VS1AN5C10
VS1AN5C10
    BANNER(邦纳)
    VS1 SERIES: INFRARED CONVERGENT
VS1AN5C10 数据手册
VS1 Series Sensors Datasheet Self-contained Miniature Sensors • • • • • • 10 V to 30 V dc operation Visible red or infrared sensing beam, depending on model 10 mm (0.4 in) or 15 mm (0.6 in) convergent point, depending on model NPN (sinking) or PNP (sourcing) output, and dark or light operate, depending on model 3-wire connection; output load capacity to 50 mA Choice of integral cable or quick-disconnect connector WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. 1. Power ON Indicator 2. Received Signal Indicator 3. 2 m Cable or 150 mm (6 inch) Quick-Disconnect Visible Red (860 nm) Beam Models Infrared (865 nm) Beam Models Focus CONVERGENT VISIBLE RED Output Type Cable1 CONVERGENT VS1AN5CV10 VS1AN5C10 NPN/LO VS1RN5CV10 VS1RN5C10 NPN/DO VS1AP5CV10 VS1AP5C10 VS1RP5CV10 VS1RP5C10 PNP/DO VS1AN5CV20 VS1AN5C20 NPN/LO VS1RN5CV20 VS1RN5C20 VS1AP5CV20 VS1AP5C20 VS1RP5CV20 VS1RP5C20 10 mm (0.4 in) 15 mm (0.6 in) PNP/LO 2 m (6.5 ft) NPN/DO PNP/LO PNP/DO Overview VS1 Series miniature self-contained sensors are designed for precision sensing in small areas previously accessible only to remote or fiber optic models. Typical applications include mounting inside vibrating feeders and electronic component handling equipment, where larger sensors will not fit. The sensing energy of a convergent-mode sensor is concentrated at the specified focus point. Convergent-mode sensors are less sensitive to background reflections, compared with diffuse-mode sensors. Contact the factory if background reflections are a problem. 1 • • To order 9 m cables models, add suffix “W/30” to the model number (e.g., VS1AN5CV10 W/30). To order 150 mm (6 inch) cable with threaded 3-pin Pico-style quick disconnect fitting models, add suffix “Q” to the model number (e.g., VS1AN5CV10Q). A model with a QD connector requires a mating cable; see Accessories on page 4. Original Document 56465 Rev. E 18 November 2016 56465 VS1 Series Sensors Installation Notes Included with each sensor is a hardware packet containing two stainless steel M2 × 0.4 × 16 mm Phillips pan-head machine screws, flat washers, lock washers, and hex nuts. To mount the sensor, use the supplied flat washer against the front surface of the sensor housing, between it and the screw head. If mounting to one of the optional brackets, place the lock washer against the back of the bracket, followed by the nut. If mounting directly to a threaded hole, place the lock washer between the screw head and the flat washer. For best results, mount the VS1 where it is protected from moisture, high humidity and dirt. 1. 2. 3. 4. Hex Nut (2) Lock Washer (2) Washer (2) M2 × 0.4 × 16 mm Phillips Pan-head Machine Screw (2) 1 2 3 4 Wiring Diagrams NPN Outputs 3 – 10-30 V dc + 1 4 PNP Outputs Load 1 + 10-30 V dc – 3 4 Key: 1 3 4 X = = = = Brown Blue Black Load Load NOTE: QD hookups are shown. Cabled hookups are functionally identical. 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 56465 Rev. E VS1 Series Sensors Specifications Supply Voltage and Current 10 V to 30 V dc (10% maximum ripple) at less than 25 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short circuit of outputs. Overload trip point ≥ 100 mA. Output Configuration SPST solid-state switch NPN (current sinking) or PNP (current sourcing), depending on model Light operate (N.O.) or dark operate (N.C.), depending on model Output Rating 50 mA maximum OFF-state leakage current: < 1 microamp at 24 V dc ON-state saturation voltage: < 0.25 V at 10 mA dc; < 0.5 V at 50 mA dc Indicators Green ON: sensor power ON Green flashing: output overload Amber ON: