QS30ELVCQ
QS30ELVCQ
    BANNER(邦纳)
    PHOTO SEN CLEAR 100MM-2M BIPOLAR
QS30ELVCQ 数据手册
WORLD-BEAM® QS30ELVC Series Expert™ Clear Object Non-Polarized Retroreflective Sensor Features • Reliable detection of clear, translucent, or opaque targets — including mirror-like surfaces • Automatic compensation algorithm compensates for dust or contamination on the sensor or reflector and for ambient temperature changes • 3 selectable thresholds based on type of target being detected • Easy configuration via push buttons or remote wire • Easy-to-read operating status indicators • Rugged housing for harsh environments; rated IP67 (NEMA 6), 1200 psi washdown per NEMA PW12 • Compact housing, mounting versatility — 30 mm threaded barrel or side-mount CLEAR PLASTIC RETRO Models Model QS30ELVC QS30ELVCQ Sensing Range and Use* 100 mm to 2 m (3.9" to 78") Light SET for clear object detection Cable** Supply Voltage Output 2 m (6.5') 5-wire cable 10 to 30V dc Bipolar (NPN and PNP) Integral 5-pin Euro-Style QD * Operation at shorter and longer distances possible. Contact factory for applications assistance. ** For 9 m (30') cable, add suffix “W/30” to the model number (e.g., QS30ELVC W/30). For 150 mm (6") pigtail with a 5-pin Euro-style connector, add suffix “Q5” to the model number (e.g., QS30ELVCQ5). For 150 mm (6") PUR cable with 5-pin threaded Euro-Style QD, add suffix “QPMA” to the model number (e.g. QS30ELVCQPMA). A model with a QD connector requires a mating cordset (see page 9). WARNING . . . Not To Be Used for Personnel Protection Never use these products as sensing devices for personnel protection. Doing so could lead to serious injury or death. These sensors do NOT include the self-checking redundant circuitry necessary to allow their use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Consult your current Banner Safety Products catalog for safety products which meet OSHA, ANSI and IEC standards for personnel protection. Printed in USA 01/09 P/N 139760 rev. A WORLD-BEAM® QS30ELVC Series Overview Amber Output LED Green Power ON LED Configuration Push Buttons The QS30ELVC is an easy-to-use, high-performance retroreflective sensor optimized for detection of clear, translucent, or opaque objects. The optical design of the sensor ensures reliable detection of PET bottles, glass containers, and optically engineered surfaces such as mirrors, LCD glass with polarizing films, or semi-conductor wafers. The sensor will not be tricked by specular reflections from the object under normal operating conditions. Switching Threshold Bargraph Display (Red) The compact housing has a large, easy-to-see bargraph display for easy configuration and status monitoring during operation. The sensor housing can be side-mounted, using integral mounting holes, or front-mounted, via the 30 mm threaded barrel. A wide assortment of mounting brackets are also available for applications requiring adjustability or robust mechanical protection. The QS30ELVC is configured for operation using the Light SET procedure described on page 4. The sensor is simply aligned to the included retroreflective target and the Light SET is initiated either via the push button or the remote wire input. A reliable detection is assured when the appropriate threshold for clear, translucent or dark object is selected. Configuration Display (Amber) Figure 1. Features Continued reliable operation is maintained as the thresholds adapt to changing signal levels over time using Banner Engineering’s auto compensation tracking algorithm. The sensor tracks the amount of light returned at every opportunity and makes fine adjustments to the switching threshold as required due to dust or contamination in the environment building up on the lens window or reflector. If the retroreflector is cleaned, returning the light to its original level, the sensor quickly adapts and continues operating with no need to perform another Light SET procedure. The sensor can recover from a cold power-up by re-using the stored threshold values from the last Light SET procedure. You only need to perform the Light SET procedure if the sensor is moved or the sensor to reflector separation distance is changed. The sensor ships from the factory as a DARK OPERATE (DO), non-polarized retroreflective sensor with auto compensation enabled for easy set-up and reliable operation. The automatic compensation