MC68HC908GR16
Data Sheet
M68HC08
Microcontrollers
MC68HC908GR16/D
Rev. 1.0
5/2003
MOTOROLA.COM/SEMICONDUCTORS
MC68HC908GR16
Data Sheet
To provide the most up-to-date information, the revision of our documents on the
World Wide Web will be the most current. Your printed copy may be an earlier
revision. To verify you have the latest information available, refer to:
http://motorola.com/semiconductors
The following revision history table summarizes changes contained in this
document. For your convenience, the page number designators have been linked
to the appropriate location.
MC68HC908GR16 — Rev. 1.0
MOTOROLA
Data Sheet
3
Revision History
Revision History
Date
February,
2003
May,
2003
Revision
Level
N/A
1.0
Initial release
N/A
Reorganized to meet latest publication standards for M68HC08 Family
documentation
N/A
Section 16. Serial Peripheral Interface (SPI) Module — Removed all
references to DMAS
215
Figure 4-2. CGM External Connections — Figure updated for consistency
68
Table 4-4. Example Filter Component Values — Table updated to reflect
new resistor values
80
Data Sheet
4
Page
Number(s)
Description
Revision History
MOTOROLA
Data Sheet — MC68HC908GR16
List of Sections
Section 1. General Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .19
Section 2. Memory . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27
Section 3. Analog-to-Digital Converter (ADC) . . . . . . . . . . . . . . . . . . . 47
Section 4. Clock Generator Module (CGM). . . . . . . . . . . . . . . . . . . . . . 59
Section 5. Configuration Register (CONFIG) . . . . . . . . . . . . . . . . . . . . 81
Section 6. Computer Operating Properly (COP) Module. . . . . . . . . . . 85
Section 7. Central Processor Unit (CPU) . . . . . . . . . . . . . . . . . . . . . . . 89
Section 8. External Interrupt (IRQ) . . . . . . . . . . . . . . . . . . . . . . . . . . . 103
Section 9. Keyboard Interrupt Module (KBI) . . . . . . . . . . . . . . . . . . . 109
Section 10. Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .117
Section 11. Low-Voltage Inhibit (LVI) . . . . . . . . . . . . . . . . . . . . . . . . . 125
Section 12. Input/Output Ports (PORTS) . . . . . . . . . . . . . . . . . . . . . . 129
Section 13. Resets and Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145
Section 14. Enhanced Serial Communications
Interface (ESCI) Module . . . . . . . . . . . . . . . . . . . . . . . . . 159
Section 15. System Integration Module (SIM) . . . . . . . . . . . . . . . . . . 195
Section 16. Serial Peripheral Interface (SPI) Module. . . . . . . . . . . . . 215
Section 17. Timebase Module (TBM). . . . . . . . . . . . . . . . . . . . . . . . . . 239
Section 18. Timer Interface Module (TIM) . . . . . . . . . . . . . . . . . . . . . . 245
Section 19. Development Support . . . . . . . . . . . . . . . . . . . . . . . . . . . 263
Section 20. Electrical Specifications. . . . . . . . . . . . . . . . . . . . . . . . . . 281
Section 21. Ordering Information
and Mechanical Specifications . . . . . . . . . . . . . . . . . . . 305
MOTOROLA
Data Sheet
List of Sections
5
List of Sections
Data Sheet
6
List of Sections
MOTOROLA
Table of Contents
1.1
1.2
1.2.1
1.2.2
1.3
1.4
1.5
1.5.1
1.5.2
1.5.3
1.5.4
1.5.5
1.5.6
1.5.7
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Standard Features of the MC68HC908GR16. . . . . . . . . . . . . . . . . .
Features of the CPU08 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
MCU Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Pin Assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Power Supply Pins (VDD and VSS) . . . . . . . . . . . . . . . . . . . . . . . . . .
Oscillator Pins (OSC1 and OSC2) . . . . . . . . . . . . . . . . . . . . . . . . . .
External Reset Pin (RST) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
External Interrupt Pin (IRQ) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
CGM Power Supply Pins (VDDA and VSSA) . . . . . . . . . . . . . . . . . . .
External Filter Capacitor Pin (VCGMXFC). . . . . . . . . . . . . . . . . . . . . .
ADC Power Supply/Reference Pins
(VDDAD/VREFH and VSSAD/VREFL) . . . . . . . . . . . . . . . . . . . . . . . .
1.5.8
Port A Input/Output (I/O) Pins (PTA7/KBD7–PTA0/KBD0). . . . . . . .
1.5.9
Port B I/O Pins (PTB7/AD7–PTB0/AD0). . . . . . . . . . . . . . . . . . . . . .
1.5.10
Port C I/O Pins (PTC6–PTC0) . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
1.5.11
Port D I/O Pins (PTD7/T2CH1–PTD0/SS) . . . . . . . . . . . . . . . . . . . .
1.5.12
Port E I/O Pins (PTE5–PTE2, PTE1/RxD, and PTE0/TxD) . . . . . . .
19
19
19
21
21
21
24
24
24
24
25
25
25
25
25
25
25
26
26
Section 2. Memory
2.1
2.2
Unimplemented Memory Locations . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.3
Reserved Memory Locations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.4
Input/Output (I/O) Section. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.5
Random-Access Memory (RAM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6
FLASH Memory (FLASH) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6.1
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6.1.1
FLASH Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6.1.2
FLASH Page Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6.1.3
FLASH Mass Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6.1.4
FLASH Program/Read Operation . . . . . . . . . . . . . . . . . . . . . . . . .
2.6.1.5
FLASH Block Protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6.1.6
FLASH Block Protect Register . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6.2
Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6.3
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
MOTOROLA
27
27
27
27
38
38
38
39
40
41
41
44
44
45
46
Data Sheet
Table of Contents
7
Table of Contents
3.1
3.2
3.3
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.3.1
ADC Port I/O Pins. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.3.2
Voltage Conversion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.3.3
Conversion Time. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.3.4
Conversion . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.3.5
Accuracy and Precision . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.3.6
Result Justification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.4
Monotonicity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.5
Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.6
Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.6.1
3.6.2
3.7
I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.7.1
ADC Analog Power Pin (VDDAD). . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.7.2
ADC Analog Ground Pin (VSSAD) . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.7.3
ADC Voltage Reference High Pin (VREFH) . . . . . . . . . . . . . . . . . . . .
3.7.4
ADC Voltage Reference Low Pin (VREFL) . . . . . . . . . . . . . . . . . . . .
3.7.5
ADC Voltage In (VADIN) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.8
I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.8.1
ADC Status and Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.8.2
ADC Data Register High and Data Register Low . . . . . . . . . . . . . . .
3.8.2.1
Left Justified Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.8.2.2
Right Justified Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.8.2.3
Left Justified Signed Data Mode . . . . . . . . . . . . . . . . . . . . . . . . . .
3.8.2.4
Eight Bit Truncation Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.8.3
ADC Clock Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
47
47
47
47
49
50
50
50
50
52
52
52
52
52
52
52
53
53
53
53
53
54
55
55
56
56
57
57
4.1
4.2
4.3
4.3.1
4.3.2
4.3.3
4.3.4
4.3.5
4.3.6
4.3.7
4.3.8
4.3.9
Crystal Oscillator Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Phase-Locked Loop Circuit (PLL). . . . . . . . . . . . . . . . . . . . . . . . . . .
PLL Circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Acquisition and Tracking Modes. . . . . . . . . . . . . . . . . . . . . . . . . . . .
Manual and Automatic PLL Bandwidth Modes . . . . . . . . . . . . . . . . .
Programming the PLL. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Special Programming Exceptions. . . . . . . . . . . . . . . . . . . . . . . . . . .
Base Clock Selector Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
CGM External Connections . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Data Sheet
8
59
59
59
61
61
61
62
63
64
67
67
67
Table of Contents
MOTOROLA
Table of Contents
4.4
4.4.1
4.4.2
4.4.3
4.4.4
4.4.5
4.4.6
4.4.7
4.4.8
4.4.9
4.4.10
4.5
4.5.1
4.5.2
4.5.3
4.5.4
4.5.5
4.5.6
4.6
4.7
4.7.1
4.7.2
4.7.3
4.8
4.8.1
4.8.2
4.8.3
Crystal Amplifier Input Pin (OSC1) . . . . . . . . . . . . . . . . . . . . . . . . . .
Crystal Amplifier Output Pin (OSC2) . . . . . . . . . . . . . . . . . . . . . . . .
External Filter Capacitor Pin (CGMXFC) . . . . . . . . . . . . . . . . . . . . .
PLL Analog Power Pin (VDDA) . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
PLL Analog Ground Pin (VSSA) . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Oscillator Enable Signal (SIMOSCEN) . . . . . . . . . . . . . . . . . . . . . . .
Oscillator Stop Mode Enable Bit (OSCSTOPENB). . . . . . . . . . . . . .
Crystal Output Frequency Signal (CGMXCLK). . . . . . . . . . . . . . . . .
CGM Base Clock Output (CGMOUT) . . . . . . . . . . . . . . . . . . . . . . . .
CGM CPU Interrupt (CGMINT). . . . . . . . . . . . . . . . . . . . . . . . . . . . .
CGM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
PLL Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
PLL Bandwidth Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . .
PLL Multiplier Select Register High . . . . . . . . . . . . . . . . . . . . . . . . .
PLL Multiplier Select Register Low . . . . . . . . . . . . . . . . . . . . . . . . . .
PLL VCO Range Select Register . . . . . . . . . . . . . . . . . . . . . . . . . . .
PLL Reference Divider Select Register . . . . . . . . . . . . . . . . . . . . . .
Special Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
CGM During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Acquisition/Lock Time Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . .
Acquisition/Lock Time Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . .
Parametric Influences on Reaction Time . . . . . . . . . . . . . . . . . . . . .
Choosing a Filter. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
69
69
69
69
69
69
69
69
70
70
70
70
71
73
74
75
75
76
76
77
77
77
78
78
78
79
80
5.1
5.2
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 81
Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 81
6.1
6.2
6.3
6.3.1
6.3.2
6.3.3
6.3.4
6.3.5
6.3.6
6.3.7
6.3.8
6.4
CGMXCLK . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
STOP Instruction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
COPCTL Write . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Power-On Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Internal Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Reset Vector Fetch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
COPD (COP Disable) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
COPRS (COP Rate Select) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
COP Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
MOTOROLA
85
85
86
86
86
86
86
87
87
87
87
87
Data Sheet
Table of Contents
9
Table of Contents
6.5
6.6
6.7
6.7.1
6.7.2
6.8
Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
COP Module During Break Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
87
87
88
88
88
88
7.1
7.2
7.3
7.3.1
7.3.2
7.3.3
7.3.4
7.3.5
7.4
7.5
7.5.1
7.5.2
7.6
7.7
7.8
Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 89
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 89
CPU Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90
Accumulator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90
Index Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90
Stack Pointer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91
Program Counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91
Condition Code Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 92
Arithmetic/Logic Unit (ALU) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 93
Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94
Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94
Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94
CPU During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94
Instruction Set Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94
Opcode Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101
8.1
8.2
8.3
8.4
8.5
8.6
IRQ Pin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
IRQ Module During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . .
IRQ Status and Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
103
103
103
106
106
107
9.1
9.2
9.3
9.4
9.5
9.5.1
9.5.2
9.6
Keyboard Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Keyboard Module During Break Interrupts . . . . . . . . . . . . . . . . . . . . . .
Data Sheet
10
109
109
109
112
113
113
113
113
Table of Contents
MOTOROLA
Table of Contents
9.7
9.7.1
9.7.2
I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 114
Keyboard Status and Control Register . . . . . . . . . . . . . . . . . . . . . . 114
Keyboard Interrupt Enable Register . . . . . . . . . . . . . . . . . . . . . . . . 115
10.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.1.1
10.1.2
10.2 Analog-to-Digital Converter (ADC) . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.2.1
10.2.2
10.3 Break Module (BRK). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.3.1
10.3.2
10.4 Central Processor Unit (CPU). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.4.1
10.4.2
10.5 Clock Generator Module (CGM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.5.1
10.5.2
10.6 Computer Operating Properly Module (COP). . . . . . . . . . . . . . . . . . . .
10.6.1
10.6.2
10.7 External Interrupt Module (IRQ) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.7.1
10.7.2
10.8 Keyboard Interrupt Module (KBI) . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.8.1
10.8.2
10.9 Low-Voltage Inhibit Module (LVI) . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.9.1
10.9.2
10.10 Enhanced Serial Communications Interface Module (ESCI) . . . . . . . .
10.10.1
10.10.2
10.11 Serial Peripheral Interface Module (SPI) . . . . . . . . . . . . . . . . . . . . . . .
10.11.1
10.11.2
10.12 Timer Interface Module (TIM1 and TIM2) . . . . . . . . . . . . . . . . . . . . . . .
10.12.1
10.12.2
10.13 Timebase Module (TBM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.13.1
10.13.2
MOTOROLA
117
117
117
117
117
117
118
118
118
118
118
118
118
118
119
119
119
119
119
119
119
120
120
120
120
120
120
120
120
120
121
121
121
121
121
121
121
121
121
Data Sheet
Table of Contents
11
Table of Contents
10.14 Exiting Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 122
10.15 Exiting Stop Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 123
11.1
11.2
11.3
11.3.1
11.3.2
11.3.3
11.3.4
11.4
11.5
11.6
11.6.1
11.6.2
Polled LVI Operation. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Forced Reset Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Voltage Hysteresis Protection. . . . . . . . . . . . . . . . . . . . . . . . . . . . .
LVI Trip Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
LVI Status Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
LVI Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
12.1
12.2
12.2.1
12.2.2
12.2.3
12.3
12.3.1
12.3.2
12.4
12.4.1
12.4.2
12.4.3
12.5
12.5.1
12.5.2
12.5.3
12.6
12.6.1
12.6.2
Port A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Port A Data Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Data Direction Register A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Port A Input Pullup Enable Register . . . . . . . . . . . . . . . . . . . . . . . .
Port B . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Port B Data Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Data Direction Register B . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Port C . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Port C Data Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Data Direction Register C . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Port C Input Pullup Enable Register . . . . . . . . . . . . . . . . . . . . . . . .
Port D . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Port D Data Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Data Direction Register D . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Port D Input Pullup Enable Register . . . . . . . . . . . . . . . . . . . . . . . .
Port E . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Port E Data Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Data Direction Register E . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
125
125
125
127
127
127
127
127
128
128
128
128
129
132
132
132
133
134
134
135
136
136
136
138
138
138
139
141
141
141
142
13.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.2 Resets . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.2.1
Effects. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.2.2
External Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.2.3
Data Sheet
12
145
145
145
145
145
Table of Contents
MOTOROLA
Table of Contents
13.2.3.1
Power-On Reset (POR) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.2.3.2
Computer Operating Properly (COP) Reset . . . . . . . . . . . . . . . .
13.2.3.3
Low-Voltage Inhibit (LVI) Reset . . . . . . . . . . . . . . . . . . . . . . . . .
13.2.3.4
Illegal Opcode Reset. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.2.3.5
Illegal Address Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.2.4
System Integration Module (SIM) Reset Status Register . . . . . . . .
13.3 Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.3.1
13.3.2
Sources. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.3.2.1
Software Interrupt (SWI) Instruction . . . . . . . . . . . . . . . . . . . . . .
13.3.2.2
Break Interrupt . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.3.2.3
13.3.2.4
Clock Generator (CGM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.3.2.5
Timer Interface Module 1 (TIM1). . . . . . . . . . . . . . . . . . . . . . . . .
13.3.2.6
Timer Interface Module 2 (TIM2). . . . . . . . . . . . . . . . . . . . . . . . .
13.3.2.7
Serial Peripheral Interface (SPI) . . . . . . . . . . . . . . . . . . . . . . . . .
13.3.2.8
Serial Communications Interface (SCI) . . . . . . . . . . . . . . . . . . . .
13.3.2.9
KBD0–KBD7 Pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.3.2.10
13.3.2.11
Timebase Module (TBM). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.3.3
Interrupt Status Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.3.3.1
Interrupt Status Register 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.3.3.2
Interrupt Status Register 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
13.3.3.3
Interrupt Status Register 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
146
146
147
147
147
147
149
149
150
152
153
153
153
153
153
154
154
155
155
155
155
156
157
157
14.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.2 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.3 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.1
Data Format . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.2
Transmitter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.2.1
Character Length . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.2.2
Character Transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.2.3
Break Characters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.2.4
Idle Characters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.2.5
Inversion of Transmitted Output . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.2.6
Transmitter Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.3
Receiver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.3.1
14.4.3.2
Character Reception . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.3.3
Data Sampling. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.3.4
Framing Errors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.3.5
Baud Rate Tolerance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.3.6
Receiver Wakeup . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
MOTOROLA
159
159
161
161
164
164
164
164
166
166
167
167
167
167
169
169
171
171
173
Data Sheet
Table of Contents
13
Table of Contents
14.4.3.7
Receiver Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.4.3.8
Error Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.5 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.5.1
14.5.2
14.6 ESCI During Break Module Interrupts . . . . . . . . . . . . . . . . . . . . . . . . .
14.7 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.7.1
PTE0/TxD (Transmit Data) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.7.2
PTE1/RxD (Receive Data) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.8 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.8.1
ESCI Control Register 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.8.2
ESCI Control Register 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.8.3
ESCI Control Register 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.8.4
ESCI Status Register 1. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.8.5
ESCI Status Register 2. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.8.6
ESCI Data Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.8.7
ESCI Baud Rate Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.8.8
ESCI Prescaler Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.9 ESCI Arbiter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.9.1
ESCI Arbiter Control Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.9.2
ESCI Arbiter Data Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.9.3
Bit Time Measurement . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
14.9.4
Arbitration Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
173
173
174
174
174
174
175
175
175
175
176
178
180
181
184
185
185
187
191
191
192
192
194
15.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.2 SIM Bus Clock Control and Generation . . . . . . . . . . . . . . . . . . . . . . . .
15.2.1
Bus Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.2.2
Clock Startup from POR or LVI Reset . . . . . . . . . . . . . . . . . . . . . .
15.2.3
Clocks in Stop Mode and Wait Mode . . . . . . . . . . . . . . . . . . . . . . .
15.3 Reset and System Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.3.1
External Pin Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.3.2
Active Resets from Internal Sources . . . . . . . . . . . . . . . . . . . . . . .
15.3.2.1
15.3.2.2
15.3.2.3
15.3.2.4
15.3.2.5
15.3.2.6
Monitor Mode Entry Module Reset (MODRST). . . . . . . . . . . . . .
15.4 SIM Counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.4.1
SIM Counter During Power-On Reset . . . . . . . . . . . . . . . . . . . . . .
15.4.2
SIM Counter During Stop Mode Recovery . . . . . . . . . . . . . . . . . . .
15.4.3
SIM Counter and Reset States . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Data Sheet
14
195
198
198
198
199
199
200
200
201
202
202
202
203
203
203
203
203
203
Table of Contents
MOTOROLA
Table of Contents
15.5 Exception Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.5.1
Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.5.1.1
Hardware Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.5.1.2
SWI Instruction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.5.1.3
15.5.2
Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.5.3
Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.5.4
Status Flag Protection in Break Mode . . . . . . . . . . . . . . . . . . . . . .
15.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.6.1
15.6.2
15.7 SIM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.7.1
Break Status Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.7.2
SIM Reset Status Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15.7.3
Break Flag Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
204
204
206
207
207
209
209
209
209
209
211
212
212
213
214
16.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.2 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.3 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.4.1
Master Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.4.2
Slave Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.5 Transmission Formats . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.5.1
Clock Phase and Polarity Controls . . . . . . . . . . . . . . . . . . . . . . . . .
16.5.2
Transmission Format When CPHA = 0. . . . . . . . . . . . . . . . . . . . . .
16.5.3
Transmission Format When CPHA = 1. . . . . . . . . . . . . . . . . . . . . .
16.5.4
Transmission Initiation Latency . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.6 Queuing Transmission Data . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.7 Error Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.7.1
Overflow Error. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.7.2
Mode Fault Error. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.8 Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.9 Resetting the SPI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.10 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.10.1
16.10.2
16.11 SPI During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.12 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.12.1
MISO (Master In/Slave Out) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.12.2
MOSI (Master Out/Slave In) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.12.3
SPSCK (Serial Clock) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.12.4
SS (Slave Select) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.12.5
CGND (Clock Ground) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
MOTOROLA
215
215
217
217
219
220
220
221
221
222
223
225
226
226
228
229
230
231
231
231
231
232
232
233
233
233
234
Data Sheet
Table of Contents
15
Table of Contents
16.13 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.13.1
SPI Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
16.13.2
SPI Status and Control Register. . . . . . . . . . . . . . . . . . . . . . . . . . .
16.13.3
SPI Data Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
234
234
236
238
17.1
17.2
17.3
17.4
17.5
17.6
17.6.1
17.6.2
17.7
TBM Interrupt Rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Timebase Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
239
239
239
240
241
241
241
242
242
18.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.2 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.3 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.4.1
TIM Counter Prescaler . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.4.2
Input Capture . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.4.3
Output Compare . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.4.3.1
Unbuffered Output Compare. . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.4.3.2
Buffered Output Compare . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.4.4
Pulse Width Modulation (PWM) . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.4.4.1
Unbuffered PWM Signal Generation. . . . . . . . . . . . . . . . . . . . . .
18.4.4.2
Buffered PWM Signal Generation . . . . . . . . . . . . . . . . . . . . . . . .
18.4.4.3
PWM Initialization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.5 Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.6.1
18.6.2
18.7 TIM During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.8 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.9 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.9.1
TIM Status and Control Register . . . . . . . . . . . . . . . . . . . . . . . . . .
18.9.2
TIM Counter Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.9.3
TIM Counter Modulo Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . .
18.9.4
TIM Channel Status and Control Registers . . . . . . . . . . . . . . . . . .
18.9.5
TIM Channel Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Data Sheet
16
245
247
247
247
250
250
250
250
251
251
252
253
253
254
255
255
255
255
255
256
256
258
258
259
262
Table of Contents
MOTOROLA
Table of Contents
19.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.2 Break Module (BRK). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.2.1
19.2.1.1
Flag Protection During Break Interrupts . . . . . . . . . . . . . . . . . . .
19.2.1.2
19.2.1.3
19.2.1.4
COP During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.2.2
Break Module Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.2.2.1
Break Status and Control Register . . . . . . . . . . . . . . . . . . . . . . .
19.2.2.2
Break Address Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.2.2.3
Break Auxiliary Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.2.2.4
Break Status Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.2.2.5
19.2.3
19.3 Monitor ROM (MON) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.3.1
19.3.1.1
Normal Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.3.1.2
Forced Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.3.1.3
Monitor Vectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.3.1.4
19.3.1.5
Break Signal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.3.1.6
Baud Rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.3.1.7
Commands . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
19.3.2
Security. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
263
263
263
265
265
265
265
265
266
266
267
267
268
268
268
269
272
274
274
275
275
275
276
279
20.1 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.2 Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.3 Functional Operating Range. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.4 Thermal Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.5 5.0-Vdc Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.6 3.3-Vdc Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.7 5.0-Volt Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.8 3.3-Volt Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.9 Output High-Voltage Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . .
20.10 Output Low-Voltage Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.11 Typical Supply Currents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.12 Clock Generation Module Characteristics . . . . . . . . . . . . . . . . . . . . . .
20.12.1
CGM Component Specifications. . . . . . . . . . . . . . . . . . . . . . . . . . .
20.12.2
CGM Electrical Specifications. . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.13 5.0-Volt ADC Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.14 3.3-Volt ADC Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
20.15 Timer Interface Module Characteristics . . . . . . . . . . . . . . . . . . . . . . . .
MOTOROLA
281
281
282
282
283
285
287
287
288
291
294
295
295
296
297
298
299
Data Sheet
Table of Contents
17
Table of Contents
20.16 5.0-Volt SPI Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 300
20.17 3.3-Volt SPI Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 301
20.18 Memory Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 304
21.1
21.2
21.3
21.4
MC Order Numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
48-Pin LQFP (Case #932) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
32-Pin LQFP (Case #873A) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Data Sheet
18
305
305
306
307
Table of Contents
MOTOROLA
1.1 Introduction
The MC68HC908GR16 is a member of the low-cost, high-performance M68HC08
Family of 8-bit microcontroller units (MCUs). All MCUs in the family use the
enhanced M68HC08 central processor unit (CPU08) and are available with a
variety of modules, memory sizes and types, and package types.
1.2 Features
For convenience, features have been organized to reflect:
Standard features of the MC68HC908GR16
1.2.1 Standard Features of the MC68HC908GR16
Features of the MC68HC908GR16 include:
High-performance M68HC08 architecture optimized for C-compilers
Fully upward-compatible object code with M6805, M146805, and M68HC05
Families
8-MHz internal bus frequency
Clock generation module supporting 32-kHz to 100-kHz crystals
FLASH program memory security(1)
On-chip programming firmware for use with host personal computer which
does not require high voltage for entry
In-system programming (ISP)
System protection features:
– Optional computer operating properly (COP) reset
– Low-voltage detection with optional reset and selectable trip points for
3.3-V and 5.0-V operation
– Illegal opcode detection with reset
– Illegal address detection with reset
1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or
copying the FLASH difficult for unauthorized users.
MOTOROLA
Data Sheet
General Description
19
General Description
Low-power design; fully static with stop and wait modes
Standard low-power modes of operation:
– Wait mode
– Stop mode
Master reset pin and power-on reset (POR)
16 Kbytes of on-chip 100k cycle write/erase capable FLASH memory
1 Kbyte of on-chip random-access memory (RAM)
406 bytes of FLASH programming routines read-only memory (ROM)
Serial peripheral interface (SPI) module
Enhanced serial communications interface (ESCI) module
Two 16-bit timer interface modules (2-channel TIM1 and 2-channel TIM2)
with selectable input capture, output compare, and pulse-width modulation
(PWM) capability on each channel
8-channel, 10-bit successive approximation analog-to-digital converter
(ADC)
BREAK (BRK) module to allow single breakpoint setting during in-circuit
debugging
Internal pullups on IRQ and RST to reduce customer system cost
Up to 37 general-purpose input/output (I/O) pins, including:
– 28 shared-function I/O pins
– Up to nine dedicated I/O pins, depending on package choice
Selectable pullups on inputs only on ports A, C, and D. Selection is on an
individual port bit basis. During output mode, pullups are disengaged.
High current 10-mA sink/source capability on all port pins
Higher current 20-mA sink/source capability on PTC0–PTC4
Timebase module (TBM) with clock prescaler circuitry for eight user
selectable periodic real-time interrupts with optional active clock source
during stop mode for periodic wakeup from stop using an external crystal
User selection of having the oscillator enabled or disabled during stop mode
8-bit keyboard wakeup port
5 mA maximum current injection on all port pins to maintain input protection
Available packages:
– 32-pin LQFP
– 48-pin low-profile quad flag pack (LQFP)
Data Sheet
General Description
MOTOROLA
General Description
MCU Block Diagram
Specific features of the MC68HC908GR16 in 32-pin LQFP are:
– Port A is only 4 bits: PTA0–PTA3; 4-pin keyboard interrupt (KBI) module
– Port B is only 6 bits: PTB0–PTB5; 6-channel ADC module
– Port C is only 2 bits: PTC0–PTC1
– Port D is only 7 bits: PTD0–PTD6; shared with SPI, TIM1, and TIM2
modules
– Port E is only 2 bits: PTE0–PTE1; shared with ESCI module
Specific features of the MC68HC908GR16 in 48-pin LQFP are:
– Port A is 8 bits: PTA0–PTA7; 8-pin KBI module
– Port B is 8 bits: PTB0–PTB7; 8-channel ADC module
– Port C is only 7 bits: PTC0–PTC6
– Port D is 8 bits: PTD0–PTD7; shared with SPI, TIM1, and TIM2 modules
– Port E is only 6 bits: PTE0–PTE5; shared with ESCI module
1.2.2 Features of the CPU08
Features of the CPU08 include:
Enhanced HC05 programming model
Extensive loop control functions
16 addressing modes (eight more than the HC05)
16-bit index register and stack pointer
Memory-to-memory data transfers
Fast 8 × 8 multiply instruction
Fast 16/8 divide instruction
Binary-coded decimal (BCD) instructions
Optimization for controller applications
Efficient C language support
1.3 MCU Block Diagram
Figure 1-1 shows the structure of the MC68HC908GR16.
1.4 Pin Assignments
Figure 1-2 and Figure 1-3 illustrate the pin assignments for the 32-pin LQFP and
48-pin LQFP respectively.
MOTOROLA
Data Sheet
General Description
21
DDRA
PORTA
PORTB
USER RAM — 1024 BYTES
PTB7/AD7
PTB6/AD6
PTB5/AD5
PTB4/AD4
PTB3/AD3
PTB2/AD2
PTB1/AD1
PTB0/AD0
PTC6(1)
PTC5(1)
PTC4(1), (2)
PTC3(1), (2)
PTC2(1), (2)
PTC1(1), (2)
PTC0(1), (2)
PTD7/T2CH1(1)
PTD6/T2CH0(1)
PTD5/T1CH1(1)
PTD4/T1CH0(1)
PTD3/SPSCK(1)
PTD2/MOSI(1)
PTD1/MISO(1)
PTD0/SS(1)
PTE5–PTE2
PTE1/RxD
PTE0/TxD
DDRB
SINGLE BREAKPOINT
BREAK MODULE
DUAL VOLTAGE
LOW-VOLTAGE INHIBIT
MODULE
USER FLASH — 15,872 BYTES
8-BIT KEYBOARD
INTERRUPT MODULE
MONITOR ROM — 350 BYTES
32–100 kHz OSCILLATOR
ENHANCED SERIAL
COMUNICATIONS
INTERFACE MODULE
PHASE LOCKED LOOP
COMPUTER OPERATING
PROPERLY MODULE
RST(3)
SYSTEM INTEGRATION
MODULE
SERIAL PERIPHERAL
INTERFACE MODULE
IRQ(3)
SINGLE EXTERNAL
INTERRUPT MODULE
MONITOR MODULE
10-BIT ANALOG-TO-DIGITAL
CONVERTER MODULE
DATA BUS SWITCH
MODULE
POWER-ON RESET
MODULE
MEMORY MAP
MODULE
POWER
CONFIGURATION
REGISTER 1–2
MODULE
CGMXFC
VDDAD/VREFH
VDDAD/VREFL
MOTOROLA
VDD
VSS
VDDA
VSSA
DDRD
General Description
CLOCK GENERATOR MODULE
DDRC
2-CHANNEL TIMER
INTERFACE MODULE 2
USER FLASH VECTOR SPACE — 44 BYTES
OSC1
OSC2
2-CHANNEL TIMER
INTERFACE MODULE 1
DDRE
FLASH PROGRAMMING ROUTINES ROM — 406 BYTES
PTA7/KBD7–PTA0/KBD0(1)
PORTC
CONTROL AND STATUS REGISTERS — 64 BYTES
PROGRAMMABLE TIMEBASE
MODULE
PORTD
ARITHMETIC/LOGIC
UNIT (ALU)
PORTE
CPU
REGISTERS
SECURITY
MODULE
MONITOR MODE ENTRY
MODULE
1. Ports are software configurable with pullup device if input port.
2. Higher current drive port pins
3. Pin contains integrated pullup device
Figure 1-1. MCU Block Diagram
General Description
Data Sheet
22
INTERNAL BUS
M68HC08 CPU
CGMXFC
VSSA
VDDA
PTC1
PTC0
PTA3/KBD3
30
29
28
27
26
25
1
OSC2
RST
31
32 OSC1
General Description
Pin Assignments
24
PTA2/KBD2
7
18
PTB4/AD4
PTD3/SPSCK
8
17
PTB3/AD3
16
PTD2/MOSI
PTB2/AD2
PTB5/AD5
15
19
14
6
PTB1/AD1
PTD1/MISO
PTB0/AD0
VDDAD/VREFH
13
PTD6/T2CH0
5
12
VSSAD/VREFL
PTD0/SS
PTD5/T1CH1
21
11
4
PTD4/T1CH0
PTA0/KBD0
IRQ
10
PTA1/KBD1
22
VDD
23
3
9
2
VSS
PTE0/TxD
PTE1/RxD
CGMXFC
VSSA
VDDA
PTC1
PTC0
PTA7/KBD7
PTA6/KBD6
PTA5/KBD5
PTA4/KBD4
46
45
44
43
42
41
40
39
38
37 PTA3/KBD3
OSC2
48 OSC1
RST 1
47
Figure 1-2. 32-Pin LQFP Pin Assignments
36 PTA2/KBD2
PTE5
7
30
VDDAD/VREFH
IRQ
8
29
PTB7/AD7
PTD0/SS
9
28
PTB6/AD6
PTD1/MISO
10
27
PTB5/AD5
PTD2/MOSI
11
26
PTB4/AD4
25 PTB3/AD3
PTB2/AD2 24
VSS 13
PTD3/SPSCK 12
23
VSSAD/VREFL
PTB1/AD1
31
22
6
PTB0/AD0
PTE4
21
PTC5
PTC4
32
19
PTE3
PTC3
PTC6
18
33
PTC2
4
PTD7/T2CH1
PTE2
17
PTA0/KBD0
PTD6/T2CH0
34
16
3
PTD5/T1CH1
PTE1/RxD
15
PTA1/KBD1
PTD4/T1CH0
35
14
2
VDD
PTE0/TxD
Figure 1-3. 48-Pin LQFP Pin Assignments
MOTOROLA
Data Sheet
General Description
23
General Description
1.5 Pin Functions
Descriptions of the pin functions are provided here.
1.5.1 Power Supply Pins (VDD and VSS)
VDD and VSS are the power supply and ground pins. The MCU operates from a
single power supply.
Fast signal transitions on MCU pins place high, short-duration current demands on
the power supply. To prevent noise problems, take special care to provide power
supply bypassing at the MCU as Figure 1-4 shows. Place the C1 bypass capacitor
as close to the MCU as possible. Use a high-frequency-response ceramic
capacitor for C1. C2 is an optional bulk current bypass capacitor for use in
applications that require the port pins to source high current levels.
MCU
VSS
VDD
C1
0.1 µF
C2
VDD
Note: Component values shown represent typical applications.
Figure 1-4. Power Supply Bypassing
1.5.2 Oscillator Pins (OSC1 and OSC2)
OSC1 and OSC2 are the connections for an external crystal, resonator, or clock
circuit. See Section 4. Clock Generator Module (CGM).
1.5.3 External Reset Pin (RST)
A logic 0 on the RST pin forces the MCU to a known startup state. RST is
bidirectional, allowing a reset of the entire system. It is driven low when any internal
reset source is asserted. This pin contains an internal pullup resistor. See
Section 15. System Integration Module (SIM).
Data Sheet
24
General Description
MOTOROLA
General Description
Pin Functions
1.5.4 External Interrupt Pin (IRQ)
IRQ is an asynchronous external interrupt pin. This pin contains an internal pullup
resistor. See Section 8. External Interrupt (IRQ).
1.5.5 CGM Power Supply Pins (VDDA and VSSA)
VDDA and VSSA are the power supply pins for the analog portion of the clock
generator module (CGM). Decoupling of these pins should be as per the digital
supply. See Section 4. Clock Generator Module (CGM).
1.5.6 External Filter Capacitor Pin (VCGMXFC)
CGMXFC is an external filter capacitor connection for the CGM. See Section 4.
1.5.7 ADC Power Supply/Reference Pins (VDDAD/VREFH and VSSAD/VREFL)
VDDAD and VSSAD are the power supply pins to the analog-to-digital converter
(ADC). VREFH and VREFL are the reference voltage pins for the ADC. VREFH is the
high reference supply for the ADC, and by default the VDDAD/VREFH pin should be
externally filtered and connected to the same voltage potential as VDD. VREFL is the
low reference supply for the ADC, and by default the VSSAD/VREFL pin should be
connected to the same voltage potential as VSS. See Section 3. Analog-to-Digital
Converter (ADC).
1.5.8 Port A Input/Output (I/O) Pins (PTA7/KBD7–PTA0/KBD0)
PTA7–PTA0 are general-purpose, bidirectional I/O port pins. Any or all of the port
A pins can be programmed to serve as keyboard interrupt pins. See Section 12.
Input/Output Ports (PORTS) and Section 9. Keyboard Interrupt Module (KBI).
These port pins also have selectable pullups when configured for input mode. The
pullups are disengaged when configured for output mode. The pullups are
selectable on an individual port bit basis.
1.5.9 Port B I/O Pins (PTB7/AD7–PTB0/AD0)
PTB7–PTB0 are general-purpose, bidirectional I/O port pins that can also be used
for analog-to-digital converter (ADC) inputs. See Section 12. Input/Output Ports
(PORTS) and Section 3. Analog-to-Digital Converter (ADC).
1.5.10 Port C I/O Pins (PTC6–PTC0)
PTC6 and PTC5 are general-purpose, bidirectional I/O port pins. PTC4–PTC0 are
general-purpose, bidirectional I/O port pins that contain higher current sink/source
capability. See Section 12. Input/Output Ports (PORTS).
MOTOROLA
Data Sheet
General Description
25
General Description
1.5.11 Port D I/O Pins (PTD7/T2CH1–PTD0/SS)
PTD7–PTD0 are special-function, bidirectional I/O port pins. PTD3–PTD0 can be
programmed to be serial peripheral interface (SPI) pins, while PTD7–PTD4 can be
individually programmed to be timer interface module (TIM1 and TIM2) pins. See
Section 18. Timer Interface Module (TIM), Section 16. Serial Peripheral
Interface (SPI) Module, and Section 12. Input/Output Ports (PORTS).
1.5.12 Port E I/O Pins (PTE5–PTE2, PTE1/RxD, and PTE0/TxD)
PTE5–PTE0 are general-purpose, bidirectional I/O port pins. PTE1 and PTE0 can
also be programmed to be enhanced serial communications interface (ESCI) pins.
See Section 14. Enhanced Serial Communications Interface (ESCI) Module
NOTE:
Any unused inputs and I/O ports should be tied to an appropriate logic level (either
VDD or VSS). Although the I/O ports of the MC68HC908GR16 do not require
termination, termination is recommended to reduce the possibility of static damage.
Data Sheet
26
General Description
MOTOROLA
Section 2. Memory
2.1 Introduction
The CPU08 can address 64 Kbytes of memory space. The memory map, shown in
Figure 2-1, includes:
15,872 bytes of user FLASH memory
1024 bytes of random-access memory (RAM)
44 bytes of user-defined vectors
350 bytes of monitor ROM
2.2 Unimplemented Memory Locations
Accessing an unimplemented location can cause an illegal address reset. In the
memory map (Figure 2-1) and in register figures in this document, unimplemented
locations are shaded.
2.3 Reserved Memory Locations
Accessing a reserved location can have unpredictable effects on microcontroller
(MCU) operation. In the Figure 2-1 and in register figures in this document,
reserved locations are marked with the word Reserved or with the letter R.
2.4 Input/Output (I/O) Section
Most of the control, status, and data registers are in the zero page area of
$0000–$003F. Additional I/O registers have these addresses:
$FE00; break status register, BSR
$FE01; SIM reset status register, SRSR
$FE02; break auxiliary register, BRKAR
$FE03; break flag control register, BFCR
$FE04; interrupt status register 1, INT1
$FE05; interrupt status register 2, INT2
$FE06; interrupt status register 3, INT3
$FE07; reserved
MOTOROLA
Data Sheet
Memory
27
Memory
$FE08; FLASH control register, FLCR
$FE09; break address register high, BRKH
$FE0A; break address register low, BRKL
$FE0B; break status and control register, BRKSCR
$FE0C; LVI status register, LVISR
$FF7E; FLASH block protect register, FLBPR
Data registers are shown in Figure 2-2. Table 2-1 is a list of vector locations.
$0000
I/O REGISTERS
64 BYTES
$003F
$0040
RAM
1024 BYTES
$043F
$0440
$04FF
UNIMPLEMENTED
192 BYTES
$0500
$057F
RESERVED
128 BYTES
$0580
$1BFF
UNIMPLEMENTED
5760 BYTES
$1C00
406 BYTES
$1D95
$1D96
UNIMPLEMENTED
41,578 BYTES
$BFFF
$C000
FLASH MEMORY
15,872 BYTES
$FDFF
$FE00
BREAK STATUS REGISTER (BSR)
$FE01
SIM RESET STATUS REGISTER (SRSR)
Figure 2-1. Memory Map
Data Sheet
28
Memory
MOTOROLA
Memory
$FE02
BREAK AUXILIARY REGISTER (BRKAR)
$FE03
BREAK FLAG CONTROL REGISTER (BFCR)
$FE04
INTERRUPT STATUS REGISTER 1 (INT1)
$FE05
INTERRUPT STATUS REGISTER 2 (INT2)
$FE06
INTERRUPT STATUS REGISTER 3 (INT3)
$FE07
RESERVED
$FE08
FLASH CONTROL REGISTER (FLCR)
$FE09
BREAK ADDRESS REGISTER HIGH (BRKH)
$FE0A
BREAK ADDRESS REGISTER LOW (BRKL)
$FE0B
BREAK STATUS AND CONTROL REGISTER (BRKSCR)
$FE0C
LVI STATUS REGISTER (LVISR)
$FE0D
UNIMPLEMENTED
3 BYTES
$FE0F
$FE10
$FE1F
UNIMPLEMENTED
16 BYTES
RESERVED FOR COMPATIBILITY WITH MONITOR CODE
FOR A-FAMILY PART
$FE20
MONITOR ROM
350 BYTES
$FF7D
$FF7E
FLASH BLOCK PROTECT REGISTER (FLBPR)
$FF7F
UNIMPLEMENTED
85 BYTES
$FFD3
$FFD4
FLASH VECTORS
44 BYTES
$FFFF(1)
1. $FFF6–$FFFD used for eight security bytes
Figure 2-1. Memory Map (Continued)
MOTOROLA
Data Sheet
Memory
29
Memory
Addr.
$0000
$0001
Register Name
Port A Data Register Read:
(PTA) Write:
See page 132. Reset:
Port B Data Register Read:
(PTB) Write:
See page 134. Reset:
$0002
Port C Data Register Read:
(PTC) Write:
See page 136. Reset:
$0003
Port D Data Register Read:
(PTD) Write:
See page 138. Reset:
$0004
$0005
Data Direction Register A Read:
(DDRA) Write:
Data Direction Register B Read:
(DDRB) Write:
See page 135. Reset:
$0006
Data Direction Register C Read:
(DDRC) Write:
$0007
Data Direction Register D Read:
(DDRD) Write:
See page 139. Reset:
$0008
$0009
Port E Data Register Read:
(PTE) Write:
See page 141. Reset:
ESCI Prescaler Register Read:
(SCPSC) Write:
See page 187. Reset:
ESCI Arbiter Control Register Read:
$000A
(SCIACTL) Write:
See page 191. Reset:
$000B
ESCI Arbiter Data Read:
Register (SCIADAT) Write:
See page 192. Reset:
Bit 7
6
5
4
3
2
1
Bit 0
PTA7
PTA6
PTA5
PTA4
PTA3
PTA2
PTA1
PTA0
PTB2
PTB1
PTB0
PTC2
PTC1
PTC0
PTD2
PTD1
PTD0
Unaffected by reset
PTB7
PTB6
PTB5
PTB4
PTB3
Unaffected by reset
PTC6
PTC5
PTC4
PTC3
Unaffected by reset
PTD7
PTD6
PTD5
PTD4
PTD3
Unaffected by reset
DDRA7
DDRA6
DDRA5
DDRA4
DDRA3
DDRA2
DDRA1
DDRA0
DDRB7
DDRB6
DDRB5
DDRB4
DDRB3
DDRB2
DDRB1
DDRB0
DDRC6
DDRC5
DDRC4
DDRC3
DDRC2
DDRC1
DDRC0
DDRD7
DDRD6
DDRD5
DDRD4
DDRD3
DDRD2
DDRD1
DDRD0
PTE5
PTE4
PTE3
PTE2
PTE1
PTE0
Unaffected by reset
PS2
PS1
PS0
PSSB4
PSSB3
PSSB2
PSSB1
PSSB0
AM0
ACLK
AFIN
ARUN
AOVFL
ARD8
AM1
ALOST
ARD7
ARD6
ARD5
ARD4
ARD3
ARD2
ARD1
ARD0
R
= Reserved
= Unimplemented
U = Unaffected
Figure 2-2. Control, Status, and Data Registers (Sheet 1 of 7)
Data Sheet
30
Memory
MOTOROLA
Memory
Addr.
$000C
$000D
$000E
$000F
Register Name
Data Direction Register E Read:
(DDRE) Write:
See page 142. Reset:
6
5
4
3
2
1
Bit 0
DDRE5
DDRE4
DDRE3
DDRE2
DDRE1
DDRE0
PTAPUE6
PTAPUE5
PTAPUE4
PTAPUE3
PTAPUE2
PTAPUE1
PTAPUE0
PTCPUE6
PTCPUE5
PTCPUE4
PTCPUE3
PTCPUE2
PTCPUE1
PTCPUE0
PTDPUE6
PTDPUE5
PTDPUE4
PTDPUE3
PTDPUE2
PTDPUE1
PTDPUE0
SPRIE
R
SPMSTR
CPOL
CPHA
SPWOM
SPE
SPTIE
OVRF
MODF
SPTE
MODFEN
SPR1
SPR0
Port A Input Pullup Enable Read: PTAPUE7
Register (PTAPUE) Write:
Port C Input Pullup Enable Read:
Register (PTCPUE) Write:
Port D Input Pullup Enable Read: PTDPUE7
Register (PTDPUE) Write:
SPI Control Register Read:
(SPCR) Write:
See page 235. Reset:
$0010
SPI Status and Control Read:
Register (SPSCR) Write:
See page 236. Reset:
$0011
SPI Data Register Read:
(SPDR) Write:
See page 238. Reset:
$0012
$0013
ESCI Control Register 1 Read:
(SCC1) Write:
See page 176. Reset:
$0014
ESCI Control Register 2 Read:
(SCC2) Write:
See page 178. Reset:
$0015
Bit 7
SPRF
ERRIE
R7
R6
R5
R4
R3
R2
R1
R0
T7
T6
T5
T4
T3
T2
T1
T0
Unaffected by reset
LOOPS
ENSCI
TXINV
M
WAKE
ILTY
PEN
PTY
SCTIE
TCIE
SCRIE
ILIE
TE
RE
RWU
SBK
T8
R
R
ORIE
NEIE
FEIE
PEIE
ESCI Control Register 3 Read:
(SCC3) Write:
See page 180. Reset:
R8
U
ESCI Status Register 1 Read:
(SCS1) Write:
See page 181. Reset:
SCTE
TC
SCRF
IDLE
OR
NF
FE
PE
1
1
BKF
RPF
$0016
$0017
ESCI Status Register 2 Read:
(SCS2) Write:
See page 184. Reset:
= Unimplemented
R
= Reserved
U = Unaffected
Figure 2-2. Control, Status, and Data Registers (Sheet 2 of 7)
MOTOROLA
Data Sheet
Memory
31
Memory
Addr.
Register Name
ESCI Data Register Read:
(SCDR) Write:
See page 185. Reset:
$0018
ESCI Baud Rate Register Read:
(SCBR) Write:
$0019
Keyboard Status Read:
and Control Register Write:
(INTKBSCR)
See page 114. Reset:
$001A
$001B
Keyboard Interrupt Enable Read:
Register (INTKBIER) Write:
See page 115. Reset:
Bit 7
6
5
4
3
2
1
Bit 0
R7
R6
R5
R4
R3
R2
R1
R0
T7
T6
T5
T4
T3
T2
T1
T0
Unaffected by reset
LINT
LINR
SCP1
SCP0
R
SCR2
SCR1
SCR0
KEYF
IMASKK
MODEK
ACKK
KBIE7
KBIE6
KBIE5
KBIE4
KBIE3
KBIE2
KBIE1
KBIE0
TBR2
TBR1
TBR0
TBIE
TBON
R
IMASK
MODE
$001C
Timebase Module Control Read:
Register (TBCR) Write:
See page 242. Reset:
IRQF
$001D
IRQ Status and Control Read:
Register (INTSCR) Write:
See page 107. Reset:
Configuration Register 2 Read:
(CONFIG2)(1) Write:
See page 82.
Reset:
COPRS
LVISTOP
$001E
Configuration Register 1 Read:
(CONFIG1)(1) Write:
See page 82. Reset:
$001F
TBIF
TACK
ACK
R
TMCLKSEL
LVIRSTD
LVIPWRD
LVI5OR3
(Note 1)
SSREC
STOP
COPD
OSCENINSCIBDSRC
STOP
1. One-time writable register after each reset, except LVI5OR3 bit. LVI5OR3 bit is only reset via POR (power-on reset).
Timer 1 Status and Control Read:
Register (T1SC) Write:
See page 256. Reset:
TOF
TOIE
TSTOP
Bit 15
14
13
12
$0021
Timer 1 Counter Read:
Register High (T1CNTH) Write:
See page 258. Reset:
Bit 7
6
5
4
3
2
1
Bit 0
$0022
Register Low (T1CNTL) Write:
R
= Reserved
$0020
= Unimplemented
PS2
PS1
PS0
10
9
Bit 8
TRST
U = Unaffected
Figure 2-2. Control, Status, and Data Registers (Sheet 3 of 7)
Data Sheet
32
Memory
MOTOROLA
Memory
Addr.
$0023
$0024
Register Name
Timer 1 Counter Modulo Read:
Register High (T1MODH) Write:
Register Low (T1MODL) Write:
See page 259. Reset:
Timer 1 Channel 0 Status and Read:
$0025
Control Register (T1SC0) Write:
$0026
Timer 1 Channel 0 Read:
Register High (T1CH0H) Write:
See page 262. Reset:
$0027
Register Low (T1CH0L) Write:
$0028
$0029
Timer 1 Channel 1 Status and Read:
Control Register (T1SC1) Write:
Timer 1 Channel 1 Read:
Register High (T1CH1H) Write:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
1
1
1
1
1
1
1
1
Bit 7
6
5
4
3
2
1
Bit 0
1
1
1
1
1
1
1
1
CH0IE
MS0B
MS0A
ELS0B
ELS0A
TOV0
CH0MAX
Bit 15
14
13
12
11
10
9
Bit 8
2
1
Bit 0
CH0F
Indeterminate after reset
Bit 7
CH1F
CH1IE
MS1A
ELS1B
ELS1A
TOV1
CH1MAX
Bit 15
14
13
12
11
10
9
Bit 8
2
1
Bit 0
PS2
PS1
PS0
TOF
$002B
Timer 2 Status and Control Read:
Register (T2SC) Write:
$002E
4
$002A
$002D
5
Register Low (T1CH1L) Write:
$002C
6
Bit 7
6
5
4
3
TOIE
TSTOP
Timer 2 Counter Read:
Register High (T2CNTH) Write:
Bit 15
14
13
12
11
10
9
Bit 8
Register Low (T2CNTL) Write:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
1
1
1
1
1
1
1
1
R
= Reserved
Timer 2 Counter Modulo Read:
Register High (T2MODH) Write:
= Unimplemented
TRST
U = Unaffected
Figure 2-2. Control, Status, and Data Registers (Sheet 4 of 7)
MOTOROLA
Data Sheet
Memory
33
Memory
Addr.
Register Name
Register Low (T2MODL) Write:
$002F
$0030
Timer 2 Channel 0 Status and Read:
Control Register (T2SC0) Write:
Timer 2 Channel 0 Read:
Register High (T2CH0H) Write:
$0031
Register Low (T2CH0L) Write:
$0032
$0033
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
1
1
1
1
1
1
1
1
CH0IE
MS0B
MS0A
ELS0B
ELS0A
TOV0
CH0MAX
Bit 15
14
13
12
11
10
9
Bit 8
2
1
Bit 0
CH0F
Bit 7
6
5
4
3
Reserved
R
R
R
R
R
R
R
R
Reserved
R
R
R
R
R
R
R
R
PLLON
BCS
PRE1
PRE0
VPR1
VPR0
1
MUL11
MUL10
MUL9
MUL8
$0035
PLL Control Register Read:
(PCTL) Write:
See page 71. Reset:
$0036
PLL Bandwidth Control Read:
Register (PBWC) Write:
See page 73. Reset:
$0037
$0038
PLL Multiplier Select High Read:
Register (PMSH) Write:
See page 74. Reset:
$0039
PLL Multiplier Select Low Read:
Register (PMSL) Write:
See page 75. Reset:
$003A
PLL VCO Select Range Read:
Register (PMRS) Write:
See page 75. Reset:
$003B
PLL Reference Divider Read:
Select Register (PMDS) Write:
See page 76. Reset:
PLLIE
AUTO
PLLF
LOCK
ACQ
R
MUL7
MUL6
MUL5
MUL4
MUL3
MUL2
MUL1
MUL0
VRS7
VRS6
VRS5
VRS4
VRS3
VRS2
VRS1
VRS0
RDS3
RDS2
RDS1
RDS0
R
= Reserved
= Unimplemented
U = Unaffected
Figure 2-2. Control, Status, and Data Registers (Sheet 5 of 7)
Data Sheet
34
MC68HC908GR16 — Rev. 1.0
Memory
MOTOROLA
Memory
Addr.
$003C
$003D
$003E
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
COCO
AIEN
ADCO
ADCH4
ADCH3
ADCH2
ADCH1
ADCH0
1
1
1
1
ADC Data High Register Read:
(ADRH) Write:
See page 55. Reset:
AD9
AD9
ADC Data Low Register Read:
(ADRL) Write:
See page 55. Reset:
AD7
AD2
AD1
AD0
R
ADC Status and Control Read:
Register (ADSCR) Write:
See page 54. Reset:
$003F
ADC Clock Register Read:
(ADCLK) Write:
See page 57. Reset:
$FE00
Break Status Register Read:
(BSR) Write:
See page 267. Reset:
Unaffected by reset
AD6
AD5
AD4
A3
Unaffected by reset
ADIV2
ADIV1
ADIV0
ADICLK
MODE1
MODE0
SBSW
R
R
R
R
R
R
POR
PIN
COP
ILOP
ILAD
MODRST
LVI
Bit 7
6
5
4
3
2
1
Bit 0
BCFE
R
R
R
R
R
R
R
IF6
IF5
IF4
IF3
IF2
IF1
$FE04
Interrupt Status Register 1 Read:
(INT1) Write:
See page 156. Reset:
R
R
R
R
R
R
R
R
IF14
IF13
IF12
IF11
IF10
IF9
IF8
IF7
$FE05
Interrupt Status Register 2 Read:
(INT2) Write:
See page 157. Reset:
R
R
R
R
R
R
R
R
(Note 2)
R
2. Writing a logic 0 clears SBSW.
$FE01
$FE02
SIM Reset Status Register Read:
(SRSR) Write:
See page 213. POR:
Break Auxiliary Register Read:
(BRKAR) Write:
Break Flag Control Read:
Register (BFCR) Write:
See page 268. Reset:
$FE03
$FE06
Interrupt Status Register 3 Read:
(INT3) Write:
IF20
IF19
IF18
IF17
IF16
IF15
R
R
R
R
R
R
R
R
R
= Reserved
= Unimplemented
U = Unaffected
Figure 2-2. Control, Status, and Data Registers (Sheet 6 of 7)
MOTOROLA
Data Sheet
Memory
35
Memory
Addr.
Register Name
Bit 7
6
5
4
3
2
1
Bit 0
R
R
R
R
R
R
R
R
Reset:
FLASH Control Register Read:
(FLCR) Write:
See page 39. Reset:
HVEN
MASS
ERASE
PGM
Bit 15
14
13
12
11
10
9
Bit 8
Bit 7
6
5
4
3
2
1
Bit 0
Read:
Reserved Write:
$FE07
$FE08
Break Address Register High Read:
$FE09
(BRKH) Write:
See page 266. Reset:
Break Address Register Low Read:
$FE0A
(BRKL) Write:
Break Status and Control Read:
Register (BRKSCR) Write:
$FE0B
$FE0C
Read:
LVI Status Register (LVISR)
Write:
See page 127.
Reset:
$FF7E
FLASH Block Protect Read:
Register (FLBPR)(3) Write:
See page 44. Reset:
BRKE
BRKA
LVIOUT
BPR7
BPR6
BPR5
BPR4
BPR3
BPR2
BPR1
BPR0
Unaffected by reset
3. Non-volatile FLASH register
$FFFF
COP Control Register Read:
(COPCTL) Write:
See page 87. Reset:
Low byte of reset vector
Writing clears COP counter (any value)
Unaffected by reset
= Unimplemented
R
= Reserved
U = Unaffected
Figure 2-2. Control, Status, and Data Registers (Sheet 7 of 7)
Data Sheet
36
Memory
MOTOROLA
Memory
Table 2-1. Vector Addresses
Vector Priority
Lowest
Vector
IF16
IF15
IF14
IF13
IF12
IF11
IF10
IF9
IF8
IF7
IF6
IF5
IF4
IF3
IF2
IF1
Highest
Address
$FFDC
Timebase Vector (High)
$FFDD
Timebase Vector (Low)
$FFDE
ADC Conversion Complete Vector (High)
$FFDF
ADC Conversion Complete Vector (Low)
$FFE0
Keyboard Vector (High)
$FFE1
Keyboard Vector (Low)
$FFE2
ESCI Transmit Vector (High)
$FFE3
ESCI Transmit Vector (Low)
$FFE4
ESCI Receive Vector (High)
$FFE5
ESCI Receive Vector (Low)
$FFE6
ESCI Error Vector (High)
$FFE7
ESCI Error Vector (Low)
$FFE8
SPI Transmit Vector (High)
$FFE9
SPI Transmit Vector (Low)
$FFEA
SPI Receive Vector (High)
$FFEB
SPI Receive Vector (Low)
$FFEC
TIM2 Overflow Vector (High)
$FFED
TIM2 Overflow Vector (Low)
$FFEE
Reserved
$FFEF
Reserved
$FFF0
TIM2 Channel 0 Vector (High)
$FFF1
TIM2 Channel 0 Vector (Low)
$FFF2
TIM1 Overflow Vector (High)
$FFF3
TIM1 Overflow Vector (Low)
$FFF4
TIM1 Channel 1 Vector (High)
$FFF5
TIM1 Channel 1 Vector (Low)
$FFF6
TIM1 Channel 0 Vector (High)
$FFF7
TIM1 Channel 0 Vector (Low)
$FFF8
PLL Vector (High)
$FFF9
PLL Vector (Low)
$FFFA
IRQ Vector (High)
$FFFB
IRQ Vector (Low)
$FFFC
SWI Vector (High)
$FFFD
SWI Vector (Low)
$FFFE
Reset Vector (High)
$FFFF
Reset Vector (Low)
MOTOROLA
Vector
Data Sheet
Memory
37
Memory
2.5 Random-Access Memory (RAM)
Addresses $0040 through $043F are RAM locations. The location of the stack
RAM is programmable. The 16-bit stack pointer allows the stack to be anywhere in
the 64-Kbyte memory space.
