R58ECRGB1
R58ECRGB1
    BANNER(邦纳)
    SEN REGISTER MARK BIPOLAR
R58ECRGB1 数据手册
R58E Series Expert™ Registration Mark Sensors Datasheet Registration Mark Sensor with Three-Color Light Source Features • • • • • • • • • • Ultra-fast 10 kHZ switching frequency Sensor automatically selects red, green, or blue LED during TEACH to optimize application contrast Outstanding color contrast sensitivity; detects 16 levels of gray scale Smart gain-control algorithm to maximize performance in low-contrast or high-gloss applications Easy to set, automatic Expert-style TEACH options include Static and Dynamic programming plus manual adjustment for fine tuning Easy-to-read 8-segment light bar indicator for TEACH and signal strength readout, plus indicators for continuous readout of output status and setup Fixed-convergent sensing at 10 mm ±3 mm (0.39 in ±0.12 in); rectangular sensing image measure 1.2 mm x 3.8 mm (0.05 in x 0.15 in) at 10 mm (0.39 in) from the lens Models available with either parallel or perpendicular sensing image Rugged zinc alloy die-cast housing with high-quality acrylic lens suitable for food processing applications; rated IEC IP67, NEMA 6 Easy selection of Light/Dark Operate (LO/DO), 30 ms pulse stretcher (OFF-delay), and 30 ms ONdelay, using the push buttons or a remote input wire WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Models Cable1 R58ECRGB1 5-wire 2 m (6.5 ft) R58ECRGB1Q8 5-pin Euro-style integral QD R58ECRGB1Q 5-pin Euro-style 150 mm QD R58ECRGB2 5-wire 2 m (6.5 ft) R58ECRGB2Q8 5-pin Euro-style integral QD R58ECRGB2Q 5-pin Euro-style 150 mm QD Focus Supply Voltage Output Type Sensing Image Orientation Parallel to sensor length 10 mm (0.39 in) 10 V dc to 30 V dc Bipolar NPN/PNP Perpendicular to sensor length 1 Integral 2 m (6.5 ft) unterminated cable models are listed. • To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. For example, R58ECRGB1 W/30. • Models with a quick disconnect require a mating cordset. Original Document 122928 Rev. D 12 April 2017 122928 R58E Series Expert™ Registration Mark Sensors Overview R58 Expert offer maintenance-free, solid-state reliability for typical color contrasts found in product and material registration applications. Fast 50microsecond sensing response produces excellent registration repeatability, even in ultra-high-speed applications. This fast response, coupled with the small 1.2 x 3.8 mm (0.05 in x 0.15 in) sensing image, allows the detection of small and inconspicuous registration marks. R58E sensors feature TEACH mode sensitivity adjustment by presenting two sensing conditions to the sensor. TEACH mode has two options: Static TEACH and Dynamic TEACH. Static TEACH is used to position the two sensing conditions individually. Dynamic TEACH provides a means for teaching a series of conditions on-the-fly; the R58E samples the sensing events and automatically sets the switchpoint between the lightest and darkest conditions. The sensor then determines which sensing condition is present for the shortest time and assigns the Output ON condition to that event (therefore, LO/DO selection is automatic). If necessary, the LO/DO setting can be reversed in Setup mode. The sensor uses a tri-color LED during either teach process and automatically selects a red, green, or blue sensing beam, based on the contrast between the registration mark and its background. For applications where the user wishes to select the sensing beam color, individual colors may be enabled/disabled in Setup mode. Power LED Dynamic (+) Push Button Dark Operate (DO) LED Light Operate (LO) LED Static (-) Push Button Output LED ON-Delay LED OFF-Delay LED Switchpoint 8-Segment Bargraph Display Figure 1. Sensor Features Sensitivity may be fine-tuned at any time by clicking the “+” or “-” buttons on the sensor. The eight-element barograph display clearly displays the relative received signal strength. The discrete bipolar (one NPN and one PNP) outputs may be configured in Setup mode to include a 30-millisecond ON-delay and/or OFF-delay, if required. Configuration is accomplished either by using the push-buttons on the sensor, or by supplying input pulses using the remote input. The buttons may be disabled using the remote input. The construction of the R58E is extremely robust, with