PD140FNT60QMU-02C
PD140FNT60QMU-02C
    CARLOGAVAZZI
    SENSOR THROUGH-BEAM 60M SPDT
PD140FNT60QMU-02C 数据手册
 PD140FNT60QMU-02C Through Beam Main features • • • • • • • Description The PD140 sensor consists of an emitter, which sends out invisible, infrared light, and a receiver, capable of detecting the light from the emitter. The sensor is encapsulated in a robust, vandalproof aluminium/polycarbonate housing. The lenses are adjustable in both ±100° horizontal and ± 15° vertical directions, which allows flexible mounting, even when emitter and receiver are mounted at different heights. The aspherical lens design gives a superior homogeneous light beam over the total beam angle. - Sensor test function: the emitter has a built-in test input designed to mute the emitter and thus evaluate the sensor function. The test function is to be controlled and monitored by the door controller. 06/03/2017 PD140FNT60QMU-02C ENG • • • • • • • • Designed for Industrial doors and gates ESPE type 2, Performance level d For door or gate widths up to 60 m Modulated, infrared light Supply voltage: 12 to 24 VAC/DC 1 A, SPDT relay output Analogue voltage output or flashing LED indication for optical alignment help Built-in holder for green laser alignment accessory tool Yellow LED for output indication Green LED indication for power ON Connection: self-lifting terminal block, 1,5 mm2 (AWG 16) Emitter test input Robust vandal-proof aluminium/polycarbonate housing IP65, NEMA 1. 2. 3. 3R. 3RX. 3SX. 3X. 5. 12. 12K rating CE, EN12453, EN12978, UL325 and UL508 approved Main functions • Designed for domestic and industrial doors and gates • Detects presence or absence of persons or vehicles by interruption of the light beam from the emitter to receiver Carlo Gavazzi Industri A/S 1 PD140FNT60QMU-02C  References Product selection key PD140FNT60 -02C Enter the code entering the corresponding option instead of Code P D 140 F N T 60 -02C Option QMU Q MU - Description Photoelectric sensor Rectangular housing Length of housing Aluminium Not used Through-beam Distance [m] Matched sensor set (Receiver and Emitter) SPDT relay (Receiver) Mute input (Emitter) Black - Sensor is only available as a matched set Sensor is only available as a matched set Type selection Function Receiver and Emitter Receiver Emitter 06/03/2017 PD140FNT60QMU-02C ENG Sensor set Not available Not available Code PD140FNT60QMU-02C PD140FNT60Q-02C PD140FNT60MU-02C Carlo Gavazzi Industri A/S 2 PD140FNT60QMU-02C  Structure A A D E G G H H D C C B B A A F Fig. 1 Emitter Element A B C D E Component Fixing holes for sensor mounting Terminal block Jumpers Green LED Yellow LED 06/03/2017 PD140FNT60QMU-02C ENG I F Fig. 2 Receiver Element F G H I Fig. 3 Rear view Component Cable gland for cable entry Hole for laser adjustment tool Lens adjustment Alternative cable entry Carlo Gavazzi Industri A/S 3 PD140FNT60QMU-02C  Sensing Detection Rated operating distance (Sn) Sensitivity adjustment (Receiver) Blind zone Hysteresis Light source Light type Detection angle Emitter beam angle Light spot size Lens adjustment ≤ 60 m @ target, PD140 emitter and excess gain 4 12 m ... 60 m 6 m ... 12 m 0.6 m ... 6 m 0.6 m 10 ... 