Photoelectrics
Diffuse-reflective
Type PD30CND10....DU
• Miniature sensor range
• Range: 1 m
• Sensitivity adjustment by Teach-In programming
• Modulated, red light 660 nm
• Supply voltage: 10 to 30 VDC
• Output: 100 mA, NPN or PNP preset
• Make or break switching function programmable
• LED indication for output, stability and power ON
• Protection: reverse polarity, short circuit and transients
• Cable and plug versions
• Excellent EMC performance
• Dust alarm output
Product Description
Ordering Key
The PD30CND10 sensor
family comes in a compact
10 x 30 x 20 mm reinforced
PMMA/ABS housing. The
sensors are useful in applications where high accuracy
detection as well as small
size is required. Compact
housing and high power
LED for excellent performance-size ratio.
Type
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
Connection type
Dust Output
The Teach-In function for
adjustment of the sensitivity makes the sensors highly
flexible. The output type is
preset (NPN or PNP), and
the output switching function
is one NO or NC output and
one dust output NO or NC.
PD30CND10PPM5DU
Type Selection
Housing
Range
Connection
WxHxD
Sn
Ordering no.
NPN
Make and break switching
Ordering no.
PNP
10 x 30 x 20 mm
10 x 30 x 20 mm
PD 30 CND 10 NPDU
PD 30 CND 10 NPM5DU
PD 30 CND 10 PPDU
PD 30 CND 10 PPM5DU
Specifications
1 m
1 m
Cable
Plug
EN 60947-5-2
Rated operating distance (Sn) Up to 1 m,
Protection
Short-circuit, reverse polarity
reference target Kodak test
and transients
card R27, white, 90%
Light source
GaAlAs, LED, 660 nm
reflective, 200 x 200 mm
Light type
Red, modulated
Blind zone
≤ 20 mm
Sensing angle
± 2º
Sensitivity
Adjustable by Teach-In
Ambient light
10,000 lux
Temperature drift
≤ 0.1%/ºC
Light
spot
110 mm @ 1.5 m
Hysteresis (H)
Operating frequency (f)
≤ 1000 Hz
(differential travel)
≤ 10%
Response time
Rated operational volt. (UB )
10 to 30 VDC
OFF-ON (tON)
≤ 0.5 ms
(ripple included)
ON-OFF (tOFF )
≤ 0.5 ms
Ripple (Urpp )
≤ 10%
Power
ON
delay
(t
≤ 300 ms
v
Output current
Output function
Continuous (Ie)
≤ 100 mA
NPN and PNP
Preset
Short-time (I)
≤ 100 mA
NO or NC
(max. load capacity 100 nF)
Programming options
No load supply current (Io)
≤ 30 mA @ 24 VDC
Output pin 4 black
NO or NC
Minimum operational current (Im) ≤ 0.5 mA
Output pin 2 white
NO or NC (dust)
OFF-state current (Ir )
≤ 100 µA
Dust alarm output
Voltage drop (Ud )
≤ 2.4 VDC @ 100 mA
Delay on operate
20 ms
Specifications are subject to change without notice (05.07.2016)
1
PD30CND10....DU
Specifications (cont.)
Indication
Output ON
Signal stability ON and
Power ON
Environment
Installation category
Pollution degree
Degree of protection
Ambient temperature
Operating
Storage
Vibration
Shock
EN 60947-5-2
LED, yellow
LED, green
III (IEC 60664/60664A;
60947-1)
3 (IEC 60664/60664A;
60947-1)
IP 67 (IEC 60529; 60947-1)
-25° to +60°C (-13° to +140°F)
-40° to +70°C (-40° to +158°F)
10 to 55 Hz, 0.5 mm/7.5 g
(IEC 60068-2-6)
30 g / 11ms, 3 pos, 3 neg
per axis
(IEC 60068-2-6, 60068-2-32)
Rated insulation voltage
≤ 500 VAC (rms)
Housing material
Body
ABS
Frontglas
PMMA Red
Connection
Cable
PVC, black, 2 m
4 x 0.14 mm2, Ø = 3.3 mm
Plug
M8, 4-pin (CON. 54-series)
Weight
Cable version
≤ 40 g
Plug version
≤ 10 g
CE-marking Yes
Approvals
cULus (UL508 + CSA)
Operation Diagram
Tv = Power ON delay
Power supply
ON
OFF
Break Output (N.C.)
Present
Not Present
Tv
ON
OFF
Make Output (N.O.)