tracking algorithm can be disabled if required through the user SETUP buttons or the remote teach wire. Indicators The sensor’s compact housing has a large, easy-to-see bargraph display plus bright LEDs for easy configuration and status monitoring during operation. Sensor power and output state are indicated by the green and amber LEDs located at the top of the sensor. Sensor configuration is indicated by the 5-segment amber display. Signal strength relative to the switchpoint is indicated by the 3-segment red Signal bargraph (see Figure 2). Clear Medium Dark Received light level is greater than switching threshold Received light level is greater than switching threshold Received light level is greater than switching threshold 8-16% of light SET level is being blocked 16-32% of light SET level is being blocked 32-64% of light SET level is being blocked > 16% of light SET level is being blocked > 32% of light SET level is being blocked > 64% of light SET level is being blocked Figure 2. Signal strength relative to the switchpoint 2    P/N 139760 rev. A Banner Engineering Corp. • Minneapolis, MN U.S.A www.bannerengineering.com • Tel: 763.544.3164 WORLD-BEAM® QS30ELVC Series Applications Clear Bottle or Object Detection 1. Mount the retroreflector. 2. Align the sensor to the retroreflector. 3. Perform Light SET (page 4) with no object present. 4. Using Switchpoint Adjustment (page 6), select the darkest switchpoint which reliably detects the object. Medium level (16% below the signal from the retroreflector) will work for most applications. Dark level will provide more robust detection under difficult environmental conditions (e.g. dust, vibration, etc). Clear Bottle or Object Counting 1. Mount the retroreflector. 2. Align the sensor to the retroreflector. 3. Disable the auto compensation function. Allow for 10 minute sensor warm-up period. 4. Position the bottles or objects so the beam is passing through the gap between the bottles. 5. Perform Light SET (page 4) on the gap condition. 6. Using Switchpoint Adjustment (page 6), select the darkest switchpoint which reliably detects the object. Medium level (16% below the signal from the retroreflector) will work for most applications. Dark level may provide more robust detection under difficult environmental conditions (e.g. dust, vibration, etc). Reflective Object Detection 1. Mount the retroreflector. 2. Align the sensor to the retroreflector. 3. Perform Light SET (page 4) with no object present. 4. Using Switchpoint Adjustment (page 6), select clear or medium switchpoint percentage (8% or 16% below the signal from the retroreflector). This will reduce the chance of specular reflection affecting the sensor.  Banner Engineering Corp. • Minneapolis, MN U.S.A www.bannerengineering.com • Tel: 763.544.3164     P/N 139760 rev. A   3 WORLD-BEAM® QS30ELVC Series Location of switchpoint Single-Point Light SET (+) • Useful for clear object detection and other applications with small variations in contrast. (-) Offset based on selected configuration Output ON • Sets a switchpoint at 8 (clear), 16 (medium) or 32 (dark) percent below the signal from the retroreflector. Darkest (no signal) • Switchpoint position is selectable using the “+” and “-” buttons. Select 8, 16, or 32 percent (Switchpoint Selection). Output OFF Most Light (saturated signal) Sensor Switchpoint Learned Signal from Retro Target • Sensor must be aimed at the reflector during the SET process. All conditions darker than the switchpoint condition result in ON output (Dark Operate). Output ON and OFF conditions can be reversed by changing Light/Dark Operate in SETUP mode (factory setting: Dark Operate). Figure 3. Low-contrast SET (Dark Operate shown) or Set Switchpoint Push Buttons • Align sensor to reflector • Press and hold “+” > 2 seconds Remote • Align sensor to reflector • Single-pulse remote line T Green Power LED: OFF Amber Output LED: ON Bargraph: Top two signal LEDs T T alternate flashing T T T T T T Sensor Feedback Indicators 0.04 seconds ≤ T ≤ 0.8 seconds T T Switchpoint Accepted T Power T LED: ON Green Amber Output LED: ON (LO) or OFF (DO) Bargraph: Appropriate LED ON • Sensor mode T returns T to RUN T T with new settings T T T Switchpoint Unacceptable Green Power LED: ON Amber Output LED: Flashing (Alarm State*) Bargraph: All OFF * See page 6 4    P/N 139760 rev. A Banner Engineering