NOTE:
For correct operation, the stack pointer must point only to RAM locations.
Within page zero are 192 bytes of RAM. Because the location of the stack RAM is
programmable, all page zero RAM locations can be used for I/O control and user
data or code. When the stack pointer is moved from its reset location at $00FF out
of page zero, direct addressing mode instructions can efficiently access all page
zero RAM locations. Page zero RAM, therefore, provides ideal locations for
frequently accessed global variables.
Before processing an interrupt, the CPU uses five bytes of the stack to save the
contents of the CPU registers.
NOTE:
For M6805 compatibility, the H register is not stacked.
During a subroutine call, the CPU uses two bytes of the stack to store the return
address. The stack pointer decrements during pushes and increments during pulls.
NOTE:
Be careful when using nested subroutines. The CPU may overwrite data in the
RAM during a subroutine or during the interrupt stacking operation.
2.6 FLASH Memory (FLASH)
This subsection describes the operation of the embedded FLASH memory. This
memory can be read, programmed, and erased from a single external supply. The
program, erase, and read operations are enabled through the use of an internal
charge pump. It is recommended that the user utilize the FLASH programming
routines provided in the on-chip ROM, which are described more fully in a separate
Motorola application note.
2.6.1 Functional Description
The FLASH memory is an array of 15,872 bytes with an additional 44 bytes of user
vectors and one byte of block protection. An erased bit reads as logic 1 and a
programmed bit reads as a logic 0. Memory in the FLASH array is organized into
two rows per page basis. For the 16-K word by 8-bit embedded FLASH memory,
the page size is 64 bytes per page and the row size is 32 bytes per row. Hence the
minimum erase page size is 64 bytes and the minimum program row size is 32
bytes. Program and erase operation operations are facilitated through control bits
in FLASH control register (FLCR). Details for these operations appear later in this
section.
Data Sheet
38
Memory
MOTOROLA
Memory
The address ranges for the user memory and vectors are:
$C000–$FDFF; user memory
$FFD4–$FFFF; these locations are reserved for user-defined interrupt and
reset vectors
Programming tools are available from Motorola. Contact your local Motorola
representative for more information.
NOTE:
A security feature prevents viewing of the FLASH contents.(1)
2.6.1.1 FLASH Control Register
The FLASH control register (FLCR) controls FLASH program and erase
operations.
Address:
Read:
$FE08
Bit 7
6
5
4
Write:
Reset:
3
2
1
Bit 0
HVEN
MASS
ERASE
PGM
= Unimplemented
Figure 2-3. FLASH Control Register (FLCR)
HVEN — High-Voltage Enable Bit
This read/write bit enables the charge pump to drive high voltages for program
and erase operations in the array. HVEN can only be set if either PGM = 1 or
ERASE = 1 and the proper sequence for program or erase is followed.
1 = High voltage enabled to array and charge pump on
0 = High voltage disabled to array and charge pump off
MASS — Mass Erase Control Bit
Setting this read/write bit configures the 16-Kbyte FLASH array for mass erase
operation.
1 = MASS erase operation selected
0 = PAGE erase operation selected
ERASE — Erase Control Bit
This read/write bit configures the memory for erase operation. ERASE is
interlocked with the PGM bit such that both bits cannot be equal to 1 or set to 1
at the same time.
1 = Erase operation selected
0 = Erase operation unselected
1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or copying the FLASH difficult for unauthorized users.
MOTOROLA
Data Sheet
Memory
39
Memory
PGM — Program Control Bit
This read/write bit configures the memory for program operation. PGM is
interlocked with the ERASE bit such that both bits cannot be equal to 1 or set
to 1 at the same time.
1 = Program operation selected
0 = Program operation unselected
2.6.1.2 FLASH Page Erase Operation
Use this step-by-step procedure to erase a page (64 bytes) of FLASH memory to
read as logic 1. A page consists of 64 consecutive bytes starting from addresses
$XX00, $XX40, $XX80, or $XXC0. The 44-byte user interrupt vectors area also
forms a page. Any FLASH memory page can be erased alone.
1. Set the ERASE bit, and clear the MASS bit in the FLASH control register.
2. Read the FLASH block protect register.
3. Write any data to any FLASH address within the page address range
desired.
4. Wait for a time, tNVS (minimum 10 µs)
5. Set the HVEN bit.
6. Wait for a time, tErase (minimum 1 ms or 4 ms)
7. Clear the ERASE bit.
8. Wait for a time, tNVH (minimum 5 µs)
9. Clear the HVEN bit.
10. After a time, tRCV (typical 1 µs), the memory can be accessed again in read
mode.
NOTE:
Programming and erasing of FLASH locations cannot be performed by code being
executed from FLASH memory. While these operations must be performed in the
order shown, other unrelated operations may occur between the steps.
It is highly recommended that interrupts be disabled during program/ erase
operations.
In applications that need more than 1000 program/erase cycles, use the 4-ms page
erase specification to get improved long-term reliability. Any application can use
this 4-ms page erase specification. However, in applications where a FLASH
location will be erased and reprogrammed less than 1000 times, and speed is
important, use the 1-ms page erase specification to get a lower minimum erase
time.
Data Sheet
40
Memory
MOTOROLA
Memory
2.6.1.3 FLASH Mass Erase Operation
Use this step-by-step procedure to erase entire FLASH memory to read as logic 1:
1. Set both the ERASE bit, and the MASS bit in the FLASH control register.
2. Read from the FLASH block protect register.
3. Write any data to any FLASH address(1) within the FLASH memory address
range.
6. Wait for a time, tMErase (minimum 4 ms)
7. Clear the ERASE and MASS bits.
8. Wait for a time, tNVHL (minimum 100 µs)
10. After a time, tRCV (minimum 1 µs), the memory can be accessed again in
read mode.
NOTE:
Mass erase is disabled whenever any block is protected (FLBPR does not equal
$FF).
2.6.1.4 FLASH Program/Read Operation
Programming of the FLASH memory is done on a row basis. A row consists of 32
consecutive bytes starting from addresses $XX00, $XX20, $XX40, $XX60, $XX80,
$XXA0, $XXC0, and $XXE0.
During the programming cycle, make sure that all addresses being written to fit
within one of the ranges specified above. Attempts to program addresses in
different row ranges in one programming cycle will fail. Use this step-by-step
procedure to program a row of FLASH memory (Figure 2-4 is a flowchart
representation).
NOTE:
Only bytes which are currently $FF may be programmed.
1. Set the PGM bit. This configures the memory for program operation and
enables the latching of address and data for programming.
3. Write any data to any FLASH address within the row address range desired.
4. Wait for a time, tNVS (minimum 10 µs).
1. When in monitor mode, with security sequence failed (see 19.3.2 Security), write to the FLASH
block protect register instead of any FLASH address.
MOTOROLA
Data Sheet
Memory
41
Memory
5.
6.
7.
8.
9.
10.
11.
12.
13.
Set the HVEN bit.
Wait for a time, tPGS (minimum 5 µs).
Write data to the FLASH address to be programmed.
Wait for a time, tPROG (minimum 30 µs).
Repeat step 7 and 8 until all the bytes within the row are programmed.
Clear the PGM bit.(1)
Wait for a time, tNVH (minimum 5 µs).
Clear the HVEN bit.
After time, tRCV (minimum 1 µs), the memory can be accessed in read mode
again.
This program sequence is repeated throughout the memory until all data is
programmed.
NOTE:
Programming and erasing of FLASH locations can not be performed by code being
executed from the same FLASH array. While these operations must be performed
in the order shown, other unrelated operations may occur between the steps. Care
must be taken within the FLASH array memory space such as the COP control
register (COPCTL) at $FFFF.
operations.
Do not exceed tPROG maximum or tHV maximum. tHV is defined as the cumulative
high voltage programming time to the same row before next erase. tHV must satisfy
this condition:
tNVX = tNVH + tPGS + (tPROG x 32) Nmax, choose P using this table:
Current N Value
P
0 < N ≤ N max
N max < N ≤ N max × 2
1
N max × 2 < N ≤ N max × 4
2
N max × 4 < N ≤ N max × 8
3
Then recalculate N:
R × f VCLKDES
N = round -------------------------------------
P
f
RCLK × 2
6. Calculate and verify the adequacy of the VCO and bus frequencies fVCLK
and fBUS.
P
f VCLK = ( 2 × N ⁄ R ) × f RCLK
f BUS = ( f VCLK ) ⁄ 4
7. Select the VCO’s power-of-two range multiplier E, according to this table:
Frequency Range
E(1)
0 < fVCLK < 8 MHz
8 MHz ≤ fVCLK < 16 MHz
1
16 MHz ≤ fVCLK < 32 MHz
2
1. Do not program E to a value of 3.
8. Select a VCO linear range multiplier, L, where fNOM = 38.4 kHz
f VCLK
L = round n --------------------------
2E × f
NOM
MOTOROLA
Data Sheet
65
9. Calculate and verify the adequacy of the VCO programmed center-of-range
frequency, fVRS. The center-of-range frequency is the midpoint between the
minimum and maximum frequencies attainable by the PLL.
E
f VRS = ( L × 2 )f NOM
For proper operation,
E
f NOM × 2
f VRS – f VCLK ≤ -------------------------2
10. Verify the choice of P, R, N, E, and L by comparing fVCLK to fVRS and
fVCLKDES. For proper operation, fVCLK must be within the application’s
tolerance of fVCLKDES, and fVRS must be as close as possible to fVCLK.
NOTE:
Exceeding the recommended maximum bus frequency or VCO frequency can
crash the MCU.
11. Program the PLL registers accordingly:
a. In the PRE bits of the PLL control register (PCTL), program the binary
equivalent of P.
b. In the VPR bits of the PLL control register (PCTL), program the binary
equivalent of E.
c. In the PLL multiplier select register low (PMSL) and the PLL multiplier
select register high (PMSH), program the binary equivalent of N.
d. In the PLL VCO range select register (PMRS), program the binary
coded equivalent of L.
e. In the PLL reference divider select register (PMDS), program the
binary coded equivalent of R.
Table 4-1 provides numeric examples (numbers are in hexadecimal notation):
Table 4-1. Numeric Example
fBUS
fRCLK
R
N
P
E
L
2.0 MHz
32.768 kHz
1
F5
D1
2.4576 MHz
32.768 kHz
1
12C
80
2.5 MHz
32.768 kHz
1
132
83
4.0 MHz
32.768 kHz
1
1E9
D1
4.9152 MHz
32.768 kHz
1
258
80
5.0 MHz
32.768 kHz
1
263
82
7.3728 MHz
32.768 kHz
1
384
C0
8.0 MHz
32.768 kHz
1
3D1
D0
Data Sheet
66
MOTOROLA
4.3.7 Special Programming Exceptions
The programming method described in 4.3.6 Programming the PLL does not
account for three possible exceptions. A value of 0 for R, N, or L is meaningless
when used in the equations given. To account for these exceptions:
• A 0 value for R or N is interpreted exactly the same as a value of 1.
• A 0 value for L disables the PLL and prevents its selection as the source for
the base clock.
See 4.3.8 Base Clock Selector Circuit.
This circuit is used to select either the crystal clock, CGMXCLK, or the VCO clock,
CGMVCLK, as the source of the base clock, CGMOUT. The two input clocks go
through a transition control circuit that waits up to three CGMXCLK cycles and
three CGMVCLK cycles to change from one clock source to the other. During this
time, CGMOUT is held in stasis. The output of the transition control circuit is then
divided by two to correct the duty cycle. Therefore, the bus clock frequency, which
is one-half of the base clock frequency, is one-fourth the frequency of the selected
clock (CGMXCLK or CGMVCLK).
The BCS bit in the PLL control register (PCTL) selects which clock drives
CGMOUT. The VCO clock cannot be selected as the base clock source if the PLL
is not turned on. The PLL cannot be turned off if the VCO clock is selected. The
PLL cannot be turned on or off simultaneously with the selection or deselection of
the VCO clock. The VCO clock also cannot be selected as the base clock source
if the factor L is programmed to a 0. This value would set up a condition
inconsistent with the operation of the PLL, so that the PLL would be disabled and
the crystal clock would be forced as the source of the base clock.
4.3.9 CGM External Connections
In its typical configuration, the CGM requires up to nine external components. Five
of these are for the crystal oscillator and two or four are for the PLL.
The crystal oscillator is normally connected in a Pierce oscillator configuration, as
shown in Figure 4-2. Figure 4-2 shows only the logical representation of the
internal components and may not represent actual circuitry. The oscillator
configuration uses five components:
• Crystal, X1
• Fixed capacitor, C1
• Tuning capacitor, C2 (can also be a fixed capacitor)
• Feedback resistor, RB
• Series resistor, RS
MOTOROLA
Data Sheet
67
The series resistor (RS) is included in the diagram to follow strict Pierce oscillator
guidelines. Refer to the crystal manufacturer’s data for more information regarding
values for C1 and C2.
Figure 4-2 also shows the external components for the PLL:
• Bypass capacitor, CBYP
• Filter network
Routing should be done with great care to minimize signal cross talk and noise.
See 20.12 Clock Generation Module Characteristics for capacitor and resistor
values.
SIMOSCEN
OSCSTOPENB
(FROM CONFIG)
CGMXCLK
OSC1
CGMXFC
OSC2
VSSA
VDDA
VDD
RB
RF1
RS
CBYP
CF2
CF1
X1
C1
C2
Note: Filter network in box can be replaced with a single capacitor, but will degrade stability.
Figure 4-2. CGM External Connections
Data Sheet
68
MOTOROLA
I/O Signals
4.4 I/O Signals
The following paragraphs describe the CGM I/O signals.
4.4.1 Crystal Amplifier Input Pin (OSC1)
The OSC1 pin is an input to the crystal oscillator amplifier.
4.4.2 Crystal Amplifier Output Pin (OSC2)
The OSC2 pin is the output of the crystal oscillator inverting amplifier.
4.4.3 External Filter Capacitor Pin (CGMXFC)
The CGMXFC pin is required by the loop filter to filter out phase corrections. An
external filter network is connected to this pin. (See Figure 4-2.)
NOTE:
To prevent noise problems, the filter network should be placed as close to the
CGMXFC pin as possible, with minimum routing distances and no routing of other
signals across the network.
4.4.4 PLL Analog Power Pin (VDDA)
VDDA is a power pin used by the analog portions of the PLL. Connect the VDDA pin
to the same voltage potential as the VDD pin.
NOTE:
Route VDDA carefully for maximum noise immunity and place bypass capacitors as
close as possible to the package.
4.4.5 PLL Analog Ground Pin (VSSA)
VSSA is a ground pin used by the analog portions of the PLL. Connect the VSSA pin
to the same voltage potential as the VSS pin.
NOTE:
Route VSSA carefully for maximum noise immunity and place bypass capacitors as
4.4.6 Oscillator Enable Signal (SIMOSCEN)
The SIMOSCEN signal comes from the system integration module (SIM) and
enables the oscillator and PLL.
4.4.7 Oscillator Stop Mode Enable Bit (OSCSTOPENB)
OSCSTOPENB is a bit in the CONFIG register that enables the oscillator to
continue operating during stop mode. If this bit is set, the Oscillator continues
running during stop mode. If this bit is not set (default), the oscillator is controlled
by the SIMOSCEN signal which will disable the oscillator during stop mode.
MOTOROLA
Data Sheet
69
4.4.8 Crystal Output Frequency Signal (CGMXCLK)
CGMXCLK is the crystal oscillator output signal. It runs at the full speed of the
crystal (fXCLK) and comes directly from the crystal oscillator circuit. Figure 4-2
shows only the logical relation of CGMXCLK to OSC1 and OSC2 and may not
represent the actual circuitry. The duty cycle of CGMXCLK is unknown and may
depend on the crystal and other external factors. Also, the frequency and amplitude
of CGMXCLK can be unstable at startup.
4.4.9 CGM Base Clock Output (CGMOUT)
CGMOUT is the clock output of the CGM. This signal goes to the SIM, which
generates the MCU clocks. CGMOUT is a 50 percent duty cycle clock running at
twice the bus frequency. CGMOUT is software programmable to be either the
oscillator output, CGMXCLK, divided by two or the VCO clock, CGMVCLK, divided
by two.
4.4.10 CGM CPU Interrupt (CGMINT)
CGMINT is the interrupt signal generated by the PLL lock detector.
4.5 CGM Registers
These registers control and monitor operation of the CGM:
• PLL control register (PCTL)
(See 4.5.1 PLL Control Register.)
• PLL bandwidth control register (PBWC)
(See 4.5.2 PLL Bandwidth Control Register.)
• PLL multiplier select register high (PMSH)
(See 4.5.3 PLL Multiplier Select Register High.)
• PLL multiplier select register low (PMSL)
(See 4.5.4 PLL Multiplier Select Register Low.)
• PLL VCO range select register (PMRS)
(See 4.5.5 PLL VCO Range Select Register.)
• PLL reference divider select register (PMDS)
(See 4.5.6 PLL Reference Divider Select Register.)
Figure 4-3 is a summary of the CGM registers.
Data Sheet
70
MOTOROLA
CGM Registers
Addr.
Register Name
Bit 7
Read:
PLL Control Register (PCTL)
Write:
$0036
See page 71.
Reset:
PLL Bandwidth Control Reg- Read:
$0037
ister (PBWC) Write:
See page 73. Reset:
$0038
$0039
See page 74. Reset:
See page 75. Reset:
$003A
See page 75. Reset:
$003B
See page 76. Reset:
6
PLLIE
PLLF
5
4
3
2
1
Bit 0
PLLON
BCS
PRE1
PRE0
VPR1
VPR0
1
MUL11
MUL10
MUL9
MUL8
AUTO
LOCK
ACQ
R
MUL7
MUL6
MUL5
MUL4
MUL3
MUL2
MUL1
MUL0
VRS7
VRS6
VRS5
VRS4
VRS3
VRS2
VRS1
VRS0
RDS3
RDS2
RDS1
RDS0
R
= Reserved
NOTES:
1. When AUTO = 0, PLLIE is forced clear and is read-only.
2. When AUTO = 0, PLLF and LOCK read as clear.
3. When AUTO = 1, ACQ is read-only.
4. When PLLON = 0 or VRS7:VRS0 = $0, BCS is forced clear and is read-only.
5. When PLLON = 1, the PLL programming register is read-only.
6. When BCS = 1, PLLON is forced set and is read-only.
= Unimplemented
Figure 4-3. CGM I/O Register Summary
The PLL control register (PCTL) contains the interrupt enable and flag bits, the
on/off switch, the base clock selector bit, the prescaler bits, and the VCO
power-of-two range selector bits.
Address:
$0036
Bit 7
Read:
Write:
Reset:
PLLIE
PLLF
5
4
3
2
1
Bit 0
PLLON
BCS
PRE1
PRE0
VPR1
VPR0
1
= Unimplemented
Figure 4-4. PLL Control Register (PCTL)
MOTOROLA
Data Sheet
71
PLLIE — PLL Interrupt Enable Bit
This read/write bit enables the PLL to generate an interrupt request when the
LOCK bit toggles, setting the PLL flag, PLLF. When the AUTO bit in the PLL
bandwidth control register (PBWC) is clear, PLLIE cannot be written and reads
as logic 0. Reset clears the PLLIE bit.
1 = PLL interrupts enabled
0 = PLL interrupts disabled
PLLF — PLL Interrupt Flag Bit
This read-only bit is set whenever the LOCK bit toggles. PLLF generates an
interrupt request if the PLLIE bit also is set. PLLF always reads as logic 0 when
the AUTO bit in the PLL bandwidth control register (PBWC) is clear. Clear the
PLLF bit by reading the PLL control register. Reset clears the PLLF bit.
1 = Change in lock condition
0 = No change in lock condition
NOTE:
Do not inadvertently clear the PLLF bit. Any read or read-modify-write operation on
the PLL control register clears the PLLF bit.
PLLON — PLL On Bit
This read/write bit activates the PLL and enables the VCO clock, CGMVCLK.
PLLON cannot be cleared if the VCO clock is driving the base clock, CGMOUT
(BCS = 1). (See 4.3.8 Base Clock Selector Circuit.) Reset sets this bit so that
the loop can stabilize as the MCU is powering up.
1 = PLL on
0 = PLL off
BCS — Base Clock Select Bit
This read/write bit selects either the crystal oscillator output, CGMXCLK, or the
VCO clock, CGMVCLK, as the source of the CGM output, CGMOUT. CGMOUT
frequency is one-half the frequency of the selected clock. BCS cannot be set
while the PLLON bit is clear. After toggling BCS, it may take up to three
CGMXCLK and three CGMVCLK cycles to complete the transition from one
source clock to the other. During the transition, CGMOUT is held in stasis. (See
4.3.8 Base Clock Selector Circuit.) Reset clears the BCS bit.
1 = CGMVCLK divided by two drives CGMOUT
0 = CGMXCLK divided by two drives CGMOUT
NOTE:
PLLON and BCS have built-in protection that prevents the base clock selector
circuit from selecting the VCO clock as the source of the base clock if the PLL is
off. Therefore, PLLON cannot be cleared when BCS is set, and BCS cannot be set
when PLLON is clear. If the PLL is off (PLLON = 0), selecting CGMVCLK requires
two writes to the PLL control register. (See 4.3.8 Base Clock Selector Circuit.)
PRE1 and PRE0 — Prescaler Program Bits
These read/write bits control a prescaler that selects the prescaler power-of-two
multiplier, P. (See 4.3.3 PLL Circuits and 4.3.6 Programming the PLL.) PRE1
and PRE0 cannot be written when the PLLON bit is set. Reset clears these bits.
NOTE:
The value of P is normally 0 when using a 32.768-kHz crystal as the reference.
Data Sheet
72
MOTOROLA
CGM Registers
Table 4-2. PRE1 and PRE0 Programming
PRE1 and PRE0
P
Prescaler Multiplier
00
01
1
2
10
2
4
11
3
8
VPR1 and VPR0 — VCO Power-of-Two Range Select Bits
These read/write bits control the VCO’s hardware power-of-two range multiplier
E that, in conjunction with L (See 4.3.3 PLL Circuits, 4.3.6 Programming the
PLL, and 4.5.5 PLL VCO Range Select Register.) controls the hardware
center-of-range frequency, fVRS. VPR1:VPR0 cannot be written when the
Table 4-3. VPR1 and VPR0 Programming
VPR1 and VPR0
E
VCO Power-of-Two
Range Multiplier
00
01
1
2
10
2
4
11
(1)
8
3
The PLL bandwidth control register (PBWC):
• Selects automatic or manual (software-controlled) bandwidth control mode
• Indicates when the PLL is locked
• In automatic bandwidth control mode, indicates when the PLL is in
acquisition or tracking mode
In manual operation, forces the PLL into acquisition or tracking mode
Address:
$0037
Bit 7
Read:
Write:
Reset:
AUTO
LOCK
5
ACQ
= Unimplemented
3
2
1
R
= Reserved
Bit 0
R
Figure 4-5. PLL Bandwidth Control Register (PBWC)
MOTOROLA
Data Sheet
73
AUTO — Automatic Bandwidth Control Bit
This read/write bit selects automatic or manual bandwidth control. When
initializing the PLL for manual operation (AUTO = 0), clear the ACQ bit before
turning on the PLL. Reset clears the AUTO bit.
1 = Automatic bandwidth control
0 = Manual bandwidth control
LOCK — Lock Indicator Bit
When the AUTO bit is set, LOCK is a read-only bit that becomes set when the
VCO clock, CGMVCLK, is locked (running at the programmed frequency).
When the AUTO bit is clear, LOCK reads as logic 0 and has no meaning. The
write one function of this bit is reserved for test, so this bit must always be
written a 0. Reset clears the LOCK bit.
1 = VCO frequency correct or locked
0 = VCO frequency incorrect or unlocked
ACQ — Acquisition Mode Bit
When the AUTO bit is set, ACQ is a read-only bit that indicates whether the PLL
is in acquisition mode or tracking mode. When the AUTO bit is clear, ACQ is a
read/write bit that controls whether the PLL is in acquisition or tracking mode.
In automatic bandwidth control mode (AUTO = 1), the last-written value from
manual operation is stored in a temporary location and is recovered when
manual operation resumes. Reset clears this bit, enabling acquisition mode.
1 = Tracking mode
0 = Acquisition mode
The PLL multiplier select register high (PMSH) contains the programming
information for the high byte of the modulo feedback divider.
Address:
Read:
$0038
Bit 7
6
5
4
Write:
Reset:
2
1
Bit 0
MUL11
MUL10
MUL9
MUL8
= Unimplemented
Figure 4-6. PLL Multiplier Select Register High (PMSH)
MUL11–MUL8 — Multiplier Select Bits
These read/write bits control the high byte of the modulo feedback divider that
selects the VCO frequency multiplier N. (See 4.3.3 PLL Circuits and 4.3.6
Programming the PLL.) A value of $0000 in the multiplier select registers
configures the modulo feedback divider the same as a value of $0001. Reset
initializes the registers to $0040 for a default multiply value of 64.
NOTE:
The multiplier select bits have built-in protection such that they cannot be written
when the PLL is on (PLLON = 1).
Data Sheet
74
MOTOROLA
CGM Registers
PMSH[7:4] — Unimplemented Bits
These bits have no function and always read as logic 0s.
The PLL multiplier select register low (PMSL) contains the programming
information for the low byte of the modulo feedback divider.
Address:
Read:
Write:
Reset:
$0038
Bit 7
6
5
4
3
2
1
Bit 0
MUL7
MUL6
MUL5
MUL4
MUL3
MUL2
MUL1
MUL0
Figure 4-7. PLL Multiplier Select Register Low (PMSL)
MUL7–MUL0 — Multiplier Select Bits
These read/write bits control the low byte of the modulo feedback divider that
selects the VCO frequency multiplier, N. (See 4.3.3 PLL Circuits and 4.3.6
Programming the PLL.) MUL7–MUL0 cannot be written when the PLLON bit
in the PCTL is set. A value of $0000 in the multiplier select registers configures
the modulo feedback divider the same as a value of $0001. Reset initializes the
register to $40 for a default multiply value of 64.
NOTE:
NOTE:
PMRS may be called PVRS on other HC08 derivatives.
The PLL VCO range select register (PMRS) contains the programming information
required for the hardware configuration of the VCO.
Address:
Read:
Write:
Reset:
$003A
Bit 7
6
5
4
3
2
1
Bit 0
VRS7
VRS6
VRS5
VRS4
VRS3
VRS2
VRS1
VRS0
Figure 4-8. PLL VCO Range Select Register (PMRS)
VRS7–VRS0 — VCO Range Select Bits
These read/write bits control the hardware center-of-range linear multiplier L
which, in conjunction with E (see 4.3.3 PLL Circuits, 4.3.6 Programming the
PLL, and 4.5.1 PLL Control Register), controls the hardware center-of-range
frequency, fVRS. VRS7–VRS0 cannot be written when the PLLON bit in the
PCTL is set. (See 4.3.7 Special Programming Exceptions.) A value of $00 in
the VCO range select register disables the PLL and clears the BCS bit in the
MOTOROLA
Data Sheet
75
PLL control register (PCTL). (See 4.3.8 Base Clock Selector Circuit and 4.3.7
Special Programming Exceptions.) Reset initializes the register to $40 for a
default range multiply value of 64.
NOTE:
The VCO range select bits have built-in protection such that they cannot be written
when the PLL is on (PLLON = 1) and such that the VCO clock cannot be selected
as the source of the base clock (BCS = 1) if the VCO range select bits are all clear.
The PLL VCO range select register must be programmed correctly. Incorrect
programming can result in failure of the PLL to achieve lock.
NOTE:
PMDS may be called PRDS on other HC08 derivatives.
The PLL reference divider select register (PMDS) contains the programming
information for the modulo reference divider.
Address:
Read:
$003B
Bit 7
6
5
4
Write:
Reset:
3
2
1
Bit 0
RDS3
RDS2
RDS1
RDS0
= Unimplemented
Figure 4-9. PLL Reference Divider Select Register (PMDS)
RDS3–RDS0 — Reference Divider Select Bits
These read/write bits control the modulo reference divider that selects the
reference division factor, R. (See 4.3.3 PLL Circuits and 4.3.6 Programming
the PLL.) RDS7–RDS0 cannot be written when the PLLON bit in the PCTL is
set. A value of $00 in the reference divider select register configures the
reference divider the same as a value of $01. (See 4.3.7 Special Programming
Exceptions.) Reset initializes the register to $01 for a default divide value of 1.
NOTE:
The reference divider select bits have built-in protection such that they cannot be
written when the PLL is on (PLLON = 1).
NOTE:
The default divide value of 1 is recommended for all applications.
PMDS7–PMDS4 — Unimplemented Bits
4.6 Interrupts
When the AUTO bit is set in the PLL bandwidth control register (PBWC), the PLL
can generate a CPU interrupt request every time the LOCK bit changes state. The
PLLIE bit in the PLL control register (PCTL) enables CPU interrupts from the PLL.
PLLF, the interrupt flag in the PCTL, becomes set whether interrupts are enabled
Data Sheet
76
MOTOROLA
Special Modes
or not. When the AUTO bit is clear, CPU interrupts from the PLL are disabled and
PLLF reads as logic 0.
Software should read the LOCK bit after a PLL interrupt request to see if the
request was due to an entry into lock or an exit from lock. When the PLL enters
lock, the VCO clock, CGMVCLK, divided by two can be selected as the CGMOUT
source by setting BCS in the PCTL. When the PLL exits lock, the VCO clock
frequency is corrupt, and appropriate precautions should be taken. If the
application is not frequency sensitive, interrupts should be disabled to prevent PLL
interrupt service routines from impeding software performance or from exceeding
stack limitations.
NOTE:
Software can select the CGMVCLK divided by two as the CGMOUT source even
if the PLL is not locked (LOCK = 0). Therefore, software should make sure the PLL
is locked before setting the BCS bit.
4.7 Special Modes
The WAIT instruction puts the MCU in low power-consumption standby modes.
4.7.1 Wait Mode
The WAIT instruction does not affect the CGM. Before entering wait mode,
software can disengage and turn off the PLL by clearing the BCS and PLLON bits
in the PLL control register (PCTL) to save power. Less power-sensitive
applications can disengage the PLL without turning it off, so that the PLL clock is
immediately available at WAIT exit. This would be the case also when the PLL is
to wake the MCU from wait mode, such as when the PLL is first enabled and
waiting for LOCK or LOCK is lost.
4.7.2 Stop Mode
If the OSCSTOPENB bit in the CONFIG register is cleared (default), then the
STOP instruction disables the CGM (oscillator and phase locked loop) and holds
low all CGM outputs (CGMXCLK, CGMOUT, and CGMINT).
If the STOP instruction is executed with the VCO clock, CGMVCLK, divided by two
driving CGMOUT, the PLL automatically clears the BCS bit in the PLL control
register (PCTL), thereby selecting the crystal clock, CGMXCLK, divided by two as
the source of CGMOUT. When the MCU recovers from STOP, the crystal clock
divided by two drives CGMOUT and BCS remains clear.
If the OSCSTOPENB bit in the CONFIG register is set, then the phase locked loop
is shut off but the oscillator will continue to operate in stop mode.
MOTOROLA
Data Sheet
77
4.7.3 CGM During Break Interrupts
The system integration module (SIM) controls whether status bits in other modules
can be cleared during the break state. The BCFE bit in the SIM break flag control
register (SBFCR) enables software to clear status bits during the break state. (See
Section 15. System Integration Module (SIM).)
To allow software to clear status bits during a break interrupt, write a logic 1 to the
BCFE bit. If a status bit is cleared during the break state, it remains cleared when
the MCU exits the break state.
To protect the PLLF bit during the break state, write a logic 0 to the BCFE bit. With
BCFE at logic 0 (its default state), software can read and write the PLL control
register during the break state without affecting the PLLF bit.
4.8 Acquisition/Lock Time Specifications
The acquisition and lock times of the PLL are, in many applications, the most
critical PLL design parameters. Proper design and use of the PLL ensures the
highest stability and lowest acquisition/lock times.
4.8.1 Acquisition/Lock Time Definitions
Typical control systems refer to the acquisition time or lock time as the reaction
time, within specified tolerances, of the system to a step input. In a PLL, the step
input occurs when the PLL is turned on or when it suffers a noise hit. The tolerance
is usually specified as a percentage of the step input or when the output settles to
the desired value plus or minus a percentage of the frequency change. Therefore,
the reaction time is constant in this definition, regardless of the size of the step
input. For example, consider a system with a 5 percent acquisition time tolerance.
If a command instructs the system to change from 0 Hz to 1 MHz, the acquisition
time is the time taken for the frequency to reach 1 MHz ±50 kHz. Fifty kHz = 5% of
the 1-MHz step input. If the system is operating at 1 MHz and suffers a –100-kHz
noise hit, the acquisition time is the time taken to return from 900 kHz to
1 MHz ±5 kHz. Five kHz = 5% of the 100-kHz step input.
Other systems refer to acquisition and lock times as the time the system takes to
reduce the error between the actual output and the desired output to within
specified tolerances. Therefore, the acquisition or lock time varies according to the
original error in the output. Minor errors may not even be registered. Typical PLL
applications prefer to use this definition because the system requires the output
frequency to be within a certain tolerance of the desired frequency regardless of
the size of the initial error.
Data Sheet
78
MOTOROLA
4.8.2 Parametric Influences on Reaction Time
Acquisition and lock times are designed to be as short as possible while still
providing the highest possible stability. These reaction times are not constant,
however. Many factors directly and indirectly affect the acquisition time.
The most critical parameter which affects the reaction times of the PLL is the
reference frequency, fRDV. This frequency is the input to the phase detector and
controls how often the PLL makes corrections. For stability, the corrections must
be small compared to the desired frequency, so several corrections are required to
reduce the frequency error. Therefore, the slower the reference the longer it takes
to make these corrections. This parameter is under user control via the choice of
crystal frequency fXCLK and the R value programmed in the reference divider. (See
4.3.3 PLL Circuits, 4.3.6 Programming the PLL, and 4.5.6 PLL Reference
Another critical parameter is the external filter network. The PLL modifies the
voltage on the VCO by adding or subtracting charge from capacitors in this
network. Therefore, the rate at which the voltage changes for a given frequency
error (thus change in charge) is proportional to the capacitance. The size of the
capacitor also is related to the stability of the PLL. If the capacitor is too small, the
PLL cannot make small enough adjustments to the voltage and the system cannot
lock. If the capacitor is too large, the PLL may not be able to adjust the voltage in
a reasonable time. (See 4.8.3 Choosing a Filter.)
Also important is the operating voltage potential applied to VDDA. The power supply
potential alters the characteristics of the PLL. A fixed value is best. Variable
supplies, such as batteries, are acceptable if they vary within a known range at very
slow speeds. Noise on the power supply is not acceptable, because it causes small
frequency errors which continually change the acquisition time of the PLL.
Temperature and processing also can affect acquisition time because the electrical
characteristics of the PLL change. The part operates as specified as long as these
influences stay within the specified limits. External factors, however, can cause
drastic changes in the operation of the PLL. These factors include noise injected
into the PLL through the filter capacitor, filter capacitor leakage, stray impedances
on the circuit board, and even humidity or circuit board contamination.
MOTOROLA
Data Sheet
79
As described in 4.8.2 Parametric Influences on Reaction Time, the external filter
network is critical to the stability and reaction time of the PLL. The PLL is also
dependent on reference frequency and supply voltage.
Figure 4-10 shows two types of filter circuits. In low-cost applications, where
stability and reaction time of the PLL are not critical, the three component filter
network of Figure 4-10 (B) can be replaced by a single capacitor, CF, shown in
Figure 4-10 (A). Refer to Table 4-4 for recommended filter components at various
reference frequencies. For reference frequencies between the values listed in the
table, extrapolate to the nearest common capacitor value. In general, a slightly
larger capacitor provides more stability at the expense of increased lock time.
CGMXFC
CGMXFC
RF1
CF2
CF
CF1
VSSA
VSSA
(A)
(B)
Figure 4-10. PLL Filter
Table 4-4. Example Filter Component Values
fRCLK
CF1
CF2
RF1
CF
32 kHz
0.15 µF
15 nF
2K
0.22 µF
40 kHz
0.12 µF
12 nF
2K
0.18 µF
50 kHz
0.10 µF
10 nF
2K
0.18 µF
60 kHz
82 nF
8.2 nF
2K
0.12 µF
70 kHz
68 nF
6.8 nF
2K
0.12 µF
80 kHz
56 nF
5.6 nF
2K
0.1 µF
90 kHz
56 nF
5.6 nF
2K
0.1 µF
100 kHz
47 nF
4.7 nF
2K
82 nF
Data Sheet
80
MOTOROLA
Data Sheet — MC68HC908GR16
Section 5. Configuration Register (CONFIG)
5.1 Introduction
This section describes the configuration registers, CONFIG1 and CONFIG2. The
configuration registers enable or disable these options:
Stop mode recovery time (32 CGMXCLK cycles or 4096 CGMXCLK cycles)
COP timeout period (218 – 24 or 213 – 24 COPCLK cycles)
STOP instruction
Computer operating properly module (COP)
Low-voltage inhibit (LVI) module control and voltage trip point selection
Enable/disable the oscillator (OSC) during stop mode
Enable/disable an extra divide by 128 prescaler in timebase module
5.2 Functional Description
The configuration registers are used in the initialization of various options. The
configuration registers can be written once after each reset. All of the configuration
register bits are cleared during reset. Since the various options affect the operation
of the microcontroller unit (MCU), it is recommended that these registers be written
immediately after reset. The configuration registers are located at $001E and
$001F and may be read at anytime.
NOTE:
On a FLASH device, the options except LVI5OR3 are one-time writable by the user
after each reset. The LVI5OR3 bit is one-time writable by the user only after each
POR (power-on reset). The CONFIG registers are not in the FLASH memory but
are special registers containing one-time writable latches after each reset. Upon
a reset, the CONFIG registers default to predetermined settings as shown in
Figure 5-1 and Figure 5-2.
MOTOROLA
Data Sheet
81
Address:
Read:
$001E
Bit 7
6
5
4
Write:
Reset:
= Unimplemented
R
3
2
1
Bit 0
R
TMCLKSEL
OSCENINSTOP
SCIBDSRC
= Reserved
Figure 5-1. Configuration Register 2 (CONFIG2)
Address:
Read:
Write:
Reset:
$001F
Bit 7
6
5
4
3
2
1
Bit 0
COPRS
LVISTOP
LVIRSTD
LVIPWRD
LVI5OR3
SSREC
STOP
COPD
See note
Note: LVI5OR3 bit is only reset via POR (power-on reset)
Figure 5-2. Configuration Register 1 (CONFIG1)
TMCLKSEL— Timebase Clock Select Bit
TMCLKSEL enables an extra divide-by-128 prescaler in the timebase module.
Setting this bit enables the extra prescaler and clearing this bit disables it. See
Section 4. Clock Generator Module (CGM) for a more detailed description of
the external clock operation.
1 = Enables extra divide-by-128 prescaler in timebase module
0 = Disables extra divide-by-128 prescaler in timebase module
OSCENINSTOP — Oscillator Enable In Stop Mode Bit
OSCENINSTOP, when set, will enable oscillator to continue to generate clocks
in stop mode. See Section 4. Clock Generator Module (CGM). This function
is used to keep the timebase running while the reset of the MCU stops. See
Section 17. Timebase Module (TBM). When clear, oscillator will cease to
generate clocks while in stop mode. The default state for this option is clear,
disabling the oscillator in stop mode.
1 = Oscillator enabled to operate during stop mode
0 = Oscillator disabled during stop mode (default)
SCIBDSRC — SCI Baud Rate Clock Source Bit
SCIBDSRC controls the clock source used for the serial communications
interface (SCI). The setting of this bit affects the frequency at which the SCI
operates.See Section 14. Enhanced Serial Communications Interface
(ESCI) Module.
1 = Internal data bus clock used as clock source for SCI (default)
0 = External oscillator used as clock source for SCI
Data Sheet
82
MOTOROLA
COPRS — COP Rate Select Bit
COPD selects the COP timeout period. Reset clears COPRS. See Section 6.
Computer Operating Properly (COP) Module
1 = COP timeout period = 213 – 24 COPCLK cycles
0 = COP timeout period = 218 – 24 COPCLK cycles
LVISTOP — LVI Enable in Stop Mode Bit
When the LVIPWRD bit is clear, setting the LVISTOP bit enables the LVI to
operate during stop mode. Reset clears LVISTOP.
1 = LVI enabled during stop mode
0 = LVI disabled during stop mode
LVIRSTD — LVI Reset Disable Bit
LVIRSTD disables the reset signal from the LVI module. See Section 11.
Low-Voltage Inhibit (LVI).
1 = LVI module resets disabled
0 = LVI module resets enabled
LVIPWRD — LVI Power Disable Bit
LVIPWRD disables the LVI module. See Section 11. Low-Voltage Inhibit
(LVI).
1 = LVI module power disabled
0 = LVI module power enabled
LVI5OR3 — LVI 5-V or 3-V Operating Mode Bit
LVI5OR3 selects the voltage operating mode of the LVI module (see Section
11. Low-Voltage Inhibit (LVI)). The voltage mode selected for the LVI should
match the operating VDD (see Section 20. Electrical Specifications) for the
LVI’s voltage trip points for each of the modes.
1 = LVI operates in 5-V mode
0 = LVI operates in 3-V mode
NOTE:
The LVI5OR3 bit is cleared by a power-on reset (POR) only. Other resets will leave
this bit unaffected.
SSREC — Short Stop Recovery Bit
SSREC enables the CPU to exit stop mode with a delay of 32 CGMXCLK cycles
instead of a 4096-CGMXCLK cycle delay.
1 = Stop mode recovery after 32 CGMXCLK cycles
0 = Stop mode recovery after 4096 CGMXCLCK cycles
NOTE:
Exiting stop mode by an LVI reset will result in the long stop recovery.
If the system clock source selected is the internal oscillator or the external
crystal and the OSCENINSTOP configuration bit is not set, the oscillator will be
disabled during stop mode. The short stop recovery does not provide enough
time for oscillator stabilization and for this reason the SSREC bit should not
be set.
MOTOROLA
Data Sheet
83
When using the LVI during normal operation but disabling during stop mode, the
LVI will have an enable time of tEN. The system stabilization time for power-on
reset and long stop recovery (both 4096 CGMXCLK cycles) gives a delay longer
than the LVI enable time for these startup scenarios. There is no period where
the MCU is not protected from a low-power condition. However, when using the
short stop recovery configuration option, the 32-CGMXCLK delay must be
greater than the LVI’s turn on time to avoid a period in startup where the LVI is
not protecting the MCU.
STOP — STOP Instruction Enable Bit
STOP enables the STOP instruction.
1 = STOP instruction enabled
0 = STOP instruction treated as illegal opcode
COPD — COP Disable Bit
COPD disables the COP module. See Section 6. Computer Operating
Properly (COP) Module.
1 = COP module disabled
0 = COP module enabled
Data Sheet
84
MOTOROLA
Section 6. Computer Operating Properly (COP) Module
6.1 Introduction
The computer operating properly (COP) module contains a free-running counter
that generates a reset if allowed to overflow. The COP module helps software
recover from runaway code. Prevent a COP reset by clearing the COP counter
periodically. The COP module can be disabled through the COPD bit in the
CONFIG register.
6.2 Functional Description
Figure 6-1 shows the structure of the COP module.
COP TIMEOUT
CLEAR STAGES 5–12
STOP INSTRUCTION
INTERNAL RESET SOURCES
RESET VECTOR FETCH
RESET CIRCUIT
12-BIT COP PRESCALER
CLEAR ALL STAGES
CGMXCLK
COPCTL WRITE
COP CLOCK
COP MODULE
6-BIT COP COUNTER
COPEN (FROM SIM)
COP DISABLE
(FROM CONFIG)
RESET
COPCTL WRITE
CLEAR
COP COUNTER
COP RATE SEL
(FROM CONFIG)
Figure 6-1. COP Block Diagram
MOTOROLA
Data Sheet
85
The COP counter is a free-running 6-bit counter preceded by a 12-bit prescaler
counter. If not cleared by software, the COP counter overflows and generates an
asynchronous reset after 218 – 24 or 213 – 24 CGMXCLK cycles, depending on the
state of the COP rate select bit, COPRS, in the configuration register. With a
213 – 24 CGMXCLK cycle overflow option, a 4.9152-MHz crystal gives a COP
timeout period of 53.3 ms. Writing any value to location $FFFF before an overflow
occurs prevents a COP reset by clearing the COP counter and stages 12–5 of the
prescaler.
NOTE:
Service the COP immediately after reset and before entering or after exiting stop
mode to guarantee the maximum time before the first COP counter overflow.
A COP reset pulls the RST pin low for 32 CGMXCLK cycles and sets the COP bit
in the reset status register (RSR).
In monitor mode, the COP is disabled if the RST pin or the IRQ1 is held at VTST.
During the break state, VTST on the RST pin disables the COP.
NOTE:
Place COP clearing instructions in the main program and not in an interrupt
subroutine. Such an interrupt subroutine could keep the COP from generating a
reset even while the main program is not working properly.
6.3 I/O Signals
The following paragraphs describe the signals shown in Figure 6-1.
6.3.1 CGMXCLK
CGMXCLK is the crystal oscillator output signal. CGMXCLK frequency is equal to
the crystal frequency.
6.3.2 STOP Instruction
The STOP instruction clears the COP prescaler.
6.3.3 COPCTL Write
Writing any value to the COP control register (COPCTL) clears the COP counter
and clears bits 12–5 of the prescaler. Reading the COP control register returns the
low byte of the reset vector. See 6.4 COP Control Register.
6.3.4 Power-On Reset
The power-on reset (POR) circuit clears the COP prescaler 4096 CGMXCLK
cycles after power-up.
Data Sheet
86
MOTOROLA
6.3.5 Internal Reset
An internal reset clears the COP prescaler and the COP counter.
6.3.6 Reset Vector Fetch
A reset vector fetch occurs when the vector address appears on the data bus. A
reset vector fetch clears the COP prescaler.
6.3.7 COPD (COP Disable)
The COPD signal reflects the state of the COP disable bit (COPD) in the
configuration register. See Section 5. Configuration Register (CONFIG).
6.3.8 COPRS (COP Rate Select)
The COPRS signal reflects the state of the COP rate select bit (COPRS) in the
The COP control register (COPCTL) is located at address $FFFF and overlaps the
reset vector. Writing any value to $FFFF clears the COP counter and starts a new
timeout period. Reading location $FFFF returns the low byte of the reset vector.
Address: $FFFF
Bit 7
6
5
4
3
Read:
Write:
Clear COP counter
Reset:
Unaffected by reset
2
1
Bit 0
Figure 6-2. COP Control Register (COPCTL)
6.5 Interrupts
The COP does not generate central processor unit (CPU) interrupt requests.
6.6 Monitor Mode
When monitor mode is entered with VTST on the IRQ pin, the COP is disabled as
long as VTST remains on the IRQ pin or the RST pin. When monitor mode is
entered by having blank reset vectors and not having VTST on the IRQ pin, the COP
is automatically disabled until a POR occurs.
MOTOROLA
Data Sheet
87
6.7 Low-Power Modes
The WAIT and STOP instructions put the microcontroller unit (MCU) in low
6.7.1 Wait Mode
The COP remains active during wait mode. If COP is enabled, a reset will occur at
COP timeout.
6.7.2 Stop Mode
Stop mode turns off the CGMXCLK input to the COP and clears the COP prescaler.
Service the COP immediately before entering or after exiting stop mode to ensure
a full COP timeout period after entering or exiting stop mode.
To prevent inadvertently turning off the COP with a STOP instruction, a
configuration option is available that disables the STOP instruction. When the
STOP bit in the configuration register has the STOP instruction disabled, execution
of a STOP instruction results in an illegal opcode reset.
6.8 COP Module During Break Mode
The COP is disabled during a break interrupt when VTST is present on the RST pin.
Data Sheet
88
MOTOROLA
Section 7. Central Processor Unit (CPU)
7.1 Introduction
The M68HC08 CPU (central processor unit) is an enhanced and fully
object-code-compatible version of the M68HC05 CPU. The CPU08 Reference
Manual (Motorola document order number CPU08RM/AD) contains a description
of the CPU instruction set, addressing modes, and architecture.
7.2 Features
Features of the CPU include:
Object code fully upward-compatible with M68HC05 Family
16-bit stack pointer with stack manipulation instructions
16-bit index register with x-register manipulation instructions
8-MHz CPU internal bus frequency
64-Kbyte program/data memory space
16 addressing modes
Memory-to-memory data moves without using accumulator
Fast 8-bit by 8-bit multiply and 16-bit by 8-bit divide instructions
Enhanced binary-coded decimal (BCD) data handling
Modular architecture with expandable internal bus definition for extension of
addressing range beyond 64 Kbytes
Low-power stop and wait modes
MOTOROLA
Data Sheet
89
7.3 CPU Registers
Figure 7-1 shows the five CPU registers. CPU registers are not part of the memory
map.
ACCUMULATOR (A)
H
X
INDEX REGISTER (H:X)
15
STACK POINTER (SP)
15
PROGRAM COUNTER (PC)
7
V 1 1 H I N Z C
CONDITION CODE REGISTER (CCR)
CARRY/BORROW FLAG
ZERO FLAG
NEGATIVE FLAG
INTERRUPT MASK
HALF-CARRY FLAG
TWO’S COMPLEMENT OVERFLOW FLAG
Figure 7-1. CPU Registers
7.3.1 Accumulator
The accumulator is a general-purpose 8-bit register. The CPU uses the
accumulator to hold operands and the results of arithmetic/logic operations.
Bit 7
6
5
4
3
2
1
Bit 0
Read:
Write:
Reset:
Unaffected by reset
Figure 7-2. Accumulator (A)
7.3.2 Index Register
The 16-bit index register allows indexed addressing of a 64-Kbyte memory space.
H is the upper byte of the index register, and X is the lower byte. H:X is the
concatenated 16-bit index register.
In the indexed addressing modes, the CPU uses the contents of the index register
to determine the conditional address of the operand.
The index register can serve also as a temporary data storage location.
Data Sheet
90
MOTOROLA
CPU Registers
Bit
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
Bit
X
X
X
X
X
X
X
X
Read:
Write:
Reset:
X = Indeterminate
Figure 7-3. Index Register (H:X)
7.3.3 Stack Pointer
The stack pointer is a 16-bit register that contains the address of the next location
on the stack. During a reset, the stack pointer is preset to $00FF. The reset stack
pointer (RSP) instruction sets the least significant byte to $FF and does not affect
the most significant byte. The stack pointer decrements as data is pushed onto the
stack and increments as data is pulled from the stack.
In the stack pointer 8-bit offset and 16-bit offset addressing modes, the stack
pointer can function as an index register to access data on the stack. The CPU
uses the contents of the stack pointer to determine the conditional address of the
operand.
Bit
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
Bit
1
1
1
1
1
1
1
Read:
Write:
Reset:
Figure 7-4. Stack Pointer (SP)
NOTE:
The location of the stack is arbitrary and may be relocated anywhere in
random-access memory (RAM). Moving the SP out of page 0 ($0000 to $00FF)
frees direct address (page 0) space. For correct operation, the stack pointer must
7.3.4 Program Counter
The program counter is a 16-bit register that contains the address of the next
instruction or operand to be fetched.
Normally, the program counter automatically increments to the next sequential
memory location every time an instruction or operand is fetched. Jump, branch,
and interrupt operations load the program counter with an address other than that
of the next sequential location.
MOTOROLA
Data Sheet
91
During reset, the program counter is loaded with the reset vector address located
at $FFFE and $FFFF. The vector address is the address of the first instruction to
be executed after exiting the reset state.
Bit
15
14
13
12
11
10
9
8
7
6
5
4
3
2
Bit
Read:
Write:
Reset:
Loaded with vector from $FFFE and $FFFF
Figure 7-5. Program Counter (PC)
7.3.5 Condition Code Register
The 8-bit condition code register contains the interrupt mask and five flags that
indicate the results of the instruction just executed. Bits 6 and 5 are set
permanently to logic 1. The following paragraphs describe the functions of the
condition code register.
Bit 7
6
5
4
3
2
1
Bit 0
V
1
1
H
I
N
Z
C
X
1
1
X
1
X
X
X
Read:
Write:
Reset:
X = Indeterminate
Figure 7-6. Condition Code Register (CCR)
V — Overflow Flag
The CPU sets the overflow flag when a two's complement overflow occurs. The
signed branch instructions BGT, BGE, BLE, and BLT use the overflow flag.
1 = Overflow
0 = No overflow
H — Half-Carry Flag
The CPU sets the half-carry flag when a carry occurs between accumulator bits
3 and 4 during an add-without-carry (ADD) or add-with-carry (ADC) operation.
The half-carry flag is required for binary-coded decimal (BCD) arithmetic
operations. The DAA instruction uses the states of the H and C flags to
determine the appropriate correction factor.
1 = Carry between bits 3 and 4
0 = No carry between bits 3 and 4
I — Interrupt Mask
When the interrupt mask is set, all maskable CPU interrupts are disabled. CPU
interrupts are enabled when the interrupt mask is cleared. When a CPU
interrupt occurs, the interrupt mask is set
Data Sheet
92
MOTOROLA
Arithmetic/Logic Unit (ALU)
automatically after the CPU registers are saved on the stack, but before the
interrupt vector is fetched.
1 = Interrupts disabled
0 = Interrupts enabled
NOTE:
To maintain M6805 Family compatibility, the upper byte of the index register (H) is
not stacked automatically. If the interrupt service routine modifies H, then the user
must stack and unstack H using the PSHH and PULH instructions.
After the I bit is cleared, the highest-priority interrupt request is serviced first.
A return-from-interrupt (RTI) instruction pulls the CPU registers from the stack
and restores the interrupt mask from the stack. After any reset, the interrupt
mask is set and can be cleared only by the clear interrupt mask software
instruction (CLI).
N — Negative flag
The CPU sets the negative flag when an arithmetic operation, logic operation,
or data manipulation produces a negative result, setting bit 7 of the result.
1 = Negative result
0 = Non-negative result
Z — Zero flag
The CPU sets the zero flag when an arithmetic operation, logic operation, or
data manipulation produces a result of $00.
1 = Zero result
0 = Non-zero result
C — Carry/Borrow Flag
The CPU sets the carry/borrow flag when an addition operation produces a
carry out of bit 7 of the accumulator or when a subtraction operation requires a
borrow. Some instructions — such as bit test and branch, shift, and rotate —
also clear or set the carry/borrow flag.
1 = Carry out of bit 7
0 = No carry out of bit 7
7.4 Arithmetic/Logic Unit (ALU)
The ALU performs the arithmetic and logic operations defined by the instruction
set.
Refer to the CPU08 Reference Manual (Motorola document order number
CPU08RM/AD) for a description of the instructions and addressing modes and
more detail about the architecture of the CPU.
MOTOROLA
Data Sheet
93
7.5 Low-Power Modes
The WAIT and STOP instructions put the MCU in low power-consumption standby
modes.
7.5.1 Wait Mode
The WAIT instruction:
Clears the interrupt mask (I bit) in the condition code register, enabling
interrupts. After exit from wait mode by interrupt, the I bit remains clear. After
exit by reset, the I bit is set.
Disables the CPU clock
7.5.2 Stop Mode
The STOP instruction:
external interrupts. After exit from stop mode by external interrupt, the I bit
remains clear. After exit by reset, the I bit is set.
After exiting stop mode, the CPU clock begins running after the oscillator
stabilization delay.
7.6 CPU During Break Interrupts
If a break module is present on the MCU, the CPU starts a break interrupt by:
Loading the instruction register with the SWI instruction
Loading the program counter with $FFFC:$FFFD or with $FEFC:$FEFD in
monitor mode
The break interrupt begins after completion of the CPU instruction in progress. If
the break address register match occurs on the last cycle of a CPU instruction, the
break interrupt begins immediately.
A return-from-interrupt instruction (RTI) in the break routine ends the break
interrupt and returns the MCU to normal operation if the break interrupt has been
deasserted.
7.7 Instruction Set Summary
Table 7-1 provides a summary of the M68HC08 instruction set.
