KTS-WB9414115AZZZZ
KTS-WB9414115AZZZZ
    SICK
    SENSOR 13MM PUSH-PULL
KTS-WB9414115AZZZZ 数据手册
Product data sheet KTS-WB9414115AZZZZ KTS Prime CONTRAST SENSORS KTS-WB9414115AZZZZ | KTS Prime CONTRAST SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. KTS-WB9414115AZZZZ 1218831 Other models and accessories www.sick.com/KTS_Prime Illustration may differ Detailed technical data Features Special applications Standard Device type Standard Dimensions (W x H x D) 26 mm x 62 mm x 47.5 mm Sensing distance 13 mm Sensing distance tolerance ± 3 mm Housing design (light emission) Middle Light source LED, RGB 1) Wave length 470 nm, 525 nm, 625 nm Light emission Long side of housing Light spot size Ø 0.9 mm Light spot direction Round Receiving filters None Teach-in mode 1-point teach-in, 2-point teach-in, teach-in dynamic, auto mode Output function Light/dark switching Delay time Adjustable Special features - Delivery status 2-point teach-in Parameter presettings None 1) 2  Average service life: 100,000 h at TU = +25 °C. REGISTRATION SENSORS | SICK Product data sheet | 2021-11-05 11:19:54 Subject to change without notice KTS-WB9414115AZZZZ | KTS Prime CONTRAST SENSORS Mechanics/electronics Supply voltage 10.8 V DC ... 28.8 V DC 1) Ripple ≤ 5 Vpp 2) Current consumption 10 s. The Q-LED (yellow) flashes and the “Err” error message appears on the display. 2021-11-05 11:19:54 | Product data sheet  Subject to change without notice REGISTRATION SENSORS | SICK 7 KTS-WB9414115AZZZZ | KTS Prime CONTRAST SENSORS A B C D E F Sensing distance Sensing distance 13 mm, light spot direction round Sensitivity in % 110 100 90 80 70 60 50 40 30 20 10 0 0 4 8 12 16 20 (0.16) (0.31) (0.47) (0.63) (0.79) Distance in mm (inch) H I J K L M N O P Q R S T Recommended accessories Other models and accessories www.sick.com/KTS_Prime Brief description Type Part no. Plate K for universal clamp bracket, steel, zinc coated, Universal clamp (2022726), mounting hardware BEF-KHS-K01 2022718 Mounting bar, straight, 200 mm, steel, steel, zinc coated, without mounting hardware BEF-MS12G-A 4056054 Mounting bar, L-shaped, 150 mm x 150 mm, steel, steel, zinc coated, without mounting hardware BEF-MS12L-A 4056052 YF2A15050VB5XLEAX 2096240 STE-1205-G 6022083 Universal bar clamp systems Plug connectors and cables Head A: female connector, M12, 5-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M12, 5-pin, straight Cable: unshielded For field bus technology 8 REGISTRATION SENSORS | SICK Product data sheet | 2021-11-05 11:19:54 Subject to change without notice KTS-WB9414115AZZZZ | KTS Prime CONTRAST SENSORS Brief description Type Part no. • Further functions: USB connection for easy configuration of the SIG200 Sensor Integration Gateway with SOPAS ET, the engineering tool from SICK, logic editor is available for easy configuration of logic functions • Connection CONFIG: 1 x M8, 4-pin female connector, USB 2.0 (USB-A) • Logic editor: yes • Communication interface: IO-Link, USB, Ethernet, PROFINET, REST API • Product category: IO-Link Master SIG200-0A0412200 1089794 • Further functions: USB connection for easy configuration of the SIG200 Sensor Integration Gateway with SOPAS ET, the engineering tool from SICK, logic editor is available for easy configuration of logic functions • Connection CONFIG: 1 x M8, 4-pin female connector, USB 2.0 (USB-A) • Logic editor: yes • Communication interface: IO-Link, USB, Ethernet, REST API • Product category: IO-Link Master SIG200-0A0G12200 1102605 Sensor Integration Gateway 2021-11-05 11:19:54 | Product data sheet  Subject to change without notice REGISTRATION SENSORS | SICK 9 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
KTS-WB9414115AZZZZ 价格&库存
很抱歉,暂时无法提供与“KTS-WB9414115AZZZZ”相匹配的价格&库存,您可以联系我们找货
