Photoelectrics
Diffuse-reflective, Transistor Output
Type PC50CND10BA
Product Description
Range: 1 m
Adjustable sensitivity
Modulated, infrared light
Supply voltage: 10 to 30 VDC
Output: 200 mA, NPN or PNP
Make and break switching function selectable
LED for output indication, signal stability and power ON
Protection: reverse polarity, short circuit, transients
Cable and plug version
High EMC immunity
Ordering Key
PC50CND10BAM1
performance. The long sensing range together with sensitivity adjustment gives a very
flexible sensor. The DC types
are with a transistor output
and the configuration is fully
programmable (NPN, PNP,
NO and NC).
Type
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
Connection type
Housing
WxHxD
Range
Sn
Ordering no.
NPN & PNP cable
Make & break switching
Ordering no.
NPN & PNP plug
17 x 50 x 50 mm
1m
PC 50 CND 10 BA
PC 50 CND 10 BAM1
The PC50CND. is a family of
general purpose diffusereflective sensors in a compact square 17 x 50 x 50 mm
reinforced PC/ABS-housing.
They are useful in applications where basic sensors
provide adequate sensing
Type Selection
Specifications
Rated operating distance (Sn) Up to 1 m,
reference target Kodak
test card R 27, white, 90%
reflectivity, 200 x 200 mm
Blind zone
Max. 10 cm
Sensitivity
Adjustable by single-turn
potentiometer
Temperature drift
≤ 0.5%/°C
Hysteresis (H)
Differential travel
3 - 20%
10 to 30 VDC
Rated operational volt. (UB )
(ripple included)
Ripple (Urpp )
≤ 10%
Output current
≤ 200 mA
Continuous (Ie)
Short-time (I)
≤ 200 mA
(max. load capacity 100 nF)
No load supply current (Io)
≤ 40 mA
Minimum operational current (Im) 0.5 mA
OFF-state current (Ir )
≤ 100 µA
Voltage drop (Ud )
≤ 2.5 VDC @ 200 mA
Protection
Short-circuit, reverse polarity, transients
Specifications are subject to change without notice (27.02.2006)
Light source
Light type
Sensing angle
Ambient light
Operating frequency
Response time
OFF-ON (tON)
ON-OFF ( tOFF )
Power ON delay (tv)
Output function
NPN and PNP
Complementary function
Indication function
Output ON
Signal stability ON and power ON
Environment
Installation category
Pollution degree
Degree of protection
Temperature
Operating
Storage
GaAlAs, LED, 880 nm
infrared, modulated
± 2° at 1/2 range
Max. 5’000 lux
500 Hz
≤ 1 ms
≤ 1 ms
< 300 ms
Switch selectable
Make and break (NO + NC)
LED, yellow
LED, green
II (IEC 60664/60664A;
60947-1)
3 (IEC 60664/60664A;
60947-1)
IP 67 (IEC 60529; 60947-1)
-20° to +60°C (-4° to +140°F)
-25° to +80°C (-13° to +176°F)
1
PC50CND10BA
Specifications (cont.)
Vibration
10 to 150 Hz, 0.5 mm/7.5 g
(IEC 60068-2-6)
2 x 1 m & 100 x 0.5 m
(IEC 60068-2-6, 60068-2-32)
50 VAC (rms)
Shock
Rated insulation voltage
Housing material
Body
Front glass
Mounting bracket
Connection
Cable
Plug
Cables for plug (M1)
Weight
Approvals
CE-marking
PC/ABS, grey
PC black
Steel, galvanized
PVC, grey, 2 m, 4 x 0.34 mm2
PBTP, M12 x 1
CON.1A-series
110 g
UL, CSA
Yes
Operation Diagram
tv = Power ON delay
Power supply
Object/target present
Break (NC) Output ON
Make (NO) Output ON
Dimensions
Plug version
24.85
17
50
21
R2.3
29
1o
21.15
35.2
50
11.3
19
41.4
9
19
Ø4.45
21 24.85
NPN/PNP
35.2
15
14.5
R2.3
LED´s
Distance
21.4
Cable version
24.85
17
50
21
R2.3
29
1o
21.15
35.2
50
11.3
19
41.4
9
19
Ø4.45
21 24.85
NPN/PNP
35.2
15
Ø5
2
R2.3
LED´s
Distance
21.4
PC50CND10BA
Wiring Diagrams
Detection Diagram
Sensor
NPN
X
Y
R27
Kodac test card
150,00
100,00
PNP
(mm)
50,00
1 BN
0,0
-50,00
4 BK
-100,00
2 WH
-150,00
400,0
600,0
800,0
1000,0
1200,0
3 BU
Sensing range (mm)
Excess Gain
Signal Stability
Excess gain
Excess gain
150%
100%
70%
Time
Green LED ON
Yellow LED ON
Sensing range (mm)
Installation Hints
Relief of cable strain
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
Delivery Contents
6.5
ø6.5
10
ø6.5
R4
Photoelectric switch: PC50 CND..
Installation instruction
Mounting bracket APC50-1
Packaging: Cardboard box
12
6.25
R2.25
Accessories
2
R4
8
16.5
4.5
13°
35
20°
90
R2
ø4.5
For further information refer to “Accessories”
ø4.5
Mounting bracket
ACP50-1
• Screwdriver for adjustment: 77-001
• Connector type CON.1A..
R4
9
4.5
21
50
Specifications are subject to change without notice (23.01.03)
3
很抱歉,暂时无法提供与“PC50CND10BAM1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1773.521601+230.28296
- 5+1684.845525+218.76881
- 10+1631.6498810+211.86163
- 25+1578.4423125+204.95289