light is sensed Amber flashing: marginal excess gain (1 to 1.5 times) in light condition Construction Black ABS/polycarbonate housing with clear acrylic lens Environmental Rating IEC IP54; NEMA 3 Connections 2 m (6.5 ft) attached cable: three #28 ga stranded conductors with PE insulation; PVC outer cable jacket; or 150 mm (6 inch) cable with 3-pin Pico-style quick-disconnect fitting. QD cables are ordered separately. Operating Conditions −20 °C to +55 °C (−4 °F to +131°F) 80% at +50 °C maximum relative humidity (non-condensing) Application Notes M2 stainless steel mounting hardware included (see Installation Notes). Optional mounting brackets are available (see Accessories list). Output Response Time 1 millisecond ON and OFF Repeatability 250 microseconds Certifications Performance Curves Table 1: Visible Red Beam Models2 Excess Gain VS1...CV10 Beam Pattern 1000 E X C E S S G A I N VS1 Series Visible Red 10 mm Convergent Mode 100 VS1 Series Visible Red 3 mm 0.08" 1 mm 0.04" 0 10 0 1 mm 0.04" 2 mm 0.08" 3 mm 1 1 mm 0.04" 10 mm 0.4" 100 mm 4.0" 0.12" 0 1000 mm 40.0" 4 mm 0.16" 1000 E X C E S S G A I N VS1 Series Visible Red 20 mm Convergent Mode 100 8 mm 0.31" 12 mm 0.47" 16 mm 0.63" VS1 Series Visible Red 20 mm Convergent Mode 6 mm 0.24" 4 mm 0.16" 2 mm 0.08" 0 10 0 2 mm 0.08" 4 mm 0.16" 6 mm 1 1 mm 0.04" 10 mm 0.4" 100 mm 4.0" 1000 mm 40.0" DISTANCE 20 mm 0.79" DISTANCE DISTANCE VS1...CV20 0.12" 10 mm Convergent Mode 2 mm 0.24" 0 10 mm 0.4" 20 mm 0.80" 30 mm 1.20" 40 mm 1.60" 50 mm 2.00" DISTANCE 2 Performance based on 90% reflectance white card test P/N 56465 Rev. E www.bannerengineering.com - Tel: +1-763-544-3164 3 VS1 Series Sensors Table 2: Infrared Beam Models2 Excess Gain Beam Pattern 1000 VS1...C10 E X C E S S G A I N VS1 Series Infrared 10 mm Convergent Mode 100 3 mm 0.12" 2 mm 0.08" 1 mm 0.04" 0 1 mm 10 10 mm 0.4" 100 mm 4.0" 0.04" 10 mm Convergent Mode 2 mm 0.08" 3 mm 0.12" 0 1 1 mm 0.04" 0 VS1 Series Infrared 1000 mm 40" 4 mm 0.16" 8 mm 0.31" 12 mm 0.47" 16 mm 0.63" 20 mm 0.79" DISTANCE DISTANCE 1000 VS1...C20 E X C E S S G A I N VS1 Series Infrared 20 mm Convergent Mode 100 6 mm 0.24" 4 mm 0.16" 2 mm 0.08" VS1 Series Infrared 0 0 20 mm Convergent Mode 2 mm 10 0.08" 4 mm 0.16" 6 mm 1 1 mm 0.04" 10 mm 0.4" 100 mm 4.0" 0.24" 0 1000 mm 40" 10 mm 0.40" 20 mm 0.80" 30 mm 1.20" 40 mm 1.60" 50 mm 2.00" DISTANCE DISTANCE Dimensions 25.7 mm (1.01") 1 15 mm (0.59") 13.5 mm (0.53") 8.3 mm (0.33") 4.1 mm (0.16") 9.2 mm (0.36") 11.6 mm (0.46") Ø2.2 mm (0.09") 1. 150 mm (6 in) Cable Accessories 3-Pin Threaded M8/Pico-Style Cordsets Model Length PKG3M-2 2 m (6.56 ft) PKG3M-5 5 m (16.40 ft) PKG3M-7 7 m (22.97 ft) PKG3M-9 PKG3M-10 4 Style Dimensions Pinout (Female) 4 35 Typ. Straight 9 m (29.53 ft) ø 9.5 M8 x 1 10 m (32.81 ft) www.bannerengineering.com - Tel: +1-763-544-3164 1 3 1 = Brown 3 = Blue 4 = Black P/N 56465 Rev. E VS1 Series Sensors Brackets SMBVS1T • Tall right-angle bracket • Stainless steel 32 Hole center spacing: A = 16.8 Hole size: A = 3.5 x 12.3 A A Hole size: A = ø 2.8 10 9 22 SMBVS1S • Short right-angle bracket • 18-ga. stainless steel Hole size: A = 3.5 x 12.3 32 Hole center spacing: A = 5.5 25 Hole center spacing: A = 16.8 SMBVS1TC • Tall right-angle compact bracket • 300 stainless steel 12 SMBVS1SC • Short right-angle bracket • 18-ga. stainless steel Hole center spacing: A = 10.0 A 11 A Hole size: A = ø 2.8 25 22 19.5 9 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Copyright Notice Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved. © Banner Engineering Corp. All rights reserved
VS1AN5C10 价格&库存
很抱歉,暂时无法提供与“VS1AN5C10”相匹配的价格&库存,您可以联系我们找货
VS1AN5C10
  • 1+1148.834921+148.64560
库存:15
