MLSE-0200A2NP0
MLSE-0200A2NP0
    SICK
    AGV SENSOR MLS 200MM
MLSE-0200A2NP0 数据手册
Product data sheet MLSE-0200A2NP0 MLS LINE GUIDANCE AND GRID LOCALIZATION MLSE-0200A2NP0 | MLS LINE GUIDANCE AND GRID LOCALIZATION A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. MLSE-0200A2NP0 1090687 Other models and accessories www.sick.com/MLS Detailed technical data Features Detection range typ. 200 mm Operating height 10 mm ... 70 mm Electrical wiring DC 4-wire Teach-in ✔ Enclosure rating IP65 1) IP67 IP68 1)  According to EN 60529. Mechanics/electronics Supply voltage 9 V DC ... 30 V DC Terminal resistor No internal terminator Protection class III Power consumption 600 mW Resolution, typ. 1 mm Repeat accuracy, typ. 1 mm Update rate 100 Hz Reverse polarity protection ✔ Short-circuit protection ✔ Ambient operating temperature –20 °C ... +70 °C Shock and vibration resistance 30 g, 11 ms/10 Hz ... 55 Hz, 1 mm EMC According to EN 60947-5-2 Connection type Cable with M8 male connector, 4-pin, 0.3 m 1) Connection type Detail Conductor cross-section 0.08 mm² Material Housing Metal Aluminum Plastic 1) 2  Do not bend below 0 °C. LOCALIZATION AND POSITIONING SOLUTIONS | SICK Product data sheet | 2021-09-27 15:41:20 Subject to change without notice MLSE-0200A2NP0 | MLS LINE GUIDANCE AND GRID LOCALIZATION Cable PUR UL File No. 1) NRKH.E181493 & NRKH7.E181493  Do not bend below 0 °C. Communication interface Communication interface CANopen Diagnosis Orientation Number of axis 3 Roll Euler angle measuring range ± 180° Pitch Euler angle measuring range ± 90° Yaw Euler angle measuring range ± 180° Resolution 0.02° Roll repeatability ± 1° Pitch repeatability ± 1° Yaw repeatability ± 1° 1) Maximum rotation rate 2,000 °/s Quaternion w measuring range 0 ... + 1 Quaternion x measuring range –1 ... 1 Quaternion y measuring range –1 ... 1 Quaternion z measuring range –1 ... 1 Update rate 100 Hz Limit frequency 100 Hz Initialization time 640 ms Sampling rate 200 Hz 2) Acceleration measuring range ± 16 g 2) Rotation rate measuring range ± 2,000 °/s 2) 1) 2)  Not long-term stable.  Raw data. Classifications ECl@ss 5.0 27270104 ECl@ss 5.1.4 27270104 ECl@ss 6.0 27270104 ECl@ss 6.2 27270104 ECl@ss 7.0 27270104 ECl@ss 8.0 27270104 ECl@ss 8.1 27270104 ECl@ss 9.0 27270104 ECl@ss 10.0 27270104 ECl@ss 11.0 27270104 ETIM 5.0 EC002544 ETIM 6.0 EC002544 2021-09-27 15:41:20 | Product data sheet  Subject to change without notice LOCALIZATION AND POSITIONING SOLUTIONS | SICK 3 MLSE-0200A2NP0 | MLS LINE GUIDANCE AND GRID LOCALIZATION EC002544 ETIM 8.0 EC002544 UNSPSC 16.0901 39122230 Dimensional drawing (Dimensions in mm (inch)) 3 L1 20 19.5 (0.79) Total length (L1) mm MLSE-0200 217 MLSE-0300 325 MLSE-0400 397 MLSE-0500 505 MLSE-0600 613 7.5 (0.3) (0.77) 14 (0.55) ø 8.2 (0.32) 2 ø 2.6 (0.10) 1 20 H I J K L M N O P Q R S T ETIM 7.0 (0.79) A B C D E F ①  Function signal indicator 1 ②  Function signal indicator 2 ③  Teach-Pad Connection diagram Cd-396 1 4 3 2 Recommended accessories Other models and accessories www.sick.com/MLS Brief description Type Part no. AKA-NXL1BXB12KX 6067651 Bus adapter CAN-USB Adapter to connect MLS with a PC 4 LOCALIZATION AND POSITIONING SOLUTIONS | SICK Product data sheet | 2021-09-27 15:41:20 Subject to change without notice MLSE-0200A2NP0 | MLS LINE GUIDANCE AND GRID LOCALIZATION Brief description Type Part no. Magnetic tape, North is top side, adhesive, width 25 mm, length 50 m MAGNETIC TAPE 5337613 Magnetic tape, South is top side, adhesive, width 25 mm, length 50 m MAGNETIC TAPE 5337614 Positioning device for magnetic markers (5337613, 5337614) for MLS TEMPLATE 4097520 YF8U14011VA3FYDN2 2098412 Bracket for low mounting, Stainless steel V2A (bracket/mounting screw), Brass (fixing screw) BEF-WNL01MPA 2065973 Bracket for lateral mounting, Stainless steel V2A (bracket/mounting screw), Brass (fixing screw) BEF-WNZ01MPA 2065577 Head A: female connector, M8, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 2 m YF8U14020UA3XLEAX 2094791 Head A: female connector, M8, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 5 m YF8U14050UA3XLEAX 2094792 Head A: female connector, M8, 4-pin, angled, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 2 m YG8U14020UA3XLEAX 2095589 Head A: female connector, M8, 4-pin, angled, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 5 m YG8U14050UA3XLEAX 2095590 Magnets Distributors YF8U14-011VA3FYDN2 Mounting brackets and plates Plug connectors and cables 2021-09-27 15:41:20 | Product data sheet  Subject to change without notice LOCALIZATION AND POSITIONING SOLUTIONS | SICK 5 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
MLSE-0200A2NP0 价格&库存
很抱歉,暂时无法提供与“MLSE-0200A2NP0”相匹配的价格&库存,您可以联系我们找货
