S-8259A Series
www.ablic.com
BATTERY MONITORING IC FOR 1-CELL PACK
© ABLIC Inc., 2015-2019
Rev.1.1_02
The S-8259A Series is an IC including high-accuracy voltage detection circuits and delay circuits.
The S-8259A Series is suitable for monitoring overcharge and overdischarge for 1-cell lithium-ion / lithium polymer rechargeable
battery packs.
Features
• High-accuracy voltage detection circuit
Overcharge detection voltage
3.500 V to 4.600 V (5 mV step)
Accuracy ±20 mV
Overcharge release voltage
3.100 V to 4.600 V*1
Accuracy ±50 mV
Overdischarge detection voltage
2.000 V to 3.400 V (10 mV step)
Accuracy ±50 mV
Overdischarge release voltage
2.000 V to 3.400 V*2
Accuracy ±100 mV
• Detection delay times are generated only by an internal circuit (external capacitors are unnecessary).
• CO pin output logic:
Active "H", active "L"
• Wide operation temperature range:
Ta = −40°C to +85°C
• Low current consumption
During operation:
1.5 μA typ., 3.0 μA max. (Ta = +25°C)
During overdischarge:
2.0 μA max. (Ta = +25°C)
• Lead-free (Sn 100%), halogen-free
*1. Overcharge release voltage = Overcharge detection voltage − Overcharge hysteresis voltage
(Overcharge hysteresis voltage can be selected from a range of 0 V to 0.4 V in 50 mV step.)
*2. Overdischarge release voltage = Overdischarge detection voltage + Overdischarge hysteresis voltage
(Overdischarge hysteresis voltage can be selected from a range of 0.1 V to 0.7 V in 100 mV step.)
Applications
• Lithium-ion rechargeable battery pack
• Lithium polymer rechargeable battery pack
Package
• SOT-23-6
1
S-8259A Series
Rev.1.1_02
Block Diagram
1. CO pin output logic active "H"
VDD
Overdischarge
detection comparator
DO
Overcharge
Control logic
VSS
Delay circuit
Oscillator
CO
VM
Figure 1
2
S-8259A Series
Rev.1.1_02
2. CO pin output logic active "L"
VDD
Overdischarge
DO
Overcharge
Control logic
VSS
Delay circuit
Oscillator
CO
VM
Figure 2
3
S-8259A Series
Rev.1.1_02
Product Name Structure
1. Product name
S-8259A xx
M6T1
U
Environmental code
U:
Package abbreviation and IC packing specifications*1
M6T1: SOT-23-6, Tape
Serial code*2
Sequentially set from AA to ZZ
*1. Refer to the tape drawing.
*2. Refer to "3. Product name list".
2. Package
Package Name
SOT-23-6
4
Table 1 Package Drawing Codes
Dimension
Tape
MP006-A-P-SD
MP006-A-C-SD
Reel
MP006-A-R-SD
S-8259A Series
Rev.1.1_02
Table 2
Product Name
S-8259AAA-M6T1U
S-8259AAB-M6T1U
S-8259AAC-M6T1U
S-8259AAD-M6T1U
S-8259AAE-M6T1U
S-8259AAG-M6T1U
S-8259AAH-M6T1U
S-8259AAI-M6T1U
S-8259AAJ-M6T1U
S-8259AAK-M6T1U
S-8259AAL-M6T1U
S-8259AAM-M6T1U
S-8259AAN-M6T1U
S-8259AAO-M6T1U
S-8259AAP-M6T1U
S-8259AAQ-M6T1U
Overcharge
Detection
Voltage
[VCU]
Overcharge Overdischarge Overdischarge Overcharge Overcharge Overdischarge
Detection
Release
Detection
Release
Detection
CO Pin
Release
Delay Time Delay Time
Voltage
Voltage
Voltage
Delay Time Output Logic*1
[tCU]
[VCL]
[VDL]
[VDU]
[tDL]
[tCL]
4.275 V
4.250 V
3.900 V
4.200 V
4.200 V
4.175 V
4.100 V
3.800 V
4.100 V
4.200 V
2.300 V
2.500 V
2.000 V