Data Sheet
94
MOTOROLA
ADC #opr
ADC opr
ADC opr
ADC opr,X
ADC opr,X
ADC ,X
ADC opr,SP
ADC opr,SP
V H I N Z C
A ← (A) + (M) + (C)
Add with Carry
IMM
DIR
EXT
IX2
IX1
IX
SP1
SP2
A9
B9
C9
D9
E9
F9
9EE9
9ED9
ii
dd
hh ll
ee ff
ff
IMM
DIR
EXT
IX2
IX1
IX
SP1
SP2
AB
BB
CB
DB
EB
FB
9EEB
9EDB
ii
dd
hh ll
ee ff
ff
ff
ee ff
A7
ii
2
– – – – – – IMM
AF
ii
2
IMM
DIR
EXT
0 – – – IX2
IX1
IX
SP1
SP2
A4
B4
C4
D4
E4
F4
9EE4
9ED4
ii
dd
hh ll
ee ff
ff
2
3
4
4
3
2
4
5
DIR
INH
INH
IX1
IX
SP1
38 dd
48
58
68 ff
78
9E68 ff
4
1
1
4
3
5
C
DIR
INH
– – INH
IX1
IX
SP1
37 dd
47
57
67 ff
77
9E67 ff
4
1
1
4
3
5
Add without Carry
AIS #opr
Add Immediate Value (Signed) to SP
SP ← (SP) + (16 « M)
– – – – – – IMM
AIX #opr
Add Immediate Value (Signed) to H:X
H:X ← (H:X) + (16 « M)
A ← (A) & (M)
ASL opr
ASLA
ASLX
ASL opr,X
ASL ,X
ASL opr,SP
A ← (A) + (M)
Logical AND
Arithmetic Shift Left
(Same as LSL)
ASR opr
ASRA
ASRX
ASR opr,X
ASR opr,X
ASR opr,SP
Arithmetic Shift Right
BCC rel
Branch if Carry Bit Clear
C
b7
b0
b7
2
3
4
4
3
2
4
5
2
3
4
4
3
2
4
5
ADD #opr
ADD opr
ADD opr
ADD opr,X
ADD opr,X
ADD ,X
ADD opr,SP
ADD opr,SP
AND #opr
AND opr
AND opr
AND opr,X
AND opr,X
AND ,X
AND opr,SP
AND opr,SP
ff
ee ff
Cycles
Effect
on CCR
Description
Operand
Operation
Opcode
Source
Form
Address
Mode
Table 7-1. Instruction Set Summary (Sheet 1 of 7)
b0
PC ← (PC) + 2 + rel ? (C) = 0
Mn ← 0
ff
ee ff
– – – – – – REL
24
rr
3
DIR (b0)
DIR (b1)
DIR (b2)
DIR (b3)
– – – – – – DIR (b4)
DIR (b5)
DIR (b6)
DIR (b7)
11
13
15
17
19
1B
1D
1F
dd
dd
dd
dd
dd
dd
dd
dd
4
4
4
4
4
4
4
4
BCLR n, opr
Clear Bit n in M
BCS rel
Branch if Carry Bit Set (Same as BLO)
PC ← (PC) + 2 + rel ? (C) = 1
– – – – – – REL
25
rr
3
BEQ rel
Branch if Equal
PC ← (PC) + 2 + rel ? (Z) = 1
– – – – – – REL
27
rr
3
BGE opr
Branch if Greater Than or Equal To
(Signed Operands)
PC ← (PC) + 2 + rel ? (N ⊕ V) = 0
– – – – – – REL
90
rr
3
BGT opr
Branch if Greater Than (Signed
Operands)
PC ← (PC) + 2 + rel ? (Z) | (N ⊕ V) = 0 – – – – – – REL
92
rr
3
MC68HC908GR16 — Rev. 1.0
MOTOROLA
Data Sheet
95
V H I N Z C
Cycles
Description
Operand
Operation
Effect
on CCR
Opcode
Source
Form
Address
Mode
Table 7-1. Instruction Set Summary (Sheet 2 of 7)
BHCC rel
Branch if Half Carry Bit Clear
PC ← (PC) + 2 + rel ? (H) = 0
– – – – – – REL
28
rr
BHCS rel
Branch if Half Carry Bit Set
PC ← (PC) + 2 + rel ? (H) = 1
– – – – – – REL
29
rr
BHI rel
Branch if Higher
PC ← (PC) + 2 + rel ? (C) | (Z) = 0
– – – – – – REL
22
rr
3
BHS rel
Branch if Higher or Same
(Same as BCC)
– – – – – – REL
24
rr
3
BIH rel
Branch if IRQ Pin High
PC ← (PC) + 2 + rel ? IRQ = 1
– – – – – – REL
2F
rr
3
BIL rel
Branch if IRQ Pin Low
PC ← (PC) + 2 + rel ? IRQ = 0
– – – – – – REL
2E
rr
3
(A) & (M)
IMM
DIR
EXT
IX2
0 – – –
IX1
IX
SP1
SP2
A5
B5
C5
D5
E5
F5
9EE5
9ED5
ii
dd
hh ll
ee ff
ff
ff
ee ff
2
3
4
4
3
2
4
5
93
rr
3
BIT #opr
BIT opr
BIT opr
BIT opr,X
BIT opr,X
BIT ,X
BIT opr,SP
BIT opr,SP
Bit Test
BLE opr
Branch if Less Than or Equal To
(Signed Operands)
BLO rel
Branch if Lower (Same as BCS)
BLS rel
PC ← (PC) + 2 + rel ? (Z) | (N ⊕ V) = 1 – – – – – – REL
3
3
– – – – – – REL
25
rr
3
Branch if Lower or Same
PC ← (PC) + 2 + rel ? (C) | (Z) = 1
– – – – – – REL
23
rr
3
BLT opr
Branch if Less Than (Signed Operands)
PC ← (PC) + 2 + rel ? (N ⊕ V) =1
– – – – – – REL
91
rr
3
BMC rel
Branch if Interrupt Mask Clear
PC ← (PC) + 2 + rel ? (I) = 0
– – – – – – REL
2C
rr
3
BMI rel
Branch if Minus
PC ← (PC) + 2 + rel ? (N) = 1
– – – – – – REL
2B
rr
3
BMS rel
Branch if Interrupt Mask Set
PC ← (PC) + 2 + rel ? (I) = 1
– – – – – – REL
2D
rr
3
BNE rel
Branch if Not Equal
PC ← (PC) + 2 + rel ? (Z) = 0
– – – – – – REL
26
rr
3
BPL rel
Branch if Plus
PC ← (PC) + 2 + rel ? (N) = 0
– – – – – – REL
2A
rr
3
BRA rel
Branch Always
PC ← (PC) + 2 + rel
– – – – – – REL
rr
3
DIR (b0)
DIR (b1)
DIR (b2)
DIR (b3)
– – – – – DIR (b4)
DIR (b5)
DIR (b6)
DIR (b7)
01
03
05
07
09
0B
0D
0F
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
5
5
5
5
5
5
5
5
– – – – – – REL
21
rr
3
DIR (b0)
DIR (b1)
DIR (b2)
– – – – – DIR (b3)
DIR (b4)
DIR (b5)
DIR (b6)
DIR (b7)
00
02
04
06
08
0A
0C
0E
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
dd rr
5
5
5
5
5
5
5
5
BRCLR n,opr,rel Branch if Bit n in M Clear
BRN rel
Branch Never
BRSET n,opr,rel Branch if Bit n in M Set
PC ← (PC) + 3 + rel ? (Mn) = 0
PC ← (PC) + 2
PC ← (PC) + 3 + rel ? (Mn) = 1
Data Sheet
96
MOTOROLA
V H I N Z C
BSET n,opr
Set Bit n in M
BSR rel
Branch to Subroutine
CBEQ opr,rel
CBEQA #opr,rel
CBEQX #opr,rel
Compare and Branch if Equal
CBEQ opr,X+,rel
CBEQ X+,rel
CBEQ opr,SP,rel
Cycles
Description
Operand
Operation
Effect
on CCR
Opcode
Source
Form
Address
Mode
Table 7-1. Instruction Set Summary (Sheet 3 of 7)
DIR (b0)
DIR (b1)
DIR (b2)
DIR (b3)
DIR (b5)
DIR (b6)
DIR (b7)
10
12
14
16
18
1A
1C
1E
dd
dd
dd
dd
dd
dd
dd
dd
4
4
4
4
4
4
4
4
PC ← (PC) + 2; push (PCL)
SP ← (SP) – 1; push (PCH)
SP ← (SP) – 1
PC ← (PC) + rel
– – – – – – REL
AD
rr
4
PC ← (PC) + 3 + rel ? (A) – (M) = $00
PC ← (PC) + 3 + rel ? (X) – (M) = $00
PC ← (PC) + 2 + rel ? (A) – (M) = $00
PC ← (PC) + 4 + rel ? (A) – (M) = $00
DIR
IMM
IMM
IX1+
IX+
SP1
31
41
51
61
71
9E61
dd rr
ii rr
ii rr
ff rr
rr
ff rr
5
4
4
5
4
6
Mn ← 1
CLC
Clear Carry Bit
C←0
– – – – – 0 INH
98
1
CLI
Clear Interrupt Mask
I←0
– – 0 – – – INH
9A
2
M ← $00
A ← $00
X ← $00
H ← $00
M ← $00
M ← $00
M ← $00
DIR
INH
INH
0 – – 0 1 – INH
IX1
IX
SP1
3F dd
4F
5F
8C
6F ff
7F
9E6F ff
(A) – (M)
IMM
DIR
EXT
IX2
IX1
IX
SP1
SP2
A1
B1
C1
D1
E1
F1
9EE1
9ED1
M ← (M) = $FF – (M)
A ← (A) = $FF – (M)
X ← (X) = $FF – (M)
M ← (M) = $FF – (M)
M ← (M) = $FF – (M)
M ← (M) = $FF – (M)
DIR
INH
INH
0 – – 1 IX1
IX
SP1
33 dd
43
53
63 ff
73
9E63 ff
(H:X) – (M:M + 1)
– – IMM
DIR
65
75
ii ii+1
dd
3
4
(X) – (M)
IMM
DIR
EXT
– – IX2
IX1
IX
SP1
SP2
A3
B3
C3
D3
E3
F3
9EE3
9ED3
ii
dd
hh ll
ee ff
ff
2
3
4
4
3
2
4
5
U – – INH
72
CLR opr
CLRA
CLRX
CLRH
CLR opr,X
CLR ,X
CLR opr,SP
CMP #opr
CMP opr
CMP opr
CMP opr,X
CMP opr,X
CMP ,X
CMP opr,SP
CMP opr,SP
Clear
Compare A with M
COM opr
COMA
COMX
COM opr,X
COM ,X
COM opr,SP
Complement (One’s Complement)
CPHX #opr
CPHX opr
Compare H:X with M
CPX #opr
CPX opr
CPX opr
CPX ,X
CPX opr,X
CPX opr,X
CPX opr,SP
CPX opr,SP
Compare X with M
DAA
Decimal Adjust A
(A)10
MOTOROLA
ii
dd
hh ll
ee ff
ff
ff
ee ff
ff
ee ff
3
1
1
1
3
2
4
2
3
4
4
3
2
4
5
4
1
1
4
3
5
2
Data Sheet
97
DEC opr
DECA
DECX
DEC opr,X
DEC ,X
DEC opr,SP
Decrement
DIV
Divide
INC opr
INCA
INCX
INC opr,X
INC ,X
INC opr,SP
JMP opr
JMP opr
JMP opr,X
JMP opr,X
JMP ,X
JSR opr
JSR opr
JSR opr,X
JSR opr,X
JSR ,X
Exclusive OR M with A
Increment
Jump
Jump to Subroutine
LDA #opr
LDA opr
LDA opr
LDA opr,X
LDA opr,X
LDA ,X
LDA opr,SP
LDA opr,SP
Load A from M
LDHX #opr
LDHX opr
Load H:X from M
LDX #opr
LDX opr
LDX opr
LDX opr,X
LDX opr,X
LDX ,X
LDX opr,SP
LDX opr,SP
Load X from M
A ← (A) – 1 or M ← (M) – 1 or X ← (X) – 1
PC ← (PC) + 3 + rel ? (result) ≠ 0
DIR
PC ← (PC) + 2 + rel ? (result) ≠ 0
INH
– – – – – – INH
IX1
IX
PC ← (PC) + 4 + rel ? (result) ≠ 0
SP1
dd rr
rr
rr
ff rr
rr
ff rr
5
3
3
5
4
6
M ← (M) – 1
A ← (A) – 1
X ← (X) – 1
M ← (M) – 1
M ← (M) – 1
M ← (M) – 1
DIR
INH
INH
IX1
IX
SP1
A ← (H:A)/(X)
H ← Remainder
– – – – INH
52
A ← (A ⊕ M)
IMM
DIR
EXT
IX2
0 – – –
IX1
IX
SP1
SP2
A8
B8
C8
D8
E8
F8
9EE8
9ED8
M ← (M) + 1
A ← (A) + 1
X ← (X) + 1
M ← (M) + 1
M ← (M) + 1
M ← (M) + 1
DIR
INH
INH
– – – IX1
IX
SP1
3C dd
4C
5C
6C ff
7C
9E6C ff
PC ← Jump Address
DIR
EXT
– – – – – – IX2
IX1
IX
BC
CC
DC
EC
FC
dd
hh ll
ee ff
ff
2
3
4
3
2
PC ← (PC) + n (n = 1, 2, or 3)
Push (PCL); SP ← (SP) – 1
Push (PCH); SP ← (SP) – 1
PC ← Unconditional Address
DIR
EXT
– – – – – – IX2
IX1
IX
BD
CD
DD
ED
FD
dd
hh ll
ee ff
ff
4
5
6
5
4
A ← (M)
IMM
DIR
EXT
0 – – – IX2
IX1
IX
SP1
SP2
A6
B6
C6
D6
E6
F6
9EE6
9ED6
ii
dd
hh ll
ee ff
ff
ff
ee ff
2
3
4
4
3
2
4
5
H:X ← (M:M + 1)
0 – – – IMM
DIR
45
55
ii jj
dd
3
4
X ← (M)
IMM
DIR
EXT
0 – – – IX2
IX1
IX
SP1
SP2
AE
BE
CE
DE
EE
FE
9EEE
9EDE
ii
dd
hh ll
ee ff
ff
2
3
4
4
3
2
4
5
Data Sheet
98
3B
4B
5B
6B
7B
9E6B
Cycles
V H I N Z C
DBNZ opr,rel
DBNZA rel
DBNZX rel
Decrement and Branch if Not Zero
DBNZ opr,X,rel
DBNZ X,rel
DBNZ opr,SP,rel
EOR #opr
EOR opr
EOR opr
EOR opr,X
EOR opr,X
EOR ,X
EOR opr,SP
EOR opr,SP
Description
Operand
Operation
Effect
on CCR
Opcode
Source
Form
Address
Mode
Table 7-1. Instruction Set Summary (Sheet 4 of 7)
3A dd
4A
5A
6A ff
7A
9E6A ff
4
1
1
4
3
5
7
ii
dd
hh ll
ee ff
ff
ff
ee ff
ff
ee ff
2
3
4
4
3
2
4
5
4
1
1
4
3
5
MOTOROLA
LSL opr
LSLA
LSLX
LSL opr,X
LSL ,X
LSL opr,SP
V H I N Z C
Logical Shift Left
(Same as ASL)
LSR opr
LSRA
LSRX
LSR opr,X
LSR ,X
LSR opr,SP
Logical Shift Right
MOV opr,opr
MOV opr,X+
MOV #opr,opr
MOV X+,opr
Move
MUL
Unsigned multiply
C
b7
DIR
INH
– – INH
IX1
IX
SP1
38 dd
48
58
68 ff
78
9E68 ff
4
1
1
4
3
5
C
DIR
INH
INH
– – 0 IX1
IX
SP1
34 dd
44
54
64 ff
74
9E64 ff
4
1
1
4
3
5
b0
b7
Cycles
Description
Operand
Operation
Effect
on CCR
Opcode
Source
Form
Address
Mode
Table 7-1. Instruction Set Summary (Sheet 5 of 7)
b0
H:X ← (H:X) + 1 (IX+D, DIX+)
DD
DIX+
0 – – – IMD
IX+D
4E
5E
6E
7E
X:A ← (X) × (A)
– 0 – – – 0 INH
42
M ← –(M) = $00 – (M)
A ← –(A) = $00 – (A)
X ← –(X) = $00 – (X)
DIR
INH
INH
– – IX1
IX
SP1
(M)Destination ← (M)Source
dd dd
dd
ii dd
dd
5
4
4
4
5
30 dd
40
50
60 ff
70
9E60 ff
4
1
1
4
3
5
NEG opr
NEGA
NEGX
NEG opr,X
NEG ,X
NEG opr,SP
Negate (Two’s Complement)
NOP
No Operation
None
– – – – – – INH
9D
1
NSA
Nibble Swap A
A ← (A[3:0]:A[7:4])
– – – – – – INH
62
3
A ← (A) | (M)
IMM
DIR
EXT
IX2
0 – – – IX1
IX
SP1
SP2
AA
BA
CA
DA
EA
FA
9EEA
9EDA
ii
dd
hh ll
ee ff
ff
2
3
4
4
3
2
4
5
ORA #opr
ORA opr
ORA opr
ORA opr,X
ORA opr,X
ORA ,X
ORA opr,SP
ORA opr,SP
Inclusive OR A and M
PSHA
Push A onto Stack
Push (A); SP ← (SP) – 1
– – – – – – INH
87
2
PSHH
Push H onto Stack
Push (H); SP ← (SP) – 1
– – – – – – INH
8B
2
PSHX
Push X onto Stack
Push (X); SP ← (SP) – 1
– – – – – – INH
89
2
PULA
Pull A from Stack
SP ← (SP + 1); Pull (A)
– – – – – – INH
86
2
PULH
Pull H from Stack
SP ← (SP + 1); Pull (H)
– – – – – – INH
8A
2
PULX
Pull X from Stack
SP ← (SP + 1); Pull (X)
– – – – – – INH
88
2
C
DIR
INH
– – INH
IX1
IX
SP1
39 dd
49
59
69 ff
79
9E69 ff
4
1
1
4
3
5
DIR
INH
INH
– – IX1
IX
SP1
36 dd
46
56
66 ff
76
9E66 ff
4
1
1
4
3
5
ROL opr
ROLA
ROLX
ROL opr,X
ROL ,X
ROL opr,SP
ROR opr
RORA
RORX
ROR opr,X
ROR ,X
ROR opr,SP
Rotate Left through Carry
b7
b0
C
Rotate Right through Carry
b7
b0
MOTOROLA
ff
ee ff
Data Sheet
99
V H I N Z C
Cycles
Description
Operand
Operation
Effect
on CCR
Opcode
Source
Form
Address
Mode
Table 7-1. Instruction Set Summary (Sheet 6 of 7)
Reset Stack Pointer
SP ← $FF
– – – – – – INH
9C
1
RTI
Return from Interrupt
SP ← (SP) + 1; Pull (CCR)
SP ← (SP) + 1; Pull (A)
SP ← (SP) + 1; Pull (X)
SP ← (SP) + 1; Pull (PCH)
SP ← (SP) + 1; Pull (PCL)
INH
80
7
RTS
Return from Subroutine
SP ← SP + 1; Pull (PCH)
SP ← SP + 1; Pull (PCL)
– – – – – – INH
81
4
A ← (A) – (M) – (C)
IMM
DIR
EXT
– – IX2
IX1
IX
SP1
SP2
A2
B2
C2
D2
E2
F2
9EE2
9ED2
RSP
ii
dd
hh ll
ee ff
ff
2
3
4
4
3
2
4
5
SBC #opr
SBC opr
SBC opr
SBC opr,X
SBC opr,X
SBC ,X
SBC opr,SP
SBC opr,SP
Subtract with Carry
SEC
Set Carry Bit
C←1
– – – – – 1 INH
99
1
SEI
Set Interrupt Mask
I←1
– – 1 – – – INH
9B
2
M ← (A)
DIR
EXT
IX2
0 – – – IX1
IX
SP1
SP2
B7
C7
D7
E7
F7
9EE7
9ED7
(M:M + 1) ← (H:X)
0 – – – DIR
35
I ← 0; Stop Oscillator
– – 0 – – – INH
8E
M ← (X)
DIR
EXT
IX2
0 – – – IX1
IX
SP1
SP2
BF
CF
DF
EF
FF
9EEF
9EDF
dd
hh ll
ee ff
ff
IMM
DIR
EXT
IX2
– – IX1
IX
SP1
SP2
A0
B0
C0
D0
E0
F0
9EE0
9ED0
ii
dd
hh ll
ee ff
ff
– – 1 – – – INH
83
9
STA opr
STA opr
STA opr,X
STA opr,X
STA ,X
STA opr,SP
STA opr,SP
Store A in M
STHX opr
Store H:X in M
STOP
Enable IRQ Pin; Stop Oscillator
STX opr
STX opr
STX opr,X
STX opr,X
STX ,X
STX opr,SP
STX opr,SP
SUB #opr
SUB opr
SUB opr
SUB opr,X
SUB opr,X
SUB ,X
SUB opr,SP
SUB opr,SP
Store X in M
Subtract
A ← (A) – (M)
ff
ee ff
dd
hh ll
ee ff
ff
ff
ee ff
3
4
4
3
2
4
5
dd
4
1
ff
ee ff
ff
ee ff
3
4
4
3
2
4
5
2
3
4
4
3
2
4
5
SWI
Software Interrupt
PC ← (PC) + 1; Push (PCL)
SP ← (SP) – 1; Push (PCH)
SP ← (SP) – 1; Push (X)
SP ← (SP) – 1; Push (A)
SP ← (SP) – 1; Push (CCR)
SP ← (SP) – 1; I ← 1
PCH ← Interrupt Vector High Byte
PCL ← Interrupt Vector Low Byte
TAP
Transfer A to CCR
CCR ← (A)
INH
84
2
TAX
Transfer A to X
X ← (A)
– – – – – – INH
97
1
TPA
Transfer CCR to A
A ← (CCR)
– – – – – – INH
85
1
Data Sheet
100
MOTOROLA
Opcode Map
Test for Negative or Zero
TSX
Transfer SP to H:X
TXA
Transfer X to A
TXS
Transfer H:X to SP
(A) – $00 or (X) – $00 or (M) – $00
DIR
INH
0 – – – INH
IX1
IX
SP1
H:X ← (SP) + 1
– – – – – – INH
95
2
A ← (X)
– – – – – – INH
9F
1
(SP) ← (H:X) – 1
– – – – – – INH
94
2
Accumulator
Carry/borrow bit
Condition code register
Direct address of operand
Direct address of operand and relative offset of branch instruction
Direct to direct addressing mode
Direct addressing mode
Direct to indexed with post increment addressing mode
High and low bytes of offset in indexed, 16-bit offset addressing
Extended addressing mode
Offset byte in indexed, 8-bit offset addressing
Half-carry bit
Index register high byte
High and low bytes of operand address in extended addressing
Interrupt mask
Immediate operand byte
Immediate source to direct destination addressing mode
Immediate addressing mode
Inherent addressing mode
Indexed, no offset addressing mode
Indexed, no offset, post increment addressing mode
Indexed with post increment to direct addressing mode
Indexed, 8-bit offset addressing mode
Indexed, 8-bit offset, post increment addressing mode
Indexed, 16-bit offset addressing mode
Memory location
Negative bit
n
opr
PC
PCH
PCL
REL
rel
rr
SP1
SP2
SP
U
V
X
Z
3D dd
4D
5D
6D ff
7D
9E6D ff
Cycles
V H I N Z C
TST opr
TSTA
TSTX
TST opr,X
TST ,X
TST opr,SP
A
C
CCR
dd
dd rr
DD
DIR
DIX+
ee ff
EXT
ff
H
H
hh ll
I
ii
IMD
IMM
INH
IX
IX+
IX+D
IX1
IX1+
IX2
M
N
Description
Operand
Operation
Effect
on CCR
Opcode
Source
Form
Address
Mode
Table 7-1. Instruction Set Summary (Sheet 7 of 7)
3
1
1
3
2
4
Any bit
Operand (one or two bytes)
Program counter
Program counter high byte
Program counter low byte
Relative addressing mode
Relative program counter offset byte
Stack pointer, 8-bit offset addressing mode
Stack pointer 16-bit offset addressing mode
Stack pointer
Undefined
Overflow bit
Index register low byte
Zero bit
Logical AND
Logical OR
Logical EXCLUSIVE OR
Contents of
Negation (two’s complement)
Immediate value
Sign extend
Loaded with
If
Concatenated with
Set or cleared
Not affected
7.8 Opcode Map
See Table 7-2.
MOTOROLA
Data Sheet
101
MSB
Branch
REL
DIR
INH
3
4
2
5
BRSET0
3 DIR
5
BRCLR0
3 DIR
5
BRSET1
3 DIR
5
BRCLR1
3 DIR
5
BRSET2
3 DIR
5
BRCLR2
3 DIR
5
BRSET3
3 DIR
5
BRCLR3
3 DIR
5
BRSET4
3 DIR
5
BRCLR4
3 DIR
5
BRSET5
3 DIR
5
BRCLR5
3 DIR
5
BRSET6
3 DIR
5
BRCLR6
3 DIR
5
BRSET7
3 DIR
5
BRCLR7
3 DIR
4
BSET0
2 DIR
4
BCLR0
2 DIR
4
BSET1
2 DIR
4
BCLR1
2 DIR
4
BSET2
2 DIR
4
BCLR2
2 DIR
4
BSET3
2 DIR
4
BCLR3
2 DIR
4
BSET4
2 DIR
4
BCLR4
2 DIR
4
BSET5
2 DIR
4
BCLR5
2 DIR
4
BSET6
2 DIR
4
BCLR6
2 DIR
4
BSET7
2 DIR
4
BCLR7
2 DIR
3
BRA
2 REL
3
BRN
2 REL
3
BHI
2 REL
3
BLS
2 REL
3
BCC
2 REL
3
BCS
2 REL
3
BNE
2 REL
3
BEQ
2 REL
3
BHCC
2 REL
3
BHCS
2 REL
3
BPL
2 REL
3
BMI
2 REL
3
BMC
2 REL
3
BMS
2 REL
3
BIL
2 REL
3
BIH
2 REL
Read-Modify-Write
INH
IX1
5
6
1
NEGX
1 INH
4
CBEQX
3 IMM
7
DIV
1 INH
1
COMX
1 INH
1
LSRX
1 INH
4
LDHX
2 DIR
1
RORX
1 INH
1
ASRX
1 INH
1
LSLX
1 INH
1
ROLX
1 INH
1
DECX
1 INH
3
DBNZX
2 INH
1
INCX
1 INH
1
TSTX
1 INH
4
MOV
2 DIX+
1
CLRX
1 INH
4
NEG
2
IX1
5
CBEQ
3 IX1+
3
NSA
1 INH
4
COM
2 IX1
4
LSR
2 IX1
3
CPHX
3 IMM
4
ROR
2 IX1
4
ASR
2 IX1
4
LSL
2 IX1
4
ROL
2 IX1
4
DEC
2 IX1
5
DBNZ
3 IX1
4
INC
2 IX1
3
TST
2 IX1
4
MOV
3 IMD
3
CLR
2 IX1
SP1
IX
9E6
7
Control
INH
INH
8
9
Register/Memory
IX2
SP2
IMM
DIR
EXT
A
B
C
D
9ED
4
SUB
3 EXT
4
CMP
3 EXT
4
SBC
3 EXT
4
CPX
3 EXT
4
AND
3 EXT
4
BIT
3 EXT
4
LDA
3 EXT
4
STA
3 EXT
4
EOR
3 EXT
4
ADC
3 EXT
4
ORA
3 EXT
4
ADD
3 EXT
3
JMP
3 EXT
5
JSR
3 EXT
4
LDX
3 EXT
4
STX
3 EXT
4
SUB
3 IX2
4
CMP
3 IX2
4
SBC
3 IX2
4
CPX
3 IX2
4
AND
3 IX2
4
BIT
3 IX2
4
LDA
3 IX2
4
STA
3 IX2
4
EOR
3 IX2
4
ADC
3 IX2
4
ORA
3 IX2
4
ADD
3 IX2
4
JMP
3 IX2
6
JSR
3 IX2
4
LDX
3 IX2
4
STX
3 IX2
5
SUB
4 SP2
5
CMP
4 SP2
5
SBC
4 SP2
5
CPX
4 SP2
5
AND
4 SP2
5
BIT
4 SP2
5
LDA
4 SP2
5
STA
4 SP2
5
EOR
4 SP2
5
ADC
4 SP2
5
ORA
4 SP2
5
ADD
4 SP2
IX1
SP1
IX
E
9EE
F
LSB
2
3
4
5
6
7
8
9
A
B
C
D
MOTOROLA
E
F
4
1
NEG
NEGA
2 DIR 1 INH
5
4
CBEQ CBEQA
3 DIR 3 IMM
5
MUL
1 INH
4
1
COM
COMA
2 DIR 1 INH
4
1
LSR
LSRA
2 DIR 1 INH
4
3
STHX
LDHX
2 DIR 3 IMM
4
1
ROR
RORA
2 DIR 1 INH
4
1
ASR
ASRA
2 DIR 1 INH
4
1
LSL
LSLA
2 DIR 1 INH
4
1
ROL
ROLA
2 DIR 1 INH
4
1
DEC
DECA
2 DIR 1 INH
5
3
DBNZ DBNZA
3 DIR 2 INH
4
1
INC
INCA
2 DIR 1 INH
3
1
TST
TSTA
2 DIR 1 INH
5
MOV
3 DD
3
1
CLR
CLRA
2 DIR 1 INH
INH Inherent
REL Relative
IMM Immediate
IX
Indexed, No Offset
DIR Direct
IX1 Indexed, 8-Bit Offset
EXT Extended
IX2 Indexed, 16-Bit Offset
DD Direct-Direct
IMD Immediate-Direct
IX+D Indexed-Direct DIX+ Direct-Indexed
*Pre-byte for stack pointer indexed instructions
5
3
NEG
NEG
3 SP1 1 IX
6
4
CBEQ
CBEQ
4 SP1 2 IX+
2
DAA
1 INH
5
3
COM
COM
3 SP1 1 IX
5
3
LSR
LSR
3 SP1 1 IX
4
CPHX
2 DIR
5
3
ROR
ROR
3 SP1 1 IX
5
3
ASR
ASR
3 SP1 1 IX
5
3
LSL
LSL
3 SP1 1 IX
5
3
ROL
ROL
3 SP1 1 IX
5
3
DEC
DEC
3 SP1 1 IX
6
4
DBNZ
DBNZ
4 SP1 2 IX
5
3
INC
INC
3 SP1 1 IX
4
2
TST
TST
3 SP1 1 IX
4
MOV
2 IX+D
4
2
CLR
CLR
3 SP1 1 IX
SP1 Stack Pointer, 8-Bit Offset
SP2 Stack Pointer, 16-Bit Offset
IX+ Indexed, No Offset with
Post Increment
IX1+ Indexed, 1-Byte Offset with
Post Increment
7
3
RTI
BGE
1 INH 2 REL
4
3
RTS
BLT
1 INH 2 REL
3
BGT
2 REL
9
3
SWI
BLE
1 INH 2 REL
2
2
TAP
TXS
1 INH 1 INH
1
2
TPA
TSX
1 INH 1 INH
2
PULA
1 INH
2
1
PSHA
TAX
1 INH 1 INH
2
1
PULX
CLC
1 INH 1 INH
2
1
PSHX
SEC
1 INH 1 INH
2
2
PULH
CLI
1 INH 1 INH
2
2
PSHH
SEI
1 INH 1 INH
1
1
CLRH
RSP
1 INH 1 INH
1
NOP
1 INH
1
STOP
1 INH
1
1
WAIT
TXA
1 INH 1 INH
2
SUB
2 IMM
2
CMP
2 IMM
2
SBC
2 IMM
2
CPX
2 IMM
2
AND
2 IMM
2
BIT
2 IMM
2
LDA
2 IMM
2
AIS
2 IMM
2
EOR
2 IMM
2
ADC
2 IMM
2
ORA
2 IMM
2
ADD
2 IMM
3
SUB
2 DIR
3
CMP
2 DIR
3
SBC
2 DIR
3
CPX
2 DIR
3
AND
2 DIR
3
BIT
2 DIR
3
LDA
2 DIR
3
STA
2 DIR
3
EOR
2 DIR
3
ADC
2 DIR
3
ORA
2 DIR
3
ADD
2 DIR
2
JMP
2 DIR
4
4
BSR
JSR
2 REL 2 DIR
2
3
LDX
LDX
2 IMM 2 DIR
2
3
AIX
STX
2 IMM 2 DIR
MSB
SUB
2 IX1
3
CMP
2 IX1
3
SBC
2 IX1
3
CPX
2 IX1
3
AND
2 IX1
3
BIT
2 IX1
3
LDA
2 IX1
3
STA
2 IX1
3
EOR
2 IX1
3
ADC
2 IX1
3
ORA
2 IX1
3
ADD
2 IX1
3
JMP
2 IX1
5
JSR
2 IX1
5
3
LDX
LDX
4 SP2 2 IX1
5
3
STX
STX
4 SP2 2 IX1
4
SUB
3 SP1
4
CMP
3 SP1
4
SBC
3 SP1
4
CPX
3 SP1
4
AND
3 SP1
4
BIT
3 SP1
4
LDA
3 SP1
4
STA
3 SP1
4
EOR
3 SP1
4
ADC
3 SP1
4
ORA
3 SP1
4
ADD
3 SP1
2
SUB
1 IX
2
CMP
1 IX
2
SBC
1 IX
2
CPX
1 IX
2
AND
1 IX
2
BIT
1 IX
2
LDA
1 IX
2
STA
1 IX
2
EOR
1 IX
2
ADC
1 IX
2
ORA
1 IX
2
ADD
1 IX
2
JMP
1 IX
4
JSR
1 IX
4
2
LDX
LDX
3 SP1 1 IX
4
2
STX
STX
3 SP1 1 IX
High Byte of Opcode in Hexadecimal
LSB
Low Byte of Opcode in Hexadecimal
Cycles
BRSET0 Opcode Mnemonic
3 DIR Number of Bytes / Addressing Mode
Data Sheet
102
Table 7-2. Opcode Map
Bit Manipulation
DIR
DIR
Section 8. External Interrupt (IRQ)
8.1 Introduction
The IRQ (external interrupt) module provides a maskable interrupt input.
8.2 Features
Features of the IRQ module include:
A dedicated external interrupt pin (IRQ)
IRQ interrupt control bits
Hysteresis buffer
Programmable edge-only or edge and level interrupt sensitivity
Automatic interrupt acknowledge
Internal pullup resistor
8.3 Functional Description
A logic 0 applied to the external interrupt pin can latch a central processor unit
(CPU) interrupt request. Figure 8-2 shows the structure of the IRQ module.
Interrupt signals on the IRQ pin are latched into the IRQ latch. An interrupt latch
remains set until one of the following actions occurs:
Vector fetch — A vector fetch automatically generates an interrupt
acknowledge signal that clears the latch that caused the vector fetch.
Software clear — Software can clear an interrupt latch by writing to the
appropriate acknowledge bit in the interrupt status and control register
(INTSCR). Writing a logic 1 to the ACK bit clears the IRQ latch.
Reset — A reset automatically clears the interrupt latch.
The external interrupt pin is falling-edge triggered and is software-configurable to
be either falling-edge or falling-edge and low-level triggered. The MODE bit in the
INTSCR controls the triggering sensitivity of the IRQ pin.
When an interrupt pin is edge-triggered only, the interrupt remains set until a vector
fetch, software clear, or reset occurs.
MOTOROLA
Data Sheet
103
USER RAM — 1024 BYTES
DDRA
PORTA
PORTB
PTB7/AD7
PTB6/AD6
PTB5/AD5
PTB4/AD4
PTB3/AD3
PTB2/AD2
PTB1/AD1
PTB0/AD0
PTC6(1)
PTC5(1)
PTC4(1), (2)
PTC3(1), (2)
PTC2(1), (2)
PTC1(1), (2)
PTC0(1), (2)
PTD7/T2CH1(1)
PTD6/T2CH0(1)
PTD5/T1CH1(1)
PTD4/T1CH0(1)
PTD3/SPSCK(1)
PTD2/MOSI(1)
PTD1/MISO(1)
PTD0/SS(1)
PTE5–PTE2
PTE1/RxD
PTE0/TxD
SINGLE BREAKPOINT
BREAK MODULE
DUAL VOLTAGE
LOW-VOLTAGE INHIBIT
MODULE
DDRB
USER FLASH — 15,872 BYTES
8-BIT KEYBOARD
INTERRUPT MODULE
MONITOR ROM — 350 BYTES
CLOCK GENERATOR MODULE
OSC1
OSC2
32–100 kHz OSCILLATOR
ENHANCED SERIAL
COMUNICATIONS
INTERFACE MODULE
PHASE LOCKED LOOP
COMPUTER OPERATING
PROPERLY MODULE
RST(3)
SYSTEM INTEGRATION
MODULE
SERIAL PERIPHERAL
INTERFACE MODULE
IRQ(3)
SINGLE EXTERNAL
INTERRUPT MODULE
MONITOR MODULE
10-BIT ANALOG-TO-DIGITAL
CONVERTER MODULE
DATA BUS SWITCH
MODULE
POWER-ON RESET
MODULE
MEMORY MAP
MODULE
POWER
CONFIGURATION
REGISTER 1–2
MODULE
CGMXFC
VDDAD/VREFH
VDDAD/VREFL
MOTOROLA
VDD
VSS
VDDA
VSSA
DDRC
2-CHANNEL TIMER
INTERFACE MODULE 2
DDRD
USER FLASH VECTOR SPACE — 44 BYTES
2-CHANNEL TIMER
INTERFACE MODULE 1
DDRE
FLASH PROGRAMMING ROUTINES ROM — 406 BYTES
PTA7/KBD7–PTA0/KBD0(1)
PORTC
CONTROL AND STATUS REGISTERS — 64 BYTES
PROGRAMMABLE TIMEBASE
MODULE
PORTD
ARITHMETIC/LOGIC
UNIT (ALU)
PORTE
CPU
REGISTERS
SECURITY
MODULE
MONITOR MODE ENTRY
MODULE
1. Ports are software configurable with pullup device if input port.
2. Higher current drive port pins
3. Pin contains integrated pullup device
Figure 8-1. Block Diagram Highlighting IRQ Block and Pins
Data Sheet
104
INTERNAL BUS
M68HC08 CPU
RESET
INTERNAL ADDRESS BUS
ACK
TO CPU FOR
BIL/BIH
INSTRUCTIONS
VECTOR
FETCH
DECODER
VDD
INTERNAL
PULLUP
DEVICE
VDD
IRQF
D
CLR
Q
IRQ
INTERRUPT
REQUEST
SYNCHRONIZER
CK
IRQ
IMASK
MODE
TO MODE
SELECT
LOGIC
HIGH
VOLTAGE
DETECT
Figure 8-2. IRQ Module Block Diagram
When an interrupt pin is both falling-edge and low-level triggered, the interrupt
remains set until both of these events occur:
Vector fetch or software clear
Return of the interrupt pin to logic 1
The vector fetch or software clear may occur before or after the interrupt pin returns
to logic 1. As long as the pin is low, the interrupt request remains pending. A reset
will clear the latch and the MODE control bit, thereby clearing the interrupt even if
the pin stays low.
When set, the IMASK bit in the INTSCR mask all external interrupt requests. A
latched interrupt request is not presented to the interrupt priority logic unless the
IMASK bit is clear.
NOTE:
The interrupt mask (I) in the condition code register (CCR) masks all interrupt
requests, including external interrupt requests.
Addr.
Register Name
$001D
IRQ Status and Control Read:
Register (INTSCR) Write:
See page 107. Reset:
Bit 7
6
5
4
3
2
IRQF
ACK
Bit 0
IMASK
MODE
= Unimplemented
Figure 8-3. IRQ I/O Register Summary
MOTOROLA
Data Sheet
105
8.4 IRQ Pin
A logic 0 on the IRQ pin can latch an interrupt request into the IRQ latch. A vector
fetch, software clear, or reset clears the IRQ latch.
If the MODE bit is set, the IRQ pin is both falling-edge-sensitive and
low-level-sensitive. With MODE set, both of the following actions must occur to
clear IRQ:
Vector fetch or software clear — A vector fetch generates an interrupt
acknowledge signal to clear the latch. Software may generate the interrupt
acknowledge signal by writing a logic 1 to the ACK bit in the interrupt status
and control register (INTSCR). The ACK bit is useful in applications that poll
the IRQ pin and require software to clear the IRQ latch. Writing to the ACK
bit prior to leaving an interrupt service routine can also prevent spurious
interrupts due to noise. Setting ACK does not affect subsequent transitions
on the IRQ pin. A falling edge that occurs after writing to the ACK bit another
interrupt request. If the IRQ mask bit, IMASK, is clear, the CPU loads the
program counter with the vector address at locations $FFFA and $FFFB.
Return of the IRQ pin to logic 1 — As long as the IRQ pin is at logic 0, IRQ
remains active.
The vector fetch or software clear and the return of the IRQ pin to logic 1 may occur
in any order. The interrupt request remains pending as long as the IRQ pin is at
logic 0. A reset will clear the latch and the MODE control bit, thereby clearing the
interrupt even if the pin stays low.
If the MODE bit is clear, the IRQ pin is falling-edge-sensitive only. With MODE
clear, a vector fetch or software clear immediately clears the IRQ latch.
The IRQF bit in the INTSCR register can be used to check for pending interrupts.
The IRQF bit is not affected by the IMASK bit, which makes it useful in applications
where polling is preferred.
Use the BIH or BIL instruction to read the logic level on the IRQ pin.
NOTE:
When using the level-sensitive interrupt trigger, avoid false interrupts by masking
interrupt requests in the interrupt routine.
8.5 IRQ Module During Break Interrupts
The BCFE bit in the SIM break flag control register (SBFCR) enables software to
clear the latch during the break state. See Section 19. Development Support.
To allow software to clear the IRQ latch during a break interrupt, write a logic 1 to
the BCFE bit. If a latch is cleared during the break state, it remains cleared when
Data Sheet
106
MOTOROLA
IRQ Status and Control Register
To protect CPU interrupt flags during the break state, write a logic 0 to the BCFE
bit. With BCFE at logic 0 (its default state), writing to the ACK bit in the IRQ status
and control register during the break state has no effect on the IRQ interrupt flags.
8.6 IRQ Status and Control Register
The IRQ status and control register (INTSCR) controls and monitors operation of
the IRQ module. The INTSCR:
• Shows the state of the IRQ flag
• Clears the IRQ latch
• Masks IRQ interrupt request
• Controls triggering sensitivity of the IRQ interrupt pin.
Address:
$001D
Bit 7
6
5
4
Read:
3
IRQF
Write:
Reset:
2
ACK
Bit 0
IMASK
MODE
= Unimplemented
Figure 8-4. IRQ Status and Control Register (INTSCR)
IRQF — IRQ Flag Bit
This read-only status bit is high when the IRQ interrupt is pending.
1 = IRQ interrupt pending
0 = IRQ interrupt not pending
ACK — IRQ Interrupt Request Acknowledge Bit
Writing a logic 1 to this write-only bit clears the IRQ latch. ACK always reads as
logic 0. Reset clears ACK.
IMASK — IRQ Interrupt Mask Bit
Writing a logic 1 to this read/write bit disables IRQ interrupt requests. Reset
clears IMASK.
1 = IRQ interrupt requests disabled
0 = IRQ interrupt requests enabled
MODE — IRQ Edge/Level Select Bit
This read/write bit controls the triggering sensitivity of the IRQ pin. Reset clears
MODE.
1 = IRQ interrupt requests on falling edges and low levels
0 = IRQ interrupt requests on falling edges only
MOTOROLA
Data Sheet
107
Data Sheet
108
MOTOROLA
Section 9. Keyboard Interrupt Module (KBI)
9.1 Introduction
The keyboard interrupt module (KBI) provides eight independently maskable
external interrupts which are accessible via PTA0–PTA7. When a port pin is
enabled for keyboard interrupt function, an internal pullup device is also enabled
on the pin.
9.2 Features
Features include:
Eight keyboard interrupt pins with separate keyboard interrupt enable bits
and one keyboard interrupt mask
Hysteresis buffers
Programmable edge-only or edge- and level- interrupt sensitivity
Exit from low-power modes
I/O (input/output) port bit(s) software configurable with pullup device(s) if
configured as input port bit(s)
9.3 Functional Description
Writing to the KBIE7–KBIE0 bits in the keyboard interrupt enable register
independently enables or disables each port A pin as a keyboard interrupt pin.
Enabling a keyboard interrupt pin also enables its internal pullup device. A logic 0
applied to an enabled keyboard interrupt pin latches a keyboard interrupt request.
A keyboard interrupt is latched when one or more keyboard pins goes low after all
were high. The MODEK bit in the keyboard status and control register controls the
triggering mode of the keyboard interrupt.
If the keyboard interrupt is edge-sensitive only, a falling edge on a keyboard
pin does not latch an interrupt request if another keyboard pin is already low.
To prevent losing an interrupt request on one pin because another pin is still
low, software can disable the latter pin while it is low.
If the keyboard interrupt is falling edge- and low-level sensitive, an interrupt
request is present as long as any keyboard interrupt pin is low and the pin
is keyboard interrupt enabled.
MOTOROLA
Data Sheet
109
PORTA
PORTB
PORTC
PTB7/AD7
PTB6/AD6
PTB5/AD5
PTB4/AD4
PTB3/AD3
PTB2/AD2
PTB1/AD1
PTB0/AD0
PTC6(1)
PTC5(1)
PTC4(1), (2)
PTC3(1), (2)
PTC2(1), (2)
PTC1(1), (2)
PTC0(1), (2)
PORTD
PTD7/T2CH1(1)
PTD6/T2CH0(1)
PTD5/T1CH1(1)
PTD4/T1CH0(1)
PTD3/SPSCK(1)
PTD2/MOSI(1)
PTD1/MISO(1)
PTD0/SS(1)
PTE5–PTE2
PTE1/RxD
PTE0/TxD
SINGLE BREAKPOINT
BREAK MODULE
DUAL VOLTAGE
LOW-VOLTAGE INHIBIT
MODULE
8-BIT KEYBOARD
INTERRUPT MODULE
OSC1
OSC2
ENHANCED SERIAL
COMUNICATIONS
INTERFACE MODULE
PHASE LOCKED LOOP
COMPUTER OPERATING
PROPERLY MODULE
RST(3)
SYSTEM INTEGRATION
MODULE
SERIAL PERIPHERAL
INTERFACE MODULE
IRQ(3)
SINGLE EXTERNAL
INTERRUPT MODULE
MONITOR MODULE
CONVERTER MODULE
DATA BUS SWITCH
MODULE
POWER-ON RESET
MODULE
MEMORY MAP
MODULE
POWER
CONFIGURATION
REGISTER 1–2
MODULE
CGMXFC
VDDAD/VREFH
VDDAD/VREFL
MOTOROLA
VDD
VSS
VDDA
VSSA
DDRC
2-CHANNEL TIMER
INTERFACE MODULE 2
DDRD
2-CHANNEL TIMER
INTERFACE MODULE 1
DDRE
PORTE
MODULE
DDRA
ARITHMETIC/LOGIC
UNIT (ALU)
DDRB
CPU
REGISTERS
SECURITY
MODULE
MONITOR MODE ENTRY
MODULE
Figure 9-1. Block Diagram Highlighting KBI Block and Pins
Data Sheet
110
INTERNAL BUS
M68HC08 CPU
INTERNAL BUS
VECTOR FETCH
DECODER
ACKK
RESET
KBD0
VDD
TO PULLUP ENABLE
KEYF
D
CLR
Q
SYNCHRONIZER
CK
KB0IE
KEYBOARD
INTERRUPT
REQUEST
IMASKK
KBD7
MODEK
TO PULLUP ENABLE
KB7IE
Figure 9-2. Keyboard Module Block Diagram
Addr.
Register Name
Keyboard Status Read:
and Control Register Write:
(INTKBSCR)
See page 114. Reset:
$001A
$001B
Keyboard Interrupt Enable Read:
Register Write:
(INTKBIER)
See page 115. Reset:
Bit 7
6
5
4
3
2
KEYF
ACKK
1
Bit 0
IMASKK
MODEK
KBIE7
KBIE6
KBIE5
KBIE4
KBIE3
KBIE2
KBIE1
KBIE0
= Unimplemented
Figure 9-3. I/O Register Summary
If the MODEK bit is set, the keyboard interrupt pins are both falling edge- and
low-level sensitive, and both of the following actions must occur to clear a keyboard
interrupt request:
• Vector fetch or software clear — A vector fetch generates an interrupt
acknowledge signal to clear the interrupt request. Software may generate
the interrupt acknowledge signal by writing a logic 1 to the ACKK bit in the
keyboard status and control register (INTKBSCR). The ACKK bit is useful in
applications that poll the keyboard interrupt pins and require software to
clear the keyboard interrupt request. Writing to the ACKK bit prior to leaving
an interrupt service routine can also prevent spurious interrupts due to
noise. Setting ACKK does not affect subsequent transitions on the keyboard
interrupt pins. A falling edge that occurs after writing to the ACKK bit latches
MOTOROLA
Data Sheet
111
another interrupt request. If the keyboard interrupt mask bit, IMASKK, is
clear, the CPU loads the program counter with the vector address at
locations $FFE0 and $FFE1.
Return of all enabled keyboard interrupt pins to logic 1 — As long as any
enabled keyboard interrupt pin is at logic 0, the keyboard interrupt remains
set.
The vector fetch or software clear and the return of all enabled keyboard interrupt
pins to logic 1 may occur in any order.
If the MODEK bit is clear, the keyboard interrupt pin is falling-edge-sensitive only.
With MODEK clear, a vector fetch or software clear immediately clears the
Reset clears the keyboard interrupt request and the MODEK bit, clearing the
interrupt request even if a keyboard interrupt pin stays at logic 0.
The keyboard flag bit (KEYF) in the keyboard status and control register can be
used to see if a pending interrupt exists. The KEYF bit is not affected by the
keyboard interrupt mask bit (IMASKK) which makes it useful in applications where
To determine the logic level on a keyboard interrupt pin, use the data direction
register to configure the pin as an input and read the data register.
NOTE:
Setting a keyboard interrupt enable bit (KBIEx) forces the corresponding keyboard
interrupt pin to be an input, overriding the data direction register. However, the data
direction register bit must be a logic 0 for software to read the pin.
9.4 Keyboard Initialization
When a keyboard interrupt pin is enabled, it takes time for the internal pullup to
reach a logic 1. Therefore, a false interrupt can occur as soon as the pin is enabled.
To prevent a false interrupt on keyboard initialization:
1. Mask keyboard interrupts by setting the IMASKK bit in the keyboard status
and control register.
2. Enable the KBI pins by setting the appropriate KBIEx bits in the keyboard
interrupt enable register.
3. Write to the ACKK bit in the keyboard status and control register to clear any
false interrupts.
4. Clear the IMASKK bit.
An interrupt signal on an edge-triggered pin can be acknowledged immediately
after enabling the pin. An interrupt signal on an edge- and level-triggered interrupt
pin must be acknowledged after a delay that depends on the external load.
Data Sheet
112
MOTOROLA
Low-Power Modes
Another way to avoid a false interrupt:
1. Configure the keyboard pins as outputs by setting the appropriate DDRA
bits in data direction register A.
2. Write logic 1s to the appropriate port A data register bits.
3. Enable the KBI pins by setting the appropriate KBIEx bits in the keyboard
9.5 Low-Power Modes
power-consumption standby modes.
9.5.1 Wait Mode
The keyboard module remains active in wait mode. Clearing the IMASKK bit in the
keyboard status and control register enables keyboard interrupt requests to bring
the MCU out of wait mode.
9.5.2 Stop Mode
The keyboard module remains active in stop mode. Clearing the IMASKK bit in the
the MCU out of stop mode.
9.6 Keyboard Module During Break Interrupts
The system integration module (SIM) controls whether the keyboard interrupt latch
can be cleared during the break state. The BCFE bit in the break flag control
register (BFCR) enables software to clear status bits during the break state.
To allow software to clear the keyboard interrupt latch during a break interrupt,
write a logic 1 to the BCFE bit. If a latch is cleared during the break state, it remains
cleared when the MCU exits the break state.
To protect the latch during the break state, write a logic 0 to the BCFE bit. With
BCFE at logic 0 (its default state), writing to the keyboard acknowledge bit (ACKK)
in the keyboard status and control register during the break state has no effect. See
9.7.1 Keyboard Status and Control Register.
MOTOROLA
Data Sheet
113
9.7 I/O Registers
These registers control and monitor operation of the keyboard module:
Keyboard status and control register (INTKBSCR)
Keyboard interrupt enable register (INTKBIER)
The keyboard status and control register:
Flags keyboard interrupt requests
Acknowledges keyboard interrupt requests
Masks keyboard interrupt requests
Controls keyboard interrupt triggering sensitivity
Address: $001A
Read:
Bit 7
6
5
4
3
2
KEYF
Write:
Reset:
ACKK
Bit 0
IMASKK
MODEK
= Unimplemented
Figure 9-4. Keyboard Status and Control Register (INTKBSCR)
Bits 7–4 — Not used
These read-only bits always read as logic 0s.
KEYF — Keyboard Flag Bit
This read-only bit is set when a keyboard interrupt is pending. Reset clears the
KEYF bit.
1 = Keyboard interrupt pending
0 = No keyboard interrupt pending
ACKK — Keyboard Acknowledge Bit
Writing a logic 1 to this write-only bit clears the keyboard interrupt request.
ACKK always reads as logic 0. Reset clears ACKK.
IMASKK — Keyboard Interrupt Mask Bit
Writing a logic 1 to this read/write bit prevents the output of the keyboard
interrupt mask from generating interrupt requests. Reset clears the IMASKK bit.
1 = Keyboard interrupt requests masked
0 = Keyboard interrupt requests not masked
MODEK — Keyboard Triggering Sensitivity Bit
This read/write bit controls the triggering sensitivity of the keyboard interrupt
pins. Reset clears MODEK.
1 = Keyboard interrupt requests on falling edges and low levels
0 = Keyboard interrupt requests on falling edges only
Data Sheet
114
MOTOROLA
I/O Registers
9.7.2 Keyboard Interrupt Enable Register
The keyboard interrupt enable register enables or disables each port A pin to
operate as a keyboard interrupt pin.
Address: $001B
Read:
Write:
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
KBIE7
KBIE6
KBIE5
KBIE4
KBIE3
KBIE2
KBIE1
KBIE0
Figure 9-5. Keyboard Interrupt Enable Register (INTKBIER)
KBIE7–KBIE0 — Keyboard Interrupt Enable Bits
Each of these read/write bits enables the corresponding keyboard interrupt pin
to latch interrupt requests. Reset clears the keyboard interrupt enable register.
1 = PTAx pin enabled as keyboard interrupt pin
0 = PTAx pin not enabled as keyboard interrupt pin
MOTOROLA
Data Sheet
115
Data Sheet
116
MOTOROLA
Section 10. Low-Power Modes
10.1 Introduction
The microcontroller (MCU) may enter two low-power modes: wait mode and stop
mode. They are common to all HC08 MCUs and are entered through instruction
execution. This section describes how each module acts in the low-power modes.
10.1.1 Wait Mode
The WAIT instruction puts the MCU in a low-power standby mode in which the
central processor unit (CPU) clock is disabled but the bus clock continues to run.
Power consumption can be further reduced by disabling the low-voltage inhibit
(LVI) module through bits in the CONFIG1 register. See Section 5. Configuration
Register (CONFIG).
10.1.2 Stop Mode
Stop mode is entered when a STOP instruction is executed. The CPU clock is
disabled and the bus clock is disabled if the OSCENINSTOP bit in the CONFIG2
register is at a logic 0. See Section 5. Configuration Register (CONFIG).
10.2 Analog-to-Digital Converter (ADC)
10.2.1 Wait Mode
The analog-to-digital converter (ADC) continues normal operation during wait
mode. Any enabled CPU interrupt request from the ADC can bring the MCU out of
wait mode. If the ADC is not required to bring the MCU out of wait mode, power
down the ADC by setting ADCH4–ADCH0 bits in the ADC status and control
register before executing the WAIT instruction.
10.2.2 Stop Mode
The ADC module is inactive after the execution of a STOP instruction. Any pending
conversion is aborted. ADC conversions resume when the MCU exits stop mode
after an external interrupt. Allow one conversion cycle to stabilize the analog
circuitry.
MOTOROLA
Data Sheet
Low-Power Modes
117
Low-Power Modes
10.3 Break Module (BRK)
10.3.1 Wait Mode
If enabled, the break (BRK) module is active in wait mode. In the break routine, the
user can subtract one from the return address on the stack if the SBSW bit in the
break status register is set.
10.3.2 Stop Mode
The break module is inactive in stop mode. A break interrupt causes exit from stop
mode and sets the SBSW bit in the break status register. The STOP instruction
does not affect break module register states.
10.4 Central Processor Unit (CPU)
10.4.1 Wait Mode
10.4.2 Stop Mode
10.5 Clock Generator Module (CGM)
10.5.1 Wait Mode
The clock generator module (CGM) remains active in wait mode. Before entering
wait mode, software can disengage and turn off the PLL by clearing the BCS and
PLLON bits in the PLL control register (PCTL). Less power-sensitive applications
can disengage the PLL without turning it off. Applications that require the PLL to
wake the MCU from wait mode also can deselect the PLL output without turning off
the PLL.
Data Sheet
118
Low-Power Modes
MOTOROLA
Low-Power Modes
Computer Operating Properly Module (COP)
10.5.2 Stop Mode
If the OSCSTOPEN bit in the CONFIG register is cleared (default), then the STOP
instruction disables the CGM (oscillator and phase-locked loop) and holds low all
CGM outputs (CGMXCLK, CGMOUT, and CGMINT).
If the STOP instruction is executed with the VCO clock, CGMVCLK, divided by two
driving CGMOUT, the PLL automatically clears the BCS bit in the PLL control
register (PCTL), thereby selecting the crystal clock, CGMXCLK, divided by two as
the source of CGMOUT. When the MCU recovers from STOP, the crystal clock
divided by two drives CGMOUT and BCS remains clear.
If the OSCSTOPEN bit in the CONFIG register is set, then the phase locked loop
is shut off, but the oscillator will continue to operate in stop mode.
10.6 Computer Operating Properly Module (COP)
10.6.1 Wait Mode
COP timeout.
10.6.2 Stop Mode
Stop mode turns off the COPCLK input to the COP and clears the COP prescaler.
The STOP bit in the CONFIG1 register enables the STOP instruction. To prevent
inadvertently turning off the COP with a STOP instruction, disable the STOP
instruction by clearing the STOP bit.
10.7 External Interrupt Module (IRQ)
10.7.1 Wait Mode
The external interrupt (IRQ) module remains active in wait mode. Clearing the
IMASK1 bit in the IRQ status and control register enables IRQ CPU interrupt
requests to bring the MCU out of wait mode.
10.7.2 Stop Mode
The IRQ module remains active in stop mode. Clearing the IMASK1 bit in the IRQ
status and control register enables IRQ CPU interrupt requests to bring the MCU
out of stop mode.
MOTOROLA
Data Sheet
Low-Power Modes
119
Low-Power Modes
10.8 Keyboard Interrupt Module (KBI)
10.8.1 Wait Mode
The keyboard interrupt (KBI) module remains active in wait mode. Clearing the
IMASKK bit in the keyboard status and control register enables keyboard interrupt
10.8.2 Stop Mode
10.9 Low-Voltage Inhibit Module (LVI)
10.9.1 Wait Mode
If enabled, the low-voltage inhibit (LVI) module remains active in wait mode. If
enabled to generate resets, the LVI module can generate a reset and bring the
10.9.2 Stop Mode
If enabled, the LVI module remains active in stop mode. If enabled to generate
resets, the LVI module can generate a reset and bring the MCU out of stop mode.
10.10 Enhanced Serial Communications Interface Module (ESCI)
10.10.1 Wait Mode
The enhanced serial communications interface (ESCI), or SCI module for short,
module remains active in wait mode. Any enabled CPU interrupt request from the
SCI module can bring the MCU out of wait mode.
If SCI module functions are not required during wait mode, reduce power
consumption by disabling the module before executing the WAIT instruction.
10.10.2 Stop Mode
The SCI module is inactive in stop mode. The STOP instruction does not affect SCI
register states. SCI module operation resumes after the MCU exits stop mode.
Because the internal clock is inactive during stop mode, entering stop mode during
an SCI transmission or reception results in invalid data.
Data Sheet
120
Low-Power Modes
MOTOROLA
Low-Power Modes
Serial Peripheral Interface Module (SPI)
10.11 Serial Peripheral Interface Module (SPI)
10.11.1 Wait Mode
The serial peripheral interface (SPI) module remains active in wait mode. Any
enabled CPU interrupt request from the SPI module can bring the MCU out of wait
mode.
If SPI module functions are not required during wait mode, reduce power
consumption by disabling the SPI module before executing the WAIT instruction.
10.11.2 Stop Mode
The SPI module is inactive in stop mode. The STOP instruction does not affect SPI
register states. SPI operation resumes after an external interrupt. If stop mode is
exited by reset, any transfer in progress is aborted, and the SPI is reset.