Corp. • Minneapolis, MN U.S.A www.bannerengineering.com • Tel: 763.544.3164 WORLD-BEAM® QS30ELVC Series SETUP Mode SETUP mode is used to change sensor configuration: • Light or Dark operate • Enable or disable automatic compensation algorithm If SETUP mode programming is interrupted and remains inactive for 60 seconds, the sensor returns to RUN mode with the most recent settings (i.e., exits and saves current selection). SETUP mode operates in the “background”, while the outputs are active; changes are updated instantly. The sensor can be configured using the remote line (see page 7). Push Button Result 0.04 seconds ≤ “Click” ≤ 0.8 seconds Access SETUP Mode • Press and hold both push buttons > 2 seconds or flash current setup • Click either push button until LEDs show desired settings Select Setting Combination Green Power LED: OFF Amber Output LED: Remains active Bargraph: Status indicators (LO and AUTO) or Sensor rotates through four setting combinations, in the following order: Setting Combination Auto LED LO LED Auto Compensation ON/DO* ON OFF Auto Compensation ON/LO ON ON Auto Compensation OFF/LO OFF ON Auto Compensation OFF/DO OFF OFF * Factory default setting Return to RUN Mode • Press and hold both push buttons > 2 seconds  Banner Engineering Corp. • Minneapolis, MN U.S.A www.bannerengineering.com • Tel: 763.544.3164 or Green Power LED: ON Amber Output LED: Remains active Bargraph: Indicates current setup • Sensor returns to RUN mode with new settings     P/N 139760 rev. A   5 WORLD-BEAM® QS30ELVC Series Switchpoint Selection The switchpoint can be selected during RUN mode and is accomplished via the push buttons or the remote wire (see Remote Line TEACH, page 7). Switchpoint selection via push buttons: • Press “+” and “-” to select desired switchpoint • Three possible choices; 8, 16 or 32 percent below the signal from the retroreflector. Selection does not wrap around. The sensor continues operating normally with the newly selected threshold value. It is not necessary to repeat the light SET. T T Push Button Disable T T T T T T may T Tbe used to disable In addition to its configuration function, Remote Configuration the push buttons for security. Disabling the push buttons prevents undesired tampering with the configuration settings. The Green Power LED blinks 4 times if a push button is pressed while they are locked out. The sensor continues operating normally and ignores the button press. Connect the gray wire of the sensor as described on page 2, and fourpulse to either enable or disable the push buttons:  T T T T T T T 0.04 < T < 0.8 s Alarm State T T T T The QS30ELVC Alarm State indicates that the sensor requires attention. In all situations,T the alarm byTrealigning the sensor to T canTbe cleared T the retroreflector, cleaning the sensor or retroreflector of contamination, and performing a Light SET to establish a valid light signal. Alarm State is indicated by: • Amber Output LED flashing T T • All 3 Red Signal LEDs OFF • Output forced to blocked state (i.e. if sensor is in dark operate (DO), the output is conducting) The sensor may enter Alarm State for three reasons: 1. The sensor may be in Alarm State when first powered up. This is normal operation and does not indicate a problem with the sensor. The Alarm State will be cleared when a valid Light SET is performed. 2. The sensor will enter Alarm State if the Light SET procedure fails. This indicates the sensor did not receive enough light from the retroreflector for reliable detection. Realign the sensor to the retroreflector, making sure all optical surfaces are free of contamination. If the automatic compensation algorithm is enabled, the sensor may recover at this point and begin operating normally. It is not necessary to repeat the Light SET procedure. If automatic compensation has been disabled, the sensor will remain in the Alarm State until the alignment has been corrected and a Light SET is successfully completed. 3. The sensor can enter Alarm State if the auto compensation algorithm is enabled and the sensor has automatically adjusted the threshold as much as possible. The sensor and retroreflector should be cleaned, or the sensor should be realigned to the retroreflector. The sensor will automatically adapt to the new light level, or a Light SET can be performed to reestablish the light level. In any case, the sensor can be returned to normal operation by ensuring a clean optical path, aligning the sensor to the retroreflector, and performing a Light SET procedure on the sensor. 