Q45VR3R
Q45VR3R
    BANNER(邦纳)
    PHOTO SEN RECEIVER 60M SPST
Q45VR3R 数据手册
Q45VR3 Series Sensors Datasheet Universal Voltage Photoelectric Sensors with Electromechanical Relay Output • • • • • • • • • • Advanced one-piece photoelectric sensors with outstanding optical performance and extremely rugged design Universal supply voltage: 12 to 250 V dc or 24 to 250 V ac Electromechanical relay for economical, high-capacity switching and immunity to electrical noise Multiple sensing modes available: opposed, diffuse, retroreflective, and convergent, plus glass and plastic fiber optic models Selectable light/dark operate Versatile plug-in modules available for output timing logic and/or signal strength display Highly visible Power, Signal (AID™ System 1), and Output indicator LEDs Choice of prewired 2 m (6.5 ft) or 9 m (30 ft) unterminated cable or Mini-style quickdisconnect fitting Versatile mounting options Designed to withstand 1200 psi washdown; exceeds its NEMA 6P and IEC IP67 rating WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models To order the 9 m (30 ft) cable models, add the suffix "W/30" to the cabled model number. For example: Q453E W/30. Models with a quick disconnect (QD) connector require a mating cable. Opposed-Mode Emitter (E) and Receiver (R) Models Because of their extremely high excess gain, these opposed-mode sensors are an excellent option for sensing in contaminated or dirty areas, and are also the best choice for long-range sensing. OPPOSED Infrared, 880 nm Models Cable Q453E Emitter 2-wire 2 m (6.5 ft) cable Q45VR3R Receiver 5-wire 2 m (6.5 ft) cable Q453EQ Emitter 3-Pin Mini-style QD Q45VR3RQ Receiver 5-Pin Mini-style QD Range 60 m (200 ft) Supply Voltage Output Type Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay Retroreflective-Mode Models The visible red sensing beam of these sensors makes them very easy to align. Model Q45VR3LP polarizes the emitted light and filters out unwanted reflections, making sensing possible in applications otherwise considered unsuited to retroreflective sensing. Specified using the model BRT-3 3-inch reflector (go to www.bannerengineering.com for additional information). P RETRO POLAR RETRO Visible red, 680 nm (non-polarized) Visible red, 680 nm (polarized) 1 U.S. Patent no. 4356393 Original Document 53997 Rev. D 30 January 2017 53997 Q45VR3 Series Sensors Non-Polarized Models Range Q45VR3LV 0.08 to 9 m (3 in to 30 ft) Q45VR3LVQ Cable Supply Voltage Output Type 5-wire 2 m (6.5 ft) cable Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay Cable Supply Voltage Output Type 5-wire 2 m (6.5 ft) cable Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay 5-Pin Mini-style QD Polarized Models Range Q45VR3LP 0.15 to 6 m (6 in to 20 ft) Q45VR3LPQ 5-Pin Mini-style QD Diffuse-Mode Models These diffuse-mode models detect objects by sensing the reflection of their own emitted light. Ideal for use when the reflectivity and profile of the object to be sensed are sufficient to return a large percentage of emitted light back to the sensor. Model Q45VR3DX is the first choice for diffuse-mode applications when there are no background objects to falsely return light. DIFFUSE Infrared, 880 nm Short Range Models Range Q45VR3D 45 cm (18 inches) Q45VR3DQ Cable Supply Voltage Output Type 5-wire 2 m (6.5 