a die-cast metal housing, plastic optics, IP67 and NEMA 6 leakproof design for harsh sensing environments. Status Indicators LED Indicates Power On Green: Run mode Off: TEACH or Setup mode Output On Amber: Output is conducting, or TEACH Output ON condition Off: Output is not conducting, or TEACH Output OFF condition Light Operate On Green: Light Operate (LO) operation Dark Operate On Green: Dark Operate (DO) operation OFF-Delay On Green: 30 ms pulse stretcher (OFF-delay) is active Off: No OFF-delay ON-Delay On Green: 30 ms ON-delay is active Off: No ON-delay 8-Segment Bargraph Display On Red: Run mode — Indicates signal strength with respect to the sensing threshold (switchpoint); higher segment number for higher sensing contrast TEACH mode — Indicates relative contrast Setup mode — Displays sensing beam LED color (see Figure 8 on page 7) Off: TEACH or Setup mode — Sensor configuration active 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 122928 Rev. D R58E Series Expert™ Registration Mark Sensors Installation Install the Lens The lens may be installed at either of two lens ports (see Figure 2 on page 3). The lens and the lens port cap are both threaded and may be exchanged by hand; no tools are required. The lens and cap both include an o-ring seal. Note: The lens port cap must be installed on the unused port for reliable operation. Fully seat the lens cap to ensure a liquid-tight seal. Mounting Considerations The R58 Expert includes a total of eight size M5 threaded holes used for mounting. These threaded holes are positioned to match the mounting hole patterns common to other registration mark sensors. The R58E includes four M5 x 0.8 x 6 mm stainless steel cap screws and a hex key wrench. The R58E focus is 10 mm (0.39 in) from the lens surface. The R58E must be mounted within 3 mm (0.12 in) of this distance from the surface of the material for reliable sensing (Figure 2 on page 3). Cap Consider the following when mounting the R58E: • • • When sensing a registration mark on a reflective (shiny) material, mount the R58E at an angle which places the lens centerline at approximately 15° off perpendicular to the material’s surface (Figure 4 on page 3). This minimizes strong direct reflections (which tend to overwhelm the sensor), and allows the sensor to discern the relatively small optical contrast offered by differences in colors. Clear materials are poor reflectors of light. When sensing a mark printed on a clear material (for example, a clear poly web), position a reflective surface directly behind the clear material to return light to the R58E. The printed mark, regardless of its color, then becomes the dark condition, as it blocks the light from reaching the reflective surface. Most clear materials are also shiny; it is important to include a 15° skew angle when sensing clear materials (Figure 4 on page 3). Whenever possible, sense a web material at a location where it passes over a tension bar or roller, to minimize the adverse effects of web “flutter” or sag (Figure 3 on page 3). Sensor Lens Surface of Material 10 ± 3 mm Lens Cap 10 ± 3 mm Figure 2. Mounting Distance and Lens Positions Approximately 15º Sensor 90º Focus Distance 10.0 mm (0.39") Opaque, Non-reflective Web Material Focus Distance 10.0 mm (0.39") Roller or Tension Bar Roller or Tension Bar Mount the sensor perpendicular to non-reflective (matte) materials Figure 3. Mounting for Matte Material P/N 122928 Rev. D Transparent or Opaque Reflective Web Material Mount the sensor at approximately 15° from perpendicular to transparent and opaque reflective materials Figure 4. Mounting for Transparent and Opaque Material www.bannerengineering.com - Tel: +1-763-544-3164 3 R58E Series Expert™ Registration Mark Sensors Wiring Diagrams Key 1 + 10-30V dc – 3 2 4 5 Load 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray Load Remote Teach Quick disconnect (QD) wiring diagrams are functionally identical. Sensor Configuration The R58E is pre-set to power up in Run mode and to sense the most recently taught registration mark. Quickly optimize the sensitivity of the R58E using one of two available TEACH modes: Static TEACH or Dynamic TEACH. Static TEACH: Both the Output ON and Output OFF conditions are presented, and sensitivity can be