VS2KRN5V
VS2KRN5V
    BANNER(邦纳)
    VS2 SERIES: SENSOR PAIRRANGE
VS2KRN5V 数据手册
VS2 Opposed-Mode Sensors Datasheet Miniature Self-Contained Sensors ER NN BA 2 VS R N5 2A VS • • • • • • • • • Totally self-contained miniature sensors 10 V dc to 30 V dc operation Visible red or infrared sensing beam, depending on model Up to 3 m (118 in) sensing range (see Range specifications) Choose dark or light operate models Choose models with NPN or PNP output 2-wire and 3-wire hookup; output load capacity to 50 mA Choice of integral cable or quick-disconnect Sensors may be purchased in pairs, or individually WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Component Cabled Models1 QD Models 2 Emitter VS25EV VS25EVQ Receiver VS2AN5R VS2AN5RQ Sensor Pair VS2KAN5V VS2KAN5VQ Emitter VS25EV VS25EVQ Receiver VS2AP5R VS2AP5RQ Sensor Pair VS2KAP5V VS2KAP5VQ Emitter VS25EV VS25EVQ Receiver VS2RN5R VS2RN5RQ Sensor Pair VS2KRN5V VS2KRN5VQ Emitter VS25EV VS25EVQ Receiver VS2RP5R VS2RP5RQ Sensor Pair VS2KRP5V VS2KRP5VQ Emitter VS25E VS25EQ Receiver VS2AN5R VS2AN5RQ Sensor Pair VS2KAN5 VS2KAN5Q Emitter VS25E VS25EQ Receiver VS2AP5R VS2AP5RQ Sensor Pair VS2KAP5 VS2KAP5Q Emitter VS25E VS25EQ Receiver VS2RN5R VS2RN5RQ Sensor Pair VS2KRN5 VS2KRN5Q Emitter VS25E VS25EQ Receiver VS2RP5R VS2RP5RQ Sensor Pair VS2KRP5 VS2KRP5Q Sensing Beam/ Range Output Type Supply Voltage NPN/ Light Operate PNP/ Light Operate Visible red, 660 nm 1.2 m (47 in) NPN/ Dark Operate PNP/ Dark Operate 10 V dc to 30 V dc NPN/ Light Operate PNP/ Light Operate Infrared, 940 nm 3.0 m (118 in) NPN/ Dark Operate PNP/ Dark Operate 1 Cabled models have 2 m (6.5 ft) integral cable; 2-wire for emitters, 3-wire for receivers. 2 QD models have 3-pin 150 mm (6.5 in) Pico-style QD. QD models require mating corset. Original Document 57248 Rev. F 26 September 2017 57248 VS2 Opposed-Mode Sensors Overview VS2 Series miniature self-contained sensors are designed for precision sensing in small areas previously accessible only to remote or fiber optic models. Typical applications include mounting inside vibrating feeders and electronic component handling equipment. Wiring Diagrams Emitters NPN Models PNP Models 3 3 – 1 10-30V dc 1 4 + 1 – 10-30 V dc + + 10-30 V dc – 3 4 Load Key 1 = Brown 3 = Blue 4 = Black Load Quick disconnect (QD) wiring diagrams are functionally identical. Specifications Supply Voltage and Current 10 V dc to 30 V dc (10% maximum ripple) Emitter: 25 mA (visible beam); 30 mA (infrared beam) Receiver: 25 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration SPST solid-state switch Choose NPN (current sinking) or PNP (current sourcing) models Choose light operate (N.O.) or dark operate (N.C.) models Output Rating 50 mA maximum Off-state leakage current: < 1 microamp at 24V dc On-state saturation voltage: < 0.25V at 10 mA dc; < 0.5V at 50 mA dc Output Protection Circuitry Protected against output short-circuit, continuous overload, and false pulse on power-up Overload trip point ≥ 100 mA Output Response Time 1 millisecond ON and 0.5 milliseconds OFF Note: 100 millisecond delay on power-up: output is nonconducting during this time Repeatability 