ft) cable Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay 5-Pin Mini-style QD Long Range Models Q45VR3DL Range Cable Supply Voltage Output Type 1.8 m (6 ft) 5-wire 2 m (6.5 ft) cable Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay Cable Supply Voltage Output Type 5-wire 2 m (6.5 ft) cable Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay Q45VR3DLQ 5-Pin Mini-style QD High Power Models Range Q45VR3DX 3 m (10 ft) Q45VR3DXQ 5-Pin Mini-style QD Convergent-Mode Models These sensors are ideal for reflective sensing of very small parts or profiles, and can accurately sense the position of parts approaching from the side. Ignores all but highly reflective objects that are outside the sensing range. CONVERGENT Visible red, 680 nm Models Q45VR3CV Focus Cable 38 mm (1.5 in) 5-wire 2 m (6.5 ft) cable Q45VR3CVQ Spot Size at Focus: 1.3 mm (0.05 in) Q45VR3CV4 100 mm (4 in) Q45VR3CV4Q 2 Spot Size at Focus: 1.5 mm (0.06 in) 5-Pin Mini-style QD 5-wire 2 m (6.5 ft) cable 5-Pin Mini-style QD Supply Voltage Output Type Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay www.bannerengineering.com - Tel: +1-763-544-3164 P/N 53997 Rev. D Q45VR3 Series Sensors Glass Fiber Optic Models These models are an excellent choice for glass fiber optic applications where faster sensor response is not important. Their high excess gain means that opposed individual fibers can operate reliably in many very hostile environments. Also, special miniature bifurcated fiber optic assemblies with bundle sizes as small as 0.5 mm (.020 in) diameter may be used successfully for diffuse-mode sensing when using sensor model Q45VR3F(Q). For more information on compatible glass fiber optics, go to www.bannerengineering.com. GLASS FIBER Infrared, 880 nm and Visible red, 650 nm Infrared, 880 nm Models Q45VR3F Q45VR3FQ Range Cable Supply Voltage Output Type Range varies by sensing mode and fiber optics used. 5-wire 2 m (6.5 ft) cable Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay 5-Pin Mini-style QD Visible Red, 650 nm Models Q45VR3FV Q45VR3FVQ Range Cable Supply Voltage Output Type Range varies by sensing mode and fiber optics used. 5-wire 2 m (6.5 ft) cable Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay 5-Pin Mini-style QD Plastic Fiber Optic Models Lower in cost than glass fiber optics, plastic fiber optics are ideal for use in situations where environmental conditions allow (for example, low levels of acids, alkalis, and solvents). Most are easily cut to length in the field, and are available in a variety of sensing end styles. For more information on compatible plastic fiber optics, go to www.bannerengineering.com. Models Q45VR3FP Q45VR3FPQ PLASTIC FIBER Visible red, 660 nm Range Cable Supply Voltage Output Type Range varies by sensing mode and fiber optics used. 5-wire 2 m (6.5 ft) cable Universal 12 to 250 V dc or 24 to 250 V ac SPDT Electro-mechanical relay 5-Pin Mini-style QD Overview Status indicator LEDs for power, signal, and output are clearly visible beneath a raised dome in the sensor’s transparent o-ring-sealed polycarbonate cover. Also located beneath the sensor’s o-ring-sealed cover are controls for light/dark operate selection and the sensitivity adjustment. • The power indicator (green) lights when power is applied to the sensor. • The signal indicator (red) lights when the sensor sees its modulated light source and pulses at a rate proportional to the strength of the received light signal; this is the AID™ Alignment Indicating Device2. • The output indicator (amber) lights when the sensor’s output is conducting. This indicator is especially useful when a timing logic module is used and signal and output conditions are not concurrent. 