6    P/N 139760 rev. A Banner Engineering Corp. • Minneapolis, MN U.S.A www.bannerengineering.com • Tel: 763.544.3164 WORLD-BEAM® QS30ELVC Series Remote Line TEACH General Notes • Connect the gray wire of the sensor to ground (0V dc), with a remote programming switch connected between them T • Run Mode is the sensor’s normal operating condition T T T T T • The duration of each Pulse is defined as “T”: 0.04 < T < 0.8 s T T T • A Hold will exit TEACH MODE and return to Run Mode with previously saved changes. The duration of a Hold is: T > 2 s • A Timeout will occur if a condition is not registered within 60 seconds, causing the sensor Tto return to Run Mode (during sensor configuration only) • Sensor configuration user feedback shown on Green LED. See flowT chart below. T T Run Mode Power LED ON, All other LEDs in normal operating condition Exit T 1x T T Light SET T T T T Power LED OFF, Red Signal LED Flashing 2x Basic Configuration Menu Power LED OFF LO and current threshold LEDs Flashing 1x LO LO LED ON DO (default ) LO LED OFF 8% Clear Bottle 2x 3x 4x 16% (default ) Medium Bottle 32% Dark Bottle 5x 2 s Hold 60 second Timeout 3x Advanced Sensor Configuration Menu Power LED OFF Auto LED Flashing 1x Push button enabled (default ) Flash Power 1x, Repeat twice Push button disabled Flash Power 2x, Repeat twice Auto. comp. enabled (default ) Auto LED ON Auto. comp. disabled Auto LED OFF 2x 3x 4x 2 s Hold 60 second Timeout 4x Push button enable /disable (legacy method ) Flash Power: 1x for enabled , Repeat twice 2x for disabled, Repeat twice 8x Restore factory defaults  Banner Engineering Corp. • Minneapolis, MN U.S.A www.bannerengineering.com • Tel: 763.544.3164 All LEDs off for 1 s     P/N 139760 rev. A   7 WORLD-BEAM® QS30ELVC Series Specifications Sensing Beam 660 nm visible red LED Sensing Range and Use 100 mm to 2 m (3.9" to 78"); Light SET for clear object detection Supply Voltage 10 to 30V dc (10% max. ripple) @ 25 mA max current, exclusive of load Supply Protection Circuitry Protected against reverse polarity, over voltage, and transient voltages Delay at Power-Up 250 ms; outputs do not conduct during this time Output Configuration Bipolar: 1 current sourcing (PNP) and 1 current sinking (NPN) Output Ratings 150 mA maximum load; see Application Note 1 OFF-state leakage current: < 50 µA at 30V dc ON-state saturation voltage: NPN: < 200 mV @ 10 mA; < 1V @ 150 mA PNP: < 1.25V @ 10 mA; < 2V @ 150 mA Output Protection Protected against output short-circuit, continuous overload, transient over-voltages, and false pulse on power up Output Response Time 500 microseconds Repeatability 150 microseconds Adjustments 2 push buttons and remote wire •  Easy push-button configuration and deterministic remote wire configuration •  Select from 3 standard thresholds based on object being detected •  Light Operate/Dark Operate configuration options selectable via push buttons or remote wire •  Push-button lockout (from remote wire only) Indicators Green LED: Power ON and feedback on configuration and remote wire pulses Amber LED: Output conducting or error condition (flashing) 3-Segment Red Signal Bargraph: Signal strength (excess gain), relative to switchpoint 5-Segment Amber Display: Sensor Configuration Construction ABS plastic housing; acrylic lens cover Environmental Rating Leakproof design rated IEC IP67 (NEMA 6); PW12 1200 PSI washdown Connections 5-conductor 2 m (6.5’) PVC cable, 9 m (30’) PVC cable, 150 mm (6") pigtail with a 5-pin Euro-style connector, 150 mm (6") PUR cable with 5-pin threaded Euro-Style QD or 5-pin integral Euro-style quick-disconnect fitting Operating Conditions Temperature: -10° to +55°C (+14° to 122°F), Max. relative humidity: 95% @ 50°C (non-condensing) Vibration and Mechanical Shock All models meet Mil. Std. 202F requirements. Method 201A (Vibration: 10 to 60 Hz max. double amplitude 0.06", maximum acceleration 10G). Also meets IEC 947-5-2 requirements: 30G, 11 ms duration, half sine wave. Application Notes 1. If supply voltage is > 24V dc, derate maximum output current 1 mA/°C above 25°C Certifications CE Pending Hookups Cabled Models bn bu wh bk gy Load Load QD Models + 10 - 30V dc – 150 mA max. load Remote Teach