ON
OFF
Object
Tv
Wiring Diagrams
NPN
1 BN
PNP
V
1 BN
V
4 BK
2 WH*
2 WH*
4 BK
3 BU
3 BU
*Dust Output
GND
*Dust Output
Detection Diagram
GND
Excess Gain
1,000
40
30
Exess gain
(mm)
10
100
10
-20
-30
-40
400
600
800
Distance (mm)
1000
1200
1400
1
10
100
1,000
10,000
Distance (mm)
2
PD30CND10....DU
Signal Stability Indication
Accessories
21.2
14
9°
32.4
1.2
25.4
Excess Gain
9°
26,3
29.3
39
1.0
0.75
3.2
Operation level x 1.25
Operation level
Operation level x 0.75
1.2
10
1.25
25.4
3.2
13.5
16.2
6.0
5.2
3
Yellow LED ON
4.4
Dust ON
14
4.4
6.0
16
10
7.3
Green LED ON
8.2
5.7
Time
4.4
Mounting bracket: APD30-1
Mounting bracket: APD30-2
Dimensions
Plug version
Cable version
Incorrect
10.8
1.1
17
Receiver
Optical axis
xxxxxxS
Correct
Emitter
Two M3
Two, 9.5 dia.
Lenses
15
15
30
5.5 5.5
25.4
R
22
Optical axis
Two, 9.5 dia.
Lenses
Power / Stability LED
Green
10.6
10-30 V
100 mA
BN: V+
UL
BU: VBK: OUT
WH: ET
25.4
Receiver
22
1.1
10.8
17
xxxxxxS
30
PD30CNP
06NPM5T
10.6
R
Output LED
Yellow
Green
5.5 5.5
Output LED
Yellow
PD30CNP
06NPM5T
10-30 V
100 mA
BN: V+
UL
BU: VBK: OUT
WH: ET
6
6
Teach Button
Teach Button
Two M3
> 100 mm
Emitter
10.25
Installation Hints
To avoid interference from inductive voltage / Relief of the cable strain
current peaks, separate the proximity switch
cables from any other power cables. E.g.
Engine, contactor or solenoid cables
Protection of the sensing face
Sensor mounted on a mobile carrier
Incorrect
Incorrect
Incorrect
Correct
Correct
> 100 mm
The cable should not be pulled
A proximity switch should not serve
as mechanical stop
Any repetitive flexing of the
cable should be avoided
Delivery Contents
Accessories
• Photoelectric switch: PD 30 CND 10 ...
• Installation instruction
• Mounting bracket APD30-MB1
• Packaging: Cardboard box
• Mounting bracket APD30-MB1 or APD30-MB2 to be
purchased separately.
3
PD30CND10....DU
Teach functions
Normal operation, optimized switching point.
1. Line up the sensor at the background. Yellow LED is
OFF and Green LED is ON.
2. Press the button for 3 seconds until both LEDs
flashes simultaneously.
(The first switch point is stored)
3. Place the object in the detection zone.
4. Press the button once and the sensor is ready to
operate (Green LED ON, Yellow LED ON)
(The second switch point is stored)
1
2
3
3 sec.
4
For dynamic set-up (running process)
1. Line up the sensor at the object. Green LED is ON,
status on the yellow LED is not important.
2. Press the button for 3 second until both LEDs flashes
simultaneously.
3. Press the button a second time for at least one
second, both LED’s flashes fast simultaneously and
keep the button pressed for at least one process
cycle, release the button and the sensor is ready to
operate (The second switch point is stored)
1
2
3
Push once
3 sec.
For maximum sensing distance
(default setting)
3. Press the button a second time and the sensor is
ready to operate (Green LED ON, Yellow LED ON)
One cycle
For make or break set-up (N.O. or N.C.)
1. Press the button for 10 seconds, until the green LEDs
flashes.
2. While the green LED flashes, the output is inverted
each time the button is pressed. Yellow LED indicates
N.O. function selected.
If the button is not pressed within the next 10
seconds, the current output is stored.
1
2
1
2
3
10 sec.
3 sec.
Push once
For minimum detection overhead.
1. Line up the sensor at the object. Yellow LED is ON
ready to operate(Green LED ON, Yellow LED ON)
1
2
For dust output (N.O. or N.C.)
1. Press the button for 15 seconds, until the yellow LEDs
flashes.
2. While the yellow LED flashes, the dust output is
inverted each time the button is pressed. Green LED
indicates N.O. function selected.
1
4
2
3
15 sec.
3 sec.
Push once
Push once
Push once
很抱歉,暂时无法提供与“PD30CND10NPM5DU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+854.388011+110.65845
- 10+724.1432110+93.78943