10.12 Timer Interface Module (TIM1 and TIM2)
10.12.1 Wait Mode
The timer interface modules (TIM) remain active in wait mode. Any enabled CPU
interrupt request from the TIM can bring the MCU out of wait mode.
If TIM functions are not required during wait mode, reduce power consumption by
stopping the TIM before executing the WAIT instruction.
10.12.2 Stop Mode
The TIM is inactive in stop mode. The STOP instruction does not affect register
states or the state of the TIM counter. TIM operation resumes when the MCU exits
stop mode after an external interrupt.
10.13 Timebase Module (TBM)
10.13.1 Wait Mode
The timebase module (TBM) remains active after execution of the WAIT
instruction. In wait mode, the timebase register is not accessible by the CPU.
If the timebase functions are not required during wait mode, reduce the power
consumption by stopping the timebase before enabling the WAIT instruction.
10.13.2 Stop Mode
The timebase module may remain active after execution of the STOP instruction if
the oscillator has been enabled to operate during stop mode through the
MOTOROLA
Data Sheet
Low-Power Modes
121
Low-Power Modes
OSCENINSTOP bit in the CONFIG2 register. The timebase module can be used
in this mode to generate a periodic wakeup from stop mode.
If the oscillator has not been enabled to operate in stop mode, the timebase module
will not be active during stop mode. In stop mode, the timebase register is not
If the timebase functions are not required during stop mode, reduce the power
consumption by stopping the timebase before enabling the STOP instruction.
10.14 Exiting Wait Mode
These events restart the CPU clock and load the program counter with the reset
vector or with an interrupt vector:
External reset — A logic 0 on the RST pin resets the MCU and loads the
program counter with the contents of locations $FFFE and $FFFF.
External interrupt — A high-to-low transition on an external interrupt pin
(IRQ pin) loads the program counter with the contents of locations: $FFFA
and $FFFB; IRQ pin.
Break interrupt — In emulation mode, a break interrupt loads the program
counter with the contents of $FFFC and $FFFD.
Computer operating properly (COP) module reset — A timeout of the COP
counter resets the MCU and loads the program counter with the contents of
$FFFE and $FFFF.
Low-voltage inhibit (LVI) module reset — A power supply voltage below the
VTRIPF voltage resets the MCU and loads the program counter with the
Clock generator module (CGM) interrupt — A CPU interrupt request from
the ICG loads the program counter with the contents of $FFF8 and $FFF9.
Keyboard interrupt (KBI) module — A CPU interrupt request from the KBI
module loads the program counter with the contents of $FFE0 and $FFE1.
Timer 1 interface (TIM1) module interrupt — A CPU interrupt request from
the TIM1 loads the program counter with the contents of:
– $FFF2 and $FFF3; TIM1 overflow
– $FFF4 and $FFF5; TIM1 channel 1
– $FFF6 and $FFF7; TIM1 channel 0
Timer 2 interface (TIM2) module interrupt — A CPU interrupt request from
the TIM2 loads the program counter with the contents of:
– $FFEC and $FFED; TIM2 overflow
– $FFF0 and $FFF1; TIM2 channel 0
Serial peripheral interface (SPI) module interrupt — A CPU interrupt request
from the SPI loads the program counter with the contents of:
– $FFE8 and $FFE9; SPI transmitter
– $FFEA and $FFEB; SPI receiver
Data Sheet
122
Low-Power Modes
MOTOROLA
Low-Power Modes
Exiting Stop Mode
Serial communications interface (SCI) module interrupt — A CPU interrupt
request from the SCI loads the program counter with the contents of:
– $FFE2 and $FFE3; SCI transmitter
– $FFE4 and $FFE5; SCI receiver
– $FFE6 and $FFE7; SCI receiver error
Analog-to-digital converter (ADC) module interrupt — A CPU interrupt
request from the ADC loads the program counter with the contents of:
$FFDE and $FFDF; ADC conversion complete.
Timebase module (TBM) interrupt — A CPU interrupt request from the TBM
loads the program counter with the contents of: $FFDC and $FFDD; TBM
interrupt.
10.15 Exiting Stop Mode
These events restart the system clocks and load the program counter with the reset
– $FFFA and $FFFB; IRQ pin
– $FFE0 and $FFE1; keyboard interrupt pins
Low-voltage inhibit (LVI) reset — A power supply voltage below the LVITRIPF
voltage resets the MCU and loads the program counter with the contents of
counter with the contents of locations $FFFC and $FFFD.
Timebase module (TBM) interrupt — A TBM interrupt loads the program
counter with the contents of locations $FFDC and $FFDD when the
timebase counter has rolled over. This allows the TBM to generate a
Upon exit from stop mode, the system clocks begin running after an oscillator
stabilization delay. A 12-bit stop recovery counter inhibits the system clocks for
4096 CGMXCLK cycles after the reset or external interrupt.
The short stop recovery bit, SSREC, in the CONFIG1 register controls the oscillator
stabilization delay during stop recovery. Setting SSREC reduces stop recovery
time from 4096 CGMXCLK cycles to 32 CGMXCLK cycles.
NOTE:
Use the full stop recovery time (SSREC = 0) in applications that use an external
crystal.
MOTOROLA
Data Sheet
Low-Power Modes
123
Low-Power Modes
Data Sheet
124
Low-Power Modes
MOTOROLA
Data Sheet — MC68HC908GR16
Section 11. Low-Voltage Inhibit (LVI)
11.1 Introduction
This section describes the low-voltage inhibit (LVI) module, which monitors the
voltage on the VDD pin and can force a reset when the VDD voltage falls below the
LVI trip falling voltage, VTRIPF.
11.2 Features
Features of the LVI module include:
Programmable LVI reset
Selectable LVI trip voltage
Programmable stop mode operation
11.3 Functional Description
Figure 11-1 shows the structure of the LVI module. The LVI is enabled out of reset.
The LVI module contains a bandgap reference circuit and comparator. Clearing the
LVI power disable bit, LVIPWRD, enables the LVI to monitor VDD voltage. Clearing
the LVI reset disable bit, LVIRSTD, enables the LVI module to generate a reset
when VDD falls below a voltage, VTRIPF. Setting the LVI enable in stop mode bit,
LVISTOP, enables the LVI to operate in stop mode. Setting the LVI 5-V or 3-V trip
point bit, LVI5OR3, enables the trip point voltage, VTRIPF, to be configured for 5-V
operation. Clearing the LVI5OR3 bit enables the trip point voltage, VTRIPF, to be
configured for 3-V operation. The actual trip points are shown in Section 20.
Electrical Specifications.
NOTE:
After a power-on reset (POR) the LVI’s default mode of operation is 3 V. If a 5-V
system is used, the user must set the LVI5OR3 bit to raise the trip point to 5-V
operation. Note that this must be done after every power-on reset since the default
will revert back to 3-V mode after each power-on reset. If the VDD supply is below
the 5-V mode trip voltage but above the 3-V mode trip voltage when POR is
released, the part will operate because VTRIPF defaults to 3-V mode after a POR.
So, in a 5-V system care must be taken to ensure that VDD is above the 5-V mode
trip voltage after POR is released.
If the user requires 5-V mode and sets the LVI5OR3 bit after a power-on reset while
the VDD supply is not above the VTRIPR for 5-V mode, the microcontroller unit
(MCU) will immediately go into reset. The LVI in this case will hold the part in reset
until either VDD goes above the rising 5-V trip point, VTRIPR, which will release reset
MOTOROLA
Data Sheet
125
or VDD decreases to approximately 0 V which will re-trigger the power-on reset and
reset the trip point to 3-V operation.
LVISTOP, LVIPWRD, LVI5OR3, and LVIRSTD are in the configuration register
(CONFIG1). See Figure 5-2. Configuration Register 1 (CONFIG1) for details of
the LVI’s configuration bits. Once an LVI reset occurs, the MCU remains in reset
until VDD rises above a voltage, VTRIPR, which causes the MCU to exit reset. See
15.3.2.5 Low-Voltage Inhibit (LVI) Reset for details of the interaction between the
SIM and the LVI. The output of the comparator controls the state of the LVIOUT
flag in the LVI status register (LVISR).
An LVI reset also drives the RST pin low to provide low-voltage protection to
external peripheral devices.
VDD
STOP INSTRUCTION
LVISTOP
FROM CONFIG1
FROM CONFIG1
LVIRSTD
LVIPWRD
FROM CONFIG
LOW VDD
DETECTOR
VDD > LVITrip = 0
LVI RESET
VDD £ LVITrip = 1
LVIOUT
LVI5OR3
FROM CONFIG1
Figure 11-1. LVI Module Block Diagram
Addr.
$FE0C
Register Name
Read:
LVI Status Register
(LVISR) Write:
See page 127.
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
LVIOUT
= Unimplemented
Figure 11-2. LVI I/O Register Summary
Data Sheet
126
MOTOROLA
LVI Status Register
11.3.1 Polled LVI Operation
In applications that can operate at VDD levels below the VTRIPF level, software can
monitor VDD by polling the LVIOUT bit. In the configuration register, the LVIPWRD
bit must be at logic 0 to enable the LVI module, and the LVIRSTD bit must be at
logic 1 to disable LVI resets.
11.3.2 Forced Reset Operation
In applications that require VDD to remain above the VTRIPF level, enabling LVI
resets allows the LVI module to reset the MCU when VDD falls below the VTRIPF
level. In the configuration register, the LVIPWRD and LVIRSTD bits must be at
logic 0 to enable the LVI module and to enable LVI resets.
11.3.3 Voltage Hysteresis Protection
Once the LVI has triggered (by having VDD fall below VTRIPF), the LVI will maintain
a reset condition until VDD rises above the rising trip point voltage, VTRIPR. This
prevents a condition in which the MCU is continually entering and exiting reset if
VDD is approximately equal to VTRIPF. VTRIPR is greater than VTRIPF by the
hysteresis voltage, VHYS.
11.3.4 LVI Trip Selection
The LVI5OR3 bit in the configuration register selects whether the LVI is configured
for 5-V or 3-V protection.
NOTE:
The microcontroller is guaranteed to operate at a minimum supply voltage. The trip
point (VTRIPF [5 V] or VTRIPF [3 V]) may be lower than this. See Section 20.
Electrical Specifications for the actual trip point voltages.
11.4 LVI Status Register
The LVI status register (LVISR) indicates if the VDD voltage was detected below
the VTRIPF level.
Address:
Read:
$FE0C
Bit 7
6
5
4
3
2
1
Bit 0
LVIOUT
Write:
Reset:
= Unimplemented
Figure 11-3. LVI Status Register (LVISR)
MOTOROLA
Data Sheet
127
LVIOUT — LVI Output Bit
This read-only flag becomes set when the VDD voltage falls below the VTRIPF
trip voltage (see Table 11-1). Reset clears the LVIOUT bit.
Table 11-1. LVIOUT Bit Indication
VDD
LVIOUT
VDD > VTRIPR
VDD < VTRIPF
1
VTRIPF < VDD < VTRIPR
Previous value
11.5 LVI Interrupts
The LVI module does not generate interrupt requests.
11.6 Low-Power Modes
The STOP and WAIT instructions put the MCU in low power-consumption standby
modes.
11.6.1 Wait Mode
If enabled, the LVI module remains active in wait mode. If enabled to generate
resets, the LVI module can generate a reset and bring the MCU out of wait mode.
11.6.2 Stop Mode
If enabled in stop mode (LVISTOP set), the LVI module remains active in stop
mode. If enabled to generate resets, the LVI module can generate a reset and bring
Data Sheet
128
MOTOROLA
Section 12. Input/Output Ports (PORTS)
12.1 Introduction
Bidirectional input-output (I/O) pins form five parallel ports. All I/O pins are
programmable as inputs or outputs. All individual bits within port A, port C, and
port D are software configurable with pullup devices if configured as input port bits.
The pullup devices are automatically and dynamically disabled when a port bit is
switched to output mode.
NOTE:
Connect any unused I/O pins to an appropriate logic level, either VDD or VSS.
Although the I/O ports do not require termination for proper operation, termination
reduces excess current consumption and the possibility of electrostatic damage.
Not all port pins are bonded out in all packages. Care sure be taken to make any
unbonded port pins an output to reduce them from being floating inputs.
Addr.
Register Name
Read:
Port A Data Register
(PTA) Write:
See page 132.
Reset:
$0000
Read:
Port B Data Register
(PTB) Write:
See page 134.
Reset:
$0001
Read:
Port C Data Register
(PTC) Write:
See page 136.
Reset:
$0002
Read:
Port D Data Register
(PTD) Write:
See page 138.
Reset:
$0003
$0004
Read:
Data Direction Register A
(DDRA) Write:
See page 132.
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
PTA7
PTA6
PTA5
PTA4
PTA3
PTA2
PTA1
PTA0
PTB2
PTB1
PTB0
PTC2
PTC1
PTC0
PTD2
PTD1
PTD0
Unaffected by reset
PTB7
PTB6
PTB5
PTB4
PTB3
Unaffected by reset
PTC6
PTC5
PTC4
PTC3
Unaffected by reset
PTD7
PTD6
PTD5
PTD4
PTD3
Unaffected by reset
DDRA7
DDRA6
DDRA5
DDRA4
DDRA3
DDRA2
DDRA1
DDRA0
= Unimplemented
Figure 12-1. I/O Port Register Summary
MOTOROLA
Data Sheet
129
Addr.
Register Name
$0007
$000F
4
3
2
1
Bit 0
DDRB7
DDRB6
DDRB5
DDRB4
DDRB3
DDRB2
DDRB1
DDRB0
DDRC6
DDRC5
DDRC4
DDRC3
DDRC2
DDRC1
DDRC0
DDRD7
DDRD6
DDRD5
DDRD4
DDRD3
DDRD2
DDRD1
DDRD0
Read:
Port E Data Register
(PTE) Write:
See page 141.
Reset:
PTE5
PTE4
PTE3
PTE2
PTE1
PTE0
Read:
Data Direction Register E
(DDRE) Write:
See page 142.
Reset:
Read:
Data Direction Register D
(DDRD) Write:
See page 139.
Reset:
$000C
$000E
5
Read:
Data Direction Register C
(DDRC) Write:
See page 136.
Reset:
$0008
$000D
6
Read:
Data Direction Register B
(DDRB) Write:
See page 135.
Reset:
$0005
$0006
Bit 7
Unaffected by reset
Read:
Port A Input Pullup Enable
PTAPUE7
Register (PTAPUE) Write:
See page 134.
Reset:
Read:
Port C Input Pullup Enable
Register (PTCPUE) Write:
See page 138.
Reset:
DDRE5
DDRE4
DDRE3
DDRE2
DDRE1
DDRE0
PTAPUE6
PTAPUE5
PTAPUE4
PTAPUE3
PTAPUE2
PTAPUE1
PTAPUE0
PTCPUE6
PTCPUE5
PTCPUE4
PTCPUE3
PTCPUE2
PTCPUE1
PTCPUE0
PTDPUE6
PTDPUE5
PTDPUE4
PTDPUE3
PTDPUE2
PTDPUE1
PTDPUE0
Read:
Port D Input Pullup Enable
PTDPUE7
Register (PTDPUE) Write:
See page 141.
Reset:
= Unimplemented
Figure 12-1. I/O Port Register Summary (Continued)
Data Sheet
130
MOTOROLA
Introduction
Table 12-1. Port Control Register Bits Summary
Port
A
B
C
D
E
Bit
DDR
Module Control
DDRA0
KBIE0
PTA0/KBD0
1
DDRA1
KBIE1
PTA1/KBD1
2
DDRA2
KBIE2
PTA2/KBD2
3
DDRA3
KBIE3
PTA3/KBD3
4
DDRA4
KBIE4
PTA4/KBD4
5
DDRA5
KBIE5
PTA5/KBD5
6
DDRA6
KBIE6
PTA6/KBD6
7
DDRA7
KBIE7
PTA7/KBD7
DDRB0
PTB0/AD0
1
DDRB1
PTB1/AD1
2
DDRB2
PTB2/AD2
3
DDRB3
4
DDRB4
5
DDRB5
PTB5/AD5
6
DDRB6
PTB6/AD6
7
DDRB7
PTB7/AD7
DDRC0
PTC0
1
DDRC1
PTC1
2
DDRC2
PTC2
3
DDRC3
PTC3
4
DDRC4
PTC4
5
DDRC5
PTC5
6
DDRC6
PTC6
DDRD0
PTD0/SS
1
DDRD1
2
DDRD2
3
DDRD3
4
DDRD4
5
DDRD5
6
DDRD6
7
DDRD7
DDRE0
1
DDRE1
2
DDRE2
PTE2
3
DDRE3
PTE3
4
DDRE4
PTE4
5
DDRE5
PTE5
KBD
ADC
SPI
SPE
PTB3/AD3
PTB4/AD4
PTD1/MISO
PTD2/MOSI
PTD3/SPSCK
TIM1
TIM2
SCI
MOTOROLA
ADCH4–ADCH0
Pin
ELS0B:ELS0A
PTD4/T1CH0
ELS1B:ELS1A
PTD5/T1CH1
ELS0B:ELS0A
PTD6/T2CH0
ELS1B:ELS1A
PTD7/T2CH1
ENSCI
PTE0/TxD
PTE1/RxD
Data Sheet
131
12.2 Port A
Port A is an 8-bit special-function port that shares all eight of its pins with the
keyboard interrupt (KBI) module. Port A also has software configurable pullup
devices if configured as an input port.
12.2.1 Port A Data Register
The port A data register (PTA) contains a data latch for each of the eight port A
pins.
Address:
Read:
Write:
$0000
Bit 7
6
5
4
3
2
1
Bit 0
PTA7
PTA6
PTA5
PTA4
PTA3
PTA2
PTA1
PTA0
KBD2
KBD1
KBD0
Reset:
Alternate
Function:
Unaffected by reset
KBD7
KBD6
KBD5
KBD4
KBD3
Figure 12-2. Port A Data Register (PTA)
PTA7–PTA0 — Port A Data Bits
These read/write bits are software programmable. Data direction of each port A
pin is under the control of the corresponding bit in data direction register A.
Reset has no effect on port A data.
KBD7–KBD0 — Keyboard Inputs
The keyboard interrupt enable bits, KBIE7–KBIE0, in the keyboard interrupt
control register (KBICR) enable the port A pins as external interrupt pins. See
Section 9. Keyboard Interrupt Module (KBI).
12.2.2 Data Direction Register A
Data direction register A (DDRA) determines whether each port A pin is an input or
an output. Writing a logic 1 to a DDRA bit enables the output buffer for the
corresponding port A pin; a logic 0 disables the output buffer.
Address:
Read:
Write:
Reset:
$0004
Bit 7
6
5
4
3
2
1
Bit 0
DDRA7
DDRA6
DDRA5
DDRA4
DDRA3
DDRA2
DDRA1
DDRA0
Figure 12-3. Data Direction Register A (DDRA)
DDRA7–DDRA0 — Data Direction Register A Bits
These read/write bits control port A data direction. Reset clears
DDRA7–DDRA0, configuring all port A pins as inputs.
1 = Corresponding port A pin configured as output
0 = Corresponding port A pin configured as input
Data Sheet
132
MOTOROLA
Port A
NOTE:
Avoid glitches on port A pins by writing to the port A data register before changing
data direction register A bits from 0 to 1.
Figure 12-4 shows the port A I/O logic.
READ DDRA ($0004)
INTERNAL DATA BUS
WRITE DDRA ($0004)
DDRAx
RESET
WRITE PTA ($0000)
PTAx
PTAx
VDD
PTAPUEx
INTERNAL
PULLUP
DEVICE
READ PTA ($0000)
Figure 12-4. Port A I/O Circuit
When bit DDRAx is a logic 1, reading address $0000 reads the PTAx data latch.
When bit DDRAx is a logic 0, reading address $0000 reads the voltage level on the
pin. The data latch can always be written, regardless of the state of its data
direction bit. Table 12-2 summarizes the operation of the port A pins.
Table 12-2. Port A Pin Functions
PTAPUE
Bit
DDRA
Bit
PTA
Bit
Accesses
to DDRA
I/O Pin
Mode
Accesses
to PTA
Read/Write
Read
Write
(1)
Input, VDD
(2)
DDRA7–DDRA0
Pin
PTA7–PTA0(3)
1
X
Input, Hi-Z(4)
DDRA7–DDRA0
Pin
PTA7–PTA0(3)
X
1
X
Output
DDRA7–DDRA0
PTA7–PTA0
PTA7–PTA0
X
1. X = Don’t care
2. I/O pin pulled up to VDD by internal pullup device
3. Writing affects data register, but does not affect input.
4. Hi-Z = High impedance
12.2.3 Port A Input Pullup Enable Register
The port A input pullup enable register (PTAPUE) contains a software configurable
pullup device for each of the eight port A pins. Each bit is individually configurable
and requires that the data direction register, DDRA, bit be configured as an input.
Each pullup is automatically and dynamically disabled when a port bit’s DDRA is
configured for output mode.
MOTOROLA
Data Sheet
133
Address:
Read:
Write:
Reset:
$000D
Bit 7
6
5
4
3
2
1
Bit 0
PTAPUE7
PTAPUE6
PTAPUE5
PTAPUE4
PTAPUE3
PTAPUE2
PTAPUE1
PTAPUE0
Figure 12-5. Port A Input Pullup Enable Register (PTAPUE)
PTAPUE7–PTAPUE0 — Port A Input Pullup Enable Bits
These writable bits are software programmable to enable pullup devices on an
input port bit.
1 = Corresponding port A pin configured to have internal pullup
0 = Corresponding port A pin has internal pullup disconnected
12.3 Port B
Port B is an 8-bit special-function port that shares six of its pins with the
analog-to-digital converter (ADC) module.
12.3.1 Port B Data Register
The port B data register (PTB) contains a data latch for each of the eight port pins.
Address:
Read:
Write:
$0001
Bit 7
6
5
4
3
2
1
Bit 0
PTB7
PTB6
PTB5
PTB4
PTB3
PTB2
PTB1
PTB0
AD2
AD1
AD0
Reset:
Alternate
Function:
Unaffected by reset
AD7
AD6
AD5
AD4
AD3
Figure 12-6. Port B Data Register (PTB)
PTB7–PTB0 — Port B Data Bits
These read/write bits are software-programmable. Data direction of each port B
pin is under the control of the corresponding bit in data direction register B.
Reset has no effect on port B data.
AD7–AD0 — Analog-to-Digital Input Bits
AD7–AD0 are pins used for the input channels to the analog-to-digital converter
module. The channel select bits in the ADC status and control register define
which port B pin will be used as an ADC input and overrides any control from
the port I/O logic by forcing that pin as the input to the analog circuitry.
NOTE:
Care must be taken when reading port B while applying analog voltages to
AD7–AD0 pins. If the appropriate ADC channel is not enabled, excessive current
drain may occur if analog voltages are applied to the PTBx/ADx pin, while PTB is
read as a digital input. Those ports not selected as analog input channels are
considered digital I/O ports.
Data Sheet
134
MC68HC908GR16 — Rev. 1.0
MOTOROLA
Port B
12.3.2 Data Direction Register B
Data direction register B (DDRB) determines whether each port B pin is an input or
an output. Writing a logic 1 to a DDRB bit enables the output buffer for the
corresponding port B pin; a logic 0 disables the output buffer.
Address:
Read:
Write:
Reset:
$0005
Bit 7
6
5
4
3
2
1
Bit 0
DDRB7
DDRB6
DDRB5
DDRB4
DDRB3
DDRB2
DDRB1
DDRB0
Figure 12-7. Data Direction Register B (DDRB)
DDRB7–DDRB0 — Data Direction Register B Bits
These read/write bits control port B data direction. Reset clears
DDRB7–DDRB0, configuring all port B pins as inputs.
1 = Corresponding port B pin configured as output
0 = Corresponding port B pin configured as input
NOTE:
Avoid glitches on port B pins by writing to the port B data register before changing
data direction register B bits from 0 to 1.
Figure 12-8 shows the port B I/O logic.
READ DDRB ($0005)
INTERNAL DATA BUS
WRITE DDRB ($0005)
RESET
DDRBx
WRITE PTB ($0001)
PTBx
PTBx
READ PTB ($0001)
Figure 12-8. Port B I/O Circuit
When bit DDRBx is a logic 1, reading address $0001 reads the PTBx data latch.
When bit DDRBx is a logic 0, reading address $0001 reads the voltage level on the
direction bit. Table 12-3 summarizes the operation of the port B pins.
MOTOROLA
Data Sheet
135
Table 12-3. Port B Pin Functions
DDRB
Bit
PTB
Bit
(1)
Input, Hi-Z
X
1
Accesses
to DDRB
I/O Pin
Mode
X
(2)
Output
Accesses
to PTB
Read/Write
Read
Write
DDRB7–DDRB0
Pin
PTB7–PTB0(3)
DDRB7–DDRB0
PTB7–PTB0
PTB7–PTB0
1. X = Don’t care
2. Hi-Z = High impedance
12.4 Port C
Port C is a 7-bit, general-purpose bidirectional I/O port. Port C also has software
configurable pullup devices if configured as an input port.
12.4.1 Port C Data Register
The port C data register (PTC) contains a data latch for each of the port C pins.
Address:
$0002
Bit 7
Read:
Write:
6
5
4
3
2
1
Bit 0
PTC6
PTC5
PTC4
PTC3
PTC2
PTC1
PTC0
Reset:
Unaffected by reset
= Unimplemented
R
= Reserved
Figure 12-9. Port C Data Register (PTC)
PTC6 and PTC0 — Port C Data Bits
These read/write bits are software-programmable. Data direction of each port C
pin is under the control of the corresponding bit in data direction register C.
Reset has no effect on port C data.
12.4.2 Data Direction Register C
Data direction register C (DDRC) determines whether each port C pin is an input
or an output. Writing a logic 1 to a DDRC bit enables the output buffer for the
corresponding port C pin; a logic 0 disables the output buffer.
Address:
$0006
Bit 7
Read:
Write:
Reset:
5
4
3
2
1
Bit 0
DDRC6
DDRC5
DDRC4
DDRC3
DDRC2
DDRC1
DDRC0
= Unimplemented
Figure 12-10. Data Direction Register C (DDRC)
Data Sheet
136
MOTOROLA
Port C
DDRC6 and DDRC0 — Data Direction Register C Bits
These read/write bits control port C data direction. Reset clears DDRC6 and
DDRC0, configuring all port C pins as inputs.
1 = Corresponding port C pin configured as output
0 = Corresponding port C pin configured as input
NOTE:
Avoid glitches on port C pins by writing to the port C data register before changing
data direction register C bits from 0 to 1.
Figure 12-11 shows the port C I/O logic.
READ DDRC ($0006)
INTERNAL DATA BUS
WRITE DDRC ($0006)
DDRCx
RESET
WRITE PTC ($0002)
PTCx
PTCx
VDD
PTCPUEx
INTERNAL
PULLUP
DEVICE
READ PTC ($0002)
Figure 12-11. Port C I/O Circuit
When bit DDRCx is a logic 1, reading address $0002 reads the PTCx data latch.
When bit DDRCx is a logic 0, reading address $0002 reads the voltage level on the
direction bit. Table 12-4 summarizes the operation of the port C pins.
Table 12-4. Port C Pin Functions
PTCPUE
Bit
DDRC
Bit
PTC
Bit
Accesses
to DDRC
I/O Pin
Mode
Accesses
to PTC
Read/Write
Read
Write
(2)
DDRC6–DDRC0
Pin
PTC6–PTC0(3)
1
X(1)
X
Input, Hi-Z(4)
DDRC6–DDRC0
Pin
PTC6–PTC0(3)
X
1
X
Output
DDRC6–DDRC0
PTC6–PTC0
PTC6–PTC0
Input, VDD
1. X = Don’t care
2. I/O pin pulled up to VDD by internal pullup device.
MOTOROLA
Data Sheet
137
12.4.3 Port C Input Pullup Enable Register
The port C input pullup enable register (PTCPUE) contains a software configurable
pullup device for each of the port C pins. Each bit is individually configurable and
requires that the data direction register, DDRC, bit be configured as an input. Each
pullup is automatically and dynamically disabled when a port bit’s DDRC is
Address:
$000E
Bit 7
Read:
Write:
Reset:
5
4
3
2
1
Bit 0
PTCPUE6
PTCPUE5
PTCPUE4
PTCPUE3
PTCPUE2
PTCPUE1
PTCPUE0
= Unimplemented
Figure 12-12. Port C Input Pullup Enable Register (PTCPUE)
PTCPUE1 and PTCPUE0 — Port C Input Pullup Enable Bits
input port bit.
1 = Corresponding port C pin configured to have internal pullup
0 = Corresponding port C pin internal pullup disconnected
12.5 Port D
Port D is an 8-bit special-function port that shares four of its pins with the serial
peripheral interface (SPI) module and three of its pins with two timer interface
(TIM1 and TIM2) modules. Port D also has software configurable pullup devices if
12.5.1 Port D Data Register
The port D data register (PTD) contains a data latch for each of the eight port D
pins.
Address:
Read:
Write:
$0003
Bit 7
6
5
4
3
2
1
Bit 0
PTD7
PTD6
PTD5
PTD4
PTD3
PTD2
PTD1
PTD0
MOSI
MISO
SS
Reset:
Alternate
Function:
Unaffected by reset
T2CH1
T2CH0
T1CH1
T1CH0
SPSCK
Figure 12-13. Port D Data Register (PTD)
PTD7–PTD0 — Port D Data Bits
These read/write bits are software-programmable. Data direction of each port D
pin is under the control of the corresponding bit in data direction register D.
Reset has no effect on port D data.
Data Sheet
138
MOTOROLA
Port D
T2CH1 and T2CH0 — Timer 2 Channel I/O Bits
The PTD6/T2CH0–PTD7/T2CH1 pins are the TIM2 input capture/output
compare pins. The edge/level select bits, ELSxB and ELSxA, determine
whether the PTD6/T2CH0–PTD7/T2CH1 pins are timer channel I/O pins or
general-purpose I/O pin. See Section 18. Timer Interface Module (TIM).
T1CH1 and T1CH0 — Timer 1 Channel I/O Bits
The PTD4/T1CH0–PTD5/T1CH1 pins are the TIM1 input capture/output
whether the PTD4/T1CH0–PTD5/T1CH1 pins are timer channel I/O pins or
general-purpose I/O pins. See Section 18. Timer Interface Module (TIM).
SPSCK — SPI Serial Clock
The PTD3/SPSCK pin is the serial clock input of the SPI module. When the SPE
bit is clear, the PTD3/SPSCK pin is available for general-purpose I/O.
MOSI — Master Out/Slave In
The PTD2/MOSI pin is the master out/slave in terminal of the SPI module. When
the SPE bit is clear, the PTD2/MOSI pin is available for general-purpose I/O.
MISO — Master In/Slave Out
The PTD1/MISO pin is the master in/slave out terminal of the SPI module. When
the SPI enable bit, SPE, is clear, the SPI module is disabled, and the PTD0/SS
Data direction register D (DDRD) does not affect the data direction of port D pins
that are being used by the SPI module. However, the DDRD bits always
determine whether reading port D returns the states of the latches or the states
of the pins. See Table 12-5.
SS — Slave Select
The PTD0/SS pin is the slave select input of the SPI module. When the SPE bit
is clear, or when the SPI master bit, SPMSTR, is set, the PTD0/SS pin is
available for general-purpose I/O. When the SPI is enabled, the DDRB0 bit in
data direction register B (DDRB) has no effect on the PTD0/SS pin.
12.5.2 Data Direction Register D
Data direction register D (DDRD) determines whether each port D pin is an input
or an output. Writing a logic 1 to a DDRD bit enables the output buffer for the
corresponding port D pin; a logic 0 disables the output buffer.
Address:
Read:
Write:
Reset:
$0007
Bit 7
6
5
4
3
2
1
Bit 0
DDRD7
DDRD6
DDRD5
DDRD4
DDRD3
DDRD2
DDRD1
DDRD0
Figure 12-14. Data Direction Register D (DDRD)
MOTOROLA
Data Sheet
139
DDRD7–DDRD0 — Data Direction Register D Bits
These read/write bits control port D data direction. Reset clears
DDRD7–DDRD0, configuring all port D pins as inputs.
1 = Corresponding port D pin configured as output
0 = Corresponding port D pin configured as input
NOTE:
Avoid glitches on port D pins by writing to the port D data register before changing
data direction register D bits from 0 to 1.
Figure 12-15 shows the port D I/O logic.
READ DDRD ($0007)
WRITE DDRD ($0007)
DDRDx
INTERNAL DATA BUS
RESET
WRITE PTD ($0003)
PTDx
PTDx
VDD
PTDPUEx
INTERNAL
PULLUP
DEVICE
READ PTD ($0003)
Figure 12-15. Port D I/O Circuit
When bit DDRDx is a logic 1, reading address $0003 reads the PTDx data latch.
When bit DDRDx is a logic 0, reading address $0003 reads the voltage level on the
direction bit. Table 12-5 summarizes the operation of the port D pins.
Table 12-5. Port D Pin Functions
PTDPUE
Bit
DDRD
Bit
PTD
Bit
Accesses
to DDRD
I/O Pin
Mode
Accesses
to PTD
Read/Write
Read
Write
(2)
DDRD7–DDRD0
Pin
PTD7–PTD0(3)
1
X(1)
X
Input, Hi-Z(4)
DDRD7–DDRD0
Pin
PTD7–PTD0(3)
X
1
X
Output
DDRD7–DDRD0
PTD7–PTD0
PTD7–PTD0
Input, VDD
1. X = Don’t care
4. Hi-Z = High imp[edance
Data Sheet
140
MOTOROLA
Port E
12.5.3 Port D Input Pullup Enable Register
The port D input pullup enable register (PTDPUE) contains a software configurable
pullup device for each of the eight port D pins. Each bit is individually configurable
and requires that the data direction register, DDRD, bit be configured as an input.
Each pullup is automatically and dynamically disabled when a port bit’s DDRD is
Address:
$000F
Read:
Write:
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
PTDPUE7
PTDPUE6
PTDPUE5
PTDPUE4
PTDPUE3
PTDPUE2
PTDPUE1
PTDPUE0
Figure 12-16. Port D Input Pullup Enable Register (PTDPUE)
PTDPUE7–PTDPUE0 — Port D Input Pullup Enable Bits
input port bit.
1 = Corresponding port D pin configured to have internal pullup
0 = Corresponding port D pin has internal pullup disconnected
12.6 Port E
Port E is a 6-bit special-function port that shares two of its pins with the enhanced
serial communications interface (ESCI) module.
12.6.1 Port E Data Register
The port E data register contains a data latch for each of the six port E pins.
Address:
Read:
Write:
$0008
Bit 7
6
4
3
2
1
Bit 0
PTE5
PTE4
PTE3
PTE2
PTE1
PTE0
RxD
TxD
Reset:
Unaffected by reset
Alternate
Function:
= Unimplemented
Figure 12-17. Port E Data Register (PTE)
PTE5–PTE0 — Port E Data Bits
These read/write bits are software-programmable. Data direction of each port E
pin is under the control of the corresponding bit in data direction register E.
Reset has no effect on port E data.
MOTOROLA
Data Sheet
141
NOTE:
Data direction register E (DDRE) does not affect the data direction of port E pins
that are being used by the ESCI module. However, the DDRE bits always
determine whether reading port E returns the states of the latches or the states of
the pins. See Table 12-6.
RxD — SCI Receive Data Input
The PTE1/RxD pin is the receive data input for the ESCI module. When the
enable SCI bit, ENSCI, is clear, the ESCI module is disabled, and the PTE1/RxD
pin is available for general-purpose I/O. See Section 14. Enhanced Serial
Communications Interface (ESCI) Module.
TxD — SCI Transmit Data Output
The PTE0/TxD pin is the transmit data output for the ESCI module. When the
enable SCI bit, ENSCI, is clear, the ESCI module is disabled, and the PTE0/TxD
12.6.2 Data Direction Register E
Data direction register E (DDRE) determines whether each port E pin is an input or
an output. Writing a logic 1 to a DDRE bit enables the output buffer for the
corresponding port E pin; a logic 0 disables the output buffer.
Address:
Read:
$000C
Bit 7
6
Write:
Reset:
5
4
3
2
1
Bit 0
DDRE5
DDRE4
DDRE3
DDRE2
DDRE1
DDRE0
= Unimplemented
Figure 12-18. Data Direction Register E (DDRE)
DDRE5–DDRE0 — Data Direction Register E Bits
These read/write bits control port E data direction. Reset clears
DDRE5–DDRE0, configuring all port E pins as inputs.
1 = Corresponding port E pin configured as output
0 = Corresponding port E pin configured as input
NOTE:
Avoid glitches on port E pins by writing to the port E data register before changing
data direction register E bits from 0 to 1.
Figure 12-19 shows the port E I/O logic.
Data Sheet
142
MOTOROLA
Port E
READ DDRE ($000C)
INTERNAL DATA BUS
WRITE DDRE ($000C)
RESET
DDREx
WRITE PTE ($0008)
PTEx
PTEx
READ PTE ($0008)
Figure 12-19. Port E I/O Circuit
When bit DDREx is a logic 1, reading address $0008 reads the PTEx data latch.
When bit DDREx is a logic 0, reading address $0008 reads the voltage level on the
direction bit. Table 12-6 summarizes the operation of the port E pins.
Table 12-6. Port E Pin Functions
DDRE
Bit
PTE
Bit
I/O Pin
Mode
X(1)
1
X
Accesses
to DDRE
Accesses
to PTE
Read/Write
Read
Write
Input, Hi-Z(2)
DDRE5–DDRE0
Pin
PTE5–PTE0(3)
Output
DDRE5–DDRE0
PTE5–PTE0
PTE5–PTE0
1. X = Don’t care
MOTOROLA
Data Sheet
143
Data Sheet
144
MOTOROLA
Section 13. Resets and Interrupts
13.1 Introduction
Resets and interrupts are responses to exceptional events during program
execution. A reset re-initializes the microcontroller (MCU) to its startup condition.
An interrupt vectors the program counter to a service routine.
13.2 Resets
A reset immediately returns the MCU to a known startup condition and begins
program execution from a user-defined memory location.
13.2.1 Effects
A reset:
Immediately stops the operation of the instruction being executed
Initializes certain control and status bits
Loads the program counter with a user-defined reset vector address from
Selects CGMXCLK divided by four as the bus clock
13.2.2 External Reset
A logic 0 applied to the RST pin for a time, tRL, generates an external reset. An
external reset sets the PIN bit in the system integration module (SIM) reset status
register.
13.2.3 Internal Reset
Sources:
Power-on reset (POR)
Low-power reset circuits
Illegal opcode
Illegal address
All internal reset sources pull the RST pin low for 32 CGMXCLK cycles to allow
resetting of external devices. The MCU is held in reset for an additional 32
CGMXCLK cycles after releasing the RST pin.
MOTOROLA
Data Sheet
145
13.2.3.1 Power-On Reset (POR)
A power-on reset (POR) is an internal reset caused by a positive transition on the
VDD pin. VDD at the POR must go below VPOR to reset the MCU. This distinguishes
between a reset and a POR. The POR is not a brown-out detector, low-voltage
detector, or glitch detector.
A power-on reset:
Holds the clocks to the central processor unit (CPU) and modules inactive
for an oscillator stabilization delay of 4096 CGMXCLK cycles
Drives the RST pin low during the oscillator stabilization delay
Releases the RST pin 32 CGMXCLK cycles after the oscillator stabilization
delay
Releases the CPU to begin the reset vector sequence 64 CGMXCLK cycles
after the oscillator stabilization delay
Sets the POR and LVI bits in the SIM reset status register and clears all
other bits in the register
OSC1
PORRST(1)
4096
CYCLES
32
CYCLES
CGMXCLK
CGMOUT
RST PIN
1. PORRST is an internally generated power-on reset pulse.
Figure 13-1. Power-On Reset Recovery
13.2.3.2 Computer Operating Properly (COP) Reset
A computer operating properly (COP) reset is an internal reset caused by an
overflow of the COP counter. A COP reset sets the COP bit in the SIM reset status
register.
To clear the COP counter and prevent a COP reset, write any value to the COP
control register at location $FFFF.
Data Sheet
146
MOTOROLA
Resets
13.2.3.3 Low-Voltage Inhibit (LVI) Reset
A low-voltage inhibit (LVI) reset is an internal reset caused by a drop in the power
supply voltage to the LVITRIPF voltage.
An LVI reset:
• Holds the clocks to the CPU and modules inactive for an oscillator
stabilization delay of 4096 CGMXCLK cycles after the power supply voltage
rises to the LVITRIPR voltage
• Drives the RST pin low for as long as VDD is below the LVITRIPR voltage and
• Releases the RST pin 32 CGMXCLK cycles after the oscillator stabilization
delay
• Releases the CPU to begin the reset vector sequence 64 CGMXCLK cycles
• Sets the LVI bit in the SIM reset status register
13.2.3.4 Illegal Opcode Reset
An illegal opcode reset is an internal reset caused by an opcode that is not in the
instruction set. An illegal opcode reset sets the ILOP bit in the SIM reset status
register.
If the stop enable bit, STOP, in the mask option register is a logic 0, the STOP
instruction causes an illegal opcode reset.
13.2.3.5 Illegal Address Reset
An illegal address reset is an internal reset caused by opcode fetch from an
unmapped address. An illegal address reset sets the ILAD bit in the SIM reset
status register.
A data fetch from an unmapped address does not generate a reset.
13.2.4 System Integration Module (SIM) Reset Status Register
This read-only register contains flags to show reset sources. All flag bits are
automatically cleared following a read of the register. Reset service can read the
SIM reset status register to clear the register after power-on reset and to determine
the source of any subsequent reset.
The register is initialized on power-up as shown with the POR bit set and all other
bits cleared. During a POR or any other internal reset, the RST pin is pulled low.
After the pin is released, it will be sampled 32 CGMXCLK cycles later. If the pin is
not above a VIH at that time, then the PIN bit in the SRSR may be set in addition to
whatever other bits are set.
NOTE:
Only a read of the SIM reset status register clears all reset flags. After multiple
resets from different sources without reading the register, multiple flags remain set.
MOTOROLA
Data Sheet
147
Address:
Read:
$FE01
Bit 7
6
5
4
3
2
1
Bit 0
POR
PIN
COP
ILOP
ILAD
MODRST
LVI
Write:
POR:
= Unimplemented
Figure 13-2. SIM Reset Status Register (SRSR)
POR — Power-On Reset Flag
1 = Power-on reset since last read of SRSR
0 = Read of SRSR since last power-on reset
PIN — External Reset Flag
1 = External reset via RST pin since last read of SRSR
0 = POR or read of SRSR since last external reset
COP — Computer Operating Properly Reset Bit
1 = Last reset caused by timeout of COP counter
0 = POR or read of SRSR since any reset
ILOP — Illegal Opcode Reset Bit
1 = Last reset caused by an illegal opcode
ILAD — Illegal Address Reset Bit
1 = Last reset caused by an opcode fetch from an illegal address
MODRST — Monitor Mode Entry Module Reset Bit
1 = Last reset caused by forced monitor mode entry.
LVI — Low-Voltage Inhibit Reset Bit
1 = Last reset caused by low-power supply voltage
Data Sheet
148
MOTOROLA
Interrupts
13.3 Interrupts
An interrupt temporarily changes the sequence of program execution to respond to
a particular event. An interrupt does not stop the operation of the instruction being
executed, but begins when the current instruction completes its operation.
13.3.1 Effects
An interrupt:
Saves the CPU registers on the stack. At the end of the interrupt, the RTI
instruction recovers the CPU registers from the stack so that normal
processing can resume.
Sets the interrupt mask (I bit) to prevent additional interrupts. Once an
interrupt is latched, no other interrupt can take precedence, regardless of its
priority.
Loads the program counter with a user-defined vector address
CONDITION CODE REGISTER
1
4
ACCUMULATOR
2
3
INDEX REGISTER (LOW BYTE)(1)
3
2
PROGRAM COUNTER (HIGH BYTE)
4
1
PROGRAM COUNTER (LOW BYTE)
5
5
STACKING
ORDER
UNSTACKING
ORDER
$00FF DEFAULT ADDRESS ON RESET
1. High byte of index register is not stacked.
Figure 13-3. Interrupt Stacking Order
MOTOROLA
Data Sheet
149
After every instruction, the CPU checks all pending interrupts if the I bit is not set.
If more than one interrupt is pending when an instruction is done, the highest
priority interrupt is serviced first. In the example shown in Figure 13-4, if an
interrupt is pending upon exit from the interrupt service routine, the pending
interrupt is serviced before the LDA instruction is executed.
CLI
BACKGROUND
ROUTINE
LDA #$FF
INT1
PSHH
INT1 INTERRUPT SERVICE ROUTINE
PULH
RTI
INT2
PSHH
INT2 INTERRUPT SERVICE ROUTINE
PULH
RTI
Figure 13-4. Interrupt Recognition Example
The LDA opcode is prefetched by both the INT1 and INT2 RTI instructions.
However, in the case of the INT1 RTI prefetch, this is a redundant operation.
NOTE:
To maintain compatibility with the M6805 Family, the H register is not pushed on
the stack during interrupt entry. If the interrupt service routine modifies the H
register or uses the indexed addressing mode, save the H register and then restore
it prior to exiting the routine.
See Figure 13-5 for a flowchart depicting interrupt processing.
13.3.2 Sources
The sources in Table 13-1 can generate CPU interrupt requests.
Data Sheet
150
MOTOROLA
Interrupts
FROM RESET
BREAK
INTERRUPT
NO
YES
YES
BITSET?
SET?
IIBIT
NO
IRQ
INTERRUPT
NO
YES
CGM
INTERRUPT
NO
YES
OTHER
INTERRUPTS
YES
NO
STACK CPU REGISTERS
SET I BIT
LOAD PC WITH INTERRUPT VECTOR
FETCH NEXT
INSTRUCTION
SWI
INSTRUCTION
YES
NO
RTI
INSTRUCTION
YES
UNSTACK CPU REGISTERS
NO
EXECUTE INSTRUCTION
Figure 13-5. Interrupt Processing
MOTOROLA
Data Sheet
151
Table 13-1. Interrupt Sources
Flag
Mask(1)
INT Register
Flag
Priority(2)
Vector
Address
Reset
None
None
None
$FFFE–$FFFF
SWI instruction
None
None
None
$FFFC–$FFFD
IRQ pin
IRQF
IMASK1
IF1
1
$FFFA–$FFFB
CGM change in lock
PLLF
PLLIE
IF2
2
$FFF8–$FFF9
TIM1 channel 0
CH0F
CH0IE
IF3
3
$FFF6–$FFF7
TIM1 channel 1
CH1F
CH1IE
IF4
4
$FFF4–$FFF5
TOF
TOIE
IF5
5
$FFF2–$FFF3
TIM2 channel 0
CH0F
CH0IE
IF6
6
$FFF0–$FFF1
TIM2 channel 1
CH1F
CH1IE
IF7
7
$FFEE–$FFEF
TOF
TOIE
IF8
8
$FFEC–$FFED
SPI receiver full
SPRF
SPRIE
SPI overflow
OVRF
ERRIE
IF9
9
$FFEA–$FFEB
SPI mode fault
MODF
ERRIE
SPI transmitter empty
SPTE
SPTIE
IF10
10
$FFE8–$FFE9
SCI receiver overrun
OR
ORIE
SCI noise flag
NF
NEIE
IF11
11
$FFE6–$FFE7
SCI framing error
FE
FEIE
SCI parity error
PE
PEIE
SCI receiver full
SCRF
SCRIE
IF12
12
$FFE4–$FFE5
SCI input idle
IDLE
ILIE
SCI transmitter empty
SCTE
SCTIE
IF13
13
$FFE2–$FFE3
TC
TCIE
Keyboard pin
KEYF
IMASKK
IF14
14
$FFE0–$FFE1
COCO
AIEN
IF15
15
$FFDE–$FFDF
TBIF
TBIE
IF16
16
$FFDC–$FFDD
Source
TIM1 overflow
TIM2 overflow
SCI transmission complete
Timebase
1. The I bit in the condition code register is a global mask for all interrupt sources except the SWI instruction.
2. 0 = highest priority
13.3.2.1 Software Interrupt (SWI) Instruction
The software interrupt (SWI) instruction causes a non-maskable interrupt.
NOTE:
A software interrupt pushes PC onto the stack. An SWI does not push PC – 1, as
a hardware interrupt does.
Data Sheet
152
MOTOROLA
Interrupts
13.3.2.2 Break Interrupt
The break module causes the CPU to execute an SWI instruction at a
software-programmable break point.
13.3.2.3 IRQ Pin
A logic 0 on the IRQ pin latches an external interrupt request.
13.3.2.4 Clock Generator (CGM)
The CGM can generate a CPU interrupt request every time the phase-locked loop
circuit (PLL) enters or leaves the locked state. When the LOCK bit changes state,
the PLL flag (PLLF) is set. The PLL interrupt enable bit (PLLIE) enables PLLF CPU
interrupt requests. LOCK is in the PLL bandwidth control register. PLLF is in the
PLL control register.
13.3.2.5 Timer Interface Module 1 (TIM1)
TIM1 CPU interrupt sources:
TIM1 overflow flag (TOF) — The TOF bit is set when the TIM1 counter value
rolls over to $0000 after matching the value in the TIM1 counter modulo
registers. The TIM1 overflow interrupt enable bit, TOIE, enables TIM1
overflow CPU interrupt requests. TOF and TOIE are in the TIM1 status and
control register.
TIM1 channel flags (CH1F–CH0F) — The CHxF bit is set when an input
capture or output compare occurs on channel x. The channel x interrupt
enable bit, CHxIE, enables channel x TIM1 CPU interrupt requests. CHxF
and CHxIE are in the TIM1 channel x status and control register.
13.3.2.6 Timer Interface Module 2 (TIM2)
TIM2 CPU interrupt sources:
TIM2 overflow flag (TOF) — The TOF bit is set when the TIM2 counter value
rolls over to $0000 after matching the value in the TIM2 counter modulo
registers. The TIM2 overflow interrupt enable bit, TOIE, enables TIM2
overflow CPU interrupt requests. TOF and TOIE are in the TIM2 status and
control register.
TIM2 channel flags (CH1F–CH0F) — The CHxF bit is set when an input
enable bit, CHxIE, enables channel x TIM2 CPU interrupt requests. CHxF
and CHxIE are in the TIM2 channel x status and control register.
MOTOROLA
Data Sheet
153
13.3.2.7 Serial Peripheral Interface (SPI)
SPI CPU interrupt sources:
SPI receiver full bit (SPRF) — The SPRF bit is set every time a byte
transfers from the shift register to the receive data register. The SPI receiver
interrupt enable bit, SPRIE, enables SPRF CPU interrupt requests. SPRF is
in the SPI status and control register and SPRIE is in the SPI control
register.
SPI transmitter empty (SPTE) — The SPTE bit is set every time a byte
transfers from the transmit data register to the shift register. The SPI
transmit interrupt enable bit, SPTIE, enables SPTE CPU interrupt requests.
SPTE is in the SPI status and control register and SPTIE is in the SPI control
register.
Mode fault bit (MODF) — The MODF bit is set in a slave SPI if the SS pin
goes high during a transmission with the mode fault enable bit (MODFEN)
set. In a master SPI, the MODF bit is set if the SS pin goes low at any time
with the MODFEN bit set. The error interrupt enable bit, ERRIE, enables
MODF CPU interrupt requests. MODF, MODFEN, and ERRIE are in the SPI
Overflow bit (OVRF) — The OVRF bit is set if software does not read the
byte in the receive data register before the next full byte enters the shift
register. The error interrupt enable bit, ERRIE, enables OVRF CPU interrupt
requests. OVRF and ERRIE are in the SPI status and control register.
13.3.2.8 Serial Communications Interface (SCI)
SCI CPU interrupt sources:
SCI transmitter empty bit (SCTE) — SCTE is set when the SCI data register
transfers a character to the transmit shift register. The SCI transmit interrupt
enable bit, SCTIE, enables transmitter CPU interrupt requests. SCTE is in
SCI status register 1. SCTIE is in SCI control register 2.
Transmission complete bit (TC) — TC is set when the transmit shift register
and the SCI data register are empty and no break or idle character has been
generated. The transmission complete interrupt enable bit, TCIE, enables
transmitter CPU interrupt requests. TC is in SCI status register 1. TCIE is in
SCI receiver full bit (SCRF) — SCRF is set when the receive shift register
transfers a character to the SCI data register. The SCI receive interrupt
enable bit, SCRIE, enables receiver CPU interrupts. SCRF is in SCI status
register 1. SCRIE is in SCI control register 2.
Idle input bit (IDLE) — IDLE is set when 10 or 11 consecutive logic 1s shift
in from the RxD pin. The idle line interrupt enable bit, ILIE, enables IDLE
CPU interrupt requests. IDLE is in SCI status register 1. ILIE is in SCI control
register 2.
Data Sheet
154
MOTOROLA
Interrupts
Receiver overrun bit (OR) — OR is set when the receive shift register shifts
in a new character before the previous character was read from the SCI data
register. The overrun interrupt enable bit, ORIE, enables OR to generate
SCI error CPU interrupt requests. OR is in SCI status register 1. ORIE is in
SCI control register 3.
Noise flag (NF) — NF is set when the SCI detects noise on incoming data
or break characters, including start, data, and stop bits. The noise error
interrupt enable bit, NEIE, enables NF to generate SCI error CPU interrupt
requests. NF is in SCI status register 1. NEIE is in SCI control register 3.
Framing error bit (FE) — FE is set when a logic 0 occurs where the receiver
expects a stop bit. The framing error interrupt enable bit, FEIE, enables FE
to generate SCI error CPU interrupt requests. FE is in SCI status register 1.
FEIE is in SCI control register 3.
Parity error bit (PE) — PE is set when the SCI detects a parity error in
incoming data. The parity error interrupt enable bit, PEIE, enables PE to
generate SCI error CPU interrupt requests. PE is in SCI status register 1.
PEIE is in SCI control register 3.
13.3.2.9 KBD0–KBD7 Pins
A logic 0 on a keyboard interrupt pin latches an external interrupt request.
13.3.2.10 Analog-to-Digital Converter (ADC)
When the AIEN bit is set, the ADC module is capable of generating a CPU interrupt
after each ADC conversion. The COCO bit is not used as a conversion complete
flag when interrupts are enabled.
13.3.2.11 Timebase Module (TBM)
The timebase module can interrupt the CPU on a regular basis with a rate defined
by TBR2–TBR0. When the timebase counter chain rolls over, the TBIF flag is set.
If the TBIE bit is set, enabling the timebase interrupt, the counter chain overflow will
generate a CPU interrupt request.
Interrupts must be acknowledged by writing a logic 1 to the TACK bit.
13.3.3 Interrupt Status Registers
The flags in the interrupt status registers identify maskable interrupt sources.
Table 13-2 summarizes the interrupt sources and the interrupt status register flags
that they set. The interrupt status registers can be useful for debugging.
MOTOROLA
Data Sheet
155
Table 13-2. Interrupt Source Flags
Interrupt
Source
Interrupt Status
Register Flag
Reset
SWI instruction
IRQ pin
IF1
CGM change of lock
IF2
TIM1 channel 0
IF3
TIM1 channel 1
IF4
TIM1 overflow
IF5
TIM2 channel 0
IF6
Reserved
IF7
TIM2 overflow
IF8
SPI receive
IF9
SPI transmit
IF10
SCI error
IF11
SCI receive
IF12
SCI transmit
IF13
Keyboard
IF14
IF15
Timebase
IF16
13.3.3.1 Interrupt Status Register 1
Address:
$FE04
Bit 7
6
5
4
3
2
1
Bit 0
Read:
IF6
IF5
IF4
IF3
IF2
IF1
Write:
R
R
R
R
R
R
R
R
Reset:
R
= Reserved
Figure 13-6. Interrupt Status Register 1 (INT1)
IF6–IF1 — Interrupt Flags 6–1
These flags indicate the presence of interrupt requests from the sources shown
in Table 13-2.
1 = Interrupt request present
0 = No interrupt request present
Bit 1 and Bit 0 — Always read 0
Data Sheet
156
MOTOROLA
Interrupts
13.3.3.2 Interrupt Status Register 2
Address:
$FE05
Bit 7
6
5
4
3
2
1
Bit 0
Read:
IF14
IF13
IF12
IF11
IF10
IF9
IF8
IF7
Write:
R
R
R
R
R
R
R
R
Reset:
R
= Reserved
Figure 13-7. Interrupt Status Register 2 (INT2)
IF14–IF7 — Interrupt Flags 14–7
in Table 13-2.
13.3.3.3 Interrupt Status Register 3
Address:
$FE06
Bit 7
6
5
4
3
2
1
Bit 0
Read:
IF20
IF19
IF18
IF17
IF16
IF15
Write:
R
R
R
R
R
R
R
R
Reset:
R
= Reserved
Figure 13-8. Interrupt Status Register 3 (INT3)
IF20–IF15 — Interrupt Flags 20–15
This flag indicates the presence of an interrupt request from the source shown
in Table 13-2.
Bits 7–6 — Always read 0
MOTOROLA
Data Sheet
157
Data Sheet
158
MOTOROLA
Section 14. Enhanced Serial Communications Interface (ESCI) Module
14.1 Introduction
The enhanced serial communications interface (ESCI) module allows
asynchronous communications with peripheral devices and other microcontroller
units (MCU).
