HTB18L-B4A5BAD04
HTB18L-B4A5BAD04
    SICK
    SENSOR 100MM NPN/PNP LO M12
HTB18L-B4A5BAD04 数据手册
Product data sheet HTB18L-B4A5BAD04 SureSense HYBRID PHOTOELECTRIC SENSORS HTB18L-B4A5BAD04 | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. HTB18L-B4A5BAD04 1079103 Other models and accessories www.sick.com/SureSense Illustration may differ Detailed technical data Features Device type Photoelectric sensors Sensor/ detection principle Photoelectric proximity sensor, Background suppression Dimensions (W x H x D) 16.2 mm x 48.5 mm x 31.8 mm Housing design (light emission) Hybrid Thread diameter (housing) M18 Mounting system type M18, nose / side (24.1 … 25.4 mm) Housing color Blue Sensing range max. 30 mm ... 300 mm 1) Sensing range 30 mm ... 250 mm 2) Type of light Visible red light Light source Laser 3) 4) Light spot size (distance) 2 mm (120 mm) Wave length 655 nm Laser class I Adjustment Potentiometer, right None Potentiometer, left None Special applications 1) 2) 3) 4) Detecting small objects  Object with 90 % reflectance (referred to standard white, DIN 5033).  Object with 6 % reflectance (referred to standard black, DIN 5033).  Average service life: 50,000 h at TU = +25 °C.  CLASS 1 LASER PRODUCT EN60825-1:2014, IEC60825-1:2014, Maximum pulse power < 2,5 mW, Pulse length: 4 μs, Wavelength: 650 ... 670 nm, Complies with 21 CFR 1040.10 and 1040.11 except for deviations pursuant to Laser Notice No. 50, dated June 24, 2007. 2 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice HTB18L-B4A5BAD04 | SureSense HYBRID PHOTOELECTRIC SENSORS Special features 1) 2) 3) 4) Signal strength light bar Sensing range pre-set: 100 mm  Object with 90 % reflectance (referred to standard white, DIN 5033).  Object with 6 % reflectance (referred to standard black, DIN 5033).  Average service life: 50,000 h at TU = +25 °C.  CLASS 1 LASER PRODUCT EN60825-1:2014, IEC60825-1:2014, Maximum pulse power < 2,5 mW, Pulse length: 4 μs, Wavelength: 650 ... 670 nm, Complies with 21 CFR 1040.10 and 1040.11 except for deviations pursuant to Laser Notice No. 50, dated June 24, 2007. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC Ripple –10 °C. Sensor cannot be turned on below Ta= –10 °C. 2021-12-08 22:34:56 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 3 HTB18L-B4A5BAD04 | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Safety-related parameters MTTFD 282.7 years DCavg 0 % Classifications ECl@ss 5.0 27270904 ECl@ss 5.1.4 27270904 ECl@ss 6.0 27270904 ECl@ss 6.2 27270904 ECl@ss 7.0 27270904 ECl@ss 8.0 27270904 ECl@ss 8.1 27270904 ECl@ss 9.0 27270904 ECl@ss 10.0 27270904 ECl@ss 11.0 27270904 ETIM 5.0 EC002719 ETIM 6.0 EC002719 ETIM 7.0 EC002719 ETIM 8.0 EC002719 UNSPSC 16.0901 39121528 Connection/pin assignment Connection type Male connector M12, 4-pin PIN assignment BN 1 + (L+) WH 2 Q2 BU 3 - (M) BK 4 Q1 4 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice HTB18L-B4A5BAD04 | SureSense HYBRID PHOTOELECTRIC SENSORS Dimensional drawing (Dimensions in mm (inch)) 16.2 (0.64) 31.4 (1.24) 10.1 (0.40) D 10.5 (0.41) B 4 7.5 (0.30) 25.4 (1.00) 24.1 (0.95) 12.7 3 (0.34) 8.6 C (0.50) 48.5 (1.91) A M12 x 1 0.9 (0.04) 2 15 (0.59) 5 M18 x 1 1 ①  LED indicator yellow: Status of received light beam ②  LED indicator green: power on ③  M3 mounting hole ④  Snap Connection for flush ring (sold seperatly) ⑤  Potentiometer (if selected) or LED Indicators Dimensions in mm (inch) Receiver Sender A B C D HTB18 / HTF18 - 1.1 (0.04) 1.1 (0.04) 4.7 (0.19) 0.6 (0.02) HTE18 / HL18 / HSE18 2.5 (0.1) 0.0 (0.0) 4.0 (0.16) 0.0 (0.0) HTB18L / HTF18L / HL18L / HSE18L 2.5 (0.1) 0.0 (0.0) 3.5 (0.14) 0.0 (0.0) Connection type See table: Connection/Pin assignment 2 1 3 4 2021-12-08 22:34:56 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 HTB18L-B4A5BAD04 | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F Adjustments possible 2 1 3 ①  LED indicator yellow: Status of received light beam ②  LED indicator green: power on ③  Signal strength light bar Characteristic curve % of sensing range H I J K L M N O P Q R S T 20 15 10 20%/90% 2 6%/90% 1 5 90%/90% 3 0 0 50 100 150 200 250 300 (1.97) (3.94) (5.91) (7.87) (9.84) (11.81) Distance in mm (inch) ①  Sensing range on black, 6% remission ②  Sensing range on gray, 20 % remission ③  Sensing range on white, 90% remission 6 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice HTB18L-B4A5BAD04 | SureSense HYBRID PHOTOELECTRIC SENSORS Light spot size mm (inch) 3 (0.14) 2 (0.08) 1 (0.04) 0 –1 (0.04) –2 (0.08) –3 (0.14) 0 100 200 300 (3.94) (7.87) (11.81) Distance in m (feet) horizontal vertical Sensing range diagram 1 30 250 2 3 30 250 300 30 250 300 0 50 100 150 200 250 300 (1.97) (3.94) (5.91) (7.87) (9.84) (11.81) Distance in mm (inch) Sensing range Sensing range max. ①  Sensing range on black, 6% remission ②  Sensing range on gray, 20 % remission ③  Sensing range on white, 90% remission Functions Set switching point Sensing range min. Sensing range max. 100 % 100 % 100 % 100 % 100 % 100 % 100 % 100 % 0% 0% 0% 0% 0% 0% 0% 0% 2021-12-08 22:34:56 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 7 HTB18L-B4A5BAD04 | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Recommended accessories Other models and accessories www.sick.com/SureSense Brief description Type Part no. YF2A14050VB3XLEAX 2096235 STE-1204-G 6009932 Plug connectors and cables Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M12, 4-pin, straight Head B: Cable: unshielded 8 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
HTB18L-B4A5BAD04 价格&库存
很抱歉,暂时无法提供与“HTB18L-B4A5BAD04”相匹配的价格&库存,您可以联系我们找货
