QS18APWLPQ2
QS18APWLPQ2
    BANNER(邦纳)
    PHOTO SEN RETRO 3.5M P-MOSFET
QS18APWLPQ2 数据手册
WORLD-BEAM® QS18 Universal Voltage Sensors Datasheet • • • • • • Easily fits or retrofits almost any mounting configuration Exceptional optical performance in a compact right-angle housing 20 V ac/dc to 140 V ac/dc or 20 V ac/dc to 270 V ac/dc operation with P-MOSFET or NMOSFET output, depending on model (see Specifications) Bright LED operating status indicators, visible from 360° Rugged, sealed housing, protected circuitry, 1200 PSI washdown Versatile mounting: front- and base-mount (M18), side-mount, and retrofit brackets WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Model Sensing Mode / LED Output Type 1 Sensing Range QS18WE QS18ANWR QS18RNWR QS18APWR N/A (Emitter) L.O. 940 nm Infrared 20 m (66 ft) Effective Beam: 10 mm (0.4 in) OPPOSED D.O. L.O. QS18RPWR D.O. QS18ANWLP L.O. QS18RNWLP D.O. QS18APWLP 660 nm Visible Red P 3.5 m (12 ft) POLAR RETRO QS18RPWLP L.O. D.O. QS18ANWLV L.O. QS18RNWLV D.O. QS18APWLV 660 nm Visible Red 6.5 m (21 ft) RETRO L.O. QS18RPWLV D.O. QS18ANWDL L.O. QS18RNWDL QS18APWDL 624 nm Visible Red 450 mm (18 in) DIFFUSE D.O. L.O. QS18RPWDL D.O. QS18ANWDXL L.O. QS18RNWDXL D.O. QS18APWDXL 850 nm Infrared 1 m (39 in) DIFFUSE QS18RPWDXL L.O. D.O. N-MOSFET (Sinking) P-MOSFET (Sourcing) N-MOSFET (Sinking) P-MOSFET (Sourcing) N-MOSFET (Sinking) P-MOSFET (Sourcing) N-MOSFET (Sinking) P-MOSFET (Sourcing) N-MOSFET (Sinking) P-MOSFET (Sourcing) The standard 2 m (6.5 ft) cable models are listed. To order the 9 m (30 ft) cable models, add the suffix "W/30" to the cabled model number. (for example, QS18WE W/30) QD models: To order models with a 150 mm (6 in) pigtail cable with 4-pin AC Micro-style QD, add suffix “Q2” to the model number (for example, QS18WEQ2). A model with a QD connector requires an accessory mating cordset. 600 V cable models: Standard models are supplied with 300 V cable. For 600 V cable, add suffix “C1” to the model number (for example, QS18WEC1). 1 MOSFET: Metal oxide semiconductor field-effect transistor. Original Document 136003 Rev. F 6 January 2017 136003 WORLD-BEAM® QS18 Universal Voltage Sensors Indicators 1. Green: Power Indicator 2. Amber: Output Indicator 3. Sensitivity (Gain) Potentiometer Wiring Diagrams Cabled Models Quick Disconnect (QD) Models 1 = Brown 3 = Blue 4 = Black (no connection for emitters) 1 2 3 4 = = = = Red/Black Red/White Red (no connection for emitters) Green (no connection for emitters) Emitter Emitter 1 1 L1 (DC+) L2 (DC–) 4 P-MOSFET P-MOSFET L1 (DC+) 3 2 Load 3 L2 (DC–) 4 N-MOSFET 2 L1 (DC+) Load L2 (DC–) No Connection N-MOSFET 1 1 3 No Connection 1 1 4 L2 (DC–) 3 3 4 L1 (DC+) 2 L1 (DC+) 3 2 Load 4 L2 (DC–) www.bannerengineering.com - Tel: +1-763-544-3164 L1 (DC+) Load L2 (DC–) No Connection P/N 136003 Rev. F WORLD-BEAM® QS18 Universal Voltage Sensors Specifications Supply Voltage P-MOSFET Models: 20 to 140 V ac/dc at less than 10 mA, exclusive of load N-MOSFET Models: 20 to 270 V ac/dc at less than 10 mA, exclusive of load Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Single Discrete Output, 100 mA load rating; N-MOSFET or P-MOSFET, depending on model number; Light Operate or Dark Operate, depending on model number Output Rating Rating: 100 mA with short circuit protection Off-state leakage current: less than 400 µA ON-state saturation voltage: P-MOSFET: 2.75 V; N-MOSFET: 2.5 V Output Protection Circuitry Protected against output short-circuit and false pulse on power up. Latching short-circuit protection; reset by cycling power. Delay at power up; outputs do not conduct during this time: 100 ms max. dc, 300 ms max. ac Required Overcurrent Protection Output Response Opposed mode: 16.6 ms (1 cycle at 60 Hz) All other modes: 8.3 ms (1/2 cycle at 60 Hz) Repeatability 1.5 ms Indicators 2 LED indicators on sensor top: Green solid: Power on Green flashing: Sensor output short circuit Amber solid: Light sensed Amber flashing: Marginal excess gain (1 to 1.5x excess gain) Adjustments Diffuse, Retroreflective and Polarized Retroreflective models only: 1turn potentiometer Sensitivity (Gain) adjustment Construction ABS housing, PMMA lens, Acetal Gain Adjuster Connections 2 m (6.5 ft) 3-conductor, 22 AWG PVC cable (300 V ac), or 150 mm (6 in) pigtail PVC cable with 4-pin threaded Micro-style connector; “C1” suffix models: 2 m (6.5 ft) 3-conductor, 22 AWG PVC cable (600 V ac). Environmental Rating IEC IP67; NEMA 6; UL Type 1 1200 PSI washdown; NEMA ICS5, Annex F-2002 (PW12) WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Operating Conditions Relative Humidity: 95% at 55 °C (non-condensing) Temperature: Less than 140 V ac/dc: −25 °C to 70 °C (−13 °F to 158 °F) (N-MOSFET and P-MOSFET models) 140 V ac/dc or greater: −25 °C to 55 °C (−13 °F to 131 °F) (NMOSFET models only) Certifications IND. CONT. EQ. Dimensions 10.2 mm 0.40" 7.5 mm 0.30" 5.2 mm 0.20" 17.3 mm 0.68" 80.5 mm 3.17" 3.8 mm 0.15" 24.1 mm 0.95" 5 mm 0.2" 36 mm 1.42" M18 X 1-6g Max. torque 2.3 Nm (20 in-lbs) 79.9 mm 3.15" 2X Ø3.3 mm 0.13" Max. torque 0.6 Nm (5 in-lbs) M18 X 1-6g Max. torque 2.3 Nm (20 in-lbs) 14.5 mm 0.57" All measurements are listed in millimeters [inches], unless noted otherwise. P/N 136003 Rev. F www.bannerengineering.com - Tel: +1-763-544-3164 3 WORLD-BEAM® QS18 Universal Voltage Sensors Packing List Sensor M18 × 1 jam nut M3 hardware packet Datasheet 24.2 mm (0.95") M3 Hardware Packet Contents 2 – M3 × 0.5 × 20 mm SS Screw 2 – M3 × 0.5 SS Hex Nut 2 – M3 SS Washer 8.0 mm (0.32") Performance Curves Opposed Mode Excess Gain Beam Pattern 1000 QS186E and QS18...R EXCESS GAIN Opposed Mode QS186E and QS18...R 750 mm 100 30 in Opposed Mode 500 mm 20 in 250 mm 10 in 0 10 0 250 mm 10 in 500 mm 20 in 750 mm 30 in 1 0.1 m (0.3') 1m (3.3') 0 100 m (330') 10 m (33') 4m 12 ft 8m 26 ft 12 m 40 ft 16 m 52 ft 20 m 66 ft DISTANCE DISTANCE Polarized Retroreflective Excess Gain Beam Pattern 1000 QS18...LP EXCESS GAIN Retroreflective Mode QS18...LP 30 mm 100 20 mm with BRT-84 Reflector 0.4 in with BRT-84 Reflector 0 0 0.1 m 0.33 ft 1m 3.3 ft 10 