Ordering number : ENA0534
LV5044V
Bi-CMOS IC
2ch step-down circuit
DC-DC Converter Controller
http://onsemi.com
Overview
The LV5044V is a high efficiency, 2-channel, step-down, DC-DC converter controller IC adopting a synchronous
rectifying system. Incorporating numerous functions on a single chip with easy external setting, it can be used for a
wide variety of applications. The device is optimal for use in multi-output power supply systems which are used in
LCD-TVs, DVD recorders, game machines, high-end office products, etc.
Features
• Provides dual step-down DC-DC converter controller circuits integrated on the same chip.
• Provides an input UVLO circuit, an overcurrent detection function, an overtemperature detection function, soft
start/soft stop functions, and a startup delay circuit.
• Output voltage monitoring functions (power good as well as OVP and UVP with timer latch functions)
• 180° interleaved operation between phase 1 and phase 2 (supports multiphase drive in 2-phase parallel operation
mode).
• Supports synchronous operation between different devices (supports master/slave operation when multiple devices
are used).
Specifications
Absolute Maximum Ratings at Ta = 25°C
Parameter
Supply voltage
Peak output current
Allowable power dissipation
Symbol
Conditions
Ratings
Unit
VIN
18
IOUT
Pd max
*1
V
±1.0
A
1
W
Operating temperature
Topr
-20 to +85
°C
Storage temperature
Tstg
-55 to +150
°C
18
V
6.5
V
18
V
6.5
V
VLIN5+0.3
V
Allowable pin voltage *2
1
HDRV1,2
CBOOT1,2
2
HDRV1,2 ,CBOOT1,2
to SW
3
VIN,
ILIM1,2
RSNS1,2, SW1,2
PGOOD1,2
4
VLIN5
5
VDD, LDRV1,2
COMP1,2, FB1,2
SS1,2, UV_DELAY
TD1,2, CT
CLKO
*1 Board size: 114.3×76.1×1.6mm3, glass epoxy board.
*2 Allowable pin voltages are referenced to the SGND and PGND pins, excluding No.2. No.2 Voltages are referenced to the SW pin.
Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the Recommended Operating
Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may affect device reliability.
Semiconductor Components Industries, LLC, 2013
August, 2013
N2806 MS PC 20060927-S00009 No.A0534-1/7
LV5044V
Recommended Operating Conditions at Ta = 25°C
Parameter
Supply voltage
Symbol
Conditions
Ratings
Unit
VIN
VIN and VLIN open.
7.5 to 16
V
VIN
VIN and VLIN short.
4.5 to 6.0
V
Electrical Characteristics at Ta = 25°C, VIN = 12V
Parameter
Symbol
Conditions
Ratings
min
typ
Unit
max
System
Comparator reference voltage
VREF
Current drain 1
ICC1
TD1, TD2 = 5V (Excluding Ciss charge.)
Current drain 2
ICC2
TD1, TD2 = 0V
5V supply voltage
VLIN5
IVLIN5 = 0 to 10mA
Overcurrent detection comparator
VCLOS
0.818
0.826
0.834
2
4
6
mA
mA
0.3
0.6
1.2
4.75
5.00
5.25
-5
V
V
+5
mV
μA
offset
Overcurrent detection reference
ICL
VIN = 10 to 14V
7.47
8.30
9.13
-7.0
current
Soft start source current
ISSSC
TD1, TD2 = 5V
-1.8
-3.5
Soft start sink current
ISSSK
TD1, TD2 = 0V
0.2
1.0
Soft start clamp voltage
VSSTO
1.2
1.6
2.0
UV_DELAY source current
ISCUVD
UV_DELAY = 2V
-4.3
-8.6
-17.2
UV_DELAY sink current
ISKUVD
UV_DELAY = 2V
0.2
1.0
1.5
2.4
3.5
87
92
97
UV_DELAY threshold voltage
VUVD
UV_DELAY operating voltage
VUVD op
VUVP detection hysteresis
100% at VFB = VREF
ΔVUVP
Overvoltage detection
VOVP
Overvoltage detection delay time
VODLY
Output discharge transistor
VSWON
112
117
10
μA
V
122
μS
1.0
5
V
mA
2
100% at VFB = VREF
μA
mA
Ω
10
μA
on-resistance
Output Block
CBOOT leakage current
ICBOOT
HDRVx and LDRVX source current
ISCDRV
VCBOOT = VSW + 6.5V
1.0
A
HDRVx and LDRVX sink current
ISKDRV
1.0
A
HDRVx low side on-resistance
RHDRV
IOUT=500mA
1.5
2.5
LDRVx low side on-resistance
RLDRV
IOUT=500mA
1.5
2.5
Simultaneous on prevention
Tdead1
LDRV off → HDRV on
50
nS
Tdead2
HDRV off → LDRV on
120
nS
Ω
Ω
dead time 1
dead time 2
Continued on next page.