2.500 V
2.800 V
2.600 V
3.000 V
2.300 V
3.000 V
3.000 V
3.650 V
4.425 V
4.350 V
4.250 V
4.375 V
3.475 V
4.050 V
3.600 V
4.200 V
4.250 V
4.170 V
3.650 V
4.325 V
4.350 V
4.250 V
4.375 V
3.475 V
4.050 V
3.600 V
4.200 V
4.150 V
3.770 V
2.500 V
2.600 V
2.600 V
2.300 V
2.800 V
2.800 V
2.500 V
2.900 V
3.300 V
2.800 V
2.800 V
3.000 V
2.900 V
3.000 V
2.600 V
3.000 V
2.880 V
3.000 V
2.980 V
3.400 V
3.000 V
3.400 V
1.0 s
1.0 s
1.0 s
256 ms
1.0 s
1.0 s
1.0 s
1.0 s
1.0 s
1.0 s
256 ms
32 ms
128 ms
32 ms
2.0 s
4.0 s
4.0 s
32 ms
4.0 s
4.0 s
4.0 s
64 ms
128 ms
256 ms
256 ms
1.0 s
1.0 s
32 ms
64 ms
64 ms
128 ms
1.0 s
128 ms
128 ms
1.0 s
1.0 s
Active "L"
Active "L"
Active "L"
Active "L"
Active "L"
Active "L"
Active "L"
Active "L"
Active "L"
Active "L"
32 ms
128 ms
32 ms
32 ms
Active "H"
Active "L"
Active "H"
Active "H"
128 ms
256 ms
Active "L"
Active "L"
128 ms
256 ms
128 ms
32 ms
256 ms
1.0 s
*1. CO pin output logic: Active "H", active "L"
Remark 1. Please contact our sales representatives for products other than the above.
2. The delay times can be changed within the range listed in Table 3. For details, please contact our sales
representatives.
Table 3
Delay Time
delay time
Overcharge release
delay time
overdischarge detection
delay time
Symbol
Selection Range
Remark
tCU
128 ms
256 ms
512 ms
1.0 s
2.0 s
4.0 s
tCL
32 ms
64 ms
128 ms
1.0 s
2.0 s
4.0 s
tDL
32 ms
64 ms
128 ms
256 ms
Select a value
from the left.
Select a value
from the left.
Select a value
from the left.
5
S-8259A Series
Rev.1.1_02
Pin Configuration
1. SOT-23-6
Table 4
Top view
6 5 4
1 2 3
Figure 3
Pin No.
Symbol
1
DO
2
VM
3
CO
4
NC*1
Description
Output pin for overdischarge detection
(CMOS output)
Negative power supply input pin for CO pin
Output pin for overcharge detection
(CMOS output)
No connection
5
VDD
Input pin for positive power supply
6
VSS
Input pin for negative power supply
*1. The NC pin is electrically open.
The NC pin can be connected to VDD pin or VSS pin.
6
S-8259A Series
Rev.1.1_02
Absolute Maximum Ratings
Table 5
(Ta = +25°C unless otherwise specified)
Item
Symbol
Input voltage between VDD pin and VSS pin
VM pin input voltage
DO pin output voltage
CO pin output voltage
Power dissipation
Operation ambient temperature
VDS
VVM
VDO
VCO
PD
Topr
Storage temperature
Tstg
Applied Pin
Unit
VSS − 0.3 to VSS + 6
VDD − 28 to VDD + 0.3
VSS − 0.3 to VDD + 0.3
VVM − 0.3 to VDD + 0.3
VDD
VM
DO
CO
650*1
−40 to +85
V
V
V
V
mW
°C
−55 to +125
°C
*1. When mounted on board
[Mounted board]
(1) Board size: 114.3 mm × 76.2 mm × t1.6 mm
(2) Board name: JEDEC STANDARD51-7
The absolute maximum ratings are rated values exceeding which the product could suffer physical
damage. These values must therefore not be exceeded under any conditions.
700
Power Dissipation (PD) [mW]
Caution
600
500
400
300
200
100
100
150
Ambient Temperature (Ta) [°C]
Figure 4 Power Dissipation of Package (When Mounted on Board)
7
S-8259A Series
Rev.1.1_02
Electrical Characteristics
1. Ta = +25°C
Item
Table 6
Symbol
Condition
Min.
Test
Typ.
Max.
