S-8206A Series
www.ablic.com
BATTERY PROTECTION IC FOR 1-CELL PACK
(SECONDARY PROTECTION)
© ABLIC Inc., 2015-2020
Rev.1.5_00
The S-8206A Series is used for secondary protection of lithium-ion / lithium polymer rechargeable batteries, and incorporates a
high-accuracy voltage detection circuit and a delay circuit.
Features
• High-accuracy voltage detection circuit
Overcharge detection voltage
3.500 V to 5.000 V (5 mV step)
Accuracy ±20 mV
Overcharge release voltage
3.100 V to 4.950 V*1
Accuracy ±50 mV
• Detection delay time is generated only by an internal circuit (external capacitors are unnecessary).
• Output logic:
Active "H", active "L"
• Output form:
CMOS output, Nch open-drain output
• Wide operation temperature range
Ta = −40°C to +85°C
• Low current consumption
During operation:
1.5 μA typ., 3.0 μA max. (Ta = +25°C)
• Lead-free (Sn 100%), halogen-free
*1. Overcharge release voltage = Overcharge detection voltage − Overcharge hysteresis voltage
(Overcharge hysteresis voltage can be selected from a range of 0.05 V to 0.4 V in 50 mV step.)
Applications
• Lithium-ion rechargeable battery pack
• Lithium polymer rechargeable battery pack
Packages
• SNT-6A
• HSNT-6 (1212)
1
BATTERY PROTECTION IC FOR 1-CELL PACK (SECONDARY PROTECTION)
S-8206A Series
Rev.1.5_00
Block Diagram
1. CMOS output, active "H"
VDD
DO
comparator
Control logic
VSS
Delay circuit
Oscillator
CO
VM
Figure 1
2
Rev.1.5_00
S-8206A Series
2. CMOS output, active "L"
VDD
DO
comparator
Control logic
VSS
Delay circuit
Oscillator
CO
VM
Figure 2
3
S-8206A Series
Rev.1.5_00
3. Nch open-drain output
VDD
DO
comparator
Control logic
VSS
Delay circuit
Oscillator
CO
VM
Figure 3
4
Rev.1.5_00
S-8206A Series
Product Name Structure
1. Product name
S-8206A xx
xxxx
U
Environmental code
U:
Package abbreviation and IC packing specifications
I6T1: SNT-6A, Tape
A6T2: HSNT-6 (1212), Tape
*1
Serial code*2
Sequentially set from AA to ZZ
*1. Refer to the tape drawing.
*2. Refer to "3. Product name list".
2. Packages
Package Name
SNT-6A
HSNT-6 (1212)
Table 1 Package Drawing Codes
Dimension
Tape
Reel
PG006-A-P-SD
PG006-A-C-SD
PG006-A-R-SD
PM006-A-P-SD
PM006-A-C-SD
PM006-A-R-SD
Land
PG006-A-L-SD
PM006-A-L-SD
5
S-8206A Series
Rev.1.5_00
3. 1 SNT-6A
Table 2
Overcharge
Overcharge Detection
Overcharge
Release Voltage
Delay Time*1
Product Name
Detection Voltage
[VCL]
[tCU]
[VCU]
S-8206AAA-I6T1U
4.500 V
4.150 V
2s
S-8206AAB-I6T1U
4.550 V
4.200 V
2s
S-8206AAC-I6T1U
4.150 V
4.000 V
2s
S-8206AAD-I6T1U
4.250 V
4.100 V
2s
S-8206AAE-I6T1U
4.150 V
4.000 V
2s
S-8206AAF-I6T1U
4.250 V
4.100 V
2s
S-8206AAG-I6T1U
4.450 V
4.150 V
2s
S-8206AAH-I6T1U
4.400 V
4.100 V
2s
S-8206AAI-I6T1U
4.350 V
4.050 V
2s
S-8206AAJ-I6T1U
4.570 V
4.220 V
2s
S-8206AAL-I6T1U
4.600 V
4.250 V
2s
S-8206AAR-I6T1U
4.130 V
4.080 V
2s
*1. Overcharge detection delay time: 1 s, 2 s, 4 s
*2. Output logic: Active "H", active "L"
*3. Output form: CMOS output, Nch open-drain output
Output Logic*2
Active "H"
Active "H"
Active "L"
Active "L"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "H"
Active "L"
Output Form*3
CMOS output
CMOS output
CMOS output
CMOS output
CMOS output
CMOS output
CMOS output
CMOS output
CMOS output
CMOS output
Remark Please contact our sales representatives for products other than the above.