bn bu wh bk gy Load Load + 10 - 30V dc – 150 mA max. load Remote Teach Note: Pink wire not used 8    P/N 139760 rev. A Banner Engineering Corp. • Minneapolis, MN U.S.A www.bannerengineering.com • Tel: 763.544.3164 WORLD-BEAM® QS30ELVC Series Dimensions Cabled Models QD Models 35.0 mm (1.38") 22.0 mm (0.87") 32.5 mm (1.28") 12.5 mm (0.49") 3.5 mm (0.14") 1.3 mm (0.05") Receiver 17.6 mm (0.69") 44.0 mm (1.73") 33.0 mm (1.30") 5.0 mm (0.20") 2 x ø3.3 mm (0.125") max. torque 0.7 Nm (6 in lbs) M30 x 1.5 Thread max. torque 6 Nm (53 in lbs) with included 30 mm mounting nut Emitter 28.8 mm (1.13") 13.0 mm (0.51") Hardware Included: (10) M3 x 0.5 x 28 stainless steel machine screws, nuts and washers Accessories Quick-Disconnect Cables Style Model Length 5-pin Euro-style straight MQDC1-506 MQDC1-515 MQDC1-530 2 m (6.5') 5 m (15') 9 m (30') Dimensions Pinout ø 15 mm (0.6") 44 mm max. (1.7") M12 x 1 Blue Wire Black Wire 38 mm max. (1.5") 5-pin Euro-style right-angle MQDC1-506RA MQDC1-515RA MQDC1-530RA 2 m (6.5') 5 m (15') 9 m (30') White Wire Brown Wire Gray Wire 38 mm max. (1.5") M12 x 1 ø 15 mm (0.6")  Banner Engineering Corp. • Minneapolis, MN U.S.A www.bannerengineering.com • Tel: 763.544.3164     P/N 139760 rev. A   9 WORLD-BEAM® QS30ELVC Series Mounting Brackets NOTE: Other sensor models shown on some views below. SMBQS30L • Right-angle bracket for cabled sensors • 14-gauge stainless steel • ± 12° tilt adjustment • Clearance for M4 (#8) hardware SMBQS30LT • Tall right-angle bracket for QD sensors with straight cordset connectors • 14-gauge stainless steel • ± 8° tilt adjustment 20° 20° R35.0 mm R35.0 mm ø4.3 mm 44.0 mm ø4.3 mm 44.0 mm 4.5 mm 4.5 mm 24.0 mm 11.0 mm 24.0 mm 11.0 mm 22.0 mm R1.7 mm 22.0 mm R33.0 mm 91.4 mm 33.0 mm 64.4 mm R33.0 mm 24° 1.9 mm SMBQS30Y 86.4 mm 16 mm 59.4 mm 1.9 mm • Heavy-duty die-cast bracket with M18 vertical mounting option • ± 8° tilt adjustment for cabled sensors • Nuts and lockwasher included SMB30SC 50.8 mm M30 x 1.5 internal • Swivel bracket with 30 mm mounting hole for sensor thread •  Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 58.7 mm 2 X R 33.0 mm 30.0 mm 17.0 mm 4 X Ø 3.3 mm 7.0 mm 66.5 mm 33 mm 56 mm 50.8 mm M30 x 1.5 internal thread 12.7 mm M18 X 1 18.0 mm 26.5 mm 16.35 mm 58.7 mm 30.0 mm 13.3 mm 24.0 mm 35.0 mm 66.5 mm 29.0 mm 12.7 mm Other Compatible Mounting Brackets (see Banner Photoelectric catalog or website for more information): • SMB30MM • SMB30A • SMB30FA 29.0 mm 10    P/N 139760 rev. A Banner Engineering Corp. • Minneapolis, MN U.S.A www.bannerengineering.com • Tel: 763.544.3164 WORLD-BEAM® QS30ELVC Series Retroreflective Targets Banner offers a wide selection of high-quality retroreflective targets. See the Accessories section of your current Banner Photoelectric Sensors catalog for complete information. NOTE: QS30ELVC sensors require corner cube type, large facet retroreflective targets only. Microprism and flexible tape reflectors are not recommended. • Corner-cube reflector • 1.0 reflectivity factor* • Max. temp. +50° C (+122° F) • Supplied with sensor BRT2X2LVC 8.9 mm 51 mm 56 mm 10 mm 51 mm 30 mm BRT40X19A 4.2 mm x 14.2 mm Slot (2) Clear Acrylic Lens • Corner-cube reflector • 1.2 reflectivity factor* • Max. temp. +50° C (+122° F) • Supplied with sensor 19.3 mm 7.3 mm • Corner-cube reflector • 3.0 reflectivity factor* • Max. temp. +50° C (+122° F) • Optional BRT92X92C 100 mm 9 mm 92 mm 100 mm 61 mm 3.5 mm 50.0 mm 92 mm 60.2 mm ø4.0 mm Clear Acrylic Lens White Base 3.5 mm *Reflectivity factor when compared with the standard BRT-3 reflector  Banner Engineering Corp. • Minneapolis, MN U.S.A www.bannerengineering.com • Tel: 763.544.3164     P/N 139760 rev. A   11 WORLD-BEAM® QS30ELVC Series WARRANTY:  Banner Engineering Corp. warrants its products to be free from defects for one year. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture found to be defective at the time it is returned to the factory during the warranty period. This warranty does not cover damage or liability for the improper application of Banner products. This warranty is in lieu of any other warranty either expressed or implied. P/N 139760 rev. A Banner Engineering Corp., 9714 Tenth Ave. No., Minneapolis, MN USA 55441 • Phone: 763.544.3164 • www.bannerengineering.com • Email: sensors@bannerengineering.com
QS30ELVCQ 价格&库存
很抱歉,暂时无法提供与“QS30ELVCQ”相匹配的价格&库存,您可以联系我们找货