6 5 1 2 3 4 1. Sensitivity adjustment 2. LEDs • Green LED: Power on indicator • Red LED: Signal indicator • Amber LED: Output status indicator 3. Optional LED signal strength display 4. Optional timing adjustment 5. Optional timing adjustment 6. Light/dark operate switch 2 US patent no. 4356393 P/N 53997 Rev. D www.bannerengineering.com - Tel: +1-763-544-3164 3 Q45VR3 Series Sensors Wiring Diagrams Q45VR3 Sensors with Attached Cable brown blue 24–250 V ac or 12–250 V dc* white NC yellow black Q45VR3 Sensors with Quick-Disconnect 5-Pin Mini-Style (model suffix Q) brown blue white C yellow NO black Q453E Emitters with Attached Cable NC C NO Q453EQ Emitters with Quick-Disconnect 3-Pin Mini-Style brown brown blue 24–250 V ac or 12–250 V dc* 24–250 V ac or 12–250 V dc* blue 24–250 V ac or 12–250 V dc* black *Connection of dc power is without regard to polarity. 4 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 53997 Rev. D Q45VR3 Series Sensors Specifications Supply Voltage and Current Universal voltage: 24 to 250 V ac, 50/60 Hz or 12 to 250 V dc (1.5 watts maximum) Supply Protection Circuitry Protected against transient voltages DC hookup is without regard to polarity. Output Configuration SPDT (Single-Pole, Double-Throw) electromechanical relay output. All models except emitters. Output Rating Max. switching power (resistive load): 1250 VA, 150 W Max. switching voltage (resistive load): 250 V ac, 125 V dc Max. switching current (resistive load): 5 A @ 250 V ac, 5A @ 30 V dc derated to 200 mA @ 125 V dc Min. voltage and current: 5 V dc, 10 mA Mechanical life of relay: 50,000,000 operations Electrical life of relay at full resistive load: 100,000 operations Output Protection Circuitry Protected against false pulse on power-up Output Response Time 15 milliseconds ON and OFF Note: 100 millisecond delay on power-up. Relay is de-energized during this time. Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Repeatability Opposed mode: 0.25 milliseconds All other sensing modes: 0.5 milliseconds Response time and repeatability specifications are independent of signal strength Adjustments Light/Dark Operate select switch; and multi-turn Sensitivity control on top of sensor beneath a transparent o-ring-sealed cover, allows precise sensitivity setting (turn clockwise to increase gain). Optional logic and logic/display modules have adjustable timing functions. Indicators Indicator LEDs are clearly visible beneath a raised transparent Lexan® dome on top of the sensor. Power (green) LED lights whenever 24 to 250 V ac, or 12 to 250 V dc power is applied Signal (red) AID™ System LED lights whenever the sensor sees its modulated light source, and pulses at a rate proportional to the strength of the received light signal Load (amber) LED lights whenever the output relay is energized Optional 7-element LED signal strength display module Construction Molded reinforced thermoplastic