20% 850 nm Infrared modulated ≤ ± 5° ≤ ± 5° 3.7 m ± 100° ± 15° Jumper pos 1 Jumper pos 2 Jumper pos 3 Infrared @30 m (half sensing distance) Horizontal Vertical Accuracy Temperature drift Repeatability ≤ 0.3%/ºC < 5% 06/03/2017 PD140FNT60QMU-02C ENG Carlo Gavazzi Industri A/S 4 PD140FNT60QMU-02C  Detection diagram D 6 A 0 33 66 98 H 131 164 197 230 262 295 328 361 394 427 459 492 19,7 5 16,4 4 13,1 3 9,8 2 6,6 1 3,3 0 0,0 -1 -3,3 -2 -6,6 -3 -9,8 -4 -13,1 -5 -16,4 -6 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 150 Y X I C -19,7 B E A B C D E Detection width [m] Sensing range [m] Detection width [feet] Sensing range [feet] Limits 06/03/2017 PD140FNT60QMU-02C ENG F G F G H I OFF ON Emitter Receiver Carlo Gavazzi Industri A/S 5 PD140FNT60QMU-02C  Excess gain C 2,0 3,3 32,8 328 0,6 1 10 100 10.000 1.000 A 100 10 1 B D A B C 5) Excess gain Sensing range [m] Sensing range [feet] E D E ESPE 2, legal detection angle 5) ESPE 2, illegal detection angle 5) See detection diagram 06/03/2017 PD140FNT60QMU-02C ENG Carlo Gavazzi Industri A/S 6 PD140FNT60QMU-02C  Features Power Supply Rated operational voltage (Ue-min - Ue-max) Rated operational voltage (UB) Ripple (Urpp ) No load supply current (Io) DC No load supply current (Io) AC Power-ON delay (tv) 12 ... 24 V AC/DC (ripple included) 10.2 ... 35 V DC 10.2 ... 26.4 V AC Within limits of UB min ≤ 55 mA @ UB max ≤ 50 mA @ UB max ≤ 100 mA @ UB max ≤ 100 mA @ UB max ≤ 200 ms ≤ 200 ms Emitter Receiver Emitter Receiver Emitter Receiver Outputs Output functions Output switching function Output current Minimum operational current (Im) Mechanical lifetime Electrical lifetime (typical) Protection Utilization category 06/03/2017 PD140FNT60QMU-02C ENG SPDT relay N.O. and N.C. < 1 A / 30 VDC Continuous(Ie) < 0.5 A / 50 VAC Continuous(Ie) ≥ 1 mA @ 5 V ≥ 5 000 000 cycles > 100 000 cycles @ Resistive load AC-1 and DC-1 reverse polarity and transients Emitter and Receiver AC-1 Non-inductive or slightly inductive loads, resistive load DC-1 EN 60947-4-1 Control of small electromagnetic AC-14 loads EN 60947-5-1 Control of electromagnets DC-13 EN 60947-5-1 (with freewheeling diode) Carlo Gavazzi Industri A/S 7 PD140FNT60QMU-02C  Operation diagram Emitter supply ON Receiver Supply ON Object Break beam Mute/Test input Active Make output (N.O.) ON A B C D F A C G D C F E E E F G Receiver startup time (150 ms) Emitter startup time (150 ms) Break response time (8 ms) Make response time (8 ms) C E G D C C B E OFF Hold Time (80 ms) Beam obstruction / mute active > 80 ms Beam obstruction / mute active < 80 ms Response times Operating frequency (f) 10 impulses / sec. tON (ON-OFF) tOFF (OFF-ON) OFF Hold time Response times < 8 ms < 8 ms > 80 ms Indication Receiver Green LED ON ON ON OFF Yellow LED OFF ON Flash1) Flash1) Power ON ON ON; EG ≥ 4 EG < 4 Output OFF ON OFF / Alignment mode OFF / Alignment mode Slow flashing or OFF = Not aligned, Higher flash rate= Better optical alignment EG = Excess gain 1) Emitter Green LED ON OFF - 06/03/2017 PD140FNT60QMU-02C ENG Power ON ON Emitting Yes No (muted) Carlo Gavazzi Industri A/S 8 PD140FNT60QMU-02C  Environmental Ambient temperature -25°... +60°C (-13°... +140°F) -40° ... +70°C (-40° ... +158°F) ≥ 100 000 lux ≥ 10 000 lux 4) Ambient light ≥ 3 000 lux 4) 0.05 J @ 200 Hz to 0.5 J @ 5 Hz 4) 3 to 5 J @ 0.5 to 2 Hz 4) Vibration Shock Drop test Rated insulation voltage (Ui) Dielectric insulation voltage Rated impulse withstand voltage Pollution degree Overvoltage category Degree of protection