Unit
Circuit
Detection Voltage
VCU
*1
Ta = −10°C ~ +60°C
VCL ≠ VCU
VCL = VCU
VDL ≠ VDU
VCU − 0.020
VCU
VCU + 0.020
VCU − 0.025
VCU
VCL − 0.050
VCL − 0.025
VDL − 0.050
VDU − 0.100
VCL
VCL
VDL
VDU
V
1
VCU + 0.025
V
1
VCL + 0.050
VCL + 0.020
VDL + 0.050
VDU + 0.100
V
V
V
V
1
1
2
2
VCL
Input Voltage
Operation voltage between VDD pin and
VSS pin
Input Current
VDL
VDU
VDSOP
1.5
6.0
V
Current consumption during operation
Current consumption during overdischarge
Output Resistance
CO pin resistance "H" 1
CO pin resistance "L" 1
DO pin resistance "H"
DO pin resistance "L"
CO pin resistance "H" 2
CO pin resistance "L" 2
Delay Time
Overcharge detection delay time
Overcharge release delay time
Overdischarge detection delay time
IOPE
IOPED
VDD = 3.4 V, VVM = 0 V
VDD = 1.5 V, VVM = 0 V
1.5
3.0
2.0
μA
μA
3
3
RCOH1
RCOL1
RDOH
RDOL
RCOH2
RCOL2
5
5
5
5
1
1
10
10
10
10
4
4
kΩ
kΩ
kΩ
kΩ
MΩ
MΩ
4
4
4
4
4
4
tCU × 0.7
tCL × 0.7
tDL × 0.7
tCU
tCL
tCU × 1.3
tCL × 1.3
tDL × 1.3
5
5
5
tCU
tCL
tDL
Active "L"
Active "H"
tDL
*1. Since products are not screened at high and low temperature, the specification for this temperature range is guaranteed by
design, not tested in production.
8
S-8259A Series
Rev.1.1_02
2. Ta = −40°C to +85°C*1
Table 7
(Ta = −40°C to +85°C*1 unless otherwise specified)
Item
Detection Voltage
Symbol
Condition
Min.
Typ.
Max.
Unit
Test
Circuit
VCU − 0.045
VCL − 0.080
VCU
VCL
VCU + 0.030
VCL + 0.060
V
V
1
1
VCL − 0.050
VDL − 0.080
VDU − 0.130
VCL
VDL
VDU
VCL + 0.030
VDL + 0.060
VDU + 0.110
V
V
V
1
2
2
1.5
6.0
V
1.5
4.0
3.0
μA
μA
3
3
2.5
2.5
2.5
2.5
0.5
0.5
10
10
10
10
4
4
30
30
30
30
kΩ
kΩ
kΩ
kΩ
MΩ
MΩ
4
4
4
4
4
4
tCU × 0.5
tCL × 0.5
tDL × 0.5
tCU
tCL
tDL
tCU × 2.5
tCL × 2.5
tDL × 2.5
5
5
5
VCU
VCL
Input Voltage
VSS pin
Input Current
Output Resistance
Delay Time
VDL
VDU
VCL ≠ VCU
VCL = VCU
VDL ≠ VDU
VDSOP
IOPE
IOPED
RCOH1
RCOL1
RDOH
RDOL
RCOH2
RCOL2
tCU
tCL
tDL
Active "L"
Active "H"
9
S-8259A Series
Rev.1.1_02
Test Circuits
Caution Unless otherwise specified, the output voltage levels "H" and "L" at CO pin (VCO) are judged by VVM +
1.0 V, and the output voltage levels "H" and "L" at DO pin (VDO) are judged by VSS + 1.0 V. Judge the CO
pin level with respect to VVM and the DO pin level with respect to VSS.
1. Overcharge detection voltage, overcharge release voltage
(Test circuit 1)
1. 1 Active "H"
Overcharge detection voltage (VCU) is defined as the voltage V1 at which VCO goes from "L" to "H" when the voltage
V1 is gradually increased from the starting condition of V1 = 3.4 V. Overcharge release voltage (VCL) is defined as
the voltage V1 at which VCO goes from "H" to "L" when the voltage V1 is then gradually decreased. Overcharge
hysteresis voltage (VHC) is defined as the difference between VCU and VCL.