14.2 Features
Features include:
Full-duplex operation
Standard mark/space non-return-to-zero (NRZ) format
Programmable baud rates
Programmable 8-bit or 9-bit character length
Separately enabled transmitter and receiver
Separate receiver and transmitter central processor unit (CPU) interrupt
requests
Programmable transmitter output polarity
Two receiver wakeup methods:
– Idle line wakeup
– address mark wakeup
Interrupt-driven operation with eight interrupt flags:
– Transmitter empty
– Transmission complete
– Receiver full
– Idle receiver input
– Receiver overrun
– Noise error
– Framing error
– Parity error
Receiver framing error detection
Hardware parity checking
1/16 bit-time noise detection
MOTOROLA
Data Sheet
159
USER RAM — 1024 BYTES
DDRA
PORTA
PORTB
PTB7/AD7
PTB6/AD6
PTB5/AD5
PTB4/AD4
PTB3/AD3
PTB2/AD2
PTB1/AD1
PTB0/AD0
PTC6(1)
PTC5(1)
PTC4(1), (2)
PTC3(1), (2)
PTC2(1), (2)
PTC1(1), (2)
PTC0(1), (2)
PTD7/T2CH1(1)
PTD6/T2CH0(1)
PTD5/T1CH1(1)
PTD4/T1CH0(1)
PTD3/SPSCK(1)
PTD2/MOSI(1)
PTD1/MISO(1)
PTD0/SS(1)
PTE5–PTE2
PTE1/RxD
PTE0/TxD
SINGLE BREAKPOINT
BREAK MODULE
DUAL VOLTAGE
LOW-VOLTAGE INHIBIT
MODULE
DDRB
USER FLASH — 15,872 BYTES
8-BIT KEYBOARD
INTERRUPT MODULE
MONITOR ROM — 350 BYTES
CLOCK GENERATOR MODULE
OSC1
OSC2
32–100 kHz OSCILLATOR
ENHANCED SERIAL
COMUNICATIONS
INTERFACE MODULE
PHASE LOCKED LOOP
COMPUTER OPERATING
PROPERLY MODULE
RST(3)
SYSTEM INTEGRATION
MODULE
SERIAL PERIPHERAL
INTERFACE MODULE
IRQ(3)
SINGLE EXTERNAL
INTERRUPT MODULE
MONITOR MODULE
10-BIT ANALOG-TO-DIGITAL
CONVERTER MODULE
DATA BUS SWITCH
MODULE
POWER-ON RESET
MODULE
MEMORY MAP
MODULE
POWER
CONFIGURATION
REGISTER 1–2
MODULE
CGMXFC
VDDAD/VREFH
VDDAD/VREFL
MOTOROLA
VDD
VSS
VDDA
VSSA
DDRC
2-CHANNEL TIMER
INTERFACE MODULE 2
DDRD
USER FLASH VECTOR SPACE — 44 BYTES
2-CHANNEL TIMER
INTERFACE MODULE 1
DDRE
FLASH PROGRAMMING ROUTINES ROM — 406 BYTES
PTA7/KBD7–PTA0/KBD0(1)
PORTC
CONTROL AND STATUS REGISTERS — 64 BYTES
PROGRAMMABLE TIMEBASE
MODULE
PORTD
ARITHMETIC/LOGIC
UNIT (ALU)
PORTE
CPU
REGISTERS
SECURITY
MODULE
MONITOR MODE ENTRY
MODULE
1. Ports are software configurable with pullup device if input port.
2. Higher current drive port pins
3. Pin contains integrated pullup device
Figure 14-1. Block Diagram Highlighting ESCI Block and Pins
Data Sheet
160
INTERNAL BUS
M68HC08 CPU
Pin Name Conventions
14.3 Pin Name Conventions
The generic names of the ESCI input/output (I/O) pins are:
RxD (receive data)
TxD (transmit data)
ESCI I/O lines are implemented by sharing parallel I/O port pins. The full name of
an ESCI input or output reflects the name of the shared port pin. Table 14-1 shows
the full names and the generic names of the ESCI I/O pins. The generic pin names
appear in the text of this section.
Table 14-1. Pin Name Conventions
Generic Pin Names
Full Pin Names
RxD
TxD
PTE1/RxD
PTE0/TxD
14.4 Functional Description
Figure 14-2 shows the structure of the ESCI module. The ESCI allows full-duplex,
asynchronous, NRZ serial communication between the MCU and remote devices,
including other MCUs. The transmitter and receiver of the ESCI operate
independently, although they use the same baud rate generator. During normal
operation, the CPU monitors the status of the ESCI, writes the data to be
transmitted, and processes received data.
The baud rate clock source for the ESCI can be selected via the configuration bit,
SCIBDSRC, of the CONFIG2 register ($001E).
For reference, a summary of the ESCI module input/output registers is provided in
Figure 14-3.
MOTOROLA
Data Sheet
161
INTERNAL BUS
ERROR
INTERRUPT
CONTROL
RECEIVE
SHIFT REGISTER
RxD
ESCI DATA
REGISTER
RECEIVER
INTERRUPT
CONTROL
TRANSMITTER
INTERRUPT
CONTROL
ESCI DATA
REGISTER
RxD
SCI_TxD
TRANSMIT
SHIFT REGISTER
TXINV
LINR
SCTIE
ARBITER-
BUS_CLK
R8
TCIE
TxD
SL
T8
SCRIE
ILIE
ACLK BIT IN SCIACTL
TE
TC
RWU
SBK
SCRF
OR
ORIE
IDLE
NF
NEIE
FE
FEIE
PE
PEIE
SCI_CLK
SCTE
RE
LOOPS
LOOPS
BUS CLOCK
CGMXCLK
ENHANCED
PRESCALER
WAKEUP
CONTROL
ENSCI
TRANSMIT
CONTROL
FLAG
CONTROL
BKF
M
RPF
WAKE
LINT
ILTY
÷4
PRESCALER
ESCIBDSRC
FROM
CONFIG2
SL
RECEIVE
CONTROL
ENSCI
BAUD RATE
GENERATOR
÷ 16
PEN
PTY
DATA SELECTION
CONTROL
SL=1 -> SCI_CLK = BUSCLK
SL=0 -> SCI_CLK = CGMXCLK (4x BUSCLK)
Figure 14-2. ESCI Module Block Diagram
Data Sheet
162
MOTOROLA
Addr.
$0009
Register Name
Read:
ESCI Prescaler Register
(SCPSC) Write:
See page 187.
Reset:
Read:
ESCI Arbiter Control
Register (SCIACTL) Write:
See page 191.
Reset:
$000A
Read:
ESCI Arbiter Data
Register (SCIADAT) Write:
See page 192.
Reset:
$000B
$0013
$0014
$0015
Read:
ESCI Control Register 1
(SCC1) Write:
See page 176.
Reset:
Read:
ESCI Control Register 2
(SCC2) Write:
See page 178.
Reset:
6
5
4
3
2
1
Bit 0
PDS2
PDS1
PDS0
PSSB4
PSSB3
PSSB2
PSSB1
PSSB0
AFIN
ARUN
AROVFL
ARD8
AM0
ACLK
ALOST
AM1
ARD7
ARD6
ARD5
ARD4
ARD3
ARD2
ARD1
ARD0
LOOPS
ENSCI
TXINV
M
WAKE
ILTY
PEN
PTY
SCTIE
TCIE
SCRIE
ILIE
TE
RE
RWU
SBK
T8
R
R
ORIE
NEIE
FEIE
PEIE
Read:
ESCI Control Register 3
(SCC3) Write:
See page 180.
Reset:
R8
U
Read:
ESCI Status Register 1
(SCS1) Write:
See page 181.
Reset:
SCTE
TC
SCRF
IDLE
OR
NF
FE
PE
1
1
Read:
ESCI Status Register 2
(SCS2) Write:
See page 184.
Reset:
BKF
RPF
Read:
ESCI Data Register
(SCDR) Write:
See page 185.
Reset:
R7
R6
R5
R4
R3
R2
R1
R0
T7
T6
T5
T4
T3
T2
T1
T0
$0016
$0017
$0018
$0019
Bit 7
Read:
ESCI Baud Rate Register
(SCBR) Write:
See page 185.
Reset:
Unaffected by reset
LINT
LINR
SCP1
SCP0
R
SCR2
SCR1
SCR0
R
= Reserved
= Unimplemented
Figure 14-3. ESCI I/O Register Summary
MOTOROLA
Data Sheet
163
14.4.1 Data Format
The SCI uses the standard non-return-to-zero mark/space data format illustrated
in Figure 14-4.
START
BIT
START
BIT
8-BIT DATA FORMAT
(BIT M IN SCC1 CLEAR)
BIT 0
BIT 1
BIT 2
BIT 3
BIT 4
BIT 5
BIT 6
PARITY
OR DATA
BIT
BIT 7
PARITY
OR DATA
BIT
9-BIT DATA FORMAT
(BIT M IN SCC1 SET)
BIT 0
BIT 1
BIT 2
BIT 3
BIT 4
BIT 5
STOP
BIT
BIT 6
BIT 7
BIT 8
NEXT
START
BIT
NEXT
START
BIT
STOP
BIT
Figure 14-4. SCI Data Formats
14.4.2 Transmitter
Figure 14-5 shows the structure of the SCI transmitter and the registers are
summarized in Figure 14-3. The baud rate clock source for the ESCI can be
selected via the configuration bit, SCIBDSRC.
14.4.2.1 Character Length
The transmitter can accommodate either 8-bit or 9-bit data. The state of the M bit
in ESCI control register 1 (SCC1) determines character length. When transmitting
9-bit data, bit T8 in ESCI control register 3 (SCC3) is the ninth bit (bit 8).
14.4.2.2 Character Transmission
During an ESCI transmission, the transmit shift register shifts a character out to the
TxD pin. The ESCI data register (SCDR) is the write-only buffer between the
internal data bus and the transmit shift register.
To initiate an ESCI transmission:
1. Enable the ESCI by writing a logic 1 to the enable ESCI bit (ENSCI) in ESCI
control register 1 (SCC1).
2. Enable the transmitter by writing a logic 1 to the transmitter enable bit (TE)
in ESCI control register 2 (SCC2).
3. Clear the ESCI transmitter empty bit (SCTE) by first reading ESCI status
register 1 (SCS1) and then writing to the SCDR. For 9-bit data, also write the
T8 bit in SCC3.
4. Repeat step 3 for each subsequent transmission.
Data Sheet
164
MOTOROLA
INTERNAL BUS
BAUD
DIVIDER
÷ 16
ESCI DATA REGISTER
SCP1
11-BIT
TRANSMIT
SHIFT REGISTER
STOP
SCP0
SCR1
H
SCR2
8
7
6
5
4
3
2
START
PRESCALER
÷4
1
L
SCI_TxD
PSSB3
PTY
MSB
PARITY
GENERATION
T8
BREAK
(ALL ZEROS)
PSSB4
PEN
PREAMBLE
(ALL ONES)
PDS0
M
SHIFT ENABLE
PDS1
TXINV
LOAD FROM SCDR
PDS2
TRANSMITTER CPU INTERRUPT REQUEST
BUS CLOCK
PRESCALER
SCR0
TRANSMITTER
CONTROL LOGIC
PSSB2
PSSB1
PSSB0
SCTE
SCTE
SCTIE
TC
TCIE
SBK
LOOPS
SCTIE
ENSCI
TC
TE
TCIE
LINT
Figure 14-5. ESCI Transmitter
At the start of a transmission, transmitter control logic automatically loads the
transmit shift register with a preamble of logic 1s. After the preamble shifts out,
control logic transfers the SCDR data into the transmit shift register. A logic 0 start
bit automatically goes into the least significant bit (LSB) position of the transmit shift
register. A logic 1 stop bit goes into the most significant bit (MSB) position.
The ESCI transmitter empty bit, SCTE, in SCS1 becomes set when the SCDR
transfers a byte to the transmit shift register. The SCTE bit indicates that the SCDR
can accept new data from the internal data bus. If the ESCI transmit interrupt
enable bit, SCTIE, in SCC2 is also set, the SCTE bit generates a transmitter CPU
interrupt request.
When the transmit shift register is not transmitting a character, the TxD pin goes to
the idle condition, logic 1. If at any time software clears the ENSCI bit in ESCI
control register 1 (SCC1), the transmitter and receiver relinquish control of the
port E pins.
MOTOROLA
Data Sheet
165
14.4.2.3 Break Characters
Writing a logic 1 to the send break bit, SBK, in SCC2 loads the transmit shift
register with a break character. For TXINV = 0 (output not inverted), a transmitted
break character contains all logic 0s and has no start, stop, or parity bit. Break
character length depends on the M bit in SCC1 and the LINR bits in SCBR. As long
as SBK is at logic 1, transmitter logic continuously loads break characters into the
transmit shift register. After software clears the SBK bit, the shift register finishes
transmitting the last break character and then transmits at least one logic 1. The
automatic logic 1 at the end of a break character guarantees the recognition of the
start bit of the next character.
When LINR is cleared in SCBR, the ESCI recognizes a break character when a
start bit is followed by eight or nine logic 0 data bits and a logic 0 where the stop bit
should be, resulting in a total of 10 or 11 consecutive logic 0 data bits. When LINR
is set in SCBR, the ESCI recognizes a break character when a start bit is followed
by 9 or 10 logic 0 data bits and a logic 0 where the stop bit should be, resulting in
a total of 11 or 12 consecutive logic 0 data bits.
Receiving a break character has these effects on ESCI registers:
• Sets the framing error bit (FE) in SCS1
• Sets the ESCI receiver full bit (SCRF) in SCS1
• Clears the ESCI data register (SCDR)
• Clears the R8 bit in SCC3
• Sets the break flag bit (BKF) in SCS2
• May set the overrun (OR), noise flag (NF), parity error (PE),
or reception in progress flag (RPF) bits
14.4.2.4 Idle Characters
For TXINV = 0 (output not inverted), a transmitted idle character contains all logic
1s and has no start, stop, or parity bit. Idle character length depends on the M bit
in SCC1. The preamble is a synchronizing idle character that begins every
transmission.
If the TE bit is cleared during a transmission, the TxD pin becomes idle after
completion of the transmission in progress. Clearing and then setting the TE bit
during a transmission queues an idle character to be sent after the character
currently being transmitted.
NOTE:
When a break sequence is followed immediately by an idle character, this SCI
design exhibits a condition in which the break character length is reduced by one
half bit time. In this instance, the break sequence will consist of a valid start bit,
eight or nine data bits (as defined by the M bit in SCC1) of logic 0 and one half data
bit length of logic 0 in the stop bit position followed immediately by the idle
character. To ensure a break character of the proper length is transmitted, always
queue up a byte of data to be transmitted while the final break sequence is in
progress.
Data Sheet
166
MOTOROLA
When queueing an idle character, return the TE bit to logic 1 before the stop bit of
the current character shifts out to the TxD pin. Setting TE after the stop bit appears
on TxD causes data previously written to the SCDR to be lost. A good time to toggle
the TE bit for a queued idle character is when the SCTE bit becomes set and just
before writing the next byte to the SCDR.
14.4.2.5 Inversion of Transmitted Output
The transmit inversion bit (TXINV) in ESCI control register 1 (SCC1) reverses
the polarity of transmitted data. All transmitted values including idle, break, start,
and stop bits, are inverted when TXINV is at logic 1. See 14.8.1 ESCI Control
Register 1.
14.4.2.6 Transmitter Interrupts
These conditions can generate CPU interrupt requests from the ESCI transmitter:
ESCI transmitter empty (SCTE) — The SCTE bit in SCS1 indicates that the
SCDR has transferred a character to the transmit shift register. SCTE can
generate a transmitter CPU interrupt request. Setting the ESCI transmit
interrupt enable bit, SCTIE, in SCC2 enables the SCTE bit to generate
Transmission complete (TC) — The TC bit in SCS1 indicates that the
transmit shift register and the SCDR are empty and that no break or idle
character has been generated. The transmission complete interrupt enable
bit, TCIE, in SCC2 enables the TC bit to generate transmitter CPU interrupt
requests.
14.4.3 Receiver
Figure 14-6 shows the structure of the ESCI receiver. The receiver I/O registers
are summarized in Figure 14-3.
14.4.3.1 Character Length
The receiver can accommodate either 8-bit or 9-bit data. The state of the M bit in
ESCI control register 1 (SCC1) determines character length. When receiving 9-bit
data, bit R8 in ESCI control register 3 (SCC3) is the ninth bit (bit 8). When receiving
8-bit data, bit R8 is a copy of the eighth bit (bit 7).
MOTOROLA
Data Sheet
167
INTERNAL BUS
SCR2
SCP0
SCR0
BUS CLOCK
DATA
RECOVERY
ALL ZEROS
BKF
PDS2
STOP
÷ 16
RxD
RPF
H
11-BIT
RECEIVE SHIFT REGISTER
8
7
6
5
4
2
1
L
PDS0
PSSB3
PSSB2
M
WAKE
ILTY
PSSB1
PEN
PSSB0
PTY
SCRF
WAKEUP
LOGIC
R8
PARITY
CHECKING
IDLE
ILIE
SCRF
SCRIE
ORIE
RWU
IDLE
ILIE
SCRIE
OR
ERROR CPU
INTERRUPT REQUEST
3
PDS1
PSSB4
CPU INTERRUPT
REQUEST
BAUD
DIVIDER
ALL ONES
PRESCALER
PRESCALER
÷4
ESCI DATA REGISTER
START
SCR1
MSB
LINR
SCP1
OR
ORIE
NF
NEIE
FE
FEIE
PE
PEIE
NF
NEIE
FE
FEIE
PE
PEIE
Figure 14-6. ESCI Receiver Block Diagram
Data Sheet
168
MOTOROLA
14.4.3.2 Character Reception
During an ESCI reception, the receive shift register shifts characters in from the
RxD pin. The ESCI data register (SCDR) is the read-only buffer between the
internal data bus and the receive shift register.
After a complete character shifts into the receive shift register, the data portion of
the character transfers to the SCDR. The ESCI receiver full bit, SCRF, in ESCI
status register 1 (SCS1) becomes set, indicating that the received byte can be
read. If the ESCI receive interrupt enable bit, SCRIE, in SCC2 is also set, the SCRF
bit generates a receiver CPU interrupt request.
14.4.3.3 Data Sampling
The receiver samples the RxD pin at the RT clock rate. The RT clock is an internal
signal with a frequency 16 times the baud rate. To adjust for baud rate mismatch,
the RT clock is resynchronized at these times (see Figure 14-7):
After every start bit
After the receiver detects a data bit change from logic 1 to logic 0 (after the
majority of data bit samples at RT8, RT9, and RT10 returns a valid logic 1
and the majority of the next RT8, RT9, and RT10 samples returns a valid
logic 0)
To locate the start bit, data recovery logic does an asynchronous search for a
logic 0 preceded by three logic 1s. When the falling edge of a possible start bit
occurs, the RT clock begins to count to 16.
START BIT
RxD
SAMPLES
START BIT
QUALIFICATION
LSB
START BIT
DATA
VERIFICATION SAMPLING
RT CLOCK
STATE
RT1
RT1
RT1
RT1
RT1
RT1
RT1
RT1
RT1
RT2
RT3
RT4
RT5
RT6
RT7
RT8
RT9
RT10
RT11
RT12
RT13
RT14
RT15
RT16
RT1
RT2
RT3
RT4
RT
CLOCK
RT CLOCK
RESET
Figure 14-7. Receiver Data Sampling
To verify the start bit and to detect noise, data recovery logic takes samples at RT3,
RT5, and RT7. Table 14-2 summarizes the results of the start bit verification
samples.
MOTOROLA
Data Sheet
169
Table 14-2. Start Bit Verification
RT3, RT5, and RT7 Samples
000
001
Yes
Yes
Noise Flag
010
011
100
101
110
111
Yes
No
Yes
No
No
No
1
If start bit verification is not successful, the RT clock is reset and a new search for
a start bit begins.
To determine the value of a data bit and to detect noise, recovery logic takes
samples at RT8, RT9, and RT10. Table 14-3 summarizes the results of the data
bit samples.
Table 14-3. Data Bit Recovery
RT8, RT9, and RT10 Samples
000
001
010
011
100
101
110
111
NOTE:
Data Bit Determination
1
1
Noise Flag
1
1
1
1
1
The RT8, RT9, and RT10 samples do not affect start bit verification. If any or all of
the RT8, RT9, and RT10 start bit samples are logic 1s following a successful start
bit verification, the noise flag (NF) is set and the receiver assumes that the bit is a
start bit.
To verify a stop bit and to detect noise, recovery logic takes samples at RT8, RT9,
and RT10. Table 14-4 summarizes the results of the stop bit samples.
Table 14-4. Stop Bit Recovery
000
001
010
011
100
101
110
111
Framing Error Flag
1
1
1
Data Sheet
170
Noise Flag
1
1
1
1
1
MOTOROLA
14.4.3.4 Framing Errors
If the data recovery logic does not detect a logic 1 where the stop bit should be in
an incoming character, it sets the framing error bit, FE, in SCS1. A break character
also sets the FE bit because a break character has no stop bit. The FE bit is set at
the same time that the SCRF bit is set.
14.4.3.5 Baud Rate Tolerance
A transmitting device may be operating at a baud rate below or above the receiver
baud rate. Accumulated bit time misalignment can cause one of the three stop bit
data samples to fall outside the actual stop bit. Then a noise error occurs. If more
than one of the samples is outside the stop bit, a framing error occurs. In most
applications, the baud rate tolerance is much more than the degree of
misalignment that is likely to occur.
As the receiver samples an incoming character, it resynchronizes the RT clock on
any valid falling edge within the character. Resynchronization within characters
corrects misalignments between transmitter bit times and receiver bit times.
Slow Data Tolerance
Figure 14-8 shows how much a slow received character can be misaligned
without causing a noise error or a framing error. The slow stop bit begins at RT8
instead of RT1 but arrives in time for the stop bit data samples at RT8, RT9, and
RT10.
MSB
STOP
RT16
RT15
RT14
RT13
RT12
RT11
RT10
RT9
RT8
RT7
RT6
RT5
RT4
RT3
RT2
RT1
RECEIVER
RT CLOCK
DATA
SAMPLES
Figure 14-8. Slow Data
For an 8-bit character, data sampling of the stop bit takes the receiver
9 bit times × 16 RT cycles + 10 RT cycles = 154 RT cycles.
With the misaligned character shown in Figure 14-8, the receiver counts 154
RT cycles at the point when the count of the transmitting device is 9 bit
times × 16 RT cycles + 3 RT cycles = 147 RT cycles.
The maximum percent difference between the receiver count and the
transmitter count of a slow 8-bit character with no errors is:
154 – 147 × 100 = 4.54%
-------------------------154
For a 9-bit character, data sampling of the stop bit takes the receiver
10 bit times × 16 RT cycles + 10 RT cycles = 170 RT cycles.
MOTOROLA
Data Sheet
171
With the misaligned character shown in Figure 14-8, the receiver counts 170
RT cycles at the point when the count of the transmitting device is 10 bit
times × 16 RT cycles + 3 RT cycles = 163 RT cycles.
transmitter count of a slow 9-bit character with no errors is:
170 – 163 × 100 = 4.12%
-------------------------170
Fast Data Tolerance
Figure 14-9 shows how much a fast received character can be misaligned
without causing a noise error or a framing error. The fast stop bit ends at RT10
instead of RT16 but is still there for the stop bit data samples at RT8, RT9, and
RT10.
STOP
IDLE OR NEXT CHARACTER
RT16
RT15
RT14
RT13
RT12
RT11
RT10
RT9
RT8
RT7
RT6
RT5
RT4
RT3
RT2
RT1
RECEIVER
RT CLOCK
DATA
SAMPLES
Figure 14-9. Fast Data
With the misaligned character shown in Figure 14-9, the receiver counts 154
10 bit times × 16 RT cycles = 160 RT cycles.
transmitter count of a fast 8-bit character with no errors is
154 – 160 × 100 = 3.90%.
With the misaligned character shown in Figure 14-9, the receiver counts 170
11 bit times × 16 RT cycles = 176 RT cycles.
transmitter count of a fast 9-bit character with no errors is:
170 – 176 × 100 = 3.53%.
Data Sheet
172
MOTOROLA
14.4.3.6 Receiver Wakeup
So that the MCU can ignore transmissions intended only for other receivers in
multiple-receiver systems, the receiver can be put into a standby state. Setting the
receiver wakeup bit, RWU, in SCC2 puts the receiver into a standby state during
which receiver interrupts are disabled.
Depending on the state of the WAKE bit in SCC1, either of two conditions on the
RxD pin can bring the receiver out of the standby state:
1. Address mark — An address mark is a logic 1 in the MSB position of a
received character. When the WAKE bit is set, an address mark wakes the
receiver from the standby state by clearing the RWU bit. The address mark
also sets the ESCI receiver full bit, SCRF. Software can then compare the
character containing the address mark to the user-defined address of the
receiver. If they are the same, the receiver remains awake and processes
the characters that follow. If they are not the same, software can set the
RWU bit and put the receiver back into the standby state.
2. Idle input line condition — When the WAKE bit is clear, an idle character on
the RxD pin wakes the receiver from the standby state by clearing the RWU
bit. The idle character that wakes the receiver does not set the receiver idle
bit, IDLE, or the ESCI receiver full bit, SCRF. The idle line type bit, ILTY,
determines whether the receiver begins counting logic 1s as idle character
bits after the start bit or after the stop bit.
NOTE:
With the WAKE bit clear, setting the RWU bit after the RxD pin has been idle will
cause the receiver to wakeup.
14.4.3.7 Receiver Interrupts
These sources can generate CPU interrupt requests from the ESCI receiver:
ESCI receiver full (SCRF) — The SCRF bit in SCS1 indicates that the
receive shift register has transferred a character to the SCDR. SCRF can
generate a receiver CPU interrupt request. Setting the ESCI receive
interrupt enable bit, SCRIE, in SCC2 enables the SCRF bit to generate
Idle input (IDLE) — The IDLE bit in SCS1 indicates that 10 or 11 consecutive
logic 1s shifted in from the RxD pin. The idle line interrupt enable bit, ILIE,
in SCC2 enables the IDLE bit to generate CPU interrupt requests.
14.4.3.8 Error Interrupts
These receiver error flags in SCS1 can generate CPU interrupt requests:
Receiver overrun (OR) — The OR bit indicates that the receive shift register
shifted in a new character before the previous character was read from the
SCDR. The previous character remains in the SCDR, and the new character
is lost. The overrun interrupt enable bit, ORIE, in SCC3 enables OR to
generate ESCI error CPU interrupt requests.
MOTOROLA
Data Sheet
173
Noise flag (NF) — The NF bit is set when the ESCI detects noise on
incoming data or break characters, including start, data, and stop bits. The
noise error interrupt enable bit, NEIE, in SCC3 enables NF to generate ESCI
Framing error (FE) — The FE bit in SCS1 is set when a logic 0 occurs where
the receiver expects a stop bit. The framing error interrupt enable bit, FEIE,
in SCC3 enables FE to generate ESCI error CPU interrupt requests.
Parity error (PE) — The PE bit in SCS1 is set when the ESCI detects a parity
error in incoming data. The parity error interrupt enable bit, PEIE, in SCC3
enables PE to generate ESCI error CPU interrupt requests.
14.5 Low-Power Modes
The WAIT and STOP instructions put the MCU in low power-consumption standby
modes.
14.5.1 Wait Mode
The ESCI module remains active in wait mode. Any enabled CPU interrupt request
from the ESCI module can bring the MCU out of wait mode.
If ESCI module functions are not required during wait mode, reduce power
consumption by disabling the module before executing the WAIT instruction.
14.5.2 Stop Mode
The ESCI module is inactive in stop mode. The STOP instruction does not affect
ESCI register states. ESCI module operation resumes after the MCU exits stop
mode.
Because the internal clock is inactive during stop mode, entering stop mode during
an ESCI transmission or reception results in invalid data.
14.6 ESCI During Break Module Interrupts
The BCFE bit in the break flag control register (SBFCR) enables software to clear
status bits during the break state. See Section 19. Development Support.
To allow software to clear status bits during a break interrupt, write a logic 1 to the
BCFE bit. If a status bit is cleared during the break state, it remains cleared when
the MCU exits the break state.
To protect status bits during the break state, write a logic 0 to the BCFE bit. With
BCFE at logic 0 (its default state), software can read and write I/O registers during
the break state without affecting status bits. Some status bits have a two-step
read/write clearing procedure. If software does the first step on such a bit before
Data Sheet
174
MOTOROLA
I/O Signals
the break, the bit cannot change during the break state as long as BCFE is at
logic 0. After the break, doing the second step clears the status bit.
14.7 I/O Signals
Port E shares two of its pins with the ESCI module. The two ESCI I/O pins are:
PTE0/TxD — transmit data
PTE1/RxD — receive data
14.7.1 PTE0/TxD (Transmit Data)
The PTE0/TxD pin is the serial data output from the ESCI transmitter. The ESCI
shares the PTE0/TxD pin with port E. When the ESCI is enabled, the PTE0/TxD
pin is an output regardless of the state of the DDRE0 bit in data direction register
E (DDRE).
14.7.2 PTE1/RxD (Receive Data)
The PTE1/RxD pin is the serial data input to the ESCI receiver. The ESCI shares
the PTE1/RxD pin with port E. When the ESCI is enabled, the PTE1/RxD pin is an
input regardless of the state of the DDRE1 bit in data direction register E (DDRE).
14.8 I/O Registers
These I/O registers control and monitor ESCI operation:
ESCI control register 1, SCC1
ESCI control register 2, SCC2
ESCI control register 3, SCC3
ESCI status register 1, SCS1
ESCI status register 2, SCS2
ESCI data register, SCDR
ESCI baud rate register, SCBR
ESCI prescaler register, SCPSC
ESCI arbiter control register, SCIACTL
ESCI arbiter data register, SCIADAT
MOTOROLA
Data Sheet
175
14.8.1 ESCI Control Register 1
ESCI control register 1 (SCC1):
Enables loop mode operation
Enables the ESCI
Controls output polarity
Controls character length
Controls ESCI wakeup method
Controls idle character detection
Enables parity function
Controls parity type
Address: $0013
Read:
Write:
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
LOOPS
ENSCI
TXINV
M
WAKE
ILTY
PEN
PTY
Figure 14-10. ESCI Control Register 1 (SCC1)
LOOPS — Loop Mode Select Bit
This read/write bit enables loop mode operation. In loop mode the RxD pin is
disconnected from the ESCI, and the transmitter output goes into the receiver
input. Both the transmitter and the receiver must be enabled to use loop mode.
Reset clears the LOOPS bit.
1 = Loop mode enabled
0 = Normal operation enabled
ENSCI — Enable ESCI Bit
This read/write bit enables the ESCI and the ESCI baud rate generator. Clearing
ENSCI sets the SCTE and TC bits in ESCI status register 1 and disables
transmitter interrupts. Reset clears the ENSCI bit.
1 = ESCI enabled
0 = ESCI disabled
TXINV — Transmit Inversion Bit
This read/write bit reverses the polarity of transmitted data. Reset clears the
TXINV bit.
1 = Transmitter output inverted
0 = Transmitter output not inverted
NOTE:
Setting the TXINV bit inverts all transmitted values including idle, break, start, and
stop bits.
Data Sheet
176
MOTOROLA
I/O Registers
M — Mode (Character Length) Bit
This read/write bit determines whether ESCI characters are eight or nine bits
long (See Table 14-5).The ninth bit can serve as a receiver wakeup signal or as
a parity bit. Reset clears the M bit.
1 = 9-bit ESCI characters
0 = 8-bit ESCI characters
Table 14-5. Character Format Selection
Control Bits
Character Format
M
PEN:PTY
Start Bits
Data Bits
Parity
Stop Bits
Character Length
0 X
1
8
None
1
10 bits
1
0 X
1
9
None
1
11 bits
1
7
Even
1
10 bits
1
7
Odd
1
10 bits
1
1 0
1
8
Even
1
11 bits
1
1 1
1
8
Odd
1
11 bits
WAKE — Wakeup Condition Bit
This read/write bit determines which condition wakes up the ESCI: a logic 1
(address mark) in the MSB position of a received character or an idle condition
on the RxD pin. Reset clears the WAKE bit.
1 = Address mark wakeup
0 = Idle line wakeup
ILTY — Idle Line Type Bit
This read/write bit determines when the ESCI starts counting logic 1s as idle
character bits. The counting begins either after the start bit or after the stop bit.
If the count begins after the start bit, then a string of logic 1s preceding the stop
bit may cause false recognition of an idle character. Beginning the count after
the stop bit avoids false idle character recognition, but requires properly
synchronized transmissions. Reset clears the ILTY bit.
1 = Idle character bit count begins after stop bit
0 = Idle character bit count begins after start bit
PEN — Parity Enable Bit
This read/write bit enables the ESCI parity function (see Table 14-5). When
enabled, the parity function inserts a parity bit in the MSB position (see Table
14-3). Reset clears the PEN bit.
1 = Parity function enabled
0 = Parity function disabled
NOTE:
PTY — Parity Bit
This read/write bit determines whether the ESCI generates and checks for odd
parity or even parity (see Table 14-5). Reset clears the PTY bit.
1 = Odd parity
0 = Even parity
Changing the PTY bit in the middle of a transmission or reception can generate a
parity error.
MOTOROLA
Data Sheet
177
14.8.2 ESCI Control Register 2
ESCI control register 2 (SCC2):
Enables these CPU interrupt requests:
– SCTE bit to generate transmitter CPU interrupt requests
– TC bit to generate transmitter CPU interrupt requests
– SCRF bit to generate receiver CPU interrupt requests
– IDLE bit to generate receiver CPU interrupt requests
Enables the transmitter
Enables the receiver
Enables ESCI wakeup
Transmits ESCI break characters
Address: $0014
Read:
Write:
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
SCTIE
TCIE
SCRIE
ILIE
TE
RE
RWU
SBK
Figure 14-11. ESCI Control Register 2 (SCC2)
SCTIE — ESCI Transmit Interrupt Enable Bit
This read/write bit enables the SCTE bit to generate ESCI transmitter CPU
interrupt requests. Setting the SCTIE bit in SCC2 enables the SCTE bit to
generate CPU interrupt requests. Reset clears the SCTIE bit.
1 = SCTE enabled to generate CPU interrupt
0 = SCTE not enabled to generate CPU interrupt
TCIE — Transmission Complete Interrupt Enable Bit
This read/write bit enables the TC bit to generate ESCI transmitter CPU
interrupt requests. Reset clears the TCIE bit.
1 = TC enabled to generate CPU interrupt requests
0 = TC not enabled to generate CPU interrupt requests
SCRIE — ESCI Receive Interrupt Enable Bit
This read/write bit enables the SCRF bit to generate ESCI receiver CPU
interrupt requests. Setting the SCRIE bit in SCC2 enables the SCRF bit to
generate CPU interrupt requests. Reset clears the SCRIE bit.
1 = SCRF enabled to generate CPU interrupt
0 = SCRF not enabled to generate CPU interrupt
ILIE — Idle Line Interrupt Enable Bit
This read/write bit enables the IDLE bit to generate ESCI receiver CPU interrupt
requests. Reset clears the ILIE bit.
1 = IDLE enabled to generate CPU interrupt requests
0 = IDLE not enabled to generate CPU interrupt requests
Data Sheet
178
MC68HC908GR16 — Rev. 1.0
MOTOROLA
I/O Registers
TE — Transmitter Enable Bit
Setting this read/write bit begins the transmission by sending a preamble of 10
or 11 logic 1s from the transmit shift register to the TxD pin. If software clears
the TE bit, the transmitter completes any transmission in progress before the
TxD returns to the idle condition (logic 1). Clearing and then setting TE during a
transmission queues an idle character to be sent after the character currently
being transmitted. Reset clears the TE bit.
1 = Transmitter enabled
0 = Transmitter disabled
NOTE:
Writing to the TE bit is not allowed when the enable ESCI bit (ENSCI) is clear.
ENSCI is in ESCI control register 1.
RE — Receiver Enable Bit
Setting this read/write bit enables the receiver. Clearing the RE bit disables the
receiver but does not affect receiver interrupt flag bits. Reset clears the RE bit.
1 = Receiver enabled
0 = Receiver disabled
NOTE:
Writing to the RE bit is not allowed when the enable ESCI bit (ENSCI) is clear.
RWU — Receiver Wakeup Bit
This read/write bit puts the receiver in a standby state during which receiver
interrupts are disabled. The WAKE bit in SCC1 determines whether an idle input
or an address mark brings the receiver out of the standby state and clears the
RWU bit. Reset clears the RWU bit.
1 = Standby state
SBK — Send Break Bit
Setting and then clearing this read/write bit transmits a break character followed
by a logic 1. The logic 1 after the break character guarantees recognition of a
valid start bit. If SBK remains set, the transmitter continuously transmits break
characters with no logic 1s between them. Reset clears the SBK bit.
1 = Transmit break characters
0 = No break characters being transmitted
NOTE:
Do not toggle the SBK bit immediately after setting the SCTE bit. Toggling SBK
before the preamble begins causes the ESCI to send a break character instead of
a preamble.
MOTOROLA
Data Sheet
179
14.8.3 ESCI Control Register 3
ESCI control register 3 (SCC3):
Stores the ninth ESCI data bit received and the ninth ESCI data bit to be
transmitted.
Enables these interrupts:
– Receiver overrun
– Noise error
– Framing error
– Parity error
Address:
$0015
Bit 7
Read:
R8
Write:
Reset:
U
6
5
4
3
2
1
Bit 0
T8
R
R
ORIE
NEIE
FEIE
PEIE
R
= Reserved
= Unimplemented
U = Unaffected
Figure 14-12. ESCI Control Register 3 (SCC3)
R8 — Received Bit 8
When the ESCI is receiving 9-bit characters, R8 is the read-only ninth bit (bit 8)
of the received character. R8 is received at the same time that the SCDR
receives the other 8 bits.
When the ESCI is receiving 8-bit characters, R8 is a copy of the eighth bit (bit
7). Reset has no effect on the R8 bit.
T8 — Transmitted Bit 8
When the ESCI is transmitting 9-bit characters, T8 is the read/write ninth bit
(bit 8) of the transmitted character. T8 is loaded into the transmit shift register at
the same time that the SCDR is loaded into the transmit shift register. Reset
clears the T8 bit.
ORIE — Receiver Overrun Interrupt Enable Bit
This read/write bit enables ESCI error CPU interrupt requests generated by the
receiver overrun bit, OR. Reset clears ORIE.
1 = ESCI error CPU interrupt requests from OR bit enabled
0 = ESCI error CPU interrupt requests from OR bit disabled
NEIE — Receiver Noise Error Interrupt Enable Bit
noise error bit, NE. Reset clears NEIE.
1 = ESCI error CPU interrupt requests from NE bit enabled
0 = ESCI error CPU interrupt requests from NE bit disabled
Data Sheet
180
MOTOROLA
I/O Registers
FEIE — Receiver Framing Error Interrupt Enable Bit
framing error bit, FE. Reset clears FEIE.
1 = ESCI error CPU interrupt requests from FE bit enabled
0 = ESCI error CPU interrupt requests from FE bit disabled
PEIE — Receiver Parity Error Interrupt Enable Bit
This read/write bit enables ESCI receiver CPU interrupt requests generated by
the parity error bit, PE. Reset clears PEIE.
1 = ESCI error CPU interrupt requests from PE bit enabled
0 = ESCI error CPU interrupt requests from PE bit disabled
14.8.4 ESCI Status Register 1
ESCI status register 1 (SCS1) contains flags to signal these conditions:
Transfer of SCDR data to transmit shift register complete
Transfer of receive shift register data to SCDR complete
Receiver input idle
Receiver overrun
Noisy data
Framing error
Parity error
Address:
Read:
$0016
Bit 7
6
5
4
3
2
1
Bit 0
SCTE
TC
SCRF
IDLE
OR
NF
FE
PE
1
1
Write:
Reset:
= Unimplemented
Figure 14-13. ESCI Status Register 1 (SCS1)
SCTE — ESCI Transmitter Empty Bit
This clearable, read-only bit is set when the SCDR transfers a character to the
transmit shift register. SCTE can generate an ESCI transmitter CPU interrupt
request. When the SCTIE bit in SCC2 is set, SCTE generates an ESCI
transmitter CPU interrupt request. In normal operation, clear the SCTE bit by
reading SCS1 with SCTE set and then writing to SCDR. Reset sets the SCTE
bit.
1 = SCDR data transferred to transmit shift register
0 = SCDR data not transferred to transmit shift register
MOTOROLA
Data Sheet
181
TC — Transmission Complete Bit
This read-only bit is set when the SCTE bit is set, and no data, preamble, or
break character is being transmitted. TC generates an ESCI transmitter CPU
interrupt request if the TCIE bit in SCC2 is also set. TC is cleared automatically
when data, preamble, or break is queued and ready to be sent. There may be
up to 1.5 transmitter clocks of latency between queueing data, preamble, and
break and the transmission actually starting. Reset sets the TC bit.
1 = No transmission in progress
0 = Transmission in progress
SCRF — ESCI Receiver Full Bit
This clearable, read-only bit is set when the data in the receive shift register
transfers to the ESCI data register. SCRF can generate an ESCI receiver CPU
interrupt request. When the SCRIE bit in SCC2 is set the SCRF generates a
CPU interrupt request. In normal operation, clear the SCRF bit by reading SCS1
with SCRF set and then reading the SCDR. Reset clears SCRF.
1 = Received data available in SCDR
0 = Data not available in SCDR
IDLE — Receiver Idle Bit
This clearable, read-only bit is set when 10 or 11 consecutive logic 1s appear
on the receiver input. IDLE generates an ESCI receiver CPU interrupt request
if the ILIE bit in SCC2 is also set. Clear the IDLE bit by reading SCS1 with IDLE
set and then reading the SCDR. After the receiver is enabled, it must receive a
valid character that sets the SCRF bit before an idle condition can set the IDLE
bit. Also, after the IDLE bit has been cleared, a valid character must again set
the SCRF bit before an idle condition can set the IDLE bit. Reset clears the
IDLE bit.
1 = Receiver input idle
0 = Receiver input active (or idle since the IDLE bit was cleared)
OR — Receiver Overrun Bit
This clearable, read-only bit is set when software fails to read the SCDR before
the receive shift register receives the next character. The OR bit generates an
ESCI error CPU interrupt request if the ORIE bit in SCC3 is also set. The data
in the shift register is lost, but the data already in the SCDR is not affected. Clear
the OR bit by reading SCS1 with OR set and then reading the SCDR. Reset
clears the OR bit.
1 = Receive shift register full and SCRF = 1
0 = No receiver overrun
Software latency may allow an overrun to occur between reads of SCS1 and
SCDR in the flag-clearing sequence. Figure 14-14 shows the normal
flag-clearing sequence and an example of an overrun caused by a delayed
flag-clearing sequence. The delayed read of SCDR does not clear the OR bit
because OR was not set when SCS1 was read. Byte 2 caused the overrun and
is lost. The next flag-clearing sequence reads byte 3 in the SCDR instead of
byte 2.
Data Sheet
182
MOTOROLA
I/O Registers
In applications that are subject to software latency or in which it is important to
know which byte is lost due to an overrun, the flag-clearing routine can check
the OR bit in a second read of SCS1 after reading the data register.
NF — Receiver Noise Flag Bit
This clearable, read-only bit is set when the ESCI detects noise on the RxD pin.
NF generates an NF CPU interrupt request if the NEIE bit in SCC3 is also set.
Clear the NF bit by reading SCS1 and then reading the SCDR. Reset clears the
NF bit.
1 = Noise detected
0 = No noise detected
BYTE 1
BYTE 2
BYTE 3
SCRF = 0
SCRF = 1
SCRF = 0
SCRF = 1
SCRF = 0
SCRF = 1
NORMAL FLAG CLEARING SEQUENCE
BYTE 4
READ SCS1
SCRF = 1
OR = 0
READ SCS1
SCRF = 1
OR = 0
READ SCS1
SCRF = 1
OR = 0
READ SCDR
BYTE 1
READ SCDR
BYTE 2
READ SCDR
BYTE 3
BYTE 1
BYTE 2
BYTE 3
SCRF = 0
OR = 0
SCRF = 1
OR = 1
SCRF = 0
OR = 1
SCRF = 1
SCRF = 1
OR = 1
DELAYED FLAG CLEARING SEQUENCE
BYTE 4
READ SCS1
SCRF = 1
OR = 0
READ SCS1
SCRF = 1
OR = 1
READ SCDR
BYTE 1
READ SCDR
BYTE 3
Figure 14-14. Flag Clearing Sequence
FE — Receiver Framing Error Bit
This clearable, read-only bit is set when a logic 0 is accepted as the stop bit. FE
generates an ESCI error CPU interrupt request if the FEIE bit in SCC3 also is
set. Clear the FE bit by reading SCS1 with FE set and then reading the SCDR.
Reset clears the FE bit.
1 = Framing error detected
0 = No framing error detected
PE — Receiver Parity Error Bit
This clearable, read-only bit is set when the ESCI detects a parity error in
incoming data. PE generates a PE CPU interrupt request if the PEIE bit in SCC3
MOTOROLA
Data Sheet
183
is also set. Clear the PE bit by reading SCS1 with PE set and then reading the
SCDR. Reset clears the PE bit.
1 = Parity error detected
0 = No parity error detected
14.8.5 ESCI Status Register 2
ESCI status register 2 (SCS2) contains flags to signal these conditions:
Break character detected
Incoming data
Address:
Read:
$0017
Bit 7
6
5
4
3
2
1
Bit 0
BKF
RPF
Write:
Reset:
= Unimplemented
Figure 14-15. ESCI Status Register 2 (SCS2)
BKF — Break Flag Bit
This clearable, read-only bit is set when the ESCI detects a break character on
the RxD pin. In SCS1, the FE and SCRF bits are also set. In 9-bit character
transmissions, the R8 bit in SCC3 is cleared. BKF does not generate a CPU
interrupt request. Clear BKF by reading SCS2 with BKF set and then reading
the SCDR. Once cleared, BKF can become set again only after logic 1s again
appear on the RxD pin followed by another break character. Reset clears the
BKF bit.
1 = Break character detected
0 = No break character detected
RPF — Reception in Progress Flag Bit
This read-only bit is set when the receiver detects a logic 0 during the RT1 time
period of the start bit search. RPF does not generate an interrupt request. RPF
is reset after the receiver detects false start bits (usually from noise or a baud
rate mismatch), or when the receiver detects an idle character. Polling RPF
before disabling the ESCI module or entering stop mode can show whether a
reception is in progress.
1 = Reception in progress
0 = No reception in progress
Data Sheet
184
MOTOROLA
I/O Registers
14.8.6 ESCI Data Register
The ESCI data register (SCDR) is the buffer between the internal data bus and the
receive and transmit shift registers. Reset has no effect on data in the ESCI data
register.
Address:
$0018
Bit 7
6
5
4
3
2
1
Bit 0
Read:
R7
R6
R5
R4
R3
R2
R1
R0
Write:
T7
T6
T5
T4
T3
T2
T1
T0
Reset:
Unaffected by reset
Figure 14-16. ESCI Data Register (SCDR)
R7/T7:R0/T0 — Receive/Transmit Data Bits
Reading address $0018 accesses the read-only received data bits, R7:R0.
Writing to address $0018 writes the data to be transmitted, T7:T0. Reset has no
effect on the ESCI data register.
NOTE:
Do not use read-modify-write instructions on the ESCI data register.
14.8.7 ESCI Baud Rate Register
The ESCI baud rate register (SCBR) together with the ESCI prescaler register
selects the baud rate for both the receiver and the transmitter.
NOTE:
There are two prescalers available to adjust the baud rate. One in the ESCI baud
rate register and one in the ESCI prescaler register.
Address:
Read:
Write:
Reset:
$0019
Bit 7
6
5
4
3
2
1
Bit 0
LINT
LINR
SCP1
SCP0
R
SCR2
SCR1
SCR0
R
= Reserved
= Unimplemented
Figure 14-17. ESCI Baud Rate Register (SCBR)
LINT — LIN Break Symbol Transmit Enable
This read/write bit selects the enhanced ESCI features for master nodes in the
local interconnect network (LIN) protocol (version 1.2) as shown in Table 14-6.
Reset clears LINT.
MOTOROLA
Data Sheet
185
Table 14-6. ESCI LIN Master Node Control Bits
NOTE:
LINT
M
Functionality
X
Normal ESCI functionality
1
13-bit generation enabled for LIN transmitter
1
1
14-bit generation enabled for LIN transmitter
LIN master nodes require significantly tighter timing tolerances than slave nodes.
Be sure to consult the current LIN specification to ensure that timing requirements
are met properly. Generally, these timing tolerances require crystals or oscillators
to be used, rather than internal clocking circuits.
LINR — LIN Break Symbol Receiver Bits
This read/write bit selects the enhanced ESCI features for slave nodes in the
local interconnect network (LIN) protocol as shown in Table 14-7. Reset clears
LINR.
Table 14-7. ESCI LIN Slave Node Control Bits
LINR
M
Functionality
X
1
11-bit break detect enabled for LIN receiver
1
1
12-bit break detect enabled for LIN receiver
In LIN (version 1.2) systems, the master node transmits a break character which
will appear as 11.05–14.95 dominant bits to the slave node. A data character of
0x00 sent from the master might appear as 7.65–10.35 dominant bit times. This
is due to the oscillator tolerance requirement that the slave node must be within
±15% of the master node's oscillator. Since a slave node cannot know if it is
running faster or slower than the master node (prior to synchronization), the
LINR bit allows the slave node to differentiate between a 0x00 character of
10.35 bits and a break character of 11.05 bits. The break symbol length must be
verified in software in any case, but the LINR bit serves as a filter, preventing
false detections of break characters that are really 0x00 data characters.
SCP1 and SCP0 — ESCI Baud Rate Register Prescaler Bits
These read/write bits select the baud rate register prescaler divisor as shown in
Table 14-8. Reset clears SCP1 and SCP0.
Table 14-8. ESCI Baud Rate Prescaling
SCP[1:0]
Baud Rate Register
Prescaler Divisor (BPD)
0 0
1
0 1
3
1 0
4
1 1
13
Data Sheet
186
MOTOROLA
I/O Registers
SCR2–SCR0 — ESCI Baud Rate Select Bits
These read/write bits select the ESCI baud rate divisor as shown in Table 14-9.
Reset clears SCR2–SCR0.
Table 14-9. ESCI Baud Rate Selection
SCR[2:1:0]
Baud Rate Divisor (BD)
0 0 0
1
0 0 1
2
0 1 0
4
0 1 1
8
1 0 0
16
1 0 1
32
1 1 0
64
1 1 1
128
14.8.8 ESCI Prescaler Register
The ESCI prescaler register (SCPSC) together with the ESCI baud rate register
NOTE:
Address:
Read:
Write:
Reset:
$0009
Bit 7
6
5
4
3
2
1
Bit 0
PDS2
PDS1
PDS0
PSSB4
PSSB3
PSSB2
PSSB1
PSSB0
Figure 14-18. ESCI Prescaler Register (SCPSC)
PDS2–PDS0 — Prescaler Divisor Select Bits
These read/write bits select the prescaler divisor as shown in
Table 14-10. Reset clears PDS2–PDS0.
NOTE:
The setting of ‘000’ will bypass this prescaler. It is not recommended to bypass the
prescaler while ENSCI is set, because the switching is not glitch free.
MOTOROLA
Data Sheet
187
Table 14-10. ESCI Prescaler Division Ratio
PS[2:1:0]
Prescaler Divisor (PD)
0 0 0
Bypass this prescaler
0 0 1
2
0 1 0
3
0 1 1
4
1 0 0
5
1 0 1
6
1 1 0
7
1 1 1
8
PSSB4–PSSB0 — Clock Insertion Select Bits
These read/write bits select the number of clocks inserted in each 32 output
cycle frame to achieve more timing resolution on the average prescaler
frequency as shown in Table 14-11. Reset clears PSSB4–PSSB0.
Use the following formula to calculate the ESCI baud rate:
SCI clock source
Baud rate = -----------------------------------------------------------------------------------64 × BPD × BD × ( PD + PDFA )
where:
SCI clock source = fBus or CGMXCLK (selected by SCIBDSRC in the
CONFIG2 register)
BPD = Baud rate register prescaler divisor
BD = Baud rate divisor
PD = Prescaler divisor
PDFA = Prescaler divisor fine adjust
Table 14-12 shows the ESCI baud rates that can be generated with a 4.9152-MHz
bus frequency.
Data Sheet
188
MOTOROLA
I/O Registers
Table 14-11. ESCI Prescaler Divisor Fine Adjust
PSSB[4:3:2:1:0]
Prescaler Divisor Fine Adjust (PDFA)
0 0 0 0 0
0/32 = 0
0 0 0 0 1
1/32 = 0.03125
0 0 0 1 0
2/32 = 0.0625
0 0 0 1 1
3/32 = 0.09375
0 0 1 0 0
4/32 = 0.125
0 0 1 0 1
5/32 = 0.15625
0 0 1 1 0
6/32 = 0.1875
0 0 1 1 1
7/32 = 0.21875
0 1 0 0 0
8/32 = 0.25
0 1 0 0 1
9/32 = 0.28125
0 1 0 1 0
10/32 = 0.3125
0 1 0 1 1
11/32 = 0.34375
0 1 1 0 0
12/32 = 0.375
0 1 1 0 1
13/32 = 0.40625
0 1 1 1 0
14/32 = 0.4375
0 1 1 1 1
15/32 = 0.46875
1 0 0 0 0
16/32 = 0.5
1 0 0 0 1
17/32 = 0.53125
1 0 0 1 0
18/32 = 0.5625
1 0 0 1 1
19/32 = 0.59375
1 0 1 0 0
20/32 = 0.625
1 0 1 0 1
21/32 = 0.65625
1 0 1 1 0
22/32 = 0.6875
1 0 1 1 1
23/32 = 0.71875
1 1 0 0 0
24/32 = 0.75
1 1 0 0 1
25/32 = 0.78125
1 1 0 1 0
26/32 = 0.8125
1 1 0 1 1
27/32 = 0.84375
1 1 1 0 0
28/32 = 0.875
1 1 1 0 1
29/32 = 0.90625
1 1 1 1 0
30/32 = 0.9375
1 1 1 1 1
31/32 = 0.96875
MOTOROLA
Data Sheet
189
Table 14-12. ESCI Baud Rate Selection Examples
PS[2:1:0]
PSSB[4:3:2:1:0]
SCP[1:0]
Prescaler
Divisor
(BPD)
SCR[2:1:0]
Baud Rate
Divisor
(BD)
Baud Rate
(fBus= 4.9152 MHz)
0 0 0
X X X X X
0 0
1
0 0 0
1
76,800
1 1 1
0 0 0 0 0
0 0
1
0 0 0
1
9600
1 1 1
0 0 0 0 1
0 0
1
0 0 0
1
9562.65
1 1 1
0 0 0 1 0
0 0
1
0 0 0
1
9525.58
1 1 1
1 1 1 1 1
0 0
1
0 0 0
1
8563.07
0 0 0
X X X X X
0 0
1
0 0 1
2
38,400
0 0 0
X X X X X
0 0
1
0 1 0
4
19,200
0 0 0
X X X X X
0 0
1
0 1 1
8
9600
0 0 0
X X X X X
0 0
1
1 0 0
16
4800
0 0 0
X X X X X
0 0
1
1 0 1
32
2400
0 0 0
X X X X X
0 0
1
1 1 0
64
1200
0 0 0
X X X X X
0 0
1
1 1 1
128
600
0 0 0
X X X X X
0 1
3
0 0 0
1
25,600
0 0 0
X X X X X
0 1
3
0 0 1
2
12,800
0 0 0
X X X X X
0 1
3
0 1 0
4
6400
0 0 0
X X X X X
0 1
3
0 1 1
8
3200
0 0 0
X X X X X
0 1
3
1 0 0
16
1600
0 0 0
X X X X X
0 1
3
1 0 1
32
800
0 0 0
X X X X X
0 1
3
1 1 0
64
400
0 0 0
X X X X X
0 1
3
1 1 1
128
200
0 0 0
X X X X X
1 0
4
0 0 0
1
19,200
0 0 0
X X X X X
1 0
4
0 0 1
2
9600
0 0 0
X X X X X
1 0
4
0 1 0
4
4800
0 0 0
X X X X X
1 0
4
0 1 1
8
2400
0 0 0
X X X X X
1 0
4
1 0 0
16
1200
0 0 0
X X X X X
1 0
4
1 0 1
32
600
0 0 0
X X X X X
1 0
4
1 1 0
64
300
0 0 0
X X X X X
1 0
4
1 1 1
128
150
0 0 0
X X X X X
1 1
13
0 0 0
1
5908
0 0 0
X X X X X
1 1
13
0 0 1
2
2954
0 0 0
X X X X X
1 1
13
0 1 0
4
1477
0 0 0
X X X X X
1 1
13
0 1 1
8
739
0 0 0
X X X X X
1 1
13
1 0 0
16
369
0 0 0
X X X X X
1 1
13
1 0 1
32
185
0 0 0
X X X X X
1 1
13
1 1 0
64
92
0 0 0
X X X X X
1 1
13
1 1 1
128
46
Data Sheet
190
MOTOROLA
ESCI Arbiter
14.9 ESCI Arbiter
The ESCI module comprises an arbiter module designed to support software for
communication tasks as bus arbitration, baud rate recovery and break time
detection. The arbiter module consists of an 9-bit counter with 1-bit overflow and
control logic. The CPU can control operation mode via the ESCI arbiter control
register (SCIACTL).
14.9.1 ESCI Arbiter Control Register
Address:
$000A
Bit 7
Read:
Write:
Reset:
AM1
6
ALOST
4
AM0
ACLK
2
1
Bit 0
AFIN
ARUN
AROVFL
ARD8
= Unimplemented
Figure 14-19. ESCI Arbiter Control Register (SCIACTL)
AM1 and AM0 — Arbiter Mode Select Bits
These read/write bits select the mode of the arbiter module as shown in Table
14-13. Reset clears AM1 and AM0.
Table 14-13. ESCI Arbiter Selectable Modes
AM[1:0]
ESCI Arbiter Mode
0 0
Idle / counter reset
0 1
Bit time measurement
1 0
Bus arbitration
1 1
Reserved / do not use
ALOST — Arbitration Lost Flag
This read-only bit indicates loss of arbitration. Clear ALOST by writing a logic 0
to AM1. Reset clears ALOST.
ACLK — Arbiter Counter Clock Select Bit
This read/write bit selects the arbiter counter clock source. Reset clears ACLK.
1 = Arbiter counter is clocked with one half of the ESCI input clock generated
by the ESCI prescaler
0 = Arbiter counter is clocked with one half of the bus clock
AFIN— Arbiter Bit Time Measurement Finish Flag
This read-only bit indicates bit time measurement has finished. Clear AFIN by
writing any value to SCIACTL. Reset clears AFIN.
1 = Bit time measurement has finished
0 = Bit time measurement not yet finished
MOTOROLA
Data Sheet
191
ARUN— Arbiter Counter Running Flag
This read-only bit indicates the arbiter counter is running. Reset clears ARUN.
1 = Arbiter counter running
0 = Arbiter counter stopped
AROVFL— Arbiter Counter Overflow Bit
This read-only bit indicates an arbiter counter overflow. Clear AROVFL by
writing any value to SCIACTL. Writing logic 0s to AM1 and AM0 resets the
counter keeps it in this idle state. Reset clears AROVFL.
1 = Arbiter counter overflow has occurred
0 = No arbiter counter overflow has occurred
ARD8— Arbiter Counter MSB
This read-only bit is the MSB of the 9-bit arbiter counter. Clear ARD8 by writing
any value to SCIACTL. Reset clears ARD8.