No.A0534-2/7
LV5044V
Continued from preceding page.
Ratings
Parameter
Symbol
Conditions
min
typ
Unit
max
Oscillator
Oscillator frequency
fOSC
CT = 130pF
280
330
kHz
1100
kHz
Oscillator frequency range
fOSC op
Maximum on duty
DON max
CT = 130pF
Minimum on time
TON min
CT = 130pF
100
VsawH
fOSC = 300kHz
2.2
2.6
Sawtooth wave low side voltage
VsawL
fOSC = 300kHz
1
1.2
On time difference between
ΔTdead
Sawtooth wave high side voltage
250
380
82
nS
V
V
5
channels 1 and 2
Error Amplifier
Error amplifier input current
IFB
-200
-100
200
nA
-100
-18
μA
700
900
μmho
1.5
2.0
2.5
dB
0.5
1.0
COMP pin source current
ICOMPSC
COMP pin sink current
ICOMPSK
18
100
gm
500
GISNS
Error amplifier gm
Current detection amplifier gain
μA
Logic Output
Sink current in the power good
IpwrgdL
VPGOOD = 0.4V
IpwrgdH
VPGOOD = 12V
mA
low state
Leakage current in the power good
μA
10
high state
TD pin threshold level
VONTD
When the TD pin is stepped up
1.5
2.4
3.5
V
VIN – VLIN5 open.
4.5
5.0
5.5
V
ITDSC
-1.8
-3.5
-7.0
μA
ITDSK
0.8
2
5
mA
TD pin open voltage
VTDH
TD pin source current during charge
TD pin sink current during discharge
CLKO high-level voltage
VCLKOH
ICLKO = 1mA
CLKO low-level voltage
VCLKOL
ICLKO = 1mA
0.7VLIN5
V
0.3VLIN5
V
4.3
V
Protection Functions
VIN UVLO release voltage
VUVLO
3.5
4.1
ΔVUVLO
UVLO hysteresis
0.2
V
Package Dimensions
unit : mm
3191B
Pd max -- Ta
9.75
0.5
5.6
7.6
16
30
1
15
0.65
0.15
0.22
1.5max
(1.3)
(0.33)
Allowable power dissipation, Pd max -- W
1.2
Specified Substrate (114.3×76.1×1.6mm3)
glass epoxy.
1.00
1.0
0.8
0.6
0.52
0.4
0.2
60
80
100
OMG0618
0.1
Ambient temperture, Ta -- °C
SANYO : SSOP30(275mil)
No.A0534-3/7
LV5044V
Pin Assignment
VDD
1
30
PGND
LDRV1
2
29
LDRV2
HDRV1
3
28
HDRV2
SW1
4
27
SW2
CBOOT1
5
26
CBOOT2
VLIN5
6
25
SGND
COMP1
7
24
COMP2
FB1
8
23
FB2
9
22
RSNS2
ILIM1 10
21
ILIM2
TD1 11
TD2
SS1 12
19
SS2
PGOOD1 13
18
PGOOD2
UV_DELAY 14
17
CT
VIN 15
16
CLKO
LV5044V
RSNS1
Top view
No.A0534-4/7
LV5044V
Block Diagram and Sample Application Circuit
No.A0534-5/7
LV5044V
Pin Functions
Pin No.
