Photoelectrics
Retro-reflective
Type PA18CLR30T, AC, PBTP housing
Ordering Key
Product Description
The PA18CLR.. is a family of
inexpensive general purpose
Retro-reflective sensors in
industrial standard 18 mm
cylindrical PBTP housing.
They are useful for simple
applications where a basic
Range: 3 m
Modulated infrared light
Supply voltage: 20 to 250 VAC
Output: 500 mA SCR
Make and break switching functions
LED output indication
High immunity to ambient light
Cable and plug versions
sensor provides adequate
sensing performance. The
sensors are simple to use
and no adjustment are necessary. The output is a 2wire NO or NC thyristor
(SCR) output.
PA18CLR30TOM6
Type
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
Connection type
Type Selection
Housing
diameter
Rated
operating
dist. (Sn)
Ordering no.
SCR/Cable
Make switching
Ordering no.
SCR/Plug
Make switching
Ordering no.
SCR/Cable
Break switching
Ordering no.
SCR/Plug
Break switching
M18
3m
PA18CLR30TO
PA18CLR30TOM6
PA18CLR30TC
PA18CLR30TCM6
Note: Plugs and reflectors to be ordered separately
Specifications
Rated operating dist. (Sn)
Temperature drift
Hysteresis (H)
(Differential travel)
Rated operational volt. (UB)
Output current (AC 12, AC 140)
Continuous (Ie)
Short-time (I)
Min. operational current (Im)
OFF-state current (Ir)
Voltage drop (Ud)
Protection
Transient voltage
Light source
Light type
Optical angle
Light spot size
Ambient light
Up to 3 m
Ref. reflector type ER4,
∅ 84 mm
0.4%/K
3 to 20%
20 to 250 VAC,
45 to 65 Hz
≤ 500 mA
≤ 3 A, max. 20 ms
10 mA
< 5 mA, typ. 2.6 mA
≤ 10 VAC, typ. 7 VAC
Transients
1 kV/0.5 J
GaAlAs LED, 880 nm
Infrared, modulated
± 2.2°
150 mm at 2 m
Max. 10,000 lux
Specifications are subject to change without notice (05.05.2008)
Operating frequency (f)
Response time
OFF-ON (tON)
ON-OFF (tOFF)
Power ON delay (tv)
Indication function
Output ON
Environment
Overvoltage category
Pollution degree
Degree of protection
Temperature
Operating
Storage
Vibration
Shock
Dielectric voltage
Max. 20 Hz, light/dark ratio 1:2
≤ 20 ms
≤ 30 ms
Typ. 100 ms
Dark (NC) or light (NO) switching
LED, yellow
III (IEC 60664/60664A; 60947-1)
3 (IEC 60664/60664A; 60947-1)
IP 67 (IEC 60529; 60947-1)
-20° to +60°C (-4° to 140°F)
-30° to + 70°C (-22° to 158°F)
10 to 150 Hz, 0.5 mm/7.5 g (IEC 60068-2-6)
2 x 1 m 100 x 0.5 m
(IEC 60068-2-32)
1600 V (IEC 60364-4-41)
1
PA18CLR30T
Specifications (cont.)
Housing material
Body
Dimensions
PBTP grey thermoplastic
polyester
Luran®, black
Polyester, black
Reinforced nylon
Front
Cable end
Nuts
Connection
Cable
Grey, 2 m, 2 x 0.5 mm2,
oilproof PVC
M12 x 1
CON.6A-.. serie
Plug
Cables for plug (M6)
Weight
Cable version
Plug version
Approvals
CE-marking
105 g
22 g
UL, CSA
Yes
M12 x 1
Operation Diagram
Power supply
Object present, light beam interrupted
Output ON: Break switching (NC)
Make switching (NO)
Wiring Diagrams
Tv
Tv
Detection Diagram
Sensor
2 BN
X
Y
ER4
Reflector
(feet)
1.6
3.3
4.9
6.6
8.2
9.8
11.5
13
60.0
0.8
30.0
0.4
-30.0
-0.4
-60.0
3 BU
2
(inch)
2 BN
(mm)
3 BU
-0.8
0.0
0.5
1.0
1.5
2.0
2.5
Distance (m)
3.0
3.5
4.0
PA18CLR30T
Installation Hints
To avoid interference from inductive voltage/
current peaks, separate the prox. switch power cables from any other power cables, e.g.
motor, contactor or solenoid cables
Relief of cable strain
Protection of the sensing face
Switch mounted on mobile carrier
A proximity switch should not serve as
mechanical stop
Any repetitive flexing of the
cable should be avoided
Incorrect
Correct
The cable should not be pulled
Delivery Contents
Accessories
• Photoelectric switch: PA18CLR30T.
• 2 nuts
• Packaging: plastic bag
Reflectors: ER series
Connector type CON.6A-.. serie
MB18A
APA18-RAR
For further information refer to "Accessories"
3
很抱歉,暂时无法提供与“PA18CLR30TO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1412.366571+182.79190