adjusted manually using the push buttons. Dynamic TEACH: The registration mark is presented during actual sensing conditions, and the sensitivity can be adjusted manually using the push buttons. Remote TEACH Configure the sensor either using the push buttons, or using a remote switch. Remote configuration also may be used to enter Setup mode to set the ON- and OFF-delay, and to disable the push buttons to prevent unauthorized adjustment of the configuration settings. To access this feature, connect the gray wire of the sensor to 0 V dc, with a remote switch between the sensor and 0 V dc. Follow the sequence of input pulses to configure the sensor (see the procedures in this document). The duration of each pulse (corresponding to a push button “click”), and the period between multiple pulses, are defined as: “T”: 0.04 seconds ≤ “T” ≤ 0.8 seconds. Push Button Enable/Disable (Lockout) In addition to its configuration function, the remote input may be used to disable the push buttons for security. Disabling the push buttons prevents unauthorized adjustment of the configuration settings. Connect the gray wire of the sensor as described in Wiring Diagrams on page 4, and four-pulse to either enable or disable the push buttons (0.04 seconds < "T" < 0.8 seconds): Note: Push buttons can be disabled/enabled from the remote line only. Static TEACH In Static TEACH mode, the sensor learns two sensing conditions after each is presented one time. The sensor automatically positions the switchpoint midway between the two conditions. The sensor returns to Run mode if either TEACH condition is not registered within 60 seconds. The sensor reverts to the previous taught conditions. 2nd Taught Condition Sensor positions threshold midway between taught conditions Cancel TEACH mode by pressing and holding the Static push button for ≥ 2 seconds. The sensor reverts to the previous taught conditions (that is, exit without saving). Static TEACH and Manual Adjust Output OFF Sensitivity may be adjusted at any time when the sensor is in Run mode by clicking the “+” and “-” buttons. Each click translates to 1/2 segment on the signal strength bargraph display. For best sensing reliability, both sensing conditions should register equally distant from the switchpoint on the signal strength bargraph display. 4 1st Taught Condition Output ON Position adjusted by Manual Adjust Figure 5. Static TEACH (Light Operate Shown) www.bannerengineering.com - Tel: +1-763-544-3164 P/N 122928 Rev. D R58E Series Expert™ Registration Mark Sensors 1. Access TEACH mode. Method Action Result LO and DO: Alternately flash green Push Button2 Press and hold Static (-) for > 2 seconds. Remote Input3 No action required; sensor is ready for the first sensing condition. Output: On amber (indicating ready to teach first sensing condition) Bargraph display: Turns off N/A 2. Teach the first sensing condition. Method Push Button Action Result a. Present the first sensing condition. LO and DO: Alternately flash green b. Click Static (-). a. Present the first sensing condition. Remote Input b. Single-pulse the remote input. Output: Off (indicating ready to teach the second sensing condition) T Bargraph display: Remains off c. Wait at least 8 seconds. 3. Teach the second sensing condition. Method Push Button Remote Input Action Result a. Present the second sensing condition. Teach Accepted • The bargraph display flashes one segment for three seconds to indicate relative contrast (see Table 1 on page 6) . • The sensor enters Run mode. b. Click Static (-). a. Present the second sensing condition. Teach Not Accepted • Pairs of bargraph display segments flash for three seconds to indicate low contrast. • The sensor returns to TEACH the first sensing condition. T b. Single-pulse the remote input. Dynamic TEACH Dynamic TEACH is used to configure sensitivity during actual sensing conditions, when looking for a mark against its background condition. The R58E takes multiple samples of the registration mark against its background material and automatically positions the threshold at the optimum level. The registration mark must be presented at least two times during Dynamic TEACH. When Dynamic TEACH is used, the Output ON state is the shorter duration (smaller) event sensed, and LO/DO is