1. 2 Active "L"
Overcharge detection voltage (VCU) is defined as the voltage V1 at which VCO goes from "H" to "L" when the voltage
the voltage V1 at which VCO goes from "L" to "H" when the voltage V1 is then gradually decreased. Overcharge
2. Overdischarge detection voltage, overdischarge release voltage
(Test circuit 2)
Overdischarge detection voltage (VDL) is defined as the voltage V1 at which VDO goes from "H" to "L" when the voltage
V1 is gradually decreased from the starting condition of V1 = 3.4 V. Overdischarge release voltage (VDU) is defined as
the voltage V1 at which VDO goes from "L" to "H" when the voltage V1 is then gradually increased. Overdischarge
hysteresis voltage (VHD) is defined as the difference between VDU and VDL.
3. Current consumption during operation
(Test circuit 3)
The current consumption during operation (IOPE) is the current that flows through VDD pin (IDD) under the set condition
of V1 = 3.4 V.
4. Current consumption during overdischarge
(Test circuit 3)
The current consumption during overdischarge (IOPED) is IDD under the set condition of V1 = 1.5 V.
5. CO pin resistance "H" 1
(Test circuit 4)
5. 1 Active "H"
The CO pin resistance "H" 1 (RCOH1) is the resistance between VDD pin and CO pin under the set conditions of
V1 = 4.7 V, V2 = 4.3 V.
5. 2 Active "L"
V1 = 3.4 V, V2 = 3.0 V.
6. CO pin resistance "L" 1
(Test circuit 4)
6. 1 Active "H"
The CO pin resistance "L" 1 (RCOL1) is the resistance between VM pin and CO pin under the set conditions of V1 = 3.4 V,
V2 = 0.4 V.
6. 2 Active "L"
The CO pin resistance "L" 1 (RCOL1) is the resistance between VM pin and CO pin under the set conditions of V1 = 4.7 V,
V2 = 0.4 V.
10
Rev.1.1_02
S-8259A Series
7. DO pin resistance "H"
(Test circuit 4)
The DO pin resistance "H" (RDOH) is the resistance between VDD pin and DO pin under the set conditions of V1 = 3.4 V,
V3 = 3.0 V.
8. DO pin resistance "L"
(Test circuit 4)
The DO pin resistance "L" (RDOL) is the resistance between VSS pin and DO pin under the set conditions of V1 = 1.8 V,
V3 = 0.4 V.
9. CO pin resistance "H" 2 (Active "L")
(Test circuit 4)
The CO pin resistance "H" 2 (RCOH2) is the resistance between VDD pin and CO pin under the set conditions of V1 = 4.7 V,
V2 = 0 V.
10. CO pin resistance "L" 2 (Active "H")
(Test circuit 4)
The CO pin resistance "L" 2 (RCOL2) is the resistance between VDD pin and CO pin under the set conditions of V1 = 4.7 V,
V2 = 4.7 V.
11. Overcharge detection delay time
(Test circuit 5)
11. 1 Active "H"
The overcharge detection delay time (tCU) is the time needed for VCO to go to "H" just after the voltage V1
increases and exceeds VCU under the set condition of V1 = 3.4 V.
11. 2 Active "L"
The overcharge detection delay time (tCU) is the time needed for VCO to go to "L" just after the voltage V1
12. Overcharge release delay time
(Test circuit 5)
12. 1 Active "H"
The overcharge release delay time (tCL) is the time needed for VCO to go to "L" just after the voltage V1 decreases
and falls below VCL under the set condition of V1 = 4.7 V.
12. 2 Active "L"
The overcharge release delay time (tCL) is the time needed for VCO to go to "H" just after the voltage V1 decreases
13. Overdischarge detection delay time
(Test circuit 5)
The overdischarge detection delay time (tDL) is the time needed for VDO to go to "L" after the voltage V1 decreases and
falls below VDL under the set condition of V1 = 3.4 V.
11
S-8259A Series
R1 = 330 Ω
Rev.1.1_02
VDD
VDD
V1
S-8259A Series
V1
C1
= 0.1 μF
VSS
VSS
VM
DO
CO
V VDO
V VCO
V VCO
COM
COM
Figure 5 Test Circuit 1
Figure 6 Test Circuit 2
VDD
VDD
V1
V1
S-8259A Series
VSS
S-8259A Series
VSS
VM
DO
VM
CO
DO
CO
A IDO
A ICO
V3
V2
COM
COM
Figure 7 Test Circuit 3
VDD
V1
S-8259A Series
VSS
VM
DO
Oscilloscope
CO
Oscilloscope
COM
Figure 9 Test Circuit 5
12
VM
DO
CO
V VDO
IDD
A
S-8259A Series
Figure 8 Test Circuit 4
Rev.1.1_02
S-8259A Series
Operation
Remark Refer to " Connection Example".