m 33 ft 10 mm 0.4 in 20 mm 0.8 in 30 mm 1.2 in 0 DISTANCE 4 0.8 in Retroreflective Mode 10 mm 10 1 0.01 m 0.03 ft 1.2 in .75 m 2.5 ft 1.5 m 5 ft 2.25 m 7.5 ft 3.0 m 10 ft 3.75 m 12.5 ft DISTANCE www.bannerengineering.com - Tel: +1-763-544-3164 P/N 136003 Rev. F WORLD-BEAM® QS18 Universal Voltage Sensors Retroreflective Excess Gain Beam Pattern 1000 QS18...LV EXCESS GAIN Retroreflective Mode QS18...LV 150 mm 100 6 in Retroreflective Mode 100 mm 4 in 50 mm 2 in with BRT-84 Reflector 0 10 with BRT-84 Reflector 1 0.01 m 0.03 ft 0.1 m 0.33 ft 2 in 100 mm 4 in 150 mm 6 in 0 10 m 33 ft 1m 3.3 ft 0 50 mm 1.5 m 5 ft 3.0 m 10 ft 4.5 m 15 ft 6.0 m 20 ft 7.5 m 25 ft DISTANCE DISTANCE Diffuse (performance based on 90% performance white test card) Excess Gain Beam Pattern 1000 EXCESS GAIN QS18A..WDL QS18A..WDL 6 mm 100 4 mm 0.15" 2 mm 0.07" 0 10 1 1 mm 0.04" 10 mm 0.4" 100 mm 4" 0.23" 0 2 mm 0.07" 4 mm 0.15" 6 mm 0.23" 1000 mm 40" 0 DISTANCE 100 mm 200 mm 300 mm 400 mm 500 mm (4") (8") (12") (16") (20") DISTANCE 1000 QS18A..WDXL QS18A..WDXL EXCESS GAIN 15 mm 100 10 mm 0.2" 0 1 1 mm 0.04" P/N 136003 Rev. F 0.4" 5 mm 10 10 mm 0.4" 100 mm 4" DISTANCE 1000 mm 40" 0.6" 0 5 mm 0.2" 10 mm 0.4" 15 mm 0.6" 0 200 mm 400 mm 600 mm 800 mm 1000 mm (8") (16") (24") (32") (40") www.bannerengineering.com - Tel: +1-763-544-3164 DISTANCE 5 WORLD-BEAM® QS18 Universal Voltage Sensors Accessories Cordsets 4-Pin Micro-Style Cordsets Model Length MQAC-406 1.83 m (6 ft) MQAC-415 4.57 m (15 ft) Style Dimensions 3 42 Typ. 2 Straight MQAC-430 Pinout (Female) 1/2-20 UNF-28 ø 14.5 9.14 m (30 ft) 4 1 1 = Red/Black 2 = Red/White 3 = Red 4 = Green Mounting Brackets SMB18A • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware SMBQS18WRS 30 C A • Retrofit bracket for Universal voltage models; sensor base threads into bracket, bracket bolts to flat surface • PBT construction • Clearance for M3 or #6-32 hardware 41 B 46 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 Other sensor model shown with bracket above. Refer to your current Banner catalog for more mounting bracket options, including: SMB312S, SMB18SF, SMB3018SC, SMB18FA. Retroreflective Targets Banner offers a wide selection of high-quality retroreflective targets. See www.bannerengineering.com for complete information. NOTE: Polarized sensors require corner cube type retroreflective targets. Non-polarized sensors may use any retroreflective target. 6 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 136003 Rev. F WORLD-BEAM® QS18 Universal Voltage Sensors Apertures Model Description Pieces Circular APQS18-020 0.5 mm dia. 6 APQS18-040 1.0 mm dia. 6 APQS18-100 2.5 mm dia. 6 APQS18-020H 0.5 × 6.4 mm 6 APQS18-040H 1.0 × 6.4 mm 6 APQS18-100H 2.5 × 6.4 mm 6 APQS18-020V 0.5 × 12.7 mm 6 APQS18-040V 1.0 × 12.7 mm 6 APQS18-100V 2.5 × 12.7 mm 6 Horizontal Slot Vertical Slot Kit APQS18-DVHX2 2 of each aperture 18 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
QS18APWLPQ2 价格&库存
很抱歉,暂时无法提供与“QS18APWLPQ2”相匹配的价格&库存,您可以联系我们找货
QS18APWLPQ2
  • 1+1342.254531+172.15856
