PD86CNP12QPMU
PD86CNP12QPMU
    CARLOGAVAZZI
    SENSOR RETROREFLECTIVE 12M SPST
PD86CNP12QPMU 数据手册
Photoelectrics Retro-reflective, Industrial Door Market Type PD86, Polarized, Relay Output, Mute Input • Range: 12 m @ ER 4 (15 m @ ER100) • Modulated, visible light, polarized • Make or break switching function, selectable by DIP-switch • Active high or active low mute function (switch selectable) • LED-indication for target detected and power • Multi supply voltage: 12-24 VDC/VAC, 50/60 Hz • 86 x 44 x 39 mm reinforced PC/ABS-housing, IP 66 • SPST relay output • High EMC and ambient light immunity • CE, UL325 and UL508 approved UL325 Product Description Ordering Key The PD86 is a powerfull polarized retro reflective sensor. The sensor is designed to meet the harsh requirements in industrial door and gate environments. With a sensing distance of 12 m, the sensor is useful in applications where dust and weather conditions will influence on the sensing distance. The sensor is made of a strong glass reinforced PC housing. With the mute input, the sensor fulfills European and North American regulations for industrial doors. Type Housing style Housing size Housing material Not used Detection principle Sensing distance Supply voltage Output Function Mute function Housing WxHxD Range (Sn) Ordering no. 86 x 44 x 39 mm 12 m PD86CNP12QPMU UL508 PD86CNP12QPMU Type Selection Specifications Rated operating dist. (Sn) Blind zone Sensitivity Temperature drift Differential travel (H) Hysteresis Rated operational volt. (UB) AC: 45 to 65 Hz Rated operational power (Relay ON) 12 VAC 24 VAC 12 VDC 24 VDC Output Contact ratings (AgCdO) Resistive loads AC 1 DC 1 Small inductive loads AC 15 DC 13 Mechanical life (typical) Electrical life (typical) Minimum load power 12 m @ ER4 ref. target (0 to 5,000 lux) ≤ 0.15 m Fixed ≤ 0.6 %/°C 3 to 20% 12-24 VDC, - 15% +20% 12-24 VAC, - 15% +20% 648 mW 1680 mW 324 mW 840 mW µ (micro gap) 0.5 A/30 VAC 1 A/30 VDC 0.5 A/50 VAC 1 A/30 VDC ≥ 1,000 000 cycles > 100,000 AC11 or DC11 1,800 operations per hour 1 mW Specifications are subject to change without notice (19.01.2012) Dielectric voltage Light source Light type Optical angle Light spot size Ambient light Operating frequency Response time (object related) OFF-ON (tON) ON-OFF (tOFF) Power ON delay (tv) DIP-switch Selectable functions Mute input Relay output Mute function Active high Response time Hold time Active low Response time Hold time Max current 1,000 VAC (rms) (cont./supply) GaAlAs, LED, 660 nm Visible, modulated ± 1.5° 280 mm at 4 m Max. 5,000 lux 20 Hz ≤ 20 ms ≤ 30 ms ≤ 300 ms (typ. 100 ms) active high or active low NO (make) or NC (break) ≥ 12 VDC/VAC < 45 ms < 70 ms < 6 VDC/VAC < 70 ms < 45 ms 35 mA @ 24 VDC 70 mA @ 24 VAC 1 PD86 Specifications (cont.) Indication Target detected Power Signal Environment Overvoltage category LED, yellow LED, green LED, green III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 66 (IEC 60529; 60947-1) Pollution degree Degree of protection Temperature Operating Storage Vibration -25° to +60°C (-76° to +140°F) -35° to +80°C (-31° to +176°F) 10 to 150 Hz, 0.5 mm/7.5 g (IEC 60068-2-6) 2 x 1 m & 100 x 0.5 m (IEC 60068-2-32) Shock Rated insulation voltage Housing material Outer cover Inner cover Backpart Cable outlet Connection Screw terminal One entry Weight UL-Approval CE-marking 250 VAC (rms) PC, grey PMMA, red ABS, black Kraiburg TC5MLZ or TP5VCZ 6 x 1.5 mm2 terminal block for cable 3 to 6.5 mm 110 g UL325, UL508 Yes EN12453, EN12445, EN12978 Wiring Diagram Green LED Power ON and signal stability Yellow LED Operation indicator Receiver 1 2 ON Emitter Dipswitches NC Active high 1 2 NO Active low 6 5 4 3 2 1 Wiring 1-2: Mute input 3-4: Output relay 5-6: AC/DC power supply Operation Diagram tv = Power ON delay Power supply Target present Object present Mute (Active high) Mute (Active low) Output NO Output NC 2 tv Mute function active tv Specifications are subject to change without notice (19.01.2012) PD86 Detection Diagram Excess Gain (inch) 0,0 6,6 13,2 19,8 (inch) 26,4 33,0 39,6 46,2 52,8 0,0 5,9 150 6,6 13,2 19,8 26,4 33,0 39,6 46,2 52,8 2 4 6 8 10 12 14 16 50 2,0 0,0 0 -50 -2,0 -100 -3,9 -150 -5,9 (inch) 3,9 (mm) 100 Excess Gain 1.000 100 10 1 0,0 2,0 4,0 6,0 8,0 10,0 12,0 14,0 0 16,0 Distance (m) Distance (m) LED 100% Safe level Hysteresis level Treshold Hysteresis level Safe level na Sig 0% l ve l le Hysteresis Hysteresis Time Yellow LED Green LED Dimensions 44 86 68,5 7,5 7,5 39 27 Specifications are subject to change without notice (19.01.2012) 3 PD86 Delivery Contents Accessories • • • • • Reflectors: ER series Photoelectric switch: PD86CNP12QPMU Screws and rawlplugs Installation instruction Packaging: Cardboard box Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled 4 A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Specifications are subject to change without notice (19.01.2012)
PD86CNP12QPMU 价格&库存
很抱歉,暂时无法提供与“PD86CNP12QPMU”相匹配的价格&库存,您可以联系我们找货
PD86CNP12QPMU
    • 1+770.89471
    库存:2
    PD86CNP12QPMU
    • 1+1065.399721+137.82572
    • 5+1012.139345+130.93568
    • 10+980.1722310+126.80024
    • 25+948.2132225+122.66586
    库存:5