polyester housing, o-ring-sealed transparent Lexan®3 cover, molded acrylic lenses, and stainless steel hardware. Q45s are designed to withstand 1200 psi washdown. The base of cabled models has a 1/2-inch NPS integral internal conduit thread. Environmental Rating NEMA 6P, IEC IP67 Connections PVC-jacketed 2 m (6.5 ft) or 9 m (30 ft) unterminated cables, or Mini-style quick-disconnect (QD) fittings are available (“Q”- suffix models). QD cables are ordered separately. Operating Conditions Temperature: –25 °C to +55 °C (−13 °F to +131 °F) 90% at +50 °C maximum relative humidity (non-condensing) Application Notes Transient suppression is recommended for contacts switching inductive loads. Optional output timing modules are available. See Output Timing Logic and Signal Strength Display Modules on page 10 for more information. Certifications 3 Lexan® is a registered trademark of General Electric Co. P/N 53997 Rev. D www.bannerengineering.com - Tel: +1-763-544-3164 5 Q45VR3 Series Sensors Dimensions Opposed, Retro, and Diffuse Sensing Modes (Model Suffix E, R, D, DL, DX, LP, and LV) Cabled Models Quick-Disconnect Models 54.1 mm (2.13") 44.5 mm (1.75") Lens Centerline 50.8 mm (2.00") 69.0 mm (2.72") 6.4 mm (0.25") 87.6 mm (3.45") 4.5 mm (#10) Screw Clearance (2) 7.1 mm (0.28") 30.0 mm (1.18") Internal Thread (1/2–14NPSM) External thread (M30 x 1.5) hex nut supplied External Thread M30 X 1.5 14 mm (0.6") Mini-style QD Connector Convergent Sensor Models Glass Fiber Optic Models Plastic Fiber Optic Models (CV and CV4) (F and FV) (FP) 61.7 mm (2.43") 6 ø 6.1 (0.24") 2m (6.5') Cable 60.5 mm (2.38") www.bannerengineering.com - Tel: +1-763-544-3164 59.9 mm (2.36") P/N 53997 Rev. D Q45VR3 Series Sensors Performance Curves Opposed Beam Pattern Excess Gain 1000 E X C E S S G A I N Effective Beam: 13 mm Q45E/R Opposed Mode Q45E/R 1.5 m 100 40 in 0.5 m 20 in 0 10 0 0.5 m 20 in 1.0 m 40 in 1.5 m 1 0.1 m 0.33 ft 1.0 m 3.3 ft 10 m 33 ft 100 m 330 ft 60 in 0 12 m 40 ft DISTANCE Excess Gain G A I N Beam Pattern Retroreflective Mode Retroreflective Mode .10 m .33 ft 1.0 m 3.3 ft 3.0 in 50 mm 2.0 in 25 mm 1.0 in 0 With BRT-3 Reflector 1 .01 m .033 ft Q45LV 75 mm 10 0 With BRT-3 Reflector 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 10 m 33 ft 0 48 m 160 ft Excess Gain Q45LV 100 36 m 120 ft 60 m 200 ft Retroreflective Polarized 1000 1000 24 m 80 ft DISTANCE Retroreflective Non-Polarized E X C E S S 60 in Opposed Mode 1.0 m 3m 10 ft 6m 20 ft DISTANCE 9m 30 ft 12 m 40 ft E X C E S S G A I N Q45LP Retroreflective Mode 100 Q45LP 75 mm Retroreflective Mode 50 mm 25 mm 10 1 .01 m .033 ft 15 m 50 ft Beam Pattern .10 m .33 ft 1.0 m 3.3 ft 0 With BRT-3 Reflector 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 10 m 33 ft 0 1.5 m 5 ft DISTANCE DISTANCE 2.0 in 1.0 in 0 With BRT-3 Reflector 3.0 in 3m 10 ft 4.5 m 15 ft 6m 20 ft 7.5 m 25 ft DISTANCE Diffuse-mode performance curves are based on a 90% reflectance white test card. Diffuse Short Range Excess Gain Diffuse Long Range Beam Pattern 1000 1000 E X C E S S G A I N Q45D Diffuse Mode 15 mm 100 0.6 in Q45D 10 mm 0.4 in Diffuse Mode 5 mm 1 1.0 mm 0.04 in 0.2 in 0 10 10 mm 0.4 in 100 mm 4.0 in DISTANCE P/N 53997 Rev. D 1000 mm 40 in 0 5 mm 0.2 in 10 mm 0.4 in 15 mm 0.6 in 0 100 mm 4.0 in 200mm 8.0 in 300 mm 12.0 in DISTANCE