1. Normal status
The S-8259A Series monitors the voltage of the battery connected between VDD pin and VSS pin to control charging
and discharging. When the battery voltage is in the range from overdischarge detection voltage (VDL) to overcharge
detection voltage (VCU), CO pin and DO pin both output the release signals. This condition is called the normal status.
2. Overcharge status
When the battery voltage becomes higher than VCU during charging in the normal status and the condition continues for
the overcharge detection delay time (tCU) or longer, CO pin outputs the overcharge detection signal. This condition is
called the overcharge status.
When the battery voltage falls below the overcharge release voltage (VCL) and the condition continues for the
overcharge release delay time (tCL) or longer, the S-8259A Series releases the overcharge status.
3. Overdischarge status
When the battery voltage falls below VDL during discharging in the normal status and the condition continues for the
overdischarge detection delay time (tDL) or longer, DO pin outputs the overdischarge detection signal. This condition is
called the overdischarge status.
When the battery voltage exceeds the overdischarge release voltage (VDU), the S-8259A Series releases the
13
S-8259A Series
Rev.1.1_02
Timing Chart
1. Overcharge detection, overdischarge detection
VCU
VCL
Battery voltage
VDU
VDL
VDD
DO pin voltage
VSS
VDD
CO pin voltage
(Active "H")
VVM
VDD
CO pin voltage
(Active "L")
VVM
Overcharge release delay time (tCL)
Overcharge detection delay time (tCU)
Status
*1
(1)
(2)
*1. (1): Normal status
(2): Overcharge status
(3): Overdischarge status
Figure 10
14
Overdischarge detection delay time (tDL)
(1)
(3)
(1)
S-8259A Series
Rev.1.1_02
Connection Example
R1
VDD
Battery
DO
C1
S-8259A Series
VSS
CO
VM
Figure 11
Symbol
Part
R1
Resistor
C1
Capacitor
Table 8 Constants for External Components
Purpose
Min.
Typ.
Max.
ESD protection,
150 Ω
330 Ω
1 kΩ
For power fluctuation
0.068 μF 0.1 μF
1.0 μF
Remark
Caution 1. The constants may be changed without notice.
2. It has not been confirmed whether the operation is normal or not in circuits other than the connection
example. In addition, the connection example and the constants do not guarantee proper operation.
Perform thorough evaluation using the actual application to set the constants.
15
S-8259A Series
Rev.1.1_02
Precautions
• The application conditions for the input voltage, output voltage, and load current should not exceed the package power
dissipation.
• Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic
protection circuit.
• ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement by
products including this IC of patents owned by a third party.
16
S-8259A Series
Rev.1.1_02
Characteristics (Typical Data)
1. Current consumption
1. 1 IOPE vs. Ta
4.0
IOPE [μA]
3.0
2.0
1.0
0.0
−40 −25
Ta [°C]
50
75 85
2. Detection voltage
2. 2 VCL vs. Ta
4.31
4.24
4.29
4.21
VCL [V]
VCU [V]
2. 1 VCU vs. Ta
4.27
4.25
4.23
4.15
4.12
−40 −25
4.09
Ta [°C]
50
75 85
2. 3 VDL vs. Ta
2.80
2.34
2.70
2.30
2.26
2.22
−40 −25
Ta [°C]
50
75 85
Ta [°C]
50
75 85
2. 4 VDU vs. Ta
2.38
VDU [V]
VDL [V]
4.18
2.60
2.50
−40 −25
2.40
Ta [°C]
50
75 85
−40 −25
17
S-8259A Series
Rev.1.1_02
3. Delay time
3. 1 tCU vs. Ta
3. 2 tCL vs. Ta
2.6
80
64
1.8
tCL [ms]
tCU [s]
2.2
1.4
1.0
32
0.6
0.2
48
16
−40 −25
Ta [°C]
50
75 85
Ta [°C]
50
75 85
−40 −25
Ta [°C]
50
75 85
3. 3 tDL vs. Ta
320
tDL [ms]
256
192
128
64
−40 −25
4. Output resistance
4. 1 RCOH1 vs. VCO
4. 2 RCOL1 vs. VCO
30
RCOL1 [kΩ]
RCOH1 [kΩ]
30
2
3
VCO [V]
4
5
4. 3 RDOH vs. VDO
2
3
VCO [V]
4
5
1
2
3
VDO [V]
4
5
4. 4 RDOL vs. VDO
30
30
RDOL [kΩ]
RDOH [kΩ]
10
2
3
VDO [V]
4
5
S-8259A Series
Rev.1.1_02
Marking Specifications
1.