set accordingly. To change the output state, change to either LO or DO in Setup mode, or pulse the remote line three times. Darkest Taught Condition Lightest Taught Condition Sensor positions threshold midway between taught conditions Output OFF Output ON Position adjusted by Manual Adjust Figure 6. Dynamic TEACH (Light or Dark Operate, depending on the sensing condition shown) Maximum Feed Rate To optimize performance and to ensure that all LED color and gain combinations are evaluated during Dynamic TEACH, the registration mark must encompass the 1.2 mm dimension of the 1.2 mm x 3.8 mm sensing image for at least 0.002 seconds. Determine the maximum feed rate using the following formula: 2 0.04 seconds ≤ “click” ≤ 0.8 seconds 3 0.04 seconds ≤ “T” ≤ 0.8 seconds P/N 122928 Rev. D www.bannerengineering.com - Tel: +1-763-544-3164 5 R58E Series Expert™ Registration Mark Sensors Maximum Feed Rate in mm/sec. = (registration mark width in mm – 1.2) / 0.002 Example with a 5 mm registration mark: Maximum Feed Rate = (5 mm – 1.2) / 0.002 = 1900 mm/sec. Note: Registration marks narrower than the 1.2 mm sensing image width can be detected at feed rates less than 600 mm/sec, but the contrast is reduced due to averaging of the background and the registration mark. Dynamic TEACH and Manual Adjust Sensitivity may be adjusted at any time when the sensor is in Run mode by clicking the “+” and “-” buttons. Each click translates to 1/2 segment on the bargraph display. For best sensing reliability, the light and dark conditions should register equally distant from the switchpoint on the bargraph display. Table 1: Contrast Bargraph Display Segment (following TEACH) Relative Contrast/Recommendation 6 to 8 Excellent: Very stable operation. 4 to 5 Good: Minor sensing variables will not affect sensing reliability. 2 to 3 Low: Minor sensing variables may affect sensing reliability. 1 Poor: Consider an alternate sensing scheme. Note: High contrast relates directly to sensing reliability; high-contrast sensing applications are most tolerant of sensing variables (for example, web flutter or variations in registration mark color and print density). 1. Access TEACH mode. Method Action Result Push Button4 Press and hold Dynamic (+) for > 2 seconds. LO and DO: Alternately flash green Remote Input5 Hold the remote line low for >2 seconds. Output: Off Bargraph display: Turns off 2. Teach the sensing conditions. Method Push Button Remote Input Action Result a. Continue to press Dynamic (+). b. Present the sensing conditions. Present registration marks at least twice. LO and DO: Alternately flash green a. Continue to hold the remote line low. Output: Off b. Present the sensing conditions. Present registration marks at least twice. Bargraph display: Remains off 3. Return to Run mode. Method Action Result Push Button Release Dynamic (+). Teach Accepted • The bargraph display flashes one segment for three seconds to indicate relative contrast (see Table 1 on page 6). • The sensor enters Run mode. Remote Input Release the remote input/switch. Teach Not Accepted • Pairs of bargraph display segments flash in unison for three seconds to warn of unacceptably low contrast. • The sensor returns to Run mode without changing settings. Setup Mode Use Setup mode to configure the discrete sensor output response for: 4 0.04 seconds ≤ “click” ≤ 0.8 seconds 5 0.04 seconds ≤ “T” ≤ 0.8 seconds 6 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 122928 Rev. D R58E Series Expert™ Registration Mark Sensors • • • Light or Dark Operate 30-millisecond pulse stretcher (OFF-delay), if required 30-millisecond ON-delay, if required Setup mode is also used to disable one or more sensing beam colors, to force the sensor to use a particular color. Access Setup mode only if the settings which result from TEACH mode configuration are not the settings required for the application or if a delay is required. The status LEDs indicate the output response configuration when the sensor is in Run mode, as shown. LO No delay DO No delay LO OFF-delay DO OFF-delay LO ON-delay LO OFF-delay ON-delay DO ON-delay DO OFF-delay ON-delay Single-Pulse or Dynamic Push Button Double-Pulse or Static Push Button Increment or decrement through the 8 possible setting combinations Figure 7. Output