VT18-8-400-M/40A/118/128
    PEPPERL+FUCHS(倍加福)
    DIFFUSED PHOTO SEN 0-400MM
VT18-8-400-M/40A/118/128 数据手册
Diffuse mode sensor VT18-8-400-M/40a/118/128 < Array control panel with highly visible LED display < Flashing power on LED in case of short-circuit < Multiple device installation possible, no mutual interference (no cross-talk) < Not sensitive to ambient light, even with switched energy saving lamps < Protection class II Diffuse mode sensor, M18 threaded housing design, metal housing, 400 mm detection range, red light, sensitivity adjuster, light/dark on, push-pull output, M12 plug Dimensions 4 Detail "A" M18 x 1 24 2 43.8 44.6 47.1 53.9 78 Detail "A" Indicating/ Operating means 7.8 L 11.2 D Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 801132_eng.pdf 65 LED yellow Light/dark switch SENS. LED green Sensing range adjuster Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Unit connector 2 1 3 4 1 Diffuse mode sensor VT18-8-400-M/40a/118/128 Technical Data General specifications Detection range 0 ... 400 mm , adjustable Detection range min. 0 ... 25 mm Detection range max. 0 ... 400 mm Light source LED Light type modulated visible red light 660 nm Diameter of the light spot approx. 4 mm at a distance of 120 mm Optical face frontal Ambient light limit Hysteresis 30000 Lux H < 15 % Functional safety related parameters MTTFd 700 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Indicators/operating means Operation indicator LED green, flashes in case of short-circuit Function indicator LED yellow, lights up with receiver lit Control elements Sensing range adjuster, light-on/dark-on changeover switch Electrical specifications Operating voltage UB Ripple No-load supply current 10 ... 30 V DC , class 2 10 % I0 Protection class < 30 mA II , rated voltage ≤ 50 V AC with pollution degree 1-2 according to IEC 60664-1 Output Switching type light/dark on, switchable Signal output Push-pull output, short-circuit protected, reverse polarity protected Switching voltage 30 V DC Switching current Switching frequency Response time max. 200 mA f 500 Hz 1 ms Conformity Product standard EN 60947-5-2 Approvals and certificates CE conformity yes UL approval cULus Listed, Type 1 enclosure CCC approval CCC approval / marking not required for products rated ≤36 V Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 801132_eng.pdf Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Storage temperature -30 ... 70 °C (-22 ... 158 °F) Mechanical specifications Degree of protection IP67 Connection 4-pin, M12 x 1 connector Material Housing brass, nickel-plated Optical face PMMA Mass 60 g Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Diffuse mode sensor VT18-8-400-M/40a/118/128 Connection Assignment Option: 1 +UB 2 n. c. 3 0V 4 Q /128 = Light on = Dark on Characteristic Curve Characteristic response curve VT18-8-400 Offset Y [mm] 15 10 5 0 -5 -10 -15 0 50 100 150 200 250 300 350 400 450 Distance X [mm] y x VT18-8-400 Relative received light strength Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 801132_eng.pdf Stability control 25 20 15 10 5 0 0 50 x 100 150 200 250 300 350 400 450 Distance X [mm] white 90 % grey 18 % black 6 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Diffuse mode sensor VT18-8-400-M/40a/118/128 Detection ranges VT18-8-400 Object colour black grey white 0 50 100 150 200 250 300 350 400 450 Distance [mm] x VT18-8-400 Emission divergence Light spot diameter [mm] 35 30 25 20 15 10 5 0 50 100 150 200 250 300 350 400 450 Distance X [mm] Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 801132_eng.pdf 0 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4 Diffuse mode sensor VT18-8-400-M/40a/118/128 Configuration Sensitivity adjustment • Turn sensitivity adjuster (counterclockwise) to minimum position. optimal setting position A position B yellow LED L • Place the object to be detected in the sensing range and turn the sensitivity adjuster clockwise until the yellow indication LED lights up. This setting indicates the position A of the sensitivity adjuster. D • Remove the object. Increase the sensitivity slowly (turning the sensitivity adjuster clockwise) until the yellow LED lights up again. This setting indicates the position B of the sensitivity adjuster. Note: In case of no background object, the LED won’t light up, even in MAX. adjustment. In that case take care, that in normal operation conditions no temporal background object light/dark switch can appear in the sensing range (e. g. parked pallets). If this can not be excluded, place (only for adjustment matter) an object at the appropriate location. Then repeat this adjustment step. After finishing the adjustment this temporal object should be removed. SENS. sensitivity adjuster Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 801132_eng.pdf • For optimal setting, now turn the sensitivity adjuster to the middle position between the positions A and B. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 5
VT18-8-400-M/40A/118/128 价格&库存
很抱歉,暂时无法提供与“VT18-8-400-M/40A/118/128”相匹配的价格&库存,您可以联系我们找货
