m (30') attached cable, or 4-pin Euro-style quick-disconnect fitting Operating Conditions Temperature: -40° to +70°C (-40° to +158°F) Maximum relative humidity: 90% at 50°C (non-condensing) Vibration and Mechanical Shock All models meet Mil. Std. 202F requirements. Method 201A (Vibration; frequency 10 to 60 Hz, max., double amplitude 0.06" acceleration 10G). Method 213B conditions H&I (Shock: 75G with unit operating; 100G for non-operation) Certifications R LISTED Quick-Disconnect (QD) Cables Style 4-pin Euro-style Straight Model MQDC-406 MQDC-415 MQDC-430 Length 2 m (6.5') 5 m (15') 9 m (30') Dimensions Pin-Out ø 15 mm (0.6") 44 mm max. (1.7") M12 x 1 White Wire Brown Wire Blue Wire 38 mm max. (1.5") 4-pin Euro-style Right-angle MQDC-406RA MQDC-415RA MQDC-430RA 2 m (6.5') 5 m (15') 9 m (30') 38 mm max. (1.5") M12 x 1 ø 15 mm (0.6") Downloaded from Elcodis.com electronic components distributor Black Wire
S18SN6DL W/30
1. 物料型号:文档列出了多种型号的传感器,包括S186E、S18SN6R、S18SP6R、S18SN6L、S18SP6L、S18SN6LP、S18SN6D、S18SN6DL、S18SN6FF25、S18SP6FF25、S18SN6FF50、S18SP6FF100等。
2. 器件简介:这些传感器是自包含的直流操作传感器,具有多种感应模式,如对射、反射、极化反射、漫反射和固定场模式。
3. 引脚分配:文档提供了两种输出配置的引脚分配,包括NPN(电流吸收)和PNP(电流源)模型。
4. 参数特性:包括供电电压和电流(不包括负载电流)、输出配置、输出额定值、输出保护电路、输出响应时间等。
5. 功能详解:传感器具有两种操作模式:亮操作和暗操作。亮操作时,当传感器看到自己的调制光或发射器的光时,N.O.(常开)输出导通。暗操作时,当传感器看到黑暗时,N.C.(常闭)输出导通。
6. 应用信息:传感器适用于多种环境,具有防漏设计,符合NEMA 6P和DIN 40050(IP69K)标准。
7. 封装信息:传感器的尺寸、电源指示灯、输出指示灯、连接方式等信息。
S18SN6DL W/30 价格&库存
很抱歉,暂时无法提供与“S18SN6DL W/30”相匹配的价格&库存,您可以联系我们找货