3. 2 HSNT-6 (1212)
Table 3
Product Name
S-8206AAA-A6T2U
S-8206AAB-A6T2U
Overcharge
Detection Voltage
[VCU]
4.500 V
4.550 V
Overcharge
Release Voltage
[VCL]
4.150 V
4.200 V
Delay Time*1
Output Logic*2
[tCU]
2s
Active "H"
2s
Active "H"
6
Output Form*3
CMOS output
CMOS output
S-8206A Series
Rev.1.5_00
Pin Configurations
1. SNT-6A
Top view
1
2
3
Table 4
6
5
4
Figure 4
Pin No.
Symbol
Description
1
2
3
NC*1
CO
DO
No connection
Connection pin of charge control FET gate
Input pin for test signal
4
VSS
Input pin for negative power supply
5
6
VDD
VM
Input pin for positive power supply
Negative power supply pin for CO pin
*1. The NC pin is electrically open.
The NC pin can be connected to VDD pin or VSS pin.
2. HSNT-6 (1212)
Table 5
Top view
1
2
3
6
5
4
Bottom view
6
5
4
1
2
3
Pin No.
1
2
3
4
5
6
Symbol
NC*2
CO
DO
VSS
VDD
VM
Description
No connection
*1
Figure 5
*1. Connect the heat sink of backside at shadowed area to the board, and set electric potential open or VDD.
However, do not use it as the function of electrode.
*2. The NC pin is electrically open.
7
S-8206A Series
Rev.1.5_00
Absolute Maximum Ratings
Table 6
(Ta = +25°C unless otherwise specified)
Item
Symbol
Applied Pin
Unit
Input voltage between VDD pin and VSS pin
VDS
VDD
VSS − 0.3 to VSS + 6
V
VM pin input voltage
VVM
VM
VDD − 28 to VDD + 0.3
V
DO pin input voltage
VDO
DO
VCO
CO
VSS − 0.3 to VDD + 0.3
VVM − 0.3 to VDD + 0.3
VVM − 0.3 to VVM + 28
400*1
480*1
−40 to +85
V
V
V
mW
mW
°C
−55 to +125
°C
CMOS output
SNT-6A
Power dissipation
HSNT-6 (1212)
Operation ambient temperature
Topr
Storage temperature
Tstg
CO pin output
voltage
PD
*1. When mounted on board
[Mounted board]
(1) Board size: 114.3 mm × 76.2 mm × t1.6 mm
(2) Board name: JEDEC STANDARD51-7
Caution
The absolute maximum ratings are rated values exceeding which the product could suffer physical
damage. These values must therefore not be exceeded under any conditions.
Power Dissipation (PD) [mW]
700
600
HSNT-6 (1212)
500
SNT-6A
400
300
200
100
100
150
Ambient Temperature (Ta) [°C]
Figure 6 Power Dissipation of Package (When Mounted on Board)
8
Rev.1.5_00
S-8206A Series
Electrical Characteristics
1. Ta = +25°C
Item
Table 7
Symbol
Condition
Test
Min.
Typ.
Max.
Unit
Circuit
Detection Voltage
VCU
Input Voltage
Operation voltage between VDD pin and
VSS pin
Input Current
Current consumption during operation
Output Resistance
CO pin resistance "H" 1
CO pin resistance "L" 1
DO pin resistance "H"
DO pin resistance "L"
CO pin resistance "H" 2
CO pin resistance "L" 2
Output Current
CO pin leakage current "L"
Delay Time
VCL
VDSOP
Ta = −10°C to +60°C*1
VCU − 0.020
VCU − 0.025
VCU
VCU
VCU + 0.020
VCU + 0.025
V
V
1
1
VCL − 0.050
VCL
VCL + 0.050
V
1
1.5
6.0
V
IOPE
VDD = 3.4 V, VVM = 0 V
1.5
3.0
μA
2
RCOH1
RCOL1
RDOH
RDOL
RCOH2
RCOL2
CMOS output
5
5
5
5
1
1
10
10
10
10
4
4
kΩ
kΩ
kΩ
kΩ
MΩ
MΩ
3
3
3
3
3
3
ICOLL
0.1
μA
3
tCU × 0.7
tCU
tCU
tCU × 1.3
4
*1. Since products are not screened at high and low temperature, the specification for this temperature range is guaranteed by
design, not tested in production.