100 microseconds Indicators Two LEDs: Green and Amber Green ON = power to sensor is ON Green flashing = output overload Amber ON = light is sensed Amber flashing = marginal excess gain (1–1.5×) in light condition Construction Black ABS housing with clear MABS lens Connections 2 m (6.5 ft) attached cable: three #28 ga stranded conductors with PE insulation; PVC outer cable jacket; or 3-pin 150 mm (6.5 in) Pico-style quick-disconnect fitting. QD cables are ordered separately. Environmental Rating IEC IP67, NEMA 6 Operating Conditions −20 °C to +55 °C (−4 °F to +131°F) 80% at +50 °C maximum relative humidity (non-condensing) Vibration and Mechanical Shock Vibration: All models meet IEC 60068-2-6, IEC 60947-5-2, UL491 Section 40, MILSTD-202F Method 201A; 10 to 60 Hz, 0.5 mm peak to peak Shock: All models meet IEC 60068-2-27, IEC 60947-5-2; 30g peak acceleration, 11 millisecond pulse duration, half-sine wave pulse shape Application Notes M2 stainless steel mounting hardware included. Optional mounting brackets are available Certifications Performance Curves Excess Gain Curves Beam Patterns 1000 E X C E S S G A I N VS2 Series Effective Beam: 3 mm Opposed Mode Visible Red 100 300 mm 12 in Opposed Mode Visible Red 200 mm 8 in 100 mm 4 in 0 10 1 0.01 m 0.4 in 0.10 m 4 in 1.0 m 40 in 0 100 mm 4 in 200 mm 8 in 300 mm 12 in 10.0 m 400 in DISTANCE 2 VS2 Series 0 0.3 m 12 in 0.6 m 24 in 0.9 m 36 in 1.2 m 48 in 1.5 m 60 in DISTANCE www.bannerengineering.com - Tel: +1-763-544-3164 P/N 57248 Rev. F VS2 Opposed-Mode Sensors Excess Gain Curves Beam Patterns 1000 E X C E S S G A I N VS2 Series Effective Beam: 3 mm Opposed Mode Infrared 100 VS2 Series 600 mm 24 in Opposed Mode Infrared 400 mm 16 in 200 mm 8 in 0 10 1 0.01 m 0.4 in 0.10 m 4 in 1.0 m 40 in 0 -200 mm -8 in -400 mm -16 in -600 mm -24 in 10.0 m 400 in 0 DISTANCE 0.75 m 2.5 ft 1.5 m 5 ft 2.25 m 7.4 ft 3.0 m 10 ft 3.75 m 13.1 ft DISTANCE Dimensions 12.0 mm (0.47") Green Power Indicator 8.0 mm (0.31") CL 2.0 mm (0.08") 4.3 mm (0.17") 3.6 mm (0.14") Amber Signal Indicator (Receiver only) 16.7 mm 25.1 mm (0.66") (0.99") 2x ø2.2 mm (0.09") 4.8 mm (0.19") Accessories Quick-Disconnect Cables 3-Pin Threaded M8/Pico-Style Cordsets Model Length PKG3M-2 2 m (6.56 ft) PKG3M-5 5 m (16.40 ft) PKG3M-7 7 m (22.97 ft) PKG3M-9 9 m (29.53 ft) PKG3M-10 10 m (32.81 ft) Style Dimensions Pinout (Female) 4 35 Typ. Straight ø 9.5 M8 x 1 1 3 1 = Brown 3 = Blue 4 = Black Apertures All models are • 0.1 mm 300 series stainless steel. P/N 57248 Rev. F www.bannerengineering.com - Tel: +1-763-544-3164 3 VS2 Opposed-Mode Sensors Model Description APVS2-0204 Two openings, 0.5 (0.02 in) and 1 mm (0.04 in) diameter APVS2-0608 Two openings, 1.5 (0.06 in) and 2.0 (0.08 in) mm diameter APVS2-02R One each, 0.5 mm (0.02 in) wide APVS2-04R One each, 1.0 mm (0.04 in) wide Circular Horizontal and Vertical Slot Brackets SMBVS2RA • Right-angle bracket • Stainless steel Hole center spacing: A = 80.0 14 4 X Ø2.3 20 Hole size: A = 3.2 x 6.0 2 X Ø3.2 20 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
VS2KRN5V 价格&库存
很抱歉,暂时无法提供与“VS2KRN5V”相匹配的价格&库存,您可以联系我们找货
VS2KRN5V
  • 1+1608.637601+208.77180
库存:2