NEMA Enclosure Types Ambient humidity range 10 ...150 Hz, 1.0 mm/15 g 30 gn / 11ms, 6 pos, 6 neg per axis 2 x 1 m and 100 x 0.5 m 50 VDC ≥ 4000 VAC rms ≥ 2 kV 3 III IP65 Indoor + outdoor: 3, 3R, 3RX, 3SX, 3X Indoor: 1, 2, 5, 12, 12K < 50% @ 70°C 2) RH < 90% @ 20°C 2) Operating 2) 3) Storage 2) Incandescent light @ 3000 … 3200 °K (EN 60947-5-2) Incandescent light 3200 °K (EN 61496-2) Fluorescent light (EN 61496-2) Stroboscopic light (EN 61496-2) Flashing beacon light (EN 61496-2) EN 60068-2-6 EN60068-2-27 EN 60068-2-31 50/60 Hz for 1 min. 1.2/50 µs EN60947-1 IEC60664; EN60947-1 IEC60539; EN60947-1 NEMA 250 NEMA 250 With no icing or condensation UL325 -25°... +55°C 4) Failure to danger (worst case alignment) 2) 3) EMC Electrostatic discharge immunity test Radiated radio-frequency electromagnetic field immunity test (80 MHz ... 1 GHz and 1.4 GHz ... 2 GHz) Electrical fast transient/Burst immunity test Conducted disturbances induced by radio-frequency fields immunity test (150 kHz ... 80 MHz) Power frequency magnetic field immunity test 06/03/2017 PD140FNT60QMU-02C ENG ± 8 kV @ air discharge ± 15 kV @ contact discharge (Closed sensor with aluminium housing) ± 8 kV @ contact discharge (during installation) IEC 61000-4-2 10 V/m IEC 61000-4-3 4 kV / 5 kHz using the capacitive coupling clamp IEC 61000-4-4 10 V rms IEC 61000-4-6 300 A/m IEC 61000-4-8 Carlo Gavazzi Industri A/S 9 PD140FNT60QMU-02C  Mechanics/electronics Connection Cable diameter Ø 5 ... 10 mm 3-pole screw terminal 5-pole screw terminal Connection Terminal Emitter Receiver Self-lifting terminal block, 1.5 mm2 (AWG 16) 2.6 x 2 mm Wiring V V N.C. + ~- C N.O. V A V C MU Fig. 4 Receiver A B Power supply Mute input (Test input) + ~ ~- A B Fig. 5 Emitter C Relay contacts Housing Cover Window Back part Sealing Cable gland Dimensions Weight 06/03/2017 PD140FNT60QMU-02C ENG Aluminium, Black PC, Black PBT, Black Neoprene PA6, Light grey 140 x 51 x 46 mm ≤ 460 g (matched set) Carlo Gavazzi Industri A/S 10 PD140FNT60QMU-02C  Dimensions (mm) 15.3 51 13 31.32 150 122.4 140 36.2 46 36.6 06/03/2017 PD140FNT60QMU-02C ENG Carlo Gavazzi Industri A/S 11 PD140FNT60QMU-02C  Compatibility and conformity Approvals and markings General reference MTTFd related to product life time Sensor designed according to EN60947-5-2 EN ISO 13849-1 (Parts count 49.9 years @ 40°C (+104°F) method, annex D.1), SN 29500 MTTFd related to safety device, perfor1332 years @ 40°C (+104°F) mance leveld EN ISO 13849-1, SN 29500 CE-marking Approvals ESPE category Performance level (PL) PFHd Mission Time 06/03/2017 PD140FNT60QMU-02C ENG (UL325) 2 d 8.57 x 10-8 Errors per hour 20 years (UL508 + C22.2) EN61496-2 EN12453 EN ISO 13849-1 EN ISO 13849-1 Carlo Gavazzi Industri A/S 12 PD140FNT60QMU-02C  Delivery contents and accessories Delivery contents • Photoelectric sensor set: PD140FNT60Q-02C + PD140FNT60MU-02C • Accessory bag (Screws, plugs, blind caps, cable glands) • Packaging: Card board box Accessories • Laser alignment tool: APD140-LA01 • Laser alignment tool without batteries (Battery: DL1/3N, CR1/3N 3V - Lithium): APD140-LA02 • Alignment test cable: APD140-TC01 COPYRIGHT ©2016 Content subject to change. Download the PDF: www.productselection.net 06/03/2017 PD140FNT60QMU-02C ENG Carlo Gavazzi Industri A/S 13
PD140FNT60QMU-02C 价格&库存
很抱歉,暂时无法提供与“PD140FNT60QMU-02C”相匹配的价格&库存,您可以联系我们找货