Response Configuration Options All Colors Red Green Double-Pulse or Static Push Button Blue Red and Green Red and Blue Green and Blue Single-Puls e or Dynamic Push Button Increment or decrement through the 7 possible setting combinations Figure 8. LED Color Configuration Options Change the output response settings or disable sensing beam color(s) as shown in Setup Configuration on page 7. Note: If Setup mode programming is interrupted and remains inactive for 60 seconds, the sensor returns to Run mode with the most recent settings (that is, exits and saves the current selection). Setup Configuration 1. Enter Setup mode. Method Action Push Button6 Press and hold both Static (-) and Dynamic (+) for > 2 seconds. Remote Input7 Result Double-pulse the remote input. T T T The 8-segment display turns off. The sensor is in Setup mode. 6 0.04 seconds ≤ “click” ≤ 0.8 seconds 7 0.04 seconds ≤ “T” ≤ 0.8 seconds P/N 122928 Rev. D www.bannerengineering.com - Tel: +1-763-544-3164 7 R58E Series Expert™ Registration Mark Sensors 2. Select the LO/DO and Delay settings. Method Action Result a. Release the buttons. Push Button b. Click Static (-) or Dynamic (+) to toggle between choices: • Dynamic (+)—increment • Static (-)—decrement T a. Wait > 8 seconds. Remote Input a. The sensor is ready to select a new setting combination. b. Sensor steps between LO/DO and Delay setting combinations, as shown Figure 7 on page 7. b. b. Enter sequential pulses to toggle between choices: • Single-pulse—increment • Double-pulse—decrement or T T T Note: There is a LO/DO settings shortcut using the remote input. From Run mode, triple-pulse the remote line. The sensor toggles between LO/DO settings on-the-fly, and continues in Run mode. 3. Enter the sensing beam color select mode from Setup mode. Method Action Result Push Button From Setup mode, press and hold Dynamic (+) > 2 seconds. Remote Input From Setup mode, four pulse the remote input. The sensor displays the currently selected sensing beam color combinations, as shown Figure 8 on page 7. T T T T T T T The visible sensing beam also provides indication of enabled sensing beam color(s). 4. Enable/Disable sensing beam colors. Method Action Result Push Button Click Static (-) or Dynamic (+) to toggle between choices: • Dynamic (+)—increment • Static (-)—decrement The sensor steps between the possible sensing beam color combinations, as shown in Figure 8 on page 7.8 T Remote Input Enter sequential pulses to toggle between choices: • Single-pulse—increment • Double-pulse—decrement The visible sensing beam also provides indication of enabled sensing beam color(s). or T T T 5. Return to Run mode. Method Action Result a. Press and hold Static (-) for > 2 seconds to return to Setup mode. Push Button b. Press and hold both push buttons > 2 seconds to return to Run mode OR wait > 60 seconds. a. Four-pulse the remote line to return to Setup mode. Remote Input b. Hold the remote line low > 2 seconds to return to Run mode OR wait >60 seconds. T T T a. T T T T The sensor returns to Run mode with new settings. These steps return to Run mode from both Setup modes. b. 8 If the new color setting has only one sensing beam color enabled, the sensor will switch to that color for sensing. If the new color setting has multiple sensing beam colors enabled, the sensor will use the color that was active prior to configuration; following the next TEACH procedure, it will select the enabled sensing beam color that has the greatest contrast. 8 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 122928 Rev. D R58E Series Expert™ Registration Mark Sensors Specifications Supply Voltage and Current 10 V dc to 30 V dc (10% maximum ripple) Supply current (exclusive of load current): 75 mA max at 10 V dc 35 mA at 30 V dc Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Outputs are bipolar: one current sourcing (PNP) and one current sinking (NPN) open-collector transistor Output Rating 100 mA maximum, each output OFF-state leakage current: NPN < 200 microamps; PNP < 10 microamps (see Application Note 1) NPN Saturation: < 1.6 V at 100 mA PNP Saturation: < 3.0 V at 100 mA Output Protection Circuitry Protected against output short-circuit, continuous overload, and false pulse on power-up Construction: Housing: Zinc alloy