14.9.2 ESCI Arbiter Data Register
Address: $000B
Read:
Bit 7
6
5
4
3
2
1
Bit 0
ARD7
ARD6
ARD5
ARD4
ARD3
ARD2
ARD1
ARD0
Write:
Reset:
= Unimplemented
Figure 14-20. ESCI Arbiter Data Register (SCIADAT)
ARD7–ARD0 — Arbiter Least Significant Counter Bits
These read-only bits are the eight LSBs of the 9-bit arbiter counter. Clear
ARD7–ARD0 by writing any value to SCIACTL. Writing logic 0s to AM1 and AM0
permanently resets the counter and keeps it in this idle state. Reset clears
ARD7–ARD0.
14.9.3 Bit Time Measurement
Two bit time measurement modes, described here, are available according to the
state of ACLK.
1. ACLK = 0 — The counter is clocked with one half of the bus clock. The
counter is started when a falling edge on the RxD pin is detected. The
counter will be stopped on the next falling edge. ARUN is set while the
counter is running, AFIN is set on the second falling edge on RxD (for
instance, the counter is stopped). This mode is used to recover the received
baud rate. See Figure 14-21.
2. ACLK = 1 — The counter is clocked with one half of the ESCI input clock
generated by the ESCI prescaler. The counter is started when a logic 0 is
detected on RxD (see Figure 14-22). A logic 0 on RxD on enabling the bit
time measurement with ACLK = 1 leads to immediate start of the counter
(see Figure 14-23). The counter will be stopped on the next rising edge of
RxD. This mode is used to measure the length of a received break.
Data Sheet
192
MOTOROLA
ESCI Arbiter
MEASURED TIME
CPU READS RESULT
OUT OF SCIADAT
COUNTER STOPS,
AFIN = 1
COUNTER STARTS,
ARUN = 1
CPU WRITES SCIACTL
WITH $20
RXD
Figure 14-21. Bit Time Measurement with ACLK = 0
MEASURED TIME
CPU READS RESULT OUT
OF SCIADAT
COUNTER STOPS, AFIN = 1
CPU WRITES SCIACTL WITH $30
COUNTER STARTS, ARUN = 1
RXD
Figure 14-22. Bit Time Measurement with ACLK = 1, Scenario A
MEASURED TIME
CPU READS RESULT
OUT OF SCIADAT
COUNTER STOPS,
AFIN = 1
COUNTER STARTS,
ARUN = 1
CPU WRITES SCIACTL
WITH $30
RXD
Figure 14-23. Bit Time Measurement with ACLK = 1, Scenario B
MOTOROLA
Data Sheet
193
14.9.4 Arbitration Mode
If AM[1:0] is set to 10, the arbiter module operates in arbitration mode. On every
rising edge of SCI_TxD (output of the ESCI module, internal chip signal), the
counter is started. When the counter reaches $38 (ACLK = 0) or $08 (ACLK = 1),
RxD is statically sensed. If in this case, RxD is sensed low (for example, another
bus is driving the bus dominant) ALOST is set. As long as ALOST is set, the TxD
pin is forced to 1, resulting in a seized transmission.
If SCI_TxD is sensed logic 0 without having sensed a logic 0 before on RxD, the
counter will be reset, arbitration operation will be restarted after the next rising edge
of SCI_TxD.
Data Sheet
194
MOTOROLA
Data Sheet — MC68HC908GR16
Section 15. System Integration Module (SIM)
15.1 Introduction
This section describes the system integration module (SIM). Together with the
central processor unit (CPU), the SIM controls all microcontroller unit (MCU)
activities. A block diagram of the SIM is shown in Figure 15-2. Table 15-1 is a
summary of the SIM input/output (I/O) registers. The SIM is a system state
controller that coordinates CPU and exception timing.
The SIM is responsible for:
Bus clock generation and control for CPU and peripherals:
– Stop/wait/reset/break entry and recovery
– Internal clock control
Master reset control, including power-on reset (POR) and computer
operating properly (COP) timeout
Interrupt control:
– Acknowledge timing
– Arbitration control timing
– Vector address generation
CPU enable/disable timing
Modular architecture expandable to 128 interrupt sources
Table 15-1 shows the internal signal names used in this section.
MOTOROLA
Data Sheet
195
DDRA
PORTA
PORTB
PTB7/AD7
PTB6/AD6
PTB5/AD5
PTB4/AD4
PTB3/AD3
PTB2/AD2
PTB1/AD1
PTB0/AD0
PTC6(1)
PTC5(1)
PTC4(1), (2)
PTC3(1), (2)
PTC2(1), (2)
PTC1(1), (2)
PTC0(1), (2)
PTD7/T2CH1(1)
PTD6/T2CH0(1)
PTD5/T1CH1(1)
PTD4/T1CH0(1)
PTD3/SPSCK(1)
PTD2/MOSI(1)
PTD1/MISO(1)
PTD0/SS(1)
PTE5–PTE2
PTE1/RxD
PTE0/TxD
SINGLE BREAKPOINT
BREAK MODULE
DUAL VOLTAGE
LOW-VOLTAGE INHIBIT
MODULE
DDRB
8-BIT KEYBOARD
INTERRUPT MODULE
OSC1
OSC2
ENHANCED SERIAL
COMUNICATIONS
INTERFACE MODULE
PHASE LOCKED LOOP
COMPUTER OPERATING
PROPERLY MODULE
RST(3)
SYSTEM INTEGRATION
MODULE
SERIAL PERIPHERAL
INTERFACE MODULE
IRQ(3)
SINGLE EXTERNAL
INTERRUPT MODULE
MONITOR MODULE
CONVERTER MODULE
DATA BUS SWITCH
MODULE
POWER-ON RESET
MODULE
MEMORY MAP
MODULE
POWER
CONFIGURATION
REGISTER 1–2
MODULE
CGMXFC
VDDAD/VREFH
VDDAD/VREFL
MOTOROLA
VDD
VSS
VDDA
VSSA
DDRC
2-CHANNEL TIMER
INTERFACE MODULE 2
DDRD
2-CHANNEL TIMER
INTERFACE MODULE 1
DDRE
PORTC
MODULE
PORTD
ARITHMETIC/LOGIC
UNIT (ALU)
PORTE
CPU
REGISTERS
SECURITY
MODULE
MONITOR MODE ENTRY
MODULE
Figure 15-1. Block Diagram Highlight SIM Block and Pins
Data Sheet
196
INTERNAL BUS
M68HC08 CPU
Introduction
MODULE STOP
MODULE WAIT
CPU STOP (FROM CPU)
CPU WAIT (FROM CPU)
STOP/WAIT
CONTROL
SIMOSCEN (TO CGM)
SIM
COUNTER
CGMXCLK (FROM CGM)
CGMOUT (FROM CGM)
÷2
CLOCK
CONTROL
VDD
CLOCK GENERATORS
INTERNAL
PULLUP
DEVICE
INTERNAL CLOCKS
FORCED MONITOR MODE ENTRY
RESET
PIN LOGIC
LVI (FROM LVI MODULE)
POR CONTROL
MASTER
RESET
CONTROL
RESET PIN CONTROL
SIM RESET STATUS REGISTER
ILLEGAL OPCODE (FROM CPU)
ILLEGAL ADDRESS (FROM ADDRESS
MAP DECODERS)
COP (FROM COP MODULE)
RESET
INTERRUPT SOURCES
INTERRUPT CONTROL
AND PRIORITY DECODE
CPU INTERFACE
Figure 15-2. SIM Block Diagram
Table 15-1. Signal Name Conventions
Signal Name
Description
CGMXCLK
Buffered version of OSC1 from clock generator module (CGM)
CGMVCLK
PLL output
CGMOUT
PLL-based or OSC1-based clock output from CGM module
(Bus clock = CGMOUT divided by two)
IAB
Internal address bus
IDB
Internal data bus
PORRST
Signal from the power-on reset module to the SIM
IRST
Internal reset signal
R/W
Read/write signal
MOTOROLA
Data Sheet
197
Addr.
Register Name
$FE00
Break Status Register Read:
(BSR) Write:
See page 212. Reset:
Bit 7
6
5
4
3
2
1
Bit 0
R
R
R
R
R
R
SBSW
R
Note(1)
1. Writing a logic 0 clears SBSW.
$FE01
$FE03
SIM Reset Status Register Read:
(SRSR) Write:
See page 213. POR:
Break Flag Control Register Read:
(BFCR) Write:
See page 214. Reset:
POR
PIN
COP
ILOP
ILAD
MODRST
LVI
BCFE
R
R
R
R
R
R
R
Interrupt Status Register 1 Read:
(INT1) Write:
See page 208. Reset:
IF6
IF5
IF4
IF3
IF2
IF1
R
R
R
R
R
R
R
R
IF14
IF13
IF12
IF11
IF10
IF9
IF8
IF7
$FE05
Interrupt Status Register 2 Read:
(INT2) Write:
R
R
R
R
R
R
R
R
IF20
IF19
IF18
IF17
IF16
IF15
$FE06
Interrupt Status Register 3 Read:
(INT3) Write:
R
R
R
R
R
R
R
R
R
= Reserved
$FE04
= Unimplemented
Figure 15-3. SIM I/O Register Summary
15.2 SIM Bus Clock Control and Generation
The bus clock generator provides system clock signals for the CPU and peripherals
on the MCU. The system clocks are generated from an incoming clock, CGMOUT,
as shown in Figure 15-4. This clock originates from either an external oscillator or
from the on-chip PLL.
15.2.1 Bus Timing
In user mode, the internal bus frequency is either the crystal oscillator output
(CGMXCLK) divided by four or the PLL output (CGMVCLK) divided by four.
15.2.2 Clock Startup from POR or LVI Reset
When the power-on reset module or the low-voltage inhibit module generates a
reset, the clocks to the CPU and peripherals are inactive and held in an inactive
phase until after the 4096 CGMXCLK cycle POR timeout has completed. The RST
pin is driven low by the SIM during this entire period. The IBUS clocks start upon
completion of the timeout.
Data Sheet
198
MOTOROLA
Reset and System Initialization
OSC2
OSCILLATOR (OSC)
CGMXCLK
OSC1
TO TBM,TIM1,TIM2, ADC
SIM
OSCENINSTOP
FROM
CONFIG
SIM COUNTER
CGMRCLK
÷2
PHASE-LOCKED LOOP (PLL)
BUS CLOCK
GENERATORS
SIMOSCEN
IT12
TO REST
OF CHIP
IT23
TO REST
OF CHIP
Figure 15-4. System Clock Signals
15.2.3 Clocks in Stop Mode and Wait Mode
Upon exit from stop mode by an interrupt or reset, the SIM allows CGMXCLK to
clock the SIM counter. The CPU and peripheral clocks do not become active until
after the stop delay timeout. This timeout is selectable as 4096 or 32 CGMXCLK
cycles. See 15.6.2 Stop Mode.
In wait mode, the CPU clocks are inactive. The SIM also produces two sets of
clocks for other modules. Refer to the wait mode subsection of each module to see
if the module is active or inactive in wait mode. Some modules can be programmed
to be active in wait mode.
15.3 Reset and System Initialization
The MCU has these reset sources:
Power-on reset module (POR)
External reset pin (RST)
Computer operating properly module (COP)
Low-voltage inhibit module (LVI)
Illegal opcode
Illegal address
Forced monitor mode entry reset (MODRST)
MOTOROLA
Data Sheet
199
All of these resets produce the vector $FFFE:$FFFF ($FEFE:$FEFF in monitor
mode) and assert the internal reset signal (IRST). IRST causes all registers to be
returned to their default values and all modules to be returned to their reset states.
An internal reset clears the SIM counter (see 15.4 SIM Counter), but an external
reset does not. Each of the resets sets a corresponding bit in the SIM reset status
register (SRSR). See 15.7 SIM Registers.
15.3.1 External Pin Reset
The RST pin circuit includes an internal pullup device. Pulling the asynchronous
RST pin low halts all processing. The PIN bit of the SIM reset status register
(SRSR) is set as long as RST is held low for a minimum of 67 CGMXCLK cycles,
assuming that neither the POR nor the LVI was the source of the reset. See Table
15-2 for details. Figure 15-5 shows the relative timing.
Table 15-2. PIN Bit Set Timing
Reset Type
Number of Cycles Required to Set PIN
POR/LVI
4163 (4096 + 64 + 3)
All others
67 (64 + 3)
CGMOUT
RST
IAB
VECT H VECT L
PC
Figure 15-5. External Reset Timing
15.3.2 Active Resets from Internal Sources
All internal reset sources actively pull the RST pin low for 32 CGMXCLK cycles to
allow resetting of external peripherals. The internal reset signal IRST continues to
be asserted for an additional 32 cycles. See Figure 15-6. An internal reset can be
caused by an illegal address, illegal opcode, COP timeout, LVI, or POR. See
Figure 15-7.
NOTE:
For LVI or POR resets, the SIM cycles through 4096 + 32 CGMXCLK cycles during
which the SIM forces the RST pin low. The internal reset signal then follows the
sequence from the falling edge of RST shown in Figure 15-6.
Data Sheet
200
MOTOROLA
IRST
RST
RST PULLED LOW BY MCU
32 CYCLES
32 CYCLES
CGMXCLK
IAB
VECTOR HIGH
Figure 15-6. Internal Reset Timing
The COP reset is asynchronous to the bus clock.
ILLEGAL ADDRESS RST
ILLEGAL OPCODE RST
COPRST
LVI
POR
MODRST
INTERNAL RESET
Figure 15-7. Sources of Internal Reset
The active reset feature allows the part to issue a reset to peripherals and other
chips within a system built around the MCU.
15.3.2.1 Power-On Reset
When power is first applied to the MCU, the power-on reset module (POR)
generates a pulse to indicate that power-on has occurred. The external reset pin
(RST) is held low while the SIM counter counts out 4096 + 32 CGMXCLK cycles.
Thirty-two CGMXCLK cycles later, the CPU and memories are released from reset
to allow the reset vector sequence to occur.
At power-on, these events occur:
A POR pulse is generated.
The internal reset signal is asserted.
The SIM enables CGMOUT.
Internal clocks to the CPU and modules are held inactive for 4096
CGMXCLK cycles to allow stabilization of the oscillator.
The RST pin is driven low during the oscillator stabilization time.
The POR bit of the SIM reset status register (SRSR) is set and all other bits
in the register are cleared.
MOTOROLA
Data Sheet
201
OSC1
PORRST
4096
CYCLES
32
CYCLES
CGMXCLK
CGMOUT
RST
$FFFE
IAB
$FFFF
Figure 15-8. POR Recovery
15.3.2.2 Computer Operating Properly (COP) Reset
An input to the SIM is reserved for the COP reset signal. The overflow of the COP
counter causes an internal reset and sets the COP bit in the SIM reset status
register (SRSR). The SIM actively pulls down the RST pin for all internal reset
sources.
The COP module is disabled if the RST pin or the IRQ pin is held at VTST while the
MCU is in monitor mode. The COP module can be disabled only through
combinational logic conditioned with the high voltage signal on the RST or the IRQ
pin. This prevents the COP from becoming disabled as a result of external noise.
During a break state, VTST on the RST pin disables the COP module.
15.3.2.3 Illegal Opcode Reset
The SIM decodes signals from the CPU to detect illegal instructions. An illegal
instruction sets the ILOP bit in the SIM reset status register (SRSR) and causes a
reset.
If the stop enable bit, STOP, in the mask option register is logic 0, the SIM treats
the STOP instruction as an illegal opcode and causes an illegal opcode reset. The
SIM actively pulls down the RST pin for all internal reset sources.
15.3.2.4 Illegal Address Reset
An opcode fetch from an unmapped address generates an illegal address reset.
The SIM verifies that the CPU is fetching an opcode prior to asserting the ILAD bit
in the SIM reset status register (SRSR) and resetting the MCU. A data fetch from
an unmapped address does not generate a reset. The SIM actively pulls down the
Data Sheet
202
MOTOROLA
SIM Counter
15.3.2.5 Low-Voltage Inhibit (LVI) Reset
The low-voltage inhibit module (LVI) asserts its output to the SIM when the VDD
voltage falls to the LVITRIPF voltage. The LVI bit in the SIM reset status register
(SRSR) is set, and the external reset pin (RST) is held low while the SIM counter
Thirty-two CGMXCLK cycles later, the CPU is released from reset to allow the
reset vector sequence to occur. The SIM actively pulls down the RST pin for all
15.3.2.6 Monitor Mode Entry Module Reset (MODRST)
The monitor mode entry module reset (MODRST) asserts its output to the SIM
when monitor mode is entered in the condition where the reset vectors are erased
($FF) (see 19.3.1.1 Normal Monitor Mode). When MODRST gets asserted, an
internal reset occurs. The SIM actively pulls down the RST pin for all internal reset
sources.
15.4 SIM Counter
The SIM counter is used by the power-on reset module (POR) and in stop mode
recovery to allow the oscillator time to stabilize before enabling the internal bus
(IBUS) clocks. The SIM counter is 13 bits long.
15.4.1 SIM Counter During Power-On Reset
The power-on reset module (POR) detects power applied to the MCU. At
power-on, the POR circuit asserts the signal PORRST. Once the SIM is initialized,
it enables the clock generation module (CGM) to drive the bus clock state machine.
15.4.2 SIM Counter During Stop Mode Recovery
The SIM counter also is used for stop mode recovery. The STOP instruction clears
the SIM counter. After an interrupt, break, or reset, the SIM senses the state of the
short stop recovery bit, SSREC, in the mask option register. If the SSREC bit is a
logic 1, then the stop recovery is reduced from the normal delay of 4096 CGMXCLK
cycles down to 32 CGMXCLK cycles. This is ideal for applications using canned
oscillators that do not require long startup times from stop mode. External crystal
applications should use the full stop recovery time, that is, with SSREC cleared.
15.4.3 SIM Counter and Reset States
External reset has no effect on the SIM counter. See 15.6.2 Stop Mode for details.
The SIM counter is free-running after all reset states. See 15.3.2 Active Resets
from Internal Sources for counter control and internal reset recovery sequences.
MOTOROLA
Data Sheet
203
15.5 Exception Control
Normal, sequential program execution can be changed in three different ways:
• Interrupts:
– Maskable hardware CPU interrupts
– Non-maskable software interrupt instruction (SWI)
• Reset
• Break interrupts
15.5.1 Interrupts
At the beginning of an interrupt, the CPU saves the CPU register contents on the
stack and sets the interrupt mask (I bit) to prevent additional interrupts. At the end
of an interrupt, the RTI instruction recovers the CPU register contents from the
stack so that normal processing can resume. Figure 15-9 shows interrupt entry
timing. Figure 15-10 shows interrupt recovery timing.
Interrupts are latched, and arbitration is performed in the SIM at the start of
interrupt processing. The arbitration result is a constant that the CPU uses to
determine which vector to fetch. Once an interrupt is latched by the SIM, no other
interrupt can take precedence, regardless of priority, until the latched interrupt is
serviced (or the I bit is cleared). See Figure 15-11.
MODULE
INTERRUPT
I BIT
IAB
IDB
DUMMY
SP
DUMMY
SP – 1
SP – 2
PC – 1[7:0] PC – 1[15:8]
SP – 3
X
SP – 4
A
VECT H
CCR
VECT L
V DATA H
START ADDR
V DATA L
OPCODE
R/W
Figure 15-9. Interrupt Entry Timing
MODULE INTERRUPT
I BIT
IAB
IDB
SP – 4
SP – 3
CCR
SP – 2
A
SP – 1
X
SP
PC
PC + 1
PC – 1 [7:0] PC – 1 [15:8] OPCODE
OPERAND
R/W
Figure 15-10. Interrupt Recovery Timing
Data Sheet
204
MOTOROLA
Exception Control
FROM RESET
BREAK
I BIT
SET?
INTERRUPT?
YES
NO
YES
I BIT SET?
NO
IRQ
INTERRUPT?
YES
NO
AS MANY INTERRUPTS
AS EXIST ON CHIP
STACK CPU REGISTERS
SET I BIT
LOAD PC WITH INTERRUPT VECTOR
FETCH NEXT
INSTRUCTION
SWI
INSTRUCTION?
YES
NO
RTI
INSTRUCTION?
YES
UNSTACK CPU REGISTERS
NO
EXECUTE INSTRUCTION
Figure 15-11. Interrupt Processing
MOTOROLA
Data Sheet
205
15.5.1.1 Hardware Interrupts
A hardware interrupt does not stop the current instruction. Processing of a
hardware interrupt begins after completion of the current instruction. When the
current instruction is complete, the SIM checks all pending hardware interrupts.
If interrupts are not masked (I bit clear in the condition code register) and if the
corresponding interrupt enable bit is set, the SIM proceeds with interrupt
processing; otherwise, the next instruction is fetched and executed.
If more than one interrupt is pending at the end of an instruction execution, the
highest priority interrupt is serviced first. Figure 15-12 demonstrates what happens
when two interrupts are pending. If an interrupt is pending upon exit from the
original interrupt service routine, the pending interrupt is serviced before the LDA
instruction is executed.
CLI
LDA #$FF
INT1
BACKGROUND
ROUTINE
PSHH
INT1 INTERRUPT SERVICE ROUTINE
PULH
RTI
INT2
PSHH
INT2 INTERRUPT SERVICE ROUTINE
PULH
RTI
Figure 15-12. Interrupt Recognition Example
The LDA opcode is prefetched by both the INT1 and INT2 RTI instructions.
However, in the case of the INT1 RTI prefetch, this is a redundant operation.
NOTE:
To maintain compatibility with the M6805 Family, the H register is not pushed on
the stack during interrupt entry. If the interrupt service routine modifies the H
register or uses the indexed addressing mode, software should save the H register
and then restore it prior to exiting the routine.
Data Sheet
206
MOTOROLA
Exception Control
15.5.1.2 SWI Instruction
The SWI instruction is a non-maskable instruction that causes an interrupt
regardless of the state of the interrupt mask (I bit) in the condition code register.
NOTE:
A software interrupt pushes PC onto the stack. A software interrupt does not push
PC – 1, as a hardware interrupt does.
15.5.1.3 Interrupt Status Registers
The flags in the interrupt status registers identify maskable interrupt sources. Table
15-3 summarizes the interrupt sources and the interrupt status register flags that
they set. The interrupt status registers can be useful for debugging.
Table 15-3. Interrupt Sources
Priority
Interrupt Source
Interrupt Status Register Flag
Highest
Reset
SWI instruction
IRQ pin
I1
ICG clock monitor
I2
TIM1 channel 0
I3
TIM1 channel 1
I4
TIM1 overflow
I5
TIM2 channel 0
I6
TIM2 channel 1
I7
TIM2 overflow
I8
SPI receiver full
I9
SPI transmitter empty
I10
SCI receive error
I11
SCI receive
I12
SCI transmit
I13
Keyboard
I14
ADC conversion complete
I15
Timebase module
I16
Lowest
MOTOROLA
Data Sheet
207
Interrupt Status
Register 1
Address:
$FE04
Bit 7
6
5
4
3
2
1
Bit 0
Read:
I6
I5
I4
I3
I2
I1
Write:
R
R
R
R
R
R
R
R
Reset:
R
= Reserved
Figure 15-13. Interrupt Status Register 1 (INT1)
I6–I1 — Interrupt Flags 1–6
These flags indicate the presence of interrupt requests from the sources shown
in Table 15-3.
1 = Interrupt request present
0 = No interrupt request present
Bit 0 and Bit 1 — Always read 0
Interrupt Status
Register 2
Address:
$FE05
Bit 7
6
5
4
3
2
1
Bit 0
Read:
I14
I13
I12
I11
I10
I9
I8
I7
Write:
R
R
R
R
R
R
R
R
Reset:
R
= Reserved
Figure 15-14. Interrupt Status Register 2 (INT2)
I14–I7 — Interrupt Flags 14–7
in Table 15-3.
Interrupt Status
Register 3
Address:
$FE06
Bit 7
6
5
4
3
2
1
Bit 0
Read:
I20
I19
I18
I17
I16
I15
Write:
R
R
R
R
R
R
R
R
Reset:
R
= Reserved
Figure 15-15. Interrupt Status Register 3 (INT3)
Bits 7–6 — Always read 0
I20–I15 — Interrupt Flags 20–15
These flags indicate the presence of an interrupt request from the source shown
in Table 15-3.
Data Sheet
208
MOTOROLA
Low-Power Modes
15.5.2 Reset
All reset sources always have equal and highest priority and cannot be arbitrated.
15.5.3 Break Interrupts
The break module can stop normal program flow at a software-programmable
break point by asserting its break interrupt output (see Section 18. Timer
Interface Module (TIM)). The SIM puts the CPU into the break state by forcing it
to the SWI vector location. Refer to the break interrupt subsection of each module
to see how each module is affected by the break state.
15.5.4 Status Flag Protection in Break Mode
The SIM controls whether status flags contained in other modules can be cleared
during break mode. The user can select whether flags are protected from being
cleared by properly initializing the break clear flag enable bit (BCFE) in the SIM
break flag control register (SBFCR).
Protecting flags in break mode ensures that set flags will not be cleared while in
break mode. This protection allows registers to be freely read and written during
break mode without losing status flag information.
Setting the BCFE bit enables the clearing mechanisms. Once cleared in break
mode, a flag remains cleared even when break mode is exited. Status flags with a
2-step clearing mechanism — for example, a read of one register followed by the
read or write of another — are protected, even when the first step is accomplished
prior to entering break mode. Upon leaving break mode, execution of the second
step will clear the flag as normal.
15.6 Low-Power Modes
Executing the WAIT or STOP instruction puts the MCU in a low
power-consumption mode for standby situations. The SIM holds the CPU in a
non-clocked state. The operation of each of these modes is described in the
following subsections. Both STOP and WAIT clear the interrupt mask (I) in the
condition code register, allowing interrupts to occur.
15.6.1 Wait Mode
In wait mode, the CPU clocks are inactive while the peripheral clocks continue to
run. Figure 15-16 shows the timing for wait mode entry.
A module that is active during wait mode can wakeup the CPU with an interrupt if
the interrupt is enabled. Stacking for the interrupt begins one cycle after the WAIT
instruction during which the interrupt occurred. In wait mode, the CPU clocks are
inactive. Refer to the wait mode subsection of each module to see if the module is
MOTOROLA
Data Sheet
209
active or inactive in wait mode. Some modules can be programmed to be active in
wait mode.
Wait mode also can be exited by a reset (or break in emulation mode). A break
interrupt during wait mode sets the SIM break stop/wait bit, SBSW, in the SIM
break status register (SBSR). If the COP disable bit, COPD, in the mask option
register is logic 0, then the computer operating properly module (COP) is enabled
and remains active in wait mode.
IAB
WAIT ADDR
IDB
WAIT ADDR + 1
PREVIOUS DATA
SAME
SAME
NEXT OPCODE
SAME
SAME
R/W
Note:
Previous data can be operand data or the WAIT opcode, depending on the
last instruction.
Figure 15-16. Wait Mode Entry Timing
Figure 15-17 and Figure 15-18 show the timing for WAIT recovery.
IAB
$6E0B
IDB
$A6
$A6
$6E0C
$A6
$00FF
$01
$0B
$00FE
$00FD
$00FC
$6E
EXITSTOPWAIT
Note: EXITSTOPWAIT = RST pin or CPU interrupt
Figure 15-17. Wait Recovery from Interrupt
32
CYCLES
IAB
IDB
32
CYCLES
$6E0B
$A6
$A6
RSTVCT H
RSTVCTL
$A6
RST
CGMXCLK
Figure 15-18. Wait Recovery from Internal Reset
Data Sheet
210
MOTOROLA
Low-Power Modes
15.6.2 Stop Mode
In stop mode, the SIM counter is reset and the system clocks are disabled. An
interrupt request from a module can cause an exit from stop mode. Stacking for
interrupts begins after the selected stop recovery time has elapsed. Reset also
causes an exit from stop mode.
The SIM disables the clock generator module outputs (CGMOUT and CGMXCLK)
in stop mode, stopping the CPU and peripherals. Stop recovery time is selectable
using the SSREC bit in the mask option register (MOR). If SSREC is set, stop
recovery is reduced from the normal delay of 4096 CGMXCLK cycles down to 32.
This is ideal for applications using canned oscillators that do not require long
NOTE:
External crystal applications should use the full stop recovery time by clearing the
SSREC bit.
The SIM counter is held in reset from the execution of the STOP instruction until
the beginning of stop recovery. It is then used to time the recovery period. Figure
15-19 shows stop mode entry timing. Figure 15-20 shows stop mode recovery time
from interrupt.
NOTE:
To minimize stop current, all pins configured as inputs should be driven to a logic
1 or logic 0.
CPUSTOP
IAB
IDB
STOP ADDR + 1
STOP ADDR
PREVIOUS DATA
SAME
NEXT OPCODE
SAME
SAME
SAME
R/W
Note: Previous data can be operand data or the STOP opcode, depending
on the last instruction.
Figure 15-19. Stop Mode Entry Timing
STOP RECOVERY PERIOD
CGMXCLK
INT/BREAK
IAB
STOP +1
STOP + 2
STOP + 2
SP
SP – 1
SP – 2
SP – 3
Figure 15-20. Stop Mode Recovery from Interrupt
MOTOROLA
Data Sheet
211
15.7 SIM Registers
The SIM has three memory-mapped registers. Table 15-4 shows the mapping of
these registers.
Table 15-4. SIM Registers
Address
Register
Access Mode
$FE00
BSR
User
$FE01
SRSR
User
$FE03
BFCR
User
15.7.1 Break Status Register
The break status register (BSR) contains a flag to indicate that a break caused an
exit from wait mode. This register is only used in emulation mode.
Address:
$FE00
Bit 7
Read:
Write:
Reset:
6
5
4
3
2
R
R
R
R
R
R
R
= Reserved
1
SBSW
Note(1)
Bit 0
R
Figure 15-21. Break Status Register (BSR)
SBSW — SIM Break Stop/Wait
This status bit is useful in applications requiring a return to wait mode after
exiting from a break interrupt. Clear SBSW by writing a logic 0 to it. Reset clears
SBSW.
1 = Wait mode was exited by break interrupt.
0 = Wait mode was not exited by break interrupt.
SBSW can be read within the break state SWI routine. The user can modify the
return address on the stack by subtracting one from it.
Data Sheet
212
MOTOROLA
SIM Registers
15.7.2 SIM Reset Status Register
This register contains six flags that show the source of the last reset provided all
previous reset status bits have been cleared. Clear the SIM reset status register by
reading it. A power-on reset sets the POR bit and clears all other bits in the register.
Address:
Read:
$FE01
Bit 7
6
5
4
3
2
1
Bit 0
POR
PIN
COP
ILOP
ILAD
MODRST
LVI
Write:
Reset:
1
= Unimplemented
Figure 15-22. SIM Reset Status Register (SRSR)
POR — Power-On Reset Bit
1 = Last reset caused by POR circuit
0 = Read of SRSR
PIN — External Reset Bit
1 = Last reset caused by external reset pin (RST)
0 = POR or read of SRSR
COP — Computer Operating Properly Reset Bit
1 = Last reset caused by COP counter
ILOP — Illegal Opcode Reset Bit
1 = Last reset caused by an illegal opcode
ILAD — Illegal Address Reset Bit (opcode fetches only)
1 = Last reset caused by an opcode fetch from an illegal address
MODRST — Monitor Mode Entry Module Reset Bit
1 = Last reset caused by monitor mode entry when vector locations $FFFE
and $FFFF are $FF after POR while IRQ = VDD
LVI — Low-Voltage Inhibit Reset Bit
1 = Last reset caused by the LVI circuit
MOTOROLA
Data Sheet
213
15.7.3 Break Flag Control Register
The break control register (BFCR) contains a bit that enables software to clear
status bits while the MCU is in a break state.
Address:
Read:
Write:
Reset:
$FE03
Bit 7
6
5
4
3
2
1
Bit 0
BCFE
R
R
R
R
R
R
R
R
= Reserved
Figure 15-23. Break Flag Control Register (BFCR)
BCFE — Break Clear Flag Enable Bit
This read/write bit enables software to clear status bits by accessing status
registers while the MCU is in a break state. To clear status bits during the break
state, the BCFE bit must be set.
1 = Status bits clearable during break
0 = Status bits not clearable during break
Data Sheet
214
MOTOROLA
Section 16. Serial Peripheral Interface (SPI) Module
16.1 Introduction
This section describes the serial peripheral interface (SPI) module, which allows
full-duplex, synchronous, serial communications with peripheral devices.
16.2 Features
Features of the SPI module include:
Full-duplex operation
Master and slave modes
Double-buffered operation with separate transmit and receive registers
Four master mode frequencies (maximum = bus frequency ÷ 2)
Maximum slave mode frequency = bus frequency
Serial clock with programmable polarity and phase
Two separately enabled interrupts:
– SPRF (SPI receiver full)
– SPTE (SPI transmitter empty)
Mode fault error flag with CPU interrupt capability
Overflow error flag with CPU interrupt capability
Programmable wired-OR mode
I2C (inter-integrated circuit) compatibility
I/O (input/output) port bit(s) software configurable with pullup device(s) if
configured as input port bit(s)
MOTOROLA
Data Sheet
215
USER RAM — 1024 BYTES
DDRA
PORTA
PORTB
PTB7/AD7
PTB6/AD6
PTB5/AD5
PTB4/AD4
PTB3/AD3
PTB2/AD2
PTB1/AD1
PTB0/AD0
PTC6(1)
PTC5(1)
PTC4(1), (2)
PTC3(1), (2)
PTC2(1), (2)
PTC1(1), (2)
PTC0(1), (2)
PTD7/T2CH1(1)
PTD6/T2CH0(1)
PTD5/T1CH1(1)
PTD4/T1CH0(1)
PTD3/SPSCK(1)
PTD2/MOSI(1)
PTD1/MISO(1)
PTD0/SS(1)
PTE5–PTE2
PTE1/RxD
PTE0/TxD
SINGLE BREAKPOINT
BREAK MODULE
DUAL VOLTAGE
LOW-VOLTAGE INHIBIT
MODULE
DDRB
USER FLASH — 15,872 BYTES
8-BIT KEYBOARD
INTERRUPT MODULE
MONITOR ROM — 350 BYTES
CLOCK GENERATOR MODULE
OSC1
OSC2
32–100 kHz OSCILLATOR
ENHANCED SERIAL
COMUNICATIONS
INTERFACE MODULE
PHASE LOCKED LOOP
COMPUTER OPERATING
PROPERLY MODULE
RST(3)
SYSTEM INTEGRATION
MODULE
SERIAL PERIPHERAL
INTERFACE MODULE
IRQ(3)
SINGLE EXTERNAL
INTERRUPT MODULE
MONITOR MODULE
10-BIT ANALOG-TO-DIGITAL
CONVERTER MODULE
DATA BUS SWITCH
MODULE
POWER-ON RESET
MODULE
MEMORY MAP
MODULE
POWER
CONFIGURATION
REGISTER 1–2
MODULE
CGMXFC
VDDAD/VREFH
VDDAD/VREFL
MOTOROLA
VDD
VSS
VDDA
VSSA
DDRC
2-CHANNEL TIMER
INTERFACE MODULE 2
DDRD
USER FLASH VECTOR SPACE — 44 BYTES
2-CHANNEL TIMER
INTERFACE MODULE 1
DDRE
FLASH PROGRAMMING ROUTINES ROM — 406 BYTES
PTA7/KBD7–PTA0/KBD0(1)
PORTC
CONTROL AND STATUS REGISTERS — 64 BYTES
PROGRAMMABLE TIMEBASE
MODULE
PORTD
ARITHMETIC/LOGIC
UNIT (ALU)
PORTE
CPU
REGISTERS
SECURITY
MODULE
MONITOR MODE ENTRY
MODULE
1. Ports are software configurable with pullup device if input port.
2. Higher current drive port pins
3. Pin contains integrated pullup device
Figure 16-1. Block Diagram Highlighting SPI Block and Pins
Data Sheet
216
INTERNAL BUS
M68HC08 CPU
Pin Name Conventions
16.3 Pin Name Conventions
The text that follows describes the SPI. The SPI I/O pin names are SS (slave
select), SPSCK (SPI serial clock), CGND (clock ground), MOSI (master out slave
in), and MISO (master in/slave out). The SPI shares four I/O pins with four parallel
I/O ports.
The full names of the SPI I/O pins are shown in Table 16-1. The generic pin names
appear in the text that follows.
Table 16-1. Pin Name Conventions
SPI Generic
Pin Names:
Full SPI
Pin Names:
SPI
MISO
MOSI
SS
SPSCK
CGND
PTD1/MISO
PTD2/MOSI
PTD0/SS
PTD3/SPSCK
VSS
16.4 Functional Description
Figure 16-2 summarizes the SPI I/O registers and Figure 16-3 shows the structure
of the SPI module.
The SPI module allows full-duplex, synchronous, serial communication between
the MCU and peripheral devices, including other MCUs. Software can poll the SPI
status flags or SPI operation can be interrupt driven.
If a port bit is configured for input, then an internal pullup device may be enabled
for that port bit. See 12.4.3 Port C Input Pullup Enable Register.
The following paragraphs describe the operation of the SPI module.
Addr.
$0010
$0011
$0012
Register Name
Read:
SPI Control Register
(SPCR) Write:
See page 235.
Reset:
Read:
SPI Status and Control
Register (SPSCR) Write:
See page 236.
Reset:
Read:
SPI Data Register
(SPDR) Write:
See page 238.
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
SPRIE
R
SPMSTR
CPOL
CPHA
SPWOM
SPE
SPTIE
OVRF
MODF
SPTE
MODFEN
SPR1
SPR0
SPRF
ERRIE
R7
R6
R5
R4
R3
R2
R1
R0
T7
T6
T5
T4
T3
T2
T1
T0
Unaffected by reset
R
= Reserved
= Unimplemented
Figure 16-2. SPI I/O Register Summary
MOTOROLA
Data Sheet
217
INTERNAL BUS
TRANSMIT DATA REGISTER
CGMOUT ÷ 2
FROM SIM
SHIFT REGISTER
7
6
5
4
3
2
1
MISO
÷2
CLOCK
DIVIDER
MOSI
÷8
RECEIVE DATA REGISTER
÷ 32
PIN
CONTROL
LOGIC
÷ 128
SPMSTR
SPE
CLOCK
SELECT
SPR1
SPSCK
M
CLOCK
LOGIC
S
SS
SPR0
SPMSTR
RESERVED
TRANSMITTER CPU INTERRUPT REQUEST
RESERVED
CPHA
MODFEN
CPOL
SPWOM
ERRIE
SPI
CONTROL
SPTIE
SPRIE
RECEIVER/ERROR CPU INTERRUPT REQUEST
SPE
SPRF
SPTE
OVRF
MODF
Figure 16-3. SPI Module Block Diagram
Data Sheet
218
MOTOROLA
16.4.1 Master Mode
The SPI operates in master mode when the SPI master bit, SPMSTR, is set.
NOTE:
Configure the SPI modules as master or slave before enabling them. Enable the
master SPI before enabling the slave SPI. Disable the slave SPI before disabling
the master SPI. See 16.13.1 SPI Control Register.
Only a master SPI module can initiate transmissions. Software begins the
transmission from a master SPI module by writing to the transmit data register. If
the shift register is empty, the byte immediately transfers to the shift register,
setting the SPI transmitter empty bit, SPTE. The byte begins shifting out on the
MOSI pin under the control of the serial clock. See Figure 16-4.
MASTER MCU
SHIFT REGISTER
SLAVE MCU
MISO
MISO
MOSI
MOSI
SPSCK
BAUD RATE
GENERATOR
SS
SHIFT REGISTER
SPSCK
VDD
SS
Figure 16-4. Full-Duplex Master-Slave Connections
The SPR1 and SPR0 bits control the baud rate generator and determine the speed
of the shift register. (See 16.13.2 SPI Status and Control Register.) Through the
SPSCK pin, the baud rate generator of the master also controls the shift register of
the slave peripheral.
As the byte shifts out on the MOSI pin of the master, another byte shifts in from the
slave on the master’s MISO pin. The transmission ends when the receiver full bit,
SPRF, becomes set. At the same time that SPRF becomes set, the byte from the
slave transfers to the receive data register. In normal operation, SPRF signals the
end of a transmission. Software clears SPRF by reading the SPI status and control
register with SPRF set and then reading the SPI data register. Writing to the SPI
data register clears the SPTE bit.
MOTOROLA
Data Sheet
219
16.4.2 Slave Mode
The SPI operates in slave mode when the SPMSTR bit is clear. In slave mode, the
SPSCK pin is the input for the serial clock from the master MCU. Before a data
transmission occurs, the SS pin of the slave SPI must be at logic 0. SS must remain
low until the transmission is complete. See 16.7.2 Mode Fault Error.
In a slave SPI module, data enters the shift register under the control of the serial
clock from the master SPI module. After a byte enters the shift register of a slave
SPI, it transfers to the receive data register, and the SPRF bit is set. To prevent an
overflow condition, slave software then must read the receive data register before
another full byte enters the shift register.
The maximum frequency of the SPSCK for an SPI configured as a slave is the bus
clock speed (which is twice as fast as the fastest master SPSCK clock that can be
generated). The frequency of the SPSCK for an SPI configured as a slave does not
have to correspond to any SPI baud rate. The baud rate only controls the speed of
the SPSCK generated by an SPI configured as a master. Therefore, the frequency
of the SPSCK for an SPI configured as a slave can be any frequency less than or
equal to the bus speed.
When the master SPI starts a transmission, the data in the slave shift register
begins shifting out on the MISO pin. The slave can load its shift register with a new
byte for the next transmission by writing to its transmit data register. The slave must
write to its transmit data register at least one bus cycle before the master starts the
next transmission. Otherwise, the byte already in the slave shift register shifts out
on the MISO pin. Data written to the slave shift register during a transmission
remains in a buffer until the end of the transmission.
When the clock phase bit (CPHA) is set, the first edge of SPSCK starts a
transmission. When CPHA is clear, the falling edge of SS starts a transmission.
See 16.5 Transmission Formats.
NOTE:
SPSCK must be in the proper idle state before the slave is enabled to prevent
SPSCK from appearing as a clock edge.
During an SPI transmission, data is simultaneously transmitted (shifted out serially)
and received (shifted in serially). A serial clock synchronizes shifting and sampling
on the two serial data lines. A slave select line allows selection of an individual
slave SPI device; slave devices that are not selected do not interfere with SPI bus
activities. On a master SPI device, the slave select line can optionally be used to
indicate multiple-master bus contention.
Data Sheet
220
MOTOROLA
16.5.1 Clock Phase and Polarity Controls
Software can select any of four combinations of serial clock (SPSCK) phase and
polarity using two bits in the SPI control register (SPCR). The clock polarity is
specified by the CPOL control bit, which selects an active high or low clock and has
no significant effect on the transmission format.
The clock phase (CPHA) control bit selects one of two fundamentally different
transmission formats. The clock phase and polarity should be identical for the
master SPI device and the communicating slave device. In some cases, the phase
and polarity are changed between transmissions to allow a master device to
communicate with peripheral slaves having different requirements.
NOTE:
Before writing to the CPOL bit or the CPHA bit, disable the SPI by clearing the SPI
enable bit (SPE).
16.5.2 Transmission Format When CPHA = 0
Figure 16-5 shows an SPI transmission in which CPHA is logic 0. The figure should
not be used as a replacement for data sheet parametric information.
Two waveforms are shown for SPSCK: one for CPOL = 0 and another for
CPOL = 1. The diagram may be interpreted as a master or slave timing diagram
since the serial clock (SPSCK), master in/slave out (MISO), and master out/slave
in (MOSI) pins are directly connected between the master and the slave. The MISO
signal is the output from the slave, and the MOSI signal is the output from the
master. The SS line is the slave select input to the slave. The slave SPI drives its
MISO output only when its slave select input (SS) is at logic 0, so that only the
selected slave drives to the master. The SS pin of the master is not shown but is
assumed to be inactive. The SS pin of the master must be high or must be
reconfigured as general-purpose I/O not affecting the SPI. (See 16.7.2 Mode Fault
Error.) When CPHA = 0, the first SPSCK edge is the MSB capture strobe.
Therefore, the slave must begin driving its data before the first SPSCK edge, and
a falling edge on the SS pin is used to start the slave data transmission. The slave’s
SS pin must be toggled back to high and then low again between each byte
transmitted as shown in Figure 16-6.
When CPHA = 0 for a slave, the falling edge of SS indicates the beginning of the
transmission. This causes the SPI to leave its idle state and begin driving the MISO
pin with the MSB of its data. Once the transmission begins, no new data is allowed
into the shift register from the transmit data register. Therefore, the SPI data
register of the slave must be loaded with transmit data before the falling edge of
SS. Any data written after the falling edge is stored in the transmit data register and
transferred to the shift register after the current transmission.
MC68HC908GR16 — Rev. 1.0
MOTOROLA
Data Sheet
221
SPSCK CYCLE #
FOR REFERENCE
1
2
3
4
5
6
7
8
MSB
BIT 6
BIT 5
BIT 4
BIT 3
BIT 2
BIT 1
LSB
BIT 6
BIT 5
BIT 4
BIT 3
BIT 2
BIT 1
LSB
SPSCK; CPOL = 0
SPSCK; CPOL =1
MOSI
FROM MASTER
MISO
FROM SLAVE
MSB
SS; TO SLAVE
CAPTURE STROBE
Figure 16-5. Transmission Format (CPHA = 0)
MISO/MOSI
BYTE 1
BYTE 2
BYTE 3
MASTER SS
SLAVE SS
CPHA = 0
SLAVE SS
CPHA = 1
Figure 16-6. CPHA/SS Timing
16.5.3 Transmission Format When CPHA = 1
Figure 16-7 shows an SPI transmission in which CPHA is logic 1. The figure should
not be used as a replacement for data sheet parametric information. Two
waveforms are shown for SPSCK: one for CPOL = 0 and another for CPOL = 1.
The diagram may be interpreted as a master or slave timing diagram since the
serial clock (SPSCK), master in/slave out (MISO), and master out/slave in (MOSI)
pins are directly connected between the master and the slave. The MISO signal is
the output from the slave, and the MOSI signal is the output from the master. The
SS line is the slave select input to the slave. The slave SPI drives its MISO output
only when its slave select input (SS) is at logic 0, so that only the selected slave
drives to the master. The SS pin of the master is not shown but is assumed to be
inactive. The SS pin of the master must be high or must be reconfigured as
general-purpose I/O not affecting the SPI. (See 16.7.2 Mode Fault Error.) When
CPHA = 1, the master begins driving its MOSI pin on the first SPSCK edge.
Therefore, the slave uses the first SPSCK edge as a start transmission signal. The
SS pin can remain low between transmissions. This format may be preferable in
systems having only one master and only one slave driving the MISO data line.
When CPHA = 1 for a slave, the first edge of the SPSCK indicates the beginning
of the transmission. This causes the SPI to leave its idle state and begin driving the
MISO pin with the MSB of its data. Once the transmission begins, no new data is
allowed into the shift register from the transmit data register. Therefore, the SPI
Data Sheet
222
MOTOROLA
data register of the slave must be loaded with transmit data before the first edge of
SPSCK. Any data written after the first edge is stored in the transmit data register
and transferred to the shift register after the current transmission.
SPSCK CYCLE #
FOR REFERENCE
1
2
3
4
5
6
7
8
MOSI
FROM MASTER
MSB
BIT 6
BIT 5
BIT 4
BIT 3
BIT 2
BIT 1
LSB
MISO
FROM SLAVE
MSB
BIT 6
BIT 5
BIT 4
BIT 3
BIT 2
BIT 1
SPSCK; CPOL = 0
SPSCK; CPOL =1
LSB
SS; TO SLAVE
CAPTURE STROBE
Figure 16-7. Transmission Format (CPHA = 1)
16.5.4 Transmission Initiation Latency
When the SPI is configured as a master (SPMSTR = 1), writing to the SPDR starts
a transmission. CPHA has no effect on the delay to the start of the transmission,
but it does affect the initial state of the SPSCK signal. When CPHA = 0, the SPSCK
signal remains inactive for the first half of the first SPSCK cycle. When CPHA = 1,
the first SPSCK cycle begins with an edge on the SPSCK line from its inactive to
its active level. The SPI clock rate (selected by SPR1:SPR0) affects the delay from
the write to SPDR and the start of the SPI transmission. (See Figure 16-8.) The
internal SPI clock in the master is a free-running derivative of the internal MCU
clock. To conserve power, it is enabled only when both the SPE and SPMSTR bits
are set. SPSCK edges occur halfway through the low time of the internal MCU
clock. Since the SPI clock is free-running, it is uncertain where the write to the
SPDR occurs relative to the slower SPSCK. This uncertainty causes the variation
in the initiation delay shown in Figure 16-8. This delay is no longer than a single
SPI bit time. That is, the maximum delay is two MCU bus cycles for DIV2, eight
MCU bus cycles for DIV8, 32 MCU bus cycles for DIV32, and 128 MCU bus cycles
for DIV128.
MOTOROLA
Data Sheet
223
WRITE
TO SPDR
INITIATION DELAY
BUS
CLOCK
MOSI
MSB
BIT 6
BIT 5
SPSCK
CPHA = 1
SPSCK
CPHA = 0
SPSCK CYCLE
NUMBER
1
2
3
INITIATION DELAY FROM WRITE SPDR TO TRANSFER BEGIN
WRITE
TO SPDR
BUS
CLOCK
EARLIEST
WRITE
TO SPDR
LATEST
SPSCK = INTERNAL CLOCK ÷ 2;
2 POSSIBLE START POINTS
BUS
CLOCK
EARLIEST
WRITE
TO SPDR
SPSCK = INTERNAL CLOCK ÷ 8;
8 POSSIBLE START POINTS
LATEST
SPSCK = INTERNAL CLOCK ÷ 32;
32 POSSIBLE START POINTS
LATEST
SPSCK = INTERNAL CLOCK ÷ 128;
128 POSSIBLE START POINTS
LATEST
BUS
CLOCK
EARLIEST
WRITE
TO SPDR
BUS
CLOCK
EARLIEST
Figure 16-8. Transmission Start Delay (Master)
Data Sheet
224
MOTOROLA
Queuing Transmission Data
16.6 Queuing Transmission Data
The double-buffered transmit data register allows a data byte to be queued and
transmitted. For an SPI configured as a master, a queued data byte is transmitted
immediately after the previous transmission has completed. The SPI transmitter
empty flag (SPTE) indicates when the transmit data buffer is ready to accept new
data. Write to the transmit data register only when the SPTE bit is high. Figure 16-9
shows the timing associated with doing back-to-back transmissions with the SPI
(SPSCK has CPHA: CPOL = 1:0).
WRITE TO SPDR
SPTE
1
3
2
8
5
10
SPSCK
CPHA:CPOL = 1:0
MOSI
MSB BIT BIT BIT BIT BIT BIT LSB MSB BIT BIT BIT BIT BIT BIT LSB MSB BIT BIT BIT
6 5 4
6 5 4 3 2 1
6 5 4 3 2 1
BYTE 1
BYTE 2
BYTE 3
9
4
SPRF
6
READ SPSCR
11
7
READ SPDR
12
1 CPU WRITES BYTE 1 TO SPDR, CLEARING SPTE BIT.
7 CPU READS SPDR, CLEARING SPRF BIT.
2 BYTE 1 TRANSFERS FROM TRANSMIT DATA
REGISTER TO SHIFT REGISTER, SETTING SPTE BIT.
8 CPU WRITES BYTE 3 TO SPDR, QUEUEING BYTE
3 AND CLEARING SPTE BIT.
9 SECOND INCOMING BYTE TRANSFERS FROM SHIFT
REGISTER TO RECEIVE DATA REGISTER, SETTING
SPRF BIT.
10 BYTE 3 TRANSFERS FROM TRANSMIT DATA
11 CPU READS SPSCR WITH SPRF BIT SET.
3 CPU WRITES BYTE 2 TO SPDR, QUEUEING BYTE 2
FIRST INCOMING BYTE TRANSFERS FROM SHIFT
SPRF BIT.
5 BYTE 2 TRANSFERS FROM TRANSMIT DATA
6 CPU READS SPSCR WITH SPRF BIT SET.
4
12 CPU READS SPDR, CLEARING SPRF BIT.
Figure 16-9. SPRF/SPTE CPU Interrupt Timing
The transmit data buffer allows back-to-back transmissions without the slave
precisely timing its writes between transmissions as in a system with a single data
buffer. Also, if no new data is written to the data buffer, the last value contained in
the shift register is the next data word to be transmitted.
For an idle master or idle slave that has no data loaded into its transmit buffer, the
SPTE is set again no more than two bus cycles after the transmit buffer empties
into the shift register. This allows the user to queue up a 16-bit value to send. For
an already active slave, the load of the shift register cannot occur until the
transmission is completed. This implies that a back-to-back write to the transmit
data register is not possible. The SPTE indicates when the next write can occur.
MOTOROLA
Data Sheet
225
16.7 Error Conditions
The following flags signal SPI error conditions:
Overflow (OVRF) — Failing to read the SPI data register before the next full
byte enters the shift register sets the OVRF bit. The new byte does not
transfer to the receive data register, and the unread byte still can be read.
OVRF is in the SPI status and control register.
Mode fault error (MODF) — The MODF bit indicates that the voltage on the
slave select pin (SS) is inconsistent with the mode of the SPI. MODF is in
16.7.1 Overflow Error
The overflow flag (OVRF) becomes set if the receive data register still has unread
data from a previous transmission when the capture strobe of bit 1 of the next
transmission occurs. The bit 1 capture strobe occurs in the middle of SPSCK
cycle 7 (see Figure 16-5 and Figure 16-7.) If an overflow occurs, all data received
after the overflow and before the OVRF bit is cleared does not transfer to the
receive data register and does not set the SPI receiver full bit (SPRF). The unread
data that transferred to the receive data register before the overflow occurred can
still be read. Therefore, an overflow error always indicates the loss of data. Clear
the overflow flag by reading the SPI status and control register and then reading
OVRF generates a receiver/error CPU interrupt request if the error interrupt enable
bit (ERRIE) is also set. The SPRF, MODF, and OVRF interrupts share the same
CPU interrupt vector (see Figure 16-12.) It is not possible to enable MODF or
OVRF individually to generate a receiver/error CPU interrupt request. However,
leaving MODFEN low prevents MODF from being set.
If the CPU SPRF interrupt is enabled and the OVRF interrupt is not, watch for an
overflow condition. Figure 16-10 shows how it is possible to miss an overflow.
The first part of Figure 16-10 shows how it is possible to read the SPSCR and
SPDR to clear the SPRF without problems. However, as illustrated by the second
transmission example, the OVRF bit can be set in between the time that SPSCR
and SPDR are read.
In this case, an overflow can be missed easily. Since no more SPRF interrupts can
be generated until this OVRF is serviced, it is not obvious that bytes are being lost
as more transmissions are completed. To prevent this, either enable the OVRF
interrupt or do another read of the SPSCR following the read of the SPDR. This
ensures that the OVRF was not set before the SPRF was cleared and that future
transmissions can set the SPRF bit. Figure 16-11 illustrates this process.
Generally, to avoid this second SPSCR read, enable the OVRF to the CPU by
setting the ERRIE bit.
Data Sheet
226
MOTOROLA
Error Conditions
BYTE 1
BYTE 2
BYTE 3
BYTE 4
1
4
6
8
SPRF
OVRF
READ
SPSCR
2
5
READ
SPDR
3
7
1
BYTE 1 SETS SPRF BIT.
2
AND OVRF BIT CLEAR.
CPU READS BYTE 1 IN SPDR,
CLEARING SPRF BIT.
BYTE 2 SETS SPRF BIT.
3
4
5
AND OVRF BIT CLEAR.
6
BYTE 3 SETS OVRF BIT. BYTE 3 IS LOST.
7
CPU READS BYTE 2 IN SPDR, CLEARING SPRF BIT,
BUT NOT OVRF BIT.
8
BYTE 4 FAILS TO SET SPRF BIT BECAUSE
OVRF BIT IS NOT CLEARED. BYTE 4 IS LOST.
Figure 16-10. Missed Read of Overflow Condition
BYTE 1
SPI RECEIVE
COMPLETE
BYTE 2
5
1
BYTE 3
7
BYTE 4
11
SPRF
OVRF
READ
SPSCR
2
READ
SPDR
4
6
3
1
2
AND OVRF BIT CLEAR.
CLEARING SPRF BIT.
3
9
8
12
10
14
13
8
CLEARING SPRF BIT.
9
CPU READS SPSCR AGAIN
TO CHECK OVRF BIT.
10 CPU READS BYTE 2 SPDR,
CLEARING OVRF BIT.
4
TO CHECK OVRF BIT.
11 BYTE 4 SETS SPRF BIT.
5
12 CPU READS SPSCR.
6
AND OVRF BIT CLEAR.
13 CPU READS BYTE 4 IN SPDR,
CLEARING SPRF BIT.
7
14 CPU READS SPSCR AGAIN
TO CHECK OVRF BIT.
Figure 16-11. Clearing SPRF When OVRF Interrupt Is Not Enabled
MOTOROLA
Data Sheet
227
Setting the SPMSTR bit selects master mode and configures the SPSCK and
MOSI pins as outputs and the MISO pin as an input. Clearing SPMSTR selects
slave mode and configures the SPSCK and MOSI pins as inputs and the MISO pin
as an output. The mode fault bit, MODF, becomes set any time the state of the
slave select pin, SS, is inconsistent with the mode selected by SPMSTR.
To prevent SPI pin contention and damage to the MCU, a mode fault error occurs if:
The SS pin of a slave SPI goes high during a transmission
The SS pin of a master SPI goes low at any time
For the MODF flag to be set, the mode fault error enable bit (MODFEN) must be
set. Clearing the MODFEN bit does not clear the MODF flag but does prevent
MODF from being set again after MODF is cleared.
MODF generates a receiver/error CPU interrupt request if the error interrupt enable
CPU interrupt vector. (See Figure 16-12.) It is not possible to enable MODF or
In a master SPI with the mode fault enable bit (MODFEN) set, the mode fault flag
(MODF) is set if SS goes to logic 0. A mode fault in a master SPI causes the
following events to occur:
NOTE:
If ERRIE = 1, the SPI generates an SPI receiver/error CPU interrupt request.
The SPE bit is cleared.
The SPTE bit is set.
The SPI state counter is cleared.
The data direction register of the shared I/O port regains control of port
drivers.
To prevent bus contention with another master SPI after a mode fault error, clear
all SPI bits of the data direction register of the shared I/O port before enabling the
SPI.
When configured as a slave (SPMSTR = 0), the MODF flag is set if SS goes high
during a transmission. When CPHA = 0, a transmission begins when SS goes low
and ends once the incoming SPSCK goes back to its idle level following the shift
of the eighth data bit. When CPHA = 1, the transmission begins when the SPSCK
leaves its idle level and SS is already low. The transmission continues until the
SPSCK returns to its idle level following the shift of the last data bit. See
NOTE:
Setting the MODF flag does not clear the SPMSTR bit. The SPMSTR bit has no
function when SPE = 0. Reading SPMSTR when MODF = 1 shows the difference
between a MODF occurring when the SPI is a master and when it is a slave.
