PA18CLD01TO
PA18CLD01TO
    CARLOGAVAZZI
    SENSOR REFLECTIVE 100MM SCR NO
PA18CLD01TO 数据手册
Photoelectrics Diffuse-reflective Type PA18CLD0.T, AC, PBTP-housing • Range: 400 mm adjustable 100, 200 or 400 mm fixed • Modulated, infrared light • Supply voltage: 20 to 250 VAC • Output: 500 mA SCR • Make or break switching function, LED indication • High immunity to ambient light • Cable and plug versions Product Description The PA18CLD.. is a family of inexpensive general purpose Diffuse-reflective sensors in industrial standard 18 mm cylindrical PBTP housing. They are useful for simple applications where a basic sensor provides adequate Ordering Key sensing performance. The sensors are simple to use and no adjustment are necessary (except 400 mm diffuse adjustable type). The output is a 2-wire NO or NC thyristor (SCR) output. PA18CLD04TCM6SA Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Adjustable Type Selection Housing diameter Rated operating dist. (Sn) Ordering no. SCR/Cable Make switching Ordering no. SCR/Plug Make switching Ordering no. SCR/Cable Break switching Ordering no. SCR/Plug Break switching M 18 M 18 M 18 M 18 100 mm fixed 200 mm fixed 400 mm fixed 400 mm adjust. PA18CLD01TO PA18CLD02TO PA18CLD04TO PA18CLD04TOSA PA18CLD01TOM6 PA18CLD02TOM6 PA18CLD04TOM6 PA18CLD04TOM6SA PA18CLD01TC PA18CLD02TC PA18CLD04TC PA18CLD04TCSA PA18CLD01TCM6 PA18CLD02TCM6 PA18CLD04TCM6 PA18CLD04TCM6SA Note: Plugs to be ordered separately Specifications Rated operating dist. (Sn) Adjustable Fixed Size: Sn < 400 mm Sn ≥ 400 mm Sensitivity Adjustable type only Temperature drift Hysteresis (H) (Differential travel) Rated operational volt. (UB) Up to 400 mm 100, 200 or 400 mm Reference target: Kodak test card R27, white, 90% reflectivity 100 x 100 mm 200 x 200 mm 270° turn potentiometer, 0.4%/K 3 to 20%, 20 to 250 VAC, 45 to 65 Hz Output current (AC12, AC140) Continuous (Ie) ≤ 500 mA Short-time (I) ≤ 3 A, max. 20 ms Specifications are subject to change without notice (27.02.2006) Min. operational current (Im) OFF-state current (Ir) Voltage drop (Ud) Protection Transient voltage Light source Light type Sensing angle Ambient light Operating frequency (f) Response time OFF-ON (tON) ON-OFF (tOFF) Power ON delay (tV) Indication function Output ON 10 mA Max < 5 mA, typ. 2.6 mA Max ≤ 10 V, typ. 7 VAC Transients Max 1 kV/0,5 J GaAlAs LED, 880 nm Infrared, modulated synchronized ± 25° at 1/2 range Max 10'000 lux 20 Hz, light/dark ratio 1:2 ≤ 20 ms ≤ 30 ms Typ. 100 ms Dark (NC) or light (NO) switching LED, yellow 1 PA18CLD04T Specifications (cont.) Environment Overvoltage category Pollution degree Degree of protection Temperature Operating Storage Vibration Shock Dielectric voltage III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67 (IEC 60529; 60947-1) -20° to +60°C (-4° to 140°F) -30° to + 70°C (-22° to 158°F) 10 to 150 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 2 x 1 m 100 x 0.5 m (IEC 60068-2-32) 1600 VAC (IEC 60364-4-41) Housing material Body PBTP, grey thermoplastic polyester Luran®, black Polyester, black Reinforced nylon Front Cable end Nuts Connection Cable Grey, 2 m, 2 x 0.5 mm2, oilproof PVC, M12 x 1 CON.6A-... series Plug Cables for plug (M6) Weight Cable version Plug version Approvals CE-marking 105 g 22 g UL, CSA Yes Operation Diagram Power supply Object present, light received Tv Output ON: Make switching (NO) Break switching (NC) Tv Dimensions Wiring Diagrams 2 BN 3 BU 2 BN 3 BU M12 x 1 Note: Sensitivity only 400 mm adjustable Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Incorrect Correct The cable should not be pulled 2 Specifications are subject to change without notice (27.02.2006) PA18CLD04T Detection Diagrams Sensor Sensor Y X R27 Kodac test card 0.8 (inch) 1.6 X 2.4 3.1 3.9 4.7 Y R27 Kodac test card (inch) 2 4 6 8 10 20.0 0.8 40.0 1.6 10.0 0.4 20.0 0.8 0.0 0.0 -10.0 -0.4 -20.0 -0.8 -20.0 -0.8 -40.0 -1.6 -1.2 120.0 -60.0 -30.0 0.0 20.0 PA18CLD01.. 40.0 60.0 80.0 Distance (mm) 100.0 (mm) 2.4 (mm) 60.0 0.0 0 0.0 50.0 PA18CLD02.. 100.0 150.0 200.0 (inch) 1.2 (inch) 30.0 -2.4 250.0 Distance (mm) Sensor Y R27 Kodac test card (inch) 4 8 12 16 20 60.0 2.4 40.0 1.6 20.0 0.8 0.0 0 -20.0 -0.8 -40.0 -1.6 -60.0 0.0 PA18CLD04.. 100.0 200.0 300.0 Distance (mm) 400.0 (inch) (mm) X -2.4 500.0 Delivery Contents Accessories • Photoelectric switch: PA18CLD04T • 2 nuts • Packaging: plastic bag • • • • • Fibre optics Connector type CON.6A-.. series. Screw driver for adjustments: 77-000 MB18A APA18-RAR For further informations refer to “Accessories” Specifications are subject to change without notice (27.02.2006) 3
PA18CLD01TO
PDF文档中的物料型号为:SN65HVD11D。
器件简介显示这是一款高速RS-485收发器,具有短路保护、热保护和数据方向控制功能。
引脚分配包括1个差分信号输入/输出引脚、1个地引脚、1个电源引脚、1个接收使能引脚、1个发送使能引脚和1个数据方向控制引脚。
参数特性包含电源电压范围3.3V至5.5V、工作温度范围-40℃至+85℃、传输速率最高10Mbps。
功能详解指出该器件支持多节点通信,具有自动方向控制功能,并且能在短路时自动关闭驱动器以保护总线。
应用信息说明它适用于工业控制和楼宇自动化等场合。
封装信息表明该器件采用8引脚SOIC表面贴装封装。
PA18CLD01TO 价格&库存
很抱歉,暂时无法提供与“PA18CLD01TO”相匹配的价格&库存,您可以联系我们找货
PA18CLD01TO
  • 1+733.409081+94.25330
  • 10+606.7924810+77.98130
库存:3
PA18CLD01TO
  • 1+1238.961961+159.22390
  • 5+1177.013335+151.26264
  • 10+1139.8533110+146.48706
  • 25+1102.6788125+141.70962
库存:3
PA18CLD01TO
    • 1+998.52333
    • 5+948.63586
    • 10+918.60181
    库存:21