9
S-8206A Series
Rev.1.5_00
Test Circuits
Caution 1. Unless otherwise specified, the output voltage levels "H" and "L" at CO pin (VCO) are judged by the
threshold voltage (1.0 V) of the N-channel FET. Judge the CO pin level with respect to VVM.
2. Set SW to ON and OFF in Nch open-drain output and CMOS output, respectively.
1. Overcharge detection voltage, overcharge release voltage
(Test circuit 1)
1. 1 Active "H"
Overcharge detection voltage (VCU) is defined as the voltage V1 at which VCO goes from "L" to "H" when the voltage
V1 is gradually increased from the starting condition of V1 = 3.4 V. Overcharge release voltage (VCL) is defined as
the voltage V1 at which VCO goes from "H" to "L" when the voltage V1 is then gradually decreased. Overcharge
hysteresis voltage (VHC) is defined as the difference between VCU and VCL.
1. 2 Active "L"
Overcharge detection voltage (VCU) is defined as the voltage V1 at which VCO goes from "H" to "L" when the
voltage V1 is gradually increased from the starting condition of V1 = 3.4 V. Overcharge release voltage (VCL) is
defined as the voltage V1 at which VCO goes from "L" to "H" when the voltage V1 is then gradually decreased.
Overcharge hysteresis voltage (VHC) is defined as the difference between VCU and VCL.
2. Current consumption during operation
(Test circuit 2)
The current consumption during operation (IOPE) is the current that flows through VDD pin (IDD) under the set condition of
V1 = 3.4 V.
3. CO pin resistance "H" 1 (CMOS output)
(Test circuit 3)
3. 1 Active "H"
The CO pin resistance "H" 1 (RCOH1) is the resistance between VDD pin and CO pin under the set conditions of V1 = 5.1 V,
V2 = 4.7 V.
3. 2 Active "L"
The CO pin resistance "H" 1 (RCOH1) is the resistance between VDD pin and CO pin under the set conditions of V1 = 3.4 V,
V2 = 3.0 V.
4. CO pin resistance "L" 1
(Test circuit 3)
4. 1 Active "H"
The CO pin resistance "L" 1 (RCOL1) is the resistance between VM pin and CO pin under the set conditions of V1 = 3.4 V,
V2 = 0.4 V.
4. 2 Active "L"
The CO pin resistance "L" 1 (RCOL1) is the resistance between VM pin and CO pin under the set conditions of V1 = 5.1 V,
V2 = 0.4 V.
5. DO pin resistance "H"
(Test circuit 3)
The DO pin resistance "H" (RDOH) is the resistance between VDD pin and DO pin under the set conditions of V1 = 3.4 V,
V3 = 3.0 V.
10
Rev.1.5_00
S-8206A Series
6. DO pin resistance "L"
(Test circuit 3)
The DO pin resistance "L" (RDOL) is the resistance between VSS pin and DO pin under the set conditions of V1 = 1.8 V,
V3 = 0.4 V.
7. CO pin resistance "H" 2 (CMOS output, active "L")
(Test circuit 3)
The CO pin resistance "H" 2 (RCOH2) is the resistance between VDD pin and CO pin under the set conditions of V1 = 5.1 V,
V2 = 0 V.
8. CO pin resistance "L" 2 (CMOS output, active "H")
(Test circuit 3)
The CO pin resistance "L" 2 (RCOL2) is the resistance between VM pin and CO pin under the set conditions of V1 = 5.1 V,
V2 = 5.1 V.