die-cast and steel housing with black painted finish and oring sealed lens and lens port cap Lens: Acrylic Lens port cap and lens holder: ABS Push-buttons: Thermoplastic elastomer Labels: Polycarbonate Environmental Rating IEC IP67, NEMA 6 Connections PVC-jacketed 5-conductor 2 m (6.5 ft) or 9 m (30 ft) cable with internal strain relief; integral 5-pin Euro-style QD fitting; or 150 mm (6 in) pigtail with 5-pin Euro-style QD fitting Operating Conditions Temperature: −10 °C to +55 °C (+14 °F to +131 °F) Storage Temperature −20 °C to +80 °C (−4 °F to +176 °F) 90% at +50 °C maximum relative humidity (non-condensing) Vibration and Mechanical Shock All models meet IEC 68-2-6 and IEC 68-2-27 testing criteria Application Notes Output Response Time 50 microseconds 1. Note: 1 second delay on power-up; output does not conduct during this time Repeatability 15 microseconds 2. 3. Tri-Color LED Sensing Image Rectangular: 1.2 mm x 3.8 mm (0.05 in x 0.15 in) at 10 mm (0.39 in) from the face of the lens; image oriented either parallel or perpendicular to sensor length, depending on model Red: 636 nm; Green: 525 nm; Blue: 472 nm Adjustments Using push buttons ("+" Dynamic and "-" Static): Manually adjust discrete output switchpoint using "+" or "-" buttons Dynamic TEACH (teach on-the-fly) sensitivity adjustment Static TEACH sensitivity adjustment Light operate/Dark operate OFF-delay/ON-delay Sensing beam color enable/disable Using Remote TEACH input (gray wire): Dynamic TEACH (teach on-the-fly) sensitivity adjustment Static TEACH sensitivity adjustment Light operate/Dark operate OFF-delay/ON-delay Sensing beam color enable/disable Disable push buttons for security Indicators 8-segment Barograph display: Red signal strength indicator relative to taught signal level; higher segment number for higher sensing contrast Light Operate: Green Dark Operate: Green OFF-Delay: Green ON-Delay: Green Output Conducting: Amber Power/Run Mode: Green NPN OFF-state leakage current is < 200 µA for load impedances > 3kΩ or optically isolated loads. For load current of 100 mA, leakage is < 1% of load current. Do not mount the sensor directly perpendicular to shiny surfaces; position it at approximately a 15° angle in relation to the sensing target (see Mounting Considerations on page 3). Minimize web or product "flutter" whenever possible to maximize sensing reliability. Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Certifications Industrial Control Equipment 3TJJ P/N 122928 Rev. D www.bannerengineering.com - Tel: +1-763-544-3164 9 R58E Series Expert™ Registration Mark Sensors Dimensions 4 X .4 mm (0.02") 10.7 mm (0.42") 30.0 mm (1.18") 2 X 8.5 mm (0.33") cable or pigtail QD 5.0 mm (0.20") 2 X 3.2 mm (0.12") 2 X 39.0 mm (1.54") 2 X 28.0 mm (1.10") 4 X M5 X 0.8 ISO-H 9.5 mm deep, max. torque 45 in./lbs. Ø 21.0 mm (Ø 0.83") 58.9 mm (2.32") 2 X 40.0 mm (1.57") 4 X 0.4 mm (0.02") 15.0 mm (0.59") 15.0 mm (0.59") 15.0 mm (0.59") 80.1 mm (3.15") 15.0 mm (0.59") 43.0 mm (1.69") 30.0 mm (1.18") 28.0 mm (1.10") 4 X M5 X 0.8 ISO-H 7 mm deep M12 X 1 21.0 mm (0.83") 15.0 mm (0.59") 20 mm (0.79") 4.5 mm (0.18") All measurements are listed in millimeters [inches], unless noted otherwise. Accessories Quick-Disconnect (QD) Cordsets 5-Pin Threaded M12/Euro-Style Cordsets—with Shield Model Length MQDEC2-506 1.83 m (6 ft) MQDEC2-515 4.57 m (15 ft) MQDEC2-530 9.14 m (30 ft) MQDEC2-550 15.2 m (50 ft) MQDEC2-506RA 1.83 m (6 ft) MQDEC2-515RA 4.57 m (15 ft) MQDEC2-530RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 10 15.2 m (50 ft) 2 1 3 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDEC2-550RA Pinout (Female) 5 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray M12 x 1 ø 14.5 [0.57"] www.bannerengineering.com - Tel: +1-763-544-3164 P/N 122928 Rev. D R58E Series Expert™ Registration Mark Sensors Mounting Brackets SMB55A • 15° offset bracket • 12-gauge stainless steel SMB55F • Flat-mount bracket • 12-gauge stainless steel SMB55RA • Right-angle bracket • 12-gauge stainless steel SMB55S • 15° offset bracket • 12-gauge stainless steel Replacement Lens UC-R55 • Replacement lens for R58A, R58B, and R58E Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
R58ECRGB1 价格&库存
很抱歉,暂时无法提供与“R58ECRGB1”相匹配的价格&库存,您可以联系我们找货
R58ECRGB1
  • 1+3787.153861+490.01273
库存:2
