GLV18-8-450/73/120
GLV18-8-450/73/120
    PEPPERL+FUCHS(倍加福)
    DIFFUSED PHT SEN 50-450MM 2XPNP
GLV18-8-450/73/120 数据手册
Diffuse mode sensor GLV18-8-450/73/120 < Efficient Line in a short M18 plastic housing for standard applications < Very high detection range < 4 LEDs indicator for 360° visibility < Optimized potentiometer design for a clear control button layout in the application < Version with front optical face < DC voltage version Diffuse mode sensor, M18 threaded housing design, plastic housing, front optical face, 450 mm detection range, red light, light/dark on, DC version, 2 PNP outputs, M12 plug Function The GLV/GLK18 series sensors help improve the efficiency of machines and systems. The design of the M18 plastic housing, the connection technology, and sensor properties are highly standardized. Concentrating on the key sensor requirements has produced a robust and reliable product series for DC and AC/DC voltage systems without any over-engineering. The mounting set included in the scope of delivery and the optimized potentiometer design ensure fast assembly and easy configuration. 15 M12 x 1 M18 x 1 7.8 Release date: 2020-11-06 Date of issue: 2020-11-06 Filename: 188567_eng.pdf 43.9 21.7 27.2 2.2 Dimensions 3.5 7 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Diffuse mode sensor GLV18-8-450/73/120 Technical Data General specifications Detection range 50 ... 450 mm adjustable Detection range max. 0 ... 450 mm Reference target 100 mm x 100 mm Kodak white Light source LED Light type modulated visible red light , 640 nm Diameter of the light spot approx. 30 mm at 400 mm Angle of divergence approx. 4 ° Optical face frontal Ambient light limit 30000 Lux Hysteresis H < 15 % Functional safety related parameters MTTFd 920 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Indicators/operating means Operation indicator LED green, statically lit Power on Function indicator LED yellow: lights when object is detected ; flashes when falling short of the stability control Control elements sensitivity adjustment Electrical specifications Operating voltage UB 10 ... 30 V DC No-load supply current I0 < 20 mA Output Switching type light/dark on Signal output 2 PNP, complementary, short-circuit protected, open collectors Switching voltage max. 30 V DC Switching current Voltage drop Switching frequency Response time max. 100 mA Ud f ≤ 1.5 V DC 500 Hz ≤ 1 ms Conformity Product standard EN 60947-5-2 Release date: 2020-11-06 Date of issue: 2020-11-06 Filename: 188567_eng.pdf Approvals and certificates EAC conformity TR CU 020/2011 Protection class II, Rated insulation voltage ≤ 50 V AC with pollution degree 1-2 according to IEC 60664-1 UL approval cULus Listed, Class 2 Power Source CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 60 °C (-13 ... 140 °F) Storage temperature -40 ... 70 °C (-40 ... 158 °F) Mechanical specifications Degree of protection IP67 Connection 4-pin, M12 x 1 connector Material Housing PC Optical face PMMA Connector plastic Mass approx. 10 g Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Diffuse mode sensor GLV18-8-450/73/120 Connection Assignment Option: /120 1 +UB 2 Q 3 0V 4 Q = Light on = Dark on Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Release date: 2020-11-06 Date of issue: 2020-11-06 Filename: 188567_eng.pdf Assembly 1 2 3 4 1 Operating display green 2 Signal display yellow 3 Sensitivity adjustment 4 Emitter 5 Receiver 2 1 5 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Diffuse mode sensor GLV18-8-450/73/120 Characteristic Curve Characteristic response curve GLV18-8-450... Offset Y [mm] 12 10 8 6 4 2 0 -2 -4 0 100 200 300 400 500 Distance X [mm] -y y x Relative received light strength Stability control 100 white 90 % grey 18 % black 6 % 10 1 0 0 100 200 300 400 x 500 600 Distance X [mm] Detection ranges Object colour black Release date: 2020-11-06 Date of issue: 2020-11-06 Filename: 188567_eng.pdf grey white 0 100 200 300 400 500 Detection range [mm] x Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4 Diffuse mode sensor GLV18-8-450/73/120 Application Accessories Mounting Bracket with swivel nut BF 18 Mounting flange, 18 mm BF 18-F Plastic mounting adapter, 18 mm BF 5-30 Universal mounting bracket for cylindrical sensors with a diameter of 5 ... 30 mm V1-G-2M-PUR Female cordset single-ended M12 straight A-coded, 4-pin, PUR cable grey V1-W-2M-PUR Female cordset single-ended M12 angled A-coded, 4-pin, PUR cable grey Release date: 2020-11-06 Date of issue: 2020-11-06 Filename: 188567_eng.pdf CPZ18B03 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 5 Diffuse mode sensor GLV18-8-450/73/120 Accessories Other suitable accessories can be found at www.pepperl-fuchs.com Application Release date: 2020-11-06 Date of issue: 2020-11-06 Filename: 188567_eng.pdf Packaging industry: • Presence checks, track loading, completeness checks, stack height control Material handling • Presence checks, target sensor, profile checks, trigger sensor Automatic doors, gates and access systems, elevator: • Secure detection for automatic door and gate systems • Monitoring function in turnstiles • Closing edge monitoring in elevators Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 6
GLV18-8-450/73/120 价格&库存
很抱歉,暂时无法提供与“GLV18-8-450/73/120”相匹配的价格&库存,您可以联系我们找货