9. CO pin leakage current "L" (Nch open-drain output)
(Test circuit 3)
9. 1 Active "H"
The CO pin leakage current "L" (ICOLL) is the current that flows through CO pin (ICO) under the set conditions of
V1 = 5.1 V, V2 = 28 V.
9. 2 Active "L"
V1 = 3.4 V, V2 = 28 V.
10. Overcharge detection delay time
(Test circuit 4)
10. 1 Active "H"
The overcharge detection delay time (tCU) is the time needed for VCO to go to "H" just after the voltage V1 increases
and exceeds VCU under the set condition of V1 = 3.4 V.
10. 2 Active "L"
The overcharge detection delay time (tCU) is the time needed for VCO to go to "L" just after the voltage V1 increases
11
S-8206A Series
R1 = 330 Ω
IDD
A
VDD
S-8206A Series
V1
C1 = 0.1 μF
VDD
V1
S-8206A Series
VSS
VSS
VM
DO
CO
V VCO SW
COM
COM
Figure 7 Test Circuit 1
Figure 8 Test Circuit 2
VDD
V1
VDD
V1
S-8206A Series
VSS
VM
DO
S-8206A Series
VSS
CO
VM
A IDO
A ICO
V3
V2
COM
DO
Oscilloscope
CO
SW
Oscilloscope
COM
Figure 9 Test Circuit 3
12
VM
DO
CO
V VDO
Rev.1.5_00
Figure 10 Test Circuit 4
Rev.1.5_00
S-8206A Series
Operation
Remark Refer to " Battery Protection IC Connection Example".
1. Overcharge detection status
The S-8206A Series monitors the voltage of the battery connected between VDD pin and VSS pin to detect overcharge.
When the battery voltage exceeds the overcharge detection voltage (VCU) during charging in the normal status and the
condition continues for the overcharge detection delay time (tCU) or longer, the S-8206A Series outputs overcharge
detection signal from the CO pin. This condition is called overcharge status. Connecting FET to the CO pin provides
charge control and a second protection.
2. Test mode
tCU can be shortened by forcibly setting the DO pin to VSS level from external. When the DO pin is forcibly set to VSS level
from external, tCU will be shortened to approximately 1/64.
13
S-8206A Series
Rev.1.5_00
Timing Charts
VCU
VCL (VCU − VHC)
Battery voltage
VDD
CO pin voltage
CMOS output
Active "H"
VVM
VDD
CO pin voltage
CMOS output
Active "L"
VVM
VDD
CO pin voltage
Active "H"
High-Z
VVM
VDD
CO pin voltage
Active "L"
High-Z
High-Z
VVM
Overcharge detection delay time (tCU)
(1)
*1
Status
*1. (1): Normal status
(2): Overcharge status
Figure 11
14
(2)
(1)
Rev.1.5_00
S-8206A Series
Figure 12 shows the connection example when CMOS output, active "H" product is used.
SCP
EB+
R1
VDD
C1
Battery
DO
S-8206A Series
FET
VSS
CO
VM
EB−
Figure 12
Table 8 Constants for External Components
Symbol
FET
Part
N-channel
MOS FET
R1
Resistor
C1
Capacitor
Caution 1.
2.
Purpose
Charge control
ESD protection,
For power fluctuation
Min.
Typ.
Max.
Remark
150 Ω
330 Ω
1 kΩ
0.068 μF
0.1 μF
1.0 μF
The constants may be changed without notice.
It has not been confirmed whether the operation is normal or not in circuits other than the connection
example. In addition, the connection example and the constants do not guarantee proper operation.
Perform thorough evaluation using the actual application to set the constants.
15
S-8206A Series
Rev.1.5_00
[For SCP, contact]
Global Sales & Marketing Division, Dexerials Corporation
Gate City Osaki East Tower 8F, 1-11-2
Osaki, Shinagawa-ku, Tokyo, 141-0032, Japan
TEL +81-3-5435-3946
Contact Us: http://www.dexerials.jp/en/
Precautions
• The application conditions for the input voltage, output voltage, and load current should not exceed the package power
dissipation.
• Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic
protection circuit.
• ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement by
products including this IC of patents owned by a third party.
