PD30CNT15
PD30CNT15
    CARLOGAVAZZI
    SENSOR THROUGH-BEAM 15M
PD30CNT15 数据手册
Photoelectrics Through-beam Type PD30CNT15....SA • Miniature sensor range • Range: 15 m • Sensitivity adjustment by potentiometer • Modulated, infrared light 850 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP preset • Make and break switching function • LED indication for output, stability and power ON • Protection: Short-circuit, reverse polarity and transients • Cable and plug versions • Excellent EMC performance Product Description Ordering Key The PD30CNT15 sensor family comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABS housing. The sensors are useful in applications where high-accuracy detection as well as small size is required. Compact housing and high power LED for excellent performance-size ratio. Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Sensitivity adjustment The potentiometer function for adjustment of the sensitivity makes the sensors highly flexible. The output type is preset (NPN or PNP), and the output switching function is NO and NC output. PD30CNT15NAM5SA Type Selection Housing Range Connection Ordering no. WxHxD Sn Emitter 10 x 30 x 20 mm 10 x 30 x 20 mm 15 m 15 m Cable Plug PD 30 CNT 15 PD 30 CNT 15 M5 Ordering no. NPN Make and break switching Ordering no. PNP Make and break switching PD 30 CNT 15 NASA PD 30 CNT 15 NAM5SA PD 30 CNT 15 PASA PD 30 CNT 15 PAM5SA Note: Emitter, receiver and connector to be ordered separately Specifications Receiver EN 60947-5-2 Rated operating distance (Sn) PD30CNT emitter ≤ 15 m Adjustment range 3 to 15 m Blind zone PD30CNT emitter None Sensitivity Electrical adjustment 210˚ Mechanical adjustment 240˚ Temperature drift ≤ 0.2%/ºC Hysteresis (H) 5% to 20% Rated operational volt. (UB ) 10 to 30 VDC (ripple included) Ripple (Urpp ) ≤ 10% Output current Continuous (Ie) ≤ 100 mA Short-time (I) ≤ 100 mA (max. load capacity 100 nF) No load supply current (Io) ≤ 20 mA @ UB max Minimum operational current (Im) ≤ 0.5 mA Specifications are subject to change without notice (13.06.2016) OFF-state current (Ir ) ≤ 100 µA Voltage drop (Ud ) ≤ 2 VDC @ Ie max Protection Short-circuit, reverse polarity and transients Ambient light ≤ 10,000 lux Operating frequency (f) ≤ 500 Hz Response time OFF-ON (tON) ≤ 1 ms ON-OFF (tOFF ) ≤ 1 ms Power ON delay (tv) ≤ 200 ms Output function Open collector NPN or PNP by sensor type Output switching function N.O. and N.C. Indication Output ON LED, yellow Signal stability ON and Power ON LED, green. See curve for condition of stability 1 PD30CNT15....SA Specifications Emitter Rated operational volt. (UB ) Ripple (Urpp ) No load supply current (Io) Light source Light type Emitter angle EN 60947-5-2 10 to 30 VDC (ripple included) ≤ 10% ≤ 25 mA @ UB max LED, 850 nm Infrared, modulated ± 2º @ half sensing distance General Specifications Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock Rated insulation voltage Light spot 110 mm @ 1.5 meters distance Power ON delay (tv) ≤ 200 ms Protection Reverse polarity and transients Indication Power ON LED, green EN 60947-5-2 III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) -25° to +60°C (-13° to +140°F) -40° to +70°C (-40° to +158°F) 10 to 150 Hz, 1.0 mm/15 G (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) ≤ 500 VAC (rms) Housing material Body ABS Light Grey Frontglas PMMA Red Trimmer shaft POM Dark Grey Connection Cable PVC, black, 2 m 4 x 0.14 mm2, Ø = 3.3 mm Plug M8, 4-pin (CON. 54-series) Weight Cable version ≤ 50 g Plug version ≤ 20 g CE-marking Yes Approvals cULus (UL508 + CSA) Operation Diagram Tv = Power ON delay Power supply ON OFF Break Output (N.C.) Present Not Present Tv ON OFF Make Output (N.O.) ON OFF Target Tv Signal Stability Indication Wiring Diagrams NPN Excess Gain 1.25 Operation level x 1.25 1.0 0.75 Operation level Operation level x 0.75 Time Green LED ON Yellow LED ON 1BN 2WH 4BK 3BU PNP 1BN 4BK 2WH 3BU 2 Specifications are subject to change without notice (13.06.2016) Emitter PD30CNT15....SA Y X Receiver Detection Diagram Excess Gain Emitter Y Distance (Inches) 6,0 9,0 12,0 15,0 18,0 21,0 24,0 19,7 (mm) 0,0 500 3,0 400 15,7 300 11,8 200 7,9 100 3,9 0 0,0 -100 -3,9 -200 -7,9 -300 -11,8 -400 -15,7 -500 -19,7 0 5 10 15 Distance (m) 20 25 Distance (Feet) 6,0 0,6 10.000 Excess Gain Receiver (Inches) X 60,0 10.000 1.000 1.000 100 100 10 10 1 0,20 1 20,00 2,00 Distance (m) Dimensions Plug version 10.6 20 20 10.6 Cable version Optical axis 10.8 17 Receiver or emitter R Optical axis Incorrect xxxxxxS Potentiometer One, 9.5 dia. Lense 15 30 Correct 15 22 30 25.4 xxxxxxS One, 9.5 dia. Lense 10.6 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET 7 Receiver or emitter PD30CNP 06NPM5T 25.4 17 R Potentiometer Power / Stability LED Green 5.5 5.5 10.8 1.1 10.6 7 10-30 V 100 mA BN: V+ UL BU: VBK: OUT WH: ET 5.5 5.5 1.1 PD30CNP 06NPM5T Output LED Yellow Power / Stability LED Green 22 Output LED Yellow Two M3 Two M3 > 100 mm 10.25 Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Accessories Delivery Contents • Mounting bracket APD30-MB1 or APD30-MB2 to be purchased separately. • Photoelectric switch: PD30CNT15 ... • Screwdriver (Receiver only) • Packaging: Plastic bag Specifications are subject to change without notice (13.06.2016) 3
PD30CNT15 价格&库存
很抱歉,暂时无法提供与“PD30CNT15”相匹配的价格&库存,您可以联系我们找货
PD30CNT15
  • 1+499.603881+62.51035
库存:4
PD30CNT15
  • 1+306.794711+38.38610
  • 5+286.203255+35.80970
  • 10+269.0437010+33.66270
库存:1