Beam Pattern Excess Gain 400 mm 500 mm 16.0 in 20.0 in E X C E S S G A I N Q45DL Diffuse Mode 100 Q45DL 10 1 .01 m .033 ft Diffuse Mode 75 mm 3.0 in 50 mm 2.0 in 25 mm 1.0 in 0 0 25 mm 1.0 in 50 mm 2.0 in 75 mm .10 m .33 ft 1.0 m 3.3 ft DISTANCE www.bannerengineering.com - Tel: +1-763-544-3164 10 m 33 ft 3.0 in 0 0.6 m 2 ft 1.2 m 4 ft 1.8 m 6 ft 2.4 m 8 ft 3.0 m 10 ft DISTANCE 7 Q45VR3 Series Sensors Diffuse High Power Excess Gain Beam Pattern 1000 E X C E S S Q45DX Diffuse Mode 100 G A I N Q45DX 75 mm 10 3.0 in Diffuse Mode 50 mm 2.0 in 25 mm 1.0 in 0 1 0.01 m 0.033 ft 0.1 m 0.33 ft 1.0 m 3.3 ft 0 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 10 m 33 ft 0 0.6 m 2 ft 1.2 m 4 ft DISTANCE 1.8 m 6 ft 2.4 m 8 ft 3.0 m 10 ft DISTANCE Convergent mode performance curves are based on a 90% reflectance white test card. Convergent (CV and CVQ Models) Convergent (CV4 and CV4Q Models) Beam Pattern Excess Gain Excess Gain 1000 E X C E S S G A I N 1000 Q45CV E X C E S S Convergent Mode 100 Q45CV 3.8 mm 0.15 in Convergent Mode 2.5 mm 0.10 in 1.2 mm 10 1 1 mm .04 in 0.05 in 0 10 mm .4 in 100 mm 4 in Beam Pattern 0.05 in 2.5 mm 0.10 in 3.8 mm 0.15 in 1000 mm 40 in 0 38 mm 1.5 in DISTANCE 75 mm 3.0 in 113 mm 4.5 in 100 Q45CV4 3.8 mm 0.15 in Convergent Mode 2.5 mm 0.10 in 1.2 mm G A I N 0 1.2 mm Q45CV4 Convergent Mode 0.05 in 0 10 0 1.2 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 1 1 mm .04 in 150 mm 190 mm 6.0 in 7.5 in 10 mm .4 in 100 mm 4 in 1000 mm 40 in 0.15 in 0 38 mm 1.5 in 113 mm 4.5 in 150 mm 190 mm 6.0 in 7.5 in DISTANCE DISTANCE DISTANCE 75 mm 3.0 in Glass fiber optic Diffuse mode performance curves are based on a 90% reflectance white test card. Glass Fiber Optic, Infrared (Opposed Mode) Excess Gain Glass Fiber Optic, Infrared (Diffuse Mode) Beam Pattern 1000 E X C E S S G A I N Opposed Mode 100 Q45F 150 mm IT23S Fibers 50 mm 10 0 IT13S Fibers 0.1 m 0.33 ft 1.0 m 3.3 ft 10 m 33 ft 6.0 in Opposed Mode 100 mm IT23S Fibers DISTANCE 8 1000 Q45F 1 0.01 m 0.03 ft Beam Pattern Excess Gain 4.0 in 2.0 in 0 IT13S Fibers 50 mm 2.0 in 100 mm 4.0 in 150 mm 6.0 in 0 0.4 m 15 in 0.8 m 30 in 1.2 m 45 in DISTANCE 1.6 m 60 in 2.0 m 75 in E X C E S S G A I N Q45F Diffuse Mode 100 Q45F 3.8 mm Diffuse Mode 2.5 mm BT13S Fiber 10 mm 0.4 in 100 mm 4.0 in DISTANCE www.bannerengineering.com - Tel: +1-763-544-3164 1000 mm 40 in 0.10 in 0.05 in BT23S Fiber 0 10 1 1 mm 0.04 in BT13S Fiber 1.3 mm BT23S Fiber 0.15 in 0 1.3 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 0.15 in 0 25 mm 1 in 50 mm 2 in 75 mm 3 in 100 mm 125 mm 4 in 5 in DISTANCE P/N 53997 Rev. D Q45VR3 Series Sensors Glass Fiber Optic, Visible Red (Opposed Mode) Excess Gain Glass Fiber Optic, Visible Red (Diffuse Mode) Beam Pattern Excess Gain 1000 1000 E X C E S S G A I N Beam Pattern Q45FV Opposed Mode Q45FV 30 mm 100 Opposed Mode 20 mm IT23S Fibers 10 mm 0.4 in 0 10 1 1.0 mm 0.04 in 10 mm 0.4 in 0 10 mm IT13S Fibers 100 mm 4 in 1.2 in 0.8 in IT23S Fibers 0.4 in IT13S Fibers 20 mm 0.8 in 30 mm 1.2 in 0 1000 mm 40 in 100 mm 4 in 150 mm 6 in 200 mm 8 in E X C E S S G A I N Q45FV Diffuse Mode 100 1.0 mm 10 BT13S Fiber 0 1.0 mm BT23S Fiber 0.04 in BT23S Fiber 2.0 mm 0.08 in 3.0 mm 10 mm 0.4 in 100 mm 4.0 in 1000 mm 40 in 0.08 in 0.04 in BT13S Fiber 0 0.12 in 0 5 mm 0.2 in 10 mm 0.4 in DISTANCE