16
S-8206A Series
Rev.1.5_00
Characteristics (Typical Data)
1. Current consumption
1. 1 IOPE vs. Ta
4.0
IOPE [μA]
3.0
2.0
1.0
0.0
−40 −25
Ta [°C]
50
75 85
2. Detection voltage
2. 1 VCU vs. Ta
2. 2 VCL vs. Ta
4.53
VCL [V]
VCU [V]
4.51
4.49
4.47
4.45
−40 −25
Ta [°C]
50
75 85
Ta [°C]
50
75 85
4.21
4.19
4.17
4.15
4.13
4.11
4.09
4.07
−40 −25
Ta [°C]
50
75 85
3. Delay time
3. 1 tCU vs. Ta
5.0
tCU [s]
4.0
3.0
2.0
1.0
−40 −25
17
S-8206A Series
Rev.1.5_00
4. Output resistance
4. 1 RCOH1 vs. VCO
4. 2 RCOL1 vs. VCO
30
RCOL1 [kΩ]
RCOH1 [kΩ]
30
2
3
4
2
VCO [V]
3
4
1
2
VDO [V]
3
4
VCO [V]
4. 4 RDOL vs. VDO
30
30
RDOL [kΩ]
RDOH [kΩ]
4. 3 RDOH vs. VDO
10
2
VDO [V]
18
10
3
4
Rev.1.5_00
S-8206A Series
Marking Specifications
1.
SNT-6A
Top view
6
5
(1) to (3):
(4) to (6):
4
Product code (refer to Product name vs. Product code)
Lot number
(1) (2) (3)
(4) (5) (6)
1
2
3
Product Code
(1)
(2)
(3)
J
N
A
J
N
B
J
N
C
J
N
D
J
N
E
J
N
F
J
N
G
J
N
H
J
N
I
J
N
J
J
N
L
J
N
R
Product Name
S-8206AAA-I6T1U
S-8206AAB-I6T1U
S-8206AAC-I6T1U
S-8206AAD-I6T1U
S-8206AAE-I6T1U
S-8206AAF-I6T1U
S-8206AAG-I6T1U
S-8206AAH-I6T1U
S-8206AAI-I6T1U
S-8206AAJ-I6T1U
S-8206AAL-I6T1U
S-8206AAR-I6T1U
2.
HSNT-6 (1212)
Top view
6
5
(1) to (3):
(4), (5):
4
Lot number
(1) (2) (3)
(4) (5)
1
2
3
Product Name
S-8206AAA-A6T2U
S-8206AAB-A6T2U
Product Code
(1)
(2)
(3)
J
N
A
J
N
B
19
1.57±0.03
6
1
5
4
2
3
+0.05
0.08 -0.02
0.5
0.48±0.02
0.2±0.05
No. PG006-A-P-SD-2.1
TITLE
SNT-6A-A-PKG Dimensions
No.
PG006-A-P-SD-2.1
ANGLE
UNIT
mm
ABLIC Inc.
+0.1
ø1.5 -0
4.0±0.1
2.0±0.05
0.25±0.05
+0.1
1.85±0.05
ø0.5 -0
4.0±0.1
0.65±0.05
3 2 1
4
5 6
Feed direction
No. PG006-A-C-SD-2.0
TITLE
SNT-6A-A-Carrier Tape
No.
PG006-A-C-SD-2.0
ANGLE
UNIT
mm
ABLIC Inc.
12.5max.
9.0±0.3
Enlarged drawing in the central part
ø13±0.2
(60°)
(60°)
No. PG006-A-R-SD-1.0
SNT-6A-A-Reel
TITLE
No.
PG006-A-R-SD-1.0
ANGLE
QTY.
UNIT
mm
ABLIC Inc.
5,000
0.52
1.36
2
0.52
0.2 0.3
1.
2.
1
(0.25 mm min. / 0.30 mm typ.)
(1.30 mm ~ 1.40 mm)
0.03 mm
SNT
1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.).
2. Do not widen the land pattern to the center of the package ( 1.30 mm ~ 1.40 mm ).
Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package.
2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm
or less from the land pattern surface.
3. Match the mask aperture size and aperture position with the land pattern.
4. Refer to "SNT Package User's Guide" for details.
1.