SOT-23-6
Top view
6
5
(1) to (3):
(4):
4
Product code (Refer to Product name vs. Product code)
Lot number
(1) (2) (3) (4)
1
2
3
Product Name
S-8259AAA-M6T1U
S-8259AAB-M6T1U
S-8259AAC-M6T1U
S-8259AAD-M6T1U
S-8259AAE-M6T1U
S-8259AAG-M6T1U
S-8259AAH-M6T1U
S-8259AAI-M6T1U
S-8259AAJ-M6T1U
S-8259AAK-M6T1U
S-8259AAL-M6T1U
S-8259AAM-M6T1U
S-8259AAN-M6T1U
S-8259AAO-M6T1U
S-8259AAP-M6T1U
S-8259AAQ-M6T1U
Product Code
(1)
(2)
(3)
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
A
B
C
D
E
G
H
I
J
K
L
M
N
O
P
Q
19
2.9±0.2
1.9±0.2
6
0.95
4
5
1
2
3
+0.1
0.15 -0.05
0.95
0.35±0.15
No. MP006-A-P-SD-2.1
TITLE
SOT236-A-PKG Dimensions
No.
MP006-A-P-SD-2.1
ANGLE
UNIT
mm
ABLIC Inc.
4.0±0.1(10 pitches:40.0±0.2)
+0.1
ø1.5 -0
+0.2
ø1.0 -0
2.0±0.05
0.25±0.1
4.0±0.1
1.4±0.2
3.2±0.2
3 2 1
4 5 6
Feed direction
No. MP006-A-C-SD-3.1
TITLE
SOT236-A-Carrier Tape
No.
MP006-A-C-SD-3.1
ANGLE
UNIT
mm
ABLIC Inc.
12.5max.
9.0±0.3
Enlarged drawing in the central part
ø13±0.2
(60°)
(60°)
No. MP006-A-R-SD-2.1
TITLE
SOT236-A-Reel
No.
MP006-A-R-SD-2.1
ANGLE
QTY
UNIT
mm
ABLIC Inc.
3,000
Disclaimers (Handling Precautions)
1.
All the information described herein (product data, specifications, figures, tables, programs, algorithms and
application circuit examples, etc.) is current as of publishing date of this document and is subject to change without
notice.
2.
The circuit examples and the usages described herein are for reference only, and do not guarantee the success of
any specific mass-production design.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products
described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other
right due to the use of the information described herein.
3.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described
herein.
4.
Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute
maximum ratings, operation voltage range and electrical characteristics, etc.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to
the use of the products outside their specified ranges.
5.
Before using the products, confirm their applications, and the laws and regulations of the region or country where they
are used and verify suitability, safety and other factors for the intended use.
6.
When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related
laws, and follow the required procedures.
7.
The products are strictly prohibited from using, providing or exporting for the purposes of the development of
weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands
caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear,
biological or chemical weapons or missiles, or use any other military purposes.
8.
The products are not designed to be used as part of any device or equipment that may affect the human body, human
life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control
systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment,
aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by
ABLIC, Inc. Do not apply the products to the above listed devices and equipments.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of
the products.
9.
In general, semiconductor products may fail or malfunction with some probability. The user of the products should
therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread
prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social
damage, etc. that may ensue from the products' failure or malfunction.
The entire system in which the products are used must be sufficiently evaluated and judged whether the products are
allowed to apply for the system on customer's own responsibility.
10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the
product design by the customer depending on the intended use.
11. The products do not affect human health under normal use. However, they contain chemical substances and heavy
metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be
careful when handling these with the bare hands to prevent injuries, etc.
12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used.
13. The information described herein contains copyright information and know-how of ABLIC Inc. The information
described herein does not convey any license under any intellectual property rights or any other rights belonging to
ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this
document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express
permission of ABLIC Inc.
14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales
representative.
15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into
the English language and the Chinese language, shall be controlling.
2.4-2019.07
www.ablic.com