Pin
1
VDD
2
LDRV1
Function
Gate drive power supply for the external low side MOSFETs. Connect this pin to VLIN5 through a filter.
Channel 1 external low side MOSFET gate drive.
This pin is also used as the signal input for short through prevention for the high and low side MOSFETs.
HDRV cannot be turned on unless this pin's voltage goes below 1V.
3
HDRV1
4
SW1
Channel 1 external high side MOSFET gate drive.
This pin is connected to the channel 1 switching node.
The external high side MOSFET source and the low side MOSFET drain are connected to this pin.This pin becomes the
return current route of pin HDRV. The drain of the discharging MOSFET used for the soft stop function is connected
internal in the IC (typ.15Ω). This pin is also used as the signal input for short through prevention for the high and low side
MOSFETs. LDRV cannot be turned on unless this pin's voltage goes below 1V referenced to PGND.
5
CBOOT1
Channel 1 bootstrap capacitor connection.
The high side MOSFET gate drive power is supplied from this pin. This pin is connected to VDD through a diode and to
SW1 through the bootstrap capacitor.
6
VLIN5
Internal 5V regulator output.
The current is supplied from VIN. The power supply for the IC internal control circuits is also supplied from this pin. A
bypass capacitor (6.8μF) is required between this pin and SGND. This pin is monitored by the UVLO function and the IC
starts operating when it first rises above 4.0V. (After starting, the IC will only stop if this voltage falls below 3.8V.)
7
COMP1
Channel 1 phase compensation.
The output of the internal transconductance amplifier is connected to this pin. The external phase compensation circuit
8
FB1
Channel 1 feedback input.
The transconductance amplifier inverting (−) input is connected to this pin. Provide the feedback potential to this pin by
voltage dividing the output voltage. The converter operates so that this pin goes to the internal reference voltage VREF,
0.8V. This pin is also monitored by both the UVP comparator and the OVP comparator. If this pin voltage falls to under
87% of the set voltage, the PGOOD1 pin will go low and the UV_TIMER will operate. If this pin voltage rises to over 117%
of the set voltage, the IC will latch in the off state.
9
RSNS1
Input for the channel 1 side overcurrent detection comparator and current detection amplifier. When resistor detection is
used, connect the low side of the current detection resistor inserted between VIN and the drain of the external high side
MOSFET to this pin. These connections must be wired independently so that the shared impedance with the main current
with respect to the detected voltage does not affect this circuit.
10
ILIM1
Connection to the channel 1 overcurrent detection trip point.
A 8.3μA (ILIM) sink constant-current supply is connected internal in the IC, and the overcurrent detection voltage ILIM ×
RLIM is generated by connecting the resistor RLIM between this pin and VIN. The voltage between VIN and ILIM is
compared to the voltage across the terminals of either the current detection resistor RSNS or the high side MOSFET to
detect the overcurrent state.
11
TD1
Channel 1 startup delay connection.
The time until the IC starts up after the power-on reset (POR) is cleared is set by the capacitor connected between this pin
and SGND. After the POR state is cleared, the external capacitor is charged by a 3.5μA constant current supplied
internally by the IC. The IC starts operation when the voltage on this pin exceeds 2.4V. The IC goes to the standby state
when the voltage on this pin is under 2.4V. If no external capacitor is connected to this pin, the IC will start as soon as the
power-on reset is cleared.
12
SS1
Channel 1 soft start capacitor connection.