2.
(1.30 mm ~ 1.40 mm)
No. PG006-A-L-SD-4.1
TITLE
SNT-6A-A
-Land Recommendation
No.
PG006-A-L-SD-4.1
ANGLE
UNIT
mm
ABLIC Inc.
0.40
1.00±0.05
0.38±0.02
0.40
4
6
3
1
+0.05
0.08 -0.02
1.20±0.04
The heat sink of back side has different electric
potential depending on the product.
Confirm specifications of each product.
Do not use it as the function of electrode.
0.20±0.05
No. PM006-A-P-SD-1.1
TITLE
HSNT-6-B-PKG Dimensions
No.
PM006-A-P-SD-1.1
ANGLE
UNIT
mm
ABLIC Inc.
2.0±0.05
+0.1
ø1.5 -0
4.0±0.1
0.25±0.05
+0.1
ø0.5 -0
0.50±0.05
4.0±0.1
1.32±0.05
3
1
4
6
Feed direction
No. PM006-A-C-SD-2.0
TITLE
HSNT-6-B-C a r r i e r Tape
No.
PM006-A-C-SD-2.0
ANGLE
UNIT
mm
ABLIC Inc.
+1.0
9.0 - 0.0
11.4±1.0
ø13±0.2
(60°)
(60°)
No. PM006-A-R-SD-1.0
TITLE
HSNT-6-B-Reel
No.
PM006-A-R-SD-1.0
ANGLE
UNIT
QTY.
mm
ABLIC Inc.
5,000
1.04min.
Land Pattern
0.24min.
1.02
0.40±0.02
0.40±0.02
(1.22)
Caution It is recommended to solder the heat sink to a board
in order to ensure the heat radiation.
PKG
Metal Mask Pattern
Aperture ratio
Aperture ratio
Caution
Mask aperture ratio of the lead mounting part is 100%.
Mask aperture ratio of the heat sink mounting part is 40%.
Mask thickness: t0.10mm to 0.12 mm
100%
40%
t0.10mm ~ 0.12 mm
TITLE
HSNT-6-B
PM006-A-L-SD-2.0
No.
ANGLE
No. PM006-A-L-SD-2.0
UNIT
mm
ABLIC Inc.
Disclaimers (Handling Precautions)
1.
All the information described herein (product data, specifications, figures, tables, programs, algorithms and
application circuit examples, etc.) is current as of publishing date of this document and is subject to change without
notice.
2.
The circuit examples and the usages described herein are for reference only, and do not guarantee the success of
any specific mass-production design.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products
described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other
right due to the use of the information described herein.
3.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described
herein.
4.
Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute
maximum ratings, operation voltage range and electrical characteristics, etc.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to
the use of the products outside their specified ranges.
5.
Before using the products, confirm their applications, and the laws and regulations of the region or country where they
are used and verify suitability, safety and other factors for the intended use.
6.
When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related
laws, and follow the required procedures.
7.
The products are strictly prohibited from using, providing or exporting for the purposes of the development of
weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands
caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear,
biological or chemical weapons or missiles, or use any other military purposes.
8.
The products are not designed to be used as part of any device or equipment that may affect the human body, human
life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control
systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment,
aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by
ABLIC, Inc. Do not apply the products to the above listed devices and equipments.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of
the products.
9.
In general, semiconductor products may fail or malfunction with some probability. The user of the products should
therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread
prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social
damage, etc. that may ensue from the products' failure or malfunction.
The entire system in which the products are used must be sufficiently evaluated and judged whether the products are
allowed to apply for the system on customer's own responsibility.
10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the
product design by the customer depending on the intended use.
11. The products do not affect human health under normal use. However, they contain chemical substances and heavy
metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be
careful when handling these with the bare hands to prevent injuries, etc.
12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used.
13. The information described herein contains copyright information and know-how of ABLIC Inc. The information
described herein does not convey any license under any intellectual property rights or any other rights belonging to
ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this
document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express
permission of ABLIC Inc.
14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales
representative.
15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into
the English language and the Chinese language, shall be controlling.
2.4-2019.07
www.ablic.com