DISTANCE DISTANCE 0.12 in Diffuse Mode 2.0 mm 1 1 mm 0.04 in 250 mm 300 mm 10 in 12 in Q45FV 3.0 mm 15 mm 0.6 in 20 mm 0.8 in 25 mm 1.0 in DISTANCE Plastic fiber optic Diffuse mode performance curves are based on a 90% reflectance white test card. Plastic Fiber Optic (Opposed Mode) Excess Gain Plastic Fiber Optic (Diffuse Mode) Beam Pattern Excess Gain 1000 E X C E S S 1000 Q45FP Opposed Mode 100 Q45FP 45 mm 0 PIT26U Fibers 100 mm 4.0 in 1.2 in 0.6 in 0 PIT26U Fibers 15 mm 10 mm 0.4 in PIT46U Fibers 15 mm 10 1 1 mm 0.04 in 1.8 in Opposed Mode 30 mm PIT46U Fibers G A I N Beam Pattern 0.6 in 30 mm 1.2 in 45 mm 1.8 in 1000 mm 40 in 0 DISTANCE 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 100 mm 125 mm 4.0 in 5.0 in DISTANCE E X C E S S G A I N Q45FP Diffuse Mode 100 PBT46U Fiber Q45FP 18 mm 0.75 in Diffuse Mode 12 mm 0.50 in PBT46U Fiber 6 mm PBT26U Fiber 1 0.1 mm 0.004 in 0.25 in 0 10 1 mm 0.04 in 10 mm 0.4 in 100 mm 4 in 0 6 mm 0.25 in 12 mm 0.50 in 18 mm 0.75 in 0 10 mm 0.4 in 20 mm 0.8 in DISTANCE 30 mm 1.2 in 40 mm 1.6 in 50 mm 2.0 in DISTANCE Accessories Cordsets 3-Pin Mini-Style Cordsets Model Length MBCC-306 1.83 m (6.5 ft) MBCC-312 3.66 m (12 ft) Style Dimensions 52 Typ. Pinout (Female) 2 3 Straight MBCC-330 1 7/8-16UN-2B ø 25.5 9.14 m (30 ft) 1 = Black 2 = Brown 3 = Blue 5-Pin Mini-Style Cordsets Model Length MBCC-506 1.83 m (6 ft) MBCC-512 3.66 m (12 ft) Style Dimensions Pinout (Female) 52 Typ. 7/8-16UN-2B P/N 53997 Rev. D ø 25.5 9.14 m (30 ft) www.bannerengineering.com - Tel: +1-763-544-3164 2 4 3 Straight MBCC-530 1 5 1 = Black 2 = Blue 3 = Yellow 4 = Brown 5 = White 9 Q45VR3 Series Sensors Retroreflective Targets Banner offers a wide selection of high-quality retroreflective targets. See www.bannerengineering.com for complete information. Note: Polarized sensors require corner cube type retroreflective targets. Non-polarized sensors may use any retroreflective target. Brackets SMB30C • 30 mm split clamp, black PBT bracket • Stainless steel mounting hardware included • Mounting hole for 30 mm sensor 56 A 66 B SMB30MM • 12-ga. stainless steel bracket with curved mounting slots for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor 13 Hole center spacing: A=ø 45 Hole size: B=ø 27.2 57 70 C 57 B A Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 SMB30SC • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 67 B 58 29 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 Output Timing Logic and Signal Strength Display Modules Q45 sensors easily accept the addition of output timing logic and signal strength display functions. Display modules have a sevenelement display that gives a more precise indication of excess gain than does the AID™ system LED that is standard on Q45 sensors. The modules listed below may be used with all Q45VR3 sensors. Refer to the module's datasheet for more information. Models Logic and/or Display Function 45LM58 Programmable output timing logic 45LM58D Programmable output timing logic plus signal strength display 45LMD Signal strength display only (no timing function) 10 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 53997 Rev. D Q45VR3 Series Sensors Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
Q45VR3R 价格&库存
很抱歉,暂时无法提供与“Q45VR3R”相匹配的价格&库存,您可以联系我们找货
Q45VR3R
  • 1+1668.945611+216.88374
库存:3