After the power-on reset (POR) is cleared and the TD pin voltage exceeds 2.4V, this capacitor is charged by a 3.5μA
internal constant current supply from the SS1 pin. This pin is connected to the transconductance amplifier's noninverting
(+) input, and the ramp waveform of the SS1 pin is reflected in the ramped-up output waveform. After the UV_DELAY time
out and the POR operates, this capacitor is discharged by the SS pin.
13
PGOOD1
Channel 1 power good pin.
An IC internal 28V MOSFET open drain is connected to this pin. This pin outputs a low level if the channel 1 output voltage
falls more than -13% relative to the set voltage. There is a hysteresis of about VREF × 1.5%.
14
UV_DELAY
Channel 1 and channel 2 common UVP delay connection.
The time until the IC switches off after the UVP state is detected is set by the capacitor connected between this pin and
SGND. If either the channel 1 or channel 2 output voltage falls under -80% of the set voltage, an IC internal 8.6μA
constant current source charges the external capacitor connected to this pin. When the voltage on this pin exceeds 2.4V,
the IC switches off. If no external capacitor is connected, the IC turns off immediately upon detection of the UVP state.
15
VIN
IC power supply.
16
CLKO
Clock output.
This pin outputs a clock signal synchronized with the CT pin oscillator waveform. When two or more LV5044V chips are
operated in synchronization, connect the CT pin of the slave device to the SLKO pin of the master device. If two or more
devices are operated in synchronization and the Td pin is used to change the startup timing between the devices, the
device that starts the soonest will be the master.
No.A0534-6/7
LV5044V
Pin No.
Pin
Function
17
CT
Connection for the oscillator circuit's external capacitor. Connect that capacitor between this pin and ground. When CT is
130pF, fOSC will be 330kHz. If an external clock is applied to this pin, the PWM control functions will operate at that clock
frequency. If an external clock is provided, that signal must be a square wave with a low level of 0V and a high level
between 3.3 and 5.0V. The square wave generator must have a fanout drive capacity of at least 1mA.and UV_DELAY
function doesn't operate when this pin is grounded.
18
PGOOD2
19
SS2
TD2
21
ILIM2
22
RSENS1
23
FB2
24
COMP2
25
SGND
Channel 2 power good pin.
Channel 2 soft start function capacitor connection.
Channel 2 startup delay connection.
Channel 2 overcurrent detection trip point setting.
Channel 2 overcurrent detection comparator input.
Channel 2 feedback input.
Channel 2 phase compensation.
IC system ground.
The reference voltage is generated referenced to this pin. The system ground must be connected to this pin.
26
CBOOT2
Channel 2 bootstrap capacitor connection.
27
SW2
28
HDRV2
This pin is connected to the channel 2 switching node.
Channel 2 external high side MOSFET gate drive.
29
LDRV2
Channel 2 external low side MOSFET gate drive.
30
PGND
Power system ground. This pin is used as the current return path for the LDRV pin.
ON Semiconductor and the ON logo are registered trademarks of Semiconductor Components Industries, LLC (SCILLC). SCILLC owns the rights to a number
of patents, trademarks, copyrights, trade secrets, and other intellectual property. A listing of SCILLC’s product/patent coverage may be accessed at
www.onsemi.com/site/pdf/Patent-Marking.pdf. SCILLC reserves the right to make changes without further notice to any products herein. SCILLC makes no
warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does SCILLC assume any liability arising out of the
application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental
damages. “Typical” parameters which may be provided in SCILLC data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical
experts. SCILLC does not convey any license under its patent rights nor the rights of others. SCILLC products are not designed, intended, or authorized for use
as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in
which the failure of the SCILLC product could create a situation where personal injury or death may occur. Should Buyer purchase or use SCILLC products for
any such unintended or unauthorized application, Buyer shall indemnify and hold SCILLC and its officers, employees, subsidiaries, affiliates, and distributors
harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or
death associated with such unintended or unauthorized use, even if such claim alleges that SCILLC was negligent regarding the design or manufacture of the
part. SCILLC is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner.
PS No.A0534-7/7