Data Sheet
228
MOTOROLA
Interrupts
When CPHA = 0, a MODF occurs if a slave is selected (SS is at logic 0) and later
unselected (SS is at logic 1) even if no SPSCK is sent to that slave. This happens
because SS at logic 0 indicates the start of the transmission (MISO driven out with
the value of MSB) for CPHA = 0. When CPHA = 1, a slave can be selected and
then later unselected with no transmission occurring. Therefore, MODF does not
occur since a transmission was never begun.
In a slave SPI (MSTR = 0), the MODF bit generates an SPI receiver/error CPU
interrupt request if the ERRIE bit is set. The MODF bit does not clear the SPE bit
or reset the SPI in any way. Software can abort the SPI transmission by clearing
the SPE bit of the slave.
NOTE:
A logic 1 voltage on the SS pin of a slave SPI puts the MISO pin in a high
impedance state. Also, the slave SPI ignores all incoming SPSCK clocks, even if it
was already in the middle of a transmission.
To clear the MODF flag, read the SPSCR with the MODF bit set and then write to
the SPCR register. This entire clearing mechanism must occur with no MODF
condition existing or else the flag is not cleared.
16.8 Interrupts
Four SPI status flags can be enabled to generate CPU interrupt requests. See
Table 16-2.
Table 16-2. SPI Interrupts
Flag
Request
SPTE
Transmitter empty
SPI transmitter CPU interrupt request
(SPTIE = 1, SPE = 1)
SPRF
Receiver full
SPI receiver CPU interrupt request
(SPRIE = 1)
OVRF
Overflow
SPI receiver/error interrupt request
(ERRIE = 1)
MODF
Mode fault
(ERRIE = 1)
Reading the SPI status and control register with SPRF set and then reading the
receive data register clears SPRF. The clearing mechanism for the SPTE flag is
always just a write to the transmit data register.
The SPI transmitter interrupt enable bit (SPTIE) enables the SPTE flag to generate
transmitter CPU interrupt requests, provided that the SPI is enabled (SPE = 1).
The SPI receiver interrupt enable bit (SPRIE) enables the SPRF bit to generate
receiver CPU interrupt requests, regardless of the state of the SPE bit. See
Figure 16-12.
The error interrupt enable bit (ERRIE) enables both the MODF and OVRF bits to
MOTOROLA
Data Sheet
229
The mode fault enable bit (MODFEN) can prevent the MODF flag from being set
so that only the OVRF bit is enabled by the ERRIE bit to generate receiver/error
NOT AVAILABLE
SPTE
SPTIE
SPE
SPI TRANSMITTER
NOT AVAILABLE
SPRIE
SPRF
SPI RECEIVER/ERROR
ERRIE
MODF
OVRF
Figure 16-12. SPI Interrupt Request Generation
The following sources in the SPI status and control register can generate CPU
interrupt requests:
SPI receiver full bit (SPRF) — The SPRF bit becomes set every time a byte
transfers from the shift register to the receive data register. If the SPI
receiver interrupt enable bit, SPRIE, is also set, SPRF generates an SPI
SPI transmitter empty (SPTE) — The SPTE bit becomes set every time a
byte transfers from the transmit data register to the shift register. If the SPI
transmit interrupt enable bit, SPTIE, is also set, SPTE generates an SPTE
16.9 Resetting the SPI
Any system reset completely resets the SPI. Partial resets occur whenever the SPI
enable bit (SPE) is low. Whenever SPE is low, the following occurs:
• The SPTE flag is set.
• Any transmission currently in progress is aborted.
• The shift register is cleared.
• The SPI state counter is cleared, making it ready for a new complete
transmission.
• All the SPI port logic is defaulted back to being general-purpose I/O.
Data Sheet
230
MOTOROLA
Low-Power Modes
These items are reset only by a system reset:
• All control bits in the SPCR register
• All control bits in the SPSCR register (MODFEN, ERRIE, SPR1, and SPR0)
• The status flags SPRF, OVRF, and MODF
By not resetting the control bits when SPE is low, the user can clear SPE between
transmissions without having to set all control bits again when SPE is set back high
for the next transmission.
By not resetting the SPRF, OVRF, and MODF flags, the user can still service these
interrupts after the SPI has been disabled. The user can disable the SPI by
writing 0 to the SPE bit. The SPI can also be disabled by a mode fault occurring in
an SPI that was configured as a master with the MODFEN bit set.
16.10 Low-Power Modes
The WAIT and STOP instructions put the MCU in low power-consumption standby
modes.
16.10.1 Wait Mode
The SPI module remains active after the execution of a WAIT instruction. In wait
mode the SPI module registers are not accessible by the CPU. Any enabled CPU
interrupt request from the SPI module can bring the MCU out of wait mode.
If SPI module functions are not required during wait mode, reduce power
consumption by disabling the SPI module before executing the WAIT instruction.
To exit wait mode when an overflow condition occurs, enable the OVRF bit to
generate CPU interrupt requests by setting the error interrupt enable bit (ERRIE).
See 16.8 Interrupts.
16.10.2 Stop Mode
The SPI module is inactive after the execution of a STOP instruction. The STOP
instruction does not affect register conditions. SPI operation resumes after an
external interrupt. If stop mode is exited by reset, any transfer in progress is
aborted, and the SPI is reset.
16.11 SPI During Break Interrupts
The system integration module (SIM) controls whether status bits in other modules
can be cleared during the break state. The BCFE bit in the SIM break flag control
register (SBFCR) enables software to clear status bits during the break state. See
Section 15. System Integration Module (SIM).
MOTOROLA
Data Sheet
231
To allow software to clear status bits during a break interrupt, write a logic 1 to the
BCFE bit. If a status bit is cleared during the break state, it remains cleared when
the MCU exits the break state.
To protect status bits during the break state, write a logic 0 to the BCFE bit. With
BCFE at logic 0 (its default state), software can read and write I/O registers during
the break state without affecting status bits. Some status bits have a 2-step
read/write clearing procedure. If software does the first step on such a bit before
the break, the bit cannot change during the break state as long as BCFE is at
logic 0. After the break, doing the second step clears the status bit.
Since the SPTE bit cannot be cleared during a break with the BCFE bit cleared, a
write to the transmit data register in break mode does not initiate a transmission nor
is this data transferred into the shift register. Therefore, a write to the SPDR in
break mode with the BCFE bit cleared has no effect.
16.12 I/O Signals
The SPI module has five I/O pins and shares four of them with a parallel I/O port.
They are:
• MISO — Data received
• MOSI — Data transmitted
• SPSCK — Serial clock
• SS — Slave select
• CGND — Clock ground (internally connected to VSS)
The SPI has limited inter-integrated circuit (I2C) capability (requiring software
support) as a master in a single-master environment. To communicate with I2C
peripherals, MOSI becomes an open-drain output when the SPWOM bit in the SPI
control register is set. In I2C communication, the MOSI and MISO pins are
connected to a bidirectional pin from the I2C peripheral and through a pullup
resistor to VDD.
16.12.1 MISO (Master In/Slave Out)
MISO is one of the two SPI module pins that transmits serial data. In full duplex
operation, the MISO pin of the master SPI module is connected to the MISO pin of
the slave SPI module. The master SPI simultaneously receives data on its MISO
pin and transmits data from its MOSI pin.
Slave output data on the MISO pin is enabled only when the SPI is configured as
a slave. The SPI is configured as a slave when its SPMSTR bit is logic 0 and its SS
pin is at logic 0. To support a multiple-slave system, a logic 1 on the SS pin puts
the MISO pin in a high-impedance state.
When enabled, the SPI controls data direction of the MISO pin regardless of the
state of the data direction register of the shared I/O port.
Data Sheet
232
MOTOROLA
I/O Signals
16.12.2 MOSI (Master Out/Slave In)
MOSI is one of the two SPI module pins that transmits serial data. In full-duplex
operation, the MOSI pin of the master SPI module is connected to the MOSI pin of
the slave SPI module. The master SPI simultaneously transmits data from its MOSI
pin and receives data on its MISO pin.
When enabled, the SPI controls data direction of the MOSI pin regardless of the
16.12.3 SPSCK (Serial Clock)
The serial clock synchronizes data transmission between master and slave
devices. In a master MCU, the SPSCK pin is the clock output. In a slave MCU, the
SPSCK pin is the clock input. In full-duplex operation, the master and slave MCUs
exchange a byte of data in eight serial clock cycles.
When enabled, the SPI controls data direction of the SPSCK pin regardless of the
16.12.4 SS (Slave Select)
The SS pin has various functions depending on the current state of the SPI. For an
SPI configured as a slave, the SS is used to select a slave. For CPHA = 0, the SS
is used to define the start of a transmission. (See 16.5 Transmission Formats.)
Since it is used to indicate the start of a transmission, the SS must be toggled high
and low between each byte transmitted for the CPHA = 0 format. However, it can
remain low between transmissions for the CPHA = 1 format. See Figure 16-13.
MISO/MOSI
BYTE 1
BYTE 2
BYTE 3
MASTER SS
SLAVE SS
CPHA = 0
SLAVE SS
CPHA = 1
Figure 16-13. CPHA/SS Timing
When an SPI is configured as a slave, the SS pin is always configured as an input.
It cannot be used as a general-purpose I/O regardless of the state of the MODFEN
control bit. However, the MODFEN bit can still prevent the state of the SS from
creating a MODF error. See 16.13.2 SPI Status and Control Register.
NOTE:
high-impedance state. The slave SPI ignores all incoming SPSCK clocks, even if
it was already in the middle of a transmission.
When an SPI is configured as a master, the SS input can be used in conjunction
with the MODF flag to prevent multiple masters from driving MOSI and SPSCK.
MOTOROLA
Data Sheet
233
(See 16.7.2 Mode Fault Error.) For the state of the SS pin to set the MODF flag,
the MODFEN bit in the SPSCK register must be set. If the MODFEN bit is low for
an SPI master, the SS pin can be used as a general-purpose I/O under the control
of the data direction register of the shared I/O port. With MODFEN high, it is an
input-only pin to the SPI regardless of the state of the data direction register of the
shared I/O port.
The CPU can always read the state of the SS pin by configuring the appropriate
pin as an input and reading the port data register. See Table 16-3.
Table 16-3. SPI Configuration
SPE
SPMSTR
MODFEN
SPI Configuration
State of SS Logic
X(1))
X
Not enabled
General-purpose I/O; SS ignored by SPI
1
X
Slave
Input-only to SPI
1
1
Master without MODF
1
1
1
Master with MODF
Input-only to SPI
1. X = Don’t care
16.12.5 CGND (Clock Ground)
CGND is the ground return for the serial clock pin, SPSCK, and the ground for the
port output buffers. It is internally connected to VSS as shown in Table 16-1.
16.13 I/O Registers
Three registers control and monitor SPI operation:
SPI status and control register (SPSCR)
SPI data register (SPDR)
The SPI control register:
Enables SPI module interrupt requests
Configures the SPI module as master or slave
Selects serial clock polarity and phase
Configures the SPSCK, MOSI, and MISO pins as open-drain outputs
Enables the SPI module
Data Sheet
234
MOTOROLA
I/O Registers
Address: $0010
Read:
Write:
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
SPRIE
R
SPMSTR
CPOL
CPHA
SPWOM
SPE
SPTIE
R
= Reserved
= Unimplemented
Figure 16-14. SPI Control Register (SPCR)
SPRIE — SPI Receiver Interrupt Enable Bit
This read/write bit enables CPU interrupt requests generated by the SPRF bit.
The SPRF bit is set when a byte transfers from the shift register to the receive
data register. Reset clears the SPRIE bit.
1 = SPRF CPU interrupt requests enabled
0 = SPRF CPU interrupt requests disabled
SPMSTR — SPI Master Bit
This read/write bit selects master mode operation or slave mode operation.
Reset sets the SPMSTR bit.
1 = Master mode
0 = Slave mode
CPOL — Clock Polarity Bit
This read/write bit determines the logic state of the SPSCK pin between
transmissions. (See Figure 16-5 and Figure 16-7.) To transmit data between
SPI modules, the SPI modules must have identical CPOL values. Reset clears
the CPOL bit.
CPHA — Clock Phase Bit
This read/write bit controls the timing relationship between the serial clock and
SPI data. (See Figure 16-5 and Figure 16-7.) To transmit data between SPI
modules, the SPI modules must have identical CPHA values. When CPHA = 0,
the SS pin of the slave SPI module must be set to logic 1 between bytes. (See
Figure 16-13.) Reset sets the CPHA bit.
SPWOM — SPI Wired-OR Mode Bit
This read/write bit disables the pullup devices on pins SPSCK, MOSI, and MISO
so that those pins become open-drain outputs.
1 = Wired-OR SPSCK, MOSI, and MISO pins
0 = Normal push-pull SPSCK, MOSI, and MISO pins
SPE — SPI Enable
This read/write bit enables the SPI module. Clearing SPE causes a partial reset
of the SPI. (See 16.9 Resetting the SPI.) Reset clears the SPE bit.
1 = SPI module enabled
0 = SPI module disabled
MOTOROLA
Data Sheet
235
SPTIE— SPI Transmit Interrupt Enable
This read/write bit enables CPU interrupt requests generated by the SPTE bit.
SPTE is set when a byte transfers from the transmit data register to the shift
register. Reset clears the SPTIE bit.
1 = SPTE CPU interrupt requests enabled
0 = SPTE CPU interrupt requests disabled
The SPI status and control register contains flags to signal these conditions:
Receive data register full
Failure to clear SPRF bit before next byte is received (overflow error)
Inconsistent logic level on SS pin (mode fault error)
Transmit data register empty
The SPI status and control register also contains bits that perform these functions:
Enable error interrupts
Enable mode fault error detection
Select master SPI baud rate
Address: $0011
Bit 7
Read:
SPRF
Write:
Reset:
ERRIE
4
3
OVRF
MODF
SPTE
2
1
Bit 0
MODFEN
SPR1
SPR0
= Unimplemented
Figure 16-15. SPI Status and Control Register (SPSCR)
SPRF — SPI Receiver Full Bit
This clearable, read-only flag is set each time a byte transfers from the shift
register to the receive data register. SPRF generates a CPU interrupt request if
the SPRIE bit in the SPI control register is set also.
During an SPRF CPU interrupt, the CPU clears SPRF by reading the SPI status
and control register with SPRF set and then reading the SPI data register.
Reset clears the SPRF bit.
1 = Receive data register full
0 = Receive data register not full
ERRIE — Error Interrupt Enable Bit
This read/write bit enables the MODF and OVRF bits to generate CPU interrupt
requests. Reset clears the ERRIE bit.
1 = MODF and OVRF can generate CPU interrupt requests
0 = MODF and OVRF cannot generate CPU interrupt requests
Data Sheet
236
MOTOROLA
I/O Registers
OVRF — Overflow Bit
This clearable, read-only flag is set if software does not read the byte in the
receive data register before the next full byte enters the shift register. In an
overflow condition, the byte already in the receive data register is unaffected,
and the byte that shifted in last is lost. Clear the OVRF bit by reading the SPI
status and control register with OVRF set and then reading the receive data
register. Reset clears the OVRF bit.
1 = Overflow
0 = No overflow
MODF — Mode Fault Bit
This clearable, read-only flag is set in a slave SPI if the SS pin goes high during
a transmission with the MODFEN bit set. In a master SPI, the MODF flag is set
if the SS pin goes low at any time with the MODFEN bit set. Clear the MODF bit
by reading the SPI status and control register (SPSCR) with MODF set and then
writing to the SPI control register (SPCR). Reset clears the MODF bit.
1 = SS pin at inappropriate logic level
0 = SS pin at appropriate logic level
SPTE — SPI Transmitter Empty Bit
This clearable, read-only flag is set each time the transmit data register
transfers a byte into the shift register. SPTE generates an SPTE CPU interrupt
request or an SPTE DMA service request if the SPTIE bit in the SPI control
NOTE:
Do not write to the SPI data register unless the SPTE bit is high.
During an SPTE CPU interrupt, the CPU clears the SPTE bit by writing to the
Reset sets the SPTE bit.
1 = Transmit data register empty
0 = Transmit data register not empty
MODFEN — Mode Fault Enable Bit
This read/write bit, when set to 1, allows the MODF flag to be set. If the MODF
flag is set, clearing the MODFEN does not clear the MODF flag. If the SPI is
enabled as a master and the MODFEN bit is low, then the SS pin is available as
a general-purpose I/O.
If the MODFEN bit is set, then this pin is not available as a general-purpose I/O.
When the SPI is enabled as a slave, the SS pin is not available as a
general-purpose I/O regardless of the value of MODFEN. See 16.12.4 SS
(Slave Select).
If the MODFEN bit is low, the level of the SS pin does not affect the operation
of an enabled SPI configured as a master. For an enabled SPI configured as a
slave, having MODFEN low only prevents the MODF flag from being set. It does
not affect any other part of SPI operation. See 16.7.2 Mode Fault Error.
MOTOROLA
Data Sheet
237
SPR1 and SPR0 — SPI Baud Rate Select Bits
In master mode, these read/write bits select one of four baud rates as shown in
Table 16-4. SPR1 and SPR0 have no effect in slave mode. Reset clears SPR1
and SPR0.
Table 16-4. SPI Master Baud Rate Selection
SPR1 and SPR0
Baud Rate Divisor (BD)
00
2
01
8
10
32
11
128
Use this formula to calculate the SPI baud rate:
CGMOUT
Baud rate = -------------------------2 × BD
where:
CGMOUT = base clock output of the clock generator module (CGM)
BD = baud rate divisor
16.13.3 SPI Data Register
The SPI data register consists of the read-only receive data register and the
write-only transmit data register. Writing to the SPI data register writes data into the
transmit data register. Reading the SPI data register reads data from the receive
data register. The transmit data and receive data registers are separate registers
that can contain different values. See Figure 16-3.
Address: $0012
Bit 7
6
5
4
3
2
1
Bit 0
Read:
R7
R6
R5
R4
R3
R2
R1
R0
Write:
T7
T6
T5
T4
T3
T2
T1
T0
Reset:
Unaffected by reset
Figure 16-16. SPI Data Register (SPDR)
R7–R0/T7–T0 — Receive/Transmit Data Bits
NOTE:
Do not use read-modify-write instructions on the SPI data register since the register
read is not the same as the register written.
Data Sheet
238
MOTOROLA
Data Sheet — MC68HC908GR16
Section 17. Timebase Module (TBM)
17.1 Introduction
This section describes the timebase module (TBM). The TBM will generate
periodic interrupts at user selectable rates using a counter clocked by the external
clock source. This TBM version uses 15 divider stages, eight of which are user
selectable. A configuration option bit to select an additional 128 divide of the
external clock source can be selected. See Section 5. Configuration Register
(CONFIG)
17.2 Features
Features of the TBM module include:
External clock or an additional divide-by-128 selected by configuration
option bit as clock source
Software configurable periodic interrupts with divide-by: 8, 16, 32, 64, 128,
2048, 8192, and 32768 taps of the selected clock source
Configurable for operation during stop mode to allow periodic wakeup from
stop
17.3 Functional Description
This module can generate a periodic interrupt by dividing the clock source supplied
from the clock generator module, CGMXCLK.
The counter is initialized to all 0s when TBON bit is cleared. The counter, shown in
Figure 17-1, starts counting when the TBON bit is set. When the counter overflows
at the tap selected by TBR2–TBR0, the TBIF bit gets set. If the TBIE bit is set, an
interrupt request is sent to the CPU. The TBIF flag is cleared by writing a 1 to the
TACK bit. The first time the TBIF flag is set after enabling the timebase module, the
interrupt is generated at approximately half of the overflow period. Subsequent
events occur at the exact period.
The timebase module may remain active after execution of the STOP instruction if
the crystal oscillator has been enabled to operate during stop mode through the
OSCENINSTOP bit in the configuration register. The timebase module can be
used in this mode to generate a periodic wakeup from stop mode.
MOTOROLA
Data Sheet
239
17.4 Interrupts
The timebase module can periodically interrupt the CPU with a rate defined by the
selected TBMCLK and the select bits TBR2–TBR0. When the timebase counter
chain rolls over, the TBIF flag is set. If the TBIE bit is set, enabling the timebase
interrupt, the counter chain overflow will generate a CPU interrupt request.
TBMCLKSEL
FROM CONFIG2
CGMXCLK
FROM CGM MODULE
TBMCLK
DIVIDE BY 128
PRESCALER
TBON
÷2
÷2
÷2
÷2
÷2
÷2
÷2
÷2
÷2
÷2
÷2
÷2
TACK
÷2
TBR0
÷2
TBR1
÷2
TBR2
TBMINT
TBIF
000
TBIE
R
001
010
100
SEL
011
101
110
111
Figure 17-1. Timebase Block Diagram
NOTE:
Interrupts must be acknowledged by writing a logic 1 to the TACK bit.
Data Sheet
240
MOTOROLA
TBM Interrupt Rate
17.5 TBM Interrupt Rate
The interrupt rate is determined by the equation:
t
TBMRATE
1
Divider
= -------------------------------- = ---------------------------f
f
TBMRATE
TBMCLK
where:
fTBMCLK = Frequency supplied from the clock generator (CGM) module
Divider = Divider value as determined by TBR2–TBR0 settings,
see Table 17-1
Table 17-1. Timebase Divider Selection
Divider Tap
TBR2
TBR1
TBR0
TMBCLKSEL
32,768
4,194,304
8192
1,048,576
262144
1
128
16,384
1
8192
1
32
4096
1
1
2048
1
1
1
8
1024
As an example, a clock source of 4.9152 MHz, with the TMCLKSEL set for
divide-by-128 and the TBR2–TBR0 set to {011}, the divider tap is1 and the interrupt
rate calculates to:
1/(4.9152 x 106/128) = 26 µs
NOTE:
Do not change TBR2–TBR0 bits while the timebase is enabled (TBON = 1).
17.6 Low-Power Modes
The WAIT and STOP instructions put the MCU in low power- consumption standby
modes.
17.6.1 Wait Mode
The timebase module remains active after execution of the WAIT instruction. In
wait mode the timebase register is not accessible by the CPU.
If the timebase functions are not required during wait mode, reduce the power
consumption by stopping the timebase before executing the WAIT instruction.
MOTOROLA
Data Sheet
241
17.6.2 Stop Mode
the internal clock generator has been enabled to operate during stop mode through
the OSCENINSTOP bit in the configuration register. The timebase module can be
If the internal clock generator has not been enabled to operate in stop mode, the
timebase module will not be active during stop mode. In stop mode, the timebase
If the timebase functions are not required during stop mode, reduce power
consumption by disabling the timebase module before executing the STOP
instruction.
17.7 Timebase Control Register
The timebase has one register, the timebase control register (TBCR), which is
used to enable the timebase interrupts and set the rate.
Address: $001C
Bit 7
Read:
TBIF
Write:
Reset:
5
4
TBR2
TBR1
TBR0
= Unimplemented
3
2
1
Bit 0
TBIE
TBON
R
R
= Reserved
TACK
Figure 17-2. Timebase Control Register (TBCR)
TBIF — Timebase Interrupt Flag
This read-only flag bit is set when the timebase counter has rolled over.
1 = Timebase interrupt pending
0 = Timebase interrupt not pending
TBR2–TBR0 — Timebase Divider Selection Bits
These read/write bits select the tap in the counter to be used for timebase
interrupts as shown in Table 17-1.
NOTE:
(TBON = 1).
TACK— Timebase Acknowledge Bit
The TACK bit is a write-only bit and always reads as 0. Writing a logic 1 to this
bit clears TBIF, the timebase interrupt flag bit. Writing a logic 0 to this bit has no
effect.
1 = Clear timebase interrupt flag
0 = No effect
Data Sheet
242
MOTOROLA
TBIE — Timebase Interrupt Enabled Bit
This read/write bit enables the timebase interrupt when the TBIF bit becomes
set. Reset clears the TBIE bit.
1 = Timebase interrupt is enabled.
0 = Timebase interrupt is disabled.
TBON — Timebase Enabled Bit
This read/write bit enables the timebase. Timebase may be turned off to reduce
power consumption when its function is not necessary. The counter can be
initialized by clearing and then setting this bit. Reset clears the TBON bit.
1 = Timebase is enabled.
0 = Timebase is disabled and the counter initialized to 0s.
MOTOROLA
Data Sheet
243
Data Sheet
244
MOTOROLA
Section 18. Timer Interface Module (TIM)
18.1 Introduction
This section describes the timer interface (TIM) module. The TIM is a two-channel
timer that provides a timing reference with input capture, output compare, and
pulse-width-modulation functions. Figure 18-1 is a block diagram of the TIM.
This particular MCU has two timer interface modules which are denoted as TIM1
and TIM2.
PRESCALER SELECT
INTERNAL
BUS CLOCK
PRESCALER
TSTOP
PS2
TRST
PS1
PS0
16-BIT COUNTER
TOF
TOIE
INTERRUPT
LOGIC
16-BIT COMPARATOR
TMODH:TMODL
TOV0
CHANNEL 0
ELS0B
ELS0A
CH0MAX
16-BIT COMPARATOR
TCH0H:TCH0L
PORT
LOGIC
T[1,2]CH0
CH0F
16-BIT LATCH
CH0IE
MS0A
INTERRUPT
LOGIC
MS0B
INTERNAL BUS
TOV1
CHANNEL 1
ELS1B
ELS1A
CH1MAX
PORT
LOGIC
T[1,2]CH1
16-BIT COMPARATOR
TCH1H:TCH1L
CH1F
16-BIT LATCH
MS1A
CH1IE
INTERRUPT
LOGIC
Figure 18-1. TIM Block Diagram
MOTOROLA
Data Sheet
245
DDRA
PORTA
PORTB
PTB7/AD7
PTB6/AD6
PTB5/AD5
PTB4/AD4
PTB3/AD3
PTB2/AD2
PTB1/AD1
PTB0/AD0
PTC6(1)
PTC5(1)
PTC4(1), (2)
PTC3(1), (2)
PTC2(1), (2)
PTC1(1), (2)
PTC0(1), (2)
PTD7/T2CH1(1)
PTD6/T2CH0(1)
PTD5/T1CH1(1)
PTD4/T1CH0(1)
PTD3/SPSCK(1)
PTD2/MOSI(1)
PTD1/MISO(1)
PTD0/SS(1)
PTE5–PTE2
PTE1/RxD
PTE0/TxD
SINGLE BREAKPOINT
BREAK MODULE
DUAL VOLTAGE
LOW-VOLTAGE INHIBIT
MODULE
DDRB
8-BIT KEYBOARD
INTERRUPT MODULE
OSC1
OSC2
ENHANCED SERIAL
COMUNICATIONS
INTERFACE MODULE
PHASE LOCKED LOOP
COMPUTER OPERATING
PROPERLY MODULE
RST(3)
SYSTEM INTEGRATION
MODULE
SERIAL PERIPHERAL
INTERFACE MODULE
IRQ(3)
SINGLE EXTERNAL
INTERRUPT MODULE
MONITOR MODULE
CONVERTER MODULE
DATA BUS SWITCH
MODULE
POWER-ON RESET
MODULE
MEMORY MAP
MODULE
POWER
CONFIGURATION
REGISTER 1–2
MODULE
CGMXFC
VDDAD/VREFH
VDDAD/VREFL
MOTOROLA
VDD
VSS
VDDA
VSSA
DDRC
2-CHANNEL TIMER
INTERFACE MODULE 2
DDRD
2-CHANNEL TIMER
INTERFACE MODULE 1
DDRE
PORTC
MODULE
PORTD
ARITHMETIC/LOGIC
UNIT (ALU)
PORTE
CPU
REGISTERS
SECURITY
MODULE
MONITOR MODE ENTRY
MODULE
Figure 18-2. Block Diagram Highlighting TIM Blocks and Pins
Data Sheet
246
INTERNAL BUS
M68HC08 CPU
Features
18.2 Features
Features of the TIM include:
Two input capture/output compare channels:
– Rising-edge, falling-edge, or any-edge input capture trigger
– Set, clear, or toggle output compare action
Buffered and unbuffered pulse-width-modulation (PWM) signal generation
Programmable TIM clock input with 7-frequency internal bus clock prescaler
selection
Free-running or modulo up-count operation
Toggle any channel pin on overflow
TIM counter stop and reset bits
18.3 Pin Name Conventions
The text that follows describes both timers, TIM1 and TIM2. The TIM input/output
(I/O) pin names are T[1,2]CH0 (timer channel 0) and T[1,2]CH1 (timer channel 1),
where “1” is used to indicate TIM1 and “2” is used to indicate TIM2. The two TIMs
share four I/O pins with four port D I/O port pins. The full names of the TIM I/O pins
are listed in Table 18-1. The generic pin names appear in the text that follows.
Table 18-1. Pin Name Conventions
TIM Generic Pin Names:
T[1,2]CH0
T[1,2]CH1
TIM1
PTD4/T1CH0
PTD5/T1CH1
TIM2
PTD6/T2CH0
PTD7/T2CH1
Full TIM Pin Names:
NOTE:
References to either timer 1 or timer 2 may be made in the following text by omitting
the timer number. For example, TCH0 may refer generically to T1CH0 and T2CH0,
and TCH1 may refer to T1CH1 and T2CH1.
18.4 Functional Description
Figure 18-1 shows the structure of the TIM. The central component of the TIM is
the 16-bit TIM counter that can operate as a free-running counter or a modulo
up-counter. The TIM counter provides the timing reference for the input capture
and output compare functions. The TIM counter modulo registers,
TMODH:TMODL, control the modulo value of the TIM counter. Software can read
the TIM counter value at any time without affecting the counting sequence.
The two TIM channels (per timer) are programmable independently as input
capture or output compare channels. If a channel is configured as input capture,
MOTOROLA
Data Sheet
247
then an internal pullup device may be enabled for that channel. See 12.5.3 Port D
Figure 18-3 summarizes the timer registers.
NOTE:
Addr.
the timer number. For example, TSC may generically refer to both T1SC and
T2SC.
Register Name
Bit 7
6
5
TOIE
TSTOP
4
3
1
Bit 0
PS2
PS1
PS0
Timer 1 Status and Control Read:
Register (T1SC) Write:
See page 256. Reset:
TOF
Timer 1 Counter Read:
Register High (T1CNTH) Write:
See page 258. Reset:
Bit 15
14
13
12
11
10
9
Bit 8
Bit 7
6
5
4
3
2
1
Bit 0
$0022
Register Low (T1CNTL) Write:
$0023
Timer 1 Counter Modulo Read:
Register High (T1MODH) Write:
Bit 15
14
13
12
11
10
9
Bit 8
1
1
1
1
1
1
1
1
Bit 7
6
5
4
3
2
1
Bit 0
1
1
1
1
1
1
1
1
CH0IE
MS0B
MS0A
ELS0B
ELS0A
TOV0
CH0MAX
Bit 15
14
13
12
11
10
9
Bit 8
2
1
Bit 0
$0020
$0021
Register Low (T1MODL) Write:
See page 259. Reset:
$0024
Timer 1 Channel 0 Status and Read:
$0025
Control Register (T1SC0) Write:
$0026
Timer 1 Channel 0 Read:
Register High (T1CH0H) Write:
See page 262. Reset:
$0027
Register Low (T1CH0L) Write:
$0028
Timer 1 Channel 1 Status and Read:
Control Register (T1SC1) Write:
$0029
Timer 1 Channel 1 Read:
Register High (T1CH1H) Write:
CH0F
TRST
Indeterminate after reset
Bit 7
6
5
4
3
CH1F
CH1IE
MS1A
ELS1B
ELS1A
TOV1
CH1MAX
Bit 15
14
13
12
11
10
9
Bit 8
= Unimplemented
Figure 18-3. TIM I/O Register Summary (Sheet 1 of 2)
Data Sheet
248
MOTOROLA
Addr.
$002A
Register Name
Register Low (T1CH1L) Write:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
PS2
PS1
PS0
Timer 2 Status and Control Read:
Register (T2SC) Write:
TOF
TOIE
TSTOP
Timer 2 Counter Read:
Register High (T2CNTH) Write:
Bit 15
14
13
12
11
10
9
Bit 8
Bit 7
6
5
4
3
2
1
Bit 0
$002D
Register Low (T2CNTL) Write:
$002E
Timer 2 Counter Modulo Read:
Register High (T2MODH) Write:
Bit 15
14
13
12
11
10
9
Bit 8
1
1
1
1
1
1
1
1
Bit 7
6
5
4
3
2
1
Bit 0
1
1
1
1
1
1
1
1
CH0IE
MS0B
MS0A
ELS0B
ELS0A
TOV0
CH0MAX
Bit 15
14
13
12
11
10
9
Bit 8
2
1
Bit 0
$002B
$002C
$002F
Register Low (T2MODL) Write:
Timer 2 Channel 0 Status and Read:
$0030
Control Register (T2SC0) Write:
$0031
Timer 2 Channel 0 Read:
Register High (T2CH0H) Write:
$0032
Register Low (T2CH0L) Write:
$0033
$0034
$0035
Timer 2 Channel 1 Status and Read:
Control Register (T2SC1) Write:
Timer 2 Channel 1 Read:
Register High (T2CH1H) Write:
Register Low (T2CH1L) Write:
CH0F
TRST
Bit 7
6
5
4
3
CH1F
CH1IE
MS1A
ELS1B
ELS1A
TOV1
CH1MAX
Bit 15
14
13
12
11
10
9
Bit 8
2
1
Bit 0
Bit 7
6
5
4
3
= Unimplemented
Figure 18-3. TIM I/O Register Summary (Sheet 2 of 2)
MOTOROLA
Data Sheet
249
18.4.1 TIM Counter Prescaler
The TIM clock source can be one of the seven prescaler outputs. The prescaler
generates seven clock rates from the internal bus clock. The prescaler select bits,
PS[2:0], in the TIM status and control register select the TIM clock source.
18.4.2 Input Capture
With the input capture function, the TIM can capture the time at which an external
event occurs. When an active edge occurs on the pin of an input capture channel,
the TIM latches the contents of the TIM counter into the TIM channel registers,
TCHxH:TCHxL. The polarity of the active edge is programmable. Input captures
can generate TIM CPU interrupt requests.
18.4.3 Output Compare
With the output compare function, the TIM can generate a periodic pulse with a
programmable polarity, duration, and frequency. When the counter reaches the
value in the registers of an output compare channel, the TIM can set, clear, or
toggle the channel pin. Output compares can generate TIM CPU interrupt
requests.
18.4.3.1 Unbuffered Output Compare
Any output compare channel can generate unbuffered output compare pulses as
described in 18.4.3 Output Compare. The pulses are unbuffered because
changing the output compare value requires writing the new value over the old
value currently in the TIM channel registers.
An unsynchronized write to the TIM channel registers to change an output compare
value could cause incorrect operation for up to two counter overflow periods. For
example, writing a new value before the counter reaches the old value but after the
counter reaches the new value prevents any compare during that counter overflow
period. Also, using a TIM overflow interrupt routine to write a new, smaller output
compare value may cause the compare to be missed. The TIM may pass the new
value before it is written.
Use the following methods to synchronize unbuffered changes in the output
compare value on channel x:
When changing to a smaller value, enable channel x output compare
interrupts and write the new value in the output compare interrupt routine.
The output compare interrupt occurs at the end of the current output
compare pulse. The interrupt routine has until the end of the counter
overflow period to write the new value.
When changing to a larger output compare value, enable TIM overflow
interrupts and write the new value in the TIM overflow interrupt routine. The
TIM overflow interrupt occurs at the end of the current counter overflow
Data Sheet
250
MOTOROLA
period. Writing a larger value in an output compare interrupt routine (at the
end of the current pulse) could cause two output compares to occur in the
same counter overflow period.
18.4.3.2 Buffered Output Compare
Channels 0 and 1 can be linked to form a buffered output compare channel whose
output appears on the TCH0 pin. The TIM channel registers of the linked pair
alternately control the output.
Setting the MS0B bit in TIM channel 0 status and control register (TSC0) links
channel 0 and channel 1. The output compare value in the TIM channel 0 registers
initially controls the output on the TCH0 pin. Writing to the TIM channel 1 registers
enables the TIM channel 1 registers to synchronously control the output after the
TIM overflows. At each subsequent overflow, the TIM channel registers (0 or 1) that
control the output are the ones written to last. TSC0 controls and monitors the
buffered output compare function, and TIM channel 1 status and control register
(TSC1) is unused. While the MS0B bit is set, the channel 1 pin, TCH1, is available
as a general-purpose I/O pin.
NOTE:
In buffered output compare operation, do not write new output compare values to
the currently active channel registers. User software should track the currently
active channel to prevent writing a new value to the active channel. Writing to the
active channel registers is the same as generating unbuffered output compares.
18.4.4 Pulse Width Modulation (PWM)
By using the toggle-on-overflow feature with an output compare channel, the TIM
can generate a PWM signal. The value in the TIM counter modulo registers
determines the period of the PWM signal. The channel pin toggles when the
counter reaches the value in the TIM counter modulo registers. The time between
overflows is the period of the PWM signal.
As Figure 18-4 shows, the output compare value in the TIM channel registers
determines the pulse width of the PWM signal. The time between overflow and
output compare is the pulse width. Program the TIM to clear the channel pin on
output compare if the state of the PWM pulse is logic 1. Program the TIM to set the
pin if the state of the PWM pulse is logic 0.
The value in the TIM counter modulo registers and the selected prescaler output
determines the frequency of the PWM output. The frequency of an 8-bit PWM
signal is variable in 256 increments. Writing $00FF (255) to the TIM counter
modulo registers produces a PWM period of 256 times the internal bus clock period
if the prescaler select value is $000. See 18.9.1 TIM Status and Control Register.
MOTOROLA
Data Sheet
251
OVERFLOW
OVERFLOW
OVERFLOW
PERIOD
PULSE
WIDTH
TCHx
OUTPUT
COMPARE
OUTPUT
COMPARE
OUTPUT
COMPARE
Figure 18-4. PWM Period and Pulse Width
The value in the TIM channel registers determines the pulse width of the PWM
output. The pulse width of an 8-bit PWM signal is variable in 256 increments.
Writing $0080 (128) to the TIM channel registers produces a duty cycle of 128/256
or 50%.
18.4.4.1 Unbuffered PWM Signal Generation
Any output compare channel can generate unbuffered PWM pulses as described
in 18.4.4 Pulse Width Modulation (PWM). The pulses are unbuffered because
changing the pulse width requires writing the new pulse width value over the old
An unsynchronized write to the TIM channel registers to change a pulse width
value could cause incorrect operation for up to two PWM periods. For example,
writing a new value before the counter reaches the old value but after the counter
reaches the new value prevents any compare during that PWM period. Also, using
a TIM overflow interrupt routine to write a new, smaller pulse width value may
cause the compare to be missed. The TIM may pass the new value before it is
written.
Use the following methods to synchronize unbuffered changes in the PWM pulse
width on channel x:
When changing to a shorter pulse width, enable channel x output compare
The output compare interrupt occurs at the end of the current pulse. The
interrupt routine has until the end of the PWM period to write the new value.
When changing to a longer pulse width, enable TIM overflow interrupts and
write the new value in the TIM overflow interrupt routine. The TIM overflow
interrupt occurs at the end of the current PWM period. Writing a larger value
in an output compare interrupt routine (at the end of the current pulse) could
cause two output compares to occur in the same PWM period.
Data Sheet
252
MOTOROLA
NOTE:
In PWM signal generation, do not program the PWM channel to toggle on output
compare. Toggling on output compare prevents reliable 0% duty cycle generation
and removes the ability of the channel to self-correct in the event of software error
or noise. Toggling on output compare also can cause incorrect PWM signal
generation when changing the PWM pulse width to a new, much larger value.
18.4.4.2 Buffered PWM Signal Generation
Channels 0 and 1 can be linked to form a buffered PWM channel whose output
appears on the TCH0 pin. The TIM channel registers of the linked pair alternately
control the pulse width of the output.
channel 0 and channel 1. The TIM channel 0 registers initially control the pulse
width on the TCH0 pin. Writing to the TIM channel 1 registers enables the TIM
channel 1 registers to synchronously control the pulse width at the beginning of the
next PWM period. At each subsequent overflow, the TIM channel registers (0 or 1)
that control the pulse width are the ones written to last. TSC0 controls and monitors
the buffered PWM function, and TIM channel 1 status and control register (TSC1)
is unused. While the MS0B bit is set, the channel 1 pin, TCH1, is available as a
NOTE:
In buffered PWM signal generation, do not write new pulse width values to the
currently active channel registers. User software should track the currently active
channel to prevent writing a new value to the active channel. Writing to the active
channel registers is the same as generating unbuffered PWM signals.
18.4.4.3 PWM Initialization
To ensure correct operation when generating unbuffered or buffered PWM signals,
use the following initialization procedure:
1. In the TIM status and control register (TSC):
a. Stop the TIM counter by setting the TIM stop bit, TSTOP.
b. Reset the TIM counter and prescaler by setting the TIM reset bit,
TRST.
2. In the TIM counter modulo registers (TMODH:TMODL), write the value for
the required PWM period.
3. In the TIM channel x registers (TCHxH:TCHxL), write the value for the
required pulse width.
4. In TIM channel x status and control register (TSCx):
a. Write 0:1 (for unbuffered output compare or PWM signals) or 1:0 (for
buffered output compare or PWM signals) to the mode select bits,
MSxB:MSxA. See Table 18-3.
b. Write 1 to the toggle-on-overflow bit, TOVx.
MOTOROLA
Data Sheet
253
c. Write 1:0 (to clear output on compare) or 1:1 (to set output on compare)
to the edge/level select bits, ELSxB:ELSxA. The output action on
compare must force the output to the complement of the pulse width
level. See Table 18-3.
NOTE:
or noise. Toggling on output compare can also cause incorrect PWM signal
5. In the TIM status control register (TSC), clear the TIM stop bit, TSTOP.
Setting MS0B links channels 0 and 1 and configures them for buffered PWM
operation. The TIM channel 0 registers (TCH0H:TCH0L) initially control the
buffered PWM output. TIM status control register 0 (TSCR0) controls and monitors
the PWM signal from the linked channels.
Clearing the toggle-on-overflow bit, TOVx, inhibits output toggles on TIM overflows.
Subsequent output compares try to force the output to a state it is already in and
have no effect. The result is a 0% duty cycle output.
Setting the channel x maximum duty cycle bit (CHxMAX) and setting the TOVx bit
generates a 100% duty cycle output. See 18.9.4 TIM Channel Status and Control
Registers.
18.5 Interrupts
The following TIM sources can generate interrupt requests:
TIM overflow flag (TOF) — The TOF bit is set when the TIM counter reaches
the modulo value programmed in the TIM counter modulo registers. The TIM
overflow interrupt enable bit, TOIE, enables TIM overflow CPU interrupt
requests. TOF and TOIE are in the TIM status and control register.
TIM channel flags (CH1F:CH0F) — The CHxF bit is set when an input
capture or output compare occurs on channel x. Channel x TIM CPU
interrupt requests are controlled by the channel x interrupt enable bit,
CHxIE. Channel x TIM CPU interrupt requests are enabled when
CHxIE = 1. CHxF and CHxIE are in the TIM channel x status and control
register.
Data Sheet
254
MOTOROLA
Low-Power Modes
18.6 Low-Power Modes
modes.
18.6.1 Wait Mode
The TIM remains active after the execution of a WAIT instruction. In wait mode, the
TIM registers are not accessible by the CPU. Any enabled CPU interrupt request
from the TIM can bring the MCU out of wait mode.
If TIM functions are not required during wait mode, reduce power consumption by
stopping the TIM before executing the WAIT instruction.
18.6.2 Stop Mode
The TIM is inactive after the execution of a STOP instruction. The STOP instruction
does not affect register conditions or the state of the TIM counter. TIM operation
resumes when the MCU exits stop mode after an external interrupt.
18.7 TIM During Break Interrupts
A break interrupt stops the TIM counter.
15.7.3 Break Flag Control Register.
the break, the bit cannot change during the break state as long as BCFE is at logic
18.8 I/O Signals
Port D shares four of its pins with the TIM. The four TIM channel I/O pins are
T1CH0, T1CH1, T2CH0, and T2CH1 as described in 18.3 Pin Name
Conventions.
Each channel I/O pin is programmable independently as an input capture pin or an
output compare pin. T1CH0 and T2CH0 can be configured as buffered output
compare or buffered PWM pins.
MOTOROLA
Data Sheet
255
18.9 I/O Registers
NOTE:
the timer number. For example, TSC may generically refer to both T1SC AND
T2SC.
These I/O registers control and monitor operation of the TIM:
TIM counter registers (TCNTH:TCNTL)
TIM channel status and control registers (TSC0 and TSC1)
TIM channel registers (TCH0H:TCH0L, TCH1H:TCH1L)
The TIM status and control register (TSC):
Enables TIM overflow interrupts
Flags TIM overflows
Stops the TIM counter
Resets the TIM counter
Prescales the TIM counter clock
Address: T1SC, $0020 and T2SC, $002B
Bit 7
Read:
TOF
Write:
Reset:
5
TOIE
TSTOP
4
3
TRST
1
Bit 0
PS2
PS1
PS0
= Unimplemented
Figure 18-5. TIM Status and Control Register (TSC)
TOF — TIM Overflow Flag Bit
This read/write flag is set when the TIM counter reaches the modulo value
programmed in the TIM counter modulo registers. Clear TOF by reading the TIM
status and control register when TOF is set and then writing a logic 0 to TOF.
If another TIM overflow occurs before the clearing sequence is complete, then
writing logic 0 to TOF has no effect. Therefore, a TOF interrupt request cannot
be lost due to inadvertent clearing of TOF. Reset clears the TOF bit. Writing a
logic 1 to TOF has no effect.
1 = TIM counter has reached modulo value
0 = TIM counter has not reached modulo value
Data Sheet
256
MOTOROLA
I/O Registers
TOIE — TIM Overflow Interrupt Enable Bit
This read/write bit enables TIM overflow interrupts when the TOF bit becomes
set. Reset clears the TOIE bit.
1 = TIM overflow interrupts enabled
0 = TIM overflow interrupts disabled
TSTOP — TIM Stop Bit
This read/write bit stops the TIM counter. Counting resumes when TSTOP is
cleared. Reset sets the TSTOP bit, stopping the TIM counter until software
clears the TSTOP bit.
1 = TIM counter stopped
0 = TIM counter active
NOTE:
Do not set the TSTOP bit before entering wait mode if the TIM is required to exit
wait mode.
TRST — TIM Reset Bit
Setting this write-only bit resets the TIM counter and the TIM prescaler. Setting
TRST has no effect on any other registers. Counting resumes from $0000.
TRST is cleared automatically after the TIM counter is reset and always reads
as logic 0. Reset clears the TRST bit.
1 = Prescaler and TIM counter cleared
0 = No effect
NOTE:
Setting the TSTOP and TRST bits simultaneously stops the TIM counter at a value
of $0000.
PS[2:0] — Prescaler Select Bits
These read/write bits select one of the seven prescaler outputs as the input to
the TIM counter as Table 18-2 shows. Reset clears the PS[2:0] bits.
Table 18-2. Prescaler Selection
PS2
PS1
PS0
Internal bus clock ÷ 1
Internal bus clock ÷ 2
Internal bus clock ÷ 4
1
Internal bus clock ÷ 8
1
Internal bus clock ÷ 16
1
Internal bus clock ÷ 32
1
1
Internal bus clock ÷ 64
1
1
1
Not available
MOTOROLA
TIM Clock Source
Data Sheet
257
18.9.2 TIM Counter Registers
The two read-only TIM counter registers contain the high and low bytes of the value
in the TIM counter. Reading the high byte (TCNTH) latches the contents of the low
byte (TCNTL) into a buffer. Subsequent reads of TCNTH do not affect the latched
TCNTL value until TCNTL is read. Reset clears the TIM counter registers. Setting
the TIM reset bit (TRST) also clears the TIM counter registers.
NOTE:
If you read TCNTH during a break interrupt, be sure to unlatch TCNTL by reading
TCNTL before exiting the break interrupt. Otherwise, TCNTL retains the value
latched during the break.
Address: T1CNTH, $0021 and T2CNTH, $002C
Read:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
Write:
Reset:
= Unimplemented
Figure 18-6. TIM Counter Registers High (TCNTH)
Address: T1CNTL, $0022 and T2CNTL, $002D
Read:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
Write:
Reset:
= Unimplemented
Figure 18-7. TIM Counter Registers Low (TCNTL)
18.9.3 TIM Counter Modulo Registers
The read/write TIM modulo registers contain the modulo value for the TIM counter.
When the TIM counter reaches the modulo value, the overflow flag (TOF) becomes
set, and the TIM counter resumes counting from $0000 at the next timer clock.
Writing to the high byte (TMODH) inhibits the TOF bit and overflow interrupts until
the low byte (TMODL) is written. Reset sets the TIM counter modulo registers.
Address: T1MODH, $0023 and T2MODH, $002E
Read:
Write:
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
1
1
1
1
1
1
1
1
Figure 18-8. TIM Counter Modulo Register High (TMODH)
Data Sheet
258
MC68HC908GR16 — Rev. 1.0
MOTOROLA
I/O Registers
Address: T1MODL, $0024 and T2MODL, $002F
Read:
Write:
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
1
1
1
1
1
1
1
1
Figure 18-9. TIM Counter Modulo Register Low (TMODL)
NOTE:
Reset the TIM counter before writing to the TIM counter modulo registers.
18.9.4 TIM Channel Status and Control Registers
Each of the TIM channel status and control registers:
Flags input captures and output compares
Enables input capture and output compare interrupts
Selects input capture, output compare, or PWM operation
Selects high, low, or toggling output on output compare
Selects rising edge, falling edge, or any edge as the active input capture
trigger
Selects output toggling on TIM overflow
Selects 0% and 100% PWM duty cycle
Selects buffered or unbuffered output compare/PWM operation
Address: T1SC0, $0025 and T2SC0, $0030
Bit 7
Read:
CH0F
Write:
Reset:
5
4
3
2
1
Bit 0
CH0IE
MS0B
MS0A
ELS0B
ELS0A
TOV0
CH0MAX
Figure 18-10. TIM Channel 0 Status and Control Register (TSC0)
Address: T1SC1, $0028 and T2SC1, $0033
Bit 7
Read:
CH1F
Write:
Reset:
CH1IE
3
2
1
Bit 0
MS1A
ELS1B
ELS1A
TOV1
CH1MAX
Figure 18-11. TIM Channel 1 Status and Control Register (TSC1)
CHxF — Channel x Flag Bit
When channel x is an input capture channel, this read/write bit is set when an
active edge occurs on the channel x pin. When channel x is an output compare
channel, CHxF is set when the value in the TIM counter registers matches the
value in the TIM channel x registers.
MOTOROLA
Data Sheet
259
When TIM CPU interrupt requests are enabled (CHxIE = 1), clear CHxF by
reading TIM channel x status and control register with CHxF set and then writing
a logic 0 to CHxF. If another interrupt request occurs before the clearing
sequence is complete, then writing logic 0 to CHxF has no effect. Therefore, an
interrupt request cannot be lost due to inadvertent clearing of CHxF.
Reset clears the CHxF bit. Writing a logic 1 to CHxF has no effect.
1 = Input capture or output compare on channel x
0 = No input capture or output compare on channel x
CHxIE — Channel x Interrupt Enable Bit
This read/write bit enables TIM CPU interrupt service requests on channel x.
Reset clears the CHxIE bit.
1 = Channel x CPU interrupt requests enabled
0 = Channel x CPU interrupt requests disabled
MSxB — Mode Select Bit B
This read/write bit selects buffered output compare/PWM operation. MSxB
exists only in the TIM1 channel 0 and TIM2 channel 0 status and control
registers.
Setting MS0B disables the channel 1 status and control register and reverts
TCH1 to general-purpose I/O.
Reset clears the MSxB bit.
1 = Buffered output compare/PWM operation enabled
0 = Buffered output compare/PWM operation disabled
MSxA — Mode Select Bit A
When ELSxB:A ≠ 00, this read/write bit selects either input capture operation or
unbuffered output compare/PWM operation. See Table 18-3.
1 = Unbuffered output compare/PWM operation
0 = Input capture operation
When ELSxB:A = 00, this read/write bit selects the initial output level of the
TCHx pin. See Table 18-3. Reset clears the MSxA bit.
1 = Initial output level low
0 = Initial output level high
NOTE:
Before changing a channel function by writing to the MSxB or MSxA bit, set the
TSTOP and TRST bits in the TIM status and control register (TSC).
ELSxB and ELSxA — Edge/Level Select Bits
When channel x is an input capture channel, these read/write bits control the
active edge-sensing logic on channel x.
When channel x is an output compare channel, ELSxB and ELSxA control the
channel x output behavior when an output compare occurs.
When ELSxB and ELSxA are both clear, channel x is not connected to port D,
and pin PTDx/TCHx is available as a general-purpose I/O pin. Table 18-3
shows how ELSxB and ELSxA work. Reset clears the ELSxB and ELSxA bits.
Data Sheet
260
MOTOROLA
I/O Registers
Table 18-3. Mode, Edge, and Level Selection
NOTE:
MSxB:MSxA
ELSxB:ELSxA
Mode
Configuration
X0
00
Pin under port control; initial output level high
X1
00
Output
preset
00
01
00
10
00
11
01
01
01
10
01
11
1X
01
1X
10
1X
11
Pin under port control; initial output level low
Capture on rising edge only
Input
capture
Capture on falling edge only
Capture on rising or falling edge
Toggle output on compare
Output compare
Clear output on compare
or PWM
Set output on compare
Buffered output
compare
or buffered
PWM
Before enabling a TIM channel register for input capture operation, make sure that
the PTD/TCHx pin is stable for at least two bus clocks.
TOVx — Toggle On Overflow Bit
When channel x is an output compare channel, this read/write bit controls the
behavior of the channel x output when the TIM counter overflows. When
channel x is an input capture channel, TOVx has no effect. Reset clears the
TOVx bit.
1 = Channel x pin toggles on TIM counter overflow.
0 = Channel x pin does not toggle on TIM counter overflow.
NOTE:
When TOVx is set, a TIM counter overflow takes precedence over a channel x
output compare if both occur at the same time.
CHxMAX — Channel x Maximum Duty Cycle Bit
When the TOVx bit is at logic 1, setting the CHxMAX bit forces the duty cycle of
buffered and unbuffered PWM signals to 100%. As Figure 18-12 shows, the
CHxMAX bit takes effect in the cycle after it is set or cleared. The output stays
at the 100% duty cycle level until the cycle after CHxMAX is cleared.
OVERFLOW
OVERFLOW
OVERFLOW
OVERFLOW
OVERFLOW
PERIOD
TCHx
OUTPUT
COMPARE
OUTPUT
COMPARE
OUTPUT
COMPARE
OUTPUT
COMPARE
CHxMAX
Figure 18-12. CHxMAX Latency
MOTOROLA
Data Sheet
261
18.9.5 TIM Channel Registers
These read/write registers contain the captured TIM counter value of the input
capture function or the output compare value of the output compare function. The
state of the TIM channel registers after reset is unknown.
In input capture mode (MSxB:MSxA = 0:0), reading the high byte of the TIM
channel x registers (TCHxH) inhibits input captures until the low byte (TCHxL) is
read.
In output compare mode (MSxB:MSxA ≠ 0:0), writing to the high byte of the TIM
channel x registers (TCHxH) inhibits output compares until the low byte (TCHxL) is
written.
Address: T1CH0H, $0026 and T2CH0H, $0031
Read:
Write:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
Reset:
Figure 18-13. TIM Channel 0 Register High (TCH0H)
Address: T1CH0L, $0027 and T2CH0L $0032
Read:
Write:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
Reset:
Figure 18-14. TIM Channel 0 Register Low (TCH0L)
Address: T1CH1H, $0029 and T2CH1H, $0034
Read:
Write:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
14
13
12
11
10
9
Bit 8
Reset:
Figure 18-15. TIM Channel 1 Register High (TCH1H)
Address: T1CH1L, $002A and T2CH1L, $0035
Read:
Write:
Reset:
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
6
5
4
3
2
1
Bit 0
Figure 18-16. TIM Channel 1 Register Low (TCH1L)
Data Sheet
262
MOTOROLA
Section 19. Development Support
19.1 Introduction
This section describes the break module, the monitor read-only memory (MON),
and the monitor mode entry methods.
19.2 Break Module (BRK)
This subsection describes the break module. The break module can generate a
break interrupt that stops normal program flow at a defined address to enter a
background program.
Features of the break module include:
Accessible input/output (I/O) registers during the break Interrupt
Central processor unit (CPU) generated break interrupts
Software-generated break interrupts
Computer operating properly (COP) disabling during break interrupts
19.2.1 Functional Description
When the internal address bus matches the value written in the break address
registers, the break module issues a breakpoint signal (BKPT) to the system
integration module (SIM). The SIM then causes the CPU to load the instruction
register with a software interrupt instruction (SWI) after completion of the current
CPU instruction. The program counter vectors to $FFFC and $FFFD ($FEFC and
$FEFD in monitor mode).
The following events can cause a break interrupt to occur:
A CPU generated address (the address in the program counter) matches
the contents of the break address registers.
Software writes a logic 1 to the BRKA bit in the break status and control
register.
When a CPU generated address matches the contents of the break address
registers, the break interrupt begins after the CPU completes its current instruction.
A return-from-interrupt instruction (RTI) in the break routine ends the break
interrupt and returns the microcontroller unit (MCU) to normal operation.
Figure 19-1 shows the structure of the break module.
Figure 19-2 provides a summary of the I/O registers.
MOTOROLA
Data Sheet
Development Support
263
Development Support
ADDRESS BUS[15:8]
BREAK ADDRESS REGISTER HIGH
8-BIT COMPARATOR
ADDRESS BUS[15:0]
BKPT
(TO SIM)
CONTROL
8-BIT COMPARATOR
BREAK ADDRESS REGISTER LOW
ADDRESS BUS[7:0]
Figure 19-1. Break Module Block Diagram
Addr.
Register Name
$FE00
Break Status Register Read:
(BSR) Write:
See page 267. Reset:
$FE02
$FE03
$FE09
Break Auxiliary Register Read:
(BRKAR) Write:
Break Flag Control Read:
Register (BFCR) Write:
See page 268.
