VS2 Convergent Mode Sensor
Datasheet
Low Profile Miniature Self-Contained Sensors
Extremely low profile self-contained miniature
Visible red sensing beam
10 v dc to 30 v dc supply voltage
NPN or PNP output, depending on model
15 mm or 30 mm convergent point, depending on model
Available in dark- or light- operate models
WARNING: Not To Be Used for Personnel Protection
Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death.
This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety
applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output
condition.
Models
Model1
Output Type
VS2AN5CV15
NPN Light Operate
VS2RN5CV15
NPN Dark Operate
VS2AP5CV15
PNP Light Operate
VS2RP5CV15
PNP Dark Operate
VS2AN5CV30
NPN Light Operate
VS2RN5CV30
NPN Dark Operate
VS2AP5CV30
PNP Light Operate
VS2RP5CV30
PNP Dark Operate
Range
Supply Voltage
15 mm (0.6 inch) ±5 mm
10 V dc to 30 V dc
30 mm (1.2 inch) ±10 mm
Overview
VS2 Series miniature self-contained sensors are designed for precision sensing in small areas previously accessible only to remote or
fiber optic models. Typical applications include mounting inside vibrating feeders and electronic component handling equipment.
1
Integral 2 m (6.5 ft) unterminated cable models are listed.
• To order the 3-pin M8/Pico-style integral quick disconnect model, add the suffix "Q" to the model number. For example, VS2AN5CV15Q.
• Models with a quick disconnect require a mating cordset.
Original Document
65411 Rev. B
1 November 2017
65411
Wiring Diagrams
NPN
PNP
3
4
1
10-30 V dc
1
10-30 V dc
3
4
Load
Load
Specifications
Supply Voltage and Current
10 V dc to 30 V dc (10% max. ripple) at less than 25 mA (exclusive of load)
Supply Protection Circuitry
Protected against reverse polarity and transient voltages
Output Configuration
SPST solid-state switch
Choose NPN or PNP models
Choose light operate or dark operate models
Indicators
Two LEDs: Green and Amber
Green ON = power to sensor is ON
Green flashing = output overload
Amber ON = light is sensed
Construction
Black ABS housing with acrylic lens
Output Rating
50 mA maximum
Off-state leakage current: < 1 microamp at 24 V dc
On-state saturation voltage: < 0.25 V at 10 mA dc; < 0.5 V at 50 mA dc
Output Protection Circuitry
Protected against output short-circuit, continuous overload, and false pulse on
power-up
Overload trip point ≥ 100 mA
Output Response Time
1 millisecond ON and OFF
Note: 150 millisecond delay maximum on powerup: output does not conduct during this time
Connections
2 m (6.5 in)PVC integral cable: three #28 ga stranded conductors with PE
insulation; 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick
disconnect (QD). Quick disconnect cables are ordered separately.
Environmental Rating
IEC IP67; NEMA 6
Operating Conditions
–20 °C to +55 °C (–4 °F to +131°F)
80% at +50 °C maximum relative humidity (non-condensing)
Vibration and Mechanical Shock Vibration and Mechanical Shock
Vibration: All models meet IEC 60068-2-6, IEC 60947-5-2, UL491 Section 40,
MIL-STD-202F Method 201A; 10 to 60 Hz, 0.5 mm peak to peak
Shock: All models meet IEC 60068-2-27, IEC 60947-5-2; 30g peak acceleration,
11 millisecond pulse duration, half-sine wave pulse shape
Application Notes
M2 stainless steel mounting hardware included. Optional mounting brackets
are available.
Repeatability
160 microseconds
Certifications
Dimensions
12.0 mm
(0.47")
Green Power
Indicator
VS2CV30 VS2CV15
21.2 mm 20.6 mm
(0.84")
(0.81")
4.8 mm
(0.19")
2
10.9 mm
(0.43")
CL
8.0 mm
(0.31")
2.0 mm
(0.08")
Amber
Signal Indicator
(Receiver only)
3.6 mm
(0.14")
4.7 mm
(0.19")
25.1 mm
(0.99")
2x ø2.2 mm
(0.09")
www.bannerengineering.com - Tel: +1-763-544-3164
P/N 65411 Rev. B
Performance Curves
Excess Gain Curve — 15 mm Models
Beam Pattern — 15 mm Models
1000
E
X
C
E
S
S
100
VS2CV15
6 mm
Convergent Mode
4 mm
VS2CV15
0.24 in
0.16 in
Convergent Mode
2 mm
0.08 in
G
A
I
N
10
1
1 mm
0.04 in
2 mm
0.08 in
4 mm
0.16 in
6 mm
0.24 in
10 mm
0.4 in
100 mm
4 in
20 mm
.8 in
1000 mm
40 in
40 mm
1.6 in
60 mm
2.4 in
80 mm
3.2 in
100 mm
4.0 in
DISTANCE
DISTANCE
Excess Gain Curve — 30 mm Models
Beam Pattern — 30 mm Models
1000
E
X
C
E
S
S
G
A
I
N
0.36 in
6 mm
Convergent Mode
100
VS2CV30
9 mm
VS2CV30
0.24 in
Convergent Mode
3 mm
0.12 in
1
1 mm
0.04 in
3 mm
0.12 in
6 mm
0.24 in
9 mm
0.36 in
10 mm
0.4 in
100 mm
4 in
1000 mm
40 in
40 mm
1.6 in
80 mm
3.2 in
120 mm
4.8 in
160 mm 200 mm
6.4 in
8.0 in
DISTANCE
DISTANCE
Accessories
Quick-Disconnect Cables
3-Pin Threaded M8/Pico-Style Cordsets
Model
Length
PKG3M-2
2 m (6.56 ft)
PKG3M-5
5 m (16.40 ft)
PKG3M-7
7 m (22.97 ft)
PKG3M-9
9 m (29.53 ft)
PKG3M-10
10 m (32.81 ft)
P/N 65411 Rev. B
Style
Dimensions
Pinout (Female)
4
35 Typ.
Straight
M8 x 1
1
3
ø 9.5
1 = Brown
3 = Blue
4 = Black
3
Brackets
SMBVS2RA
• Right-angle bracket
• Stainless steel
Hole center spacing: A = 80.0
14
4 X Ø2.3
2 X Ø3.2
Hole size: A = 3.2 x 6.0
Banner Engineering Corp. Limited Warranty
Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or
replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover
damage or liability for misuse, abuse, or the improper application or installation of the Banner product.
THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE.
This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY
OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT
DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE.
Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously
manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the
product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the
product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time.
Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to:
www.bannerengineering.com.
© Banner Engineering Corp. All rights reserved
很抱歉,暂时无法提供与“VS2RP5CV15Q”相匹配的价格&库存,您可以联系我们找货
