GRL18S-F233Y
GRL18S-F233Y
    SICK
    SENSOR RETROREFLECTIVE 6M PNP
GRL18S-F233Y 数据手册
Product data sheet GRL18S-F233Y GR18S CYLINDRICAL PHOTOELECTRIC SENSORS GRL18S-F233Y | GR18S CYLINDRICAL PHOTOELECTRIC SENSORS A B C D E F Ordering information Type Part no. GRL18S-F233Y 1058206 Other models and accessories www.sick.com/GR18S Illustration may differ Detailed technical data Features H I J K L M N O P Q R S T Sensor/ detection principle Photoelectric retro-reflective sensor, Dual lens Dimensions (W x H x D) 18 mm x 18 mm x 38.1 mm Housing design (light emission) Cylindrical Thread diameter (housing) M18 x 1 Optical axis Axial, fully flush Sensing range max. 0.03 m ... 7.2 m 1) Sensing range 0.06 m ... 6 m 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 175 mm (7 m) Wave length 650 nm Adjustment None Indication LED indicator green Operating indicator Static: power on LED indicator yellow Status of received light beam Static: object not present Static off: object present 1) 2) 2  Reflector PL80A.  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-01 16:33:33 Subject to change without notice GRL18S-F233Y | GR18S CYLINDRICAL PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple 49 °C, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected.  At Uv
GRL18S-F233Y
物料型号:GRL18S-F233Y
器件简介:SICK GR18S系列为圆柱形光电传感器,具有双重镜头设计,适用于工业自动化领域。
引脚分配:3针M12连接器,分别为正极(L+)、负极(M)和输出(Q)。
参数特性: - 供电电压:10VDC至30VDC - 电流消耗:30mA - 输出类型:PNP - 响应时间:小于500ms - 开关频率:1000Hz - 感测范围:最大0.03米至7.2米,标准范围0.06米至6米 - 光源类型:可见红光,波长650nm - 光源寿命:平均10万小时 - 外壳防护等级:IP67
功能详解: - 传感器采用光电反射式原理,具有轴向、完全齐平的光轴设计。
- 指示灯包括绿色(操作指示,静态:电源开启)和黄色(接收到光束状态,静态:物体不在,静态关闭:物体在)。
应用信息:适用于需要精确检测物体存在与位置的工业自动化场景。
封装信息:金属外壳,镀镍黄铜和ABS材料,光学元件为PMMA塑料材质。
GRL18S-F233Y 价格&库存
很抱歉,暂时无法提供与“GRL18S-F233Y”相匹配的价格&库存,您可以联系我们找货