Reset:
Break Address High Read:
Register (BRKH) Write:
See page 266. Reset:
$FE0A
Break Address Low Read:
Register (BRKL) Write:
$FE0B
Break Status and Control Read:
Register (BRKSCR) Write:
1. Writing a logic 0 clears SBSW.
Bit 7
6
5
4
3
2
R
R
R
R
R
R
1
SBSW
Note(1)
Bit 0
R
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Bit 0
BCFE
R
R
R
R
R
R
R
Bit15
Bit14
Bit13
Bit12
Bit11
Bit10
Bit9
Bit8
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Bit 0
BRKE
BRKA
R
= Reserved
= Unimplemented
Figure 19-2. Break I/O Register Summary
Data Sheet
264
Development Support
MOTOROLA
Development Support
Break Module (BRK)
19.2.1.1 Flag Protection During Break Interrupts
The system integration module (SIM) controls whether or not module status bits
can be cleared during the break state. The BCFE bit in the break flag control
register (BFCR) enables software to clear status bits during the break state. See
15.7.3 Break Flag Control Register and the Break Interrupts subsection for
each module.
19.2.1.2 CPU During Break Interrupts
The CPU starts a break interrupt by:
Loading the instruction register with the SWI instruction
Loading the program counter with $FFFC:$FFFD ($FEFC:$FEFD in monitor
mode)
The break interrupt begins after completion of the CPU instruction in progress. If
the break address register match occurs on the last cycle of a CPU instruction, the
break interrupt begins immediately.
19.2.1.3 TIM During Break Interrupts
A break interrupt stops the timer counter.
19.2.1.4 COP During Break Interrupts
The COP is disabled during a break interrupt with monitor mode when BDCOP bit
is set in break auxiliary register (BRKAR).
19.2.2 Break Module Registers
These registers control and monitor operation of the break module:
Break status and control register (BRKSCR)
Break address register high (BRKH)
Break address register low (BRKL)
Break status register (BSR)
Break flag control register (BFCR)
MOTOROLA
Data Sheet
Development Support
265
Development Support
19.2.2.1 Break Status and Control Register
The break status and control register (BRKSCR) contains break module enable
and status bits.
Address: $FE0B
Bit 7
6
BRKE
BRKA
Read:
5
4
3
2
1
Bit 0
Write:
Reset:
= Unimplemented
Figure 19-3. Break Status and Control Register (BRKSCR)
BRKE — Break Enable Bit
This read/write bit enables breaks on break address register matches. Clear
BRKE by writing a logic 0 to bit 7. Reset clears the BRKE bit.
1 = Breaks enabled on 16-bit address match
0 = Breaks disabled
BRKA — Break Active Bit
This read/write status and control bit is set when a break address match occurs.
Writing a logic 1 to BRKA generates a break interrupt. Clear BRKA by writing a
logic 0 to it before exiting the break routine. Reset clears the BRKA bit.
1 = Break address match
0 = No break address match
19.2.2.2 Break Address Registers
The break address registers (BRKH and BRKL) contain the high and low bytes of
the desired breakpoint address. Reset clears the break address registers.
Address: $FE09
Bit 7
6
5
4
3
2
1
Bit 0
Bit 15
Bit 14
Bit 13
Bit 12
Bit 11
Bit 10
Bit 9
Bit 8
Read:
Write:
Reset:
Figure 19-4. Break Address Register High (BRKH)
Address: $FE0A
Bit 7
6
5
4
3
2
1
Bit 0
Bit 7
Bit 6
Bit 5
Bit 4
Bit 3
Bit 2
Bit 1
Bit 0
Read:
Write:
Reset:
Figure 19-5. Break Address Register Low (BRKL)
Data Sheet
266
Development Support
MOTOROLA
Development Support
Break Module (BRK)
19.2.2.3 Break Auxiliary Register
The break auxiliary register (BRKAR) contains a bit that enables software to
disable the COP while the MCU is in a state of break interrupt with monitor mode.
Address: $FE02
Read:
Bit 7
6
5
4
3
2
1
Bit 0
BDCOP
Write:
Reset:
= Unimplemented
Figure 19-6. Break Auxiliary Register (BRKAR)
BDCOP — Break Disable COP Bit
This read/write bit disables the COP during a break interrupt. Reset clears the
BDCOP bit.
1 = COP disabled during break interrupt
0 = COP enabled during break interrupt.
19.2.2.4 Break Status Register
The break status register (BSR) contains a flag to indicate that a break caused an
exit from wait mode. This register is only used in emulation mode.
Address: $FE00
Bit 7
6
5
4
3
2
R
R
R
R
R
R
Read:
1
Bit 0
SBSW
Write:
Note(1)
Reset:
R
= Reserved
R
Figure 19-7. Break Status Register (BSR)
SBSW — SIM Break Stop/Wait
This status bit is useful in applications requiring a return to wait mode after
exiting from a break interrupt. Clear SBSW by writing a logic 0 to it. Reset clears
SBSW.
1 = Wait mode was exited by break interrupt
0 = Wait mode was not exited by break interrupt
SBSW can be read within the break state SWI routine. The user can modify the
return address on the stack by subtracting one from it.
MOTOROLA
Data Sheet
Development Support
267
Development Support
19.2.2.5 Break Flag Control Register
The break control register (BFCR) contains a bit that enables software to clear
status bits while the MCU is in a break state.
Address: $FE03
Bit 7
6
5
4
3
2
1
Bit 0
BCFE
R
R
R
R
R
R
R
Read:
Write:
Reset:
R
= Reserved
Figure 19-8. Break Flag Control Register (BFCR)
BCFE — Break Clear Flag Enable Bit
This read/write bit enables software to clear status bits by accessing status
registers while the MCU is in a break state. To clear status bits during the break
state, the BCFE bit must be set.
1 = Status bits clearable during break
0 = Status bits not clearable during break
19.2.3 Low-Power Modes
modes. If enabled, the break module will remain enabled in wait and stop modes.
However, since the internal address bus does not increment in these modes, a
break interrupt will never be triggered.
19.3 Monitor ROM (MON)
This section describes the monitor ROM (MON) and the monitor mode entry
methods. The monitor ROM allows complete testing of the microcontroller unit
(MCU) through a single-wire interface with a host computer. Monitor mode entry
can be achieved without use of the higher test voltage, VTST, as long as vector
addresses $FFFE and $FFFF are blank, thus reducing the hardware requirements
for in-circuit programming.
Features of the monitor ROM include:
Normal user-mode pin functionality
One pin dedicated to serial communication between monitor read-only
memory (ROM) and host computer
Standard mark/space non-return-to-zero (NRZ) communication with host
computer
Standard communication baud rate (9,600 @ 2.4576-MHz bus frequency)
Data Sheet
268
Development Support
MOTOROLA
Development Support
Monitor ROM (MON)
Execution of code in random-access memory (RAM) or FLASH
FLASH memory security feature(1)
FLASH memory programming interface
350 bytes monitor ROM code size ($FE20 to $FF6A)
Monitor mode entry without high voltage, VTST, if reset vector is blank
($FFFE and $FFFF contain $FF)
Normal monitor mode entry if high voltage is applied to IRQ
19.3.1 Functional Description
Figure 19-9 shows a simplified diagram of the monitor mode.
The monitor ROM receives and executes commands from a host computer.
Figure 19-10 and Figure 19-11 show example circuits used to enter monitor mode
and communicate with a host computer via a standard RS-232 interface.
Simple monitor commands can access any memory address. In monitor mode, the
MCU can execute code downloaded into RAM by a host computer while most MCU
pins retain normal operating mode functions. All communication between the host
computer and the MCU is through the PTA0 pin. A level-shifting and multiplexing
interface is required between PTA0 and the host computer. PTA0 is used in a
wired-OR configuration and requires a pullup resistor.
Table 19-1 shows the pin conditions for entering monitor mode. As specified in the
table, monitor mode may be entered after a power-on reset (POR) and will allow
communication at 14,400 baud provided one of the following sets of conditions is
met:
If $FFFE and $FFFF does not contain $FF (programmed state):
– The external clock is 4.9152 MHz
– PTB4 = low
– IRQ = VTST
If $FFFE and $FFFF do not contain $FF (programmed state):
– The external clock is 9.8304 MHz
– PTB4 = high
– IRQ = VTST
If $FFFE and $FFFF contain $FF (erased state):
– The external clock is 32.768 kHz
– IRQ = VSS
The last two conditions are the forced monitor mode.
1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or
copying the FLASH difficult for unauthorized users.
MOTOROLA
Data Sheet
Development Support
269
Development Support
POR RESET
NO
CONDITIONS
FROM Table 19-1
PTA0 = 1,
PTA1 = 0, RESET
BLANK?
IRQ = VTST?
YES
PTA0 = 1, PTA1 = 0,
PTB0 = 1, AND
PTB1 = 0?
NO
NO
YES
YES
FORCED
MONITOR MODE
NORMAL
USER MODE
NORMAL
MONITOR MODE
FACTORY
USE ONLY
SEND 8 BYTES
SECURITY
IS RESET
POR?
YES
NO
YES
ARE ALL
SECURITY BYTES
CORRECT?
NO
DISABLE FLASH
ENABLE FLASH
MONITOR MODE ENTRY
DEBUGGING
AND FLASH
PROGRAMMING
(IF FLASH
IS ENABLED)
EXECUTE
MONITOR CODE
YES
DOES RESET
OCCUR?
NO
Figure 19-9. Simplified Monitor Mode Entry Flowchart
Data Sheet
270
Development Support
MOTOROLA
Development Support
Monitor ROM (MON)
MC68HC908GR16
N.C.
RST
VDD
47 pF
VDDA
OSC2
MAX232
1
1 µF
4
0.1 µF
C5
10 k
3
IRQ
10 k
PTB1
10 k
C4
74HC125
3
2
9
PTA1
10 kΩ
74HC125
5
6
10
8
PTB0
VDD
DB9
7
1 kΩ
VTST
2
PTB4
V– 6
5 C2–
10 k
C3
V+ 2
C2+
VDD
OSC1
9.8304 MHz
GND 15
C1–
10 MΩ
27 pF
16
3
1 µF
VDD
VCC
C1+
VDD
PTA0
VSSA
VSS
4
1
5
Figure 19-10. Normal Monitor Mode Circuit
MC68HC908GR16
N.C.
RST
47 pF
OSC2
MAX232
1
1 µF
4
VCC
GND 15
C2+
V+ 2
5 C2–
0.1 µF
C5
C3
N.C.
9
N.C.
PTB0
N.C.
PTB1
N.C.
10 k
74HC125
5
6
10
8
PTB4
C4
DB9
3
IRQ
VDD
V– 6
7
OSC1
9.8304 MHz
2
VDDA
10 MΩ
27 pF
16
C1–
VDD
VDD
3
1 µF
C1+
VDD
74HC125
3
2
PTA1
10 kΩ
PTA0
4
VSSA
VSS
1
5
Figure 19-11. Forced Monitor Mode Circuit (IRQ = VDD)
MOTOROLA
Data Sheet
Development Support
271
Development Support
MC68HC908GR16
N.C.
33 pF
RST
VDD
10 k
VDDA
OSC2
MAX232
1
1 µF
C1+
VDD
VCC
0.1 µF
C1–
GND 15
C2+
V+ 2
10 MΩ
15 pF
16
3
C5
OSC1
32.768 kHz
C3
IRQ
4
1 µF
5 C2–
VDD
V– 6
3
7
8
N.C.
PTB0
N.C.
PTB1
N.C.
10 k
74HC125
5
6
10
9
4.7 k
PTB4
C4
DB9
2
VDD
74HC125
3
2
PTA1
10 kΩ
PTA0
VSSA
VSS
4
1
5
Figure 19-12. Forced Monitor Mode Circuit (IRQ = GND)
Enter monitor mode with pin configuration shown in Table 19-1 by pulling RST low
and then high. The rising edge of RST latches monitor mode. Once monitor mode
is latched, the values on the specified pins can change.
Once out of reset, the MCU waits for the host to send eight security bytes (see
19.3.2 Security). After the security bytes, the MCU sends a break signal (10
consecutive logic 0s) to the host, indicating that it is ready to receive a command.
19.3.1.1 Normal Monitor Mode
If VTST is applied to IRQ and PTB4 is low upon monitor mode entry, the bus
frequency is a divide-by-two of the input clock. If PTB4 is high with VTST applied to
IRQ upon monitor mode entry, the bus frequency will be a divide-by-four of the
input clock. Holding the PTB4 pin low when entering monitor mode causes a
bypass of a divide-by-two stage at the oscillator only if VTST is applied to IRQ. In
this event, the CGMOUT frequency is equal to the CGMXCLK frequency, and the
OSC1 input directly generates internal bus clocks. In this case, the OSC1 signal
must have a 50% duty cycle at maximum bus frequency.
When monitor mode was entered with VTST on IRQ, the computer operating
properly (COP) is disabled as long as VTST is applied to either IRQ or RST.
Data Sheet
272
Development Support
MOTOROLA
MOTOROLA
Table 19-1. Monitor Mode Signal Requirements and Options
Mode
Normal
Monitor
IRQ
X
GND
VDD
VTST
or
VTST
VTST
Forced
Monitor
Development Support
User
Reset
RST
Vector
VDD
or
VTST
Divider
PLL
COP
X
X
Communication
Speed
Comments
External
Bus
Baud
Clock
Frequency Rate
X
X
X
Reset condition
PTA1
PTB0
PTB1
PTB4
X
X
X
X
X
X
X
1
OFF Disabled
4.9152
MHz
2.4576
MHz
9600
X
1
OFF Disabled
9.8304
MHz
2.4576
MHz
9600
1
X
X
X
OFF Disabled
16 MHz
4 MHz
9600
1
X
X
X
ON
32.768
kHz
2.4576
MHz
9600
X
X
X
X
X
OFF Enabled
X
X
X
X
X
X
X
X
X
X
X
VDD
VDD VDD
or
or
GND VTST
Mode
Selection
PTA0
$FF
(blank)
$FF
GND VDD
(blank)
VDD VDD
$FF
or
or
(blank)
GND VTST
VDD
Serial
Communication
Not
$FF
X
Disabled
Enabled
User mode —
illegal address reset
MON08
VTST RST
COM
SSEL MOD0 MOD1 DIV4
OSC1
Function
[5]
[8]
[10]
[12]
[14]
[16]
[13]
[6]
[Pin No.]
1. PTA0 must have a pullup resistor to VDD in monitor mode.
2. Communication speed in the table is an example to obtain a baud rate of 9600. Baud rate using external oscillator is bus frequency / 256.
3. External clock is an 32.768 kHz crystal on OSC1 and OSC2 or a 32.768 kHz, 4.9152 MHz, or 9.8304 MHz canned oscillator on OSC1.
4. X = don’t care
5. MON08 pin refers to P&E Microcomputer Systems’ MON08-Cyclone 2 by 8-pin connector.
1
3
5
7
9
11
13
2
4
6
8
10
12
14
GND
RST
IRQ
PTA0
PTA1
PTB0
PTB1
15
16
PTB4
Development Support
Monitor ROM (MON)
Data Sheet
273
NC
NC
NC
NC
NC
NC
OSC1
VDD
Development Support
This condition states that as long as VTST is maintained on the IRQ pin after
entering monitor mode, or if VTST is applied to RST after the initial reset to get into
monitor mode (when VTST was applied to IRQ), then the COP will be disabled. In
the latter situation, after VTST is applied to the RST pin, VTST can be removed from
the IRQ pin in the interest of freeing the IRQ for normal functionality in monitor
mode.
19.3.1.2 Forced Monitor Mode
If entering monitor mode without high voltage on IRQ, then all port B pin
requirements and conditions, including the PTB4 frequency divisor selection, are
not in effect. This is to reduce circuit requirements when performing in-circuit
programming.
NOTE:
Once the reset vector has been programmed, the traditional method of applying a
voltage, VTST, to IRQ must be used to enter monitor mode.
An external oscillator of 9.8304 MHz is required for a baud rate of 9600, as the
internal bus frequency is automatically set to the external frequency divided by
four.
When the forced monitor mode is entered the COP is always disabled regardless
of the state of IRQ or RST.
19.3.1.3 Monitor Vectors
In monitor mode, the MCU uses different vectors for reset, SWI (software interrupt),
and break interrupt than those for user mode. The alternate vectors are in the $FE
page instead of the $FF page and allow code execution from the internal monitor
firmware instead of user code.
Table 19-2 summarizes the differences between user mode and monitor mode.
Table 19-2. Mode Differences
Functions
Modes
Reset
Vector High
Reset
Vector Low
Break
Vector High
Break
Vector Low
SWI
Vector High
SWI
Vector Low
User
$FFFE
$FFFF
$FFFC
$FFFD
$FFFC
$FFFD
Monitor
$FEFE
$FEFF
$FEFC
$FEFD
$FEFC
$FEFD
Data Sheet
274
Development Support
MOTOROLA
Development Support
Monitor ROM (MON)
19.3.1.4 Data Format
Communication with the monitor ROM is in standard non-return-to-zero (NRZ)
mark/space data format. Transmit and receive baud rates must be identical.
START
BIT
BIT 0
BIT 1
BIT 2
BIT 3
BIT 4
BIT 5
BIT 6
BIT 7
STOP
BIT
NEXT
START
BIT
Figure 19-13. Monitor Data Format
19.3.1.5 Break Signal
A start bit (logic 0) followed by nine logic 0 bits is a break signal. When the monitor
receives a break signal, it drives the PTA0 pin high for the duration of two bits and
then echoes back the break signal.
MISSING STOP BIT
2-STOP BIT DELAY BEFORE ZERO ECHO
2
3
4
5
6
7
2
3
4
5
6
7
Figure 19-14. Break Transaction
19.3.1.6 Baud Rate
The communication baud rate is controlled by the crystal frequency or external
clock and the state of the PTB4 pin (when IRQ is set to VTST) upon entry into
monitor mode. If monitor mode was entered with VDD on IRQ and the reset vector
blank, then the baud rate is independent of PTB4.
Table 19-1 also lists external frequencies required to achieve a standard baud rate
of 9600 bps. The effective baud rate is the bus frequency divided by 256. If using
a crystal as the clock source, be aware of the upper frequency limit that the internal
clock module can handle. See 20.7 5.0-Volt Control Timing or 20.8 3.3-Volt
Control Timing for this limit.
MOTOROLA
Data Sheet
Development Support
275
Development Support
19.3.1.7 Commands
The monitor ROM firmware uses these commands:
READ (read memory)
WRITE (write memory)
IREAD (indexed read)
IWRITE (indexed write)
READSP (read stack pointer)
RUN (run user program)
The monitor ROM firmware echoes each received byte back to the PTA0 pin for
error checking. An 11-bit delay at the end of each command allows the host to send
a break character to cancel the command. A delay of two bit times occurs before
each echo and before READ, IREAD, or READSP data is returned. The data
returned by a read command appears after the echo of the last byte of the
command.
NOTE:
Wait one bit time after each echo before sending the next byte.
FROM HOST
4
ADDRESS
HIGH
READ
READ
4
1
ADDRESS
HIGH
ADDRESS
LOW
1
4
ADDRESS
LOW
DATA
1
3, 2
4
ECHO
RETURN
Notes:
1 = Echo delay, 2 bit times
2 = Data return delay, 2 bit times
3 = Cancel command delay, 11 bit times
4 = Wait 1 bit time before sending next byte.
Figure 19-15. Read Transaction
FROM HOST
3
ADDRESS
HIGH
WRITE
WRITE
1
3
ADDRESS
HIGH
1
ADDRESS
LOW
3
ADDRESS
LOW
1
DATA
DATA
3
1
2, 3
ECHO
Notes:
2 = Cancel command delay, 11 bit times
3 = Wait 1 bit time before sending next byte.
Figure 19-16. Write Transaction
Data Sheet
276
Development Support
MOTOROLA
Development Support
Monitor ROM (MON)
A brief description of each monitor mode command is given in Table 19-3 through
Table 19-8.
Table 19-3. READ (Read Memory) Command
Description
Read byte from memory
Operand
2-byte address in high-byte:low-byte order
Data Returned
Returns contents of specified address
Opcode
$4A
Command Sequence
SENT TO MONITOR
READ
ADDRESS
HIGH
READ
ADDRESS
HIGH
ADDRESS
LOW
ADDRESS
LOW
DATA
ECHO
RETURN
Table 19-4. WRITE (Write Memory) Command
Description
Operand
Data Returned
Opcode
Write byte to memory
2-byte address in high-byte:low-byte order; low byte followed by data byte
None
$49
Command Sequence
FROM HOST
WRITE
ADDRESS
HIGH
WRITE
ADDRESS
HIGH
ADDRESS
LOW
ADDRESS
LOW
DATA
DATA
ECHO
Table 19-5. IREAD (Indexed Read) Command
Description
Operand
Data Returned
Opcode
Read next 2 bytes in memory from last address accessed
2-byte address in high byte:low byte order
Returns contents of next two addresses
$1A
Command Sequence
FROM HOST
IREAD
IREAD
ECHO
MOTOROLA
DATA
DATA
RETURN
Data Sheet
Development Support
277
Development Support
Table 19-6. IWRITE (Indexed Write) Command
Description
Operand
Data Returned
Opcode
Write to last address accessed + 1
Single data byte
None
$19
Command Sequence
FROM HOST
IWRITE
IWRITE
DATA
DATA
ECHO
A sequence of IREAD or IWRITE commands can access a block of memory
sequentially over the full 64-Kbyte memory map.
Table 19-7. READSP (Read Stack Pointer) Command
Description
Operand
Data Returned
Opcode
Reads stack pointer
None
Returns incremented stack pointer value (SP + 1) in high-byte:low-byte order
$0C
Command Sequence
FROM HOST
READSP
SP
HIGH
READSP
ECHO
SP
LOW
RETURN
Table 19-8. RUN (Run User Program) Command
Description
Executes PULH and RTI instructions
Operand
None
Data Returned
None
Opcode
$28
Command Sequence
FROM HOST
RUN
RUN
ECHO
Data Sheet
278
Development Support
MOTOROLA
Development Support
Monitor ROM (MON)
The MCU executes the SWI and PSHH instructions when it enters monitor mode.
The RUN command tells the MCU to execute the PULH and RTI instructions.
Before sending the RUN command, the host can modify the stacked CPU registers
to prepare to run the host program. The READSP command returns the
incremented stack pointer value, SP + 1. The high and low bytes of the program
counter are at addresses SP + 5 and SP + 6.
SP
HIGH BYTE OF INDEX REGISTER
SP + 1
CONDITION CODE REGISTER
SP + 2
ACCUMULATOR
SP + 3
LOW BYTE OF INDEX REGISTER
SP + 4
HIGH BYTE OF PROGRAM COUNTER
SP + 5
LOW BYTE OF PROGRAM COUNTER
SP + 6
SP + 7
Figure 19-17. Stack Pointer at Monitor Mode Entry
19.3.2 Security
A security feature discourages unauthorized reading of FLASH locations while in
monitor mode. The host can bypass the security feature at monitor mode entry by
sending eight security bytes that match the bytes at locations $FFF6–$FFFD.
Locations $FFF6–$FFFD contain user-defined data.
NOTE:
Do not leave locations $FFF6–$FFFD blank. For security reasons, program
locations $FFF6–$FFFD even if they are not used for vectors.
During monitor mode entry, the MCU waits after the power-on reset for the host to
send the eight security bytes on pin PTA0. If the received bytes match those at
locations $FFF6–$FFFD, the host bypasses the security feature and can read all
FLASH locations and execute code from FLASH. Security remains bypassed until
a power-on reset occurs. If the reset was not a power-on reset, security remains
bypassed and security code entry is not required. See Figure 19-18.
Upon power-on reset, if the received bytes of the security code do not match the
data at locations $FFF6–$FFFD, the host fails to bypass the security feature. The
MCU remains in monitor mode, but reading a FLASH location returns an invalid
value and trying to execute code from FLASH causes an illegal address reset. After
receiving the eight security bytes from the host, the MCU transmits a break
character, signifying that it is ready to receive a command.
NOTE:
The MCU does not transmit a break character until after the host sends the eight
security bytes.
MOTOROLA
Data Sheet
Development Support
279
Development Support
VDD
4096 + 32 CGMXCLK CYCLES
COMMAND
BYTE 8
BYTE 2
BYTE 1
RST
FROM HOST
PA0
4
BYTE 8 ECHO
2
Notes:
5 = Wait until a clock is stable (if PLL is enabled) and the monitor ROM runs
1
COMMAND ECHO
1
BREAK
1
BYTE 2 ECHO
FROM MCU
4
1
BYTE 1 ECHO
5
Figure 19-18. Monitor Mode Entry Timing
To determine whether the security code entered is correct, check to see if bit 6 of
RAM address $40 is set. If it is, then the correct security code has been entered
and FLASH can be accessed.
If the security sequence fails, the device should be reset by a power-on reset and
brought up in monitor mode to attempt another entry. After failing the security
sequence, the FLASH module can also be mass erased by executing an erase
routine that was downloaded into internal RAM. The mass erase operation clears
the security code locations so that all eight security bytes become $FF (blank).
Data Sheet
280
Development Support
MOTOROLA
Section 20. Electrical Specifications
20.1 Introduction
This section contains electrical and timing specifications.
20.2 Absolute Maximum Ratings
Maximum ratings are the extreme limits to which the MCU can be exposed without
permanently damaging it.
NOTE:
This device is not guaranteed to operate properly at the maximum ratings. Refer to
20.5 5.0-Vdc Electrical Characteristics and 20.6 3.3-Vdc Electrical
Characteristics for guaranteed operating conditions.
Characteristic(1)
Symbol
Value
Unit
Supply voltage
VDD
–0.3 to + 6.0
V
Input voltage
VIn
VSS – 0.3 to VDD + 0.3
V
I
± 15
mA
Maximum current for pins
PTC0–PTC4
IPTC0–PTC4
± 25
mA
Maximum current into VDD
Imvdd
150
mA
Maximum current out of VSS
Imvss
150
mA
Storage temperature
Tstg
–55 to +150
°C
Maximum current per pin
excluding those specified below
1. Voltages referenced to VSS
NOTE:
This device contains circuitry to protect the inputs against damage due to high
static voltages or electric fields; however, it is advised that normal precautions be
taken to avoid application of any voltage higher than maximum-rated voltages to
this high-impedance circuit. For proper operation, it is recommended that VIn and
VOut be constrained to the range VSS ≤ (VIn or VOut) ≤ VDD. Reliability of operation
is enhanced if unused inputs are connected to an appropriate logic voltage level
(for example, either VSS or VDD).
MOTOROLA
Data Sheet
281
20.3 Functional Operating Range
Characteristic
Symbol
Value
Unit
TA
–40 to +125
°C
VDD
5.0 ±10%
3.3 ±10%
V
Operating temperature range
Operating voltage range
20.4 Thermal Characteristics
Characteristic
Symbol
Value
Unit
Thermal resistance
32-pin LQFP
48-pin LQFP
θJA
95
95
°C/W
I/O pin power dissipation
PI/O
User determined
W
Power dissipation(1)
PD
PD = (IDD × VDD) + PI/O =
K/(TJ + 273 °C)
W
Constant(2)
K
Average junction temperature
Maximum junction temperature
PD × (TA + 273 °C)
+ PD2 × θJA
W/°C
TJ
TA + (PD × θJA)
°C
TJM
125
°C
1. Power dissipation is a function of temperature.
2. K is a constant unique to the device. K can be determined for a known TA and measured PD.
With this value of K, PD and TJ can be determined for any value of TA.
Data Sheet
282
MOTOROLA
Symbol
Min
Typ(2)
Max
Unit
VOH
VOH
VOH
IOH1
VDD – 0.8
VDD – 1.5
VDD – 1.5
V
V
V
50
mA
IOH2
50
mA
IOHT
100
mA
VOL
VOL
VOL
IOL1
0.4
1.5
1.5
V
V
V
50
mA
IOL2
50
mA
IOLT
100
mA
Input high voltage
All ports, IRQ, RST, OSC1
VIH
0.7 × VDD
VDD
V
Input low voltage
VIL
VSS
0.2 × VDD
V
30
12
mA
mA
3
50
500
µA
µA
µA
µA
µA
Characteristic(1)
Output high voltage
(ILoad = –2.0 mA) all I/O pins
(ILoad = –10.0 mA) all I/O pins
(ILoad = –20.0 mA) pins PTC0–PTC4 only
Maximum combined IOH for port PTA7–PTA3,
port PTC0–PTC1, port E, port PTD0–PTD3
Maximum combined IOH for port PTA2–PTA0,
port B, port PTC2–PTC6, port PTD4–PTD7
Maximum total IOH for all port pins
Output low voltage
(ILoad = 1.6 mA) all I/O pins
(ILoad = 10 mA) all I/O pins
(ILoad = 20 mA) pins PTC0–PTC4 only
Maximum total IOL for all port pins
VDD supply current
Run(3)
Wait(4)
Stop(5)
25°C
25°C with TBM enabled(6)
25°C with LVI and TBM enabled(6)
–40°C to 125°C with TBM enabled(6)
–40°C to 125°C with LVI and TBM enabled(6)
IDD
I/O ports Hi-Z leakage current(7)
IIL
–10
+10
µA
Input current
IIn
–1
+1
µA
Pullup resistors (as input only)
Ports PTA7/KBD7–PTA0/KBD0, PTC6–PTC0,
PTD7/T2CH1–PTD0/SS
RPU
65
kΩ
Capacitance
Ports (as input or output)
COut
CIn
12
8
pF
Monitor mode entry voltage
VTST
VDD + 2.5
VDD + 4.0
V
Continued on next page
MOTOROLA
Data Sheet
283
Symbol
Min
Typ(2)
Max
Unit
Low-voltage inhibit, trip falling voltage
VTRIPF
3.9
4.25
4.50
V
Low-voltage inhibit, trip rising voltage
VTRIPR
4.2
4.35
4.60
V
Low-voltage inhibit reset/recover hysteresis
(VTRIPF + VHYS = VTRIPR)
VHYS
60
mV
POR rearm voltage(8)
VPOR
mV
POR reset voltage(9)
VPORRST
800
mV
RPOR
0.035
V/ms
Characteristic(1)
POR rise time ramp rate(10)
1. VDD = 5.0 Vdc ± 10%, VSS = 0 Vdc, TA = TA (min) to TA (max), unless otherwise noted
2. Typical values reflect average measurements at midpoint of voltage range, 25°C only.
3. Run (operating) IDD measured using external square wave clock source (fOSC = 32 MHz). All inputs 0.2 V from rail. No
dc loads. Less than 100 pF on all outputs. CL = 20 pF on OSC2. All ports configured as inputs. OSC2 capacitance linearly
affects run IDD. Measured with all modules enabled.
4. Wait IDD measured using external square wave clock source (fOSC = 32 MHz). All inputs 0.2 V from rail. No dc loads. Less
than 100 pF on all outputs. CL = 20 pF on OSC2. All ports configured as inputs. OSC2 capacitance linearly affects wait
IDD. Measured with ICG and LVI enabled.
5. Stop IDD is measured with OSC1 = VSS.
6. Stop IDD with TBM enabled is measured using an external square wave clock source (fOSC = 32 MHz). All inputs 0.2 V
from rail. No dc loads. Less than 100 pF on all outputs. All inputs configured as inputs.
7. Pullups and pulldowns are disabled. Port B leakage is specified in 20.13 5.0-Volt ADC Characteristics.
8. Maximum is highest voltage that POR is guaranteed.
9. Maximum is highest voltage that POR is possible.
10. If minimum VDD is not reached before the internal POR reset is released, RST must be driven low externally until minimum
VDD is reached.
Data Sheet
284
MOTOROLA
3.3-Vdc Electrical Characteristics
20.6 3.3-Vdc Electrical Characteristics
Symbol
Min
Typ(2)
Max
Unit
VOH
VOH
VOH
IOH1
VDD – 0.3
VDD – 1.0
VDD – 1.0
V
V
V
30
mA
IOH2
30
mA
IOHT
60
mA
VOL
VOL
VOL
IOL1
0.3
1.0
0.8
V
V
V
30
mA
IOL2
30
mA
IOLT
60
mA
Input high voltage
VIH
0.7 × VDD
VDD
V
Input low voltage
VIL
VSS
0.3 × VDD
V
8
3
12
6
mA
mA
2
12
200
30
300
µA
µA
µA
µA
µA
Characteristic(1)
Output high voltage
(ILoad = –0.6 mA) all I/O pins
(ILoad = –4.0 mA) all I/O pins
(ILoad = –10.0 mA) pins PTC0–PTC4 only
Output low voltage
VDD supply current
Run(3)
Wait(4)
Stop(5)
25°C
IDD
IIL
–10
+10
µA
Input current
IIn
–1
+1
µA
PTD7/T2CH1–PTD0/SS
RPU
65
kΩ
Capacitance
COut
CIn
12
8
pF
VTST
VDD + 2.5
VDD + 4.0
V
MOTOROLA
Data Sheet
285
Symbol
Min
Typ(2)
Max
Unit
VTRIPF
2.35
2.6
2.7
V
VTRIPR
2.4
2.66
2.8
V
VHYS
100
mV
VPOR
mV
VPORRST
800
mV
RPOR
0.02
V/ms
Characteristic(1)
1. VDD = 3.3 Vdc ± 10%, VSS = 0 Vdc, TA = TA (min) to TA (max), unless otherwise noted
3. Run (operating) IDD measured using external square wave clock source (fOSC = 16 MHz). All inputs 0.2 V from rail. No
4. Wait IDD measured using external square wave clock source (fOSC = 16 MHz). All inputs 0.2 V from rail. No dc loads. Less
6. Stop IDD with TBM enabled is measured using an external square wave clock source (fOSC = 16 MHz). All inputs 0.2 V
VDD is reached.
Data Sheet
286
MOTOROLA
Characteristic(1)
Symbol
Min
Max
Unit
fOSC
32
dc
100
32.8
kHz
MHz
Internal operating frequency
fOP (fBus)
8.2
MHz
Internal clock period (1/fOP)
tCYC
122
ns
RESET input pulse width low(3)
tIRL
50
ns
IRQ interrupt pulse width low(4) (edge-triggered)
tILIH
50
ns
IRQ interrupt pulse period
tILIL
Note 5
tCYC
Frequency of operation
Crystal option
External clock option(2)
1. VSS = 0 Vdc; timing shown with respect to 20% VDD and 70% VDD unless otherwise noted.
2. No more than 10% duty cycle deviation from 50%.
3. Minimum pulse width reset is guaranteed to be recognized. It is possible for a smaller pulse width to cause a reset.
4. Minimum pulse width is for guaranteed interrupt. It is possible for a smaller pulse width to be recognized.
20.8 3.3-Volt Control Timing
Characteristic(1)
Symbol
Min
Max
Unit
fOSC
32
dc
100
16.4
kHz
MHz
fOP (fBus)
4.1
MHz
tCYC
244
ns
tIRL
125
ns
tILIH
125
ns
tILIL
Note 5
tCYC
Crystal option
(3)
tRL
RST
tILIL
tILIH
IRQ
Figure 20-1. RST and IRQ Timing
MOTOROLA
Data Sheet
287
20.9 Output High-Voltage Characteristics
–5
IOH (mA)
–10
–40
85
–15
–20
–25
–30
–35
–40
3
3.2
3.4
3.6
VOH (V)
3.8
4.0
4.2
VOH > VDD –0.8 V @ IOH = –2.0 mA
VOH > VDD –1.5 V @ IOH = –10.0 mA
Figure 20-2. Typical High-Side Driver Characteristics –
Port PTA3–PTA0 (VDD = 4.5 Vdc)
IOH (mA)
–5
–40
85
–10
–15
–20
–25
1.3
1.5
1.7
1.9
VOH (V)
2.1
2.3
2.5
VOH > VDD –0.3 V @ IOH = –0.6 mA
VOH > VDD –1.0 V @ IOH = –4.0 mA
Figure 20-3. Typical High-Side Driver Characteristics –
Port PTA3–PTA0 (VDD = 3.0 Vdc)
Data Sheet
288
MOTOROLA
–5
IOH (mA)
–10
–40
85
–15
–20
–25
–30
–35
–40
3
3.2
3.4
3.6
VOH (V)
3.8
4.0
4.2
VOH > VDD –0.8 V @ IOH = –10.0 mA
Figure 20-4. Typical High-Side Driver Characteristics –
Port PTC1–PTC0 (VDD = 4.5 Vdc)
IOH (mA)
–5
–40
85
–10
–15
–20
–25
1.3
1.5
1.7
1.9
VOH (V)
2.1
2.3
2.5
VOH > VDD –0.5 V @ IOH = –4.0 mA
Figure 20-5. Typical High-Side Driver Characteristics –
Port PTC1–PTC0 (VDD = 3.0 Vdc)
MOTOROLA
Data Sheet
289
–10
–20
–40
85
IOH (mA)
–30
–40
–50
–60
–70
–80
–90
3
3.2
3.4
3.6
3.8
VOH (V)
4.0
4.2
4.4
4.6
Figure 20-6. Typical High-Side Driver Characteristics –
Ports PTB5–PTB0, PTD6–PTD0, and
PTE1–PTE0 (VDD = 5.5 Vdc)
IOH (mA)
–5
–40
85
–10
–15
–20
–25
1.3
1.5
1.7
1.9
VOH (V)
2.1
2.3
2.5
Figure 20-7. Typical High-Side Driver Characteristics –
PTE1–PTE0 (VDD = 3.0 Vdc)
Data Sheet
290
MOTOROLA
Output Low-Voltage Characteristics
20.10 Output Low-Voltage Characteristics
35
30
–40
85
IOL (mA)
25
10
5
0.4
0.6
0.8
1.0
VOL (V)
1.2
1.4
1.6
VOL < 0.4 V @ IOL = 1.6 mA
VOL < 1.5 V @ IOL = 10.0 mA
Figure 20-8. Typical Low-Side Driver Characteristics –
Port PTA3–PTA0 (VDD = 5.5 Vdc)
14
12
–40
85
IOL (mA)
10
8
6
4
2
0.4
0.6
0.8
1.0
VOL (V)
1.2
1.4
1.6
VOL < 0.3 V @ IOL = 0.5 mA
VOL < 1.0 V @ IOL = 6.0 mA
Figure 20-9. Typical Low-Side Driver Characteristics –
MOTOROLA
Data Sheet
291
60
IOL (mA)
50
40
–40
85
30
0.6
0.8
1.0
1.2
1.4
1.6
VOL (V)
VOL < 1.0 V @ IOL = 15 mA
Figure 20-10. Typical Low-Side Driver Characteristics –
30
IOL (mA)
25
–40
85
10
5
0.4
0.6
0.8
1.0
VOL (V)
1.2
1.4
1.6
VOL < 0.8 V @ IOL = 10 mA
Figure 20-11. Typical Low-Side Driver Characteristics –
Data Sheet
292
MOTOROLA
35
30
–40
85
IOL (mA)
25
10
5
0.4
0.6
0.8
1.0
VOL (V)
1.2
1.4
1.6
Figure 20-12. Typical Low-Side Driver Characteristics –
14
12
–40
85
IOL (mA)
10
8
6
4
2
0.4
0.6
0.8
1.0
VOL (V)
1.2
1.4
1.6
Figure 20-13. Typical Low-Side Driver Characteristics –
MOTOROLA
Data Sheet
293
20.11 Typical Supply Currents
16
14
12
IDD (mA)
10
8
6
4
5.5 V
3.6 V
2
2
3
4
5
fbus (MHz)
6
7
8
9
Figure 20-14. Typical Operating IDD, with All Modules
Turned On (–40°C to 125°C)
5.0
4.5
4.0
IDD (mA)
3.5
3.0
2.5
2.0
1.5
1.0
5.5 V
3.6 V
0.5
2
3
4
fbus (MHz)
5
6
7
8
Figure 20-15. Typical Wait Mode IDD, with all Modules Disabled
(–40°C to 125°C)
Data Sheet
294
MOTOROLA
Clock Generation Module Characteristics
1.35
1.30
IDD (µA)
1.25
1.20
1.15
1.10
5.5 V
3.6 V
1.05
1
2
3
4
5
fbus (MHz)
6
7
8
9
Figure 20-16. Typical Stop Mode IDD, with all Modules Disabled
(–40°C to 125°C)
20.12 Clock Generation Module Characteristics
20.12.1 CGM Component Specifications
Characteristic
Symbol
Min
Typ
Max
Unit
fXCLK
30
32.768
100
kHz
Crystal load capacitance(1)
CL
pF
Crystal fixed capacitance
C1
6
2 × CL
40
pF
Crystal tuning capacitance
C2
6
2 × CL
40
pF
Feedback bias resistor
RB
10
10
22
MΩ
Series resistor (2)
RS
330
330
470
kΩ
External clock
1. Consult crystal manufacturer’s data.
2. Not required for high-frequency crystals
MOTOROLA
Data Sheet
295
20.12.2 CGM Electrical Specifications
Description
Symbol
Min
Typ
Max
Unit
VDD
3.0
5.5
V
T
–40
25
125
o
Crystal reference frequency
fRCLK
30
32.768
100
kHz
Range nominal multiplier
fNOM
38.4
kHz
VCO center-of-range frequency(1)
fVRS
38.4 k
40.0 M
Hz
Medium-voltage VCO center-of-range frequency(2)
fVRS
38.4 k
40.0 M
Hz
VCO range linear range multiplier
L
1
255
VCO power-of-two range multiplier
2E
1
4
VCO multiply factor
N
1
4095
VCO prescale multiplier
2P
1
1
8
Operating voltage
Reference divider factor
C
R
1
1
15
fVCLK
38.4 k
40.0 M
Hz
Bus operating frequency
fBUS
8.2
MHz
Bus frequency @ medium voltage(2)
fBUS
4.1
MHz
Manual acquisition time
tLock
50
ms
Automatic lock time
tLock
50
ms
fJ
fRCLK x
0.025% x
2P N/4
Hz
External clock input frequency
PLL disabled
fOSC
dc
32.8 M
Hz
PLL enabled
fOSC
30 k
1.5 M
Hz
VCO operating frequency
(1)
PLL jitter(3)
1. 5.0 V ± 10% VDD
2. 3.3 V ± 10% VDD
3. Deviation of average bus frequency over 2 ms. N = VCO multiplier.
Data Sheet
296
MOTOROLA
Characteristic(1)
Symbol
Min
Max
Unit
Comments
Supply voltage
VDDAD
4.5
5.5
V
VDDAD should be tied to
the same potential as VDD
via separate traces.
Input voltages
VADIN
VDDAD
V
VADIN
68HC908GR16 : Microcontroller
The MC68HC908GR16 is a member of the low-cost, high-performance M68HC08 Family of 8-bit
microcontroller units (MCUs). All MCUs in the family use the enhanced M68HC08 central processor unit
(CPU08) and are available with a variety of modules, memory sizes and types, and package types.
Page Contents:
Features
Documentation
Tools
Rich Media
Note: Automotive customers requiring the data book or samples of the Automotive 68HC908GR16
(1 to 8MHz clock) should contact their local automotive marketer.
Orderable Parts
Related Links
Block Diagram
Other Info:
FAQs
3rd Party Design Help
Training
3rd Party Tool
Vendors
68HC908GR16 Features
High-performance M68HC08 architecture optimized for C-compilers
Fully upward-compatible object code with M6805, M146805, and M68HC05 Families
8-MHz internal bus frequency
Clock generation module supporting 32-kHz to 100-kHz crystals
FLASH program memory security
On-chip programming firmware for use with host personal computer which does not require high
voltage for entry
1 Kbyte of on-chip random-access memory (RAM)
Serial peripheral interface (SPI) module
Enhanced serial communications interface (ESCI) module (optimized for LIN)
Two 16-bit timer interface modules (2-channel TIM1 and 2-channel TIM2) with selectable input
capture, output compare, and pulse-width modulation (PWM) capability on each channel
8-channel, 10-bit resolution analog-to-digital converter (ADC)
Internal pullups on IRQ and RST to reduce customer system cost
Up to 37 general-purpose input/output (I/O) pins
Selectable pullups on inputs only on ports A, C, and D
High current 10-mA sink/source capability on all port pins
Higher current 20-mA sink/source capability on PTC0-PTC4
Timebase module (TBM) with clock prescaler circuitry for eight user selectable periodic real-time
interrupts with optional active clock source during stop mode for periodic wakeup from stop using
an external crystal
8-bit keyboard wakeup port
In-system programming (ISP)
System protection features:
❍ Optional computer operating properly (COP) reset
❍ Low-voltage detection with optional reset and selectable trip points for 3.3-V and 5.0-V
operation
❍ Illegal opcode detection with reset
❍ Illegal address detection with reset
Low-power design; fully static with stop and wait modes
Standard low-power modes of operation:
❍ Wait mode
❍ Stop mode
Master rest pin and power-on reset (POR)
Rate this Page
Submit
Care to Comment?
Return to Top
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR16.htm (1 of 7) [28-Nov-03 11:14:14 AM]
68HC908GR16 Product Summary Page
68HC908GR16 Documentation
Documentation
Application Note
ID
Name
AN1050_D
Designing for Electromagnetic Compatibility (EMC) with
HCMOS Microcontrollers
AN1218/D
HC05 to HC08 Optimization
AN1219/D
M68HC08 Integer Math Routines
AN1219SW
Software Files for AN1219 zipped
Vendor ID Format
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
pdf
82
pdf
347
2
1/01/1993
pdf
177
1
1/01/1997
zip
77
63
55
pdf
24
zip
pdf
78
pdf
104
pdf
47
pdf
77
2
1/24/2003
pdf
67
pdf
80
pdf
213
1
5/07/2001
pdf
250
pdf
86
1
1/01/1998
pdf
48
1
1/01/1999
pdf
84
pdf
55
zip
2
pdf
116
pdf
36
pdf
741
zip
31
AN1221SW
Hamming Error Control Coding Techniques with the HC08 MOTOROLA
pdf
MCU
MOTOROLA
Software Files for AN1221 zipped
zip
AN1222/D
Arithmetic Waveform Synthesis with the HC05/08 MCUs
AN1222SW
Software Files for AN1222 zipped
AN1221/D
AN1259/D
AN1263/D
System Design and Layout Techniques for Noise
Reduction in MCU-Based Systems
Designing for Electromagnetic Compatibility with SingleChip Microcontrollers
AN1274/D
HC08 SCI Operation with Various Input Clocks
AN1516/D
Liquid Level Control Using a Motorola Pressure Sensor
AN1705/D
Noise Reduction Techniques for Microcontroller-Based
Systems
AN1744/D
Resetting Microcontrollers During Power Transitions
AN1752/D
Data Structures for 8-Bit Microcontrollers
AN1771/D
Precision Sine-Wave Tone Synthesis Using 8-Bit MCUs
AN1775/D
Expanding Digital Input with an A/D Converter
AN1783/D
Determining MCU Oscillator Start-Up Parameters
AN1818/D
Software SCI Routines with the 16-Bit Timer Module
AN1820/D
Software I2C Communications
AN1820SW
Software files for AN1820 zipped
AN1837/D
Non-Volatile Memory Technology Overview
AN2093/D
Creating Efficient C Code for the MC68HC08
AN2120/D
Connecting an M68HC08 Family Microcontroller to an
Internet Service Provider (ISP) Using the Point-to-Point
Protocol (PPP)
AN2120SW
Software for AN2120, zip format
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
Size Rev Date Last
Order
K
# Modified Availability
1.0 7/31/2002
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR16.htm (2 of 7) [28-Nov-03 11:14:14 AM]
AN2149/D
AN2159/D
Compressor Induction Motor Stall and Rotation Detection
using Microcontrollers
Digital Direct Current Ignition System Using HC08
Microcontrollers
AN2159SW
AN2262/D
Wireless HC08 Modem
AN2262SW
Software files for application note AN2262
AN2295
Developer's Serial Bootloader for M68HC08
AN2295SW
Software for AN2295
AN2321/D
Designing for Board Level Electromagnetic Compatibility
AN2396/D
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
Opto Isolation Circuits For In Circuit Debugging of
68HC9(S)12 and 68HC908 Microcontrollers
Servo Motor Control Application on a Local Area
Interconnect Network (LIN)
Software files for AN2396
AN2438/D
ADC Definitions and Specifications
AN2504
On-Chip FLASH Programming API for CodeWarrior
AN2504SW
Software files for application note AN2504
AN2545SW
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
AN2396SW
AN2545
MOTOROLA
MOTOROLA
AN2159SW
AN2342
MOTOROLA
MOTOROLA
MOTOROLA
MOTOROLA
pdf
127
pdf
129
zip
182
1
3/08/2002
1
6/18/2002
pdf
1185
zip
31
pdf
738
zip
725 4.0
pdf
5/30/2001
11/20/2001
1.1 6/25/2002
4
1628
10/29/2003
10/21/2003
pdf
155
pdf
678
zip
564
pdf
297
pdf
530
zip
59
18
Using MC68HC908GR/GZ On-Chip FLASH Programming MOTOROLA
pdf
Routines
MOTOROLA
Software files to accompany application note AN2545
zip
10/15/2003
10/21/2003
Brochure
ID
Name
Vendor ID Format
BR68HC08FAMAM/D 68HC08 Family: High Performance and Flexibility
MOTOROLA
pdf
FLYREMBEDFLASH/D Embedded Flash: Changing the Technology World for MOTOROLA
pdf
the Better
Size Rev Date Last
Order
K
5/21/2003
57 2
68
2
5/21/2003
Data Sheets
ID
Name
MC68HC908GR16/D
MC68HC908GR16 Technical Data
Vendor ID
MOTOROLA
Format Size K Rev #
pdf
4089
1
Date Last
Modified
5/07/2003
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR16.htm (3 of 7) [28-Nov-03 11:14:14 AM]
Order
Availability
Engineering Bulletin
ID
EB389/D
EB390/D
EB396/D
EB398
EB608/D
Name
Vendor ID Format
TOF Consideration when Measuring a Long Input Capture
Event
Porting the AN2120/D UDP/IP Code to the Avnet
Evaluation Board
Use of OSC2/XTAL as a Clock Output on Motorola
Microcontrollers
Techniques to Protect MCU Applications Against
Malfunction Due to Code Run-Away
Interrupt Handling Considerations When Modifying
EEPROM on HC08 Microcontrollers
MOTOROLA
pdf
MOTOROLA
1501
pdf
MOTOROLA
MOTOROLA
MOTOROLA
Size Rev Date Last
Order
K
4/15/2002
55
1
5/09/2002
pdf
49
pdf
pdf
96
8/13/2002
8/14/2002
Errata - Click here for important errata information
ID
Name
MSE908GR16_5L35K/D
Mask Set Errata for MSE908GR16_5L35K
Vendor ID
Format
MOTOROLA
pdf
Size Rev
K
Date Last
Modified
Order
Availability
29
2/21/2003
Fact Sheets
ID
Name
CWDEVSTUDFACTHC08
Development Studio
Vendor ID
Date Last
Modified
Order Availability
5/13/2002
Format Size K Rev #
MOTOROLA
pdf
48
2
Product Change Notices
ID
Name
PCN8698
CARBON FIBER ITW QFP TRAY CONVERSION
PCN8701
Size Rev Date Last
K
Modified
Order
Availability
Vendor ID
Format
MOTOROLA
htm
100
HC908GZ16 AND HC908GR16 MC QUALIFICATION MOTOROLA
htm
6
Reference Manual
ID
Name
Vendor ID
Format
ADCRM/AD
Analog-to-Digital Reference Manual
MOTOROLA
pdf
CPU08RM/AD
CPU08RM Central Processor Unit Reference Manual MOTOROLA
pdf
TIM08RM/AD
TIM08 Timer Interface Module Reference Manual
pdf
MOTOROLA
Size Rev Date Last
K
Modified
231
3
4/03/2002
1.0
1/10/1996
2666
771
Order
Availability
Selector Guide
ID
Name
SG1002
Analog Selector Guide - Quarter 4, 2003
SG1006
Microcontrollers Selector Guide - Quarter 4, 2003
SG1010
Sensors Selector Guide - Quarter 4, 2003
SG1011
SG2000CR
SG2039
Vendor ID Format
MOTOROLA
MOTOROLA
MOTOROLA
pdf
pdf
pdf
Software and Development Tools Selector Guide - Quarter MOTOROLA
pdf
4, 2003
MOTOROLA
Application Selector Guide Index and Cross-Reference.
pdf
Application Selector Guide - Vacuum Cleaners Vacuum
Cleaners
MOTOROLA
pdf
Size Rev Date Last
Order
K
579
10/24/2003
219
287
3
10/24/2003
10/24/2003
11/11/2003
6/17/2003
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR16.htm (4 of 7) [28-Nov-03 11:14:14 AM]
Users Guide
ID
Name
Vendor ID Format
CDSWHC08QS
CodeWarrior™ Development Studio for 68HC08 Quick
Start Guide
MOTOROLA
pdf
Size Rev Date Last
Order
K
2847
9/20/2002
2.1
Return to Top
68HC908GR16 Tools
Hardware Tools
Emulators/Probes/Wigglers
ID
Name
AX-6811
AX-6811
IC10000
IC20000
IC40000
Vendor ID Format
Size Rev
Order
K
# Availability
HITEX
iC1000 PowerEmulator
ISYS
iC2000 PowerEmulator
ISYS
iC4000 ActiveEmulator
ISYS
SOFTEC
In-Circuit, Real-Time Debugger/Programmer for Motorola 68HC08
INDART-HC08/D
Family (USB)
Evaluation/Development Boards and Systems
ID
Name
M68CBL05C
Size
Rev #
K
Order
Availability
Vendor ID
Format
Low-noise Flex Cable
MOTOROLA
KITMMEVS08GZ16
Modular Evaluation System (MMEVS)
MOTOROLA
KITMMDS08GZ16
Modular Development System (MMDS) Kits
MOTOROLA
M68EML08GZ16
Emulation Module
MOTOROLA
M68MULTILINK08
MON08 Multilink
METROWERKS
INDART-HC08/GZ
Design Kit for Motorola MC68HC908GZ/GR (USB)
SOFTEC
Programmers
ID
POWERLAB
Name
Universal Programmer
Vendor ID
SYSGEN
Format
Size K
Rev #
Order Availability
Software
Application Software
Code Examples
ID
HC08DELAYSW
HC08EXSW
Operating Systems
ID
CMX-TINY+
Name
Vendor ID Format
HC08 Software Example: Subroutine that delays for a whole
number of milliseconds
HC08 Software Example: Library containing software
examples in assembly for 68HC08
Name
CMX-Tiny+
Vendor ID
CMX
MOTOROLA
MOTOROLA
Size Rev
Order
K
# Availability
zip
2
zip
14
Format
Size K
Rev #
Order Availability
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR16.htm (5 of 7) [28-Nov-03 11:14:14 AM]
Software Tools
Assemblers
ID
ADX-08
Name
ADX-08 Macro Assembler-Linker and IDE
Compilers
ID
CX6808S
Name
ICC08
ICC08 V6 STD
Debuggers
ID
AX-6811
NOICE08
Vendor ID
AVOCET
Order Availability
Vendor ID Format Size K Rev # Order Availability
COSMIC
CX6808 C Cross Compiler for HC08 and HCS08
Name
Format Size K Rev #
Format
Size K
Rev #
Order Availability
AX-6811
Vendor ID
HITEX
NoICE08
IDE (Integrated Development Environment)
ID
Name
CDCWSEHC08
CodeWarrior Development Studio™ for HC(S)08 Special Edition
Format
METROWERKS
IDEA08
CodeWarrior Development Studio for Motorola HC08
METROWERKS
Microcontrollers Professional Edition
METROWERKS
Microcontrollers Standard Edition
IDEA08 integrated development environment for HC08 and HCS08
COSMIC
IC-SW-OPR
winIDEA
CWHC08PRO
CWHC08STD
Performance and Testing
ID
AX-6811
ISYS
Name
AX-6811
Vendor ID
HITEX
Size Rev
Order
K
# Availability
Vendor ID
Format
Size K
Rev #
Order Availability
Return to Top
Rich Media
Rich Media
Webcast
ID
Name
Vendor ID Format
CodeWarrior Development Tools for 68HC08 and HCS12
Microcontrollers.
RMWC_CODEWARRIOR
MOTOROLA
Listen to our webcast for an overview of some of the challenges
html
that developers face and an explanation of the CodeWarrior
tools that help to address these challenges.
8-bit Microcontroller Overview and Q-Family of Flash
Microcontrollers
Listen to our companion webcasts to learn about Motorola's
MOTOROLA
RMWC_QFAMILY
htm
recent 8-bit products and services-especially the HC08 QFamily-that offer maximum design flexibility while helping you
get to market fast.
Return to Top
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR16.htm (6 of 7) [28-Nov-03 11:14:14 AM]
Size Rev
Order
K
# Availability
4
0.0
5
1.1
Orderable Parts Information
Package Info
Tape
and
Reel
Life Cycle
Description (code)
KMC908GR16CFA
LQFP 48
7*7*1.4P0.5
No
PRODUCT RAPID
GROWTH(2)
$4.00
more
KMC908GR16CFJ
LQFP 32
7*7*1.4P0.8
No
PRODUCT RAPID
GROWTH(2)
$3.80
more
KMC908GR16MFA
LQFP 48
7*7*1.4P0.5
No
$4.44
more
KMC908GR16MFJ
LQFP 32
7*7*1.4P0.8
No
$4.22
more
KMC908GR16VFA
LQFP 48
7*7*1.4P0.5
No
PRODUCT RAPID
GROWTH(2)
$4.42
more
KMC908GR16VFJ
LQFP 32
7*7*1.4P0.8
No
PRODUCT RAPID
GROWTH(2)
$4.00
more
MC68HC908GR16CFA
LQFP 48
7*7*1.4P0.5
No
PRODUCT RAPID
GROWTH(2)
$4.00
more
MC68HC908GR16CFJ
LQFP 32
7*7*1.4P0.8
No
PRODUCT RAPID
GROWTH(2)
$4.00
more
MC68HC908GR16MFA
LQFP 48
7*7*1.4P0.5
No
PRODUCT RAPID
GROWTH(2)
$4.40
more
MC68HC908GR16MFJ
LQFP 32
7*7*1.4P0.8
No
PRODUCT RAPID
GROWTH(2)
$4.18
more
MC68HC908GR16VFA
LQFP 48
7*7*1.4P0.5
No
PRODUCT RAPID
GROWTH(2)
$4.20
more
MC68HC908GR16VFJ
LQFP 32
7*7*1.4P0.8
No
PRODUCT RAPID
GROWTH(2)
$3.99
more
PartNumber
Budgetary Price
Additional Info Order Availability
QTY 1000+ ($US)
NOTE: Are you looking for an obsolete orderable part? Click HERE to check our distributors' inventory.
Return to Top
Related Links
Microcontrollers
Motor Control
Sensors
Return to Top
http://www.motorola.com/ | Site Map | Contact Motorola | Terms of Use | Privacy Practices
© Copyright 1994-2003 Motorola, Inc. All Rights Reserved.
file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR16.htm (7 of 7) [28-Nov-03 11:14:14 AM]
